11 Replies Latest reply on Dec 7, 2012 10:20 AM by DJ Gecko
    Vector.<*> triggers a "Problem" in Flash Builder but doesn't create an error during runtime.
    DJ Gecko Level 1
      In Flash Builder 4.6 I get an error for this:
      var testVector:Vector.<*> = new Vector.<*>();
      trace(testVector.length);
      Sometimes the error shows up in the "Problems" panel and pointing at the trace it says something about byte code. Other times it just shows the "?" symbol next to the trace command that says "Access of undefined property length".
      When I test the movie there are no runtime errors.
      Can someone explain this?
      cheers.
        • 1. Re: Vector.<*> triggers a "Problem" in Flash Builder but doesn't create an error during runtime.
          Gaius Coffey Level 2
          Why would you do that anyway?
          If the thing about vectors over arrays is there speed because they don't have to resolve datatypes, setting it to an untyped * seems a bit weird. You could use Vector.<Object> instead which is practically the same thing, but is at least a defined type so might eliminate the compiler warning.
          But, again, why do this?
          When I use Vector, it is because I want to do fast operations with a set of items of a known datatype or interface and, for that, Vector makes coding exceptionally easy and satisfying. But with a pretty much undefined type like * or Object, all of those advantages are lost as, at the very least, you have to do type checking interrogation whenever you want to process what you have.
          G
          • 2. Re: Vector.<*> triggers a "Problem" in Flash Builder but doesn't create an error during runtime.
            DJ Gecko Level 1
            Hi Gaius,
            There are lots of reason why I would want to use a vector this way.
            One is for building a shuffle function that will shuffle any type of Vector.
            public function shuffleArray(array:Vector.<*>):void
                                          for (var i:int = array.length-1; i >=0; i--)
                                                    var randomIndex:int = Math.floor(Math.random()*(i+1));
                                                    var itemAtIndex:Object = array[randomIndex];
                                                    array[randomIndex] = array[i];
                                                    array[i] = itemAtIndex;
            var testVector:Vector = new Vector.<uint>( [1, 2, 3, 4] );
            shuffleArray(Vector.<*>(testVector));
            Changing it from * to Object did not work.
            Thanks.
            • 3. Re: Vector.<*> triggers a "Problem" in Flash Builder but doesn't create an error during runtime.
              Very surprised if that doesn't work as vector.<Object>.
              I can see why that would be useful, but the same could be achieved with;
              [code]
              public static function randomSort(a:*,b:*):int { return Math.random()>0.5?1:-1; }
              var testVector:Vector.<uint> = Vector.<uint>([1,2,3,4]);
              testVector = testVector.sort(randomSort);
              [/code]
              (Plus there is the possibility of an invalid index with your sort function when random returns 1.)
              G
              • 4. Re: Vector.<*> triggers a "Problem" in Flash Builder but doesn't create an error during runtime.
                DJ Gecko Level 1
                Hi Gaius,
                When using a * or Object with a Vector the code does work, but Flash Builder shows the "?" mark error, and sometimes, for some strange reason, will show the "!" problem. Please read my original post.
                The sort method for randomizing doesn't produce a very good result.
                "...there isn’t an even 1/26 chance that any given letter will end up in any given slot. This is because we’re only swapping adjacent pairs of elements, and doing no more than that. Still, it’s a neat method..."
                That quote is taken from here: http://active.tutsplus.com/tutorials/actionscript/quick-tip-how-to-randomly-shuffle-an-arr ay-in-as3/
                cheers.
                • 5. Re: Vector.<*> triggers a "Problem" in Flash Builder but doesn't create an error during runtime.
                  That's a good article, but my comment on invalid index still holds with what you have. One of his other approaches would avoid that.
                  For the undefined property length, I think the compiler is struggling to deduce properties when it is expecting a defined type and is receiving instead *.
                  Vector is intentionally specific about typing because that is one of the ways it makes its performance gains - it can run more efficiently when it doesn't need to interrogate each piece of data to deduce what it is etc.
                  G
                  • 6. Re: Vector.<*> triggers a "Problem" in Flash Builder but doesn't create an error during runtime.
                    This avoids the problem and means you can use the function with Array as well as with Vector.
