9 Replies Latest reply on Dec 19, 2012 8:00 AM by Xiaoyi Tong
    Dreamweaver CS6 no longer shows up in Extension Manager
    parker1111
      Just tried to install an extension within Extension Manger CS6 - and Dreamweaver does not appear in the list of programs. Doe anyone know what do I need to do to get it back? Thanks
        • 1. Re: Dreamweaver CS6 no longer shows up in Extension Manager
          Carl Sun Level 4
          Which extension have you installed? Could you generate log files to help troubleshooting? Refer to http://forums.adobe.com/message/4275082#4275082 for the steps.
          • 2. Re: Dreamweaver CS6 no longer shows up in Extension Manager
            Helen Eichel Level 1
            Below is the log. Thanks for your help
            12/18/12 12:06:50.020 AM com.apple.launchd.peruser.501[145]: (com.apple.PackageKit.InstallStatus) Throttling respawn: Will start in 10 seconds
            12/18/12 12:07:16.918 AM loginwindow[94]: *** WARNING: -[NSImage compositeToPoint:operation:] is deprecated in MacOSX 10.8 and later. Please use -[NSImage drawAtPoint:fromRect:operation:fraction:] instead.
            12/18/12 12:07:16.919 AM loginwindow[94]: *** WARNING: -[NSImage compositeToPoint:fromRect:operation:] is deprecated in MacOSX 10.8 and later. Please use -[NSImage drawAtPoint:fromRect:operation:fraction:] instead.
            12/18/12 12:07:18.445 AM com.apple.launchd.peruser.501[145]: ([0x0-0x1ab1ab].com.microsoft.error_reporting[4266]) Exited: Terminated: 15
            12/18/12 12:07:18.445 AM coreservicesd[28]: UnblockWaitingSyncronousLaunches(), err=268435459 from mach_msg_send()
            12/18/12 12:07:18.486 AM WindowServer[121]: dict count after removing entry for window 0x28 is 0
            12/18/12 12:07:18.523 AM WindowServer[121]: CGXGetConnectionProperty: Invalid connection 41219
            12/18/12 12:07:18.524 AM WindowServer[121]: CGXGetConnectionProperty: Invalid connection 41219
            12/18/12 12:07:18.527 AM coreservicesd[28]: SendFlattenedData, got error #268435459 (ipc/send) invalid destination port from ::mach_msg(), sending notification kLSNotifyApplicationDeath to notificationID=178
            12/18/12 12:07:18.528 AM coreservicesd[28]: SendFlattenedData, got error #268435459 (ipc/send) invalid destination port from ::mach_msg(), sending notification kLSNotifyApplicationDeath to notificationID=166
            12/18/12 12:07:18.532 AM com.apple.launchd.peruser.501[145]: (com.apple.talagent[158]) Exited: Killed: 9
            12/18/12 12:07:18.533 AM com.apple.launchd.peruser.501[145]: (com.prosofteng.DGMonitor[189]) Exited: Killed: 9
            12/18/12 12:07:18.541 AM Splashtop Streamer[201]: going to close SRFeature.
            12/18/12 12:07:18.553 AM WindowServer[121]: CGXGetConnectionProperty: Invalid connection 41219
            12/18/12 12:07:18.554 AM coreservicesd[28]: SendFlattenedData, got error #268435460 (ipc/send) timed out from ::mach_msg(), sending notification kLSNotifyApplicationDeath to notificationID=930
            12/18/12 12:07:18.554 AM WindowServer[121]: CGXGetConnectionProperty: Invalid connection 41219
            12/18/12 12:07:18.798 AM coreservicesd[28]: SendFlattenedData, got error #268435459 (ipc/send) invalid destination port from ::mach_msg(), sending notification kLSNotifyApplicationDeath to notificationID=150
            12/18/12 12:07:18.799 AM WindowServer[121]: CGXGetConnectionProperty: Invalid connection 41219
            12/18/12 12:07:18.902 AM SRServiceAgent[183]: cannot find SRFeature
            12/18/12 12:07:19.045 AM loginwindow[94]: sendQuitEventToApp (FMCore): AESendMessage returned error -1712
            12/18/12 12:07:19.067 AM loginwindow[94]: sendQuitEventToApp (Image Capture Extension): AESendMessage returned error -600
            12/18/12 12:07:19.067 AM loginwindow[94]: Application terminate returned -600
            12/18/12 12:07:19.068 AM com.apple.launchd.peruser.501[145]: ([0x0-0x24024].com.apple.AppleSpell[268]) Exited: Terminated: 15
            12/18/12 12:07:19.070 AM com.apple.launchd.peruser.501[145]: (com.apple.mdworker.shared.04000000-0000-0000-0000-000000000000[4985]) Exited: Killed: 9
            12/18/12 12:07:19.070 AM com.apple.launchd.peruser.501[145]: (com.apple.mdworker.bundles[5013]) Exited: Killed: 9
            12/18/12 12:07:19.076 AM com.apple.launchd.peruser.501[145]: (com.apple.CalendarAgent[178]) Exited: Killed: 9
            12/18/12 12:07:19.544 AM Splashtop Streamer[201]:    AC Power
            12/18/12 12:07:20.084 AM loginwindow[94]: DEAD_PROCESS: 94 console
            12/18/12 12:07:20.152 AM com.apple.kextd[12]: Warning: /Volumes/Macintosh HD/System/Library/Extensions: No such file or directory
            12/18/12 12:07:20.154 AM airportd[5015]: _doAutoJoin: Already associated to “abrazite”. Bailing on auto-join.
            12/18/12 12:07:20.157 AM shutdown[5018]: halt by Imacom:
            12/18/12 12:07:20.157 AM shutdown[5018]: SHUTDOWN_TIME: 1355807240 157154
            12/18/12 12:07:20.168 AM UserEventAgent[148]: [CaptiveServerDied:1107] Captive Daemon Died @port 64555
            12/18/12 7:02:25.000 AM bootlog[0]: BOOT_TIME 1355832145 0
            12/18/12 7:02:27.000 AM kernel[0]: PMAP: PCID enabled
            12/18/12 7:02:27.000 AM kernel[0]: Darwin Kernel Version 12.2.0: Sat Aug 25 00:48:52 PDT 2012; root:xnu-2050.18.24~1/RELEASE_X86_64
            12/18/12 7:02:27.000 AM kernel[0]: vm_page_bootstrap: 8169427 free pages and 186413 wired pages
            12/18/12 7:02:27.000 AM kernel[0]: kext submap [0xffffff7f80741000 - 0xffffff8000000000], kernel text [0xffffff8000200000 - 0xffffff8000741000]
            12/18/12 7:02:27.000 AM kernel[0]: zone leak detection enabled
            12/18/12 7:02:27.000 AM kernel[0]: standard timeslicing quantum is 10000 us
            12/18/12 7:02:27.000 AM kernel[0]: standard background quantum is 2500 us
            12/18/12 7:02:27.000 AM kernel[0]: mig_table_max_displ = 74
            12/18/12 7:02:27.000 AM kernel[0]: corecrypto kext started!
            12/18/12 7:02:27.000 AM kernel[0]: Running kernel space in FIPS MODE
            12/18/12 7:02:27.000 AM kernel[0]: Plist hmac value is    735d392b68241ef173d81097b1c8ce9ba283521626d1c973ac376838c466757d
            12/18/12 7:02:27.000 AM kernel[0]: Computed hmac value is 735d392b68241ef173d81097b1c8ce9ba283521626d1c973ac376838c466757d
            12/18/12 7:02:27.000 AM kernel[0]: corecrypto.kext FIPS integrity POST test passed!
            12/18/12 7:02:27.000 AM kernel[0]: corecrypto.kext FIPS AES CBC POST test passed!
            12/18/12 7:02:27.000 AM kernel[0]: corecrypto.kext FIPS TDES CBC POST test passed!
            12/18/12 7:02:27.000 AM kernel[0]: corecrypto.kext FIPS AES ECB AESNI POST test passed!
            12/18/12 7:02:27.000 AM kernel[0]: corecrypto.kext FIPS AES XTS AESNI POST test passed!
            12/18/12 7:02:27.000 AM kernel[0]: corecrypto.kext FIPS SHA POST test passed!
            12/18/12 7:02:27.000 AM kernel[0]: corecrypto.kext FIPS HMAC POST test passed!
            12/18/12 7:02:27.000 AM kernel[0]: corecrypto.kext FIPS ECDSA POST test passed!
            12/18/12 7:02:27.000 AM kernel[0]: corecrypto.kext FIPS DRBG POST test passed!
            12/18/12 7:02:27.000 AM kernel[0]: corecrypto.kext FIPS POST passed!
            12/18/12 7:02:27.000 AM kernel[0]: AppleACPICPU: ProcessorId=0 LocalApicId=0 Enabled
            12/18/12 7:02:27.000 AM kernel[0]: AppleACPICPU: ProcessorId=1 LocalApicId=32 Enabled
            12/18/12 7:02:27.000 AM kernel[0]: AppleACPICPU: ProcessorId=2 LocalApicId=2 Enabled
            12/18/12 7:02:27.000 AM kernel[0]: AppleACPICPU: ProcessorId=3 LocalApicId=34 Enabled
            12/18/12 7:02:27.000 AM kernel[0]: AppleACPICPU: ProcessorId=4 LocalApicId=4 Enabled
            12/18/12 7:02:25.749 AM com.apple.launchd[1]: *** launchd[1] has started up. ***
            12/18/12 7:02:27.000 AM kernel[0]: AppleACPICPU: ProcessorId=5 LocalApicId=36 Enabled
            12/18/12 7:02:27.000 AM kernel[0]: AppleACPICPU: ProcessorId=6 LocalApicId=16 Enabled
            12/18/12 7:02:27.000 AM kernel[0]: AppleACPICPU: ProcessorId=7 LocalApicId=48 Enabled
            12/18/12 7:02:27.000 AM kernel[0]: AppleACPICPU: ProcessorId=8 LocalApicId=18 Enabled
            12/18/12 7:02:27.000 AM kernel[0]: AppleACPICPU: ProcessorId=9 LocalApicId=50 Enabled
            12/18/12 7:02:27.000 AM kernel[0]: AppleACPICPU: ProcessorId=10 LocalApicId=20 Enabled
            12/18/12 7:02:27.000 AM kernel[0]: AppleACPICPU: ProcessorId=11 LocalApicId=52 Enabled
            12/18/12 7:02:27.000 AM kernel[0]: AppleACPICPU: ProcessorId=12 LocalApicId=1 Enabled
            12/18/12 7:02:27.000 AM kernel[0]: AppleACPICPU: ProcessorId=13 LocalApicId=33 Enabled
            12/18/12 7:02:27.000 AM kernel[0]: AppleACPICPU: ProcessorId=14 LocalApicId=3 Enabled
            12/18/12 7:02:27.000 AM kernel[0]: AppleACPICPU: ProcessorId=15 LocalApicId=35 Enabled
            12/18/12 7:02:27.000 AM kernel[0]: AppleACPICPU: ProcessorId=16 LocalApicId=5 Enabled
            12/18/12 7:02:27.000 AM kernel[0]: AppleACPICPU: ProcessorId=17 LocalApicId=37 Enabled
            12/18/12 7:02:27.000 AM kernel[0]: AppleACPICPU: ProcessorId=18 LocalApicId=17 Enabled
            12/18/12 7:02:27.000 AM kernel[0]: AppleACPICPU: ProcessorId=19 LocalApicId=49 Enabled
            12/18/12 7:02:27.000 AM kernel[0]: AppleACPICPU: ProcessorId=20 LocalApicId=19 Enabled
            12/18/12 7:02:27.000 AM kernel[0]: AppleACPICPU: ProcessorId=21 LocalApicId=51 Enabled
            12/18/12 7:02:27.000 AM kernel[0]: AppleACPICPU: ProcessorId=22 LocalApicId=21 Enabled
            12/18/12 7:02:27.000 AM kernel[0]: AppleACPICPU: ProcessorId=23 LocalApicId=53 Enabled
            12/18/12 7:02:27.000 AM kernel[0]: calling mpo_policy_init for TMSafetyNet
            12/18/12 7:02:27.000 AM kernel[0]: Security policy loaded: Safety net for Time Machine (TMSafetyNet)
            12/18/12 7:02:27.000 AM kernel[0]: calling mpo_policy_init for Sandbox
            12/18/12 7:02:27.000 AM kernel[0]: Security policy loaded: Seatbelt sandbox policy (Sandbox)
            12/18/12 7:02:27.000 AM kernel[0]: calling mpo_policy_init for Quarantine
            12/18/12 7:02:27.000 AM kernel[0]: Security policy loaded: Quarantine policy (Quarantine)
            12/18/12 7:02:27.000 AM kernel[0]: Copyright (c) 1982, 1986, 1989, 1991, 1993
            12/18/12 7:02:27.000 AM kernel[0]: The Regents of the University of California. All rights reserved.
            12/18/12 7:02:27.000 AM kernel[0]: MAC Framework successfully initialized
            12/18/12 7:02:27.000 AM kernel[0]: using 16384 buffer headers and 10240 cluster IO buffer headers
            12/18/12 7:02:27.000 AM kernel[0]: IOAPIC: Version 0x20 Vectors 64:87
            12/18/12 7:02:27.000 AM kernel[0]: ACPI: System State [S0 S3 S4 S5]
            12/18/12 7:02:27.000 AM kernel[0]: PFM64 (40 cpu) 0xff80000000, 0x80000000
            12/18/12 7:02:27.000 AM kernel[0]: [ PCI configuration begin ]
            12/18/12 7:02:27.000 AM kernel[0]: AppleIntelCPUPowerManagement: Turbo Ratios 222233
            12/18/12 7:02:27.000 AM kernel[0]: AppleIntelCPUPowerManagement: (built 23:03:24 Jun 24 2012) initialization complete
            12/18/12 7:02:27.000 AM kernel[0]: console relocated to 0xff80010000
            12/18/12 7:02:27.000 AM kernel[0]: PCI configuration changed (bridge=7 device=2 cardbus=0)
            12/18/12 7:02:27.000 AM kernel[0]: [ PCI configuration end, bridges 15 devices 51 ]
            12/18/12 7:02:27.000 AM kernel[0]: mbinit: done [128 MB total pool size, (85/42) split]
            12/18/12 7:02:27.000 AM kernel[0]: Pthread support ABORTS when sync kernel primitives misused
            12/18/12 7:02:27.000 AM kernel[0]: ETH0 cannot assert wake from D3cold
            12/18/12 7:02:27.000 AM kernel[0]: ETH1 cannot assert wake from D3cold
            12/18/12 7:02:27.000 AM kernel[0]: rooting via boot-uuid from /chosen: 725DCE99-0F42-35F8-83CF-232BE79F8C0F
            12/18/12 7:02:27.000 AM kernel[0]: Waiting on <dict ID="0"><key>IOProviderClass</key><string ID="1">IOResources</string><key>IOResourceMatch</key><string ID="2">boot-uuid-media</string></dict>
            12/18/12 7:02:27.000 AM kernel[0]: com.apple.AppleFSCompressionTypeZlib kmod start
            12/18/12 7:02:27.000 AM kernel[0]: com.apple.AppleFSCompressionTypeDataless kmod start
            12/18/12 7:02:27.000 AM kernel[0]: com.apple.AppleFSCompressionTypeZlib load succeeded
            12/18/12 7:02:27.000 AM kernel[0]: com.apple.AppleFSCompressionTypeDataless load succeeded
            12/18/12 7:02:27.000 AM kernel[0]: AppleIntelCPUPowerManagementClient: ready
            12/18/12 7:02:27.000 AM kernel[0]: Intel82574L::start - Built Jun 24 2012 23:07:38 -- running on device at b10 d0 f0
            12/18/12 7:02:27.000 AM kernel[0]: Intel82574L::start - Built Jun 24 2012 23:07:38 -- running on device at b9 d0 f0
            12/18/12 7:02:27.000 AM kernel[0]: BTCOEXIST off
            12/18/12 7:02:27.000 AM kernel[0]: BRCM tunables:
            12/18/12 7:02:27.000 AM kernel[0]: pullmode[1] txringsize[  256] reapmin[   32] reapcount[  128]
            12/18/12 7:02:27.000 AM kernel[0]: highWaterMark: VO[  192]  VI[  192]  BE[  192]  BK[  192]
            12/18/12 7:02:25.749 AM com.apple.launchd[1]: *** Shutdown logging is enabled. ***
            12/18/12 7:02:27.657 AM com.apple.launchd[1]: (com.apple.automountd) Unknown key for boolean: NSSupportsSuddenTermination
            12/18/12 7:02:27.000 AM kernel[0]: FireWire (OHCI) TI ID 823f built-in now active, GUID 78ca39fffe123fc8; max speed s800.
            12/18/12 7:02:27.000 AM kernel[0]: Got boot device = IOService:/AppleACPIPlatformExpert/PCI0@0/AppleACPIPCI/SATA@1F,2/AppleAHCI/PRT2@2/IOAHCID evice@0/AppleAHCIDiskDriver/IOAHCIBlockStorageDevice/IOBlockStorageDriver/OCZ-VERTEX4 Media/IOGUIDPartitionScheme/Vertex SSD @2
            12/18/12 7:02:27.000 AM kernel[0]: BSD root: disk0s2, major 1, minor 2
            12/18/12 7:02:27.000 AM kernel[0]: Kernel is LP64
            12/18/12 7:02:27.000 AM kernel[0]: USBF:          1.494          [0xffffff80403c6000] The IOUSBFamily is having trouble enumerating a USB device that has been plugged in.  It will keep retrying.  (Port 3 of Hub at 0x1d100000)
            12/18/12 7:02:28.000 AM kernel[0]: Intel82574L: Ethernet address e8:06:88:cc:10:44
            12/18/12 7:02:28.000 AM kernel[0]: Intel82574L: Ethernet address e8:06:88:cc:24:84
            12/18/12 7:02:28.000 AM kernel[0]: AirPort_Brcm4331: Ethernet address 00:26:08:fd:72:91
            12/18/12 7:02:28.000 AM kernel[0]: IO80211Controller::dataLinkLayerAttachComplete():  adding AppleEFINVRAM notification
            12/18/12 7:02:29.393 AM airportd[27]: _processDLILEvent: en2 attached (down)
            12/18/12 7:02:29.443 AM com.apple.SecurityServer[15]: Session 100000 created
            12/18/12 7:02:29.000 AM kernel[0]: createVirtIf(): ifRole = 1
            12/18/12 7:02:29.000 AM kernel[0]: in func createVirtualInterface ifRole = 1
            12/18/12 7:02:29.000 AM kernel[0]: AirPort_Brcm4331_P2PInterface::init name <p2p0> role 1 this 0xffffff8040eae000
            12/18/12 7:02:29.000 AM kernel[0]: AirPort_Brcm4331_P2PInterface::init() <p2p> role 1
            12/18/12 7:02:29.000 AM kernel[0]: Created virtif 0xffffff8040eae000 p2p0
            12/18/12 7:02:29.000 AM kernel[0]: USBF:          4.757          [0xffffff80403c6000] The IOUSBFamily was not able to enumerate a device.
            12/18/12 7:02:29.485 AM com.apple.SecurityServer[15]: Entering service
            12/18/12 7:02:29.555 AM UserEventAgent[11]: Captive: [HandleNetworkInformationChanged:2435] nwi_state_copy returned NULL
            12/18/12 7:02:29.683 AM mDNSResponder[51]: mDNSResponder mDNSResponder-379.32.1 (Aug 31 2012 19:05:06) starting OSXVers 12
            12/18/12 7:02:29.768 AM systemkeychain[56]: done file: /var/run/systemkeychaincheck.done
            12/18/12 7:02:29.796 AM mDNSResponder[51]: D2D_IPC: Loaded
            12/18/12 7:02:29.796 AM mDNSResponder[51]: D2DInitialize succeeded
            12/18/12 7:02:29.000 AM kernel[0]: Intel82574L::setLinkStatus - not active  1face000, 0
            12/18/12 7:02:29.000 AM kernel[0]: AirPort: Link Down on en2. Reason 8 (Disassociated because station leaving).
            12/18/12 7:02:29.000 AM kernel[0]: en2::IO80211Interface::postMessage bssid changed
            12/18/12 7:02:29.000 AM kernel[0]: Previous Shutdown Cause: 5
            12/18/12 7:02:29.000 AM kernel[0]: IOBluetoothUSBDFU::probe
            12/18/12 7:02:29.000 AM kernel[0]: IOBluetoothUSBDFU::probe ProductID - 0x8215 FirmwareVersion - 0x0201
            12/18/12 7:02:29.000 AM kernel[0]: [BroadcomBluetoothHCIControllerUSBTransport][start] -- completed
            12/18/12 7:02:29.000 AM kernel[0]: [IOBluetoothHCIController][staticBluetoothHCIControllerTransportShowsUp] -- Received Bluetooth Controller register service notification
            12/18/12 7:02:29.000 AM kernel[0]: [IOBluetoothHCIController][start] -- completed
            12/18/12 7:02:29.000 AM kernel[0]: [IOBluetoothHCIController::setConfigState] calling registerService
            12/18/12 7:02:29.000 AM kernel[0]: [AGPM Controller] unknownPlatform
            12/18/12 7:02:29.000 AM kernel[0]: AppleTyMCEDriver::start coreVIDPID = 0x2c708086 Number of packages = 1 Number of cpus = 24 memory monitor trough PCI
            12/18/12 7:02:29.000 AM kernel[0]: Intel82574L::setLinkStatus - not active  1face001, 0
            12/18/12 7:02:30.307 AM configd[17]: bootp_session_transmit: bpf_write(en2) failed: Network is down (50)
            12/18/12 7:02:30.307 AM configd[17]: DHCP en2: INIT-REBOOT transmit failed
            12/18/12 7:02:30.327 AM configd[17]: setting hostname to "Mac-Pro-Imacom-5.local"
            12/18/12 7:02:30.000 AM kernel[0]: DSMOS has arrived
            12/18/12 7:02:30.000 AM kernel[0]: Intel82574L::setLinkStatus - not active  1face001, 0
            12/18/12 7:02:30.000 AM kernel[0]: USBF:          5.660          [0xffffff80403c6000] The IOUSBFamily is having trouble enumerating a USB device that has been plugged in.  It will keep retrying.  (Port 3 of Hub at 0x1d100000)
            12/18/12 7:02:30.348 AM configd[17]: network changed: DNS*
            12/18/12 7:02:30.000 AM kernel[0]: Intel82574L::setLinkStatus - not active  1face000, 0
            12/18/12 7:02:31.000 AM kernel[0]: MacAuthEvent en2   Auth result for: 00:0f:66:43:a4:fa  MAC AUTH succeeded
            12/18/12 7:02:31.000 AM kernel[0]: MacAuthEvent en2   Auth result for: 00:0f:66:43:a4:fa Unsolicited  Auth
            12/18/12 7:02:31.000 AM kernel[0]: wlEvent: en2 en2 Link UP virtIf = 0
            12/18/12 7:02:31.000 AM kernel[0]: AirPort: Link Up on en2
            12/18/12 7:02:31.000 AM kernel[0]: en2: BSSID changed to 00:0f:66:43:a4:fa
            12/18/12 7:02:31.000 AM kernel[0]: en2::IO80211Interface::postMessage bssid changed
            12/18/12 7:02:31.971 AM airportd[27]: _doAutoJoin: Already associated to “abrazite”. Bailing on auto-join.
            12/18/12 7:02:31.990 AM airportd[27]: _doAutoJoin: Already associated to “abrazite”. Bailing on auto-join.
            12/18/12 7:02:31.000 AM kernel[0]: AirPort: RSN handshake complete on en2
            12/18/12 7:02:32.268 AM hidd[99]: Posting 'com.apple.iokit.hid.displayStatus' notifyState=1
            12/18/12 7:02:32.271 AM hidd[99]: void __IOHIDLoadBundles(): Loaded 0 HID plugins
            12/18/12 7:02:32.279 AM coreservicesd[28]: FindBestLSSession(), no match for inSessionID 0xfffffffffffffffc auditTokenInfo( uid=0 euid=0 auSessionID=100000 create=false
            12/18/12 7:02:32.316 AM awacsd[107]: Starting awacsd connectivity-78 (Jul 26 2012 14:37:46)
            12/18/12 7:02:32.000 AM kernel[0]: macx_swapon SUCCESS
            12/18/12 7:02:32.346 AM kdc[97]: label: default
            12/18/12 7:02:32.346 AM kdc[97]:           dbname: od:/Local/Default
            12/18/12 7:02:32.346 AM kdc[97]:           mkey_file: /var/db/krb5kdc/m-key
            12/18/12 7:02:32.346 AM kdc[97]:           acl_file: /var/db/krb5kdc/kadmind.acl
            12/18/12 7:02:32.350 AM awacsd[107]: InnerStore CopyAllZones: no info in Dynamic Store
            12/18/12 7:02:32.354 AM apsd[109]: CGSLookupServerRootPort: Failed to look up the port for "com.apple.windowserver.active" (1102)
            12/18/12 7:02:32.356 AM apsd[109]: CGSLookupServerRootPort: Failed to look up the port for "com.apple.windowserver.active" (1102)
            12/18/12 7:02:32.356 AM appleeventsd[104]: main: Starting up
            12/18/12 7:02:32.363 AM com.apple.kextd[12]: Can't load /System/Library/Extensions/CiscoVPN.kext - no code for running kernel's architecture.
            12/18/12 7:02:32.363 AM netbiosd[90]: Unable to start NetBIOS name service:
            12/18/12 7:02:32.367 AM SystemStarter[80]: Cisco Systems VPN Client Kernel Extension (118) did not complete successfully
            12/18/12 7:02:32.368 AM SystemStarter[80]: The following StartupItems failed to start properly:
            12/18/12 7:02:32.368 AM SystemStarter[80]: /System/Library/StartupItems/CiscoVPN
            12/18/12 7:02:32.368 AM SystemStarter[80]:  - execution of Startup script failed
            12/18/12 7:02:32.370 AM kdc[97]: WARNING Found KDC certificate (O=System Identity,CN=com.apple.kerberos.kdc)is missing the PK-INIT KDC EKU, this is bad for interoperability.
            12/18/12 7:02:32.379 AM loginwindow[94]: Login Window Application Started
            12/18/12 7:02:32.386 AM com.apple.usbmuxd[78]: usbmuxd-296.3 on Jul 25 2012 at 00:28:37, running 64 bit
            12/18/12 7:02:32.424 AM kdc[97]: KDC started
            12/18/12 7:02:32.453 AM locationd[95]: NOTICE,Location icon should now be in state 0
            12/18/12 7:02:32.489 AM mds[91]: (Normal) FMW: FMW 0 0
            12/18/12 7:02:32.493 AM WindowServer[122]: Server is starting up
            12/18/12 7:02:32.496 AM WindowServer[122]: Session 256 retained (2 references)
            12/18/12 7:02:32.496 AM WindowServer[122]: Session 256 released (1 references)
            12/18/12 7:02:32.506 AM WindowServer[122]: Session 256 retained (2 references)
            12/18/12 7:02:32.507 AM WindowServer[122]: init_page_flip: page flip mode is on
            12/18/12 7:02:32.839 AM BBDaemon[111]: IOBSDNameMatching returned a NULL dictionary.
