3 Replies Latest reply on Dec 11, 2012 9:20 AM by gkaiseril
    Automatic time formatting
    yeungyam Level 1
      I have a text field that I want the user to input a time. I want the field to automatically convert the number into time.
      For example, if the user inputs 856, the text will be converted to 8:56.
      If the user intputs 1224; the text field will display 12:24.
      I have taken a look at the thread here:
      http://forums.adobe.com/thread/1103677?tstart=0
      but it doesn't act exactly as I want because in this case the user has to input 4 digits and the column (:).
        • 1. Re: Automatic time formatting
          If you want military time, that is 24 hour time format without the ":" separator, then you need to use a text field and not a "Time" format. You then need to create custom keystroke, validation, and format scripts. If you access the value of the field in another script, you need to get the value as a string unless you want to lose the leading zero.
          • 2. Re: Automatic time formatting
            yeungyam Level 1
            In the text field, I have custom validation
            // 24 hour time validation script for times form 00:00 to 23:59
            var RE_24hr = /^(2[0-3]|[01]?[0-9])([0-5]?[0-9])$/;
            if(RE_24hr.test(event.value) == false && event.value != "") {
            app.alert("Enter time in 24 hour format and a value between 00:00 - 23:59", 1, 0, "Time Value Error");
            and custom format
            if(((event.value) >= "001") && ((event.value) <= "959"))
            {event.value = util.printx("9:99", event.value);}
            if(((event.value) >= "1000") && ((event.value) <= "2359"))
            {event.value = util.printx("99:99", event.value);}
            When I enter 940, it's fine and shows 9:40
            But if I enter 1059, it converts to 10:5
            • 3. Re: Automatic time formatting
              In military time, all times are 4 digits long. If you do not want to lose the leading zero, you must access the value as a string.
              If you are going to compare numbers, do not use quotation marks around the value or you are creating a text string and not a floating point number.
              I would use RegExp for the custom format. But is this needed if the entered value has been validated?
              You have to be using a text field with "Fromat" of "None".
              Also you might try the following validation script:
              // Military 24 hour time validation script for times form 00:00 to 23:59
              var RE_24hr = /^(2[0-3]|[01]?[0][0-9])([0-5]?[0-9])$/;
              app.alert("Enter time in Military 24 hour format and a value between 0000 - 2359", 1, 0, "Time Value Error");
              event.rc = false;
              It requires the leading zero for times less 1000.
