5 Replies Latest reply on Jul 4, 2006 2:03 AM by blemmo
    Generate a random number, to a certain decimal point
    twistedpancreas Level 1
      Howdy is there anyway to generate a random number (within a range), to a certain decimal point and then display it in a text box?
      I know how to do a full number, but am struggling to find out how you get random numbers with decimals.
      Thanks in advance.
        • 1. Re: Generate a random number, to a certain decimal point
          blemmo Level 1
          Generate a full number that has as many digits as the float number you want, then divide by 10^the number of decimal parts.
          E.g., if your number consists of 3 full numbers and 2 decimals, like 123.45, generate a 5-digit number (12345), then divide by 100 (10^2), to get 123.45.
          That's also the way to round numbers to a certain accuracy: for 2 decimal parts, multiply by 100, round it and divide by 100.
          hth,
          blemmo
          • 2. Re: Generate a random number, to a certain decimal point
            well atm im using this code:
            function shuffle(){
            return Math.floor(Math.random() * 2);
            var allNumbers=[];
            for(var i=10;i<=20;i++){
            allNumbers.push(i);
            allNumbers.sort(shuffle);
            results=[];
            for(var r=0;r<1;r++){
            results.push(allNumbers[r]);
            trace(results);
            display1.text=results[0];
            so instead of the *2 should i have return Math.floor(Math.random() * 100)/100;
            • 3. Re: Generate a random number, to a certain decimal point
              blemmo Level 1
              I can't see where you're going with that code... it shuffles an array of full numbers and gets one of them. If you want decimal numbers you could just fill the array with decimals instead of full numbers. Changing the shuffle method wouldn't change the numbers in the array, just the way of sorting it.
              If you want just one random number, you don't need the array at all, but you could use something like this:
              Math.round( (10 + Math.random() * 10) * 100 ) / 100;
              for a random number with 2 decimal parts between 10 and 20.
              hth,
              blemmo
              • 4. Re: Generate a random number, to a certain decimal point
                ok sorry, im more a designer than programmer, so im learning Actionscripting as i need it.
                so if i had
                display = Math.round( (10 + Math.random() * 10) * 100 ) / 100;
                where "display" is the var name of a text box this would work?
                so is this right, basically (10 + Math.random() is telling the random number to be 2 digits long? sorry then i get lost
                • 5. Re: Generate a random number, to a certain decimal point
                  blemmo Level 1
                  If 'display' is the variable bound to a textbox, it's ok. If it's the instance name (like in the 1st posting), it should be display.text.
                  The expression works like this:
                  Math.random() gets a number like 0.123456789.
                  To have 2 decimal parts, move the dot (.) 2 digits to the right. This is done by multiplying with 100. Now it's 12.3456789.
                  Now Math.round() this, and we have 12.
                  Last step is moving the dot 2 digits to the left again, which means divide by 100, and we then have 0.12. In short:
                  Math.round( Math.random()*100 ) / 100
                  That's the way to round numbers to a certain accuracy. For 3 decimal parts, use 1000 instead of 100, and so on.
                  The part (10 + Math.random() * 10) is there to get numbers between 10 and 20: Math.random() is always between 0 and 1, so by multiplying this with 10, we get numbers between 0 and 10. As the lowest number should be 10, we must add 10 to this, so that the result is between 10 and 20.
                  It's a bit complicated on the first look, but if you think it through it's all quite logical.
                  greets,
                  blemmo