                    [code]
                    protected static function randomSortArrayOrVector(a:Object):void {
                                                  if(a.hasOwnProperty('length')) {
                                                            var l:int = a['length'];
                                                            for (var i:int = l-1; i>-1; i--)
        var randomIndex:int = int(Math.random()*(l-1));
        var itemAtIndex:Object = a[randomIndex];
        a[randomIndex] = a[i];
        a[i] = itemAtIndex;
                    [/code]
                    • 7. Re: Vector.<*> triggers a "Problem" in Flash Builder but doesn't create an error during runtime.
                      OK, I take that back, I read up on the docs and see that Math.random() returns 0 <= n < 1 where I thought it was <=1.
                      I also ran a test bed on the Math.random() thing and I see what your man means. My method of calculating the index gave a slight imbalance towards the end of letter distributions, but I can't see why!
                      Have reverted to yours for the below, on first run it looked good, but I am seeing a cluster around the original letter position? (EG: Follow position 0 for a, position 1 for b etc. and you will see they have a disproportionate number there.)
                      G
                      [code]
                      protected function doTheTest():void {
                      var iterations:uint = 100000;
                      var index:Dictionary = new Dictionary;
                      var i:int = 0;
                      var letter:String;
                      var pos:int;
                      var currentLetterIndex:Vector.<uint>;
                      var toSort:Vector.<String>;
                      var testSource:Vector.<String> = Vector.<String>(["a","b","c","d","e","f","g","h","i","j","k","l","m","n","o","p","q","r", "s","t","u","v","w","x","y","z"]);
                      testSource.fixed = true;
                      var posIndex:Vector.<uint> = new Vector.<uint>;
                      posIndex.length = testSource.length;
                      posIndex.fixed = true;
                      // Build the index using a copy of the posIndex input.
                      for(i=0;i<testSource.length;i++) index[testSource[i]] = posIndex.concat();
                      // TEST USING JUST RANDOM
                      for(i=0;i<iterations;i++) {
                                // Use a concat to prevent sort changing inputs
                                toSort = testSource.concat();
                                toSort = toSort.sort(function (a:*,b:*):int { return Math.random()>0.5?1:-1; });
                                for(pos=0;pos<toSort.length;pos++) {
                                          letter = toSort[pos];
                                          currentLetterIndex = index[letter] as Vector.<uint>;
                                          currentLetterIndex[pos]++;
                      trace("@@@@@ USING RANDOM @@@@");
                      for(i=0;i<testSource.length;i++) {
                                letter = testSource[i];
                                trace("POSITION COUNT OF "+letter+" is:"+index[letter].join(","));
                      // Test using function
                                randomSortArrayOrVector(toSort);
                      trace("@@@@@ USING SORT FUNCTION @@@@");
