1 Reply Latest reply on Dec 8, 2012 4:35 PM by Peter Kahrel
    Find/replace first occurrence of text
    CrossLM
      I need some help to get me started with writing a script which searches for a string and replaces only the first occurrence of the text found.
      The document (as received from my customer) contains an index, like this (very common):
      Abc
      Apo
      Axy
      Bee
      Bri
      Byq
      I want to find the first occurence of A and B and C and so on and change that to the following result:
      A
      Abc
      Apo
      Axy
      B
      Bee
      Bri
      Byq
      I have looked at the example scripts of InDesign CS3, like 'ChangeText':
      //Search the document for the string "copy" and change it to "text".
      app.findTextPreferences.findWhat = "copy";
      app.changeTextPreferences.changeTo = "text";
      app.documents.item(0).changeText();
      But that script changes all text found and I can't figure out how to change the first occurrence only.
      Can someone give a clue how to solve this?
      Thanks and regards,
      Bert
        • 1. Re: Find/replace first occurrence of text
          Peter Kahrel Adobe Community Professional & MVP
          If your index doesn't contain any formatting and if each topic name starts with an upper-case letter, you can use this grep query:
          Find what: ^(\u).+\r(\1.+\r)+
          Change to: $1\r$0
          Here's a breakdown:
          ^        from beginning of paragraph
          (\u)     upper-case letter, create referent (the referent is created by the parentheses)
          .+        any characters. . .
          \r        . . .up to and including the paragraph mark
                    (up to here the code says 'match a paragraph that starts with a uc letter)
          (         begin grouping
             \1    reference to the first variable, that's the uc letter
             .+\r  again to the end of the paragraph, including the paragraph mark
          )          close the group
          +          repeat at least once
          Do this in the interface and you'll see that each time you press Find, a block of paragraphs is selected that start with the same letter.
          The Change to expression says 'replace the block with the captial we matched followed by a retrurn and the whole group'.
          As I said, this works only on unformatted text, and non-letters (quotation marks, brackets, etc.) spoil things. To cope with these situations you need some script.
          Peter
