7 Replies Latest reply on Mar 11, 2016 3:12 AM by tssee@imgof.com
    delete one guide at a time
    bala281972 Level 1
      Hi
      any idea on how to delete/remove one guide at a time pl. I've gone through the forum which clears all the guides but couldnt find any help on deleting guides one at a time.
      Any possible solution
        • 1. Re: delete one guide at a time
          Michael L Hale Level 5
          With version greater than CS4 guides are part of the Object Model.
          app.activeDocument.guides.length;// number of guides in document
          app.activeDocument.guides[0].remove();// remove a guide by index
          The index is in the order the guides were created.
          You can also determine where a guide is by looking at it's coordinate and direction priperties.
          • 2. Re: delete one guide at a time
            Ghoulfool Level 1
            And for those mere motals using the Ludditian CS2? I noticed that the script listener doesn't pick up on guide deletion. And since they're not part of the the object model it's gonna be quite difficult to remove them (or even move them to off the canvas)
            • 3. Re: delete one guide at a time
              Yes, with older versions you are stuck with using Action Manger to work with guides. And as far as I can tell you can't remove a single guide with AM code.
              You can remove all guides and you can create guides. I also have code that will let you get info about the current guides in a document. With that you could get the info about the guides in a document, remove all the guides, then add back the ones you want to keep. Not pretty but it should work. Here is the code.
              To get guide info:
              #target photoshop
              app.bringToFront();
              /* the info about guides can be found in the photoshop tag hex 35 42 49 4D 04 08
                 the length of the tag is found at offset 11. that value is the length to the next tag
                 the number of guides can be found at offset 27. From that point the data repeats
                 for each guide. 4 bytes for the location. That value / 32 = pixels
                 and one byte for type 0 = vert and 1 = horz
                 Note: this info is just a best guess from looking at the data
              // Function: getGuideInfo
              // Description: Saves the document as a temp jpg file
              //                        and extracts the info about the guides
              //                        in document if any
              // Usage: var guides = getGuideInfo( activeDocument );
              // Input: Document
              // Return: Object: TotalCount property  = number of guides
              //                  HorizontalCount property = number of horizontal guides
              //                  VerticalCount property = number of vertical guides
              //                  Horizontal = horizontal guides
              //                  Vertical property = vertical guides
              // Source: Modified from http://ps-scripts.com/bb/viewtopic.php?t=3283
              function getGuideInfo( doc ) {
                 saveOptions = new JPEGSaveOptions();
                 // we don't care about image quality in the temp file
                 // we do want the smallest file size
                 saveOptions.quality = 0;// we don't care about image quality in the temp file
                 var tempFile = new File( Folder.temp + '/' +'guideTemp.jpg' );
                 // Dupe the doc, make it savable as JPEG, save it, then close the file
                 doc = doc.duplicate();
                 if( doc.mode == DocumentMode.BITMAP ) doc.changeMode(ChangeMode.GRAYSCALE);
                 doc.bitsPerChannel = BitsPerChannelType.EIGHT;
                 doc.changeMode(ChangeMode.RGB);
                 doc.saveAs(tempFile, saveOptions, true);
                 doc.close(SaveOptions.DONOTSAVECHANGES);
                tempFile.encoding = 'BINARY';
                tempFile.open('r');
                var str = tempFile.read();
                tempFile.close();
                tempFile.remove();
                 var guideTag = '8BIM\x04\x08';
                 var tagPos = str.search(guideTag);
                 var guides = new Object;
                 guides.toString = function(){ return 'GuideInfo'; }
                 var horGuides = new Array;
                 var vertGuides = new Array;
                 if( tagPos != -1 ) {
                    var tagLength = 12 + str.charCodeAt( tagPos + 11 );
                    var guideStr = str.substring( tagPos, tagPos+tagLength );
                    guides.count = str.charCodeAt( tagPos + 27 );
                    var pointer = tagPos + 28;
                    for( var i =0; i < guides.count; i++ ){
                     //  var n = ((str[pointer] << 3) + (str[pointer+1] << 2) + (str[pointer+2] << 1) + str[pointer+3])/32;
