12 Replies Latest reply on Dec 20, 2012 2:08 AM by Laubender
    How I can generate a report of pictures coordinates?
    Patrick Gaudreault
      I need to extract the top left corner and bottom right corner coordinates of pictures in a document, with page number and images name.
      I understand the way geometricbounds works, but I'm unable to understand how the images are bound with the coordinate.
      Can Anyone help me!
        • 1. Re: How I can generate a report of pictures coordinates?
          -hans- Level 4
          I guess you mean the coordinates of the masked images = coordinates of a page item¿
          app.activeDocument.allGraphics will return a array of all graphics.
          check if parent of the graphic is a page item and get the geometric- or visual bounds. returned Bounds: [y1,x1,y2,x2]. so get the pairs for topleft and bottomright.
          The graphic itsself has got the properties parentPage and name.
          So you've got all you want.
          Hans-Gerd Claßen
          • 2. Re: How I can generate a report of pictures coordinates?
            -hans- Level 4
            You may try this snippet:
            #target Indesign
            //check for active Document
            if(app.documents.length != 0){
               var currDoc = app.activeDocument;
               //array to catch infos
                var  graphicsInfos = [];
                  }else{
                      //no open document
                   exit();}
            //necessary
            currDoc.zeroPoint = [0,0];
            //get Measurement Units as string, set ruler Origin to Page
            with(currDoc.viewPreferences){
                var hUnit = horizontalMeasurementUnits.toString();
                var vUnit = verticalMeasurementUnits.toString();
                rulerOrigin    =  RulerOrigin.PAGE_ORIGIN;
                //get all graphics of document
            var getGraphics = currDoc.allGraphics;
            for(var i = 0; i < getGraphics.length; i++){
                //create object to store graphic infos
                currInfo = new Object();
            currGraphic = getGraphics[i];
            //Position, on page
            currInfo['Position'] = 'NaN'
            if(currGraphic.parent.hasOwnProperty('visibleBounds')){
                currParentBounds = currGraphic.parent.visibleBounds;
                topLeft = '' + currParentBounds[1] + ' ' + hUnit + ' / ' + currParentBounds[0] + ' ' + vUnit;
                bottomRight =  '' + currParentBounds[3] + ' ' + hUnit + ' / ' + currParentBounds[2] + ' ' + vUnit;
                currInfo['Position'] = 'Position\n topLeft: ' + topLeft + ' | ' + 'bottomRight: ' + bottomRight;
                currInfo['Page'] = 'Page: ' + currGraphic.parentPage.name;
                currInfo['Name'] = 'Name: ' + currGraphic.itemLink.name;
                //store infos of graphic in array
            graphicsInfos.push(currInfo) ;
            //arrayToString
            l = graphicsInfos.length;
            newString = currDoc.name + '\n';
            while(l--){
                newString = newString + graphicsInfos[l].Name + '\n' + graphicsInfos[l].Page + '\n' + graphicsInfos[l].Position + '\n\n'
            //write file
                var _file = new File('~/Desktop/' + currDoc.name.replace(/indd/, '') + 'txt');
                    _file.open( 'w' );
                    _file.encoding = 'UTF-8';
                _file.write( newString );
                _file.close();
            Report will be saved on the desktop. Indesign-Documentname + txt
            Hope it'll run
            Hans-Gerd Claßen
            • 3. Re: How I can generate a report of pictures coordinates?
