4 Replies Latest reply on Dec 3, 2012 8:36 AM by Todeka
    Frames
    community help Level 1
      This question was posted in response to the following article: http://help.adobe.com/en_US/robohelp/robohtml/WS5b3ccc516d4fbf351e63e3d11aff59c8c5-7fd9.ht ml
        • 1. Re:  Frames
          Todeka
          DHTML effects (e.g. dropdown hotspot) do not appear to work within framesets. Is there a solution?
          • 2. Re:  Frames
            Hi there
            I think we need more information to go on here. DHTML certainly *DOES* work in frames because it works in WebHelp and FlashHelp outputs. Those outputs are presented using frames.
            So we need more information in order to help. Which specific DHTML effect are you attempting to use? How are you seeing it fail?
            Cheers... Rick
            • 3. Re:  Frames
              Todeka Level 1
              Hi Rick,
              I have used the new frameset function to create two frames: top one fixed, bottom one scrolling. I have put a topic into each frame. Each topic works fine standalone (that is the dropdown text and twisties function). When used in the frames, the dropdown is permanent dropped and there is no twistie. The text only popup works fine.
              HTML of Frameset
              Test Procedure
              <ul>                 <li class="P-Note"><p class="Note">Use a <a class="popupspot" href="JavaScript:hhctrl.TextPopup('Part number','arial,11',10,10,0xa53800,0xffffff)">Scotchbright<?rh-symbol_start                  name="Trademark" ?>™<?rh-symbol_end ?></a> or equivalent flap wheel                  in a power drill. </p></li> </ul> <?rh-list_start class="MainStep" level="1" style="list-style: rh-list;        list-style: rh-list;" ?><p class="MainStep">Protect all exposed openings..</p><?rh-list_end ?> <?rh-list_start class="MainStep" level="1" style="list-style: rh-list;        list-style: rh-list;" ?><p class="MainStep">Clean the inner bore surface..</p><?rh-list_end ?> <?rh-list_start class="MainStep" level="1" style="list-style: rh-list;        list-style: rh-list;" ?><p class="MainStep"><?rh-dropspot_start                  class="dropspot" href="javascript:TextPopup(this)" id="a1" dataid="POPUP578350426" ?>Clean the block<?rh-dropspot_end ?> </p> <?rh-droptext_start class="droptext" id="POPUP578350426" style="display: none;" ?>                 <?rh-list_start class="MainStep" level="2" style="list-style: rh-list;        list-style: rh-list;" ?><p class="SubStep">Clean the                  surface of the block.</p><?rh-list_end ?>                 <?rh-list_start class="MainStep" level="2" style="list-style: rh-list;        list-style: rh-list;" ?><p class="SubStep">Clean the                  cylinder head studs with a wire brush and brake cleaner.</p><?rh-list_end ?>                 <p class="MainStep">x</p><?rh-droptext_end ?><?rh-list_end ?> <?rh-region_start type="footer" style="width: 100%; position: relative;" ?>                 <p> </p> <?rh-region_end type="footer" ?> <?rh-script_start ?><script type="text/javascript" language="JavaScript1.2">//<![CDATA[                 if( typeof( TextPopupInit ) != 'function' ) TextPopupInit = new Function();                 TextPopupInit('a1', 'POPUP578350426'); //\]\]\></script><?rh-script_end ?> </body>
              </html
              • 4. Re:  Frames
                Todeka Level 1
                OK, seems they work in a compiled system, just don't work in the preview window.
