8 Replies Latest reply on Dec 18, 2012 7:34 PM by el_sim
    OpenOffice under CF 9 throws com.sun.star.task.ErrorCodeIOException
    el_sim
      We are having a problem with OpenOffice that throws com.sun.star.task.ErrorCodeIOException exception while converting some .doc files into .pdf. Most of the .doc files are being converted normally so does the  .rtf and .docx files. But few .doc files permanently throw this exception. What might be wrong with those files? Did anyone had this problem?
      We are using the most simple code:
      <cfdocument format="pdf"
      srcfile="C:\Temp\555.doc"
      filename="C:\Temp\New555.pdf">
      </cfdocument>
      What should we look at?
      Thank you!
        • 1. Re: OpenOffice under CF 9 throws com.sun.star.task.ErrorCodeIOException
          BKBK Adobe Community Professional & MVP
          What do you mean by "a problem with OpenOffice that throws com.sun.star.task.ErrorCodeIOException"? The code you show is entirely ColdFusion. Was there any indication in the error-message to suggest a connection with Open Office?
          Using Open Office 3.4.1, I saved the file C:\Temp\555.doc successively as MS Word 97/2000/XP(.doc), MS Word 95(.doc) and MS Word 6.0(.doc). I then ran your code. In every case it worked as expected. However, I am on CF 10.
          • 2. Re: OpenOffice under CF 9 throws com.sun.star.task.ErrorCodeIOException
            el_sim Level 1
            Thank you for your reply. Yes, the above code is entirely ColdFusion but internally <cfdocument> "supports conversion of a Word document to PDF or HTML using OpenOffice libraries". In other words, this ColdFusion statement runs OpenOffice and it gets an exception from OpenOffice.
            What do you mean saying that you've saved the file? I did not attach my actual "problematic" files here. I don't think these posts have the attachment capability. If you're interested I can e-mail you the file(s) in question. Please let me know.
            • 3. Re: OpenOffice under CF 9 throws com.sun.star.task.ErrorCodeIOException
              I guessed as much. I still wonder whether ColdFusion includes its own independent Open Office libraries or whether it makes use of Open Office resouces currently on your machine. That isn't clear to me from the documentation on using cfdocument with Open Office. I am looking into it some more.
              Sorry about the misunderstanding. To reproduce your error, I used Open Office to create my own file named 555.doc, and saved it at  c:\temp. In any case, I am curious about your problematic DOC files. I should like to receive them. I have sent you my e-mail address.
              • 4. Re: OpenOffice under CF 9 throws com.sun.star.task.ErrorCodeIOException
                Could you please show us the entire stack trace (for the exception)? Thanks.
                • 5. Re: OpenOffice under CF 9 throws com.sun.star.task.ErrorCodeIOException
                  el_sim Level 1
                  Sure, here it is:
                  "Error","jrpp-7","12/17/12","11:13:10","CCN Engine","The following exception occurred while converting C:\Temp\401.doc: com.sun.star.task.ErrorCodeIOException:  The specific sequence of files included or processed is: C:\Inetpub\wwwroot\MaintenancePrograms\DocintoPDF.cfm, line: 3 "
                  coldfusion.document.OpenOfficeUNOHelper$DocumentConversionException: The following exception occurred while converting C:\Temp\401.doc: com.sun.star.task.ErrorCodeIOException:
                      at coldfusion.document.OpenOfficeUNOHelper.doExport(OpenOfficeUNOHelper.java:637)
                      at coldfusion.tagext.lang.DocumentTag.exportWithOpenOffice(DocumentTag.java:2346)