            12/18/12 7:02:32.000 AM kernel[0]: Ethernet [Intel82574L]: Link up on en0, 1-Gigabit, Full-duplex, Symmetric flow-control, Debug [796d,af48,0de1,0200,c5e1,2800]
            12/18/12 7:02:32.000 AM kernel[0]: Intel82574L::setLinkStatus - active  1face000, b
            12/18/12 7:02:34.003 AM WindowServer[122]: mux_initialize: Couldn't find any matches
            12/18/12 7:02:34.000 AM kernel[0]: USBF:          9.346          [0xffffff80403c6000] The IOUSBFamily was not able to enumerate a device.
            12/18/12 7:02:34.018 AM WindowServer[122]: GLCompositor enabled for tile size [256 x 256]
            12/18/12 7:02:34.019 AM WindowServer[122]: CGXGLInitMipMap: mip map mode is on
            12/18/12 7:02:34.043 AM WindowServer[122]: WSMachineUsesNewStyleMirroring: false
            12/18/12 7:02:34.044 AM WindowServer[122]: Display 0x04241064: GL mask 0x1; bounds (0, 0)[2560 x 1600], 57 modes available
            Main, Active, on-line, enabled, boot, Vendor 610, Model 9232, S/N 2009ce4, Unit 0, Rotation 0
            UUID 0x000006100000923202009ce400000000
            12/18/12 7:02:34.044 AM WindowServer[122]: Display 0x003f003e: GL mask 0x4; bounds (0, 0)[0 x 0], 1 modes available
            off-line, enabled, Vendor ffffffff, Model ffffffff, S/N ffffffff, Unit 2, Rotation 0
            UUID 0xffffffffffffffffffffffff003f003e
            12/18/12 7:02:34.044 AM WindowServer[122]: Display 0x003f003d: GL mask 0x2; bounds (0, 0)[0 x 0], 1 modes available
            off-line, enabled, Vendor ffffffff, Model ffffffff, S/N ffffffff, Unit 1, Rotation 0
            UUID 0xffffffffffffffffffffffff003f003d
            12/18/12 7:02:34.053 AM WindowServer[122]: Created shield window 0x5 for display 0x04241064
            12/18/12 7:02:34.053 AM WindowServer[122]: Created shield window 0x6 for display 0x003f003e
            12/18/12 7:02:34.053 AM WindowServer[122]: Created shield window 0x7 for display 0x003f003d
            12/18/12 7:02:34.054 AM WindowServer[122]: Display 0x04241064: GL mask 0x1; bounds (0, 0)[2560 x 1600], 57 modes available
            12/18/12 7:02:34.054 AM WindowServer[122]: Display 0x003f003e: GL mask 0x4; bounds (3584, 0)[1 x 1], 1 modes available
            12/18/12 7:02:34.055 AM WindowServer[122]: Display 0x003f003d: GL mask 0x2; bounds (3585, 0)[1 x 1], 1 modes available
            12/18/12 7:02:34.055 AM WindowServer[122]: CGXPerformInitialDisplayConfiguration
            12/18/12 7:02:34.055 AM WindowServer[122]:   Display 0x04241064: MappedDisplay Unit 0; Vendor 0x610 Model 0x9232 S/N 33594596 Dimensions 25.24 x 15.79; online enabled, Bounds (0,0)[2560 x 1600], Rotation 0, Resolution 1
            12/18/12 7:02:34.055 AM WindowServer[122]:   Display 0x003f003e: MappedDisplay Unit 2; Vendor 0xffffffff Model 0xffffffff S/N -1 Dimensions 0.00 x 0.00; offline enabled, Bounds (3584,0)[1 x 1], Rotation 0, Resolution 1
            12/18/12 7:02:34.055 AM WindowServer[122]:   Display 0x003f003d: MappedDisplay Unit 1; Vendor 0xffffffff Model 0xffffffff S/N -1 Dimensions 0.00 x 0.00; offline enabled, Bounds (3585,0)[1 x 1], Rotation 0, Resolution 1
            12/18/12 7:02:34.079 AM WindowServer[122]: GLCompositor: GL renderer id 0x01021b01, GL mask 0x00000007, accelerator 0x00004037, unit 0, caps QEX|QGL|MIPMAP, vram 1024 MB
            12/18/12 7:02:34.079 AM WindowServer[122]: GLCompositor: GL renderer id 0x01021b01, GL mask 0x00000007, texture units 8, texture max 16384, viewport max {16384, 16384}, extensions FPRG|NPOT|GLSL|FLOAT
            12/18/12 7:02:34.082 AM loginwindow[94]: **DMPROXY** Found `/System/Library/CoreServices/DMProxy'.
            12/18/12 7:02:34.085 AM launchctl[127]: launchctl: Dubious permissions on file (skipping): /Library/LaunchAgents/com.adobe.AAM.Updater-1.0.plist
            12/18/12 7:02:34.119 AM WindowServer[122]: Created shield window 0x8 for display 0x04241064
            12/18/12 7:02:34.120 AM WindowServer[122]: Display 0x04241064: MappedDisplay Unit 0; ColorProfile { 2, "Cinema HD"}; TransferFormula (1.000000, 1.000000, 1.000000)
            12/18/12 7:02:34.125 AM launchctl[129]: launchctl: Dubious permissions on file (skipping): /Library/LaunchAgents/com.adobe.AAM.Updater-1.0.plist
            12/18/12 7:02:34.140 AM launchctl[129]: com.apple.findmymacmessenger: Already loaded
            12/18/12 7:02:34.152 AM com.apple.SecurityServer[15]: Session 100005 created
            12/18/12 7:02:34.166 AM airportd[27]: _doAutoJoin: Already associated to “abrazite”. Bailing on auto-join.
            12/18/12 7:02:34.196 AM loginwindow[94]: Login Window Started Security Agent
            12/18/12 7:02:34.257 AM SecurityAgent[140]: This is the first run
            12/18/12 7:02:34.257 AM SecurityAgent[140]: MacBuddy was run = 0
            12/18/12 7:02:34.267 AM WindowServer[122]: MPAccessSurfaceForDisplayDevice: Set up page flip mode on display 0x04241064 device: 0x10a8fb320  isBackBuffered: 1 numComp: 3 numDisp: 3
            12/18/12 7:02:34.294 AM SecurityAgent[140]: User info context values set for Imacom
            12/18/12 7:02:34.579 AM loginwindow[94]: Login Window - Returned from Security Agent
            12/18/12 7:02:34.604 AM loginwindow[94]: ERROR | ScreensharingLoginNotification | Failed sending message to screen sharing GetScreensharingPort, err: 1102
            12/18/12 7:02:34.614 AM loginwindow[94]: USER_PROCESS: 94 console
            12/18/12 7:02:34.634 AM airportd[27]: _doAutoJoin: Already associated to “abrazite”. Bailing on auto-join.
            12/18/12 7:02:34.641 AM launchctl[146]: launchctl: Dubious permissions on file (skipping): /Library/LaunchAgents/com.adobe.AAM.Updater-1.0.plist
            12/18/12 7:02:34.660 AM launchctl[147]: launchctl: Dubious permissions on file (skipping): /Library/LaunchAgents/com.adobe.AAM.Updater-1.0.plist
            12/18/12 7:02:34.667 AM com.apple.launchd[1]: (com.wacom.wacomtablet[136]) Exited with code: 255
            12/18/12 7:02:34.673 AM com.apple.launchd.peruser.501[145]: (com.apple.gamed) Ignored this key: UserName
            12/18/12 7:02:34.673 AM com.apple.launchd.peruser.501[145]: (com.apple.gamed) Ignored this key: GroupName
            12/18/12 7:02:34.674 AM com.apple.launchd.peruser.501[145]: (com.apple.ReportCrash) Falling back to default Mach exception handler. Could not find: com.apple.ReportCrash.Self
            12/18/12 7:02:34.678 AM loginwindow[94]: Connection with distnoted server was invalidated
            12/18/12 7:02:34.684 AM distnoted[149]: # distnote server agent  absolute time: 10.031002845   civil time: Tue Dec 18 07:02:34 2012   pid: 149 uid: 501  root: no
            12/18/12 7:02:34.723 AM WindowServer[122]: **DMPROXY** (2) Found `/System/Library/CoreServices/DMProxy'.
            12/18/12 7:02:34.959 AM com.apple.SecurityServer[15]: Session 100003 created
            12/18/12 7:02:34.979 AM WindowServer[122]: Display 0x04241064: MappedDisplay Unit 0; ColorProfile { 2, "Cinema HD"}; TransferFormula (1.000000, 1.000000, 1.000000)
            12/18/12 7:02:34.988 AM coreservicesd[28]: SendFlattenedData, got error #268435460 (ipc/send) timed out from ::mach_msg(), sending notification kLSNotifyApplicationReady to notificationID=122
            12/18/12 7:02:35.000 AM kernel[0]: USBF:          10.235          [0xffffff80403c6000] The IOUSBFamily is having trouble enumerating a USB device that has been plugged in.  It will keep retrying.  (Port 3 of Hub at 0x1d100000)
            12/18/12 7:02:35.008 AM coreservicesd[28]: SendFlattenedData, got error #268435460 (ipc/send) timed out from ::mach_msg(), sending notification kLSNotifyApplicationBirth to notificationID=122
            12/18/12 7:02:35.033 AM talagent[158]: _LSSetApplicationInformationItem(kLSDefaultSessionID, asn, _kLSApplicationIsHiddenKey, hidden ? kCFBooleanTrue : kCFBooleanFalse, NULL) produced OSStatus -50 on line 623 in TCApplication.m
            12/18/12 7:02:35.041 AM talagent[158]: _LSSetApplicationInformationItem(kLSDefaultSessionID, asn, TAL_kLSIsProxiedForTALKey, kCFBooleanTrue, NULL) produced OSStatus -50 on line 626 in TCApplication.m
            12/18/12 7:02:35.043 AM com.apple.launchd.peruser.501[145]: (com.akamai.client.plist[190]) Bug: 12C60: launchd + 95444 [7DCC9489-2DF5-3807-83FA-EF5666EE8078]: 0xd
            12/18/12 7:02:35.043 AM com.apple.launchd.peruser.501[145]: (com.akamai.single-user-client[189]) Bug: 12C60: launchd + 95444 [7DCC9489-2DF5-3807-83FA-EF5666EE8078]: 0xd
            12/18/12 7:02:35.049 AM com.apple.launchd.peruser.501[145]: (com.adobe.ARM.0d92f8f114b2d0af95462120762f939f6c66651ac8ac214cb7bdbd84[193]) Exited with code: 2
            12/18/12 7:02:35.050 AM com.apple.launchd.peruser.501[145]: (com.apple.afpstat-qfa[179]) Exited with code: 2
            12/18/12 7:02:35.000 AM kernel[0]: CODE SIGNING: cs_invalid_page(0x1000): p=183[GoogleSoftwareUp] clearing CS_VALID
            12/18/12 7:02:35.081 AM SRServiceAgent[181]: service agent got ipc message: 1094931542
            12/18/12 7:02:35.082 AM SRServiceAgent[181]: try start streamer
            12/18/12 7:02:35.085 AM SRServiceAgent[181]: start check timer
            12/18/12 7:02:35.086 AM SRServiceAgent[181]: create new task
            12/18/12 7:02:35.086 AM SRServiceAgent[181]: task is not running, launch task
            12/18/12 7:02:35.125 AM launchctl[197]: launchctl: Dubious permissions on file (skipping): /Library/LaunchAgents/com.adobe.AAM.Updater-1.0.plist
            12/18/12 7:02:35.197 AM NetworkBrowserAgent[202]: Starting NetworkBrowserAgent
            12/18/12 7:02:35.384 AM Splashtop Streamer[195]: NSWindow does not support utility styleMask 0x10
            12/18/12 7:02:35.387 AM Splashtop Streamer[195]: NSWindow does not support utility styleMask 0x10
            12/18/12 7:02:35.392 AM Splashtop Streamer[195]: NSWindow does not support utility styleMask 0x10
            12/18/12 7:02:35.398 AM Splashtop Streamer[195]: NSWindow does not support utility styleMask 0x10
            12/18/12 7:02:35.401 AM Splashtop Streamer[195]: NSWindow does not support utility styleMask 0x10
            12/18/12 7:02:35.409 AM GoogleSoftwareUpdateDaemon[211]: -[KeystoneDaemon logServiceState] GoogleSoftwareUpdate daemon (1.1.0.3659) vending:
                      com.google.Keystone.Daemon.UpdateEngine: 2 connection(s)
                      com.google.Keystone.Daemon.Administration: 0 connection(s)
            12/18/12 7:02:35.413 AM Splashtop Streamer[195]: Could not connect the action toggleServer: to target of class SplashtopRemoteAppDelegate
            12/18/12 7:02:35.431 AM Splashtop Streamer[195]: ---- http://www.splashtop.com/splashtop2#otherproducts-tab
            12/18/12 7:02:35.437 AM GoogleSoftwareUpdateDaemon[211]: -[KSUpdateEngine updateProductID:] KSUpdateEngine updating product ID: "com.google.Keystone"
            12/18/12 7:02:35.446 AM GoogleSoftwareUpdateDaemon[211]: -[KSCheckAction performAction] KSCheckAction checking 1 ticket(s).
            12/18/12 7:02:35.459 AM GoogleSoftwareUpdateDaemon[211]: -[KSUpdateCheckAction performAction] KSUpdateCheckAction starting update check for ticket(s): {(
                      <KSTicket:0x5546470
                                productID=com.google.Keystone
                                version=1.1.0.3659
                                xc=<KSPathExistenceChecker:0x5546000 path=/Library/Google/GoogleSoftwareUpdate/GoogleSoftwareUpdate.bundle/>
                                serverType=Omaha
                                url=https://tools.google.com/service/update2
                                creationDate=2011-07-11 14:46:13
            Using server: <KSOmahaServer:0x1848210
                      engine=<KSDaemonUpdateEngine:0x1846fc0>
                      params={
                                EngineVersion = "1.1.0.3659";
                                ActivesInfo = {
                                          "com.google.picasa" = {
                                                    LastRollCallPingDate = 2012-12-17 08:00:00 +0000;
                                                    LastActivePingDate = 2012-03-16 07:00:00 +0000;
                                                    LastActiveDate = 2012-03-16 03:12:34 +0000;
                                          "com.google.Chrome" = {
                                                    LastActiveDate = 2012-11-16 04:43:04 +0000;
                                                    LastActivePingDate = 2012-11-16 08:00:01 +0000;
                                          "com.google.Keystone" = {
                                                    LastActiveDate = 2012-12-18 12:02:35 +0000;
                                                    LastActivePingDate = 2012-12-17 08:00:00 +0000;
                                          "com.google.GoogleDrive" = {
                                                    LastActiveDate = 2012-12-08 20:19:33 +0000;
                                                    LastActivePingDate = 2012-12-09 08:00:00 +0000;
                                          "com.google.talkplugin" = {
                                                    LastActivePingDate = 2012-07-21 07:00:00 +0000;
                                                    LastActiveDate = 2012-01-19 13:54:09 +0000;
                                UserInitiated = 0;
                                IsSystem = 1;
                                OmahaOSVersion = "10.8.2_i486";
                                Identity = KeystoneDaemon;
                                AllowedSubdomains = (
                                          ".omaha.sandbox.google.com",
                                          ".tools.google.com",
                                          ".www.google.com",
                                          ".corp.google.com"
            12/18/12 7:02:35.463 AM Splashtop Streamer[195]: -[DisplayView initWithFrame:] [{{0, 0}, {380, 70}}][{{0, 0}, {380, 70}}]
            12/18/12 7:02:35.465 AM Splashtop Streamer[195]: -[DisplayView(Private) setTextField:string:] 1 [{{20, 0}, {380, 70}}]
            12/18/12 7:02:35.466 AM Splashtop Streamer[195]: -[DisplayView(Private) setTextField:string:] 2 [{{20, 0}, {85, 14}}]
            12/18/12 7:02:35.469 AM GoogleSoftwareUpdateDaemon[211]: -[KSUpdateCheckAction performAction] KSUpdateCheckAction running KSServerUpdateRequest: <KSOmahaServerUpdateRequest:0x4946170
                      server=<KSOmahaServer:0x1848210>
                      url="https://tools.google.com/service/update2"
                      runningFetchers=0
                      tickets=1
                      activeTickets=1
                      rollCallTickets=1
                      body=
                                <?xml version="1.0" encoding="UTF-8" standalone="yes"?>
                                <o:gupdate xmlns:o="http://www.google.com/update2/request" protocol="2.0" version="KeystoneDaemon-1.1.0.3659" ismachine="1">
                                    <o:os platform="mac" version="MacOSX" sp="10.8.2_i486"></o:os>
                                    <o:app appid="com.google.Keystone" version="1.1.0.3659" lang="en-us" installage="525" brand="GGLG">
                                        <o:ping r="1" a="1"></o:ping>
                                        <o:updatecheck></o:updatecheck>
                                    </o:app>
                                </o:gupdate>
            12/18/12 7:02:35.499 AM DGAgent[187]: Resolved DG link from bookmark. /Applications/Drive Genius 3.app
            12/18/12 7:02:35.563 AM CalendarAgent[176]: *** -[IADomainCache init]: IA domains cache is out of date.
            12/18/12 7:02:35.617 AM launchctl[222]: launchctl: Dubious permissions on file (skipping): /Library/LaunchAgents/com.adobe.AAM.Updater-1.0.plist
            12/18/12 7:02:35.766 AM GoogleSoftwareUpdateDaemon[211]: -[KSOutOfProcessFetcher(PrivateMethods) helperDidTerminate:] The Internet connection appears to be offline. [NSURLErrorDomain:-1009]
            12/18/12 7:02:35.766 AM GoogleSoftwareUpdateDaemon[211]: -[KSServerUpdateRequest(PrivateMethods) fetcher:failedWithError:] KSServerUpdateRequest fetch failed. (productIDs: com.google.Keystone) [com.google.UpdateEngine.CoreErrorDomain:702 - 'https://tools.google.com/service/update2'] (The Internet connection appears to be offline. [NSURLErrorDomain:-1009])
            12/18/12 7:02:35.767 AM GoogleSoftwareUpdateDaemon[211]: -[KSUpdateCheckAction(PrivateMethods) finishAction] KSUpdateCheckAction found updates: {( )}
            12/18/12 7:02:35.772 AM GoogleSoftwareUpdateDaemon[211]: -[KSPrefetchAction performAction] KSPrefetchAction no updates to prefetch.
            12/18/12 7:02:35.773 AM GoogleSoftwareUpdateDaemon[211]: -[KSMultiUpdateAction performAction] KSSilentUpdateAction had no updates to apply.
            12/18/12 7:02:35.775 AM GoogleSoftwareUpdateDaemon[211]: -[KSMultiUpdateAction performAction] KSPromptAction had no updates to apply.
            12/18/12 7:02:35.775 AM Splashtop Streamer[195]: going to close SRFeature.
            12/18/12 7:02:35.779 AM GoogleSoftwareUpdateDaemon[211]: -[KSUpdateEngine(PrivateMethods) updateFinish] KSUpdateEngine update processing complete.
            12/18/12 7:02:35.896 AM YouSendIt Desktop App[229]: Set Version number 2.0.0.204
            12/18/12 7:02:35.902 AM Trim Enabler[226]: ON
            12/18/12 7:02:36.000 AM kernel[0]: USBF:          11. 97          [0xffffff80403c6000] The IOUSBFamily gave up enumerating a USB device after 10 retries.  (Port 3 of Hub at 0x1d100000)
            12/18/12 7:02:36.000 AM kernel[0]: USBF:          11. 97          [0xffffff80403c6000] The IOUSBFamily was not able to enumerate a device.
            12/18/12 7:02:36.054 AM WindowServer[122]: **DMPROXY** (2) Found `/System/Library/CoreServices/DMProxy'.
            12/18/12 7:02:36.101 AM WindowServer[122]: Display 0x04241064: MappedDisplay Unit 0; ColorProfile { 2, "Cinema HD"}; TransferFormula (1.000000, 1.000000, 1.000000)
            12/18/12 7:02:36.125 AM WindowServer[122]: Display 0x04241064: MappedDisplay Unit 0; ColorProfile { 2, "Cinema HD"}; TransferFormula (1.000000, 1.000000, 1.000000)
            12/18/12 7:02:36.260 AM YouSendIt Desktop App[229]: finderPearlServerConnection = (** NSConnection 0x101c086e0 receivePort <NSMachPort: 0x101c08500> sendPort <NSMachPort: 0x101c08500> refCount 1 remoteUsesKeyedDO: 0 **), pearlServices = <YSIPearlServices: 0x101c01920>
            12/18/12 7:02:36.292 AM YouSendIt Desktop App[229]: Need to check OSAX bundle
            12/18/12 7:02:36.293 AM YouSendIt Desktop App[229]: internal version=2.0.0.204, installed version=2.0.0.204
            12/18/12 7:02:36.293 AM coreservicesd[28]: SendFlattenedData, got error #268435460 (ipc/send) timed out from ::mach_msg(), sending notification kLSNotifyApplicationReady to notificationID=163
            12/18/12 7:02:36.294 AM YouSendIt Desktop App[229]: No valid connection
            12/18/12 7:02:36.365 AM Finder[160]: SDL checking if Pearl was loaded. hasLoaded=NO, addr=1089ac2f4
            12/18/12 7:02:36.365 AM Finder[160]: not loaded, returning 1
            12/18/12 7:02:36.365 AM Finder[160]: handleYSILoad
            12/18/12 7:02:36.367 AM Finder[160]: YSI pearl loaded
            12/18/12 7:02:36.436 AM Finder[160]: pearl listener registered
            12/18/12 7:02:36.548 AM GoogleSoftwareUpdateDaemon[211]: -[KSUpdateEngine updateAllProducts] KSUpdateEngine updating all installed products.
            12/18/12 7:02:36.551 AM GoogleSoftwareUpdateDaemon[211]: -[KSCheckAction performAction] KSCheckAction checking 2 ticket(s).
            12/18/12 7:02:36.579 AM GoogleSoftwareUpdateDaemon[211]: -[KSUpdateCheckAction performAction] KSUpdateCheckAction starting update check for ticket(s): {(
                      <KSTicket:0x5547540
                                version=1.1.0.3659
                                xc=<KSPathExistenceChecker:0x5546d20 path=/Library/Google/GoogleSoftwareUpdate/GoogleSoftwareUpdate.bundle/>
                                serverType=Omaha
                      <KSTicket:0x5547af0
                                productID=com.google.talkplugin
                                version=3.10.2.10212
                                xc=<KSPathExistenceChecker:0x5546250 path=/Library/Application Support/Google/GoogleTalkPlugin.app>
                                serverType=Omaha
                                creationDate=2012-07-20 22:50:59
            Using server: <KSOmahaServer:0x3646350
                      params={
                                ActivesInfo = {
                                UserInitiated = 0;
                                IsSystem = 1;
                                          ".www.google.com",
                                          ".corp.google.com"
            12/18/12 7:02:36.581 AM GoogleSoftwareUpdateDaemon[211]: -[KSUpdateCheckAction performAction] KSUpdateCheckAction running KSServerUpdateRequest: <KSOmahaServerUpdateRequest:0x36473c0
                      server=<KSOmahaServer:0x3646350>
                      runningFetchers=0
                      tickets=2
                      activeTickets=1
                      rollCallTickets=2
                      body=
                                    </o:app>
                                    <o:app appid="com.google.talkplugin" version="3.10.2.10212" lang="en-us" installage="150" brand="GGLG">
                                        <o:ping r="1"></o:ping>
                                    </o:app>
                                </o:gupdate>
            12/18/12 7:02:36.000 AM kernel[0]: Finder (map: 0xffffff804051c6a8) triggered DYLD shared region unnest for map: 0xffffff804051c6a8, region 0x7fff8e600000->0x7fff8e800000. While not abnormal for debuggers, this increases system memory footprint until the target exits.
            12/18/12 7:02:36.653 AM CalendarAgent[176]: [com.apple.calendar.store.log.caldav.queue] [Account refresh failed with error: Error Domain=NSURLErrorDomain Code=-1009 "The Internet connection appears to be offline." UserInfo=0x7fe75e017ac0 {NSUnderlyingError=0x7fe761e13160 "The Internet connection appears to be offline.", NSErrorFailingURLStringKey=https://imacom%40imacomdesign.com@www.google.com/calendar/dav/imacom%40imacomdesign.com/us er///imacom%40imacomdesign.com@www.google.com/calendar/dav/imacom%40imacomdesign.com/user/, NSErrorFailingURLKey=https://imacom%40imacomdesign.com@www.google.com/calendar/dav/imacom%40imacomdesign.com/us er///imacom%40imacomdesign.com@www.google.com/calendar/dav/imacom%40imacomdesign.com/user/, AccountName=hmeichel@imacomdesign.com, CalDAVErrFromRefresh=YES, NSLocalizedDescription=The Internet connection appears to be offline.}]
            12/18/12 7:02:36.657 AM coreservicesd[28]: SendFlattenedData, got error #268435460 (ipc/send) timed out from ::mach_msg(), sending notification kLSNotifyApplicationReady to notificationID=181
            12/18/12 7:02:36.714 AM GoogleSoftwareUpdateDaemon[211]: -[KSOutOfProcessFetcher(PrivateMethods) helperDidTerminate:] The Internet connection appears to be offline. [NSURLErrorDomain:-1009]
            12/18/12 7:02:36.714 AM GoogleSoftwareUpdateDaemon[211]: -[KSServerUpdateRequest(PrivateMethods) fetcher:failedWithError:] KSServerUpdateRequest fetch failed. (productIDs: com.google.Keystone, ... (2)) [com.google.UpdateEngine.CoreErrorDomain:702 - 'https://tools.google.com/service/update2'] (The Internet connection appears to be offline. [NSURLErrorDomain:-1009])
            12/18/12 7:02:36.716 AM GoogleSoftwareUpdateDaemon[211]: -[KSUpdateCheckAction(PrivateMethods) finishAction] KSUpdateCheckAction found updates: {( )}
            12/18/12 7:02:36.722 AM GoogleSoftwareUpdateDaemon[211]: -[KSPrefetchAction performAction] KSPrefetchAction no updates to prefetch.
            12/18/12 7:02:36.723 AM GoogleSoftwareUpdateDaemon[211]: -[KSMultiUpdateAction performAction] KSSilentUpdateAction had no updates to apply.
            12/18/12 7:02:36.724 AM GoogleSoftwareUpdateDaemon[211]: -[KSMultiUpdateAction performAction] KSPromptAction had no updates to apply.
            12/18/12 7:02:36.727 AM GoogleSoftwareUpdateDaemon[211]: -[KSUpdateEngine(PrivateMethods) updateFinish] KSUpdateEngine update processing complete.
            12/18/12 7:02:36.776 AM appleprofilepolicyd[240]: appleprofilepolicyd: profiling drivers not loaded, loading
            12/18/12 7:02:36.821 AM SRFeature[242]: Display server path : /Applications/Splashtop Streamer.app/Contents/MacOS/SRFeature.app/Contents/MacOS/SRXDisplayServer.app/Contents/Ma cOS/SRXDisplayServer
            12/18/12 7:02:36.842 AM SRXDisplayServer[244]: No SRX Display Card
            12/18/12 7:02:37.114 AM SRFeature[242]: pInfo data: [2][b000000][b][0]
            12/18/12 7:02:37.116 AM SRFeature[242]: FH: GetInfo
            12/18/12 7:02:37.839 AM coreservicesd[28]: SendFlattenedData, got error #268435460 (ipc/send) timed out from ::mach_msg(), sending notification kLSNotifyChildApplicationLaunch to notificationID=131
            12/18/12 7:02:37.869 AM configd[17]: network changed: v4(en0+:10.10.1.104) DNS+ Proxy+ SMB
            12/18/12 7:02:36.860 AM ntpd[74]: proto: precision = 1.000 usec
            12/18/12 7:02:37.342 AM blued[71]: kBTXPCUpdateUserPreferences gConsoleUserUID = 501
            12/18/12 7:02:37.485 AM coreaudiod[138]: 2012-12-18 07:02:37.484586 AM [AirPlay] Started browsing for _airplay._tcp.
