0 Replies Latest reply on Jul 16, 2006 2:14 PM by cmyck
    Not getting my sources listed with fdb
    cmyck Level 1
      I am trying to get fdb working with a little test project.
      From using "help run" with fdb I found this:
      On the Macintosh, the only supported form of the command is 'run' with no
      arguments. You must then manually launch the Flash player.
      So I compile the swf with the debug=true option, type run in the running fdb and then open the swf in the standalone debug player.
      I get:
      fdb) run
      Waiting for Player to connect
      Player connected; session starting.
      Set breakpoints and then type 'continue' to resume the session.
      [SWF] Volumes:Work:Jobs:Sichtwerk other:SWAdmin Project:SWAdmin:bin:SWAdmin.swf - 420,100 bytes after decompression
      (fdb)
      Now, I am supposed to set some breakpoints. If I then use "info files" I get some list but my class Test.as isn't listed nor is anything contained in SWAdmin.mxml.
      Any pointers in the right direction would be appreciated.
      Cheers,
      Phil
