4 Replies Latest reply on Jan 20, 2013 7:09 PM by hadoop1984
    Why wave mouse will increase "inactive time"
    hadoop1984
      My Test Case is draw Two triangles  and  then wait six millseconds ,it's fps is 60.
      If I wave mouse on the stage then the fps is not stable the Inactive time will increase, and I have no way to decrease the inactive time.
      why? Is this a bug of flash player?
      Here is the scout sceen capture
        • 1. Re: Why wave mouse will increase "inactive time"
          hadoop1984 Level 1
          this is a fps graph from GPUView when I wave mouse on the flash stage
          when no mouse move event happened the fps is stable 60
          this is my test app
          <code>
          package
                    import com.adobe.utils.AGALMiniAssembler;
                    import com.adobe.utils.PerspectiveMatrix3D;
                    import flash.display.Bitmap;
                    import flash.display.Sprite;
                    import flash.display.StageAlign;
                    import flash.display.StageDisplayState;
                    import flash.display.StageScaleMode;
                    import flash.display3D.Context3D;
                    import flash.display3D.Context3DCompareMode;
                    import flash.display3D.Context3DProgramType;
                    import flash.display3D.Context3DTextureFormat;
                    import flash.display3D.Context3DVertexBufferFormat;
                    import flash.display3D.IndexBuffer3D;
                    import flash.display3D.Program3D;
                    import flash.display3D.VertexBuffer3D;
                    import flash.display3D.textures.Texture;
                    import flash.events.Event;
                    import flash.events.MouseEvent;
                    import flash.geom.Matrix3D;
                    import flash.geom.Rectangle;
                    import flash.text.TextField;
                    import flash.utils.getTimer;
                    [SWF(width="1000",height="600", backgroundColor = 0x000000, frameRate="60")]
                    public class SingleThreadRender extends Sprite
                              [Embed( source = "RockSmooth.jpg" )]
                              protected const TextureBitmap:Class;
                              protected var context3D:Context3D;
                              protected var vertexbuffer:VertexBuffer3D;
                              protected var indexBuffer:IndexBuffer3D;
                              protected var program:Program3D;
                              protected var texture:Texture;
                              protected var projectionTransform:PerspectiveMatrix3D;
                              private   var dataReady :Boolean = false;
                              private   var text      :TextField = null;
                              public function SingleThreadRender()
                                        text = new TextField();
                                        text.text = "gogo";
                                        addChild(text);
                                        stage.mouseChildren = false;
                                        startRenderThread();
                              private function startRenderThread() :void {
                                        stage.stage3Ds[0].addEventListener( Event.CONTEXT3D_CREATE, initMolehill );
                                        stage.stage3Ds[0].requestContext3D();
                                        stage.scaleMode = StageScaleMode.NO_SCALE;
                                        stage.align = StageAlign.TOP_LEFT;
                                        stage.stageHeight = 600
                                        stage.stageWidth = 800;
                                        addEventListener(Event.ENTER_FRAME, onRender);
                                        stage.addEventListener(MouseEvent.RIGHT_CLICK,rightClickHandler);
                              protected function initMolehill(e:Event):void
                                        context3D = stage.stage3Ds[0].context3D;
                                        context3D.configureBackBuffer(1000, 600, 1, true);
                                        var vertices:Vector.<Number> = Vector.<Number>([
                                                  -3,-3, 0,0, 0, // x, y, z, u, v
                                                  -3, 3, 0, 0, 1,
                                                  3, -3, 0, 1, 1,
                                                  3, 3, 0, 1, 0]);
                                        vertexbuffer = context3D.createVertexBuffer(4, 5);
                                        vertexbuffer.uploadFromVector(vertices, 0, 4);
                                        indexBuffer = context3D.createIndexBuffer(6);
                                        indexBuffer.uploadFromVector (Vector.<uint>([0, 1, 2, 2, 3, 0]), 0, 6);
                                        var bitmap:Bitmap = new TextureBitmap();
                                        texture = context3D.createTexture(bitmap.bitmapData.width, bitmap.bitmapData.height, Context3DTextureFormat.BGRA, false);
                                        texture.uploadFromBitmapData(bitmap.bitmapData);
                                        var vertexShaderAssembler : AGALMiniAssembler = new AGALMiniAssembler();
                                        vertexShaderAssembler.assemble( Context3DProgramType.VERTEX,
                                                  "m44 op, va0, vc0\n" + // pos to clipspace
                                                  "mov v0, va1" // copy uv
                                        var fragmentShaderAssembler : AGALMiniAssembler= new AGALMiniAssembler();
                                        fragmentShaderAssembler.assemble( Context3DProgramType.FRAGMENT,
                                                  "tex ft1, v0, fs0 <2d,linear,nomip>\n" +
                                                  "mov oc, ft1"
                                        program = context3D.createProgram();
                                        program.upload( vertexShaderAssembler.agalcode, fragmentShaderAssembler.agalcode);
                                        projectionTransform = new PerspectiveMatrix3D();
                                        var aspect:Number = 4/3;
                                        var zNear:Number = 0.1;
                                        var zFar:Number = 1000;
                                        var fov:Number = 45*Math.PI/180;
                                        projectionTransform.perspectiveFieldOfViewLH(fov, aspect, zNear, zFar);
                              private function rightClickHandler(event :MouseEvent) :void {
                                        stage.removeEventListener(MouseEvent.RIGHT_CLICK,rightClickHandler);
                                        stage.fullScreenSourceRect = new Rectangle( 0,0,stage.fullScreenWidth,stage.fullScreenHeight);
                                        stage.displayState = StageDisplayState.FULL_SCREEN_INTERACTIVE;
                              private var firstTime :Boolean = true;
                              protected function onRender(e:Event):void
                                        if(stage.frameRate != 60) {
                                                  stage.frameRate = 60;
                                        if ( !context3D )
                                                  return;
                                        var start :int = flash.utils.getTimer();
                                        var now :int = 0;
                                        while(true) {
                                                  now = flash.utils.getTimer();
                                                  if((now - start) > 6) {
                                                            break;
                                        context3D.clear ( 1,1, 1, 1 );
                                        context3D.setDepthTest( true, Context3DCompareMode.LESS_EQUAL);
                                        context3D.setVertexBufferAt (0, vertexbuffer, 0, Context3DVertexBufferFormat.FLOAT_3);
                                        context3D.setVertexBufferAt(1, vertexbuffer, 3, Context3DVertexBufferFormat.FLOAT_2);
                                        context3D.setTextureAt(0, texture);
                                        context3D.setProgram(program);
                                        var m:Matrix3D = new Matrix3D();
                                        m.appendTranslation(0, 0, 2);
                                        m.append(projectionTransform);
                                        context3D.setProgramConstantsFromMatrix(Context3DProgramType.VERTEX, 0, m, true);
                                        var i:int = 2;
                                        while(i--)
                                                  context3D.drawTriangles(indexBuffer,0,2);
                                        context3D.present();
                                        while(true) {
                                                            break;
          <code>
          • 2. Re: Why wave mouse will increase "inactive time"
            BradVan21
            I am getting the same thing... makes it very hard to test things.... would be nice to know how to stop this.
            • 3. Re: Why wave mouse will increase "inactive time"
              hadoop1984 Level 1
              flash player's mouse and keyboard process design is a bunch of ****.
              mouse event will cause the inactive time increase. The high frequency mouse will cause the game lag.
              And flash player will drop the mouse event randomly .
              A bunch of **** .But no better choice. ****!!!
              • 4. Re: Why wave mouse will increase "inactive time"
                hadoop1984 Level 1
                Why  S H I T is masked