            12/18/12 7:02:37.485 AM coreaudiod[138]: 2012-12-18 07:02:37.485139 AM [AirPlay] Started browsing for _raop._tcp.
            12/18/12 7:02:37.777 AM Trim Enabler[226]: ON
            12/18/12 7:02:37.980 AM com.apple.launchd[1]: (com.apple.xprotectupdater[76]) Exited with code: 252
            12/18/12 7:02:38.000 AM kernel[0]: Intel82574L::timeoutHandler - no link - reset the chipset once  1face001, 0
            12/18/12 7:02:38.000 AM kernel[0]: Intel82574L::setLinkStatus - not active  1face001, 0
            12/18/12 7:02:39.277 AM locationd[291]: NOTICE,Location icon should now be in state 0
            12/18/12 7:02:39.000 AM kernel[0]: Intel82574L::setLinkStatus - not active  1face001, 0
            12/18/12 7:02:39.338 AM UserEventAgent[148]: cannot find fw daemon port 1102
            12/18/12 7:02:39.353 AM GoogleSoftwareUpdateDaemon[211]: -[KeystoneDaemon logServiceState] GoogleSoftwareUpdate daemon (1.1.0.3659) vending:
                      com.google.Keystone.Daemon.UpdateEngine: 1 connection(s)
            12/18/12 7:02:40.373 AM launchctl[304]: launchctl: Dubious permissions on file (skipping): /Library/LaunchAgents/com.adobe.AAM.Updater-1.0.plist
            12/18/12 7:02:40.515 AM com.apple.launchd.peruser.501[145]: ([0x0-0x1f01f].com.yousendit.YouSendIt[229]) Job appears to have crashed: Abort trap: 6
            12/18/12 7:02:40.623 AM Splashtop Streamer[195]: SRFEAT_NOTIFY_SERVER_CLOUD_NOTIFY_MSG
            12/18/12 7:02:40.623 AM Splashtop Streamer[195]: [ProcServerNotification] SRS_SERVER_RTN_INFO : [200][.srloginnotify.xml]
            12/18/12 7:02:40.625 AM Splashtop Streamer[195]:   receive backend string notify
            12/18/12 7:02:40.625 AM Splashtop Streamer[195]: -[CMXMLParser length]: unrecognized selector sent to instance 0x101600330
            12/18/12 7:02:40.628 AM Splashtop Streamer[195]: (
                      0   CoreFoundation                      0x00007fff8bddd0a6 __exceptionPreprocess + 198
                      1   libobjc.A.dylib                     0x00007fff8d0a03f0 objc_exception_throw + 43
                      2   CoreFoundation                      0x00007fff8be736ea -[NSObject(NSObject) doesNotRecognizeSelector:] + 186
                      3   CoreFoundation                      0x00007fff8bdcb5ce ___forwarding___ + 414
                      4   CoreFoundation                      0x00007fff8bdcb3b8 _CF_forwarding_prep_0 + 232
                      5   Foundation                          0x00007fff8b995ea8 -[NSPlaceholderString initWithString:] + 169
                      6   Splashtop Streamer                  0x000000010000be8f -[SplashtopRemoteAppDelegate getXMLContent:] + 199
                      7   CoreFoundation                      0x00007fff8be395cc ____CFXNotificationPostToken_block_invoke_0 + 284
                      8   CoreFoundation                      0x00007fff8bd9a272 __CFRUNLOOP_IS_CALLING_OUT_TO_A_BLOCK__ + 18
                      9   CoreFoundation                      0x00007fff8bd5aa4f __CFRunLoopDoBlocks + 255
                      10  CoreFoundation                      0x00007fff8bd7edda __CFRunLoopRun + 810
                      11  CoreFoundation                      0x00007fff8bd7e6b2 CFRunLoopRunSpecific + 290
                      12  HIToolbox                           0x00007fff8dcb20a4 RunCurrentEventLoopInMode + 209
                      13  HIToolbox                           0x00007fff8dcb1e42 ReceiveNextEventCommon + 356
                      14  HIToolbox                           0x00007fff8dcb1cd3 BlockUntilNextEventMatchingListInMode + 62
                      15  AppKit                              0x00007fff90c7d613 _DPSNextEvent + 685
                      16  AppKit                              0x00007fff90c7ced2 -[NSApplication nextEventMatchingMask:untilDate:inMode:dequeue:] + 128
                      17  AppKit                              0x00007fff90c74283 -[NSApplication run] + 517
                      18  AppKit                              0x00007fff90c18cb6 NSApplicationMain + 869
                      19  Splashtop Streamer                  0x00000001000018b4 start + 52
            12/18/12 7:02:40.700 AM ReportCrash[246]: Saved crash report for YouSendIt Desktop App[229] version 2.0.0.204 (2.0.0.204) to /Users/Imacom/Library/Logs/DiagnosticReports/YouSendIt Desktop App_2012-12-18-070240_Mac-Pro-Imacom-5.crash
            12/18/12 7:02:40.719 AM ReportCrash[246]: Removing excessive log: file://localhost/Users/Imacom/Library/Logs/DiagnosticReports/YouSendIt%20Desktop%20App_20 12-11-21-081142_Mac-Pro-Imacom-5.crash
            12/18/12 7:02:40.862 AM Trim Enabler[226]: /Applications/Trim En
            12/18/12 7:02:41.352 AM iCalExternalSync[265]: [0x7fa98040e460] |Miscellaneous|Error| SyncServices precondition failure in [ISyncConcreteSession pushChangesFromRecord:withIdentifier:]: you can't change the record's entity name from com.apple.calendars.MailAlarm to com.apple.calendars.DisplayAlarm in {
                "com.apple.syncservices.RecordEntityName" = "com.apple.calendars.DisplayAlarm";
                description = "";
                owner =     (
                    "Event/p935"
                triggerduration = "-900";
            12/18/12 7:02:41.353 AM iCalExternalSync[265]: [ICalExternalSync ]Encountered exception: [ISyncConcreteSession pushChangesFromRecord:withIdentifier:]: you can't change the record's entity name from com.apple.calendars.MailAlarm to com.apple.calendars.DisplayAlarm in {
                description = "";
                owner =     (
                    "Event/p935"
            } withStack: (
                      0   iCalExternalSync                    0x000000010655ba60 iCalExternalSync + 125536
                      1   iCalExternalSync                    0x000000010654aac9 iCalExternalSync + 56009
                      2   iCalExternalSync                    0x000000010655a694 iCalExternalSync + 120468
                      3   libdyld.dylib                       0x00007fff91f037e1 start + 0
            12/18/12 7:02:41.353 AM iCalExternalSync[265]: [ICalExternalSync ]NSException name:ISyncInvalidArgumentsException reason:[ISyncConcreteSession pushChangesFromRecord:withIdentifier:]: you can't change the record's entity name from com.apple.calendars.MailAlarm to com.apple.calendars.DisplayAlarm in {
                description = "";
                owner =     (
                    "Event/p935"
            12/18/12 7:02:41.354 AM SyncServer[274]: [0x7fd958c0be00] |Server|Warning| lost connection 0x7fd95d01dfd0 to com.apple.iCal
            12/18/12 7:02:42.531 AM Splashtop Streamer[195]: going to close SRFeature.
            12/18/12 7:02:42.534 AM configd[17]: network changed: v4(en0:10.10.1.104, en2+:10.10.1.110) DNS* Proxy SMB
            12/18/12 7:02:42.551 AM UserEventAgent[11]: Captive: en2: Not probing 'abrazite' (protected network)
            12/18/12 7:02:42.555 AM configd[17]: network changed: v4(en0:10.10.1.104, en2!:10.10.1.110) DNS Proxy SMB
            12/18/12 7:02:45.022 AM CalendarAgent[176]: [com.apple.calendar.store.log.caldav] [During deep refresh in calendar "ImacomDesign", had collection tag match, but etag mismatch for url https://www.google.com/calendar/dav/imacom%40imacomdesign.com/events/http%3A%2F%2Fwww.brig httalk.com%2Fwebcast%2F452%2F30511.ics: server resource not present locally - cTag:63491464012 syncToken:(null)]
            12/18/12 7:02:45.023 AM CalendarAgent[176]: [com.apple.calendar.store.log.caldav] [During deep refresh in calendar "ImacomDesign", had collection tag match, but etag mismatch for url https://www.google.com/calendar/dav/imacom%40imacomdesign.com/events/http%3A%2F%2Fwww.brig httalk.com%2Fwebcast%2F21640.ics: server resource not present locally - cTag:63491464012 syncToken:(null)]
            12/18/12 7:02:46.257 AM awacsd[107]: Exiting
            12/18/12 7:02:46.689 AM Splashtop Streamer[195]: cannot create remote port
            12/18/12 7:02:46.689 AM Splashtop Streamer[195]: Error -50 sending  ping to SRFeature.
            12/18/12 7:02:46.689 AM Splashtop Streamer[195]: Can not find SRFeature alive
            12/18/12 7:02:46.690 AM Splashtop Streamer[195]: going to close SRFeature.
            12/18/12 7:02:47.730 AM SRFeature[311]: Display server path : /Applications/Splashtop Streamer.app/Contents/MacOS/SRFeature.app/Contents/MacOS/SRXDisplayServer.app/Contents/Ma cOS/SRXDisplayServer
            12/18/12 7:02:47.750 AM SRXDisplayServer[313]: No SRX Display Card
            12/18/12 7:02:47.974 AM SRFeature[311]: pInfo data: [2][b000000][b][0]
            12/18/12 7:02:47.975 AM SRFeature[311]: FH: GetInfo
            12/18/12 7:02:51.312 AM CalendarAgent[176]: [com.apple.calendar.store.log.caldav] [During deep refresh in calendar "Helen Eichel - Work", had collection tag match, but etag mismatch for url https://www.google.com/calendar/dav/imacomdesign.com_7klr0v2r8acrf2adifrcupk6i4%40group.ca lendar.google.com/events/http%3A%2F%2Fwww.brighttalk.com%2Fwebcast%2F21640.ics: server resource not present locally - cTag:63486933486 syncToken:(null)]
            12/18/12 7:02:51.312 AM CalendarAgent[176]: [com.apple.calendar.store.log.caldav] [During deep refresh in calendar "Helen Eichel - Work", had collection tag match, but etag mismatch for url https://www.google.com/calendar/dav/imacomdesign.com_7klr0v2r8acrf2adifrcupk6i4%40group.ca lendar.google.com/events/http%3A%2F%2Fwww.brighttalk.com%2Fwebcast%2F452%2F30511.ics: server resource not present locally - cTag:63486933486 syncToken:(null)]
            12/18/12 7:02:52.844 AM Splashtop Streamer[195]: SRFEAT_NOTIFY_SERVER_CLOUD_NOTIFY_MSG
            12/18/12 7:02:52.000 AM kernel[0]: Sandbox: sandboxd(214) deny mach-lookup com.apple.coresymbolicationd
            12/18/12 7:02:52.844 AM Splashtop Streamer[195]: [ProcServerNotification] SRS_SERVER_RTN_INFO : [200][.srloginnotify.xml]
            12/18/12 7:02:52.845 AM Splashtop Streamer[195]:   receive backend string notify
            12/18/12 7:02:52.845 AM Splashtop Streamer[195]: -[CMXMLParser length]: unrecognized selector sent to instance 0x103e0e8c0
            12/18/12 7:02:52.846 AM Splashtop Streamer[195]: -[CMXMLParser length]: unrecognized selector sent to instance 0x103e0e8c0
            12/18/12 7:02:52.847 AM Splashtop Streamer[195]: (
                      10  CoreFoundation                      0x00007fff8bd7f220 __CFRunLoopRun + 1904
            12/18/12 7:02:52.848 AM Splashtop Streamer[195]:   receive backend string notify
            12/18/12 7:02:52.848 AM Splashtop Streamer[195]: -[CMXMLParser length]: unrecognized selector sent to instance 0x101511e20
            12/18/12 7:02:52.849 AM Splashtop Streamer[195]: (
                      10  CoreFoundation                      0x00007fff8bd7edb4 __CFRunLoopRun + 772
                      13  HIToolbox                           0x00007fff8dcb1d84 ReceiveNextEventCommon + 166
            12/18/12 7:02:53.561 AM com.apple.launchd[1]: (com.apple.coreservices.appleid.authentication[135]) Exit timeout elapsed (20 seconds). Killing
            12/18/12 7:02:57.194 AM iCalExternalSync[320]: [0x7fb7d9c0e460] |Miscellaneous|Error| SyncServices precondition failure in [ISyncConcreteSession pushChangesFromRecord:withIdentifier:]: you can't change the record's entity name from com.apple.calendars.MailAlarm to com.apple.calendars.DisplayAlarm in {
                description = "";
                owner =     (
                    "Event/p935"
            12/18/12 7:02:57.194 AM iCalExternalSync[320]: [ICalExternalSync ]Encountered exception: [ISyncConcreteSession pushChangesFromRecord:withIdentifier:]: you can't change the record's entity name from com.apple.calendars.MailAlarm to com.apple.calendars.DisplayAlarm in {
                description = "";
                owner =     (
                    "Event/p935"
            } withStack: (
                      0   iCalExternalSync                    0x000000010fd44a60 iCalExternalSync + 125536
                      1   iCalExternalSync                    0x000000010fd33ac9 iCalExternalSync + 56009
                      2   iCalExternalSync                    0x000000010fd43694 iCalExternalSync + 120468
            12/18/12 7:02:57.195 AM iCalExternalSync[320]: [ICalExternalSync ]NSException name:ISyncInvalidArgumentsException reason:[ISyncConcreteSession pushChangesFromRecord:withIdentifier:]: you can't change the record's entity name from com.apple.calendars.MailAlarm to com.apple.calendars.DisplayAlarm in {
                description = "";
                owner =     (
                    "Event/p935"
            12/18/12 7:02:57.196 AM SyncServer[274]: [0x7fd958c0be00] |Server|Warning| lost connection 0x7fd95aa15fb0 to com.apple.iCal
            12/18/12 7:02:58.730 AM sandboxd[214]: ([317]) WebProcess(317) deny mach-lookup ATS Query Port 184
            12/18/12 7:02:58.740 AM sandboxd[214]: ([317]) WebProcess(317) deny mach-lookup ATS Query Port 184
            12/18/12 7:02:58.749 AM sandboxd[214]: ([317]) WebProcess(317) deny mach-lookup ATS Query Port 184
            12/18/12 7:02:58.757 AM sandboxd[214]: ([317]) WebProcess(317) deny mach-lookup ATS Query Port 184
            12/18/12 7:02:58.768 AM sandboxd[214]: ([317]) WebProcess(317) deny mach-lookup ATS Query Port 184
            12/18/12 7:02:58.778 AM sandboxd[214]: ([317]) WebProcess(317) deny mach-lookup ATS Query Port 184
            12/18/12 7:02:58.788 AM sandboxd[214]: ([317]) WebProcess(317) deny mach-lookup ATS Query Port 184
            12/18/12 7:02:58.810 AM sandboxd[214]: ([317]) WebProcess(317) deny mach-lookup ATS Query Port 184
            12/18/12 7:03:05.412 AM GoogleSoftwareUpdateDaemon[211]: -[KeystoneDaemon main] GoogleSoftwareUpdateDaemon inactive, shutdown.
            12/18/12 7:03:07.741 AM GoogleTalkPlugin[327]: objc[327]: Class MacCocoaSocketServerHelper is implemented in both /Library/Application Support/Google/GoogleTalkPlugin.app/Contents/MacOS/GoogleTalkPlugin and /Library/Application Support/Google/GoogleTalkPlugin.app/Contents/Frameworks/libgoogletalkremoting.dylib. One of the two will be used. Which one is undefined.
            12/18/12 7:03:07.810 AM GoogleTalkPlugin[328]: objc[328]: Class MacCocoaSocketServerHelper is implemented in both /Library/Application Support/Google/GoogleTalkPlugin.app/Contents/MacOS/GoogleTalkPlugin and /Library/Application Support/Google/GoogleTalkPlugin.app/Contents/Frameworks/libgoogletalkremoting.dylib. One of the two will be used. Which one is undefined.
            12/18/12 7:03:08.047 AM GoogleTalkPlugin[328]: QuickTimeUSBVDCDigitizer:  Found a camera (0xfffffffffd300000) , but was not able to start it up (0xe00002c5)
            12/18/12 7:03:08.333 AM com.apple.launchd.peruser.501[145]: ([0x0-0x2d02d].com.google.GoogleTalkPluginD[327]) Exited with code: 1
            12/18/12 7:03:33.276 AM launchctl[334]: launchctl: Dubious permissions on file (skipping): /Library/LaunchAgents/com.adobe.AAM.Updater-1.0.plist
            12/18/12 7:03:33.471 AM com.apple.SecurityServer[15]: Session 100002 created
            12/18/12 7:06:36.000 AM kernel[0]: Sandbox: sandboxd(350) deny mach-lookup com.apple.coresymbolicationd
            12/18/12 7:06:36.526 AM sandboxd[350]: ([317]) WebProcess(317) deny mach-lookup ATS Query Port 184
            12/18/12 7:06:36.537 AM sandboxd[350]: ([317]) WebProcess(317) deny mach-lookup ATS Query Port 184
            12/18/12 7:06:36.546 AM sandboxd[350]: ([317]) WebProcess(317) deny mach-lookup ATS Query Port 184
            12/18/12 7:07:28.290 AM com.apple.kextd[12]: Warning: /Volumes/Macintosh HD/System/Library/Extensions: No such file or directory
            12/18/12 7:07:47.899 AM Remote Desktop Connection[357]: objc[357]: Class NLAssertionHandler is implemented in both /Applications/Remote Desktop Connection.app/Contents/Frameworks/mbuinstrument.framework/Versions/14/mbuinstrument and /Applications/Remote Desktop Connection.app/Contents/Frameworks/TSClient.framework/Versions/14/TSClient. One of the two will be used. Which one is undefined.
            12/18/12 7:50:05.263 AM sandboxd[489]: ([317]) WebProcess(317) deny mach-lookup ATS Query Port 184
            12/18/12 7:50:05.000 AM kernel[0]: Sandbox: sandboxd(489) deny mach-lookup com.apple.coresymbolicationd
            12/18/12 7:50:05.273 AM sandboxd[489]: ([317]) WebProcess(317) deny mach-lookup ATS Query Port 184
            12/18/12 7:50:05.304 AM sandboxd[489]: ([317]) WebProcess(317) deny mach-lookup ATS Query Port 184
            12/18/12 7:50:05.325 AM sandboxd[489]: ([317]) WebProcess(317) deny mach-lookup ATS Query Port 184
            12/18/12 7:50:05.346 AM sandboxd[489]: ([317]) WebProcess(317) deny mach-lookup ATS Query Port 184
            12/18/12 7:51:48.000 AM kernel[0]: Sandbox: sandboxd(495) deny mach-lookup com.apple.coresymbolicationd
            12/18/12 7:51:48.853 AM sandboxd[495]: ([317]) WebProcess(317) deny mach-lookup ATS Query Port 184
            12/18/12 8:01:16.000 AM kernel[0]: CODE SIGNING: cs_invalid_page(0x1000): p=526[GoogleSoftwareUp] clearing CS_VALID
            12/18/12 8:01:16.769 AM GoogleSoftwareUpdateDaemon[527]: -[KeystoneDaemon logServiceState] GoogleSoftwareUpdate daemon (1.1.0.3659) vending:
            12/18/12 8:01:16.783 AM GoogleSoftwareUpdateDaemon[527]: -[KSUpdateEngine updateProductID:] KSUpdateEngine updating product ID: "com.google.Keystone"
            12/18/12 8:01:16.787 AM GoogleSoftwareUpdateDaemon[527]: -[KSCheckAction performAction] KSCheckAction checking 1 ticket(s).
            12/18/12 8:01:16.794 AM GoogleSoftwareUpdateDaemon[527]: -[KSUpdateCheckAction performAction] KSUpdateCheckAction starting update check for ticket(s): {(
                      <KSTicket:0x2661b0
                                version=1.1.0.3659
                                xc=<KSPathExistenceChecker:0x2660f0 path=/Library/Google/GoogleSoftwareUpdate/GoogleSoftwareUpdate.bundle/>
                                serverType=Omaha
            Using server: <KSOmahaServer:0x26d460
                      engine=<KSDaemonUpdateEngine:0x1c59b30>
                      params={
                                ActivesInfo = {
                                                    LastActiveDate = 2012-12-18 13:01:16 +0000;
                                UserInitiated = 0;
                                IsSystem = 1;
                                          ".www.google.com",
                                          ".corp.google.com"
            12/18/12 8:01:16.795 AM GoogleSoftwareUpdateDaemon[527]: -[KSUpdateCheckAction performAction] KSUpdateCheckAction running KSServerUpdateRequest: <KSOmahaServerUpdateRequest:0x2728d0
                      server=<KSOmahaServer:0x26d460>
                      runningFetchers=0
                      tickets=1
                      activeTickets=1
                      rollCallTickets=1
                      body=
                                    </o:app>
                                </o:gupdate>
            12/18/12 8:01:17.091 AM GoogleSoftwareUpdateDaemon[527]: -[KSUpdateCheckAction(KSServerUpdateRequestDelegate) serverRequest:fetchedWithResponse:] KSUpdateCheckAction received KSServerUpdateResponse: <KSOmahaServerUpdateResponse:0x8059d60
                      status=200
                      tickets=1
                      activeTickets=1
                      rollCallTickets=1
                      data=
                                <gupdate xmlns="http://www.google.com/update2/response" protocol="2.0" server="prod">
                                    <daystart elapsed_seconds="18077"></daystart>
                                    <app appid="com.google.Keystone" status="ok">
                                        <ping status="ok"></ping>
                                        <updatecheck status="noupdate"></updatecheck>
                                    </app>
                                </gupdate>
            12/18/12 8:01:17.105 AM GoogleSoftwareUpdateDaemon[527]: -[KSUpdateCheckAction(PrivateMethods) finishAction] KSUpdateCheckAction found updates: {( )}
            12/18/12 8:01:17.108 AM GoogleSoftwareUpdateDaemon[527]: -[KSPrefetchAction performAction] KSPrefetchAction no updates to prefetch.
            12/18/12 8:01:17.109 AM GoogleSoftwareUpdateDaemon[527]: -[KSMultiUpdateAction performAction] KSSilentUpdateAction had no updates to apply.
            12/18/12 8:01:17.110 AM GoogleSoftwareUpdateDaemon[527]: -[KSMultiUpdateAction performAction] KSPromptAction had no updates to apply.
            12/18/12 8:01:17.112 AM GoogleSoftwareUpdateDaemon[527]: -[KSUpdateEngine(PrivateMethods) updateFinish] KSUpdateEngine update processing complete.
            12/18/12 8:01:17.817 AM GoogleSoftwareUpdateDaemon[527]: -[KSUpdateEngine updateAllProducts] KSUpdateEngine updating all installed products.
            12/18/12 8:01:17.819 AM GoogleSoftwareUpdateDaemon[527]: -[KSCheckAction performAction] KSCheckAction checking 2 ticket(s).
            12/18/12 8:01:17.825 AM GoogleSoftwareUpdateDaemon[527]: -[KSUpdateCheckAction performAction] KSUpdateCheckAction starting update check for ticket(s): {(
                      <KSTicket:0x2661b0
                                version=1.1.0.3659
                                xc=<KSPathExistenceChecker:0x26b1c0 path=/Library/Google/GoogleSoftwareUpdate/GoogleSoftwareUpdate.bundle/>
                                serverType=Omaha
                      <KSTicket:0x26c570
                                xc=<KSPathExistenceChecker:0x2600f0 path=/Library/Application Support/Google/GoogleTalkPlugin.app>
                                serverType=Omaha
            Using server: <KSOmahaServer:0x3b65910
                      params={
                                ActivesInfo = {
                                                    LastRollCallPingDate = 2012-12-18 08:00:00 +0000;
                                                    LastActivePingDate = 2012-12-18 08:00:00 +0000;
                                UserInitiated = 0;
                                IsSystem = 1;
                                          ".www.google.com",
                                          ".corp.google.com"
            12/18/12 8:01:17.826 AM GoogleSoftwareUpdateDaemon[527]: -[KSUpdateCheckAction performAction] KSUpdateCheckAction running KSServerUpdateRequest: <KSOmahaServerUpdateRequest:0x3b66a20
                      server=<KSOmahaServer:0x3b65910>
                      runningFetchers=0
                      tickets=2
                      activeTickets=0
                      rollCallTickets=1
                      body=
                                    </o:app>
                                    </o:app>
                                </o:gupdate>
            12/18/12 8:01:18.087 AM GoogleSoftwareUpdateDaemon[527]: -[KSUpdateCheckAction(KSServerUpdateRequestDelegate) serverRequest:fetchedWithResponse:] KSUpdateCheckAction received KSServerUpdateResponse: <KSOmahaServerUpdateResponse:0x1858130
                      status=200
                      tickets=2
                      activeTickets=0
                      rollCallTickets=1
                      data=
                                    <daystart elapsed_seconds="18078"></daystart>
                                    </app>
                                    <app appid="com.google.talkplugin" status="ok">
                                    </app>
                                </gupdate>
            12/18/12 8:01:18.090 AM GoogleSoftwareUpdateDaemon[527]: -[KSUpdateCheckAction(PrivateMethods) finishAction] KSUpdateCheckAction found updates: {( )}
            12/18/12 8:01:18.093 AM GoogleSoftwareUpdateDaemon[527]: -[KSPrefetchAction performAction] KSPrefetchAction no updates to prefetch.
            12/18/12 8:01:18.094 AM GoogleSoftwareUpdateDaemon[527]: -[KSMultiUpdateAction performAction] KSSilentUpdateAction had no updates to apply.
            12/18/12 8:01:18.095 AM GoogleSoftwareUpdateDaemon[527]: -[KSMultiUpdateAction performAction] KSPromptAction had no updates to apply.
            12/18/12 8:01:18.097 AM GoogleSoftwareUpdateDaemon[527]: -[KSUpdateEngine(PrivateMethods) updateFinish] KSUpdateEngine update processing complete.
            12/18/12 8:01:20.747 AM GoogleSoftwareUpdateDaemon[527]: -[KeystoneDaemon logServiceState] GoogleSoftwareUpdate daemon (1.1.0.3659) vending:
            12/18/12 8:01:46.772 AM GoogleSoftwareUpdateDaemon[527]: -[KeystoneDaemon main] GoogleSoftwareUpdateDaemon inactive, shutdown.
            12/18/12 8:02:34.498 AM gconsync[535]: [0x7fdce040a540] |ISyncManager|Warning| Could not retrieve ISyncClient with id com.apple.Keychain!
            12/18/12 8:02:36.061 AM WindowServer[122]: Created shield window 0x64 for display 0x04241064
            12/18/12 8:02:36.064 AM WindowServer[122]: device_generate_desktop_screenshot: authw 0x0(0), shield 0x0(0)
            12/18/12 8:02:36.077 AM WindowServer[122]: device_generate_lock_screen_screenshot: authw 0x0(0), shield 0x0(0)
            12/18/12 8:07:36.138 AM helpd[173]: Could not find access page in directory /Applications/Final Cut Pro.app/Contents/Resources/English.lproj/Final Cut Pro Help
            12/18/12 8:07:36.139 AM helpd[173]: Could not find access page in directory /Applications/Final Cut Pro.app/Contents/Resources/English.lproj/Final Cut Pro Help
            12/18/12 8:07:46.163 AM helpd[173]: CFPropertyListCreateFromXMLData(): Old-style plist parser: missing semicolon in dictionary on line 1. Parsing will be abandoned. Break on _CFPropertyListMissingSemicolon to debug.
