0 Replies Latest reply on Dec 10, 2012 10:02 PM by taggedtext
    Error while placing indesign tagged text
    taggedtext
      Iam using a visual basic application to program with indesign cs5.5.
      While placing an Indesign Tagged Text file into a textframe using
      TextFrame.Place(filename,false)
      option, sometimes the place method shows an error.
      The tagged text file is created just before the place method is called.
      When I debug the program, there is no error. I found that sometimes
      Indesign could not find the tagged file which is just created. It is taking
      little time to found the file from the folder. But when I check if the file
      exist in the folder using VB code, the file is there.
      if fs.fileexists(filename) = true then
      end if
      Still it is showing error.
      What could be the reason?.
