1 Reply Latest reply on Dec 6, 2012 6:50 PM by Ned Murphy
    importing images XML Problem
    TheScarecrow Level 1
      Hey I have an XML file that has images in it.  I am wanting to import the images into flash into arrays then I want place them on the stage. I have it importing corretly I think.  Has anyone done this before and give me any hints at placing the images?  I figure I will have to set a variable to too the function what array to use.  Thanks.
      XML CODE
      <gallery>
                <image id="image01" category = "Registration" url="DSCN2217.JPG" />
                <image id="image02" category = "Registration" url="DSCN2218.JPG" />
                <image id="image03" category = "Registration" url="DSCN2219.JPG" />
                <image id="image04" category = "Registration" url="DSCN2220.JPG" />
                <image id="image05" category = "Registration" url="DSCN2221.JPG" />
                <image id="image01" category = "Banquet" url="DSCN2222.JPG" />
                <image id="image02" category = "Banquet" url="DSCN2223.JPG" />
                <image id="image03" category = "Banquet" url="DSCN2224.JPG" />
                <image id="image04" category = "Banquet" url="DSCN2225.JPG" />
                <image id="image05" category = "Banquet" url="DSCN2226.JPG" />
      </gallery>
      AS3 SCRIPT
      xmlData = new XML();
      xmlData.ignoreWhite = true;
      xmlData.load("images.xml");
      //xmlData.onLoad =loadXML;
      xmlData.onLoad = function(success:Boolean)
                if (success)
                          if (xmlData.status == 0)
                                    regArray = new Array();
                                    banArray = new Array();
                                    var xmlDataToXMLString:String = new String();// initializes a new string variable
                                    xmlDataToXMLString = xmlData.toString();// converts dots XML object to a string and stores it in dotsToXMLString.
                                    var xmlDataXML:XML = new XML(xmlDatadotsToXMLString);// creates new XML object with the string contents from above.
                                    xmlDataXML.parseXML(xmlDataToXMLString);// parses the string from above.
                                    var xmlDataNodes:Object = xmlDataXML.firstChild;// Saves the firstChild (in this case, the outermost element) as an object
                                    var xmlDataNodesChildren:Object = xmlDataNodes.childNodes;// Saves the childNodes of firstChild as an object
                                    for (i = 0; i < xmlDataNodesChildren.length; i++)
                                              switch (xmlDataNodes.childNodes[i].attributes.category)
                                                        case "Registration" :
        xmlNodeID = xmlDataNodes.childNodes[i].attributes.ID;
        xmlNodeURL = xmlDataNodes.childNodes[i].attributes.url;
        //regArray = new Array();
        regArray.push({id:xmlNodeID, url:xmlNodeURL});
        //trace(xmlDataNodes.childNodes[i]);
        break;
                                                        case "Banquet" :
        banArray.push({id:xmlNodeID, url:xmlNodeURL});
        break;
                                              //trace(xmlDataNodes.childNodes[i].attributes.category);
                                    trace(regArray);
                                    trace(banArray);
                          else
                                    trace("Problem parsing XML.");
                else
                          trace("Could not load XML");
      function placeImages() {