                                for (var i:int = l-1; i >=0; i--)
                                          a[i] = itemAtIndex;
                      [/code]
                      POSITION COUNT OF a is:3150,3207,3010,2741,2653,3063,4174,2606,2674,2991,3172,3889,4872,18865,3851,3356,3219, 2971,2732,3930,3319,2814,2944,3058,3222,3517
                      POSITION COUNT OF b is:6815,7482,2634,2925,3023,2921,3107,3416,3459,3508,3444,3387,3212,3170,3331,3439,3444,3 375,3312,3158,3180,3339,3776,4356,5441,7346
                      POSITION COUNT OF c is:6149,5382,8320,2133,2209,2931,3224,3274,3427,3438,3290,3114,2888,2859,2997,3180,3431,3 493,3551,3416,3732,3906,4336,4864,5206,5250
                      POSITION COUNT OF d is:4516,4382,4620,9761,2966,2096,2555,3285,3365,3274,3083,2785,2603,2759,2730,3145,3469,3 706,3752,3890,4169,4343,4888,4868,4797,4193
                      POSITION COUNT OF e is:3418,3385,4878,4681,11058,3387,2456,2421,2769,3163,2892,2596,2457,2390,2622,2934,3392, 3813,4177,4334,4471,4700,4857,4672,4364,3713
                      POSITION COUNT OF f is:3178,3193,4506,4454,5179,11514,3753,2834,2303,2027,2308,2454,2275,2290,2466,2960,3444, 3941,4292,4489,4647,4824,4686,4498,4058,3427
                      POSITION COUNT OF g is:3035,3073,3577,4665,4627,5549,11737,4087,3112,2132,1750,1557,1789,2331,2568,2930,3469, 3979,4324,4564,4606,4686,4468,4278,3757,3350
                      POSITION COUNT OF h is:3194,3121,3219,4018,3595,4356,5302,12154,3533,3078,2513,2009,1867,1874,2414,2967,3466, 4079,4251,4441,4409,4535,4436,3912,3792,3465
                      POSITION COUNT OF i is:3460,3486,3287,3430,3748,3089,3875,4449,12535,3322,2844,2694,2401,2421,2671,2886,3405, 3980,4252,4225,4137,4181,4016,3803,3734,3669
                      POSITION COUNT OF j is:3757,3675,3415,3147,4020,2644,2855,3510,4389,13514,3192,2865,2896,2833,2905,3039,3367, 3740,4102,3909,3678,3859,3672,3624,3666,3727
                      POSITION COUNT OF k is:3634,3707,3409,3020,3141,3712,2390,2780,3514,4322,15026,3388,3034,3047,3165,3287,3290, 3432,4098,3759,3514,3279,3497,3508,3484,3563
                      POSITION COUNT OF l is:3564,3493,3382,2775,2990,4085,2299,2409,2970,3430,4434,17142,3665,3362,3419,3301,3245, 3115,3767,3581,3318,3031,3144,3187,3385,3507
                      POSITION COUNT OF m is:3213,3343,3112,2871,2789,3128,3887,2504,2607,3228,3750,4587,18391,3865,3430,3379,3078, 3046,2858,4219,3164,2925,2877,3176,3151,3422
                      POSITION COUNT OF n is:73,81,150,308,571,1106,2135,3639,6189,9115,11788,13690,14242,12757,9894,6957,4005,2012 ,880,292,98,14,4,0,0,0
                      POSITION COUNT OF o is:3096,3174,2864,2839,2678,2966,3400,3826,2849,2956,3121,3355,4061,5195,18308,3599,3090, 2907,2645,2548,4380,3016,2836,3255,3371,3665
                      POSITION COUNT OF p is:3396,3317,3083,3026,2878,3017,3400,4197,3156,3107,3039,3140,3521,4147,5073,16486,3221, 2919,2523,2535,3989,3072,3056,3430,3474,3798
                      POSITION COUNT OF q is:3650,3640,3377,3409,3183,3283,3465,3721,3714,3292,3057,2977,2999,3334,3963,4776,15045, 2912,2596,2421,2562,4140,3361,3570,3714,3839
                      POSITION COUNT OF r is:3639,3711,3590,3727,3646,3596,3739,3887,3812,3216,3058,2854,2705,2849,3179,3988,4711,1 3457,2936,2571,2689,3802,3523,3555,3687,3873
                      POSITION COUNT OF s is:3769,3828,3832,4172,4138,3880,4010,3987,3798,3504,2908,2438,2318,2291,2679,3553,4241,5 000,12631,3288,2755,2763,3986,3206,3509,3516
