9 Replies Latest reply on Nov 8, 2013 3:37 AM by Ryan Young
    CS5.5 (Applescript) Packaging and PDF creation script
    Colin Flashman Adobe Community Professional
      Hello there.
      I have an applescript droplet which, once an InDesign file is dragged onto it, it creates:
      • a High Quality PDF;
      • a Press Quality PDF;
      • a Smallest File Size PDF; and
      • a packaged InDesign file without the instructions.txt.
      It's an amazing script but I need it to do one more thing... put the four items into its own folder.
      Here is how the script looks so far:
      on open mgItems
          repeat with mgThisItem in mgItems
              tell application id "com.adobe.InDesign"
                  try
                      open mgThisItem
                      set mgDocName to name of active document
                      set text item delimiters of AppleScript to " "
                      set mgShortName to text item 1 of mgDocName
                      set text item delimiters of AppleScript to ""
                      set mgHRFilePath to "Macintosh HD:Users:colly:Desktop:testfolder:" & mgShortName & "_HR.pdf" as string
                      set properties of PDF export preferences to properties of PDF export preset "[High Quality Print]"
                      tell active document
                          export format PDF type to mgHRFilePath without showing options
                      end tell
                      set mgHRDigitalFilePath to "Macintosh HD:Users:colly:Desktop:testfolder:" & mgShortName & "_HRD.pdf" as string
                      set properties of PDF export preferences to properties of PDF export preset "[Press Quality]"
                          export format PDF type to mgHRDigitalFilePath without showing options
                      end tell
                      set mgProofFilePath to "Macintosh HD:Users:colly:Desktop:testfolder:" & mgShortName & "_proof.pdf" as string
                      set properties of PDF export preferences to properties of PDF export preset "[Smallest File Size]"
                          export format PDF type to mgProofFilePath without showing options
                      end tell
                      set mgPackageFilePath to "Macintosh HD:Users:colly:Desktop:testfolder:" & mgShortName as string
                          package to mgPackageFilePath with copying fonts, ignore preflight errors, copying profiles, updating graphics, including hidden layers, copying linked graphics and creating report
                      end tell
                      close active document
                  on error
                      -- decide what kind of error handling you want to include if the file won't open
                  end try
              end tell
          end repeat
          display dialog "PDFs created and InDesign file packaged"
      end open
      As it works at the moment, many indesign files can be dragged onto this droplet, but they all end up in the same folder e.g. upon processing two indesign files, one called namequestion and the other called splash, all files populate the one folder as such:
      namequestion.indd
      namequestion.indd_HR.pdf
      namequestion.indd_HRD.pdf
      namequestion.indd_proof.pdf
      splash.indd
      splash.indd_HR.pdf
      splash.indd_HRD.pdf
      splash.indd_proof.pdf
      what I would like the script to do is put each set of 4 items into their own folders e.g.
      namequestion (folder)
         namequestion.indd
      splash (folder)
         splash.indd
         splash.indd_HR.pdf
         splash.indd_HRD.pdf
      it's probably a rather simple fix but this is my first crack at an applescript... normally play with javascript and still learning all that.
      Peter Kahrel has a very good javascript at http://www.kahrel.plus.com/indesign/batch_convert.html  but to get the outcome above (that's how it's been told to be made) Pete's script has to be run four times with much drag and dropping afterwards.
      Many thanks
      Colin
        • 1. Re: CS5.5 (Applescript) Packaging and PDF creation script
          Muppet Mark Level 5
          You have 2 choices here really… Either AppleScript the Finder To create the required folders and save the files in to these… Or write the script in ExtendScript and have an AppleScript wrapper just call the app's do script method…
          edit… where are you dragging files from and where did you want the new folders creating?
          • 2. Re: CS5.5 (Applescript) Packaging and PDF creation script
            Kevin Parrott Level 2
            Hi cdflash, try this works fine here using IDCS6 OSX 10.7.4
            on open mgItems
                        try
                            open mgThisItem
                            set mgShortName to text 1 thru -6 of mgShortName
                            tell application "Finder"
                            set mgHRFilePath to (make new folder at desktop with properties {name:mgShortName}) as string
                            end tell
                            set mgShortNameForPDF to mgShortName & "_HR" as string
                                export format PDF type to (mgHRFilePath & mgShortNameForPDF & ".pdf") without showing options
                            end tell
                            set mgShortNameForPDF to mgShortName & "_HRD" as string
                            end tell
                            set mgShortNameForPDF to mgShortName & "_proof" as string
                            end tell
                            set mgPackageFilePath to mgHRFilePath
                                package to (mgPackageFilePath & mgShortName) with copying fonts, ignore preflight errors, copying profiles, updating graphics, including hidden layers, copying linked graphics and creating report
                            end tell
                            close active document saving no -- or yes
                        on error
                        end try
                    end tell
                end repeat
                activate
                display dialog "PDFs created and InDesign file packaged" giving up after 2
            end open
            • 3. Re: CS5.5 (Applescript) Packaging and PDF creation script
              Muppet Mark Level 5
              You don't need to step in and out of the active document to export each just do it in one…
              • 4. Re: CS5.5 (Applescript) Packaging and PDF creation script
                -hans- Level 4
                Ha, ha,
                many help for this ;-)
                did it with just few changes. hope it'll work.
