1 Reply Latest reply on Dec 10, 2012 12:30 PM by rush_pawan
    HtmlRules DocType node ignored for Rich Text Editor
    bjsswanson10
      The widget api suggests that you can change the default wrapping tag for the rich text editor content via the DocType object on the HtmlRules object under a rich text editor:
      defaultEditBlock : String
      The default edit block type to use; defaults to "p" Added in CQ 5.4.
      I need to change this so that I can include the content of a rich text editor field within a p tag which has a particular class (you cannot put one p tag inside another so the automatic wrapping breaks out of my predefined p tag).
      Unfortunatly it would seem that this node is being ignored.
      What do I need to do to remove the p tags or if not that then change them to something that would go inside a p tag?
      The following is the xml for the rich text editor, the rtePlugins node seems to work correctly but not the htmlRules node.
      <introText
                                         jcr:primaryType="cq:Widget"
        allowBlank="{Boolean}false"
        fieldLabel="Intro text"
        name="./introText"
        xtype="richtext">
        <htmlRules jcr:primaryType="nt:unstructured">
        <docType jcr:primaryType="nt:unstructured"
        defaultEditBlock="span">
        </docType>
        </htmlRules>
        <rtePlugins jcr:primaryType="nt:unstructured">
        <edit
        features="[cut,copy,paste-default, paste-plaintext]"/>
        <format
        features="[]"/>
        <justify
        features="[]"/>
        <lists
        features="[]"/>
        </rtePlugins>
      </introText>