                      POSITION COUNT OF t is:3692,3761,4099,4493,4484,4423,4251,4218,3815,3462,2883,2494,2145,1895,2182,2630,3651,4 920,5611,11928,3719,2874,3380,2906,3053,3031
                      POSITION COUNT OF u is:3786,3809,4243,4633,4804,4607,4425,4106,3902,3223,2869,2511,2216,2122,2143,2393,2793,3 626,4956,5761,11321,3847,2805,3621,2702,2776
                      POSITION COUNT OF v is:3901,3834,4447,4785,4917,4857,4395,4187,3765,3338,2876,2482,2254,2217,2257,2467,2729,2 997,3305,4342,5305,11215,3445,3708,3008,2967
                      POSITION COUNT OF w is:4119,4132,4657,4947,4837,4714,4345,3984,3689,3328,2887,2500,2417,2350,2516,2622,2755,2 857,3133,3557,3844,5094,10545,3286,3921,2964
                      POSITION COUNT OF x is:4535,4515,4916,4866,4544,4190,4010,3721,3610,3279,3126,2740,2661,2682,2797,2887,3123,3 077,2954,2817,3418,4208,4645,10185,3771,2723
                      POSITION COUNT OF y is:5207,5053,4972,4476,3983,3699,3593,3462,3441,3348,3283,3049,2903,2899,3145,3336,3343,3 236,3066,2914,2709,2771,4125,4476,9639,3872
                      POSITION COUNT OF z is:6054,6216,4401,3698,3339,3187,3218,3336,3603,3405,3407,3303,3208,3196,3295,3503,3574,3 410,3296,3111,2867,2762,2692,2998,4094,10827
                      POSITION COUNT OF a is:7048,6896,6922,6642,6495,6966,8035,6402,6483,6809,7073,7718,8670,22643,7736,7221,7116, 6875,6623,7677,7131,6625,6800,6941,7063,7390
                      POSITION COUNT OF b is:10633,11230,6457,6756,6792,6692,6971,7303,7370,7371,7234,7276,7067,7033,7248,7380,7193 ,7317,7085,6973,7032,7294,7618,8184,9211,11280
                      POSITION COUNT OF c is:9963,9370,12206,6047,6121,6835,6944,7120,7334,7346,7046,6967,6800,6727,6815,6963,7207, 7300,7433,7250,7650,7631,8173,8698,9006,9048
                      POSITION COUNT OF d is:8432,8347,8465,13595,6812,6018,6390,7084,7266,7053,6926,6559,6392,6570,6602,6871,7326, 7609,7478,7807,7926,8172,8807,8827,8576,8090
                      POSITION COUNT OF e is:7275,7183,8780,8527,14854,7144,6158,6350,6632,7002,6750,6560,6352,6330,6366,6728,7262, 7660,8003,8206,8152,8471,8854,8506,8241,7654
                      POSITION COUNT OF f is:7028,7011,8403,8289,8987,15354,7533,6746,6212,5784,6127,6470,6030,6054,6297,6828,7380, 7775,8164,8296,8457,8726,8496,8283,7984,7286
                      POSITION COUNT OF g is:6759,6885,7316,8482,8489,9464,15543,7935,6885,6009,5649,5328,5699,6170,6360,6837,7325, 7786,8223,8485,8597,8552,8240,8130,7605,7247
                      POSITION COUNT OF h is:6992,7025,7100,7814,7429,8068,9226,15944,7358,6918,6299,5845,5777,5802,6294,6767,7369, 7877,8173,8285,8309,8292,8280,7700,7691,7366
                      POSITION COUNT OF i is:7266,7242,7153,7312,7722,6900,7608,8355,16314,7192,6621,6512,6248,6231,6543,6751,7332, 7841,8109,8013,7993,8191,7756,7744,7567,7484
                      POSITION COUNT OF j is:7598,7575,7144,6972,7850,6484,6684,7355,8206,17234,7042,6845,6888,6612,6761,6778,7155, 7588,8040,7917,7627,7615,7505,7441,7594,7490
                      POSITION COUNT OF k is:7442,7647,7303,6735,6972,7552,6286,6572,7308,8254,18843,7258,6883,6913,6986,7113,7195, 7365,7984,7558,7411,7179,7291,7275,7324,7351
                      POSITION COUNT OF l is:7428,7376,7194,6669,6800,7895,6185,6135,6817,7225,8293,20967,7465,7239,7274,7260,7071, 6900,7610,7371,7239,6850,6968,7002,7329,7438
