6 Replies Latest reply on Dec 14, 2012 10:23 AM by areohbee
    Nikon Capture NX or Camera Raw
    sergtomas
      Using Nikon Capture NX, Camera Raw best for photos?
        • 1. Re: Nikon Capture NX or Camera Raw
          areohbee Level 5
          Consider clarifying your question.
          Are you asking if ACR is better than NX2?
          If so, I'd say in many ways: yes; in other ways: no.
          Rob
          • 2. Re: Nikon Capture NX or Camera Raw
            Yammer Level 4
            I ditched Capture NX years ago because it was much slower on my computer. I was having to wait seconds for preview updates, where CR was instantaneous. No competition. I haven't tried it recently, but then I'm very happy with CR, which has evolved in all the right ways.
            I am finding CR slower at the moment, but then I'm probably due for a hardware upgrade soon. I'll keep putting this off as long as possible, but software developers have this way of forcing your hand ;-)
            • 3. Re: Nikon Capture NX or Camera Raw
              oli.die
              ACR has the better workflow. By far. There's only one problem that I can't manage in ACR: bright blue light. Whenever this comes up I have to fire up NX2. Luckily this does not happen too often. The attached exemple was made during CS5 days. CS6 still hast the same problem.
              • 4. Re: Nikon Capture NX or Camera Raw
                areohbee Level 5
                oli.die wrote:
                ...bright blue light...
                Does this happen regardless of camera profile chosen? - consider bringing this to Adobe's attention (e.g. Eric Chan) independently (e.g. new thread here, or adobe feedback site), if you haven't already.
                • 5. Re: Nikon Capture NX or Camera Raw
                  oli.die Level 1
                  No, I have not brought this to Adobe's attention but I will now. I have always used the latest Process (2010 CS5 OR 2012 CS6) und Adobe Standard camera profil. Will check again.
                  Thanks!
                  • 6. Re: Nikon Capture NX or Camera Raw
                    areohbee Level 5
                    Indeed different profiles have different ways of handling things, especially at the extremes - especially when one or more channels is clipped.
                    In addition to comparing profile behavior, consider the point curve in ACR - @Lr4 we can now reshape the curves on a channel by channel basis, and that way fix many of these types of problems - admittedly such changes may need to be done uniquely for each photo.
                    And of course if (Adobe Standard) profile needs a tweak for handling such end cases, Adobe may be open to that... - if not for older cameras (in which case such a tweak might change the appearance of already-edited photos), at least for newer ones.
                    R
