1. Re: How do I script SWF files instead of JPG files in XML loader?
kglad Dec 5, 2012 9:49 PM (in response to nikolaig)first, load your xml and use an complete listener function to loop through your images, load the thumbs, add each to a parent movieclip, arrange their positions and assign the parent a mouse listener and a url string property to match the corresponding url attribute.
2. Re: How do I script SWF files instead of JPG files in XML loader?
nikolaig Dec 5, 2012 10:13 PM (in response to kglad)O.K. Here is my COMPLETE function.
xmlLoader.addEventListener(Event.COMPLETE, LoadXML);
function LoadXML(e:Event):void {
trace("xml load complete");
xmlData = new XML(e.target.data);
//trace(xmlData.image); //we'll see each image xml element listed in the output panel with this xmlList
buildScroller(xmlData.image); //rather than trace the xmlList, we send it to our buildScroller function
//build scroller from xml
function buildScroller(imageList:XMLList):void{
trace("build Scroller");
//var scroller_x:int=0;
for (var item:uint = 0; item<imageList.length();item++) {
var thisOne:MovieClip = new MovieClip();
//thisOne.img_width=imageList[item].attribute("width");
//outline
var blackBox:Sprite = new Sprite();
blackBox.graphics.beginFill(0xFFFFFF);
blackBox.graphics.drawRect(-1, -1, 86, 128);//-1,-1 places rectangle 1px left and up.86, 128 draws rectangle 1px wider on all sides of placed image dimenstions of 84x126
thisOne.addChild(blackBox);
//scroller_x += thisOne.img_width + 20;
//var currentX = currentImageWidth+spaceBetween;//modified line to adjust variable thumb widths
thisOne.x = (84 + padding) *item;//84 is the width of the loaded images and 15 (which was before paddign var) is the padding
//thisOne.x = scroller_x;//modified line to adjust variable thumb widths
thisOne.itemNum = item;
thisOne.title = imageList[item].attribute("title");
thisOne.link = imageList[item].attribute("url");
thisOne.src = imageList[item].attribute("src");
thisOne.alpha = 0;//makes all thumb images at alpha=0 before they are fully loaded
//trace(thisOne.itemNum, thisOne.title, thisOne.link, thisOne.src);
//Loading and Adding the Images
//image container
var thisThumb:MovieClip = new MovieClip();
//add image
var ldr:Loader = new Loader();
//var url:String = imageList[item].attribute("src");
var urlReq:URLRequest = new URLRequest(thisOne.src);
trace("loading thumbnail "+item+" into Scroller: " + thisOne.src);//url
ldr.load(urlReq);
//assign event listeners for Loader
ldr.contentLoaderInfo.addEventListener(Event.COMPLETE,completeHandler);//tells us when the loading is complete
ldr.contentLoaderInfo.addEventListener(IOErrorEvent.IO_ERROR, errorHandler);//tells us if there are any typo errors when the loading is complete
thisThumb.addChild(ldr);
thisOne.addChild(thisThumb);
//create listeners for this thumb
thisOne.buttonMode = true;//makes boxes act as buttons
thisOne.addEventListener(MouseEvent.CLICK, clickScrollerItem);//makes boxes act as buttons
thisOne.addEventListener(MouseEvent.MOUSE_OVER, overScrollerItem);//traces the title when the mouse is over the bounding box in the Output Panel
thisOne.addEventListener(MouseEvent.MOUSE_OUT, outScrollerItem);//traces the title when the mouse is out the bounding box in the Output Panel
//add item
scroller.addChild(thisOne);
But I am not sure if I expressed myself clearly. All what you have indicated happens. Images are being loaded and url strings are working. I can not figure out how to tweek the code so instead of url specified in xml file I can load swf image into the SWF loader on the same screen?
3. Re: How do I script SWF files instead of JPG files in XML loader?
kglad Dec 6, 2012 6:25 AM (in response to nikolaig)i don't see where you assigned url string properties (eg, urlString) to the parent movieclips. once you do that, you use that string to load the large image in clickScrolleritem:
function clickScrolleritem(e:MouseEvent):void{
loader_howToLoader2.url = MovieClip(e.currentTarget).urlString;
loader_howToLoader2.load(true);}
4. Re: How do I script SWF files instead of JPG files in XML loader?
nikolaig Dec 6, 2012 7:51 AM (in response to kglad)Thanks for a straight forward answer.
I thought I am assigning the url string properties in the xml file as this:
<image src="myImage.jpg" title="myImageTitle" url="http://www.888acolyte.com"/>
is it where I specify the individual links? Or I forget about the url from xml file all together? Do I still need to pass a sourceVar for the SWF loader?
Here is the constractor code from the SWF loader:
loader_howToLoader2 = new SWFLoader(sourceVar,
5. Re: How do I script SWF files instead of JPG files in XML loader?
kglad Dec 6, 2012 8:06 AM (in response to kglad)yes, you did. i missed that.
so you used link instead of urlString:
loader_howToLoader2.url = MovieClip(e.currentTarget).link;
6. Re: How do I script SWF files instead of JPG files in XML loader?
nikolaig Dec 6, 2012 5:13 PM (in response to kglad)wow, great - it works! I was searching for it for a long time.
For other newbies i wanted to add that you have to replace url in the xml file (
url="http://www.888acolyte.com"/ in my example with the link to the swf file you want to load. For example like this :
url="appThumbs_loadSWFs/upanddownglowingvase_tl.swf"Thanks for your help.
btw. why I do not need to add this line
loader_howToLoader2.url = sourceVar;to this code:
loader_howToLoader2.load(true); -
7. Re: How do I script SWF files instead of JPG files in XML loader?
kglad Dec 6, 2012 9:04 PM (in response to nikolaig)loader_howToLoader2.url is the url string you want to load.
it can be a variable like sourceVar or the link property of a movieclip. as long as the variable/property point to a valid url string, the loader will work.
