0 Replies Latest reply on Jul 13, 2006 7:14 AM by thellers_rem
    Flash/Director LocalConnection - AllowDomain
      I am using the LocalConnection object to communicate between a Flash MX2004 SWF and a Director MX2004 movie (running in the Authoring environment). I need the two to communicate across different domains but, although I have followed the documentation, this does not appear to work!
      My Director movie WILL execute the called handler when the calling SWF is run locally, but NOT when it is run on the web.
      The documentation says that in order to allow the sending LocalConnection to talk cross-domain to the receiving LocalConnection I need to do the following:
      1) Make sure both connections are connected with names starting with an underscore... CHECK. My LCs are connected as "_SourceLC" and "_DestLC"
      2) Make sure that the allowDomain functions for both LCs are set to return true for the required domains... CHECK. My LCs' allowDomain functions both simply return true
      When running cross-domain, when I call the desination LC (_DestLC) from the source LC (_SourceLC), it gets as far as the allowDomain function, but does NOT execute the required function. However, when both are run on the same domain, the allowDomain function is executed followed by the required function being successfully executed.
      Can anyone help? Am I missing something, or is the documentation wrong?
