2 Replies Latest reply on Dec 15, 2012 3:24 AM by -hans-
    Indesign Image capabilities?
    web_rook7 Level 1
      Is there a way in ID to tag images? For instance, if I'm building layouts for an ipad, I then have to export the images in PS to save out for web and devices, 144dpi, etc. It would be nice if I could export the images at the exact size, rotation, etc. from ID to PS. It would also be nice if ID could let me tag the images so I know the picture box frame specs etc. Is there a way to do this or is there a plugin for this type of functionality? Any insight would be appreciated.
        • 1. Re: Indesign Image capabilities?
          I've moved this to the scripting forum in hopes that someone here will have some ideas.
          • 2. Re: Indesign Image capabilities?
            -hans- Level 4
            here's what I've once used to export cropped / masked images to JPG with. Added a labeling for the picContainer.
            Have a look if it pardly fits your needs...
            #target InDesign
            // getested ID CS 5.5
            with(app.jpegExportPreferences){
                //set to your wishes ...
                antiAlias = true;
            embedColorProfile = false;
            exportResolution = 144;
            jpegColorSpace = JpegColorSpaceEnum.RGB; //JpegColorSpaceEnum.CMYK, JpegColorSpaceEnum.GRAY     r/w    One of RGB, CMYK or Gray
            jpegQuality = JPEGOptionsQuality.HIGH; //JPEGOptionsQuality.MEDIUM, JPEGOptionsQuality.LOW, JPEGOptionsQuality.MAXIMUM     r/w    The compression quality.
            jpegRenderingStyle = JPEGOptionsFormat.BASELINE_ENCODING; // JPEGOptionsFormat.PROGRESSIVE_ENCODING     r/w    The rendering style.
            simulateOverprint = true;
            var theDoc = app.activeDocument;
            var docName = theDoc.name;
            var docShortName = docName.replace(/.indd/, '')
            var docPath = '' + theDoc.fullName;
            var docContainerPath = docPath.replace(docName, '')
            var destPath = docContainerPath + '/' + docShortName + '_jpgExport/'
            if(Folder(destPath).create() != true){alert('Zielordner konnte nicht erstellt werden.'); exit()}
            var theLinks = theDoc.links;
            l = theLinks.length;
            while(l--){
            if(theLinks[l].linkType.search(/Word|Excel|Text/) === -1){
                theName = theLinks[l].name.replace(/\..{3,4}/,  '')
            myContainer =     theLinks[l].parent.parent;
            gBounds = myContainer.geometricBounds.join(', ');
            myContainer.label = gBounds;
            parentPageNumber = myContainer.parentPage.name;
            newFile =new File(destPath + parentPageNumber + '_' + theName + '.jpg');
            if(myContainer.exportFile(ExportFormat.JPG,  newFile) === false){alert(newFile + ' konnte nicht geschrieben werden')}
            Hope it'll be of any help
            Hans-Gerd Claßen