                      at coldfusion.tagext.lang.DocumentTag.doStartTag(DocumentTag.java:1165)
                      at cfDocintoPDF2ecfm1369872646.runPage(C:\Inetpub\wwwroot\MaintenancePrograms\DocintoPDF.cfm :3)
                      at coldfusion.runtime.CfJspPage.invoke(CfJspPage.java:231)
                      at coldfusion.tagext.lang.IncludeTag.doStartTag(IncludeTag.java:416)
                      at coldfusion.filter.CfincludeFilter.invoke(CfincludeFilter.java:65)
                      at coldfusion.filter.ApplicationFilter.invoke(ApplicationFilter.java:363)
                      at coldfusion.filter.RequestMonitorFilter.invoke(RequestMonitorFilter.java:48)
                      at coldfusion.filter.MonitoringFilter.invoke(MonitoringFilter.java:40)
                      at coldfusion.filter.PathFilter.invoke(PathFilter.java:87)
                      at coldfusion.filter.LicenseFilter.invoke(LicenseFilter.java:27)
                      at coldfusion.filter.ExceptionFilter.invoke(ExceptionFilter.java:70)
                      at coldfusion.filter.BrowserDebugFilter.invoke(BrowserDebugFilter.java:74)
                      at coldfusion.filter.ClientScopePersistenceFilter.invoke(ClientScopePersistenceFilter.java:2 8)
                      at coldfusion.filter.BrowserFilter.invoke(BrowserFilter.java:38)
                      at coldfusion.filter.NoCacheFilter.invoke(NoCacheFilter.java:46)
                      at coldfusion.filter.GlobalsFilter.invoke(GlobalsFilter.java:38)
                      at coldfusion.filter.DatasourceFilter.invoke(DatasourceFilter.java:22)
                      at coldfusion.filter.CachingFilter.invoke(CachingFilter.java:53)
                      at coldfusion.CfmServlet.service(CfmServlet.java:200)
                      at coldfusion.bootstrap.BootstrapServlet.service(BootstrapServlet.java:89)
                      at jrun.servlet.FilterChain.doFilter(FilterChain.java:86)
                      at coldfusion.monitor.event.MonitoringServletFilter.doFilter(MonitoringServletFilter.java:42 )
                      at coldfusion.bootstrap.BootstrapFilter.doFilter(BootstrapFilter.java:46)
                      at jrun.servlet.FilterChain.doFilter(FilterChain.java:94)
                      at jrun.servlet.FilterChain.service(FilterChain.java:101)
                      at jrun.servlet.ServletInvoker.invoke(ServletInvoker.java:106)
                      at jrun.servlet.JRunInvokerChain.invokeNext(JRunInvokerChain.java:42)
                      at jrun.servlet.JRunRequestDispatcher.invoke(JRunRequestDispatcher.java:286)
                      at jrun.servlet.ServletEngineService.dispatch(ServletEngineService.java:543)
                      at jrun.servlet.jrpp.JRunProxyService.invokeRunnable(JRunProxyService.java:203)
                      at jrunx.scheduler.ThreadPool$ThreadThrottle.invokeRunnable(ThreadPool.java:428)
                      at jrunx.scheduler.WorkerThread.run(WorkerThread.java:66)
                  • 6. Re: OpenOffice under CF 9 throws com.sun.star.task.ErrorCodeIOException
                    Thanks for the files. The problem seems to be caused by Comment fields associated with the .doc document. I am looking into it.
                    • 7. Re: OpenOffice under CF 9 throws com.sun.star.task.ErrorCodeIOException
                      I have studied the 2 files you sent me. Apparently, the files were originally created with a Microsoft Office product before being saved with Open Office. For whatever reason, they still contain proprietary Microsoft Office formatting information in the so-called Comment fields.
