2 Replies Latest reply on Jul 18, 2006 4:07 PM by TucsonJava
    Access Child Objects in AS Object from FDS
    Bill White Level 1
      I have a dataservice setup to fill an arraycollection of Teacher objects. Each Teacher object has a School object. These appear to be properly returned from FDS as strongly-typed objects. In the debugger, I can see my arraycollection of Teacher objects and I can see valid School objects nested inside each one. However, when I tried to display the data in a datagrid, I cannot get the properties of the School object nested in the Teacher object to print out. Here is what I'm trying to do:
      <mx:DataGrid id="teachers_datagrid" editable="true" dataProvider="{teachersArray}">
      <mx:columns>
      <mx:DataGridColumn dataField="teacherid" headerText="Teacher Id" editable="false"/>
      <mx:DataGridColumn dataField="teachername" headerText="Teacher Name"/>
      <mx:DataGridColumn dataField="school.schoolid" headerText="School Id"/>
      <mx:DataGridColumn dataField="school.schoolname" headerText="School Name"/>
      </mx:columns>
      </mx:DataGrid>
      For some reason, the school.schoolid and school.schoolname values will not show up, while the teacherid and teachername appear correctly. If I just put 'school', I can see the value of the object represented as a string (ie [Object]). When I look in the debugger, I see what appears to be a correct arraycollection of Teachers with valid School properties inside them. Is there some other way to display the child properties that are complex objects?
