9 Replies Latest reply on Sep 29, 2015 8:45 AM by discrhythmia
    Script for calculating start time and end time
    Burkhardtz
      I am using Adobe Acrobat Pro and needing a script to calculate start time and end time for a timesheet (start time and end time are hh:MM) 24 hours please see below can anyone help me ......
        • 1. Re: Script for calculating start time and end time
          Will all the time events happen within one day?
          Will any event happen at midnight of the day?
          How do you want the start and end times calculated?
          I know how to compute the elapsed time from the start and end times.
          Is this for just one row of data, one day, or multiple rows or days?
          Do you need the total of all the "Total Hours" rows?
          How do you want the computed time difference displayed, as hours and decimal hours or hours and minutes?
          • 2. Re: Script for calculating start time and end time
            Burkhardtz Level 1
            It will be a daily work sheet (events will happen within one day)
            The day's hours will start from 08:00 am to 16:30pm
            The start and end times will be free text the guys will input them themselves but in 24 hour format it's the total hours I need a script for
            This will be multiple rows (they complete more than 1 job a day)
            I do need the total to populate in the "Total Hours" column for each individual row
            Time to be shown as hours and decimal hours
            • 3. Re: Script for calculating start time and end time
              First, if you are using 24 hour civilian time format there is no pre or post meridian time, am or pm, since all time values within the day are unique.
              You set the formats for Text72 and Text73 to "Time" "HH:MM" and Text74 to "Number" with 2 decimal places.
              Because certain calculations will be repeated for many rows, I would use functions to define the calculation code sequence once and then just call that function with the necessary parameters to provide the result of the calculation. The functions that are needed are to convert the time strings to minutes, compute the difference in minutes for the time in and time out with a given format, and rounding the difference to 2 decimal places.
              // document level functions
              function Round(nValue, nPrecision) {
              // round a number a given precision
              return util.printf("%,100." + nPrecision + "f", nValue);
              } // end round
              function Time2Min(cFormat, sTime) {
              sTime = sTime.toLowerCase();
              // adjust for 12:MM am
              if( (cFormat == "h:MM tt" | cFormat == "hh:MM tt") & ( (sTime.substr(0, 2) == "12" & sTime.substr(6,1) == 'a') | (sTime.substr(0, 2) == "12" & sTime.substr(5,1) == 'a') ) )
                 sTime = "00" + sTime.substr(2, sTime.length - 2);
              // convert a formatted time string to number of minutes since midnight
              // get time object
              var oTime = util.scand("mm/dd/yyyy " + cFormat, "01/01/1970 " + sTime);
              // convert to milliseconds
              var nTime = oTime.getTime();
              // convert to milliseconds to minutes and return value
              nTime = nTime / (1000 * 60);
              // return round to whole minutes
              return Round(nTime, 0);
              } // end Time2Min
              function TimeDiff(cFormat, cTimeIn, cTimeOut) {
              var nDiff = 0;
              // get the value of the time in and out fields
                 var sOut = this.getField(cTimeOut).value;
                 var sIn = this.getField(cTimeIn).value;
                 // compute if we have both values
                 if(sOut != "" && sIn != "") {
                    // convert time string to minutes and compute difference
                 nDiff = Time2Min(cFormat, sOut) - Time2Min(cFormat, sIn);
                    // convert to hours
                    nDiff = nDiff / 60;
                 }   // end if sOut & sIn
                 // return rounded value
                 return Number(Round(nDiff, 2));
              // end of document level functions
              You can then use a custom calculation where you only need to change the names of the time in and time out fields for the Total Hours field. For the time in field of "Text72" and the time out field of "Text73" the computation for the Total Hours field "Text74" could be:
              var cIn = "Text72", cOut = "Text73";
              event.value = TimeDiff("HH:MM", cIn, cOut);
              // convert zero entry to null
              if(event.value == 0) event.value = "";
              For the grand total of hours you can use the "Field is the Sum of the following fields:" and select the "Total Hours" fields to sum.
              Sample Time Sheet
              • 4. Re: Script for calculating start time and end time
                Burkhardtz Level 1
                Thank you for your response it was very useful however the guys have mentioned to me that they would like the time for the complete day as they will be completing night works on occasions so there time would look like this:
                So the negative should read 20:00 to 04:00 total hours 8.5, is there anything in the way of updating the script to show this?
                Real appreciative of the help
                • 5. Re: Script for calculating start time and end time
                  If you are covering more than one day, it is best to include the dates. You could assume that if the end time is before the start time, you are ending in the next day and could add 12 hours to the calculation.
                  The above assumes the shift will be less than 12 hours. If over 12 hours, than you need some way to determine that and having the date would resolve that issue. But then your calculation will use a different approach for the calculation. You would use the JavaScript date object and its various methods to compute the elapsed time.
                  • 6. Re: Script for calculating start time and end time
                    Talex904
                    What would the script look like to add 12 hours to the calculation?
                    • 7. Re: Script for calculating start time and end time
                      Change:
                      to
                      // convert time strings to minutes:
                      var nOut = Time2Min(cFormat, sOut);
                      var nIn = Time2Min(cFormat, sIn);
                      if(nOut < nin) nOut =+= 1440; add 24 hours for assumed next day;
                         nDiff = nOut - msIn);
                      • 8. Re: Script for calculating start time and end time
                        Burkhardtz Level 1
                        I changed the script as follows however an error message came up?  All i did was take the thread and paste over what you told me to change
                        • 9. Re: Script for calculating start time and end time
                          discrhythmia
                          I'm running into the same problem as when he change the script to correct for an end-time that occurs the following day.  Would you mind reviewing this thread and helping solve the syntax error?