            12/18/12 8:07:46.165 AM helpd[173]: CFPropertyListCreateFromXMLData(): Old-style plist parser: missing semicolon in dictionary on line 1. Parsing will be abandoned. Break on _CFPropertyListMissingSemicolon to debug.
            12/18/12 8:14:05.014 AM WindowServer[122]: handle_will_sleep_auth_and_shield_windows: no lock state data
            12/18/12 8:16:51.947 AM mdworker[570]: CFPropertyListCreateFromXMLData(): Old-style plist parser: missing semicolon in dictionary on line 1. Parsing will be abandoned. Break on _CFPropertyListMissingSemicolon to debug.
            12/18/12 8:19:59.191 AM WebProcess[317]: *** WARNING: -[NSImage dissolveToPoint:fraction:] is deprecated in MacOSX 10.8 and later. Please use -[NSImage drawAtPoint:fromRect:operation:fraction:] instead.
            12/18/12 8:19:59.191 AM WebProcess[317]: *** WARNING: -[NSImage dissolveToPoint:fromRect:fraction:] is deprecated in MacOSX 10.8 and later. Please use -[NSImage drawAtPoint:fromRect:operation:fraction:] instead.
            12/18/12 8:19:59.207 AM WebProcess[317]: *** WARNING: -[NSImage compositeToPoint:operation:] is deprecated in MacOSX 10.8 and later. Please use -[NSImage drawAtPoint:fromRect:operation:fraction:] instead.
            12/18/12 8:19:59.207 AM WebProcess[317]: *** WARNING: -[NSImage compositeToPoint:fromRect:operation:] is deprecated in MacOSX 10.8 and later. Please use -[NSImage drawAtPoint:fromRect:operation:fraction:] instead.
            12/18/12 8:24:41.000 AM kernel[0]: Sandbox: sandboxd(621) deny mach-lookup com.apple.coresymbolicationd
            12/18/12 8:24:41.535 AM sandboxd[621]: ([317]) WebProcess(317) deny mach-lookup ATS Query Port 184
            12/18/12 8:24:41.545 AM sandboxd[621]: ([317]) WebProcess(317) deny mach-lookup ATS Query Port 184
            12/18/12 8:24:41.554 AM sandboxd[621]: ([317]) WebProcess(317) deny mach-lookup ATS Query Port 184
            12/18/12 8:24:50.243 AM sandboxd[621]: ([317]) WebProcess(317) deny mach-lookup ATS Query Port 184
            12/18/12 8:24:50.253 AM sandboxd[621]: ([317]) WebProcess(317) deny mach-lookup ATS Query Port 184
            12/18/12 8:25:00.605 AM sandboxd[621]: ([317]) WebProcess(317) deny mach-lookup ATS Query Port 184
            12/18/12 8:25:00.615 AM sandboxd[621]: ([317]) WebProcess(317) deny mach-lookup ATS Query Port 184
            12/18/12 8:28:46.122 AM Dreamweaver[592]: objc[592]: Class WebCoreMovieObserver is implemented in both /Applications/Adobe Dreamweaver CS6/Configuration/browsers/webkit/WebKitDw.dylib and /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebCore.framework/Versi ons/A/WebCore. One of the two will be used. Which one is undefined.
            12/18/12 8:34:16.000 AM kernel[0]: Adobe Photoshop  (map: 0xffffff80438572b8) triggered DYLD shared region unnest for map: 0xffffff80438572b8, region 0x7fff89800000->0x7fff89a00000. While not abnormal for debuggers, this increases system memory footprint until the target exits.
            12/18/12 8:34:24.733 AM Adobe Photoshop CS6[653]: *** WARNING: -[NSObject(NSKeyValueCoding) takeValuesFromDictionary:] is deprecated. It will be removed in a future release and should no longer be used.
            12/18/12 8:34:59.697 AM launchctl[672]: launchctl: Dubious permissions on file (skipping): /Library/LaunchAgents/com.adobe.AAM.Updater-1.0.plist
            12/18/12 8:59:59.888 AM UserEventAgent[148]: Could not get event name for stream/token: com.apple.time/18: 0x3: No such process
            12/18/12 8:59:59.888 AM UserEventAgent[148]: Could not look up channel/token: com.apple.time/0x18: 0x3: No such process
            12/18/12 8:59:59.000 AM kernel[0]: CODE SIGNING: cs_invalid_page(0x1000): p=748[GoogleSoftwareUp] clearing CS_VALID
            12/18/12 8:59:59.888 AM UserEventAgent[148]: Bug: 12C60: libxpc.dylib + 36100 [FAC04D8B-680E-325F-8F0C-DD69859D0E01]: 0x3
            12/18/12 8:59:59.894 AM UserEventAgent[148]: Could not get event name for stream/token: com.apple.time/21: 0x3: No such process
            12/18/12 8:59:59.903 AM UserEventAgent[148]: Could not get event name for stream/token: com.apple.time/25: 0x3: No such process
            12/18/12 8:59:59.911 AM UserEventAgent[148]: Could not get event name for stream/token: com.apple.time/29: 0x3: No such process
            12/18/12 8:59:59.914 AM UserEventAgent[148]: Could not get event name for stream/token: com.apple.time/30: 0x3: No such process
            12/18/12 8:59:59.914 AM UserEventAgent[148]: Could not look up channel/token: com.apple.time/0x30: 0x3: No such process
            12/18/12 8:59:59.914 AM UserEventAgent[148]: Bug: 12C60: libxpc.dylib + 36100 [FAC04D8B-680E-325F-8F0C-DD69859D0E01]: 0x3
            12/18/12 8:59:59.922 AM UserEventAgent[148]: Could not get event name for stream/token: com.apple.time/34: 0x3: No such process
            12/18/12 8:59:59.940 AM UserEventAgent[148]: Could not get event name for stream/token: com.apple.time/42: 0x3: No such process
            12/18/12 8:59:59.974 AM UserEventAgent[148]: Could not get event name for stream/token: com.apple.time/58: 0x3: No such process
            12/18/12 8:59:59.983 AM UserEventAgent[148]: Could not get event name for stream/token: com.apple.time/62: 0x3: No such process
            12/18/12 8:59:59.991 AM UserEventAgent[148]: Could not get event name for stream/token: com.apple.time/66: 0x3: No such process
            12/18/12 8:59:59.998 AM UserEventAgent[148]: Could not get event name for stream/token: com.apple.time/69: 0x3: No such process
            12/18/12 9:02:34.558 AM gconsync[760]: [0x7ff7b840a540] |ISyncManager|Warning| Could not retrieve ISyncClient with id com.apple.Keychain!
            12/18/12 9:02:47.673 AM Splashtop Streamer[195]: SRFEAT_NOTIFY_SERVER_CLOUD_NOTIFY_MSG
            12/18/12 9:02:47.673 AM Splashtop Streamer[195]: [ProcServerNotification] SRS_SERVER_RTN_INFO : [200][.srhbnotify.xml]
            12/18/12 9:02:47.675 AM Splashtop Streamer[195]:   receive backend string notify
            12/18/12 9:02:47.675 AM Splashtop Streamer[195]: -[CMXMLParser length]: unrecognized selector sent to instance 0x10a110ca0
            12/18/12 9:02:47.676 AM Splashtop Streamer[195]: (
            12/18/12 9:02:47.677 AM Splashtop Streamer[195]:   receive backend string notify
            12/18/12 9:02:47.677 AM Splashtop Streamer[195]: -[CMXMLParser length]: unrecognized selector sent to instance 0x103e0e200
            12/18/12 9:02:47.678 AM Splashtop Streamer[195]: (
            12/18/12 9:10:29.101 AM WindowServer[122]: Created shield window 0x1e3 for display 0x04241064
            12/18/12 9:10:29.101 AM WindowServer[122]: device_generate_desktop_screenshot: authw 0x0(0), shield 0x0(0)
            12/18/12 9:10:29.119 AM WindowServer[122]: device_generate_lock_screen_screenshot: authw 0x0(0), shield 0x0(0)
            12/18/12 9:13:42.415 AM WindowServer[122]: handle_will_sleep_auth_and_shield_windows: no lock state data
            12/18/12 9:32:21.000 AM kernel[0]: Adobe Photoshop  (map: 0xffffff8043858c18) triggered DYLD shared region unnest for map: 0xffffff8043858c18, region 0x7fff89800000->0x7fff89a00000. While not abnormal for debuggers, this increases system memory footprint until the target exits.
            12/18/12 9:32:59.974 AM WindowServer[122]: CGXDisableUpdate: UI updates were forcibly disabled by application "Photoshop" for over 1.00 seconds. Server has re-enabled them.
            12/18/12 9:33:00.984 AM WindowServer[122]: reenable_update_for_connection: UI updates were finally reenabled by application "Photoshop" after 2.01 seconds (server forcibly re-enabled them after 1.00 seconds)
            12/18/12 9:51:04.807 AM Adobe Photoshop CS6[653]: clip: empty path.
            12/18/12 9:51:04.808 AM Adobe Photoshop CS6[653]: clip: empty path.
            12/18/12 9:53:38.568 AM Adobe Photoshop CS6[653]: clip: empty path.
            12/18/12 9:53:38.569 AM Adobe Photoshop CS6[653]: clip: empty path.
            12/18/12 9:54:12.409 AM Adobe Photoshop CS6[653]: clip: empty path.
            12/18/12 9:54:12.410 AM Adobe Photoshop CS6[653]: clip: empty path.
            12/18/12 9:54:48.706 AM mdworker[922]: CFPropertyListCreateFromXMLData(): Old-style plist parser: missing semicolon in dictionary on line 1. Parsing will be abandoned. Break on _CFPropertyListMissingSemicolon to debug.
            12/18/12 9:55:45.174 AM WindowServer[122]: _CGXGetWindowOrderingGroup: Operation on a window 0x4e requiring rights 0x5 by caller Photoshop
            12/18/12 9:55:45.176 AM WindowServer[122]: _CGXGetWindowOrderingGroup: Operation on a window 0x4e requiring rights 0x5 by caller Photoshop
            12/18/12 9:55:45.177 AM WindowServer[122]: _CGXGetWindowOrderingGroup: Operation on a window 0x4e requiring rights 0x5 by caller Photoshop
            12/18/12 9:58:43.000 AM kernel[0]: CODE SIGNING: cs_invalid_page(0x1000): p=952[GoogleSoftwareUp] clearing CS_VALID
            12/18/12 10:00:34.786 AM WindowServer[122]: _CGXGetWindowOrderingGroup: Operation on a window 0x72 requiring rights 0x5 by caller Photoshop
            12/18/12 10:00:34.787 AM WindowServer[122]: _CGXGetWindowOrderingGroup: Operation on a window 0x72 requiring rights 0x5 by caller Photoshop
            12/18/12 10:00:34.788 AM WindowServer[122]: _CGXGetWindowOrderingGroup: Operation on a window 0x72 requiring rights 0x5 by caller Photoshop
            12/18/12 10:00:34.789 AM WindowServer[122]: _CGXGetWindowOrderingGroup: Operation on a window 0x72 requiring rights 0x5 by caller Photoshop
            12/18/12 10:02:34.597 AM gconsync[970]: [0x7fb80040a540] |ISyncManager|Warning| Could not retrieve ISyncClient with id com.apple.Keychain!
            12/18/12 10:06:23.548 AM mdworker[979]: CFPropertyListCreateFromXMLData(): Old-style plist parser: missing semicolon in dictionary on line 1. Parsing will be abandoned. Break on _CFPropertyListMissingSemicolon to debug.
            12/18/12 10:06:24.917 AM WindowServer[122]: _CGXGetWindowOrderingGroup: Operation on a window 0x72 requiring rights 0x5 by caller Photoshop
            12/18/12 10:06:24.920 AM WindowServer[122]: _CGXGetWindowOrderingGroup: Operation on a window 0x72 requiring rights 0x5 by caller Photoshop
            12/18/12 10:06:24.921 AM WindowServer[122]: _CGXGetWindowOrderingGroup: Operation on a window 0x72 requiring rights 0x5 by caller Photoshop
            12/18/12 10:09:32.000 AM kernel[0]: Sandbox: sandboxd(996) deny mach-lookup com.apple.coresymbolicationd
            12/18/12 10:09:32.910 AM sandboxd[996]: ([317]) WebProcess(317) deny file-read-data /Users/Imacom/Library/Preferences/pbs.plist
            12/18/12 10:09:32.930 AM sandboxd[996]: ([317]) WebProcess(317) deny file-read-data /Users/Imacom/Library/Preferences/com.apple.ServicesMenu.Services.plist
            12/18/12 10:09:32.950 AM sandboxd[996]: ([317]) WebProcess(317) deny mach-lookup com.apple.pbs.fetch_services
            12/18/12 10:11:09.682 AM sandboxd[999]: ([317]) WebProcess(317) deny mach-lookup ATS Query Port 184
            12/18/12 10:11:09.000 AM kernel[0]: Sandbox: sandboxd(999) deny mach-lookup com.apple.coresymbolicationd
            12/18/12 10:11:09.692 AM sandboxd[999]: ([317]) WebProcess(317) deny mach-lookup ATS Query Port 184
            12/18/12 10:11:09.701 AM sandboxd[999]: ([317]) WebProcess(317) deny mach-lookup ATS Query Port 184
            12/18/12 10:11:09.711 AM sandboxd[999]: ([317]) WebProcess(317) deny mach-lookup ATS Query Port 184
            12/18/12 10:11:09.720 AM sandboxd[999]: ([317]) WebProcess(317) deny mach-lookup ATS Query Port 184
            12/18/12 10:11:09.730 AM sandboxd[999]: ([317]) WebProcess(317) deny mach-lookup ATS Query Port 184
            12/18/12 10:11:09.740 AM sandboxd[999]: ([317]) WebProcess(317) deny mach-lookup ATS Query Port 184
            12/18/12 10:11:09.749 AM sandboxd[999]: ([317]) WebProcess(317) deny mach-lookup ATS Query Port 184
            12/18/12 10:11:09.759 AM sandboxd[999]: ([317]) WebProcess(317) deny mach-lookup ATS Query Port 184
            12/18/12 10:11:09.768 AM sandboxd[999]: ([317]) WebProcess(317) deny mach-lookup ATS Query Port 184
            12/18/12 10:11:09.778 AM sandboxd[999]: ([317]) WebProcess(317) deny mach-lookup ATS Query Port 184
            12/18/12 10:11:09.788 AM sandboxd[999]: ([317]) WebProcess(317) deny mach-lookup ATS Query Port 184
            12/18/12 10:11:09.798 AM sandboxd[999]: ([317]) WebProcess(317) deny mach-lookup ATS Query Port 184
            12/18/12 10:11:09.807 AM sandboxd[999]: ([317]) WebProcess(317) deny mach-lookup ATS Query Port 184
            12/18/12 10:11:09.817 AM sandboxd[999]: ([317]) WebProcess(317) deny mach-lookup ATS Query Port 184
            12/18/12 10:11:09.826 AM sandboxd[999]: ([317]) WebProcess(317) deny mach-lookup ATS Query Port 184
            12/18/12 10:11:09.836 AM sandboxd[999]: ([317]) WebProcess(317) deny mach-lookup ATS Query Port 184
            12/18/12 10:11:09.846 AM sandboxd[999]: ([317]) WebProcess(317) deny mach-lookup ATS Query Port 184
            12/18/12 10:11:09.856 AM sandboxd[999]: ([317]) WebProcess(317) deny mach-lookup ATS Query Port 184
            12/18/12 10:11:09.865 AM sandboxd[999]: ([317]) WebProcess(317) deny mach-lookup ATS Query Port 184
            12/18/12 10:11:09.875 AM sandboxd[999]: ([317]) WebProcess(317) deny mach-lookup ATS Query Port 184
            12/18/12 10:11:36.187 AM sandboxd[999]: ([317]) WebProcess(317) deny mach-lookup ATS Query Port 184
            12/18/12 10:11:36.221 AM sandboxd[999]: ([317]) WebProcess(317) deny mach-lookup ATS Query Port 184
            12/18/12 10:11:36.242 AM sandboxd[999]: ([317]) WebProcess(317) deny mach-lookup ATS Query Port 184
            12/18/12 10:11:36.262 AM sandboxd[999]: ([317]) WebProcess(317) deny mach-lookup ATS Query Port 184
            12/18/12 10:15:51.000 AM kernel[0]: Sandbox: sandboxd(1027) deny mach-lookup com.apple.coresymbolicationd
            12/18/12 10:15:52.048 AM sandboxd[1027]: ([317]) WebProcess(317) deny mach-lookup ATS Query Port 184
            12/18/12 10:15:52.060 AM sandboxd[1027]: ([317]) WebProcess(317) deny mach-lookup ATS Query Port 184
            12/18/12 10:15:52.072 AM sandboxd[1027]: ([317]) WebProcess(317) deny mach-lookup ATS Query Port 184
            12/18/12 10:15:52.084 AM sandboxd[1027]: ([317]) WebProcess(317) deny mach-lookup ATS Query Port 184
            12/18/12 10:15:52.096 AM sandboxd[1027]: ([317]) WebProcess(317) deny mach-lookup ATS Query Port 184
            12/18/12 10:15:52.108 AM sandboxd[1027]: ([317]) WebProcess(317) deny mach-lookup ATS Query Port 184
            12/18/12 10:15:52.120 AM sandboxd[1027]: ([317]) WebProcess(317) deny mach-lookup ATS Query Port 184
            12/18/12 10:15:52.132 AM sandboxd[1027]: ([317]) WebProcess(317) deny mach-lookup ATS Query Port 184
            12/18/12 10:16:23.911 AM sandboxd[1031]: ([317]) WebProcess(317) deny mach-lookup ATS Query Port 184
            12/18/12 10:16:23.000 AM kernel[0]: Sandbox: sandboxd(1031) deny mach-lookup com.apple.coresymbolicationd
            12/18/12 10:17:12.000 AM kernel[0]: Sandbox: sandboxd(1032) deny mach-lookup com.apple.coresymbolicationd
            12/18/12 10:17:12.211 AM sandboxd[1032]: ([317]) WebProcess(317) deny mach-lookup ATS Query Port 184
            12/18/12 10:17:12.223 AM sandboxd[1032]: ([317]) WebProcess(317) deny mach-lookup ATS Query Port 184
            12/18/12 10:18:31.212 AM WindowServer[122]: _CGXGetWindowOrderingGroup: Operation on a window 0x304 requiring rights 0x5 by caller Photoshop
            12/18/12 10:32:33.934 AM com.apple.launchd.peruser.501[145]: (com.adobe.ARM.0d92f8f114b2d0af95462120762f939f6c66651ac8ac214cb7bdbd84[1078]) Job failed to exec(3). Setting up event to tell us when to try again: 2: No such file or directory
            12/18/12 10:32:33.934 AM com.apple.launchd.peruser.501[145]: (com.adobe.ARM.0d92f8f114b2d0af95462120762f939f6c66651ac8ac214cb7bdbd84[1078]) Job failed to exec(3) for weird reason: 2
            12/18/12 10:37:51.205 AM WindowServer[122]: _CGXGetWindowOrderingGroup: Operation on a window 0x4e requiring rights 0x5 by caller Photoshop
            12/18/12 10:37:51.206 AM WindowServer[122]: _CGXGetWindowOrderingGroup: Operation on a window 0x4e requiring rights 0x5 by caller Photoshop
            12/18/12 10:37:51.207 AM WindowServer[122]: _CGXGetWindowOrderingGroup: Operation on a window 0x4e requiring rights 0x5 by caller Photoshop
            12/18/12 10:37:51.210 AM WindowServer[122]: _CGXGetWindowOrderingGroup: Operation on a window 0x4e requiring rights 0x5 by caller Photoshop
            12/18/12 10:39:51.757 AM WindowServer[122]: _CGXGetWindowOrderingGroup: Operation on a window 0x72 requiring rights 0x5 by caller Photoshop
            12/18/12 10:39:51.761 AM WindowServer[122]: _CGXGetWindowOrderingGroup: Operation on a window 0x72 requiring rights 0x5 by caller Photoshop
            12/18/12 10:39:51.762 AM WindowServer[122]: _CGXGetWindowOrderingGroup: Operation on a window 0x72 requiring rights 0x5 by caller Photoshop
            12/18/12 10:39:51.763 AM WindowServer[122]: _CGXGetWindowOrderingGroup: Operation on a window 0x72 requiring rights 0x5 by caller Photoshop
            12/18/12 10:41:12.632 AM WindowServer[122]: _CGXGetWindowOrderingGroup: Operation on a window 0x72 requiring rights 0x5 by caller Photoshop
            12/18/12 10:41:12.633 AM WindowServer[122]: _CGXGetWindowOrderingGroup: Operation on a window 0x72 requiring rights 0x5 by caller Photoshop
            12/18/12 10:41:12.637 AM WindowServer[122]: _CGXGetWindowOrderingGroup: Operation on a window 0x72 requiring rights 0x5 by caller Photoshop
            12/18/12 10:41:12.638 AM WindowServer[122]: _CGXGetWindowOrderingGroup: Operation on a window 0x72 requiring rights 0x5 by caller Photoshop
            12/18/12 10:47:44.625 AM mdworker[1108]: CFPropertyListCreateFromXMLData(): Old-style plist parser: missing semicolon in dictionary on line 1. Parsing will be abandoned. Break on _CFPropertyListMissingSemicolon to debug.
            12/18/12 10:53:18.923 AM WindowServer[122]: CGXDisableUpdate: UI updates were forcibly disabled by application "Photoshop" for over 1.00 seconds. Server has re-enabled them.
            12/18/12 10:53:22.701 AM WindowServer[122]: reenable_update_for_connection: UI updates were finally reenabled by application "Photoshop" after 4.78 seconds (server forcibly re-enabled them after 1.00 seconds)
            12/18/12 10:55:24.388 AM Adobe Photoshop CS6[653]: clip: empty path.
            12/18/12 10:55:24.389 AM Adobe Photoshop CS6[653]: clip: empty path.
            12/18/12 10:55:50.360 AM Adobe Photoshop CS6[653]: clip: empty path.
            12/18/12 10:55:50.361 AM Adobe Photoshop CS6[653]: clip: empty path.
            12/18/12 10:56:07.132 AM Adobe Photoshop CS6[653]: clip: empty path.
            12/18/12 10:56:07.133 AM Adobe Photoshop CS6[653]: clip: empty path.
            12/18/12 10:57:26.000 AM kernel[0]: CODE SIGNING: cs_invalid_page(0x1000): p=1166[GoogleSoftwareUp] clearing CS_VALID
            12/18/12 10:58:33.721 AM Adobe Bridge CS6[580]: CFPropertyListCreateFromXMLData(): Old-style plist parser: missing semicolon in dictionary on line 1. Parsing will be abandoned. Break on _CFPropertyListMissingSemicolon to debug.
            12/18/12 10:58:33.730 AM Adobe Bridge CS6[580]: CFPropertyListCreateFromXMLData(): Old-style plist parser: missing semicolon in dictionary on line 1. Parsing will be abandoned. Break on _CFPropertyListMissingSemicolon to debug.
            12/18/12 11:02:34.721 AM gconsync[1189]: [0x7fc590c0a540] |ISyncManager|Warning| Could not retrieve ISyncClient with id com.apple.Keychain!
            12/18/12 11:02:39.347 AM com.apple.launchd[1]: (com.apple.softwareupdatecheck.periodic) Throttling respawn: Will start in 1 seconds
            12/18/12 11:02:47.477 AM Splashtop Streamer[195]: SRFEAT_NOTIFY_SERVER_CLOUD_NOTIFY_MSG
            12/18/12 11:02:47.478 AM Splashtop Streamer[195]: [ProcServerNotification] SRS_SERVER_RTN_INFO : [200][.srhbnotify.xml]
            12/18/12 11:02:47.479 AM Splashtop Streamer[195]:   receive backend string notify
            12/18/12 11:02:47.479 AM Splashtop Streamer[195]: -[CMXMLParser length]: unrecognized selector sent to instance 0x103e07910
            12/18/12 11:02:47.480 AM Splashtop Streamer[195]: -[CMXMLParser length]: unrecognized selector sent to instance 0x103e07910
            12/18/12 11:02:47.481 AM Splashtop Streamer[195]: (
            12/18/12 11:02:47.481 AM Splashtop Streamer[195]:   receive backend string notify
            12/18/12 11:02:47.481 AM Splashtop Streamer[195]: -[CMXMLParser length]: unrecognized selector sent to instance 0x103e07910
            12/18/12 11:02:47.482 AM Splashtop Streamer[195]: -[CMXMLParser length]: unrecognized selector sent to instance 0x103e07910
            12/18/12 11:02:47.483 AM Splashtop Streamer[195]: (
            12/18/12 11:03:55.157 AM Adobe Photoshop CS6[653]: clip: empty path.
            12/18/12 11:03:55.159 AM Adobe Photoshop CS6[653]: clip: empty path.
            12/18/12 11:05:15.128 AM mdworker[1142]: CFPropertyListCreateFromXMLData(): Old-style plist parser: missing semicolon in dictionary on line 1. Parsing will be abandoned. Break on _CFPropertyListMissingSemicolon to debug.
