4 Replies Latest reply on Dec 12, 2012 12:24 PM by skatcat1
    Failure to install the update for Adobe Flash Player "A required file (:3) could not be installed."
    skatcat1
      I've bee trying to install the update for Adobe Flash Player for some time and keep getting install failed....."A required file (:3) could not be installed."  Of course I'm going to the suggested installation problems website but nothing there seems to address this specfic failure mode.  Can anybody help?
      Windows 7, IE9 browser
      Message was edited by: skatcat1
        • 1. Re: Failure to install the update for Adobe Flash Player "A required file (:3) could not be installed."
          pwillener Level 8
          Could you post the contents of the FlashInstall.log file from C:\Windows\system32\Macromed\Flash
          • 2. Re: Failure to install the update for Adobe Flash Player "A required file (:3) could not be installed."
            skatcat1 Level 1
            Pat.....Thanks for the response.  I found the file your requesting, but can't find a way to attach it to this post.  How can I get it to you?  Also, do you want the file folder w/contents or the contents copy/pasted?
            • 3. Re: Failure to install the update for Adobe Flash Player "A required file (:3) could not be installed."
              pwillener Level 8
              Sorry, this forum does not allow attachments.  Just paste the last 50 or so lines of the file's contents.
              • 4. Re: Failure to install the update for Adobe Flash Player "A required file (:3) could not be installed."
                skatcat1 Level 1
                Can't seem to post it to the forum directly, so maybe this will get through:
                =O====== M/11.1.102.55 2011-11-29+21-25-19.819 ========
                0000 00000010
                "C:\Users\Dennis\AppData\Local\Temp\install_flash_player_ax_64bit.exe" -dlm
                -install
                0001 00001036 Software\Macromedia\FlashPlayer\SafeVersions/11.0 2
                0002 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
                0003 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
                0004 00000020 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
                0005 00001037 SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe
                Flash Player ActiveX/ 2
                0006 00000013 C:\Windows\system32\Macromed\Flash\Flash64_11_1_102.ocx
                0007 00000015
                C:\Windows\system32\Macromed\Flash\FlashUtil64_11_1_102_ActiveX.exe
                0008 00000016
                C:\Windows\system32\Macromed\Flash\FlashUtil64_11_1_102_ActiveX.dll
                0009 00000019 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
                0010 00000011 1
                =X====== M/11.1.102.55 2011-11-29+21-25-24.321 ========
                =O====== M/11.1.102.55 2011-11-30+06-27-03.194 ========
                0000 00000010
                -install
                0001 00001041
                =X====== M/11.1.102.55 2011-11-30+06-27-03.356 ========
                =O====== M/11.1.102.55 2011-11-30+06-28-34.314 ========
                0000 00000010
                -install
                0001 00001041
                =X====== M/11.1.102.55 2011-11-30+06-28-34.453 ========
                =O====== M/11.1.102.55 2011-11-30+06-28-59.623 ========
                0000 00000010
                -install
                0001 00000020 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
                0002 00001040 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
                =X====== M/11.1.102.55 2011-11-30+06-28-59.781 ========
                =O====== M/11.1.102.55 2011-11-30+06-37-36.210 ========
                0000 00000010
                -install
                0002 00000013 C:\Windows\system32\Macromed\Flash\Flash64_11_1_102.ocx
                0003 00001024 C:\Windows\system32\Macromed\Flash\Flash64_11_1_102.ocx 183
                0004 00000015
                0005 00001024
                C:\Windows\system32\Macromed\Flash\FlashUtil64_11_1_102_ActiveX.exe 183
                0006 00000016
                0007 00001024
                C:\Windows\system32\Macromed\Flash\FlashUtil64_11_1_102_ActiveX.dll 183
                0008 00000019 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
                0009 00000011 1
                =X====== M/11.1.102.55 2011-11-30+06-37-40.431 ========
                =O====== M/11.2.202.235 2012-05-12+03-59-10.853 ========
                0000 00000010
                "C:\Users\Dennis\AppData\Local\Temp\install_flash_player_ax_64bit.exe" -iv 8
                -install -au 1
                0002 00001015 C:\Windows\system32\Macromed\Flash\Flash64_11_1_102.ocx 5
                0003 00000018
                0004 00001015 C:\Windows\system32\Macromed\Flash\Flash64_11_1_102.ocx 5
                0005 00001015
                C:\Windows\system32\Macromed\Flash\FlashUtil64_11_1_102_ActiveX.exe 5
                0006 00000013 C:\Windows\system32\Macromed\Flash\Flash64_11_2_202_235.ocx
                0007 00000015
                C:\Windows\system32\Macromed\Flash\FlashUtil64_11_2_202_235_ActiveX.exe
                0008 00000016
                C:\Windows\system32\Macromed\Flash\FlashUtil64_11_2_202_235_ActiveX.dll
                0010 00000011 1
                0011 00000012
                =X====== M/11.2.202.235 2012-05-12+03-59-15.768 ========
                =O====== M/11.2.202.235 2012-07-18+18-26-40.707 ========
                0000 00000010
                "C:\Windows\system32\Macromed\Flash\FlashUtil64_11_2_202_235_ActiveX.exe"
                -maintain activex
                0001 00001011
                =X====== M/11.2.202.235 2012-07-18+18-26-46.808 ========
