18 Replies Latest reply on Apr 4, 2018 7:39 AM by SiWinter
    Photoshop CS6 - Batch function will not save files
    SusanSherman Level 1
      OK, I have used the "Automate/Batch" function well over a hundred times, so this situation (first time using it in CS6) is VERY frustrating!
      Running Adobe CS6 extended v. 13.0.1 x32 on a Win XP sp3 OS.
      I have a slew of photos that need nothing done except to resize from the native file size to 6 in x 4 in @ 150 ppi and save into a new folder (to not override the original).  I have recorded the action multiple times now and each time I run the action, the files do not save! Here are the various parameters I've used:
      Attempt #1:
           Action Steps Recorded -
        • Open
        • Save for web (set size parameters here)
        • Close
            Batch settings -
        • Play Set: correct folder selected; Action: correct action selected
        • Source: folder - selected folder where native files are located (on desktop)
        • NO checkmarks next to any options
        • Destination: folder - selected folder where small files should be saved (on desktop)
        • NO checkmark on override action
        • Did not change file naming parameters
      Result #1 - DID NOT SAVE FILES
      Attempt #2:
        • Open
        • Close
           Batch settings -
        • Cehckmark override Action "Open" commands
      Result #2 - DID NOT SAVE FILES
      Attempt #3:
        • Open
        • Close
            Batch settings -
        • Checkmark override action "Open" commands
        • Checkmark override action "Save As" commands
      Result #3- DID NOT SAVE FILES
      Attempt #4:
        • Open
        • Image Size (set parameters here)
        • Save as (set folder location here)
        • Close
           Batch settings -
        • Checkmark override Action "Open" commands
      Result #4- DID NOT SAVE FILES
      Attempt #5:
        • Open
        • Close
             Batch settings -
      Result #5- DID NOT SAVE FILES
      Please help!  This has never been a problem before CS6 and I truly am at my wits end trying to figure out why the files will not save.  I have several hundred files that I need to run this on, so doing it individually is not an option.
      Thanks in advance for any and all insights!
