3 Replies Latest reply on Dec 14, 2012 3:23 AM by Pierre Labbe
    Display the dialog box "Step and repeat"
    Pierre Labbe
      I am absolute beginner in script.
      I want to create a script (for InDesign CS6) that just displays the dialog box of the command "Step and repeat" from the Edit menu.
      I tried this :
      app.menuActions.itemByID(43521).invoke();
      The dialog box appears and disappears immediately.
      Thx for you help.
        • 1. Re: Display the dialog box "Step and repeat"
          Marc Autret Level 5
          Hi Pierre,
          I'm afraid this is not doable
          In fact, you should have the following runtime error: “The requested action opened an asynchronous previewable modal dialog. This is not compatible with the scripting architecture, and so the dialog has been automatically dismissed using the default button.”
          [In French: « L'action demandée a eu pour effet d'ouvrir une boîte de dialogue modale asynchrone prévisualisable. Celle-ci est incompatible avec l'architecture de script et a donc été automatiquement fermée à l'aide du bouton par défaut. »]
          Because of the Preview feature it embeds, the Step and Repeat dialog box cannot be safely triggered from a script, even if you emulate the corresponding menu selection:
          // THIS WILL FAIL AS WELL:
          with( app.menus.itemByName("$ID/Main").
                  menuElements.itemByName("$ID/Edit").
                  menuItems.itemByName("$ID/Step and Repeat...") )
              { isValid && enabled && select(); }
          Hence, I think there is no way to reach your goal through scripting.
          Marc
          • 2. Re: Display the dialog box "Step and repeat"
            Jump_Over Level 5
            To be more optimistic:
            do not give up with your goal!
            1. to display this dialog you can use a keyboard shortcut (item is selected)
            2. script could help you to create your own "step_repeat" dialog and to keep your own interaction with user
            3. script could execute step_repeat operation without dialog using your default/calculated/read  values
            rgds
            • 3. Re: Display the dialog box "Step and repeat"
              Pierre Labbe Level 1
              Bonjour Marc,
              Merci pour ta réponse.
              Je m'en doutais un peu car avec Configurator 3, j'obtiens le même résultat : la fenêtre ne reste pas affichée.
              Dommage,
              Pierre