            12/18/12 11:05:16.208 AM WindowServer[122]: _CGXGetWindowOrderingGroup: Operation on a window 0x65 requiring rights 0x5 by caller Photoshop
            12/18/12 11:05:16.209 AM WindowServer[122]: _CGXGetWindowOrderingGroup: Operation on a window 0x65 requiring rights 0x5 by caller Photoshop
            12/18/12 11:05:16.210 AM WindowServer[122]: _CGXGetWindowOrderingGroup: Operation on a window 0x65 requiring rights 0x5 by caller Photoshop
            12/18/12 11:05:16.229 AM WindowServer[122]: _CGXGetWindowOrderingGroup: Operation on a window 0x65 requiring rights 0x5 by caller Photoshop
            12/18/12 11:05:16.230 AM WindowServer[122]: _CGXGetWindowOrderingGroup: Operation on a window 0x65 requiring rights 0x5 by caller Photoshop
            12/18/12 11:05:16.232 AM WindowServer[122]: _CGXGetWindowOrderingGroup: Operation on a window 0x65 requiring rights 0x5 by caller Photoshop
            12/18/12 11:05:29.334 AM WindowServer[122]: _CGXGetWindowOrderingGroup: Operation on a window 0x72 requiring rights 0x5 by caller Photoshop
            12/18/12 11:05:29.335 AM WindowServer[122]: _CGXGetWindowOrderingGroup: Operation on a window 0x72 requiring rights 0x5 by caller Photoshop
            12/18/12 11:05:29.336 AM WindowServer[122]: _CGXGetWindowOrderingGroup: Operation on a window 0x72 requiring rights 0x5 by caller Photoshop
            12/18/12 11:05:29.337 AM WindowServer[122]: _CGXGetWindowOrderingGroup: Operation on a window 0x72 requiring rights 0x5 by caller Photoshop
            12/18/12 11:05:29.338 AM WindowServer[122]: _CGXGetWindowOrderingGroup: Operation on a window 0x72 requiring rights 0x5 by caller Photoshop
            12/18/12 11:05:29.339 AM WindowServer[122]: _CGXGetWindowOrderingGroup: Operation on a window 0x72 requiring rights 0x5 by caller Photoshop
            12/18/12 11:05:29.340 AM WindowServer[122]: _CGXGetWindowOrderingGroup: Operation on a window 0x72 requiring rights 0x5 by caller Photoshop
            12/18/12 11:07:38.128 AM iCalExternalSync[1212]: [0x7fafcbc0e460] |Miscellaneous|Error| SyncServices precondition failure in [ISyncConcreteSession pushChangesFromRecord:withIdentifier:]: you can't change the record's entity name from com.apple.calendars.MailAlarm to com.apple.calendars.DisplayAlarm in {
                description = "";
                owner =     (
                    "Event/p935"
            12/18/12 11:07:38.129 AM iCalExternalSync[1212]: [ICalExternalSync ]Encountered exception: [ISyncConcreteSession pushChangesFromRecord:withIdentifier:]: you can't change the record's entity name from com.apple.calendars.MailAlarm to com.apple.calendars.DisplayAlarm in {
                description = "";
                owner =     (
                    "Event/p935"
            } withStack: (
                      0   iCalExternalSync                    0x0000000105e52a60 iCalExternalSync + 125536
                      1   iCalExternalSync                    0x0000000105e41ac9 iCalExternalSync + 56009
                      2   iCalExternalSync                    0x0000000105e51694 iCalExternalSync + 120468
            12/18/12 11:07:38.130 AM iCalExternalSync[1212]: [ICalExternalSync ]NSException name:ISyncInvalidArgumentsException reason:[ISyncConcreteSession pushChangesFromRecord:withIdentifier:]: you can't change the record's entity name from com.apple.calendars.MailAlarm to com.apple.calendars.DisplayAlarm in {
                description = "";
                owner =     (
                    "Event/p935"
            12/18/12 11:07:38.131 AM SyncServer[1213]: [0x7fbfb940be00] |Server|Warning| lost connection 0x7fbfbc200f30 to com.apple.iCal
            12/18/12 11:08:08.613 AM iCalExternalSync[1214]: [0x7fe858c0e460] |Miscellaneous|Error| SyncServices precondition failure in [ISyncConcreteSession pushChangesFromRecord:withIdentifier:]: you can't change the record's entity name from com.apple.calendars.MailAlarm to com.apple.calendars.DisplayAlarm in {
                description = "";
                owner =     (
                    "Event/p935"
            12/18/12 11:08:08.614 AM iCalExternalSync[1214]: [ICalExternalSync ]Encountered exception: [ISyncConcreteSession pushChangesFromRecord:withIdentifier:]: you can't change the record's entity name from com.apple.calendars.MailAlarm to com.apple.calendars.DisplayAlarm in {
                description = "";
                owner =     (
                    "Event/p935"
            } withStack: (
                      0   iCalExternalSync                    0x0000000104027a60 iCalExternalSync + 125536
                      1   iCalExternalSync                    0x0000000104016ac9 iCalExternalSync + 56009
                      2   iCalExternalSync                    0x0000000104026694 iCalExternalSync + 120468
            12/18/12 11:08:08.614 AM iCalExternalSync[1214]: [ICalExternalSync ]NSException name:ISyncInvalidArgumentsException reason:[ISyncConcreteSession pushChangesFromRecord:withIdentifier:]: you can't change the record's entity name from com.apple.calendars.MailAlarm to com.apple.calendars.DisplayAlarm in {
                description = "";
                owner =     (
                    "Event/p935"
            12/18/12 11:08:08.615 AM SyncServer[1213]: [0x7fbfb940be00] |Server|Warning| lost connection 0x7fbfbc0015b0 to com.apple.iCal
            12/18/12 11:08:19.092 AM WindowServer[122]: _CGXGetWindowOrderingGroup: Operation on a window 0x72 requiring rights 0x5 by caller Photoshop
            12/18/12 11:18:01.116 AM iCalExternalSync[1245]: [0x7ff06040e460] |Miscellaneous|Error| SyncServices precondition failure in [ISyncConcreteSession pushChangesFromRecord:withIdentifier:]: you can't change the record's entity name from com.apple.calendars.MailAlarm to com.apple.calendars.DisplayAlarm in {
                description = "";
                owner =     (
                    "Event/p935"
            12/18/12 11:18:01.116 AM iCalExternalSync[1245]: [ICalExternalSync ]Encountered exception: [ISyncConcreteSession pushChangesFromRecord:withIdentifier:]: you can't change the record's entity name from com.apple.calendars.MailAlarm to com.apple.calendars.DisplayAlarm in {
                description = "";
                owner =     (
                    "Event/p935"
            } withStack: (
                      0   iCalExternalSync                    0x000000010e80da60 iCalExternalSync + 125536
                      1   iCalExternalSync                    0x000000010e7fcac9 iCalExternalSync + 56009
                      2   iCalExternalSync                    0x000000010e80c694 iCalExternalSync + 120468
            12/18/12 11:18:01.117 AM iCalExternalSync[1245]: [ICalExternalSync ]NSException name:ISyncInvalidArgumentsException reason:[ISyncConcreteSession pushChangesFromRecord:withIdentifier:]: you can't change the record's entity name from com.apple.calendars.MailAlarm to com.apple.calendars.DisplayAlarm in {
                description = "";
                owner =     (
                    "Event/p935"
            12/18/12 11:18:01.118 AM SyncServer[1247]: [0x7fd41840be00] |Server|Warning| lost connection 0x7fd41b5007a0 to com.apple.iCal
            12/18/12 11:18:06.485 AM Adobe Photoshop CS6[653]: clip: empty path.
            12/18/12 11:18:06.486 AM Adobe Photoshop CS6[653]: clip: empty path.
            12/18/12 11:19:15.837 AM Adobe Photoshop CS6[653]: clip: empty path.
            12/18/12 11:19:15.838 AM Adobe Photoshop CS6[653]: clip: empty path.
            12/18/12 11:19:51.065 AM mdworker[1225]: CFPropertyListCreateFromXMLData(): Old-style plist parser: missing semicolon in dictionary on line 1. Parsing will be abandoned. Break on _CFPropertyListMissingSemicolon to debug.
            12/18/12 11:23:44.339 AM WindowServer[122]: _CGXGetWindowOrderingGroup: Operation on a window 0x320 requiring rights 0x5 by caller Photoshop
            12/18/12 11:23:44.340 AM WindowServer[122]: _CGXGetWindowOrderingGroup: Operation on a window 0x320 requiring rights 0x5 by caller Photoshop
            12/18/12 11:23:44.341 AM WindowServer[122]: _CGXGetWindowOrderingGroup: Operation on a window 0x320 requiring rights 0x5 by caller Photoshop
            12/18/12 11:23:44.342 AM WindowServer[122]: _CGXGetWindowOrderingGroup: Operation on a window 0x320 requiring rights 0x5 by caller Photoshop
            12/18/12 11:34:09.600 AM WindowServer[122]: Created shield window 0x52d for display 0x04241064
            12/18/12 11:34:09.600 AM WindowServer[122]: device_generate_desktop_screenshot: authw 0x0(0), shield 0x0(0)
            12/18/12 11:34:09.618 AM WindowServer[122]: device_generate_lock_screen_screenshot: authw 0x0(0), shield 0x0(0)
            12/18/12 11:36:37.669 AM WindowServer[122]: handle_will_sleep_auth_and_shield_windows: no lock state data
            12/18/12 11:39:20.122 AM WindowServer[122]: _CGXGetWindowOrderingGroup: Operation on a window 0x65 requiring rights 0x5 by caller Photoshop
            12/18/12 11:39:20.124 AM WindowServer[122]: _CGXGetWindowOrderingGroup: Operation on a window 0x65 requiring rights 0x5 by caller Photoshop
            12/18/12 11:39:20.134 AM WindowServer[122]: _CGXGetWindowOrderingGroup: Operation on a window 0x65 requiring rights 0x5 by caller Photoshop
            12/18/12 11:39:20.135 AM WindowServer[122]: _CGXGetWindowOrderingGroup: Operation on a window 0x65 requiring rights 0x5 by caller Photoshop
            12/18/12 11:39:20.136 AM WindowServer[122]: _CGXGetWindowOrderingGroup: Operation on a window 0x65 requiring rights 0x5 by caller Photoshop
            12/18/12 11:39:20.137 AM WindowServer[122]: _CGXGetWindowOrderingGroup: Operation on a window 0x65 requiring rights 0x5 by caller Photoshop
            12/18/12 11:44:01.344 AM mdworker[1304]: CFPropertyListCreateFromXMLData(): Old-style plist parser: missing semicolon in dictionary on line 1. Parsing will be abandoned. Break on _CFPropertyListMissingSemicolon to debug.
            12/18/12 11:44:02.894 AM WindowServer[122]: _CGXGetWindowOrderingGroup: Operation on a window 0x65 requiring rights 0x5 by caller Photoshop
            12/18/12 11:44:02.895 AM WindowServer[122]: _CGXGetWindowOrderingGroup: Operation on a window 0x65 requiring rights 0x5 by caller Photoshop
            12/18/12 11:44:02.896 AM WindowServer[122]: _CGXGetWindowOrderingGroup: Operation on a window 0x65 requiring rights 0x5 by caller Photoshop
            12/18/12 11:44:02.897 AM WindowServer[122]: _CGXGetWindowOrderingGroup: Operation on a window 0x65 requiring rights 0x5 by caller Photoshop
            12/18/12 11:44:02.898 AM WindowServer[122]: _CGXGetWindowOrderingGroup: Operation on a window 0x65 requiring rights 0x5 by caller Photoshop
            12/18/12 11:44:02.899 AM WindowServer[122]: _CGXGetWindowOrderingGroup: Operation on a window 0x65 requiring rights 0x5 by caller Photoshop
            12/18/12 11:44:02.900 AM WindowServer[122]: _CGXGetWindowOrderingGroup: Operation on a window 0x65 requiring rights 0x5 by caller Photoshop
            12/18/12 11:44:02.901 AM WindowServer[122]: _CGXGetWindowOrderingGroup: Operation on a window 0x65 requiring rights 0x5 by caller Photoshop
            12/18/12 11:50:35.005 AM ReportCrash[1359]: Saved crash report for Adobe Photoshop CS6[653] version 13.0.2 (13.0.2.23) to /Users/Imacom/Library/Logs/DiagnosticReports/Adobe Photoshop CS6_2012-12-18-115035_Mac-Pro-Imacom-5.crash
            12/18/12 11:50:35.029 AM com.apple.launchd.peruser.501[145]: ([0x0-0x81081].com.adobe.Photoshop[653]) Job appears to have crashed: Segmentation fault: 11
            12/18/12 11:50:43.000 AM kernel[0]: Adobe Photoshop  (map: 0xffffff80418e8488) triggered DYLD shared region unnest for map: 0xffffff80418e8488, region 0x7fff89800000->0x7fff89a00000. While not abnormal for debuggers, this increases system memory footprint until the target exits.
            12/18/12 11:51:05.973 AM Adobe Photoshop CS6[1364]: *** WARNING: -[NSObject(NSKeyValueCoding) takeValuesFromDictionary:] is deprecated. It will be removed in a future release and should no longer be used.
            12/18/12 11:56:09.000 AM kernel[0]: CODE SIGNING: cs_invalid_page(0x1000): p=1401[GoogleSoftwareUp] clearing CS_VALID
            12/18/12 11:57:36.518 AM mdwrite[1409]: [ERROR] [0.000s] com.apple. UBItemStatusNotification.c:805 _do_UBItemStatusNotificationRegisterURLs() can't find realpath for "/Users/Imacom/Library/Mobile Documents/com~apple~system~spotlight/mdlabels", was blocked at "/Users/Imacom/Library/Mobile Documents": 2 (No such file or directory)
            12/18/12 11:57:52.444 AM Finder[160]: pearlBrowserSelectionChanged.
            12/18/12 11:58:02.983 AM librariand[1419]: MMe quota status changed: under quota
            12/18/12 11:58:03.155 AM com.apple.XType.FontHelper[1422]: FontHelper:  message received. (<dictionary: 0x7f8fc2c1cfd0> { count = 2, contents =
                      "query" => <string: 0x7f8fc2c1d130> { length = 107, contents = "com_apple_ats_name_postscript == "Arial-BoldMT" && kMDItemContentTypeTree != com.adobe.postscript-lwfn-font" }
                      "restricted" => <bool: 0x7fff766c6320>: true
            12/18/12 11:58:03.156 AM com.apple.XType.FontHelper[1422]: AutoActivation:  scopes (
                "/Library/Application Support/Apple/Fonts"
            12/18/12 11:58:03.171 AM com.apple.XType.FontHelper[1422]: FontHelper:  message received. (<dictionary: 0x7f8fc7c02cb0> { count = 2, contents =
                      "query" => <string: 0x7f8fc7c02e10> { length = 102, contents = "com_apple_ats_name_postscript == "ArialMT" && kMDItemContentTypeTree != com.adobe.postscript-lwfn-font" }
            12/18/12 11:58:03.171 AM com.apple.XType.FontHelper[1422]: AutoActivation:  scopes (
            12/18/12 11:58:15.549 AM Finder[160]: CFPropertyListCreateFromXMLData(): Old-style plist parser: missing semicolon in dictionary on line 1. Parsing will be abandoned. Break on _CFPropertyListMissingSemicolon to debug.
            12/18/12 11:58:15.550 AM Finder[160]: CFPropertyListCreateFromXMLData(): Old-style plist parser: missing semicolon in dictionary on line 1. Parsing will be abandoned. Break on _CFPropertyListMissingSemicolon to debug.
            12/18/12 11:58:15.551 AM Finder[160]: CFPropertyListCreateFromXMLData(): Old-style plist parser: missing semicolon in dictionary on line 1. Parsing will be abandoned. Break on _CFPropertyListMissingSemicolon to debug.
            12/18/12 11:58:15.552 AM Finder[160]: CFPropertyListCreateFromXMLData(): Old-style plist parser: missing semicolon in dictionary on line 1. Parsing will be abandoned. Break on _CFPropertyListMissingSemicolon to debug.
            12/18/12 11:58:15.553 AM Finder[160]: CFPropertyListCreateFromXMLData(): Old-style plist parser: missing semicolon in dictionary on line 1. Parsing will be abandoned. Break on _CFPropertyListMissingSemicolon to debug.
            12/18/12 11:58:15.554 AM Finder[160]: CFPropertyListCreateFromXMLData(): Old-style plist parser: missing semicolon in dictionary on line 1. Parsing will be abandoned. Break on _CFPropertyListMissingSemicolon to debug.
            12/18/12 12:02:34.840 PM gconsync[1449]: [0x7f833240a540] |ISyncManager|Warning| Could not retrieve ISyncClient with id com.apple.Keychain!
            12/18/12 12:08:09.939 PM mdworker[1304]: CFPropertyListCreateFromXMLData(): Old-style plist parser: missing semicolon in dictionary on line 1. Parsing will be abandoned. Break on _CFPropertyListMissingSemicolon to debug.
            12/18/12 12:08:11.041 PM WindowServer[122]: _CGXGetWindowOrderingGroup: Operation on a window 0x6d requiring rights 0x5 by caller Photoshop
            12/18/12 12:08:11.042 PM WindowServer[122]: _CGXGetWindowOrderingGroup: Operation on a window 0x6d requiring rights 0x5 by caller Photoshop
            12/18/12 12:08:11.043 PM WindowServer[122]: _CGXGetWindowOrderingGroup: Operation on a window 0x6d requiring rights 0x5 by caller Photoshop
            12/18/12 12:08:11.044 PM WindowServer[122]: _CGXGetWindowOrderingGroup: Operation on a window 0x6d requiring rights 0x5 by caller Photoshop
            12/18/12 12:13:41.688 PM Finder[160]: pearlBrowserSelectionChanged.
            12/18/12 12:13:51.744 PM Finder[160]: pearlBrowserSelectionChanged.
            12/18/12 12:15:30.000 PM kernel[0]: MacAuthEvent en2   Auth result for: 00:0f:66:43:a4:fa  MAC AUTH succeeded
            12/18/12 12:15:30.000 PM kernel[0]: wlEvent: en2 en2 Link UP virtIf = 0
            12/18/12 12:15:30.000 PM kernel[0]: AirPort: RSN handshake complete on en2
            12/18/12 12:15:30.000 PM kernel[0]: wl0: Roamed or switched channel, reason #2, bssid 00:0f:66:43:a4:fa
            12/18/12 12:15:30.000 PM kernel[0]: en2: BSSID changed to 00:0f:66:43:a4:fa
            12/18/12 12:15:30.000 PM kernel[0]: en2::IO80211Interface::postMessage bssid changed
            12/18/12 12:15:41.358 PM quicklookd[1502]: ImageIO: CGImageReadSessionGetCachedImageBlockData *** CGImageReadSessionGetCachedImageBlockData: readSession [0x7fe952b020f0] has bad readRef [0x7fe952b05b40]
            12/18/12 12:15:44.659 PM Finder[160]: pearlBrowserSelectionChanged.
            12/18/12 12:15:46.343 PM Finder[160]: pearlBrowserSelectionChanged.
            12/18/12 12:15:47.732 PM Finder[160]: pearlBrowserSelectionChanged.
            12/18/12 12:15:50.500 PM Finder[160]: pearlBrowserSelectionChanged.
            12/18/12 12:15:51.964 PM Finder[160]: pearlBrowserSelectionChanged.
            12/18/12 12:15:58.940 PM Finder[160]: pearlBrowserSelectionChanged.
            12/18/12 12:16:01.133 PM Finder[160]: pearlBrowserSelectionChanged.
            12/18/12 12:16:03.015 PM Finder[160]: pearlBrowserSelectionChanged.
            12/18/12 12:16:05.084 PM Finder[160]: pearlBrowserSelectionChanged.
            12/18/12 12:16:07.276 PM Finder[160]: pearlBrowserSelectionChanged.
            12/18/12 12:16:09.172 PM Finder[160]: pearlBrowserSelectionChanged.
            12/18/12 12:16:10.247 PM Finder[160]: pearlBrowserSelectionChanged.
            12/18/12 12:16:11.375 PM Finder[160]: pearlBrowserSelectionChanged.
            12/18/12 12:16:12.727 PM Finder[160]: pearlBrowserSelectionChanged.
            12/18/12 12:19:32.269 PM WindowServer[122]: _CGXGetWindowOrderingGroup: Operation on a window 0x6d requiring rights 0x5 by caller Photoshop
            12/18/12 12:19:32.270 PM WindowServer[122]: _CGXGetWindowOrderingGroup: Operation on a window 0x6d requiring rights 0x5 by caller Photoshop
            12/18/12 12:22:44.461 PM WindowServer[122]: _CGXGetWindowOrderingGroup: Operation on a window 0x6d requiring rights 0x5 by caller Photoshop
            12/18/12 12:22:44.462 PM WindowServer[122]: _CGXGetWindowOrderingGroup: Operation on a window 0x6d requiring rights 0x5 by caller Photoshop
            12/18/12 12:23:23.848 PM WindowServer[122]: _CGXGetWindowOrderingGroup: Operation on a window 0x676 requiring rights 0x5 by caller Photoshop
            12/18/12 12:23:23.849 PM WindowServer[122]: _CGXGetWindowOrderingGroup: Operation on a window 0x676 requiring rights 0x5 by caller Photoshop
            12/18/12 12:24:24.891 PM Finder[160]: pearlBrowserSelectionChanged.
            12/18/12 12:24:31.907 PM Finder[160]: pearlBrowserSelectionChanged.
            12/18/12 12:24:33.645 PM Finder[160]: pearlBrowserSelectionChanged.
            12/18/12 12:24:35.738 PM Finder[160]: pearlBrowserSelectionChanged.
            12/18/12 12:24:37.082 PM Finder[160]: pearlBrowserSelectionChanged.
            12/18/12 12:24:38.234 PM Finder[160]: pearlBrowserSelectionChanged.
            12/18/12 12:24:39.202 PM Finder[160]: pearlBrowserSelectionChanged.
            12/18/12 12:24:48.074 PM Finder[160]: pearlBrowserSelectionChanged.
            12/18/12 12:24:56.795 PM Finder[160]: pearlBrowserSelectionChanged.
            12/18/12 12:24:59.227 PM Finder[160]: pearlBrowserSelectionChanged.
            12/18/12 12:25:06.675 PM Finder[160]: pearlBrowserSelectionChanged.
            12/18/12 12:25:09.099 PM Finder[160]: pearlBrowserSelectionChanged.
            12/18/12 12:25:20.601 PM Finder[160]: pearlBrowserSelectionChanged.
            12/18/12 12:25:46.309 PM WindowServer[122]: _CGXGetWindowOrderingGroup: Operation on a window 0x6d requiring rights 0x5 by caller Photoshop
            12/18/12 12:31:53.510 PM mdworker[1482]: CFPropertyListCreateFromXMLData(): Old-style plist parser: missing semicolon in dictionary on line 1. Parsing will be abandoned. Break on _CFPropertyListMissingSemicolon to debug.
            12/18/12 12:31:54.740 PM WindowServer[122]: _CGXGetWindowOrderingGroup: Operation on a window 0x6d requiring rights 0x5 by caller Photoshop
            12/18/12 12:31:54.741 PM WindowServer[122]: _CGXGetWindowOrderingGroup: Operation on a window 0x6d requiring rights 0x5 by caller Photoshop
            12/18/12 12:31:54.742 PM WindowServer[122]: _CGXGetWindowOrderingGroup: Operation on a window 0x6d requiring rights 0x5 by caller Photoshop
            12/18/12 12:31:54.743 PM WindowServer[122]: _CGXGetWindowOrderingGroup: Operation on a window 0x6d requiring rights 0x5 by caller Photoshop
            12/18/12 12:39:02.682 PM mdworker[1616]: CFPropertyListCreateFromXMLData(): Old-style plist parser: missing semicolon in dictionary on line 1. Parsing will be abandoned. Break on _CFPropertyListMissingSemicolon to debug.
            12/18/12 12:53:17.555 PM mdworker[1654]: CFPropertyListCreateFromXMLData(): Old-style plist parser: missing semicolon in dictionary on line 1. Parsing will be abandoned. Break on _CFPropertyListMissingSemicolon to debug.
            12/18/12 12:54:52.000 PM kernel[0]: CODE SIGNING: cs_invalid_page(0x1000): p=1697[GoogleSoftwareUp] clearing CS_VALID
            12/18/12 12:54:54.241 PM mdworker[1692]: CFPropertyListCreateFromXMLData(): Old-style plist parser: missing semicolon in dictionary on line 1. Parsing will be abandoned. Break on _CFPropertyListMissingSemicolon to debug.
            12/18/12 12:54:55.405 PM WindowServer[122]: _CGXGetWindowOrderingGroup: Operation on a window 0x72 requiring rights 0x5 by caller Photoshop
            12/18/12 12:54:55.406 PM WindowServer[122]: _CGXGetWindowOrderingGroup: Operation on a window 0x72 requiring rights 0x5 by caller Photoshop
            12/18/12 12:54:55.407 PM WindowServer[122]: _CGXGetWindowOrderingGroup: Operation on a window 0x72 requiring rights 0x5 by caller Photoshop
            12/18/12 12:54:55.408 PM WindowServer[122]: _CGXGetWindowOrderingGroup: Operation on a window 0x72 requiring rights 0x5 by caller Photoshop
            12/18/12 12:54:55.411 PM WindowServer[122]: _CGXGetWindowOrderingGroup: Operation on a window 0x72 requiring rights 0x5 by caller Photoshop
            12/18/12 12:54:55.412 PM WindowServer[122]: _CGXGetWindowOrderingGroup: Operation on a window 0x72 requiring rights 0x5 by caller Photoshop
            12/18/12 12:54:55.413 PM WindowServer[122]: _CGXGetWindowOrderingGroup: Operation on a window 0x72 requiring rights 0x5 by caller Photoshop
            12/18/12 12:54:55.414 PM WindowServer[122]: _CGXGetWindowOrderingGroup: Operation on a window 0x72 requiring rights 0x5 by caller Photoshop
            12/18/12 12:54:55.415 PM WindowServer[122]: _CGXGetWindowOrderingGroup: Operation on a window 0x72 requiring rights 0x5 by caller Photoshop
            12/18/12 12:57:44.474 PM WindowServer[122]: _CGXGetWindowOrderingGroup: Operation on a window 0x6d requiring rights 0x5 by caller Photoshop
            12/18/12 12:57:44.475 PM WindowServer[122]: _CGXGetWindowOrderingGroup: Operation on a window 0x6d requiring rights 0x5 by caller Photoshop
            12/18/12 12:57:44.476 PM WindowServer[122]: _CGXGetWindowOrderingGroup: Operation on a window 0x6d requiring rights 0x5 by caller Photoshop
            12/18/12 12:57:44.477 PM WindowServer[122]: _CGXGetWindowOrderingGroup: Operation on a window 0x6d requiring rights 0x5 by caller Photoshop
            12/18/12 12:57:44.478 PM WindowServer[122]: _CGXGetWindowOrderingGroup: Operation on a window 0x6d requiring rights 0x5 by caller Photoshop
            12/18/12 12:57:44.479 PM WindowServer[122]: _CGXGetWindowOrderingGroup: Operation on a window 0x6d requiring rights 0x5 by caller Photoshop
            12/18/12 12:57:44.480 PM WindowServer[122]: _CGXGetWindowOrderingGroup: Operation on a window 0x6d requiring rights 0x5 by caller Photoshop
            12/18/12 12:57:44.481 PM WindowServer[122]: _CGXGetWindowOrderingGroup: Operation on a window 0x6d requiring rights 0x5 by caller Photoshop
            12/18/12 12:57:44.484 PM WindowServer[122]: _CGXGetWindowOrderingGroup: Operation on a window 0x6d requiring rights 0x5 by caller Photoshop
            12/18/12 12:57:44.485 PM WindowServer[122]: _CGXGetWindowOrderingGroup: Operation on a window 0x6d requiring rights 0x5 by caller Photoshop
            12/18/12 12:57:44.486 PM WindowServer[122]: _CGXGetWindowOrderingGroup: Operation on a window 0x6d requiring rights 0x5 by caller Photoshop
            12/18/12 1:02:34.948 PM gconsync[1724]: [0x7fb13340a540] |ISyncManager|Warning| Could not retrieve ISyncClient with id com.apple.Keychain!
