3 Replies Latest reply on Dec 11, 2012 9:05 AM by lithodora
    Creating Styles.. and then nesting styles
    lithodora
      Seems simple enough:
      tell application "Adobe InDesign CS5.5"
      tell active document
        set myCharacterStyle to make character style with properties {name:"Year", size:26.0, fill color:"Paper", stroke color:"Black", stroke weight:0.75, font:"Helvetica", font style:"Black"}
        set myCharacterStyle to make character style with properties {name:"Years", size:18.0, fill color:"Black", stroke color:nothing, stroke weight:nothing, horizontal scale:80.0, vertical scale:80.0, font:"Helvetica", font style:"Black"}
        set myParagraphStyle to make paragraph style with properties {name:"Year"}
        set nested styles of myParagraphStyle to {{applied character style:"Year", repetition:1, inclusive:false, delimiter:any word}, {applied character style:"Years", repetition:2, inclusive:true, delimiter:any word}}
      end tell
      end tell
      The font and the point size do not come through when the style is created. The nested styles also do not come through.
      I tried applied font:"Helvetica" to get 'font family not available'. Also, font:font "Helvetica"...
      What I get right now I is no font defined or size. The rest works.
      So what am I doing wrong here?
        • 1. Re: Creating Styles.. and then nesting styles
          Mary Posner Level 3
          Try this:
          applied font: "Helvetica     Black"
          Note that there's a tab between the font name and the font style.
          • 2. Re: Creating Styles.. and then nesting styles
            -hans- Level 4
            Hi lithodora,
            as Mary Posner wrote a character style doesn't have the property 'font', but 'applied font' and 'font style'.
            "... specified as either a font object or the name of font family."
            just look it up in the dictionary ...
            Try always to work with references.
                --you've got to set myHelvetica to your needs!
                set myHelveticas to (font family of every font whose name contains "Helvetica") --will return the helvetica font familiy names
                set myHelvetica to item 1 of myHelveticas --just randomly pick one for my example, hoping it's got a 'black' style ;-) ...
                    set myCharacterStyle01 to make character style with properties {name:"test", size:26.0, fill color:"Paper", stroke color:"Black", stroke weight:0.75, applied font:myHelvetica, font style:"Black"}
                    set myCharacterStyle02 to make character style with properties {name:"tests", size:18.0, fill color:"Black", stroke color:nothing, stroke weight:nothing, horizontal scale:80.0, vertical scale:80.0, applied font:myHelvetica, font style:"Black"}
                    set myParagraphStyle to make paragraph style with properties {name:"nextTest"}
                    tell myParagraphStyle
                        make new nested style with properties {applied character style:myCharacterStyle01, repetition:1, inclusive:false, delimiter:any word}
                        make new nested style with properties {applied character style:myCharacterStyle02, repetition:2, inclusive:true, delimiter:any word}
                    end tell
                end tell
            end tell
            • 3. Re: Creating Styles.. and then nesting styles
              lithodora Level 1
              Thank you for the help!
              I had tried the applied font first, but had changed my approach due to the properties returned of the existing style. It didn't have a property for applied font, but did have font. That is why I had gone that way.
              Rather than use a repeat to step through every Helvetica till I come up with one that works I have followed what Mary posted which works. I can't believe I forgot to use the Tab.
              Again, thank you both for the help.