              Patrick Gaudreault Level 1
              Hi Hans, it didn't work, but I came up with this script, but I need to add page number
              Here's the script I came up:
              app.activeDocument.viewPreferences.rulerOrigin = RulerOrigin.PAGE_ORIGIN;
              list = [];
              imgs = app.activeDocument.allGraphics;
              unitname = getCurrentUnit();
              for (i=0; i<imgs.length; i++)
              left = imgs[i].parent.geometricBounds[1];
              top = imgs[i].parent.geometricBounds[0];
              bottom = imgs[i].parent.geometricBounds[3];
              right = imgs[i].parent.geometricBounds[2];
              // some fair rounding
              switch (unitname)
                case 'px':
                 left = roundMe(left, 1);
                 top = roundMe(top, 1);
                 bottom = roundMe(bottom, 1);
                 right = roundMe(right, 1);
                 break;
                case 'in':
                 left = roundMe(left, 2);
                 top = roundMe(top, 2);
                 bottom = roundMe(bottom, 2);
                 right = roundMe(right, 2);
                 break;
                default:
              list.push (imgs[i].itemLink.name+'\t'+'('+left+','+top+')'+'\t('+bottom+','+right+')' );
              // alert (list.join('\r')); exit();
              defaultFile = new File (Folder.myDocuments+"/"+app.activeDocument.name.replace(/\.indd$/i, '')+".txt");
              if (File.fs == "Windows")
              writeFile = defaultFile.saveDlg( 'Save report', "Plain text file:*.txt;All files:*.*" );
              else
              writeFile = defaultFile.saveDlg( 'Save report');
              if (writeFile != null)
              if (writeFile.open("w"))
                writeFile.encoding = "utf8";
                writeFile.write (list.join("\r")+"\r");
                writeFile.close();
              function roundMe(val,to)
              var t = 1;
              while (to-- > 0) t *= 10;
              return Math.round(val*t)/t;
              function getCurrentUnit ()
              switch (app.activeDocument.viewPreferences.horizontalMeasurementUnits)
                case MeasurementUnits.POINTS: return "pt";
                case MeasurementUnits.PICAS: return "pt";
                case MeasurementUnits.INCHES: return "in";
                case MeasurementUnits.INCHES_DECIMAL: return "in";
                case MeasurementUnits.MILLIMETERS: return "mm";
                case MeasurementUnits.CENTIMETERS: return "cm";
                case MeasurementUnits.CICEROS: return "c";
                case MeasurementUnits.AGATES: return "ag";
                case MeasurementUnits.PIXELS: return "px";
                default: alert ("Oh, come on!"); exit(0);
              It's working, but I need the page number and I don't know how to insert the page number.
              Have any idea?
              Thanks for your help!
              Patrick
              • 4. Re: How I can generate a report of pictures coordinates?
                Sajeev Sridharan Level 4
                Try this:
                list = [];
                currInfo = 'Page: ' + imgs[i].parentPage.name;
                switch (unitname)
                  case 'px':
                   break;
                  case 'in':
                   break;
                  default:
                list.push (imgs[i].itemLink.name+'\t'+'('+left+','+top+')'+'\t('+bottom+','+right+')' + '\t' + currInfo);
                else
                  writeFile.close();
                var t = 1;
                Vandy
                • 5. Re: How I can generate a report of pictures coordinates?
                  -hans- Level 4
                  it's tested for ID CS 5.5 Mac & PC -> Runs fine here.
                  (Won't run CS4 & prior)
                  Have a nice day
                  Hans-Gerd Claßen
                  • 6. Re: How I can generate a report of pictures coordinates?
                    Thanks everyone for your help!
                    The script works, but I don't know why, I have an Error Number 21
                    The script works with some files, but not with other. I don't understand why!
                    Also, I need to get the pictures from a specified layer.
                    Anyone have a suggestion?
                    I've worked with the script from Vandy.
                    Patrick
                    • 7. Re: How I can generate a report of pictures coordinates?
                      @Patrick – if "parentPage" returns "null", it means, that the object (the image, better: the  container that hold the image) resides on the pasteboard.
                      And therefore there could be no "parentPage".
                      Uwe
                      • 8. Re: How I can generate a report of pictures coordinates?
                        Thanks for the tips, an image was left outside the pasteboard!
                        The only thing left is to select only the pictures on a layer.
                        Have any idea about the script, I didn't find anything.
                        Thank you for your help!
                        Patrick
                        • 9. Re: How I can generate a report of pictures coordinates?
                          -hans- Level 4
                          a layer has got its own property 'allGraphics'.
                          Layers parent is the document. Any idea¿ Have a try!
                          Hans-Gerd Claßen
                          • 10. Re: How I can generate a report of pictures coordinates?
                            @Hans-Gerd – but that method has one drawback:
                            the scope of "allGraphics" of a "layer" Object is restricted to "normal" document pages.
                            Graphics on master pages are left out there. You have to deal with them differently…
                            Some call it a bug, some call it "it's by design" ;-)
                            Uwe
                            • 12. Re: How I can generate a report of pictures coordinates?
                              I should have said:
                              "is restricted to "normal" document spreads", not "pages".
                              All graphics of containers on the pasteboards are included as well.
                              Uwe