            12/18/12 1:02:47.655 PM Splashtop Streamer[195]: SRFEAT_NOTIFY_SERVER_CLOUD_NOTIFY_MSG
            12/18/12 1:02:47.656 PM Splashtop Streamer[195]: [ProcServerNotification] SRS_SERVER_RTN_INFO : [200][.srhbnotify.xml]
            12/18/12 1:02:47.657 PM Splashtop Streamer[195]:   receive backend string notify
            12/18/12 1:02:47.657 PM Splashtop Streamer[195]: -[CMXMLParser length]: unrecognized selector sent to instance 0x1013726f0
            12/18/12 1:02:47.658 PM Splashtop Streamer[195]: -[CMXMLParser length]: unrecognized selector sent to instance 0x1013726f0
            12/18/12 1:02:47.659 PM Splashtop Streamer[195]: (
                      0   CoreFoundation                      0x00007fff8bddd0a6 __exceptionPreprocess + 198
                      1   libobjc.A.dylib                     0x00007fff8d0a03f0 objc_exception_throw + 43
                      2   CoreFoundation                      0x00007fff8be736ea -[NSObject(NSObject) doesNotRecognizeSelector:] + 186
                      3   CoreFoundation                      0x00007fff8bdcb5ce ___forwarding___ + 414
                      4   CoreFoundation                      0x00007fff8bdcb3b8 _CF_forwarding_prep_0 + 232
                      5   Foundation                          0x00007fff8b995ea8 -[NSPlaceholderString initWithString:] + 169
                      6   Splashtop Streamer                  0x000000010000be8f -[SplashtopRemoteAppDelegate getXMLContent:] + 199
                      7   CoreFoundation                      0x00007fff8be395cc ____CFXNotificationPostToken_block_invoke_0 + 284
                      8   CoreFoundation                      0x00007fff8bd9a272 __CFRUNLOOP_IS_CALLING_OUT_TO_A_BLOCK__ + 18
                      9   CoreFoundation                      0x00007fff8bd5aa4f __CFRunLoopDoBlocks + 255
                      11  CoreFoundation                      0x00007fff8bd7e6b2 CFRunLoopRunSpecific + 290
                      12  HIToolbox                           0x00007fff8dcb20a4 RunCurrentEventLoopInMode + 209
                      13  HIToolbox                           0x00007fff8dcb1e42 ReceiveNextEventCommon + 356
                      14  HIToolbox                           0x00007fff8dcb1cd3 BlockUntilNextEventMatchingListInMode + 62
                      15  AppKit                              0x00007fff90c7d613 _DPSNextEvent + 685
                      16  AppKit                              0x00007fff90c7ced2 -[NSApplication nextEventMatchingMask:untilDate:inMode:dequeue:] + 128
                      17  AppKit                              0x00007fff90c74283 -[NSApplication run] + 517
                      18  AppKit                              0x00007fff90c18cb6 NSApplicationMain + 869
                      19  Splashtop Streamer                  0x00000001000018b4 start + 52
            12/18/12 1:02:47.659 PM Splashtop Streamer[195]:   receive backend string notify
            12/18/12 1:02:47.660 PM Splashtop Streamer[195]: -[CMXMLParser length]: unrecognized selector sent to instance 0x104d06ea0
            12/18/12 1:02:47.661 PM Splashtop Streamer[195]: (
            12/18/12 1:07:19.490 PM Finder[160]: pearlBrowserSelectionChanged.
            12/18/12 1:07:22.467 PM Finder[160]: pearlBrowserSelectionChanged.
            12/18/12 1:07:23.331 PM Finder[160]: pearlBrowserSelectionChanged.
            12/18/12 1:07:25.035 PM Finder[160]: pearlBrowserSelectionChanged.
            12/18/12 1:11:53.088 PM WindowServer[122]: _CGXGetWindowOrderingGroup: Operation on a window 0x72 requiring rights 0x5 by caller Photoshop
            12/18/12 1:11:53.089 PM WindowServer[122]: _CGXGetWindowOrderingGroup: Operation on a window 0x72 requiring rights 0x5 by caller Photoshop
            12/18/12 1:11:53.090 PM WindowServer[122]: _CGXGetWindowOrderingGroup: Operation on a window 0x72 requiring rights 0x5 by caller Photoshop
            12/18/12 1:11:53.091 PM WindowServer[122]: _CGXGetWindowOrderingGroup: Operation on a window 0x72 requiring rights 0x5 by caller Photoshop
            12/18/12 1:11:53.092 PM WindowServer[122]: _CGXGetWindowOrderingGroup: Operation on a window 0x72 requiring rights 0x5 by caller Photoshop
            12/18/12 1:11:53.093 PM WindowServer[122]: _CGXGetWindowOrderingGroup: Operation on a window 0x72 requiring rights 0x5 by caller Photoshop
            12/18/12 1:11:53.098 PM WindowServer[122]: _CGXGetWindowOrderingGroup: Operation on a window 0x72 requiring rights 0x5 by caller Photoshop
            12/18/12 1:11:53.099 PM WindowServer[122]: _CGXGetWindowOrderingGroup: Operation on a window 0x72 requiring rights 0x5 by caller Photoshop
            12/18/12 1:11:53.100 PM WindowServer[122]: _CGXGetWindowOrderingGroup: Operation on a window 0x72 requiring rights 0x5 by caller Photoshop
            12/18/12 1:11:53.101 PM WindowServer[122]: _CGXGetWindowOrderingGroup: Operation on a window 0x72 requiring rights 0x5 by caller Photoshop
            12/18/12 1:11:53.102 PM WindowServer[122]: _CGXGetWindowOrderingGroup: Operation on a window 0x72 requiring rights 0x5 by caller Photoshop
            12/18/12 1:11:53.103 PM WindowServer[122]: _CGXGetWindowOrderingGroup: Operation on a window 0x72 requiring rights 0x5 by caller Photoshop
            12/18/12 1:24:05.836 PM WindowServer[122]: Created shield window 0x91a for display 0x04241064
            12/18/12 1:24:05.836 PM WindowServer[122]: device_generate_desktop_screenshot: authw 0x0(0), shield 0x0(0)
            12/18/12 1:24:05.854 PM WindowServer[122]: device_generate_lock_screen_screenshot: authw 0x0(0), shield 0x0(0)
            12/18/12 1:25:04.564 PM WindowServer[122]: handle_will_sleep_auth_and_shield_windows: no lock state data
            12/18/12 1:31:21.473 PM WindowServer[122]: _CGXGetWindowOrderingGroup: Operation on a window 0x6d requiring rights 0x5 by caller Photoshop
            12/18/12 1:32:00.282 PM loginwindow[94]: *** WARNING: -[NSImage compositeToPoint:operation:] is deprecated in MacOSX 10.8 and later. Please use -[NSImage drawAtPoint:fromRect:operation:fraction:] instead.
            12/18/12 1:32:00.282 PM loginwindow[94]: *** WARNING: -[NSImage compositeToPoint:fromRect:operation:] is deprecated in MacOSX 10.8 and later. Please use -[NSImage drawAtPoint:fromRect:operation:fraction:] instead.
            12/18/12 1:32:09.428 PM com.apple.launchd.peruser.501[145]: ([0x0-0x140140].com.adobe.Photoshop[1364]) Exited: Terminated: 15
            12/18/12 1:32:13.000 PM kernel[0]: Adobe Photoshop  (map: 0xffffff80504ecc18) triggered DYLD shared region unnest for map: 0xffffff80504ecc18, region 0x7fff89800000->0x7fff89a00000. While not abnormal for debuggers, this increases system memory footprint until the target exits.
            12/18/12 1:32:32.977 PM Adobe Photoshop CS6[1825]: *** WARNING: -[NSObject(NSKeyValueCoding) takeValuesFromDictionary:] is deprecated. It will be removed in a future release and should no longer be used.
            12/18/12 1:33:00.578 PM mdworker[1807]: CFPropertyListCreateFromXMLData(): Old-style plist parser: missing semicolon in dictionary on line 1. Parsing will be abandoned. Break on _CFPropertyListMissingSemicolon to debug.
            12/18/12 1:33:01.735 PM WindowServer[122]: _CGXGetWindowOrderingGroup: Operation on a window 0x6d requiring rights 0x5 by caller Photoshop
            12/18/12 1:50:00.308 PM librariand[1903]: MMe quota status changed: under quota
            12/18/12 1:50:00.330 PM Mail[1902]: Using V2 Layout
            12/18/12 1:50:00.887 PM com.apple.SecurityServer[15]: Session 100015 created
            12/18/12 1:50:01.475 PM Mail[1902]: [<_LibSasl2SASLClient: 0x7f8eecb02010> mechanism: PLAIN security layer: no] Failed to start the SASL connection
            SASL(-1): generic failure:
            12/18/12 1:50:01.727 PM Finder[160]: pearlBrowserSelectionChanged.
            12/18/12 1:50:02.239 PM Finder[160]: pearlBrowserSelectionChanged.
            12/18/12 1:50:05.250 PM Mail[1902]: *** -[IADomainCache init]: IA domains cache is out of date.
            12/18/12 1:50:06.722 PM iCalExternalSync[1907]: [0x7ffadbc0e460] |Miscellaneous|Error| SyncServices precondition failure in [ISyncConcreteSession pushChangesFromRecord:withIdentifier:]: you can't change the record's entity name from com.apple.calendars.MailAlarm to com.apple.calendars.DisplayAlarm in {
                "com.apple.syncservices.RecordEntityName" = "com.apple.calendars.DisplayAlarm";
                description = "";
                owner =     (
                    "Event/p935"
                triggerduration = "-900";
            12/18/12 1:50:06.722 PM iCalExternalSync[1907]: [ICalExternalSync ]Encountered exception: [ISyncConcreteSession pushChangesFromRecord:withIdentifier:]: you can't change the record's entity name from com.apple.calendars.MailAlarm to com.apple.calendars.DisplayAlarm in {
                description = "";
                owner =     (
                    "Event/p935"
            } withStack: (
                      0   iCalExternalSync                    0x0000000101cd2a60 iCalExternalSync + 125536
                      1   iCalExternalSync                    0x0000000101cc1ac9 iCalExternalSync + 56009
                      2   iCalExternalSync                    0x0000000101cd1694 iCalExternalSync + 120468
                      3   libdyld.dylib                       0x00007fff91f037e1 start + 0
            12/18/12 1:50:06.723 PM iCalExternalSync[1907]: [ICalExternalSync ]NSException name:ISyncInvalidArgumentsException reason:[ISyncConcreteSession pushChangesFromRecord:withIdentifier:]: you can't change the record's entity name from com.apple.calendars.MailAlarm to com.apple.calendars.DisplayAlarm in {
                description = "";
                owner =     (
                    "Event/p935"
            12/18/12 1:50:06.724 PM SyncServer[1901]: [0x7f9710c0be00] |Server|Warning| lost connection 0x7f9713900490 to com.apple.iCal
            12/18/12 1:50:08.267 PM com.apple.XType.FontHelper[1910]: FontHelper:  message received. (<dictionary: 0x7f8feb41cfd0> { count = 2, contents =
                      "query" => <string: 0x7f8feb41d130> { length = 100, contents = "com_apple_ats_name_postscript == "arial" && kMDItemContentTypeTree != com.adobe.postscript-lwfn-font" }
            12/18/12 1:50:08.267 PM com.apple.XType.FontHelper[1910]: AutoActivation:  scopes (
            12/18/12 1:50:08.282 PM com.apple.XType.FontHelper[1910]: FontHelper:  message received. (<dictionary: 0x7f8feb41cca0> { count = 2, contents =
                      "query" => <string: 0x7f8feb41ce00> { length = 102, contents = "com_apple_ats_name_postscript == "Georgia" && kMDItemContentTypeTree != com.adobe.postscript-lwfn-font" }
            12/18/12 1:50:08.282 PM com.apple.XType.FontHelper[1910]: AutoActivation:  scopes (
            12/18/12 1:50:08.000 PM kernel[0]: Sandbox: sandboxd(1911) deny mach-lookup com.apple.coresymbolicationd
            12/18/12 1:50:08.822 PM com.apple.XType.FontHelper[1910]: FontHelper:  message received. (<dictionary: 0x7f8feb41d0e0> { count = 2, contents =
                      "query" => <string: 0x7f8feb41cca0> { length = 102, contents = "com_apple_ats_name_postscript == "Calibri" && kMDItemContentTypeTree != com.adobe.postscript-lwfn-font" }
            12/18/12 1:50:08.823 PM com.apple.XType.FontHelper[1910]: AutoActivation:  scopes (
            12/18/12 1:50:08.840 PM com.apple.XType.FontHelper[1910]: FontHelper:  message received. (<dictionary: 0x7f8feb41cca0> { count = 2, contents =
                      "query" => <string: 0x7f8feb41e0b0> { length = 100, contents = "com_apple_ats_name_postscript == "Arial" && kMDItemContentTypeTree != com.adobe.postscript-lwfn-font" }
            12/18/12 1:50:08.840 PM com.apple.XType.FontHelper[1910]: AutoActivation:  scopes (
            12/18/12 1:50:09.436 PM sandboxd[1911]: ([1902]) Mail(1902) deny mach-lookup ATS Query Port 184
            12/18/12 1:50:09.455 PM sandboxd[1911]: ([1902]) Mail(1902) deny mach-lookup ATS Query Port 184
            12/18/12 1:50:09.473 PM sandboxd[1911]: ([1902]) Mail(1902) deny mach-lookup ATS Query Port 184
            12/18/12 1:50:11.867 PM com.apple.XType.FontHelper[1910]: FontHelper:  message received. (<dictionary: 0x7f8fec1013c0> { count = 2, contents =
                      "query" => <string: 0x7f8fec1004a0> { length = 101, contents = "com_apple_ats_name_postscript == "Tahoma" && kMDItemContentTypeTree != com.adobe.postscript-lwfn-font" }
            12/18/12 1:50:11.867 PM com.apple.XType.FontHelper[1910]: AutoActivation:  scopes (
            12/18/12 1:50:12.544 PM sandboxd[1911]: ([1902]) Mail(1902) deny mach-lookup ATS Query Port 184
            12/18/12 1:50:14.144 PM com.apple.XType.FontHelper[1910]: FontHelper:  message received. (<dictionary: 0x7f8feb41eca0> { count = 2, contents =
                      "query" => <string: 0x7f8feb41e0b0> { length = 101, contents = "com_apple_ats_name_postscript == "tahoma" && kMDItemContentTypeTree != com.adobe.postscript-lwfn-font" }
            12/18/12 1:50:14.144 PM com.apple.XType.FontHelper[1910]: AutoActivation:  scopes (
            12/18/12 1:50:14.761 PM sandboxd[1911]: ([1902]) Mail(1902) deny mach-lookup ATS Query Port 184
            12/18/12 1:50:14.779 PM sandboxd[1911]: ([1902]) Mail(1902) deny mach-lookup ATS Query Port 184
            12/18/12 1:50:14.797 PM sandboxd[1911]: ([1902]) Mail(1902) deny mach-lookup ATS Query Port 184
            12/18/12 1:50:14.814 PM sandboxd[1911]: ([1902]) Mail(1902) deny mach-lookup ATS Query Port 184
            12/18/12 1:50:27.628 PM WindowServer[122]: _CGXGetWindowOrderingGroup: Operation on a window 0x9a8 requiring rights 0x5 by caller Photoshop
            12/18/12 1:50:34.118 PM Finder[160]: pearlBrowserSelectionChanged.
            12/18/12 1:50:39.391 PM iCalExternalSync[1915]: [0x7fab7040e460] |Miscellaneous|Error| SyncServices precondition failure in [ISyncConcreteSession pushChangesFromRecord:withIdentifier:]: you can't change the record's entity name from com.apple.calendars.MailAlarm to com.apple.calendars.DisplayAlarm in {
                description = "";
                owner =     (
                    "Event/p935"
            12/18/12 1:50:39.392 PM iCalExternalSync[1915]: [ICalExternalSync ]Encountered exception: [ISyncConcreteSession pushChangesFromRecord:withIdentifier:]: you can't change the record's entity name from com.apple.calendars.MailAlarm to com.apple.calendars.DisplayAlarm in {
                description = "";
                owner =     (
                    "Event/p935"
            } withStack: (
                      0   iCalExternalSync                    0x00000001050cfa60 iCalExternalSync + 125536
                      1   iCalExternalSync                    0x00000001050beac9 iCalExternalSync + 56009
                      2   iCalExternalSync                    0x00000001050ce694 iCalExternalSync + 120468
            12/18/12 1:50:39.393 PM iCalExternalSync[1915]: [ICalExternalSync ]NSException name:ISyncInvalidArgumentsException reason:[ISyncConcreteSession pushChangesFromRecord:withIdentifier:]: you can't change the record's entity name from com.apple.calendars.MailAlarm to com.apple.calendars.DisplayAlarm in {
                description = "";
                owner =     (
                    "Event/p935"
            12/18/12 1:50:39.393 PM SyncServer[1901]: [0x7f9710c0be00] |Server|Warning| lost connection 0x7f9719b00360 to com.apple.iCal
            12/18/12 1:51:02.604 PM WindowServer[122]: _CGXGetWindowOrderingGroup: Operation on a window 0x6d requiring rights 0x5 by caller Photoshop
            12/18/12 1:51:02.605 PM WindowServer[122]: _CGXGetWindowOrderingGroup: Operation on a window 0x6d requiring rights 0x5 by caller Photoshop
            12/18/12 1:51:10.557 PM Finder[160]: pearlBrowserSelectionChanged.
            12/18/12 1:51:33.803 PM Finder[160]: pearlBrowserSelectionChanged.
            12/18/12 1:51:41.248 PM Finder[160]: pearlBrowserSelectionChanged.
            12/18/12 1:51:44.003 PM Finder[160]: pearlBrowserSelectionChanged.
            12/18/12 1:51:55.404 PM Finder[160]: pearlBrowserSelectionChanged.
            12/18/12 1:53:35.369 PM GoogleSoftwareUpdateDaemon[1931]: -[KeystoneDaemon logServiceState] GoogleSoftwareUpdate daemon (1.1.0.3659) vending:
                      com.google.Keystone.Daemon.UpdateEngine: 2 connection(s)
                      com.google.Keystone.Daemon.Administration: 0 connection(s)
            12/18/12 1:53:35.000 PM kernel[0]: CODE SIGNING: cs_invalid_page(0x1000): p=1930[GoogleSoftwareUp] clearing CS_VALID
            12/18/12 1:53:35.382 PM GoogleSoftwareUpdateDaemon[1931]: -[KSUpdateEngine updateProductID:] KSUpdateEngine updating product ID: "com.google.Keystone"
            12/18/12 1:53:35.386 PM GoogleSoftwareUpdateDaemon[1931]: -[KSCheckAction performAction] KSCheckAction checking 1 ticket(s).
            12/18/12 1:53:35.392 PM GoogleSoftwareUpdateDaemon[1931]: -[KSUpdateCheckAction performAction] KSUpdateCheckAction starting update check for ticket(s): {(
                      <KSTicket:0x66089b0
                                productID=com.google.Keystone
                                version=1.1.0.3659
                                xc=<KSPathExistenceChecker:0x66085a0 path=/Library/Google/GoogleSoftwareUpdate/GoogleSoftwareUpdate.bundle/>
                                serverType=Omaha
                                url=https://tools.google.com/service/update2
                                creationDate=2011-07-11 14:46:13
            Using server: <KSOmahaServer:0x4608120
                      engine=<KSDaemonUpdateEngine:0x224910>
                      params={
                                EngineVersion = "1.1.0.3659";
                                ActivesInfo = {
                                          "com.google.picasa" = {
                                                    LastActiveDate = 2012-03-16 03:12:34 +0000;
                                                    LastActivePingDate = 2012-03-16 07:00:00 +0000;
                                          "com.google.Chrome" = {
                                                    LastActivePingDate = 2012-11-16 08:00:01 +0000;
                                                    LastActiveDate = 2012-11-16 04:43:04 +0000;
                                          "com.google.Keystone" = {
                                                    LastActiveDate = 2012-12-18 18:53:35 +0000;
                                          "com.google.GoogleDrive" = {
                                                    LastActivePingDate = 2012-12-09 08:00:00 +0000;
                                                    LastActiveDate = 2012-12-08 20:19:33 +0000;
                                          "com.google.talkplugin" = {
                                                    LastActiveDate = 2012-01-19 13:54:09 +0000;
                                                    LastActivePingDate = 2012-07-21 07:00:00 +0000;
                                UserInitiated = 0;
                                IsSystem = 1;
                                OmahaOSVersion = "10.8.2_i486";
                                Identity = KeystoneDaemon;
                                AllowedSubdomains = (
                                          ".omaha.sandbox.google.com",
                                          ".tools.google.com",
                                          ".www.google.com",
                                          ".corp.google.com"
            12/18/12 1:53:35.394 PM GoogleSoftwareUpdateDaemon[1931]: -[KSUpdateCheckAction performAction] KSUpdateCheckAction running KSServerUpdateRequest: <KSOmahaServerUpdateRequest:0x460d930
                      server=<KSOmahaServer:0x4608120>
                      url="https://tools.google.com/service/update2"
                      runningFetchers=0
                      tickets=1
                      activeTickets=0
                      rollCallTickets=0
                      body=
                                <?xml version="1.0" encoding="UTF-8" standalone="yes"?>
                                <o:gupdate xmlns:o="http://www.google.com/update2/request" protocol="2.0" version="KeystoneDaemon-1.1.0.3659" ismachine="1">
                                    <o:os platform="mac" version="MacOSX" sp="10.8.2_i486"></o:os>
                                    <o:app appid="com.google.Keystone" version="1.1.0.3659" lang="en-us" installage="526" brand="GGLG">
                                        <o:updatecheck></o:updatecheck>
                                    </o:app>
                                </o:gupdate>
            12/18/12 1:53:35.683 PM GoogleSoftwareUpdateDaemon[1931]: -[KSUpdateCheckAction(KSServerUpdateRequestDelegate) serverRequest:fetchedWithResponse:] KSUpdateCheckAction received KSServerUpdateResponse: <KSOmahaServerUpdateResponse:0x509970
                      status=200
                      tickets=1
                      activeTickets=0
                      rollCallTickets=0
                      data=
                                <gupdate xmlns="http://www.google.com/update2/response" protocol="2.0" server="prod">
                                    <daystart elapsed_seconds="39215"></daystart>
                                    <app appid="com.google.Keystone" status="ok">
                                        <updatecheck status="noupdate"></updatecheck>
                                    </app>
                                </gupdate>
            12/18/12 1:53:35.688 PM GoogleSoftwareUpdateDaemon[1931]: -[KSUpdateCheckAction(PrivateMethods) finishAction] KSUpdateCheckAction found updates: {( )}
            12/18/12 1:53:35.691 PM GoogleSoftwareUpdateDaemon[1931]: -[KSPrefetchAction performAction] KSPrefetchAction no updates to prefetch.
            12/18/12 1:53:35.692 PM GoogleSoftwareUpdateDaemon[1931]: -[KSMultiUpdateAction performAction] KSSilentUpdateAction had no updates to apply.
            12/18/12 1:53:35.693 PM GoogleSoftwareUpdateDaemon[1931]: -[KSMultiUpdateAction performAction] KSPromptAction had no updates to apply.
            12/18/12 1:53:35.695 PM GoogleSoftwareUpdateDaemon[1931]: -[KSUpdateEngine(PrivateMethods) updateFinish] KSUpdateEngine update processing complete.
            12/18/12 1:53:36.415 PM GoogleSoftwareUpdateDaemon[1931]: -[KSUpdateEngine updateAllProducts] KSUpdateEngine updating all installed products.
            12/18/12 1:53:36.417 PM GoogleSoftwareUpdateDaemon[1931]: -[KSCheckAction performAction] KSCheckAction checking 2 ticket(s).
            12/18/12 1:53:36.423 PM GoogleSoftwareUpdateDaemon[1931]: -[KSUpdateCheckAction performAction] KSUpdateCheckAction starting update check for ticket(s): {(
                      <KSTicket:0x660cea0
                                version=1.1.0.3659
                                xc=<KSPathExistenceChecker:0x6608bd0 path=/Library/Google/GoogleSoftwareUpdate/GoogleSoftwareUpdate.bundle/>
                                serverType=Omaha
                      <KSTicket:0x660df70
                                productID=com.google.talkplugin
                                version=3.10.2.10212
                                xc=<KSPathExistenceChecker:0x660e010 path=/Library/Application Support/Google/GoogleTalkPlugin.app>
                                serverType=Omaha
                                creationDate=2012-07-20 22:50:59
            Using server: <KSOmahaServer:0x660b0a0
                      params={
                                ActivesInfo = {
                                                    LastRollCallPingDate = 2012-12-18 08:00:00 +0000;
                                                    LastActivePingDate = 2012-12-18 08:00:00 +0000;
                                UserInitiated = 0;
                                IsSystem = 1;
                                          ".www.google.com",
                                          ".corp.google.com"
            12/18/12 1:53:36.424 PM GoogleSoftwareUpdateDaemon[1931]: -[KSUpdateCheckAction performAction] KSUpdateCheckAction running KSServerUpdateRequest: <KSOmahaServerUpdateRequest:0x660efb0
                      server=<KSOmahaServer:0x660b0a0>
                      runningFetchers=0
                      tickets=2
                      activeTickets=0
                      rollCallTickets=0
                      body=
                                    </o:app>
                                    <o:app appid="com.google.talkplugin" version="3.10.2.10212" lang="en-us" installage="150" brand="GGLG">
                                    </o:app>
                                </o:gupdate>
            12/18/12 1:53:36.687 PM GoogleSoftwareUpdateDaemon[1931]: -[KSUpdateCheckAction(KSServerUpdateRequestDelegate) serverRequest:fetchedWithResponse:] KSUpdateCheckAction received KSServerUpdateResponse: <KSOmahaServerUpdateResponse:0x4209140
                      status=200
                      tickets=2
                      activeTickets=0
                      rollCallTickets=0
                      data=
                                    <daystart elapsed_seconds="39216"></daystart>
                                    </app>
                                    <app appid="com.google.talkplugin" status="ok">
                                    </app>
                                </gupdate>
            12/18/12 1:53:36.690 PM GoogleSoftwareUpdateDaemon[1931]: -[KSUpdateCheckAction(PrivateMethods) finishAction] KSUpdateCheckAction found updates: {( )}
            12/18/12 1:53:36.693 PM GoogleSoftwareUpdateDaemon[1931]: -[KSPrefetchAction performAction] KSPrefetchAction no updates to prefetch.
            12/18/12 1:53:36.694 PM GoogleSoftwareUpdateDaemon[1931]: -[KSMultiUpdateAction performAction] KSSilentUpdateAction had no updates to apply.
            12/18/12 1:53:36.695 PM GoogleSoftwareUpdateDaemon[1931]: -[KSMultiUpdateAction performAction] KSPromptAction had no updates to apply.
            12/18/12 1:53:36.697 PM GoogleSoftwareUpdateDaemon[1931]: -[KSUpdateEngine(PrivateMethods) updateFinish] KSUpdateEngine update processing complete.
            12/18/12 1:53:39.346 PM GoogleSoftwareUpdateDaemon[1931]: -[KeystoneDaemon logServiceState] GoogleSoftwareUpdate daemon (1.1.0.3659) vending:
                      com.google.Keystone.Daemon.UpdateEngine: 1 connection(s)
            12/18/12 1:54:05.372 PM GoogleSoftwareUpdateDaemon[1931]: -[KeystoneDaemon main] GoogleSoftwareUpdateDaemon inactive, shutdown.
