1 Reply Latest reply on Dec 16, 2012 9:37 AM by raeben3
    Adding tags to PDF deletes text (Calibri) - suggestions?
    sruss/REL
      When I create a PDF from Word for Mac and open it in Acrobat X the font looks fine. When I add tags, however - which I must do for accessibility reasons - random letters seem to disappear (usually from 1- to 3-letter words).
      I am using a Mac running OS X Lion, using Word for Mac v 14.2.5 and Adobe Acrobat Pro 10.1.4. The only font I have seen this problem with is Calibri, but I would prefer not to simply switch fonts as all our documents use Calibri. The problem is we must now make them 508 compliant (accessibility). As I had not added tags before I had not had this problem. If I manually add tags via the TouchUp Reading Order tool, I don't have this problem. This is fine for short documents, but it just isn't feasible long-term.
      I have tried embedding fonts through preflight before adding tags, to no avail. Does anyone have any suggestions? Is there a fix for this?
        • 1. Re: Adding tags to PDF deletes text (Calibri) - suggestions?
          raeben3 Level 3
          I wonder if the text is dropping out or somehow just slipping underneath a layer in the PDF.  I have no idea without trying myself and I just don't have the same set up you have (I have a Mac but do not have Word on that machine; I typically run Word on a Windows 7 machine and do all my accessibility work there).
          One thing I would try, which someone  referenced in another thread -- "when exporting the tagged PDF with 'Create Acrobat Layers' selected it stopped the text from going behind objects (disappearing)." They had a different workflow (using Indesign) so it may not work for you, but it's worth a try.
