• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Trying to parse a word doc...
New Here ,
Jul 14, 2006 Jul 14, 2006
I have an application that uses CFPOP to pull email and attachments from a vendor. The attachments are all word doc files that have the same name. I am trying to "read" the doc file for certain information and then rename the file based on this info and then re-attach the file and CFMAIL it to a different user...
Where I am having the problem is reading the word doc. Is it possible to parse a doc file for content without converting it or displaying it?
TOPICS
Advanced techniques
Views
280
Translate
Translate
Report
Report
Community guidelines
community guidelines
Contributor ,
The only way I can think of without using XML is to create a custom tag (written in C++ or Java) that parses the word document and passes the text as a variable back to you. A good example of a parser written in C++ can be found at:
http://www.codeproject.com/com/MSWACPP.asp
You should just have to adjust the code so it works with Coldfusion (Probably use a CFAPI DLL in this case).
Actually, you could perform the majority (if not all) of what you want to do right in the custom tag.
Good luck.
Votes
Translate
Translate
Report
Report
Participant ,
LATEST
I have added some code on my site that shows how to read a doc file using coldFusion.
I hope this helps you.
T
www.burnette.us
Votes
Translate
Translate
Report
Report
Resources
Documentation