            12/18/12 1:55:17.967 PM sandboxd[1939]: ([1902]) Mail(1902) deny mach-lookup ATS Query Port 184
            12/18/12 1:55:17.000 PM kernel[0]: Sandbox: sandboxd(1939) deny mach-lookup com.apple.coresymbolicationd
            12/18/12 1:55:17.981 PM sandboxd[1939]: ([1902]) Mail(1902) deny mach-lookup ATS Query Port 184
            12/18/12 1:55:17.994 PM sandboxd[1939]: ([1902]) Mail(1902) deny mach-lookup ATS Query Port 184
            12/18/12 1:55:18.008 PM sandboxd[1939]: ([1902]) Mail(1902) deny mach-lookup ATS Query Port 184
            12/18/12 1:55:18.021 PM sandboxd[1939]: ([1902]) Mail(1902) deny mach-lookup ATS Query Port 184
            12/18/12 1:55:18.034 PM sandboxd[1939]: ([1902]) Mail(1902) deny mach-lookup ATS Query Port 184
            12/18/12 1:56:01.373 PM WindowServer[122]: dict count after removing entry for window 0x22 is 0
            12/18/12 1:56:01.402 PM com.apple.launchd.peruser.501[145]: (com.apple.Finder[160]) Job appears to have crashed: Segmentation fault: 11
            12/18/12 1:56:01.559 PM ReportCrash[1943]: Saved crash report for Finder[160] version 10.8.1 (10.8.1) to /Users/Imacom/Library/Logs/DiagnosticReports/Finder_2012-12-18-135601_Mac-Pro-Imacom-5.cr ash
            12/18/12 1:56:17.097 PM mdwrite[1946]: [ERROR] [0.000s] com.apple. UBItemStatusNotification.c:805 _do_UBItemStatusNotificationRegisterURLs() can't find realpath for "/Users/Imacom/Library/Mobile Documents/com~apple~system~spotlight/mdlabels", was blocked at "/Users/Imacom/Library/Mobile Documents": 2 (No such file or directory)
            12/18/12 1:56:24.287 PM WindowServer[122]: CGXDisableUpdate: UI updates were forcibly disabled by application "Finder" for over 1.00 seconds. Server has re-enabled them.
            12/18/12 1:56:28.370 PM WindowServer[122]: reenable_update_for_connection: UI updates were finally reenabled by application "Finder" after 5.08 seconds (server forcibly re-enabled them after 1.00 seconds)
            12/18/12 1:57:46.048 PM Finder[1944]: CFPropertyListCreateFromXMLData(): Old-style plist parser: missing semicolon in dictionary on line 1. Parsing will be abandoned. Break on _CFPropertyListMissingSemicolon to debug.
            12/18/12 1:57:46.049 PM Finder[1944]: CFPropertyListCreateFromXMLData(): Old-style plist parser: missing semicolon in dictionary on line 1. Parsing will be abandoned. Break on _CFPropertyListMissingSemicolon to debug.
            12/18/12 1:57:46.050 PM Finder[1944]: CFPropertyListCreateFromXMLData(): Old-style plist parser: missing semicolon in dictionary on line 1. Parsing will be abandoned. Break on _CFPropertyListMissingSemicolon to debug.
            12/18/12 1:57:46.051 PM Finder[1944]: CFPropertyListCreateFromXMLData(): Old-style plist parser: missing semicolon in dictionary on line 1. Parsing will be abandoned. Break on _CFPropertyListMissingSemicolon to debug.
            12/18/12 1:57:46.052 PM Finder[1944]: CFPropertyListCreateFromXMLData(): Old-style plist parser: missing semicolon in dictionary on line 1. Parsing will be abandoned. Break on _CFPropertyListMissingSemicolon to debug.
            12/18/12 1:57:46.053 PM Finder[1944]: CFPropertyListCreateFromXMLData(): Old-style plist parser: missing semicolon in dictionary on line 1. Parsing will be abandoned. Break on _CFPropertyListMissingSemicolon to debug.
            12/18/12 2:00:01.000 PM kernel[0]: Adobe Photoshop  (map: 0xffffff80504ec960) triggered DYLD shared region unnest for map: 0xffffff80504ec960, region 0x7fff89800000->0x7fff89a00000. While not abnormal for debuggers, this increases system memory footprint until the target exits.
            12/18/12 2:00:23.000 PM kernel[0]: Adobe Photoshop  (map: 0xffffff80504ec960) triggered DYLD shared region unnest for map: 0xffffff80504ec960, region 0x7fff89800000->0x7fff89a00000. While not abnormal for debuggers, this increases system memory footprint until the target exits.
            12/18/12 2:02:35.077 PM gconsync[2013]: [0x7fcff140a540] |ISyncManager|Warning| Could not retrieve ISyncClient with id com.apple.Keychain!
            12/18/12 2:02:50.421 PM iCalExternalSync[2017]: [0x7faa9b40e460] |Miscellaneous|Error| SyncServices precondition failure in [ISyncConcreteSession pushChangesFromRecord:withIdentifier:]: you can't change the record's entity name from com.apple.calendars.MailAlarm to com.apple.calendars.DisplayAlarm in {
                description = "";
                owner =     (
                    "Event/p935"
            12/18/12 2:02:50.421 PM iCalExternalSync[2017]: [ICalExternalSync ]Encountered exception: [ISyncConcreteSession pushChangesFromRecord:withIdentifier:]: you can't change the record's entity name from com.apple.calendars.MailAlarm to com.apple.calendars.DisplayAlarm in {
                description = "";
                owner =     (
                    "Event/p935"
            } withStack: (
                      0   iCalExternalSync                    0x000000010f802a60 iCalExternalSync + 125536
                      1   iCalExternalSync                    0x000000010f7f1ac9 iCalExternalSync + 56009
                      2   iCalExternalSync                    0x000000010f801694 iCalExternalSync + 120468
            12/18/12 2:02:50.422 PM iCalExternalSync[2017]: [ICalExternalSync ]NSException name:ISyncInvalidArgumentsException reason:[ISyncConcreteSession pushChangesFromRecord:withIdentifier:]: you can't change the record's entity name from com.apple.calendars.MailAlarm to com.apple.calendars.DisplayAlarm in {
                description = "";
                owner =     (
                    "Event/p935"
            12/18/12 2:02:50.423 PM SyncServer[2014]: [0x7fefc9c0be00] |Server|Warning| lost connection 0x7fefcab06aa0 to com.apple.iCal
            12/18/12 2:06:53.057 PM mdworker[1887]: CFPropertyListCreateFromXMLData(): Old-style plist parser: missing semicolon in dictionary on line 1. Parsing will be abandoned. Break on _CFPropertyListMissingSemicolon to debug.
            12/18/12 2:06:54.392 PM WindowServer[122]: _CGXGetWindowOrderingGroup: Operation on a window 0x6d requiring rights 0x5 by caller Photoshop
            12/18/12 2:07:20.087 PM quicklookd[2031]: ImageIO: CGImageReadSessionGetCachedImageBlockData *** CGImageReadSessionGetCachedImageBlockData: readSession [0x7f96d9201bd0] has bad readRef [0x7f96d9201e30]
            12/18/12 2:11:33.095 PM Adobe Photoshop CS6[1825]: clip: empty path.
            12/18/12 2:11:33.096 PM Adobe Photoshop CS6[1825]: clip: empty path.
            12/18/12 2:12:37.840 PM mdworker[2047]: CFPropertyListCreateFromXMLData(): Old-style plist parser: missing semicolon in dictionary on line 1. Parsing will be abandoned. Break on _CFPropertyListMissingSemicolon to debug.
            12/18/12 2:15:06.974 PM quicklookd[2031]: [QL] _QLServerGetThumbnail: can't convert path to url
            12/18/12 2:15:06.975 PM quicklookd[2031]: [QL] _QLServerGetThumbnail: can't convert path to url
            12/18/12 2:15:07.482 PM com.apple.quicklook.satellite[2065]: bootstrap_look_up2 failed with 0x44c
            12/18/12 2:15:07.000 PM kernel[0]: Sandbox: sandboxd(2066) deny mach-lookup com.apple.coresymbolicationd
            12/18/12 2:15:08.203 PM sandboxd[2066]: ([2065]) QuickLookSatelli(2065) deny mach-lookup com.apple.PowerManagement.control
            12/18/12 2:15:08.224 PM sandboxd[2066]: ([2065]) QuickLookSatelli(2065) deny mach-lookup ATS Query Port 184
            12/18/12 2:15:08.244 PM sandboxd[2066]: ([2065]) QuickLookSatelli(2065) deny mach-lookup ATS Query Port 184
            12/18/12 2:15:08.264 PM sandboxd[2066]: ([2065]) QuickLookSatelli(2065) deny mach-lookup ATS Query Port 184
            12/18/12 2:15:08.286 PM sandboxd[2066]: ([2065]) QuickLookSatelli(2065) deny mach-lookup ATS Query Port 184
            12/18/12 2:15:08.297 PM sandboxd[2066]: ([2065]) QuickLookSatelli(2065) deny mach-lookup ATS Query Port 184
            12/18/12 2:15:15.686 PM com.apple.quicklook.satellite[2065]: [QL] Using too much memory (126 MB), hit critical threshold (120 MB), exiting immediately to clean up.
            12/18/12 2:15:17.686 PM com.apple.quicklook.satellite[2065]: [QL] Using too much memory (146 MB), hit critical threshold (120 MB), exiting immediately to clean up.
            12/18/12 2:15:17.704 PM com.apple.launchd[1]: (com.apple.quicklook.satellite.70D680DA-6052-4AEE-825C-D7AE7AF67E7C[2065]) Exited: Killed: 9
            12/18/12 2:15:38.237 PM com.apple.quicklook.satellite[2069]: [QL] Using too much memory (133 MB), hit critical threshold (120 MB), exiting immediately to clean up.
            12/18/12 2:15:38.271 PM com.apple.launchd[1]: (com.apple.quicklook.satellite.70D680DA-6052-4AEE-825C-D7AE7AF67E7C[2069]) Exited: Killed: 9
            12/18/12 2:16:30.448 PM com.apple.launchd.peruser.501[145]: ([0x0-0x1ba1ba].com.adobe.Photoshop[1825]) Job appears to have crashed: Abort trap: 6
            12/18/12 2:16:30.632 PM ReportCrash[2076]: Saved crash report for Adobe Photoshop CS6[1825] version 13.0.2 (13.0.2.23) to /Users/Imacom/Library/Logs/DiagnosticReports/Adobe Photoshop CS6_2012-12-18-141630_Mac-Pro-Imacom-5.crash
            12/18/12 2:16:37.000 PM kernel[0]: Adobe Photoshop  (map: 0xffffff80504ecc18) triggered DYLD shared region unnest for map: 0xffffff80504ecc18, region 0x7fff89800000->0x7fff89a00000. While not abnormal for debuggers, this increases system memory footprint until the target exits.
            12/18/12 2:16:53.222 PM WindowServer[122]: CGXDisableUpdate: UI updates were forcibly disabled by application "Photoshop" for over 1.00 seconds. Server has re-enabled them.
            12/18/12 2:16:56.092 PM WindowServer[122]: reenable_update_for_connection: UI updates were finally reenabled by application "Photoshop" after 3.87 seconds (server forcibly re-enabled them after 1.00 seconds)
            12/18/12 2:17:01.502 PM WindowServer[122]: CGXDisableUpdate: UI updates were forcibly disabled by application "Photoshop" for over 1.00 seconds. Server has re-enabled them.
            12/18/12 2:17:02.845 PM WindowServer[122]: reenable_update_for_connection: UI updates were finally reenabled by application "Photoshop" after 2.34 seconds (server forcibly re-enabled them after 1.00 seconds)
            12/18/12 2:17:05.318 PM WindowServer[122]: CGXDisableUpdate: UI updates were forcibly disabled by application "Photoshop" for over 1.00 seconds. Server has re-enabled them.
            12/18/12 2:17:06.664 PM WindowServer[122]: reenable_update_for_connection: UI updates were finally reenabled by application "Photoshop" after 2.35 seconds (server forcibly re-enabled them after 1.00 seconds)
            12/18/12 2:17:09.158 PM WindowServer[122]: CGXDisableUpdate: UI updates were forcibly disabled by application "Photoshop" for over 1.00 seconds. Server has re-enabled them.
            12/18/12 2:17:10.451 PM WindowServer[122]: reenable_update_for_connection: UI updates were finally reenabled by application "Photoshop" after 2.29 seconds (server forcibly re-enabled them after 1.00 seconds)
            12/18/12 2:17:32.721 PM Adobe Photoshop CS6[2081]: *** WARNING: -[NSObject(NSKeyValueCoding) takeValuesFromDictionary:] is deprecated. It will be removed in a future release and should no longer be used.
            12/18/12 2:20:51.996 PM quicklookd[2091]: [QL] _QLServerGetThumbnail: can't convert path to url
            12/18/12 2:20:51.997 PM quicklookd[2091]: [QL] _QLServerGetThumbnail: can't convert path to url
            12/18/12 2:20:51.999 PM quicklookd[2091]: [QL] _QLServerGetThumbnail: can't convert path to url
            12/18/12 2:20:52.581 PM com.apple.quicklook.satellite[2108]: bootstrap_look_up2 failed with 0x44c
            12/18/12 2:20:52.760 PM quicklookd[2091]: [QL] _QLServerGetThumbnail: can't convert path to url
            12/18/12 2:20:52.761 PM quicklookd[2091]: [QL] _QLServerGetThumbnail: can't convert path to url
            12/18/12 2:20:52.000 PM kernel[0]: Sandbox: sandboxd(2109) deny mach-lookup com.apple.coresymbolicationd
            12/18/12 2:20:52.785 PM quicklookd[2091]: [QL] _QLServerGetThumbnail: can't convert path to url
            12/18/12 2:20:53.246 PM sandboxd[2109]: ([2108]) QuickLookSatelli(2108) deny mach-lookup com.apple.PowerManagement.control
            12/18/12 2:20:53.258 PM sandboxd[2109]: ([2108]) QuickLookSatelli(2108) deny mach-lookup ATS Query Port 184
            12/18/12 2:20:53.269 PM sandboxd[2109]: ([2108]) QuickLookSatelli(2108) deny mach-lookup ATS Query Port 184
            12/18/12 2:20:53.280 PM sandboxd[2109]: ([2108]) QuickLookSatelli(2108) deny mach-lookup ATS Query Port 184
            12/18/12 2:20:53.291 PM sandboxd[2109]: ([2108]) QuickLookSatelli(2108) deny mach-lookup ATS Query Port 184
            12/18/12 2:20:53.303 PM sandboxd[2109]: ([2108]) QuickLookSatelli(2108) deny mach-lookup ATS Query Port 184
            12/18/12 2:20:53.314 PM sandboxd[2109]: ([2108]) QuickLookSatelli(2108) deny mach-lookup ATS Query Port 184
            12/18/12 2:28:17.962 PM sandboxd[2144]: ([2143]) QuickLookSatelli(2143) deny file-read-data /Volumes/Clone Vertex SSD (513.11 GB)/Users/Shared/Documents/Adobe/Help/en_US/PremierePro/CS5/Using/WSCE1EF46C-AB40-45f9-BA D8-D790421BD01A.html
            12/18/12 2:28:17.000 PM kernel[0]: Sandbox: sandboxd(2144) deny mach-lookup com.apple.coresymbolicationd
            12/18/12 2:30:21.220 PM com.apple.quicklook.satellite[2159]: bootstrap_look_up2 failed with 0x44c
            12/18/12 2:30:21.477 PM sandboxd[2160]: ([2159]) QuickLookSatelli(2159) deny mach-lookup com.apple.PowerManagement.control
            12/18/12 2:30:21.000 PM kernel[0]: Sandbox: sandboxd(2160) deny mach-lookup com.apple.coresymbolicationd
            12/18/12 2:30:22.020 PM com.apple.quicklook.satellite[2159]: [QL] Using too much memory (188 MB), hit critical threshold (180 MB), exiting immediately to clean up.
            12/18/12 2:30:24.020 PM com.apple.quicklook.satellite[2159]: [QL] Using too much memory (128 MB), hit critical threshold (120 MB), exiting immediately to clean up.
            12/18/12 2:30:24.045 PM com.apple.launchd[1]: (com.apple.quicklook.satellite.FF53CAA4-6090-4F05-A11B-C3CE95301247[2159]) Exited: Killed: 9
            12/18/12 2:32:47.349 PM iCalExternalSync[2180]: [0x7ffca1c0e460] |Miscellaneous|Error| SyncServices precondition failure in [ISyncConcreteSession pushChangesFromRecord:withIdentifier:]: you can't change the record's entity name from com.apple.calendars.MailAlarm to com.apple.calendars.DisplayAlarm in {
                description = "";
                owner =     (
                    "Event/p935"
            12/18/12 2:32:47.349 PM iCalExternalSync[2180]: [ICalExternalSync ]Encountered exception: [ISyncConcreteSession pushChangesFromRecord:withIdentifier:]: you can't change the record's entity name from com.apple.calendars.MailAlarm to com.apple.calendars.DisplayAlarm in {
                description = "";
                owner =     (
                    "Event/p935"
            } withStack: (
                      0   iCalExternalSync                    0x0000000105dfba60 iCalExternalSync + 125536
                      1   iCalExternalSync                    0x0000000105deaac9 iCalExternalSync + 56009
                      2   iCalExternalSync                    0x0000000105dfa694 iCalExternalSync + 120468
            12/18/12 2:32:47.350 PM iCalExternalSync[2180]: [ICalExternalSync ]NSException name:ISyncInvalidArgumentsException reason:[ISyncConcreteSession pushChangesFromRecord:withIdentifier:]: you can't change the record's entity name from com.apple.calendars.MailAlarm to com.apple.calendars.DisplayAlarm in {
                description = "";
                owner =     (
                    "Event/p935"
            12/18/12 2:32:47.351 PM SyncServer[2181]: [0x7fe7cbc0be00] |Server|Warning| lost connection 0x7fe7cf500f60 to com.apple.iCal
            12/18/12 2:46:46.763 PM WindowServer[122]: _CGXGetWindowOrderingGroup: Operation on a window 0x6d requiring rights 0x5 by caller Photoshop
            12/18/12 2:46:46.764 PM WindowServer[122]: _CGXGetWindowOrderingGroup: Operation on a window 0x6d requiring rights 0x5 by caller Photoshop
            12/18/12 2:46:46.765 PM WindowServer[122]: _CGXGetWindowOrderingGroup: Operation on a window 0x6d requiring rights 0x5 by caller Photoshop
            12/18/12 2:46:46.767 PM WindowServer[122]: _CGXGetWindowOrderingGroup: Operation on a window 0x6d requiring rights 0x5 by caller Photoshop
            12/18/12 2:46:46.784 PM WindowServer[122]: _CGXGetWindowOrderingGroup: Operation on a window 0x6d requiring rights 0x5 by caller Photoshop
            12/18/12 2:46:46.785 PM WindowServer[122]: _CGXGetWindowOrderingGroup: Operation on a window 0x6d requiring rights 0x5 by caller Photoshop
            12/18/12 2:46:46.786 PM WindowServer[122]: _CGXGetWindowOrderingGroup: Operation on a window 0x6d requiring rights 0x5 by caller Photoshop
            12/18/12 2:50:14.353 PM mdworker[2057]: CFPropertyListCreateFromXMLData(): Old-style plist parser: missing semicolon in dictionary on line 1. Parsing will be abandoned. Break on _CFPropertyListMissingSemicolon to debug.
            12/18/12 2:50:15.477 PM WindowServer[122]: _CGXGetWindowOrderingGroup: Operation on a window 0x72 requiring rights 0x5 by caller Photoshop
            12/18/12 2:50:15.478 PM WindowServer[122]: _CGXGetWindowOrderingGroup: Operation on a window 0x72 requiring rights 0x5 by caller Photoshop
            12/18/12 2:50:15.479 PM WindowServer[122]: _CGXGetWindowOrderingGroup: Operation on a window 0x72 requiring rights 0x5 by caller Photoshop
            12/18/12 2:50:15.480 PM WindowServer[122]: _CGXGetWindowOrderingGroup: Operation on a window 0x72 requiring rights 0x5 by caller Photoshop
            12/18/12 2:50:15.485 PM WindowServer[122]: _CGXGetWindowOrderingGroup: Operation on a window 0x72 requiring rights 0x5 by caller Photoshop
            12/18/12 2:52:18.000 PM kernel[0]: CODE SIGNING: cs_invalid_page(0x1000): p=2239[GoogleSoftwareUp] clearing CS_VALID
            12/18/12 2:59:57.663 PM quicklookd[2262]: [QL] _QLServerGetThumbnail: can't convert path to url
            12/18/12 2:59:57.730 PM com.apple.quicklook.satellite[2264]: bootstrap_look_up2 failed with 0x44c
            12/18/12 2:59:57.000 PM kernel[0]: Sandbox: sandboxd(2265) deny mach-lookup com.apple.coresymbolicationd
            12/18/12 2:59:58.394 PM sandboxd[2265]: ([2264]) QuickLookSatelli(2264) deny mach-lookup com.apple.PowerManagement.control
            12/18/12 2:59:58.406 PM sandboxd[2265]: ([2264]) QuickLookSatelli(2264) deny mach-lookup ATS Query Port 184
            12/18/12 2:59:58.418 PM sandboxd[2265]: ([2264]) QuickLookSatelli(2264) deny mach-lookup ATS Query Port 184
            12/18/12 2:59:58.432 PM sandboxd[2265]: ([2264]) QuickLookSatelli(2264) deny mach-lookup ATS Query Port 184
            12/18/12 2:59:58.444 PM sandboxd[2265]: ([2264]) QuickLookSatelli(2264) deny mach-lookup ATS Query Port 184
            12/18/12 2:59:58.455 PM sandboxd[2265]: ([2264]) QuickLookSatelli(2264) deny mach-lookup ATS Query Port 184
            12/18/12 3:00:03.213 PM quicklookd[2262]: ImageIO: CGImageReadSessionGetCachedImageBlockData *** CGImageReadSessionGetCachedImageBlockData: readSession [0x7fed032063a0] has bad readRef [0x7fed030055e0]
            12/18/12 3:00:03.229 PM quicklookd[2262]: ImageIO: CGImageReadSessionGetCachedImageBlockData *** CGImageReadSessionGetCachedImageBlockData: readSession [0x7fed07100ba0] has bad readRef [0x7fed05a03eb0]
            12/18/12 3:02:35.164 PM gconsync[2283]: [0x7fdb29c0a540] |ISyncManager|Warning| Could not retrieve ISyncClient with id com.apple.Keychain!
            12/18/12 3:02:39.347 PM com.apple.launchd[1]: (com.apple.softwareupdatecheck.periodic) Throttling respawn: Will start in 1 seconds
            12/18/12 3:02:47.606 PM Splashtop Streamer[195]: SRFEAT_NOTIFY_SERVER_CLOUD_NOTIFY_MSG
            12/18/12 3:02:47.606 PM Splashtop Streamer[195]: [ProcServerNotification] SRS_SERVER_RTN_INFO : [200][.srhbnotify.xml]
            12/18/12 3:02:47.608 PM Splashtop Streamer[195]:   receive backend string notify
            12/18/12 3:02:47.608 PM Splashtop Streamer[195]: -[CMXMLParser length]: unrecognized selector sent to instance 0x103850700
            12/18/12 3:02:47.609 PM Splashtop Streamer[195]: -[CMXMLParser length]: unrecognized selector sent to instance 0x103850700
            12/18/12 3:02:47.610 PM Splashtop Streamer[195]: (
                      10  CoreFoundation                      0x00007fff8bd7f220 __CFRunLoopRun + 1904
            12/18/12 3:02:47.610 PM Splashtop Streamer[195]:   receive backend string notify
            12/18/12 3:02:47.611 PM Splashtop Streamer[195]: -[CMXMLParser length]: unrecognized selector sent to instance 0x103850700
            12/18/12 3:02:47.612 PM Splashtop Streamer[195]: (
                      10  CoreFoundation                      0x00007fff8bd7edb4 __CFRunLoopRun + 772
                      13  HIToolbox                           0x00007fff8dcb1d84 ReceiveNextEventCommon + 166
            12/18/12 3:02:55.154 PM com.apple.quicklook.satellite[2292]: bootstrap_look_up2 failed with 0x44c
            12/18/12 3:02:55.551 PM quicklookd[2291]: [QL] _QLServerGetThumbnail: can't convert path to url
            12/18/12 3:02:55.613 PM quicklookd[2291]: [QL] _QLServerGetThumbnail: can't convert path to url
            12/18/12 3:02:55.000 PM kernel[0]: Sandbox: sandboxd(2293) deny mach-lookup com.apple.coresymbolicationd
            12/18/12 3:02:55.837 PM sandboxd[2293]: ([2292]) QuickLookSatelli(2292) deny mach-lookup com.apple.PowerManagement.control
            12/18/12 3:02:55.853 PM quicklookd[2291]: [QL] _QLServerGetThumbnail: can't convert path to url
            12/18/12 3:02:55.856 PM sandboxd[2293]: ([2292]) QuickLookSatelli(2292) deny mach-lookup ATS Query Port 184
            12/18/12 3:02:55.877 PM sandboxd[2293]: ([2292]) QuickLookSatelli(2292) deny mach-lookup ATS Query Port 184
            12/18/12 3:02:55.897 PM sandboxd[2293]: ([2292]) QuickLookSatelli(2292) deny mach-lookup ATS Query Port 184
            12/18/12 3:02:55.917 PM sandboxd[2293]: ([2292]) QuickLookSatelli(2292) deny mach-lookup ATS Query Port 184
            12/18/12 3:02:55.958 PM sandboxd[2293]: ([2292]) QuickLookSatelli(2292) deny mach-lookup ATS Query Port 184
            12/18/12 3:02:56.058 PM quicklookd[2291]: ImageIO: CGImageReadSessionGetCachedImageBlockData *** CGImageReadSessionGetCachedImageBlockData: readSession [0x7fe0d5006990] has bad readRef [0x7fe0d1c0b590]
            12/18/12 3:11:36.097 PM WindowServer[122]: _CGXGetWindowOrderingGroup: Operation on a window 0x9ef requiring rights 0x5 by caller Photoshop
            12/18/12 3:11:36.098 PM WindowServer[122]: _CGXGetWindowOrderingGroup: Operation on a window 0x9ef requiring rights 0x5 by caller Photoshop
            12/18/12 3:11:36.099 PM WindowServer[122]: _CGXGetWindowOrderingGroup: Operation on a window 0x9ef requiring rights 0x5 by caller Photoshop
            12/18/12 3:11:36.100 PM WindowServer[122]: _CGXGetWindowOrderingGroup: Operation on a window 0x9ef requiring rights 0x5 by caller Photoshop
            12/18/12 3:11:36.101 PM WindowServer[122]: _CGXGetWindowOrderingGroup: Operation on a window 0x9ef requiring rights 0x5 by caller Photoshop
            12/18/12 3:11:36.102 PM WindowServer[122]: _CGXGetWindowOrderingGroup: Operation on a window 0x9ef requiring rights 0x5 by caller Photoshop
            12/18/12 3:11:36.125 PM WindowServer[122]: _CGXGetWindowOrderingGroup: Operation on a window 0x9ef requiring rights 0x5 by caller Photoshop
            12/18/12 3:11:36.127 PM WindowServer[122]: _CGXGetWindowOrderingGroup: Operation on a window 0x9ef requiring rights 0x5 by caller Photoshop
            12/18/12 3:11:36.128 PM WindowServer[122]: _CGXGetWindowOrderingGroup: Operation on a window 0x9ef requiring rights 0x5 by caller Photoshop
            12/18/12 3:19:43.123 PM mdworker[2256]: CFPropertyListCreateFromXMLData(): Old-style plist parser: missing semicolon in dictionary on line 1. Parsing will be abandoned. Break on _CFPropertyListMissingSemicolon to debug.