                      POSITION COUNT OF m is:7087,7165,6896,6675,6676,6871,7747,6262,6431,7058,7537,8384,22213,7716,7419,7231,6931, 6900,6726,8026,7101,6751,6706,7166,6983,7342
                      POSITION COUNT OF n is:3852,3871,3988,4172,4429,4956,6124,7441,9986,12986,15719,17590,18088,16635,13686,10935 ,7846,5889,4687,4236,3881,3785,3829,3802,3872,3715
                      POSITION COUNT OF o is:6866,7064,6615,6767,6480,6823,7323,7696,6676,6793,7023,7350,7849,9114,22166,7449,6926, 6765,6495,6341,8193,6843,6709,7071,7135,7468
                      POSITION COUNT OF p is:7193,7026,6895,6964,6695,6943,7216,8137,7037,7075,6934,6906,7501,8031,8943,20305,6953, 6805,6349,6270,7931,6920,6861,7205,7249,7656
                      POSITION COUNT OF q is:7579,7429,7228,7229,7031,7111,7503,7598,7564,7129,7008,6713,6773,7245,7856,8638,18874, 6647,6369,6336,6377,7991,7262,7386,7458,7666
                      POSITION COUNT OF r is:7569,7512,7489,7561,7480,7480,7618,7714,7643,7139,6896,6714,6584,6672,7008,7773,8468,1 7287,6842,6296,6471,7707,7444,7382,7555,7696
                      POSITION COUNT OF s is:7631,7652,7786,8035,8000,7669,7883,7832,7641,7318,6793,6215,6080,6106,6473,7478,8088,8 843,16527,7221,6594,6627,7894,6995,7238,7381
                      POSITION COUNT OF t is:7595,7565,7976,8352,8392,8295,8161,8123,7658,7288,6726,6284,5956,5719,6024,6433,7496,8 705,9380,15755,7497,6850,7208,6746,6893,6923
                      POSITION COUNT OF u is:7607,7682,8120,8468,8687,8454,8236,8038,7677,7142,6790,6347,5983,5960,6010,6198,6692,7 389,8731,9681,15085,7692,6747,7415,6649,6520
                      POSITION COUNT OF v is:7788,7658,8249,8635,8874,8696,8176,8027,7656,7193,6633,6322,6027,6004,6098,6352,6614,6 844,7214,8105,9286,15075,7225,7629,6908,6712
                      POSITION COUNT OF w is:7993,8006,8534,8767,8664,8648,8203,7935,7597,7150,6682,6337,6295,6167,6251,6448,6626,6 782,6968,7390,7561,8914,14369,7148,7760,6805
                      POSITION COUNT OF x is:8353,8453,8780,8724,8248,8011,7825,7651,7523,7215,6993,6612,6547,6523,6587,6704,6916,6 945,6794,6680,7174,7993,8508,14019,7617,6605
                      POSITION COUNT OF y is:9123,8969,8834,8331,7764,7516,7413,7130,7263,7153,7058,6787,6792,6720,7020,7295,7271,7 054,6897,6784,6544,6638,7950,8492,13483,7719
                      POSITION COUNT OF z is:9900,10161,8167,7480,7257,7155,7009,7115,7463,7164,7305,7134,7041,7064,7177,7264,7368, 7252,7096,7041,6781,6616,6500,6813,8009,14668
                      Message was edited by: Gaius Coffey
                      • 8. Re: Vector.<*> triggers a "Problem" in Flash Builder but doesn't create an error during runtime.
                        Huh.
                        Not happy with that, only managed to get an even distribution after
                        a) modifying the index selection to ensure there is
                        b) running the random sort twice
                        Otherwise, I was seeing a seemingly unavoidable cluster around the original position of the letter.
                        G
                        [code]
                                            for (var i:int=0;i<l;i++)
                                                      var randomIndex:int = i;
                                                      while(randomIndex==i) randomIndex = (Math.random()*l*1000)%l;
                                                      a[i] = itemAtIndex;
                                  // NOTE DOUBLE SORT!
