2 Replies Latest reply on Dec 1, 2012 9:23 AM by p0ckets904
    How do I fix this error? "Could not complete your request because DynamicLink is not available?
    p0ckets904 Level 1
      I am trying to open a video to edit in CS6 and I get this error: Could not complete your request because DynamicLink is not available
      I read on one of these formus that I should uninstall and reinstall the program.
      I tried to uninstall the program and it told me to use the Adobe Application Manager.
      Adobe Application Manager failed and it told me to download the Adobe Support Advisor.
      Adobe Support Advisor told me that there was an issue:" cpsid_82829s1: "A restart is pending," bootstrapper error has occurred. "Token Number: 40-87772-063201122012
      I followed the instructions it gave me to correct this issue:
      If you receive the error "Installer has detected that a machine restart is pending. It is recommended that you quit the installer, restart try again," do the following:
          Restart the computer and try the installation again.
          If the installation fails, delete the InProgress registry key:
      Disclaimer: This procedure involves editing the Windows registry. Adobe doesn't provide support for editing the registry, which contains critical system and application information. Make sure to back up the registry before editing it. For more information about the registry, see Windows registry information for advanced users on the Microsoft support site, or contact Microsoft.
      1. Launch Windows Registry Editor.
        • (Windows XP) Choose Start > Run, type regedit in the Open text box and click OK.
        • (Windows Vista/ Windows 7) Choose Start, type regedit in the Search box, and press Enter.
      2. Navigate to HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Session Manager.
      3. Delete the InProgress key.
      I was not able to find the "InProgress" key.
      I just want to be able to edit video using my CS6!!! Please help!
      My system info:
      Adobe Photoshop Version: 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00) x32
      Operating System: Windows 7 64-bit
      Version: 6.1
      System architecture: Intel CPU Family:6, Model:14, Stepping:5 with MMX, SSE Integer, SSE FP, SSE2, SSE3, SSE4.1, SSE4.2, HyperThreading
      Physical processor count: 4
      Logical processor count: 8
      Processor speed: 1729 MHz
      Built-in memory: 4027 MB
      Free memory: 1810 MB
      Memory available to Photoshop: 3255 MB
      Memory used by Photoshop: 60 %
      Image tile size: 128K
      Image cache levels: 4
      OpenGL Drawing: Enabled.
      OpenGL Drawing Mode: Advanced
      OpenGL Allow Normal Mode: True.
      OpenGL Allow Advanced Mode: True.
      OpenGL Allow Old GPUs: Not Detected.
      Video Card Vendor: NVIDIA Corporation
      Video Card Renderer: GeForce GT 330M/PCI/SSE2
      Display: 1
      Display Bounds:=  top: 0, left: 0, bottom: 768, right: 1366
      Video Card Number: 1
      Video Card: NVIDIA GeForce GT 330M
      OpenCL Unavailable
      Driver Version: 8.16.11.8988
      Driver Date: 20100505000000.000000-000
      Video Card Driver: nvd3dumx.dll,nvwgf2umx.dll,nvwgf2umx.dll,nvd3dum,nvwgf2um,nvwgf2um
      Video Mode: 1366 x 768 x 4294967296 colors
      Video Card Caption: NVIDIA GeForce GT 330M
      Video Card Memory: 1024 MB
      Video Rect Texture Size: 8192
      Serial number: 91190138603683837940
      Application folder: C:\Program Files (x86)\Adobe\Adobe Photoshop CS6\
      Temporary file path: C:\Users\Ainge\AppData\Local\Temp\
      Photoshop scratch has async I/O enabled
      Scratch volume(s):
        Startup, 452.7G, 265.3G free
      Required Plug-ins folder: C:\Program Files (x86)\Adobe\Adobe Photoshop CS6\Required\
      Primary Plug-ins folder: C:\Program Files (x86)\Adobe\Adobe Photoshop CS6\Plug-ins\
      Additional Plug-ins folder: not set
      Installed components:
         A3DLIBS.dll   A3DLIB Dynamic Link Library   9.2.0.112
         ACE.dll   ACE 2012/01/18-15:07:40   66.492997   66.492997
         adbeape.dll   Adobe APE 2012/01/25-10:04:55   66.1025012   66.1025012
         AdobeLinguistic.dll   Adobe Linguisitc Library   6.0.0
         AdobeOwl.dll   Adobe Owl 2012/02/09-16:00:02   4.0.93   66.496052
         AdobePDFL.dll   PDFL 2011/12/12-16:12:37   66.419471   66.419471
         AdobePIP.dll   Adobe Product Improvement Program   6.0.0.1654
         AdobeXMP.dll   Adobe XMP Core 2012/02/06-14:56:27   66.145661   66.145661
         AdobeXMPFiles.dll   Adobe XMP Files 2012/02/06-14:56:27   66.145661   66.145661
         AdobeXMPScript.dll   Adobe XMP Script 2012/02/06-14:56:27   66.145661   66.145661
         adobe_caps.dll   Adobe CAPS   6,0,29,0
