8 Replies Latest reply: Jul 25, 2013 11:22 AM by knockonthesky79 RSS
    "Some Export Functions Were Not Performed"
    DanRVM Community Member
      I am running Lightroom 4.2 on Windows 8 and routinely receive the message "Some Export Functions Were Not Performed" / "File Cannot Be Written" when trying to export. I have 128GB of space available on the drive I am writing to, do not use a "Second Copy", and have full administrative rights to the drive. There were a couple times when I was able to export an image but when trying to repeat the same process they too now fail.
      Any assistance would be greatly appreciated!
        • 1. Re: "Some Export Functions Were Not Performed"
          I may have discovered the culprit. I use GoodSync to keep files in sync between several computers at home and away. I disabled the automatic synchronization while I was editing but forgot to disable GoodSync Connect which behaves as an intermediary to facilitate connections outside of the same network. Once disabled, I also rebooted and the error has yet to appear. Though rebooting may have solved the issue, I suspecting GoodSync Connect.
          • 2. Re: "Some Export Functions Were Not Performed"
            Still having issues... Seems rebooting gains me some time but the problem cames back - sometimes with a couple files, other times with several.
            • 3. Re: "Some Export Functions Were Not Performed"
              I've learned a little more about the issue.
              When there is a failure to export, Lightroom actually creates an invalid file (in my case a JPG) in the destination folder. When I try to delete that file, Windows reports the following:
              "The action can't be completed because the file is open in Adobe PHotoshop Lightroom 64-bit."
              If I shut down Lightroom, I can delete the file. Then, if I re-launch Lightroom and try the export again, it often works.
              • 4. Re: "Some Export Functions Were Not Performed"
                Cornelia-I Community Member
                LR should also create a special temporary collection for the images where such export problems have been encountered. You should find it in the top left section below All Photographs.
                You could try to export directly again from that collection. If it was a temporary issue for the first time, it might work the second time.
                Cornelia
                • 5. Re: "Some Export Functions Were Not Performed"
                  Thank you. Right now I'm suspecting Adobe PhotoShop Elements' watching of my destination folder. I've tried disabling PSE's "watch folders" and will see how it goes.
                  • 6. Re: "Some Export Functions Were Not Performed"
                    Yes, make sure that your export destination is without access from other software while LR is exporting.
                    Be that some cloud synch software, virus scan or other watching stuff.
                    Good luck, Cornelia
                    • 7. Re: "Some Export Functions Were Not Performed"
                      More detail...
                      I eliminated GoodSync, Windows 8 Photo app, and Adobe PhotoShop Elements Organizer as the root of the problems as I was still experiencing the inability to export with these services totally disabled.
                      I still do not know the cause of the problem but when LR4 exports a file that it said it couldn't do successfully it creates an illegitimate JPG file in the destination folder and I am unable to delete the bad JPG file because LIGHTROOM has a lock on it.
                      I'm wondering if it is a Windows 8 issue.
                      Anyone else?
                      • 8. Re: "Some Export Functions Were Not Performed"
                        knockonthesky79
                        Hi Dan,
                        I just started having this problem. I have windows 8, have had the new computer for 7 months now and no issues until today. Now I cannot export any photos because of this. Last night when I could export 3, my watermark was not showing up. Been trouble shooting it and so solve yet.