                        [/code]
                        @@@@@ USING DOUBLE SORT SORT FUNCTION @@@@
                        POSITION COUNT OF a is:3814,3819,3822,3938,3808,3867,3932,3750,3835,3813,3955,3854,3880,3685,3812,3757,3935,3 816,3844,3823,3898,3817,3889,3796,3934,3907
                        POSITION COUNT OF b is:3888,3901,3833,3863,3852,3845,3894,3863,3874,3799,3793,3732,3919,3912,3828,3783,3800,3 871,3826,3882,3861,3895,3718,3903,3933,3732
                        POSITION COUNT OF c is:3849,3732,3925,3783,3868,3838,3820,3757,3714,3929,3865,4006,3789,3836,3788,3887,3870,3 989,3887,3802,3763,3868,3875,3925,3844,3791
                        POSITION COUNT OF d is:3944,3835,3870,3750,3741,3856,3873,3796,3863,3801,3790,3739,3938,3888,3879,3866,3789,3 859,3866,3820,3816,3853,3867,3888,3912,3901
                        POSITION COUNT OF e is:3803,3967,3928,3802,3914,3798,3855,3851,3883,3774,3938,3838,3749,3828,3846,3959,3782,3 895,3722,3967,3732,3782,3874,3802,3887,3824
                        POSITION COUNT OF f is:3952,3825,3901,3733,3767,3808,3844,3924,3842,3826,3725,3778,3763,3953,3848,3937,3972,3 939,3916,3741,3866,3942,3875,3828,3778,3717
                        POSITION COUNT OF g is:3870,3888,3817,3772,3809,3875,3875,3838,3893,3922,3746,3782,3853,3894,3745,3820,3780,3 684,3975,3965,3951,3778,3788,3889,3908,3883
                        POSITION COUNT OF h is:3891,3798,3863,3749,3766,3874,3789,3856,3876,3960,3834,3908,3933,3886,3903,3813,3844,3 841,3794,3698,3876,3849,3776,3794,3966,3863
                        POSITION COUNT OF i is:3857,3791,3898,3854,3810,3912,3798,3866,3747,3843,3807,3892,3830,3756,3912,3852,3922,3 762,3871,3852,3828,3969,3823,3848,3773,3927
                        POSITION COUNT OF j is:3859,3953,3801,3928,3847,3785,3783,3831,3736,3817,3733,3810,3816,3900,3848,3948,3874,3 898,3928,3820,3903,3820,3814,3830,3809,3909
                        POSITION COUNT OF k is:3892,3822,3866,3890,3876,3785,3855,3896,3832,3735,3793,3839,3873,3876,3778,3912,3806,3 876,3784,3941,3820,3752,3884,3868,3871,3878
                        POSITION COUNT OF l is:3872,3990,3919,3865,3878,3889,3851,3864,3787,3759,3840,3927,3900,3900,3831,3762,3901,3 870,3764,3714,3748,3797,3788,3896,3759,3929
                        POSITION COUNT OF m is:3913,3834,3963,3771,3812,3860,3870,3881,3843,3902,3876,3795,3766,3728,3865,3771,3816,3 717,3841,3846,4027,3832,3962,3796,3877,3836
                        POSITION COUNT OF n is:3876,3777,3833,3975,3792,3780,3925,3810,3858,3789,3954,3913,3826,3932,3798,3831,3768,3 769,3837,3796,3827,3934,3864,3879,3846,3811
                        POSITION COUNT OF o is:3885,3720,3934,3902,3889,3729,3827,3880,3869,3804,3838,3892,3846,3797,3932,3872,3825,3 849,3772,3971,3832,3773,3873,3888,3826,3775
                        POSITION COUNT OF p is:3858,3930,3834,3949,3954,3849,3961,3914,3805,3719,3804,3767,3870,3798,3870,3851,3760,3 786,3841,3817,3883,3865,3888,3852,3799,3776
                        POSITION COUNT OF q is:3854,3825,3808,3837,4053,3914,3940,3709,3844,3913,3866,3760,3799,3792,3793,3850,3920,3 851,3823,3856,3795,3840,3817,3834,3853,3854
                        POSITION COUNT OF r is:3846,3828,3856,3907,3938,3852,3806,3851,3875,3854,3882,3833,3772,3787,3718,3882,3745,3 772,3815,3956,3826,3866,3897,3869,3958,3809
                        POSITION COUNT OF s is:3814,3877,3734,3809,3962,3792,3738,3957,3899,3902,3840,3935,3868,3765,3934,3778,3800,3 830,3934,3787,3844,3789,3847,3806,3914,3845
