1 Reply Latest reply on Dec 5, 2012 6:26 AM by Peter Spier
    Compatibilidad idesign 6.0 con CS5.5
    PlacoLL Level 1
      Hola buenas tardes,
      Quisiera saber si es posible abrir un archivo de idesign versión 6 en la de 5.5, y si es posible ¿ que hay que hacer?
        • 1. Re: Compatibilidad idesign 6.0 con CS5.5
          .indd files cannot be opened in versions earlier than the one from which they were saved. You can export a .idml file from CS6 and open that in CS5.5, CS5, or CS4, but there will be slight changes in text flow due to differnces in the text engines, and if you used any fetures in CS6 that are not supported in the earlier version they will be lost.
