6 Replies Latest reply on Jul 15, 2006 3:33 PM by MikerRoo
    SQL help
    Level 7
      I need some help with a SQL statement.
      I have 2 tables in a database. One is 'team' and the other is 'users'. The
      share the common key 'username'
      What I would like is to query both tables using a join and then output only
      the username that do not appear in both lists.
      For example:
      Team: Users:
      Bob Bob
      Tammy Tammy
      Joe Joe
      Mike
      The results would only be Mike's information.
      Please help!
      Wally Kolcz
      Developer / Support
        • 1. Re: SQL help
          MikerRoo Level 1
          You did not specify which DB you are using and that is very important for this kind of query.
          SQL like this will work for quality or STANDARDS COMPLIANT DB's:
          SELECT
          U.UserName,
          T.UserName
          FROM
          USERS U
          FULL OUTER JOIN
          TEAM T ON U.UserName = T.UserName
          WHERE
          U.UserName IS NULL
          OR
          T.UserName IS NULL
          • 2. Re: SQL help
            draves Level 1
            If your data base supports a full outer join you might get by with one statement something like:
            select nvl(a.username,b.username) from team a full outer join users b on a.username = b.username
            where a.username is null or b.username is null
            Otherwise you will need to do something like one of the following:
            (select username from team
            minus
            select username from users)
            union
            (select username from users
            minus
            select username from team)
            select a.username from team a left outer join users b on a.username = b.username
            where b.username is null
            union
            select b.username from users b left outer join team a on b.username = a.username
            • 3. Re: SQL help
              Level 7
              I am using a MySQL 5 database, if that helps.
              • 4. Re: SQL help
                Level 7
                Thanks you.
                I don't know if it matters, but I just want the list from the 'users' table
                and never from the 'team' table.
                It is to allow team members that are not assigned to a project to be added
                at a different time.
                • 5. Re: SQL help
                  Level 7
                  After reading the MySQL site, will this work to only show the results in
                  table 1 that do not exist in table 2?
                  SELECT table1.* FROM table1 LEFT JOIN table2 ON table1.id=table2.id WHERE
                  table2.id IS NULL
                  • 6. Re: SQL help
                    MikerRoo Level 1
                    Yes, it should.