         AGM.dll   AGM 2012/01/18-15:07:40   66.492997   66.492997
         ahclient.dll    AdobeHelp Dynamic Link Library   1,7,0,56
         aif_core.dll   AIF   3.0   62.490293
         aif_ocl.dll   AIF   3.0   62.490293
         aif_ogl.dll   AIF   3.0   62.490293
         amtlib.dll   AMTLib   6.0.0.75 (BuildVersion: 6.0; BuildDate: Mon Jan 16 2012 18:00:00)   1.000000
         ARE.dll   ARE 2012/01/18-15:07:40   66.492997   66.492997
         AXE8SharedExpat.dll   AXE8SharedExpat 2011/12/16-15:10:49   66.26830   66.26830
         AXEDOMCore.dll   AXEDOMCore 2011/12/16-15:10:49   66.26830   66.26830
         Bib.dll   BIB 2012/01/18-15:07:40   66.492997   66.492997
         BIBUtils.dll   BIBUtils 2012/01/18-15:07:40   66.492997   66.492997
         boost_date_time.dll   DVA Product   6.0.0
         boost_signals.dll   DVA Product   6.0.0
         boost_system.dll   DVA Product   6.0.0
         boost_threads.dll   DVA Product   6.0.0
         cg.dll   NVIDIA Cg Runtime   3.0.00007
         cgGL.dll   NVIDIA Cg Runtime   3.0.00007
         CIT.dll   Adobe CIT   2.0.5.19287   2.0.5.19287
         CoolType.dll   CoolType 2012/01/18-15:07:40   66.492997   66.492997
         data_flow.dll   AIF   3.0   62.490293
         dvaaudiodevice.dll   DVA Product   6.0.0
         dvacore.dll   DVA Product   6.0.0
         dvamarshal.dll   DVA Product   6.0.0
         dvamediatypes.dll   DVA Product   6.0.0
         dvaplayer.dll   DVA Product   6.0.0
         dvatransport.dll   DVA Product   6.0.0
         dvaunittesting.dll   DVA Product   6.0.0
         dynamiclink.dll   DVA Product   6.0.0
         ExtendScript.dll   ExtendScript 2011/12/14-15:08:46   66.490082   66.490082
         FileInfo.dll   Adobe XMP FileInfo 2012/01/17-15:11:19   66.145433   66.145433
         filter_graph.dll   AIF   3.0   62.490293
         hydra_filters.dll   AIF   3.0   62.490293
         icucnv40.dll   International Components for Unicode 2011/11/15-16:30:22    Build gtlib_3.0.16615
         icudt40.dll   International Components for Unicode 2011/11/15-16:30:22    Build gtlib_3.0.16615
         image_compiler.dll   AIF   3.0   62.490293
         image_flow.dll   AIF   3.0   62.490293
         image_runtime.dll   AIF   3.0   62.490293
         JP2KLib.dll   JP2KLib 2011/12/12-16:12:37   66.236923   66.236923
         libeay32.dll   The OpenSSL Toolkit   0.9.8g
         libifcoremd.dll   Intel(r) Visual Fortran Compiler   10.0 (Update A)
         libmmd.dll   Intel(r) C Compiler, Intel(r) C++ Compiler, Intel(r) Fortran Compiler   10.0
         LogSession.dll   LogSession   2.1.2.1640
         mediacoreif.dll   DVA Product   6.0.0
         MPS.dll   MPS 2012/02/03-10:33:13   66.495174   66.495174
         msvcm80.dll   Microsoft® Visual Studio® 2005   8.00.50727.6195
         msvcm90.dll   Microsoft® Visual Studio® 2008   9.00.30729.1
         msvcp100.dll   Microsoft® Visual Studio® 2010   10.00.40219.1
         msvcp71.dll   Microsoft® Visual Studio .NET   7.10.3077.0
         msvcp80.dll   Microsoft® Visual Studio® 2005   8.00.50727.6195
         msvcp90.dll   Microsoft® Visual Studio® 2008   9.00.30729.1
         msvcr100.dll   Microsoft® Visual Studio® 2010   10.00.40219.1
         msvcr71.dll   Microsoft® Visual Studio .NET   7.10.3052.4
         msvcr80.dll   Microsoft® Visual Studio® 2005   8.00.50727.6195
         msvcr90.dll   Microsoft® Visual Studio® 2008   9.00.30729.1
         pdfsettings.dll   Adobe PDFSettings   1.04
         Photoshop.dll   Adobe Photoshop CS6   CS6
         Plugin.dll   Adobe Photoshop CS6   CS6
         PlugPlug.dll   Adobe(R) CSXS PlugPlug Standard Dll (32 bit)   3.0.0.383
         PSArt.dll   Adobe Photoshop CS6   CS6
         PSViews.dll   Adobe Photoshop CS6   CS6
         SCCore.dll   ScCore 2011/12/14-15:08:46   66.490082   66.490082
         ScriptUIFlex.dll   ScriptUIFlex 2011/12/14-15:08:46   66.490082   66.490082
         shfolder.dll   Microsoft(R) Windows (R) 2000 Operating System   5.50.4027.300
         ssleay32.dll   The OpenSSL Toolkit   0.9.8g
         tbb.dll   Intel(R) Threading Building Blocks for Windows   3, 0, 2010, 0406
         tbbmalloc.dll   Intel(R) Threading Building Blocks for Windows   3, 0, 2010, 0406
         TfFontMgr.dll   FontMgr   9.3.0.113
         TfKernel.dll   Kernel   9.3.0.113
         TFKGEOM.dll   Kernel Geom   9.3.0.113
         TFUGEOM.dll   Adobe, UGeom©   9.3.0.113
         updaternotifications.dll   Adobe Updater Notifications Library   6.0.0.24 (BuildVersion: 1.0; BuildDate: BUILDDATETIME)   6.0.0.24
         WRServices.dll   WRServices Friday January 27 2012 13:22:12   Build 0.17112   0.17112
         wu3d.dll   U3D Writer   9.3.0.113
      Required plug-ins:
         Accented Edges 13.0
         Adaptive Wide Angle 13.0
         ADM 3.11x01
         Angled Strokes 13.0