                    //var n = Number( '0x'+getHexString( str, pointer )+getHexString( str, pointer+1 )+getHexString( str, pointer+2 )+getHexString( str, pointer+3 ))/32;
                           var n = ((str.charCodeAt(pointer)<< 32) + (str.charCodeAt(pointer + 1)<< 16) +
                                  (str.charCodeAt(pointer + 2) << 8) + str.charCodeAt(pointer+3))/32;
              if  (str.charCodeAt( pointer + 4 ) == 0) {
                        //vertical
                        vertGuides = insertValueInOrder(vertGuides, n);
                     } else {
                        //horizontal
                        horGuides = insertValueInOrder(horGuides, n);
                      // guides[ i ] =  [ (str.charCodeAt( pointer + 4 ) ? 'horz':'vert'), n ];
                       pointer = pointer + 5;
                   guides.HorizontalCount =horGuides.length;
                   guides.VerticalCount =vertGuides.length;
                   guides.Horizontal = horGuides;
                   guides.Vertical = vertGuides;
                 }else{
                    guides.TotalCount = 0;
                   guides.HorizontalCount =0;
                   guides.VerticalCount =0;
                 function insertValueInOrder(a , n) {
                    var b = new Array;
                    var i = 0;
                    if (a[0] == undefined)
                       b[0] = n;
                    else {
                       while (a[i] < n && i < a.length) {
                             b[i] = a[i];
                             i++;
                       b[i] = n;
                       while (i < a.length) {
                          b[i+1] = a[i];
                          i++;
                    return b;
                 return guides;
                function fromCharCode(input) {
                    output = eval("String.fromCharCode(" + input + ")");
                   return output;
              // demo
              var masterDocument = app.activeDocument;
              var guideInfo = getGuideInfo( masterDocument );
              var s = "Vertical Guides: " + guideInfo.Vertical + "\nHorizontal Guides: " + guideInfo.Horizontal;
              alert(s);
              To remove all guides:
              function clearAllGuides() {
                   var desc = new ActionDescriptor();
                      var ref = new ActionReference();
                      ref.putEnumerated( charIDToTypeID( "Gd  " ), charIDToTypeID( "Ordn" ), charIDToTypeID( "Al  " ) );
                   desc.putReference( charIDToTypeID( "null" ), ref );
                   executeAction( charIDToTypeID( "Dlt " ), desc, DialogModes.NO );
              To add a guide:
              function guideLine(position, type,unit) {// from Paul MR
                 //units '#Pxl' pixel '#Rlt' =Relative  '#Prc' = percent
                 // types: 'Vrtc' & 'Hrzn'
                      var desc2 = new ActionDescriptor();
                      desc2.putUnitDouble( charIDToTypeID('Pstn'), charIDToTypeID(unit), position);
                      desc2.putEnumerated( charIDToTypeID('Ornt'), charIDToTypeID('Ornt'), charIDToTypeID(type) );
                  desc.putObject( charIDToTypeID('Nw  '), charIDToTypeID('Gd  '), desc2 );
                  executeAction( charIDToTypeID('Mk  '), desc, DialogModes.NO );
              • 4. Re: delete one guide at a time
                cameronmcefee Level 1
                I'm about 3.5 years too late, but here's how to delete a guide by its index:
                function removeGuideByIndex(idx) {
                   // Build a reference to the guide we want
                  // Guide indexes start at 1 for some reason.
                  ref.putIndex(charIDToTypeID('Gd  '), idx+1)
                  // Create a descriptor with our reference in it
                  desc.putReference(charIDToTypeID('null'), ref)
                  // Execute the delete action on our descriptor.
                  executeAction(charIDToTypeID('Dlt '), desc, DialogModes.NO);
                • 5. Re: delete one guide at a time
                  Level 1
                  I tried the script but does not work for me.
                  • 6. Re: delete one guide at a time
                    Can you be more specific about what doesn't work? It's working fine for me in CC+
                    To test:
                    1. Create a new document.
                    2. Create a guide on the left side, then one on the right side.
                    3. Run the function above with removeGuideByIndex(0)
                    The guide on the left will disappear, as it was the first guide added.
                    *I'm making the assumption you are familiar with how JavaScript works. If not, the code above is just a function declaration and won't do anything unless you know your guide's index and how to call a function with it.
                    • 7. Re: delete one guide at a time
                      Level 1
                      I tried in every way but does not go
                      Use photoshop cc2014
