6 Replies Latest reply on Jan 7, 2013 11:40 PM by RameshBacha
    Login user programatically
    danchapmanme Level 1
      I want to be able to login a user programmatically on my CQ website. I have created users wih a user id from a genenered UUID, and I store the user's email address as normal as a profile property.
      Example:
      User ID/Username/Login ID: 3b60ef68-881c-4ad7-b5b4-ffc0c7ebcca6
      Email: test@test.com
      When the user wants to login they will supply their email address and password. I have used a form with a custom action, and using forward.jsp to intercept the form post. I will lookup the user id (UUID) based on the email adress and the programatically post this information to the j_security_check servlet. However, when I post to j_security_check it just displays a blank screen. I get a 302 status code back from the form post, which I guess means the login was successful as invalid user details produces a status code 403.
      import org.apache.commons.httpclient.HttpClient,
      import org.apache.commons.httpclient.HttpException,
      import org.apache.commons.httpclient.HttpStatus,
      import org.apache.commons.httpclient.methods.PostMethod
      HttpClient httpClient = new HttpClient();
      PostMethod postMethod = new PostMethod( "http://localhost:4502/content/test-site/en/login/j_security_check" );
      postMethod.addParameter( "resource","http://localhost:4502/content/test-site/en/login.html");
      postMethod.addParameter( "_charset_","UTF-8");
      postMethod.addParameter( "j_username",  "test@test.com" );
      postMethod.addParameter( "j_password", "test" );
      status = httpClient.executeMethod( postMethod );
      contents = postMethod.getResponseBodyAsString();
      postMethod.releaseConnection();
        • 1. Re: Login user programatically
          Jörg Hoh Adobe Employee
          What do you want to achieve? What's your requirement you want to solve with this code?
          Jörg
          • 2. Re: Login user programatically
            cqnewuser
            Hi I am intereted in working out how to programmatically authenticate a user too.
            • 3. Re: Login user programatically
              justin_at_adobe Adobe Employee
              Unless otherwise configured, CQ supports HTTP Basic Authentication. That's going to be simpler than using the token-cookie based authentication.
              • 4. Re: Login user programatically
                RameshBacha Level 1
                Hi Justin,
                Can you please provide an example for using HTTP Basic authentication using CQ5.
                We have requirement, where when i click on a link from external application i should be able to login in to CQ5 using Http Basic authentication. I will create a dedicated username: password for that application and using those credentials on clicking on a link i should login into CQ5.
                i tried the following.. but it's not working. Below is the code for the same.
                <!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN" "http://www.w3.org/TR/html4/loose.dtd">
                <html>
                <head>
                  <title> New Document </title>
                <script type="text/javascript" src="base64.js"></script>
                function make_basic_auth() {
                alert("in basic_auth");
                  var tok = 'admin:admin';
                  var hash = Base64.encode(tok);
                  return "Basic " + hash;
                function httpbasicauth(){
                var auth = make_basic_auth();
                var url = 'http://localhost:4502/libs/cq/core/content/login.html';
                var xmlhttp;
                if (window.XMLHttpRequest)
                  {// code for IE7+, Firefox, Chrome, Opera, Safari
                  xmlhttp=new XMLHttpRequest();
                else
                  {// code for IE6, IE5
                  xmlhttp=new ActiveXObject("Microsoft.XMLHTTP");
                  xmlhttp.onreadystatechange = function() {
                        if(xmlhttp.readyState == 4){
                            alert(xmlhttp.readyState);
                           window.location.href = "http://localhost:4502/welcome"
                xmlhttp.open('GET',url);
                xmlhttp.setRequestHeader('Authorization', auth);
                xmlhttp.send();
                </script>
                </head>
                <body>
                  <div id="myDiv"><h2>Login to CQ5 using AJAX request</h2></div>
                  <a href="#" onclick="httpbasicauth()">CQ5 Site admin</a>
                </html>
                can you please correct me to make it work. Using this i am going into readystate==4 block and it's redirected to cq login page.
                • 5. Re: Login user programatically
                  Ramesh-
                  For what you are describing, I would recommend using a cookie-based SSO system. Note that this is an entirely different use case than what Dan originally requested (for which Basic Auth is the correct solution).
                  Regards,
                  Justin
                  • 6. Re: Login user programatically
                    RameshBacha Level 1
                    Hi Justin,
                    we have not integrated all our applications with SSO. It's in planning.
                    As of now i am doing a simple POC to make sure that on clicking a link from HTML form i should be able to login into CQ5 by using it's existing login functionality.
                    Is there any way to do it? HTTP Basic authentication or any other apporach you would suggest.
