3 Replies Latest reply on Dec 5, 2012 9:39 PM by spushpendra2000
    LiveCycle ES3 webService usage
    spushpendra2000 Level 1
      I went through one of the APIs usage and its talks about
      • Assign the LiveCycle ES2.5 user name to the field GeneratePDFServiceClient.ClientCredentials.UserName.UserName.
      • Assign the corresponding password value to the field GeneratePDFServiceClient.ClientCredentials.UserName.Password.
      Which user name and password do i need to give here, as i entered a couple while installing es3.
      Also, let me know the location where i can get the user name i supplied while installing ES3.
      Regards
      Pushpendra
        • 1. Re: LiveCycle ES3 webService usage
          While using the following code
          ExportPDFResult result = pdfGenClient.exportPDF2(
                          inDoc,
                          inputFileName,
                          ConvertPDFFormatType.RTF,
                          null);
          I am getting the exception.
          Error OCCURRED: ALC-PDG-080-023-Acrobat_PATH environment variable either not set or is invalid. Please set this variable to point to Acrobat.exe in Acrobat version 10. Acrobat_PATH should be set to
          <Acrobat_Home>\Acrobat 10.0\Acrobat\Acrobat.exe. Here <Acrobat_Home> is the parent folder where the Acrobat is installed.
          I have configured the Path variable as
          Microsoft Windows [Version 6.1.7601]
          Copyright (c) 2009 Microsoft Corporation.  All rights reserved.
          C:\Users\pushpendra.singh>echo %Acrobat_PATH%
          C:\Program Files (x86)\Adobe\Acrobat 11.0\Acrobat\Acrobat.exe
          Do i need to downgrade and install Acrobat 10.I was under the impression that back porting should always be supported by Acrobat 11.
          Let me know
          Regards
          Pushpendra
          • 2. Re: LiveCycle ES3 webService usage
            I have now installed Acrobat Pro X but i stil the same error.
            Can anybody pinpoint me the issue?
            I  have noticed this issues in other places in our forum as well but found no solution
            regards
            Pushpendra