                        POSITION COUNT OF t is:3827,3868,3813,3851,3856,3857,3857,3849,3836,3884,3850,3827,3779,3929,3818,3661,3939,3 877,3720,3934,3836,3963,3867,3781,3785,3936
                        POSITION COUNT OF u is:3789,3767,3832,3853,3834,4001,3844,3791,3992,3952,3787,3864,3826,3899,3810,3834,3845,3 892,3842,3799,3754,3949,3831,3891,3777,3745
                        POSITION COUNT OF v is:3803,3931,3845,3860,3832,3932,3837,3892,3885,3894,3858,3907,3801,3776,3860,3839,3859,3 829,3749,3824,3801,3794,3894,3794,3773,3931
                        POSITION COUNT OF w is:3779,3760,3812,3805,3887,3776,3778,3886,3772,3810,3859,3894,3889,3879,3899,3882,3930,3 850,3974,3903,3884,3839,3756,3824,3793,3880
                        POSITION COUNT OF x is:3737,3861,3649,3956,3775,3879,3802,3809,3904,3775,3928,3835,3868,3905,3939,3888,3881,3 892,3876,3831,3908,3723,3772,3895,3857,3855
                        POSITION COUNT OF y is:3785,3906,3774,3745,3734,3884,3856,3730,3858,3937,3927,3835,3945,3856,3864,3903,3826,3 905,3883,3833,3847,3922,3839,3812,3820,3774
                        POSITION COUNT OF z is:3743,3795,3870,3853,3746,3763,3790,3949,3878,3887,3912,3838,3902,3843,3882,3862,3811,3 881,3916,3822,3874,3789,3922,3812,3748,3912
                        • 9. Re: Vector.<*> triggers a "Problem" in Flash Builder but doesn't create an error during runtime.
                          Oops!
                          Just noticed error in my original code as I added one index to the other...
                          WIll test again based on the original.
                          • 10. Re: Vector.<*> triggers a "Problem" in Flash Builder but doesn't create an error during runtime.
                            OK, so your original index is ok. Struggling to see why though...
                            @@@@@ USING i+1 AS PER ORIGINAL FUNCTION @@@@
                            POSITION COUNT OF a is:3813,3756,3805,3886,3896,3827,3820,3838,3847,3813,3879,3841,3816,3872,3909,3894,3849,3 806,3925,3920,3804,3800,3750,3769,3876,3989
                            POSITION COUNT OF b is:3860,3903,3929,3727,3899,3769,3856,3812,3717,3908,3855,3927,3858,3777,3854,3845,3907,3 910,3784,3806,3854,3819,3804,3912,3854,3854
                            POSITION COUNT OF c is:3803,3816,3811,3868,3831,3844,3844,3871,3814,3798,3758,3913,3921,3681,3930,3882,3840,3 928,3871,3846,3807,3926,3843,3859,3907,3788
                            POSITION COUNT OF d is:3843,3919,3981,3759,3746,3755,3753,3898,3913,3717,3779,3848,3905,3863,3759,3834,3876,3 847,3946,3887,3744,3841,3899,3806,3948,3934
                            POSITION COUNT OF e is:3848,3921,3787,3817,3850,3992,3774,3839,3890,3931,3804,3793,3826,3891,3765,3845,3792,3 759,3895,3871,3903,3793,3813,3889,3804,3908
                            POSITION COUNT OF f is:3835,3718,3780,3839,3794,3890,3889,3851,3887,3852,3827,3761,3825,3906,3918,3863,3811,3 799,4019,3913,3798,3942,3941,3806,3774,3762
                            POSITION COUNT OF g is:3813,3913,3907,3823,3876,3750,3868,3874,3764,3857,3818,3817,3867,3821,3802,3849,3825,3 829,3809,3800,3816,3992,3861,3943,3838,3868
                            POSITION COUNT OF h is:3868,3769,3775,3828,3757,3970,3869,3873,3897,3841,3814,3932,3825,3857,3843,3767,3891,3 770,3849,3903,3869,3859,3897,3782,3774,3921
                            POSITION COUNT OF i is:3940,3813,3873,3709,3821,3746,3909,3915,3869,3862,3909,3850,3841,3907,3844,3830,3767,3 809,3902,3836,3858,3768,3776,3867,3919,3860
                            POSITION COUNT OF j is:3957,3911,3927,3880,3904,3822,3831,3863,3847,3835,3833,3706,3898,3812,3807,3910,3748,3 957,3836,3812,3835,3745,3789,3900,3765,3870
