3 Replies Latest reply on Dec 6, 2012 10:41 PM by csm_phil
    find and change GREP
    hurix@123 Level 1
      I have find and change the paragraph marks using GREP using Javascript  ["~b~b+", "\\r"] // Multiple Return to Single Return
      But i want to add spaceAfter using GREP javascript below is my code:
      app.findGrepPreferences = NothingEnum.nothing;
      app.changeGrepPreferences = NothingEnum.nothing;
      app.findGrepPreferences.findWhat = "~b~b+";
      app.changeGrepPreferences.changeTo = "/r", "spaceAfter = 1.5"; (This is not updated while execute the script)
      Hurix
      Message was edited by: hurix@123
        • 1. Re: find and change GREP
          csm_phil Level 4
          Hi Hurix@123,
          Use the below line for remove the multile enter mark. You have to try to add the after space in your end.
          app.findGrepPreferences.findWhat = "(?<=\\r)\\r+";
          app.changeGrepPreferences.changeTo = "";
          app.activeDocument.changeGrep();
          The below line is wrong. you have to use \\r.
          thx,
          csm_phil
          • 2. Re: find and change GREP
            hurix@123 Level 1
            Hi csm_phil,
            correct answer.
            and also  i have to change the format SPACEABOVE = 1.5MM
            please suggest me.
            Hurix
            • 3. Re: find and change GREP
              csm_phil Level 4
              Hi Hurix@123,
              First, whatever you try you end, don't expect everything in the forum. Otherwise you never learn. this is my suggestion only.
              And you wrote the correct answer is not a important, you just click the option is correct or help full answer.
              app.findGrepPreferences.findWhat = "\\r+(?<=\\r)";
              app.changeGrepPreferences.spaceAfter = "1.5";
              thx,
              csm_phil