                      For example, one of the documents contains the following 6 Comments:
                      <!--[if gte mso 9]><xml>
                      <o:DocumentProperties>
                        <o:Author>NetShell</o:Author>
                        <o:Template>Normal</o:Template>
                        <o:LastAuthor>NetShell</o:LastAuthor>
                        <o:Revision>3</o:Revision>
                        <o:TotalTime>3</o:TotalTime>
                        <o:Created>2012-12-15T21:34:00Z</o:Created>
                        <o:LastSaved>2012-12-15T21:37:00Z</o:LastSaved>
                        <o:Pages>1</o:Pages>
                        <o:Words>74</o:Words>
                        <o:Characters>423</o:Characters>
                        <o:Company>NetShell Consulting</o:Company>
                        <o:Lines>3</o:Lines>
                        <o:Paragraphs>1</o:Paragraphs>
                        <o:CharactersWithSpaces>496</o:CharactersWithSpaces>
                        <o:Version>14.00</o:Version>
                      </o:DocumentProperties>
                      <o:OfficeDocumentSettings>
                        <o:AllowPNG/>
                      </o:OfficeDocumentSettings>
                      </xml><![endif]-->
                      <w:WordDocument>
                        <w:SpellingState>Clean</w:SpellingState>
                        <w:GrammarState>Clean</w:GrammarState>
                        <w:TrackMoves>false</w:TrackMoves>
                        <w:TrackFormatting/>
                        <w:ValidateAgainstSchemas/>
                        <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid>
                        <w:IgnoreMixedContent>false</w:IgnoreMixedContent>
                        <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText>
                        <w:DoNotPromoteQF/>
                        <w:LidThemeOther>EN-US</w:LidThemeOther>
                        <w:LidThemeAsian>X-NONE</w:LidThemeAsian>
                        <w:LidThemeComplexScript>X-NONE</w:LidThemeComplexScript>
                        <w:Compatibility>
                         <w:BreakWrappedTables/>
                         <w:SplitPgBreakAndParaMark/>
                        </w:Compatibility>
                        <w:DoNotOptimizeForBrowser/>
                        <m:mathPr>
                         <m:mathFont m:val="Cambria Math"/>
                         <m:brkBin m:val="before"/>
                         <m:brkBinSub m:val="&#45;-"/>
                         <m:smallFrac m:val="off"/>
                         <m:dispDef/>
                         <m:lMargin m:val="0"/>
                         <m:rMargin m:val="0"/>
                         <m:defJc m:val="centerGroup"/>
                         <m:wrapIndent m:val="1440"/>
                         <m:intLim m:val="subSup"/>
                         <m:naryLim m:val="undOvr"/>
                        </m:mathPr></w:WordDocument>
                      </xml><![endif]-->
                      <w:LatentStyles DefLockedState="false" DefUnhideWhenUsed="true"
                        DefSemiHidden="true" DefQFormat="false" DefPriority="99"
                        LatentStyleCount="267">
                        <w:LsdException Locked="false" Priority="0" SemiHidden="false"
                         UnhideWhenUsed="false" QFormat="true" Name="Normal"/>
                        <w:LsdException Locked="false" Priority="9" SemiHidden="false"
                         UnhideWhenUsed="false" QFormat="true" Name="heading 1"/>
                        <w:LsdException Locked="false" Priority="9" QFormat="true" Name="heading 2"/>
                        <w:LsdException Locked="false" Priority="9" QFormat="true" Name="heading 3"/>
                        <w:LsdException Locked="false" Priority="9" QFormat="true" Name="heading 4"/>
                        <w:LsdException Locked="false" Priority="9" QFormat="true" Name="heading 5"/>
                        <w:LsdException Locked="false" Priority="9" QFormat="true" Name="heading 6"/>
                        <w:LsdException Locked="false" Priority="9" QFormat="true" Name="heading 7"/>
                        <w:LsdException Locked="false" Priority="9" QFormat="true" Name="heading 8"/>
                        <w:LsdException Locked="false" Priority="9" QFormat="true" Name="heading 9"/>
                        <w:LsdException Locked="false" Priority="39" Name="toc 1"/>
                        <w:LsdException Locked="false" Priority="39" Name="toc 2"/>
                        <w:LsdException Locked="false" Priority="39" Name="toc 3"/>
                        <w:LsdException Locked="false" Priority="39" Name="toc 4"/>
                        <w:LsdException Locked="false" Priority="39" Name="toc 5"/>
