2 Replies Latest reply on Dec 15, 2012 9:14 AM by Noel Carboni
    Photoshop CS6 ppi setting
    TarakV
      It looks like, that in  CS6 the Crop Tool you can no longer set the PPI - Is this so?
      If so, who on Earth made that decision, it was real time saver. This would effect me to the extent I'll go back to CS5 as I'm using this feature quite a lot. Pity because CS6 has some nice features.
        • 1. Re: Photoshop CS6 ppi setting
          conroy Level 5
          When the crop frame with black handles is visible (e.g. after clicking on the image with Crop Tool), press R key for a dialog where you can enter resolution.
          • 2. Re: Photoshop CS6 ppi setting
            Noel Carboni Level 8
            The PPI can be set in Photoshop 13.0 - it's just done a bit more indirectly, by choosing Size & Resolution from the drop-down menu.  You can make it a bit more direct by defining a preset, assuming you use the same values over and over.
            Direct 3 box operation of the Crop tool has been restored in the 13.1 version Cloud subscribers have just received...
            -Noel
