7 Replies Latest reply on Dec 11, 2012 12:07 PM by gkaiseril
    keeping a field empty
    James A Hiltz CET Level 1
      the following expression works but if the fields "wd2" and "m2" are accidentally filled in and then deleted the event value displays 0.0
      my goal is simple. if the fields are filled in then deleted the event field should read " ".
      var m2 = getField("M_2").value; var wd2 = +getField("WD_2").value; if (wd2 === "0.0") { event.value = " "; } else { event.value = (m2 / (wd2 - m2) * 100); }
        • 1. Re: keeping a field empty
          George_Johnson MVP & Adobe Community Professional
          The following expression should never evaluate to true:
          if (wd2 === "0.0")
          When this previous line of code is executed:
          The value in the variable wd2 is a number, so the strict comparison to the string "0.0" will always be false. I'm not entirely sure how you'd like this to behave, but I think the following should do it"
          // Get the field values, as numbers
          var m2 = +getField("M_2").value;
          // If wd2 is blank or zero, set this field to a single space
          if (wd2 === 0) {
              event.value = " ";
          } else {
              //...otherwise, set this field value to the result of the following calculation
          I suspect you may want something else. If so, please give more details.
          • 2. Re: keeping a field empty
            Hi George,
            Thank you for the reply.
            What you provided me dose work nicely however, I receive the error message “The value does not match the format of the event field” and the event field will not clear if the numbers are removed from wd2 and m2.
            Any suggestions?
            James A Hiltz CET
            Construction Quality Control, RSO
            Untitled
            [removed personal information]
            Proud to be recognized as one of Canada’s top 50 small & Medium Employers.
            Message was edited by: sinious
            • 3. Re: keeping a field empty
              Why do you want to set the value of the field to a single space, as opposed to blank?
              • 4. Re: keeping a field empty
                Actually I do want it to be a blank space but it comes up as a single space.
                I guess I am missing a something.
                James A Hiltz CET
                Untitled
                • 5. Re: keeping a field empty
                  Because your original code used a single space, that's what I did. If you don;t want that, just remove it in the code so that that one line becomes:
                  event.value = "";  // Blank this field
                  And the error should go away as well.
                  BTW, it seems you're responding by email. When you do that your signature lines are included. They contain some personal info that you might not want displayed in a public forum. I will report this to a moderator so that it will be removed, but you might want to do the same. This issue can be avoided if you reply via the forum instead of email.
                  • 6. Re: keeping a field empty
                    George,
                    Thank you that fixed my small issue.
                    James A Hiltz CET
                    Untitled
                    8212 Manning Aveenue
                    Fort McMurray, Alberta
                    T9H 1V9
                    Email: Jim.hiltz@terracon.ca
                    Ph: 780-743-9343
                    Fax: 780-743-2420
                    • 7. Re: keeping a field empty
                      You should only run your script with a non-zero divisor.
                      event.value = ""; // defalut value
                      // If wd2 is blank or zero set this field to a single space
                      if (wd2 == 0)  {
                          event.value = " ";
                      // do not calculate if m2 is zero or wd2 - m2 is zero
                      if( ((wd2 - m2) != 0) && (m2 != 0) ) {
