1 Reply Latest reply on Jan 22, 2013 10:26 AM by $Nith$
    Unable to use component in workbench
    prasaxen Level 1
      I developed a sample component with a single service and 2 operations mapped to 2 methods of implementation class.
      Also  i tried using composite editors in component.xml and also used property-editor tags.
      Component gets installed properly and start properly.
      Even when i try to put operations on process map, both operations comes, but as soon as i click on process properties it gets hanged, nothing happens it shows Input and Ouput sections are loading but nothing happens....
      My component.xml file looks like as:-
      <component xmlns="http://adobe.com/idp/dsc/component/document">
          <component-id>com.tcs.sample.customer</component-id>
          <version>${project.version}</version>    <!--Pick up version from project pom.xml-->
          <!--<load-class>com.tcs.impl.CustomerServiceImpl</load-class> -->
          <bootstrap-class>com.tcs.BootstrapService</bootstrap-class>
          <lifecycle-class>com.tcs.LifecycleService</lifecycle-class>
          <descriptor-class>com.adobe.idp.dsc.component.impl.DefaultPOJODescriptorImpl</descriptor- class>
          <search-order>PARENT_LAST</search-order>
          <!--<class-path></class-path> Include external jar if you've dependencies-->
          <supports-export>true</supports-export>
          <export-packages>
              <package>com.tcs.impl</package>
              <package>com.tcs.model</package>
          </export-packages>
          <data-types>
              <data-type java-class="com.tcs.model.Customer" id="com.tcs.model.Customer" standard="true"/>
              <data-type java-class="com.tcs.model.GenderTypes" id="com.tcs.model.GenderTypes" standard="true"/>
          </data-types>
          <editors>
              <composite-editor id="CustomerEditorType">
                  <composite-type>com.tcs.model.Customer</composite-type>
                  <attributes>
                      <attribute name="firstName" title="First Name"/>
                      <attribute name="lastName" title="Last Name"/>
                      <attribute name="age" title="Age">
                          <property-editor editor-id="com.adobe.idp.dsc.propertyeditor.system.SpinnerPropertyEditorComponent"/>
                      </attribute>
                      <attribute name="dob" title="Date of Birth">
                          <property-editor editor-id="com.adobe.idp.dsc.propertyeditor.system.CalendarPropertyEditorComponent"/>
                      </attribute>
                  </attributes>
              </composite-editor>
          </editors>
          <services>
              <service name="customer" title="Customer Service" orchestrateable="true">
                  <implementation-class>com.tcs.impl.CustomerServiceImpl</implementation-class>
                  <request-processing-strategy>SINGLE_INSTANCE</request-processing-strategy>
                  <supported-connectors>REST,SOAP</supported-connectors>
                  <specifications>
                      <specification spec-id="com.tcs.CustomerService"/>
                  </specifications>
                  <hint>customer service custom component</hint>
                  <auto-deploy category-id="Customer" service-id="customer" minor-version="0" major-version="1"/>
                  <config-parameter name="sample" type="java.lang.String" title="Sample config param for customer">
                      <hint>sample config param</hint>
                  </config-parameter>
                  <operation-config>
                      <operation-name>*</operation-name>
                      <transaction-type>Container</transaction-type>
                      <transaction-propagation>Supports</transaction-propagation>
                  </operation-config>
                  <operations>
                      <operation anonymous-access="true" name="createCustomer" method="createCustomer">
                          <input-parameter name="customer" type="com.tcs.model.Customer" title="customer">
                              <property-editor editor-id="CustomerEditorType"/>
                              <supported-expr-types>Variable</supported-expr-types>
                          </input-parameter>
                          <input-parameter name="genderTypes" type="com.tcs.model.GenderTypes" title="gender">
                              <property-editor editor-id="com.adobe.idp.dsc.propertyeditor.system.Enum"/>
                          </input-parameter>
                          <output-parameter name="customerId" type="int"/>
                      </operation>
                      <operation anonymous-access="true" name="getCustomerName" method="getCustomerName">
                          <input-parameter name="customerId" type="int" title="customerId">
                              <supported-expr-types>Literal,XPath,Template,Variable</supported-expr-types>
                          </input-parameter>
                          <output-parameter name="name" type="java.lang.String"/>
                      </operation>
                  </operations>
              </service>
          </services>
      </component>
      And contract of project is as
      public interface CustomerService {
          public int createCustomer(Customer customer, GenderTypes genderTypes);
          public String getCustomerName(int customerId);
      And model class is Customer with proper getters and setters for firstName,lastName,age,gender,dob
      GenderTypes is a ENUM with Male, Female as values.
      Please help me.
      Prashast
        • 1. Re: Unable to use component in workbench
          $Nith$ Level 4
          I hope you have created a basic (simple) DSC component.
          In the xml you have mentioned about two more class definitions "bootstrap-class" and "lifecycle-class".
          have you created those classes?
          If not, just remove those entries from the xml and deploy the component again. For a basic DSC you need not write any bootstrap/lifecycle implementations.
          Nith
