3 Replies Latest reply on Dec 10, 2012 2:45 AM by [Jongware]
    How to get default dictionary for Active document
    RajGaikwad
      we want to write a script to get default Dictionary for active InDesign document.
      we are getting it by manual way that:
      Edit => Preferences => Dictionary => Language drop down
      but how can we do this task by using Java script.
      We tried by using Document.DictionaryPreferences but not getting the value.
      so please help me out to get the Default Dictionary language from active document
        • 1. Re: How to get default dictionary for Active document
          Cenchen Level 2
               I am geeting all languages list but can't able to assign the value. Maybe its readonly property.
          var len = app.languagesWithVendors.length;
          var arr = []
          for(var i=0;i<len;i++)
              arr.push(app.languagesWithVendors.item(i).name)
          arr = arr.toString().replace(/,/g,"\n");
          alert(arr)
          • 2. Re: How to get default dictionary for Active document
            Jump_Over Level 5
            myLanguages = app.languagesWithVendors // every app languages
            myLanguage = myLanguages[10]     // language with index = 10; use any you want
            myDoc.textDefault.appliedLanguage = myLanguage;     //this set default language for a new text in myDoc
            maybe not exactly what you wanted...
            • 3. Re: How to get default dictionary for Active document
              The OP is misunderstanding the purpose of this Preference field.
              This is not true. This preference dialog is to set a preference for a language. The 'selected item' here has no relation at all with the "active InDesign document" (other than that the selected language may be used in the active document).
              So you don't get "the" default dictionary, you get "a" default dictionary -- for the very first language in the list. If your intention is to get "the" default dictionary per language in your document, you have to
              1st: gather a list of all used languages in your document, and
              2nd: find out the dictionary for each of them.
              (neither of which I have a good one-liner for).
              Without further clarification from the OP, we might never know.