                            POSITION COUNT OF k is:3729,3970,3831,3897,3818,3774,3825,3781,3857,3857,3825,3845,3929,3842,3812,3749,3857,3 916,3845,3805,3812,3816,3881,3950,3772,4005
                            POSITION COUNT OF l is:3774,3763,3869,3786,3868,3888,3797,3919,3763,3980,3849,3972,3754,3909,3772,3958,3793,3 876,3804,3862,3915,3818,3820,3862,3899,3730
                            POSITION COUNT OF m is:3755,3877,3947,3897,3792,3838,3847,3940,3858,3909,3805,3768,3806,3877,3861,3761,3921,3 820,3861,3937,3845,3791,3862,3789,3813,3823
                            POSITION COUNT OF n is:4003,3911,3777,3977,3788,3735,3933,3777,3820,3812,3968,3887,3806,3772,3740,3946,3878,3 829,3960,3777,3859,3845,3822,3792,3856,3730
                            POSITION COUNT OF o is:3893,3747,3912,3727,3879,3802,3955,3855,3789,3903,3851,3817,3874,3880,3874,3800,3762,3 736,3838,3850,3875,3822,3842,3863,4009,3845
                            POSITION COUNT OF p is:3834,3762,3895,3863,3831,3841,3850,3853,3948,3792,3779,3827,3910,3869,3900,3858,3893,3 854,3834,3790,3786,3810,3741,3994,3883,3803
                            POSITION COUNT OF q is:3930,3836,3847,3907,3757,3886,3857,3871,3926,3873,3963,3806,3868,3756,3872,3816,3938,3 818,3764,3860,3738,3868,3858,3835,3822,3728
                            POSITION COUNT OF r is:3753,3900,3782,3875,3826,3992,3822,3851,3758,3792,3865,3880,3819,3883,3851,3745,3859,3 931,3823,3830,3910,3884,3880,3816,3782,3891
                            POSITION COUNT OF s is:3782,3888,3956,3877,3970,3874,3892,3853,3882,3825,3775,3891,3731,3718,3839,3941,3829,3 820,3892,3721,3881,3874,3852,3872,3745,3820
                            POSITION COUNT OF t is:3830,3759,3784,3784,3943,3850,3774,3816,3845,3814,3733,3836,3894,3870,3841,3908,3838,3 997,3803,3929,3934,3749,3993,3816,3757,3903
                            POSITION COUNT OF u is:3854,3881,3851,3749,3869,3850,3845,3858,3917,3817,3945,3877,3782,3759,3872,3929,3797,3 923,3859,3842,3870,3798,3956,3739,3860,3701
                            POSITION COUNT OF v is:3899,3875,3837,3862,3895,3814,3841,3891,3844,3833,3833,3812,3816,3918,3893,3850,3924,3 741,3917,3563,3924,3847,3812,3798,3934,3827
                            POSITION COUNT OF w is:3916,3849,3782,3947,3727,3937,3796,3826,3871,3808,3943,3855,3776,3949,3797,3764,3792,3 789,3669,3936,3845,3896,3828,3929,3876,3897
                            POSITION COUNT OF x is:3861,3788,3852,4003,3881,3824,3816,3731,3774,3932,3800,3803,3933,3802,3944,3872,3901,3 906,3688,3808,3798,3918,3887,3815,3782,3881
                            POSITION COUNT OF y is:3801,3970,3781,3861,3862,3812,3870,3762,3892,3799,3926,3871,3912,3894,3812,3761,3895,3 764,3777,3940,3842,3893,3824,3772,3817,3890
                            POSITION COUNT OF z is:3806,3785,3722,3852,3920,3918,3867,3782,3811,3840,3864,3865,3808,3915,3889,3823,3817,3 866,3830,3956,3878,3886,3769,3825,3934,3772
                            • 11. Re: Vector.<*> triggers a "Problem" in Flash Builder but doesn't create an error during runtime.
                              DJ Gecko Level 1
                              I didn't mean to start a discussion about approaches for shuffling an array. I just want to understand why the Vector.<*> and Vector.<Object> are giving errors in Flash Builder but running fine during run time and not giving any errors. I completely understand what an index array is for (Vector Array), but sometimes, as I demonstrated, I do need to use * or Object.
                              Cheers.
