7 Replies Latest reply on Dec 4, 2012 12:45 AM by Michael Thornburgh
    Video Phone only works when specific user initiates connection
    gmcdaid1
      I have an application based on the Cirrus Video phone demo as presented here:
      http://labs.adobe.com/technologies/cirrus/samples/
      In general, this works fine, but for one specific user with whom I test, I have the following issue:
      When I initate the call, we are paired together by Cirrus, but his video/audio does not transmit to me. He can however see and hear me just fine.
      When he initaites the call, everything works fine.
      I'm concerned that this is an issue re. NAT/Firewall setup on standard home broadband connections, in that UDP is allowed through his firewall when the firewall sees that the connection has been initiated by him.
      I'm a web developer, rather than a Flash developer, and I'm just looking for a few leads so that I can investigate this.
      G
        • 1. Re: Video Phone only works when specific user initiates connection
          Michael Thornburgh Adobe Employee
          if video is working one way, then most likely it is a coding problem in VideoPhoneLabs somehow, since the underlying connection is bidirectional.
          • 2. Re: Video Phone only works when specific user initiates connection
            gmcdaid1 Level 1
            Its not a coding problem. It works on some connections and not on others.
            • 3. Re: Video Phone only works when specific user initiates connection
              when you say "his video/audio does not transmit to me. He can however see and hear me just fine", i assume that means that in the bad call, he receives your video/audio but you do not receive his video/audio.  there is only one network connection between the two of you, over which the video/audio would flow in both directions. if it's working in one direction, then the network connection is up, and if there was video/audio from the other side would also be able to flow over the same connection.
              given your description of the symptoms, the only conclusion is a coding error in the VideoPhoneLabs application.  if there was some kind of NAT/firewall issue that prevented the network connection from working properly, then the call couldn't work at all in either direction.
              • 4. Re: Video Phone only works when specific user initiates connection
                gmcdaid1 Level 1
                No, there are other possibilities. I was just looking for confirmation.
                For instance, it may be the case that his firewall only permits *established* UDP traffic, rather than *unsolicited* UDP traffic.
                ie
                If his Flash client peers with mine first, his firewall then knows that this is OK, whereas if my client tries to peer with his first, I get blocked, as his firewall doesn't know anything about my source ip address.
                I don't know if this is the case, or if there are other potential issues re. security, NAT etc, but I do know that it is not a coding problem.
                • 5. Re: Video Phone only works when specific user initiates connection
                  RTMFP is a two-way connection-oriented transport protocol, with a handshake and acknowledgements and stuff, and the video streaming protocol requires a "play" command to be received P2P from the subscriber for the publisher to start sending the video data in the first place.  if video/audio flows in one direction, that requires bidirectional network connectivity, over which the video/audio from the other end could also flow.
                  a direction-sensitive NAT/firewall network issue can exist, but that would block any video/audio from flowing in *either* direction during the call.
                  • 6. Re: Video Phone only works when specific user initiates connection
                    gmcdaid1 Level 1
                    My application works as follows:
                    User1 (me) askes User2 (friend) if they would like to speak via AJAX text chat system
                    When User2 confirms that they would like to do this:
                    User1 browser loads Flash app
                    Flash app connects and obtains session key from cirrus
                    Flash app writes that session key to database
                    User2 browser loads Flash app
                    Flash app checks DB to see if session key exists
                    If not, it waits, and check again in 10 secs
                    When session key is finally found, Flash app connects to cirrus
                    Cirrus now exchanges network data between clients, and P2P connection is established
                    Call is placed from User2 to User1
                    User1 answers
                    Video and audio transmission starts from User1, and is received by User2
                    No Video and audio transmission is received by User1 from User2 (text chat over Cirrus is however possible)
                    All of this works in the majority of cases with other users, and when the roles are reversed, it also works.
                    The only time it doesn't work, it when I try to call my friend.
                    The behaviour described above can be seen in both my app, and the sample provided by Adobe at:
                    I hear what you are saying about RTMFP, but it really doesn't look like a coding problem, unless that problem also exists in the Adobe demo.
                    • 7. Re: Video Phone only works when specific user initiates connection
                      have you verified (by debug traces or similar), in the scenario that you describe above, that User1 is specifying the correct peer ID when subscribing to User2's stream?  and by "verified", i mean printing out User2's NetConnection.nearID on User2, and printing out the peer ID that User1 is using to get User2's stream on User1, and making sure they are identical?