                        <w:LsdException Locked="false" Priority="39" Name="toc 6"/>
                        <w:LsdException Locked="false" Priority="39" Name="toc 7"/>
                        <w:LsdException Locked="false" Priority="39" Name="toc 8"/>
                        <w:LsdException Locked="false" Priority="39" Name="toc 9"/>
                        <w:LsdException Locked="false" Priority="35" QFormat="true" Name="caption"/>
                        <w:LsdException Locked="false" Priority="10" SemiHidden="false"
                         UnhideWhenUsed="false" QFormat="true" Name="Title"/>
                        <w:LsdException Locked="false" Priority="1" Name="Default Paragraph Font"/>
                        <w:LsdException Locked="false" Priority="11" SemiHidden="false"
                         UnhideWhenUsed="false" QFormat="true" Name="Subtitle"/>
                        <w:LsdException Locked="false" Priority="22" SemiHidden="false"
                         UnhideWhenUsed="false" QFormat="true" Name="Strong"/>
                        <w:LsdException Locked="false" Priority="20" SemiHidden="false"
                         UnhideWhenUsed="false" QFormat="true" Name="Emphasis"/>
                        <w:LsdException Locked="false" Priority="59" SemiHidden="false"
                         UnhideWhenUsed="false" Name="Table Grid"/>
                        <w:LsdException Locked="false" UnhideWhenUsed="false" Name="Placeholder Text"/>
                        <w:LsdException Locked="false" Priority="1" SemiHidden="false"
                         UnhideWhenUsed="false" QFormat="true" Name="No Spacing"/>
                        <w:LsdException Locked="false" Priority="60" SemiHidden="false"
                         UnhideWhenUsed="false" Name="Light Shading"/>
                        <w:LsdException Locked="false" Priority="61" SemiHidden="false"
                         UnhideWhenUsed="false" Name="Light List"/>
                        <w:LsdException Locked="false" Priority="62" SemiHidden="false"
                         UnhideWhenUsed="false" Name="Light Grid"/>
                        <w:LsdException Locked="false" Priority="63" SemiHidden="false"
                         UnhideWhenUsed="false" Name="Medium Shading 1"/>
                        <w:LsdException Locked="false" Priority="64" SemiHidden="false"
                         UnhideWhenUsed="false" Name="Medium Shading 2"/>
                        <w:LsdException Locked="false" Priority="65" SemiHidden="false"
                         UnhideWhenUsed="false" Name="Medium List 1"/>
                        <w:LsdException Locked="false" Priority="66" SemiHidden="false"
                         UnhideWhenUsed="false" Name="Medium List 2"/>
                        <w:LsdException Locked="false" Priority="67" SemiHidden="false"
                         UnhideWhenUsed="false" Name="Medium Grid 1"/>
                        <w:LsdException Locked="false" Priority="68" SemiHidden="false"
                         UnhideWhenUsed="false" Name="Medium Grid 2"/>
                        <w:LsdException Locked="false" Priority="69" SemiHidden="false"
                         UnhideWhenUsed="false" Name="Medium Grid 3"/>
                        <w:LsdException Locked="false" Priority="70" SemiHidden="false"
                         UnhideWhenUsed="false" Name="Dark List"/>
                        <w:LsdException Locked="false" Priority="71" SemiHidden="false"
                         UnhideWhenUsed="false" Name="Colorful Shading"/>
                        <w:LsdException Locked="false" Priority="72" SemiHidden="false"
                         UnhideWhenUsed="false" Name="Colorful List"/>
                        <w:LsdException Locked="false" Priority="73" SemiHidden="false"
                         UnhideWhenUsed="false" Name="Colorful Grid"/>
                         UnhideWhenUsed="false" Name="Light Shading Accent 1"/>
                         UnhideWhenUsed="false" Name="Light List Accent 1"/>
                         UnhideWhenUsed="false" Name="Light Grid Accent 1"/>
                         UnhideWhenUsed="false" Name="Medium Shading 1 Accent 1"/>
                         UnhideWhenUsed="false" Name="Medium Shading 2 Accent 1"/>
                         UnhideWhenUsed="false" Name="Medium List 1 Accent 1"/>
                        <w:LsdException Locked="false" UnhideWhenUsed="false" Name="Revision"/>
                        <w:LsdException Locked="false" Priority="34" SemiHidden="false"
                         UnhideWhenUsed="false" QFormat="true" Name="List Paragraph"/>
                        <w:LsdException Locked="false" Priority="29" SemiHidden="false"
                         UnhideWhenUsed="false" QFormat="true" Name="Quote"/>