         Average 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
         Bas Relief 13.0
         BMP 13.0
         Camera Raw 7.1
         Chalk & Charcoal 13.0
         Charcoal 13.0
         Chrome 13.0
         Cineon 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
         Clouds 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
         Collada 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
         Color Halftone 13.0
         Colored Pencil 13.0
         CompuServe GIF 13.0
         Conté Crayon 13.0
         Craquelure 13.0
         Crop and Straighten Photos 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
         Crop and Straighten Photos Filter 13.0
         Crosshatch 13.0
         Crystallize 13.0
         Cutout 13.0
         Dark Strokes 13.0
         De-Interlace 13.0
         Difference Clouds 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
         Diffuse Glow 13.0
         Displace 13.0
         Dry Brush 13.0
         Eazel Acquire 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
         Embed Watermark 4.0
         Extrude 13.0
         FastCore Routines 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
         Fibers 13.0
         Film Grain 13.0
         Filter Gallery 13.0
         Fresco 13.0
         Glass 13.0
         Glowing Edges 13.0
         Grain 13.0
         Graphic Pen 13.0
         Halftone Pattern 13.0
         HDRMergeUI 13.0
         IFF Format 13.0
         Ink Outlines 13.0
         JPEG 2000 13.0
         Lens Blur 13.0
         Lens Correction 13.0
         Lens Flare 13.0
         Liquify 13.0
         Matlab Operation 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
         Measurement Core 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
         Mezzotint 13.0
         MMXCore Routines 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
         Mosaic Tiles 13.0
         Multiprocessor Support 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
         Neon Glow 13.0
         Note Paper 13.0
         NTSC Colors 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
         Ocean Ripple 13.0
         Oil Paint 13.0
         OpenEXR 13.0
         Paint Daubs 13.0
         Palette Knife 13.0
         Patchwork 13.0
         Paths to Illustrator 13.0
         PCX 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
         Photocopy 13.0
         Photoshop 3D Engine 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
         Picture Package Filter 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
         Pinch 13.0
         Pixar 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
         Plaster 13.0
         Plastic Wrap 13.0
         PNG 13.0
         Pointillize 13.0
         Polar Coordinates 13.0
         Portable Bit Map 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
         Poster Edges 13.0
         Radial Blur 13.0
         Radiance 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
         Read Watermark 4.0
         Reticulation 13.0
         Ripple 13.0
         Rough Pastels 13.0
         Save for Web 13.0
         ScriptingSupport 13.0
         Shear 13.0
         Smart Blur 13.0
         Smudge Stick 13.0
         Solarize 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
         Spatter 13.0
         Spherize 13.0
         Sponge 13.0
         Sprayed Strokes 13.0
         Stained Glass 13.0
         Stamp 13.0
         Sumi-e 13.0
         Targa 13.0
         Texturizer 13.0
         Tiles 13.0
         Torn Edges 13.0
         Twirl 13.0
         Underpainting 13.0
         Vanishing Point 13.0
         Variations 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
         Water Paper 13.0
         Watercolor 13.0
         Wave 13.0
         WIA Support 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
         Wind 13.0
         Wireless Bitmap 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
         ZigZag 13.0
      Optional and third party plug-ins: NONE
      Plug-ins that failed to load: NONE
      Flash:
         Mini Bridge
         Kuler
      Installed TWAIN devices: NONE
        • 1. Re: How do I fix this error? "Could not complete your request because DynamicLink is not available?
          Noel Carboni Level 8
          The first thing anyone is going to advise you, since you're running 13.0, is to update to 13.0.1.
          Go into Photoshop and choose Help - Updates.
          -Noel
          • 2. Re: How do I fix this error? "Could not complete your request because DynamicLink is not available?
            p0ckets904 Level 1
            I tried to update and it keeps telling me to get the Application Manager. And this is what happens
              • #If the installation fails, delete the InProgress registry key:
