This content has been marked as final.
Show 1 reply
1. Re: manipulate recordset inside cfr
Eddie Lotter Sep 17, 2013 8:35 AM (in response to robylab)Yes, this is possible.
For example, in the calling CFM file, add your parameter:
<cfreportparam name="prmOrderBy" value = "order by LastName">
Then, in Report Builder, add the following line at the bottom of the SQL query:
#param.prmOrderBy#
Naturally you wouldn't hard-code the "order by" clause, you would use a variable.
You could, of course, handle the query dynamically in your calling CFM file and pass the query result-set to the report so that the report does not run its internal query.