                        <w:LsdException Locked="false" Priority="30" SemiHidden="false"
                         UnhideWhenUsed="false" QFormat="true" Name="Intense Quote"/>
                         UnhideWhenUsed="false" Name="Medium List 2 Accent 1"/>
                         UnhideWhenUsed="false" Name="Medium Grid 1 Accent 1"/>
                         UnhideWhenUsed="false" Name="Medium Grid 2 Accent 1"/>
                         UnhideWhenUsed="false" Name="Medium Grid 3 Accent 1"/>
                         UnhideWhenUsed="false" Name="Dark List Accent 1"/>
                         UnhideWhenUsed="false" Name="Colorful Shading Accent 1"/>
                         UnhideWhenUsed="false" Name="Colorful List Accent 1"/>
                         UnhideWhenUsed="false" Name="Colorful Grid Accent 1"/>
                         UnhideWhenUsed="false" Name="Light Shading Accent 2"/>
                         UnhideWhenUsed="false" Name="Light List Accent 2"/>
                         UnhideWhenUsed="false" Name="Light Grid Accent 2"/>
                         UnhideWhenUsed="false" Name="Medium Shading 1 Accent 2"/>
                         UnhideWhenUsed="false" Name="Medium Shading 2 Accent 2"/>
                         UnhideWhenUsed="false" Name="Medium List 1 Accent 2"/>
                         UnhideWhenUsed="false" Name="Medium List 2 Accent 2"/>
                         UnhideWhenUsed="false" Name="Medium Grid 1 Accent 2"/>
                         UnhideWhenUsed="false" Name="Medium Grid 2 Accent 2"/>
                         UnhideWhenUsed="false" Name="Medium Grid 3 Accent 2"/>
                         UnhideWhenUsed="false" Name="Dark List Accent 2"/>
                         UnhideWhenUsed="false" Name="Colorful Shading Accent 2"/>
                         UnhideWhenUsed="false" Name="Colorful List Accent 2"/>
                         UnhideWhenUsed="false" Name="Colorful Grid Accent 2"/>
                         UnhideWhenUsed="false" Name="Light Shading Accent 3"/>
                         UnhideWhenUsed="false" Name="Light List Accent 3"/>
                         UnhideWhenUsed="false" Name="Light Grid Accent 3"/>
                         UnhideWhenUsed="false" Name="Medium Shading 1 Accent 3"/>
                         UnhideWhenUsed="false" Name="Medium Shading 2 Accent 3"/>
                         UnhideWhenUsed="false" Name="Medium List 1 Accent 3"/>
                         UnhideWhenUsed="false" Name="Medium List 2 Accent 3"/>
                         UnhideWhenUsed="false" Name="Medium Grid 1 Accent 3"/>
                         UnhideWhenUsed="false" Name="Medium Grid 2 Accent 3"/>
                         UnhideWhenUsed="false" Name="Medium Grid 3 Accent 3"/>
                         UnhideWhenUsed="false" Name="Dark List Accent 3"/>
                         UnhideWhenUsed="false" Name="Colorful Shading Accent 3"/>
                         UnhideWhenUsed="false" Name="Colorful List Accent 3"/>
                         UnhideWhenUsed="false" Name="Colorful Grid Accent 3"/>
                         UnhideWhenUsed="false" Name="Light Shading Accent 4"/>
                         UnhideWhenUsed="false" Name="Light List Accent 4"/>
                         UnhideWhenUsed="false" Name="Light Grid Accent 4"/>
                         UnhideWhenUsed="false" Name="Medium Shading 1 Accent 4"/>
                         UnhideWhenUsed="false" Name="Medium Shading 2 Accent 4"/>
                         UnhideWhenUsed="false" Name="Medium List 1 Accent 4"/>
                         UnhideWhenUsed="false" Name="Medium List 2 Accent 4"/>
                         UnhideWhenUsed="false" Name="Medium Grid 1 Accent 4"/>
                         UnhideWhenUsed="false" Name="Medium Grid 2 Accent 4"/>
                         UnhideWhenUsed="false" Name="Medium Grid 3 Accent 4"/>
                         UnhideWhenUsed="false" Name="Dark List Accent 4"/>
                         UnhideWhenUsed="false" Name="Colorful Shading Accent 4"/>
                         UnhideWhenUsed="false" Name="Colorful List Accent 4"/>
                         UnhideWhenUsed="false" Name="Colorful Grid Accent 4"/>
                         UnhideWhenUsed="false" Name="Light Shading Accent 5"/>
                         UnhideWhenUsed="false" Name="Light List Accent 5"/>
                         UnhideWhenUsed="false" Name="Light Grid Accent 5"/>
                         UnhideWhenUsed="false" Name="Medium Shading 1 Accent 5"/>
                         UnhideWhenUsed="false" Name="Medium Shading 2 Accent 5"/>
                         UnhideWhenUsed="false" Name="Medium List 1 Accent 5"/>
                         UnhideWhenUsed="false" Name="Medium List 2 Accent 5"/>