                dest will be the folder exports on the desktop.
                property baseFolder : (path to desktop as text) & "exports:"
                on open mgItems
                            try
                                open mgThisItem
                                set targetFolderPath to my createFolder(mgShortName)
                                set mgHRFilePath to targetFolderPath & mgShortName & "_HR.pdf" as string
                                end tell
                                set mgHRDigitalFilePath to targetFolderPath & mgShortName & "_HRD.pdf" as string
                                end tell
                                set mgProofFilePath to targetFolderPath & mgShortName & "_proof.pdf" as string
                                end tell
                                set mgPackageFilePath to targetFolderPath & mgShortName as string
                                end tell
                            on error e
                                display dialog e
                            end try
                        end tell
                    end repeat
                end open
                on createFolder(nameString)
                    set macFolderPath to baseFolder & nameString
                    do shell script "mkdir -p " & quoted form of POSIX path of macFolderPath
                    return macFolderPath & ":"
                end createFolder
                Hans-Gerd Claßen
                • 5. Re: CS5.5 (Applescript) Packaging and PDF creation script
                  Muppet Mark Level 5
                  Untested but can't you do like this…
                  on open mgItems
                                                try
                    open mgThisItem
                                                          tell the active document to export format PDF type to mgHRFilePath without showing options
                                                          tell the active document to export format PDF type to mgHRDigitalFilePath without showing options
                                                          tell the active document to export format PDF type to mgProofFilePath without showing options
                                                          tell the active document to package to mgPackageFilePath with copying fonts, ignore preflight errors, copying profiles, updating graphics, including hidden layers, copying linked graphics and creating report
                                                on error e
                    display dialog e
                                                end try
                                      end tell
                            end repeat
                  end open
                  end createFolder
                  • 6. Re: CS5.5 (Applescript) Packaging and PDF creation script
                    very nice, works a treat in cs6, I would just add the below, just to eliminate having to click on the dialog.
                    close active document saving no --or yes
                    • 7. Re: CS5.5 (Applescript) Packaging and PDF creation script
                      -hans- Level 4
                      Of course,
                      just did the changes requested ... ;_)
                      their may be other changes possible too ...
                      Hans-Gerd Claßen
                      • 8. Re: CS5.5 (Applescript) Packaging and PDF creation script
                        @ Muppet Mark
                        That was bang-on... nearly. I changed the line:
                        to
                        set text item delimiters of AppleScript to ".indd"
                        mainly because of how our jobs are filed. A typical folder will have, for example:
                        49505 cover.indd
                        49505 text.indd
                        49505 endpaper.indd
                        49505 dust jacket.indd
                        and running the script purely cut and pasted from this forum would result in the PDFs overwriting, and the indesign files packaging into the same folder.
                        @ Kevin
                        I agree, added that line so the "do you want to save" dialog box would not appear.
                        thank you all very much for your prompt and excellent assistance.
                        Colin
                        • 9. Re: CS5.5 (Applescript) Packaging and PDF creation script
                          Ryan Young
                          Hello guys.
                          First off sorry to bump quite an old thread, but this thread has been really helpful and the only thing I've found on the internet that has helped me create what I needed.
                          But I need a little help to perfect the script.
                          At the minute I have the script doing all the things above, except it only creates two pdfs, the high quality and smallest file size and also exports an .idml.
                          However the .idml goes into the folder with the pdfs rather than into the packaged files folder, like so:
                          A7_Test
                          A7_Test_DownSaved.idml
                          A7_Test_Packaged
                          A7_Test_LR.pdf
                          A7_Test_HR.pdf
                          I would like .idml  to go into that packaged files folder, I've tinkered around with it but can't get it to work. Can anyone help?
                          Here's the code:
                          on open mgItems
                                                        try
                            open mgThisItem
        set mgProofFilePath to targetFolderPath & mgShortName & "_LR.pdf" as string
        set mgPackageFilePath to targetFolderPath & mgShortName & "_Packaged" as string
        set mgIdmlFilePath to targetFolderPath & mgShortName & "_DownSaved.idml" as string
        tell the active document to export format InDesign markup to mgIdmlFilePath without showing options
                                                        on error e
                            display dialog e
                                                        end try
                                              end tell
                                    end repeat
                          end open
                          end createFolder
