0 Replies Latest reply on Dec 6, 2012 12:21 PM by Abdul_Rasheed
    Cluster Controller exception during DR scenario
    Abdul_Rasheed
      Hi All,
      We have setup a new DR environment as mentioned below. While replicating a DR scenario we found issues with the DR Author.
      • Set three author Instances (Primary , secondary and DR) and one publish instance. <All 3 are on a separate windows machine>
      • Changed the content in DR, it was reflected to the other 2 clustered author Instances and vice-versa. <Cluster works fine>
      • <DR Scenario> Unplugged the Primary and secondary Instance LAN cables.
      • Changed the content in DR server and tried to replicate , which resulted in an exception.
      • Restarted the DR Instance. It was working fine and was a stand alone cluster.
      Error log while we did step 4.
      06.12.2012 00:01:07.261 *ERROR* [0:0:0:0:0:0:0:1 [1354732267246] POST /content/xxx/xxx/jcr:content/par/text_5048 HTTP/1.1] org.apache.sling.servlets.post.impl.operations.ModifyOperation Exception during response processing. java.lang.IllegalStateException: d
      at com.day.crx.core.cluster.ClusterController.checkNotStopped(ClusterController.java:1384)
      at com.day.crx.core.cluster.ClusterController.newCall(ClusterController.java:887)
      at com.day.crx.persistence.tar.ClusterTarSet.call(ClusterTarSet.java:1172)
      at com.day.crx.persistence.tar.ClusterTarSet.lockSend(ClusterTarSet.java:758)
      at com.day.crx.persistence.tar.ClusterTarSet.lockShared(ClusterTarSet.java:655)
      at com.day.crx.persistence.tar.ClusterTarSet.lockShared(ClusterTarSet.java:614)
      at com.day.crx.persistence.tar.ClusterTarSet.lockShared(ClusterTarSet.java:642)
      at com.day.crx.persistence.tar.TarPersistenceManager.tryStore(TarPersistenceManager.java:525 )
      at com.day.crx.persistence.tar.TarPersistenceManager.storeTransaction(TarPersistenceManager. java:500)
      at com.day.crx.persistence.tar.TarPersistenceManager.store(TarPersistenceManager.java:488)
      at org.apache.jackrabbit.core.state.SharedItemStateManager$Update.end(SharedItemStateManager .java:757)
      at org.apache.jackrabbit.core.state.SharedItemStateManager.update(SharedItemStateManager.jav a:1487)
      at org.apache.jackrabbit.core.state.LocalItemStateManager.update(LocalItemStateManager.java: 351)
      at org.apache.jackrabbit.core.state.XAItemStateManager.update(XAItemStateManager.java:354)
      at org.apache.jackrabbit.core.state.LocalItemStateManager.update(LocalItemStateManager.java: 326)
      Is this a known issue with CQ?
      CQ Version used is 5.4
      Appreciate your inputs on this.
      Abdul