                         UnhideWhenUsed="false" Name="Medium Grid 1 Accent 5"/>
                         UnhideWhenUsed="false" Name="Medium Grid 2 Accent 5"/>
                         UnhideWhenUsed="false" Name="Medium Grid 3 Accent 5"/>
                         UnhideWhenUsed="false" Name="Dark List Accent 5"/>
                         UnhideWhenUsed="false" Name="Colorful Shading Accent 5"/>
                         UnhideWhenUsed="false" Name="Colorful List Accent 5"/>
                         UnhideWhenUsed="false" Name="Colorful Grid Accent 5"/>
                         UnhideWhenUsed="false" Name="Light Shading Accent 6"/>
                         UnhideWhenUsed="false" Name="Light List Accent 6"/>
                         UnhideWhenUsed="false" Name="Light Grid Accent 6"/>
                         UnhideWhenUsed="false" Name="Medium Shading 1 Accent 6"/>
                         UnhideWhenUsed="false" Name="Medium Shading 2 Accent 6"/>
                         UnhideWhenUsed="false" Name="Medium List 1 Accent 6"/>
                         UnhideWhenUsed="false" Name="Medium List 2 Accent 6"/>
                         UnhideWhenUsed="false" Name="Medium Grid 1 Accent 6"/>
                         UnhideWhenUsed="false" Name="Medium Grid 2 Accent 6"/>
                         UnhideWhenUsed="false" Name="Medium Grid 3 Accent 6"/>
                         UnhideWhenUsed="false" Name="Dark List Accent 6"/>
                         UnhideWhenUsed="false" Name="Colorful Shading Accent 6"/>
                         UnhideWhenUsed="false" Name="Colorful List Accent 6"/>
                         UnhideWhenUsed="false" Name="Colorful Grid Accent 6"/>
                        <w:LsdException Locked="false" Priority="19" SemiHidden="false"
                         UnhideWhenUsed="false" QFormat="true" Name="Subtle Emphasis"/>
                        <w:LsdException Locked="false" Priority="21" SemiHidden="false"
                         UnhideWhenUsed="false" QFormat="true" Name="Intense Emphasis"/>
                        <w:LsdException Locked="false" Priority="31" SemiHidden="false"
                         UnhideWhenUsed="false" QFormat="true" Name="Subtle Reference"/>
                        <w:LsdException Locked="false" Priority="32" SemiHidden="false"
                         UnhideWhenUsed="false" QFormat="true" Name="Intense Reference"/>
                        <w:LsdException Locked="false" Priority="33" SemiHidden="false"
                         UnhideWhenUsed="false" QFormat="true" Name="Book Title"/>
                        <w:LsdException Locked="false" Priority="37" Name="Bibliography"/>
                        <w:LsdException Locked="false" Priority="39" QFormat="true" Name="TOC Heading"/>
                      </w:LatentStyles>
                      </xml><![endif]-->
                      <!--[if gte mso 10]>
                      <style>
                      /* Style Definitions */
                      table.MsoNormalTable
                          {mso-style-name:"Table Normal";
                          mso-tstyle-rowband-size:0;
                          mso-tstyle-colband-size:0;
                          mso-style-noshow:yes;
                          mso-style-priority:99;
                          mso-style-parent:"";
                          mso-padding-alt:0in 5.4pt 0in 5.4pt;
                          mso-para-margin:0in;
                          mso-para-margin-bottom:.0001pt;
                          mso-pagination:widow-orphan;
                          font-size:10.0pt;
                          font-family:"Times New Roman","serif";}
                      </style>
                      <![endif]-->
                      <o:shapedefaults v:ext="edit" spidmax="1026"/>
                      </xml><![endif]-->
                      <o:shapelayout v:ext="edit">
                        <o:idmap v:ext="edit" data="1"/>
                      </o:shapelayout></xml><![endif]-->
                      It is clear to me why the two files you sent me are causing the exception. As Open Office .DOC files, they are corrupted.
                      • 8. Re: OpenOffice under CF 9 throws com.sun.star.task.ErrorCodeIOException
                        el_sim Level 1
                        Thank you for your attention to this problem. Those files are not corrupted. They open nicely and they can be seen neat and clean with all the desired features.
                        One of our developers figured out that the OpenOffice converter "chokes" on the table objects created in Word 97-2003 in all of these files.
                        Does someone know anything about how the PDF converter works with the older Word? Is there any known limitation on how many generations of formats the OpenOffice converter accepts?