            12/18/12 3:19:44.609 PM WindowServer[122]: _CGXGetWindowOrderingGroup: Operation on a window 0x6d requiring rights 0x5 by caller Photoshop
            12/18/12 3:27:51.913 PM librariand[2418]: MMe quota status changed: under quota
            12/18/12 3:27:51.940 PM Mail[2415]: Using V2 Layout
            12/18/12 3:27:52.564 PM com.apple.SecurityServer[15]: Session 100017 created
            12/18/12 3:34:27.349 PM WindowServer[122]: _CGXGetWindowOrderingGroup: Operation on a window 0x2ff requiring rights 0x5 by caller Photoshop
            12/18/12 3:34:27.350 PM WindowServer[122]: _CGXGetWindowOrderingGroup: Operation on a window 0x2ff requiring rights 0x5 by caller Photoshop
            12/18/12 3:34:27.351 PM WindowServer[122]: _CGXGetWindowOrderingGroup: Operation on a window 0x2ff requiring rights 0x5 by caller Photoshop
            12/18/12 3:34:27.352 PM WindowServer[122]: _CGXGetWindowOrderingGroup: Operation on a window 0x2ff requiring rights 0x5 by caller Photoshop
            12/18/12 3:34:27.353 PM WindowServer[122]: _CGXGetWindowOrderingGroup: Operation on a window 0x2ff requiring rights 0x5 by caller Photoshop
            12/18/12 3:34:27.354 PM WindowServer[122]: _CGXGetWindowOrderingGroup: Operation on a window 0x2ff requiring rights 0x5 by caller Photoshop
            12/18/12 3:34:27.355 PM WindowServer[122]: _CGXGetWindowOrderingGroup: Operation on a window 0x2ff requiring rights 0x5 by caller Photoshop
            12/18/12 3:34:27.356 PM WindowServer[122]: _CGXGetWindowOrderingGroup: Operation on a window 0x2ff requiring rights 0x5 by caller Photoshop
            12/18/12 3:34:27.357 PM WindowServer[122]: _CGXGetWindowOrderingGroup: Operation on a window 0x2ff requiring rights 0x5 by caller Photoshop
            12/18/12 3:34:27.358 PM WindowServer[122]: _CGXGetWindowOrderingGroup: Operation on a window 0x2ff requiring rights 0x5 by caller Photoshop
            12/18/12 3:44:58.409 PM mdworker[2426]: CFPropertyListCreateFromXMLData(): Old-style plist parser: missing semicolon in dictionary on line 1. Parsing will be abandoned. Break on _CFPropertyListMissingSemicolon to debug.
            12/18/12 3:45:00.743 PM WindowServer[122]: _CGXGetWindowOrderingGroup: Operation on a window 0x72 requiring rights 0x5 by caller Photoshop
            12/18/12 3:45:35.000 PM kernel[0]: MacAuthEvent en2   Auth result for: 00:0f:66:43:a4:fa  MAC AUTH succeeded
            12/18/12 3:45:35.000 PM kernel[0]: wlEvent: en2 en2 Link UP virtIf = 0
            12/18/12 3:45:35.000 PM kernel[0]: AirPort: RSN handshake complete on en2
            12/18/12 3:45:35.000 PM kernel[0]: wl0: Roamed or switched channel, reason #2, bssid 00:0f:66:43:a4:fa
            12/18/12 3:45:35.000 PM kernel[0]: en2: BSSID changed to 00:0f:66:43:a4:fa
            12/18/12 3:45:35.000 PM kernel[0]: en2::IO80211Interface::postMessage bssid changed
            12/18/12 3:48:12.925 PM com.apple.quicklook.satellite[2507]: bootstrap_look_up2 failed with 0x44c
            12/18/12 3:48:12.000 PM kernel[0]: Sandbox: sandboxd(2508) deny mach-lookup com.apple.coresymbolicationd
            12/18/12 3:48:12.966 PM sandboxd[2508]: ([2507]) QuickLookSatelli(2507) deny file-read-data /Volumes/Macintosh HD/IMACOM L2/IMA/Cequent/Laitner Files/Laitner - BC/includes/style.css
            12/18/12 3:48:12.971 PM sandboxd[2508]: ([2507]) QuickLookSatelli(2507) deny file-read-data /Volumes/Macintosh HD/IMACOM L2/IMA/Cequent/Laitner Files/Laitner - BC/i/logo.jpg
            12/18/12 3:48:12.975 PM sandboxd[2508]: ([2507]) QuickLookSatelli(2507) deny file-read-data /Volumes/Macintosh HD/IMACOM L2/IMA/Cequent/Laitner Files/Laitner - BC/i/menu.jpg
            12/18/12 3:48:12.979 PM sandboxd[2508]: ([2507]) QuickLookSatelli(2507) deny file-read-data /Volumes/Macintosh HD/IMACOM L2/IMA/Cequent/Laitner Files/Laitner - BC/i/cleaningtips.jpg
            12/18/12 3:48:12.983 PM sandboxd[2508]: ([2507]) QuickLookSatelli(2507) deny file-read-data /Volumes/Macintosh HD/IMACOM L2/IMA/Cequent/Laitner Files/Laitner - BC/i/clear.gif
            12/18/12 3:48:12.987 PM sandboxd[2508]: ([2507]) QuickLookSatelli(2507) deny file-read-data /Volumes/Macintosh HD/IMACOM L2/IMA/Cequent/Laitner Files/Laitner - BC/i/product_videos.gif
            12/18/12 3:48:12.991 PM sandboxd[2508]: ([2507]) QuickLookSatelli(2507) deny file-read-data /Volumes/Macintosh HD/IMACOM L2/IMA/Cequent/Laitner Files/Laitner - BC/i/search.jpg
            12/18/12 3:48:12.995 PM sandboxd[2508]: ([2507]) QuickLookSatelli(2507) deny file-read-data /Volumes/Macintosh HD/IMACOM L2/IMA/Cequent/Laitner Files/Laitner - BC/i/cequent-logo.jpg
            12/18/12 3:48:12.999 PM sandboxd[2508]: ([2507]) QuickLookSatelli(2507) deny file-read-data /Volumes/Macintosh HD/IMACOM L2/IMA/Cequent/Laitner Files/Laitner - BC/i/amazon.jpg
            12/18/12 3:48:13.003 PM sandboxd[2508]: ([2507]) QuickLookSatelli(2507) deny file-read-data /Volumes/Macintosh HD/IMACOM L2/IMA/Cequent/Laitner Files/Laitner - BC/i/secretary.jpg
            12/18/12 3:48:13.007 PM sandboxd[2508]: ([2507]) QuickLookSatelli(2507) deny file-read-data /Volumes/Macintosh HD/IMACOM L2/IMA/Cequent/Laitner Files/Laitner - BC/i/location/tn_map1.gif
            12/18/12 3:48:13.011 PM sandboxd[2508]: ([2507]) QuickLookSatelli(2507) deny file-read-data /Volumes/Macintosh HD/IMACOM L2/IMA/Cequent/Laitner Files/Laitner - BC/i/location/tn_map2.gif
            12/18/12 3:48:13.015 PM sandboxd[2508]: ([2507]) QuickLookSatelli(2507) deny file-read-data /Volumes/Macintosh HD/IMACOM L2/IMA/Cequent/Laitner Files/Laitner - BC/i/location/tn_map3.gif
            12/18/12 3:48:13.019 PM sandboxd[2508]: ([2507]) QuickLookSatelli(2507) deny file-read-data /Volumes/Macintosh HD/IMACOM L2/IMA/Cequent/Laitner Files/Laitner - BC/i/location/tn_map4.gif
            12/18/12 3:48:13.023 PM sandboxd[2508]: ([2507]) QuickLookSatelli(2507) deny file-read-data /Volumes/Macintosh HD/IMACOM L2/IMA/Cequent/Laitner Files/Laitner - BC/i/location/tn_building.gif
            12/18/12 3:48:13.027 PM sandboxd[2508]: ([2507]) QuickLookSatelli(2507) deny file-read-data /Volumes/Macintosh HD/IMACOM L2/IMA/Cequent/Laitner Files/Laitner - BC/i/location/map1.gif
            12/18/12 3:48:13.031 PM sandboxd[2508]: ([2507]) QuickLookSatelli(2507) deny file-read-data /Volumes/Macintosh HD/IMACOM L2/IMA/Cequent/Laitner Files/Laitner - BC/i/wmp_powerbrush.jpg
            12/18/12 3:48:13.034 PM sandboxd[2508]: ([2507]) QuickLookSatelli(2507) deny file-read-data /Volumes/Macintosh HD/IMACOM L2/IMA/Cequent/Laitner Files/Laitner - BC/i/usaflag2.jpg
            12/18/12 3:48:13.038 PM sandboxd[2508]: ([2507]) QuickLookSatelli(2507) deny file-read-data /Volumes/Macintosh HD/IMACOM L2/IMA/Cequent/Laitner Files/Laitner - BC/i/leftback.jpg
            12/18/12 3:48:13.043 PM sandboxd[2508]: ([2507]) QuickLookSatelli(2507) deny file-read-data /Volumes/Macintosh HD/IMACOM L2/IMA/Cequent/Laitner Files/Laitner - BC/i/redpixel.jpg
            12/18/12 3:48:13.676 PM sandboxd[2508]: ([2507]) QuickLookSatelli(2507) deny mach-lookup com.apple.PowerManagement.control
            12/18/12 3:51:01.000 PM kernel[0]: CODE SIGNING: cs_invalid_page(0x1000): p=2523[GoogleSoftwareUp] clearing CS_VALID
            12/18/12 3:56:07.000 PM kernel[0]: Adobe Photoshop  (map: 0xffffff80438571d0) triggered DYLD shared region unnest for map: 0xffffff80438571d0, region 0x7fff89800000->0x7fff89a00000. While not abnormal for debuggers, this increases system memory footprint until the target exits.
            12/18/12 3:56:07.000 PM kernel[0]: ALF: ifnet_get_address_list_family error 12
            12/18/12 3:56:15.458 PM mdworker[2426]: CFPropertyListCreateFromXMLData(): Old-style plist parser: missing semicolon in dictionary on line 1. Parsing will be abandoned. Break on _CFPropertyListMissingSemicolon to debug.
            12/18/12 3:56:21.460 PM WindowServer[122]: _CGXGetWindowOrderingGroup: Operation on a window 0xdd2 requiring rights 0x5 by caller Photoshop
            12/18/12 3:56:21.461 PM WindowServer[122]: _CGXGetWindowOrderingGroup: Operation on a window 0xdd2 requiring rights 0x5 by caller Photoshop
            12/18/12 3:56:21.462 PM WindowServer[122]: _CGXGetWindowOrderingGroup: Operation on a window 0xdd2 requiring rights 0x5 by caller Photoshop
            12/18/12 3:56:21.463 PM WindowServer[122]: _CGXGetWindowOrderingGroup: Operation on a window 0xdd2 requiring rights 0x5 by caller Photoshop
            12/18/12 3:56:21.468 PM WindowServer[122]: _CGXGetWindowOrderingGroup: Operation on a window 0xdd2 requiring rights 0x5 by caller Photoshop
            12/18/12 3:56:21.470 PM WindowServer[122]: _CGXGetWindowOrderingGroup: Operation on a window 0xdd2 requiring rights 0x5 by caller Photoshop
            12/18/12 3:56:21.471 PM WindowServer[122]: _CGXGetWindowOrderingGroup: Operation on a window 0xdd2 requiring rights 0x5 by caller Photoshop
            12/18/12 3:56:21.472 PM WindowServer[122]: _CGXGetWindowOrderingGroup: Operation on a window 0xdd2 requiring rights 0x5 by caller Photoshop
            12/18/12 3:56:21.473 PM WindowServer[122]: _CGXGetWindowOrderingGroup: Operation on a window 0xdd2 requiring rights 0x5 by caller Photoshop
            12/18/12 3:56:21.474 PM WindowServer[122]: _CGXGetWindowOrderingGroup: Operation on a window 0xdd2 requiring rights 0x5 by caller Photoshop
            12/18/12 3:56:21.475 PM WindowServer[122]: _CGXGetWindowOrderingGroup: Operation on a window 0xdd2 requiring rights 0x5 by caller Photoshop
            12/18/12 4:02:23.583 PM sandboxd[2585]: ([317]) WebProcess(317) deny mach-lookup ATS Query Port 184
            12/18/12 4:02:23.000 PM kernel[0]: Sandbox: sandboxd(2585) deny mach-lookup com.apple.coresymbolicationd
            12/18/12 4:02:23.773 PM sandboxd[2585]: ([317]) WebProcess(317) deny mach-lookup ATS Query Port 184
            12/18/12 4:02:35.230 PM gconsync[2589]: [0x7fa52240a540] |ISyncManager|Warning| Could not retrieve ISyncClient with id com.apple.Keychain!
            12/18/12 4:07:42.637 PM WindowServer[122]: CGXDisableUpdate: UI updates were forcibly disabled by application "Photoshop" for over 1.00 seconds. Server has re-enabled them.
            12/18/12 4:07:44.047 PM WindowServer[122]: reenable_update_for_connection: UI updates were finally reenabled by application "Photoshop" after 2.41 seconds (server forcibly re-enabled them after 1.00 seconds)
            12/18/12 4:18:59.881 PM Finder[1944]: --ImageKit Error: IKCacheDatabase::entryAtIndex - bad index
            12/18/12 4:31:53.828 PM com.apple.Preview.TrustedBookmarksService[2691]: Failure to de-serialize bookmark data file.
            12/18/12 4:44:32.895 PM WindowServer[122]: _CGXGetWindowOrderingGroup: Operation on a window 0x6d requiring rights 0x5 by caller Photoshop
            12/18/12 4:44:32.896 PM WindowServer[122]: _CGXGetWindowOrderingGroup: Operation on a window 0x6d requiring rights 0x5 by caller Photoshop
            12/18/12 4:46:00.000 PM kernel[0]: Adobe Photoshop  (map: 0xffffff8043858220) triggered DYLD shared region unnest for map: 0xffffff8043858220, region 0x7fff89800000->0x7fff89a00000. While not abnormal for debuggers, this increases system memory footprint until the target exits.
            12/18/12 4:49:39.991 PM Adobe Photoshop CS6[2081]: clip: empty path.
            12/18/12 4:49:39.992 PM Adobe Photoshop CS6[2081]: clip: empty path.
            12/18/12 4:49:45.000 PM kernel[0]: CODE SIGNING: cs_invalid_page(0x1000): p=2771[GoogleSoftwareUp] clearing CS_VALID
            12/18/12 4:50:00.268 PM librariand[2774]: MMe quota status changed: under quota
            12/18/12 4:50:00.288 PM Mail[2773]: Using V2 Layout
            12/18/12 4:50:00.729 PM com.apple.SecurityServer[15]: Session 100022 created
            12/18/12 4:50:01.325 PM Mail[2773]: [<_LibSasl2SASLClient: 0x7fdc2ea6c190> mechanism: PLAIN security layer: no] Failed to start the SASL connection
            12/18/12 4:50:04.689 PM Mail[2773]: *** -[IADomainCache init]: IA domains cache is out of date.
            12/18/12 4:50:07.359 PM Adobe Photoshop CS6[2081]: clip: empty path.
            12/18/12 4:50:07.361 PM Adobe Photoshop CS6[2081]: clip: empty path.
            12/18/12 4:50:08.420 PM com.apple.XType.FontHelper[2781]: FontHelper:  message received. (<dictionary: 0x7fcc1c900cc0> { count = 2, contents =
                      "query" => <string: 0x7fcc1c900e20> { length = 100, contents = "com_apple_ats_name_postscript == "arial" && kMDItemContentTypeTree != com.adobe.postscript-lwfn-font" }
                      "restricted" => <bool: 0x7fff766c6320>: true
            12/18/12 4:50:08.420 PM com.apple.XType.FontHelper[2781]: AutoActivation:  scopes (
                "/Library/Application Support/Apple/Fonts"
            12/18/12 4:50:08.452 PM com.apple.XType.FontHelper[2781]: FontHelper:  message received. (<dictionary: 0x7fcc1c904650> { count = 2, contents =
                      "query" => <string: 0x7fcc1c904160> { length = 100, contents = "com_apple_ats_name_postscript == "Arial" && kMDItemContentTypeTree != com.adobe.postscript-lwfn-font" }
            12/18/12 4:50:08.452 PM com.apple.XType.FontHelper[2781]: AutoActivation:  scopes (
            12/18/12 4:50:08.476 PM com.apple.XType.FontHelper[2781]: FontHelper:  message received. (<dictionary: 0x7fcc1fb00450> { count = 2, contents =
                      "query" => <string: 0x7fcc1fb005b0> { length = 101, contents = "com_apple_ats_name_postscript == "Tahoma" && kMDItemContentTypeTree != com.adobe.postscript-lwfn-font" }
            12/18/12 4:50:08.476 PM com.apple.XType.FontHelper[2781]: AutoActivation:  scopes (
            12/18/12 4:50:08.000 PM kernel[0]: Sandbox: sandboxd(2782) deny mach-lookup com.apple.coresymbolicationd
            12/18/12 4:50:09.177 PM sandboxd[2782]: ([2773]) Mail(2773) deny mach-lookup ATS Query Port 184
            12/18/12 4:50:09.195 PM sandboxd[2782]: ([2773]) Mail(2773) deny mach-lookup ATS Query Port 184
            12/18/12 4:50:10.357 PM sandboxd[2782]: ([2773]) Mail(2773) deny mach-lookup ATS Query Port 184
            12/18/12 4:50:10.375 PM sandboxd[2782]: ([2773]) Mail(2773) deny mach-lookup ATS Query Port 184
            12/18/12 4:50:10.392 PM sandboxd[2782]: ([2773]) Mail(2773) deny mach-lookup ATS Query Port 184
            12/18/12 4:50:10.410 PM sandboxd[2782]: ([2773]) Mail(2773) deny mach-lookup ATS Query Port 184
            12/18/12 4:50:10.428 PM sandboxd[2782]: ([2773]) Mail(2773) deny mach-lookup ATS Query Port 184
            12/18/12 4:50:10.445 PM sandboxd[2782]: ([2773]) Mail(2773) deny mach-lookup ATS Query Port 184
            12/18/12 4:50:10.487 PM sandboxd[2782]: ([2773]) Mail(2773) deny mach-lookup ATS Query Port 184
            12/18/12 4:50:10.508 PM sandboxd[2782]: ([2773]) Mail(2773) deny mach-lookup ATS Query Port 184
            12/18/12 4:50:13.062 PM sandboxd[2782]: ([2773]) Mail(2773) deny mach-lookup ATS Query Port 184
            12/18/12 4:50:13.082 PM sandboxd[2782]: ([2773]) Mail(2773) deny mach-lookup ATS Query Port 184
            12/18/12 4:50:13.102 PM sandboxd[2782]: ([2773]) Mail(2773) deny mach-lookup ATS Query Port 184
            12/18/12 4:50:13.122 PM sandboxd[2782]: ([2773]) Mail(2773) deny mach-lookup ATS Query Port 184
            12/18/12 4:50:13.142 PM sandboxd[2782]: ([2773]) Mail(2773) deny mach-lookup ATS Query Port 184
            12/18/12 4:50:13.162 PM sandboxd[2782]: ([2773]) Mail(2773) deny mach-lookup ATS Query Port 184
            12/18/12 4:50:13.180 PM sandboxd[2782]: ([2773]) Mail(2773) deny mach-lookup ATS Query Port 184
            12/18/12 4:50:13.198 PM sandboxd[2782]: ([2773]) Mail(2773) deny mach-lookup ATS Query Port 184
            12/18/12 4:50:37.750 PM iCalExternalSync[2785]: [0x7fc740c0e460] |Miscellaneous|Error| SyncServices precondition failure in [ISyncConcreteSession pushChangesFromRecord:withIdentifier:]: you can't change the record's entity name from com.apple.calendars.MailAlarm to com.apple.calendars.DisplayAlarm in {
                description = "";
                owner =     (
                    "Event/p935"
            12/18/12 4:50:37.751 PM iCalExternalSync[2785]: [ICalExternalSync ]Encountered exception: [ISyncConcreteSession pushChangesFromRecord:withIdentifier:]: you can't change the record's entity name from com.apple.calendars.MailAlarm to com.apple.calendars.DisplayAlarm in {
                description = "";
                owner =     (
                    "Event/p935"
            } withStack: (
                      0   iCalExternalSync                    0x000000010859aa60 iCalExternalSync + 125536
                      1   iCalExternalSync                    0x0000000108589ac9 iCalExternalSync + 56009
                      2   iCalExternalSync                    0x0000000108599694 iCalExternalSync + 120468
            12/18/12 4:50:37.752 PM iCalExternalSync[2785]: [ICalExternalSync ]NSException name:ISyncInvalidArgumentsException reason:[ISyncConcreteSession pushChangesFromRecord:withIdentifier:]: you can't change the record's entity name from com.apple.calendars.MailAlarm to com.apple.calendars.DisplayAlarm in {
                description = "";
                owner =     (
                    "Event/p935"
            12/18/12 4:50:37.753 PM SyncServer[2780]: [0x7fe47840be00] |Server|Warning| lost connection 0x7fe479408730 to com.apple.iCal
            12/18/12 4:57:12.010 PM WindowServer[122]: _CGXGetWindowOrderingGroup: Operation on a window 0x65 requiring rights 0x5 by caller Photoshop
            12/18/12 4:57:12.011 PM WindowServer[122]: _CGXGetWindowOrderingGroup: Operation on a window 0x65 requiring rights 0x5 by caller Photoshop
            12/18/12 4:57:12.013 PM WindowServer[122]: _CGXGetWindowOrderingGroup: Operation on a window 0x65 requiring rights 0x5 by caller Photoshop
            12/18/12 4:57:12.014 PM WindowServer[122]: _CGXGetWindowOrderingGroup: Operation on a window 0x65 requiring rights 0x5 by caller Photoshop
            12/18/12 4:57:12.015 PM WindowServer[122]: _CGXGetWindowOrderingGroup: Operation on a window 0x65 requiring rights 0x5 by caller Photoshop
            12/18/12 4:58:45.477 PM quicklookd[2811]: ImageIO: CGImageReadSessionGetCachedImageBlockData *** CGImageReadSessionGetCachedImageBlockData: readSession [0x7fc0f9804940] has bad readRef [0x7fc0f8420f70]
            12/18/12 5:02:35.353 PM gconsync[2828]: [0x7f997bc0a540] |ISyncManager|Warning| Could not retrieve ISyncClient with id com.apple.Keychain!
            12/18/12 5:02:47.502 PM Splashtop Streamer[195]: SRFEAT_NOTIFY_SERVER_CLOUD_NOTIFY_MSG
            12/18/12 5:02:47.502 PM Splashtop Streamer[195]: [ProcServerNotification] SRS_SERVER_RTN_INFO : [200][.srhbnotify.xml]
            12/18/12 5:02:47.503 PM Splashtop Streamer[195]:   receive backend string notify
            12/18/12 5:02:47.504 PM Splashtop Streamer[195]: -[CMXMLParser length]: unrecognized selector sent to instance 0x106029cd0
            12/18/12 5:02:47.505 PM Splashtop Streamer[195]: (
            12/18/12 5:02:47.506 PM Splashtop Streamer[195]:   receive backend string notify
            12/18/12 5:02:47.506 PM Splashtop Streamer[195]: -[CMXMLParser length]: unrecognized selector sent to instance 0x106029cd0
            12/18/12 5:02:47.507 PM Splashtop Streamer[195]: (
            12/18/12 5:25:22.928 PM WindowServer[122]: Created shield window 0xfd3 for display 0x04241064
            12/18/12 5:25:22.928 PM WindowServer[122]: device_generate_desktop_screenshot: authw 0x0(0), shield 0x0(0)
            12/18/12 5:25:22.946 PM WindowServer[122]: device_generate_lock_screen_screenshot: authw 0x0(0), shield 0x0(0)
            12/18/12 5:30:23.080 PM helpd[648]: Could not find access page in directory /Applications/Final Cut Pro.app/Contents/Resources/English.lproj/Final Cut Pro Help
            12/18/12 5:30:23.081 PM helpd[648]: Could not find access page in directory /Applications/Final Cut Pro.app/Contents/Resources/English.lproj/Final Cut Pro Help
            12/18/12 5:30:33.117 PM helpd[648]: CFPropertyListCreateFromXMLData(): Old-style plist parser: missing semicolon in dictionary on line 1. Parsing will be abandoned. Break on _CFPropertyListMissingSemicolon to debug.
            12/18/12 5:30:33.118 PM helpd[648]: CFPropertyListCreateFromXMLData(): Old-style plist parser: missing semicolon in dictionary on line 1. Parsing will be abandoned. Break on _CFPropertyListMissingSemicolon to debug.
            12/18/12 5:31:38.181 PM WindowServer[122]: handle_will_sleep_auth_and_shield_windows: no lock state data
            12/18/12 5:33:03.978 PM GoogleTalkPlugin[2931]: objc[2931]: Class MacCocoaSocketServerHelper is implemented in both /Library/Application Support/Google/GoogleTalkPlugin.app/Contents/MacOS/GoogleTalkPlugin and /Library/Application Support/Google/GoogleTalkPlugin.app/Contents/Frameworks/libgoogletalkremoting.dylib. One of the two will be used. Which one is undefined.
            12/18/12 5:41:49.848 PM Finder[1944]: --ImageKit Error: IKCacheDatabase::entryAtIndex - bad index
            12/18/12 5:44:38.000 PM kernel[0]: MacAuthEvent en2   Auth result for: 00:0f:66:43:a4:fa  MAC AUTH succeeded
            12/18/12 5:44:38.000 PM kernel[0]: wlEvent: en2 en2 Link UP virtIf = 0
            12/18/12 5:44:38.000 PM kernel[0]: AirPort: RSN handshake complete on en2
            12/18/12 5:44:38.000 PM kernel[0]: wl0: Roamed or switched channel, reason #2, bssid 00:0f:66:43:a4:fa
            12/18/12 5:44:38.000 PM kernel[0]: en2: BSSID changed to 00:0f:66:43:a4:fa
            12/18/12 5:44:38.000 PM kernel[0]: en2::IO80211Interface::postMessage bssid changed
            12/18/12 5:47:01.079 PM CalendarAgent[176]: Unexpected EOF, returning last token as fallback
            12/18/12 5:47:35.764 PM iCalExternalSync[2973]: [0x7fb3e040e460] |Miscellaneous|Error| SyncServices precondition failure in [ISyncConcreteSession pushChangesFromRecord:withIdentifier:]: you can't change the record's entity name from com.apple.calendars.MailAlarm to com.apple.calendars.DisplayAlarm in {
                description = "";
                owner =     (
                    "Event/p935"
            12/18/12 5:47:35.765 PM iCalExternalSync[2973]: [ICalExternalSync ]Encountered exception: [ISyncConcreteSession pushChangesFromRecord:withIdentifier:]: you can't change the record's entity name from com.apple.calendars.MailAlarm to com.apple.calendars.DisplayAlarm in {
                description = "";
                owner =     (
                    "Event/p935"
            } withStack: (
                      0   iCalExternalSync                    0x00000001037e0a60 iCalExternalSync + 125536
                      1   iCalExternalSync                    0x00000001037cfac9 iCalExternalSync + 56009
                      2   iCalExternalSync                    0x00000001037df694 iCalExternalSync + 120468
            12/18/12 5:47:35.765 PM iCalExternalSync[2973]: [ICalExternalSync ]NSException name:ISyncInvalidArgumentsException reason:[ISyncConcreteSession pushChangesFromRecord:withIdentifier:]: you can't change the record's entity name from com.apple.calendars.MailAlarm to com.apple.calendars.DisplayAlarm in {
                description = "";
                owner =     (
                    "Event/p935"
            12/18/12 5:47:35.766 PM SyncServer[2975]: [0x7fbd49c0be00] |Server|Warning| lost connection 0x7fbd4c300f30 to com.apple.iCal
            12/18/12 5:48:28.000 PM kernel[0]: CODE SIGNING: cs_invalid_page(0x1000): p=2978[GoogleSoftwareUp] clearing CS_VALID
            12/18/12 5:50:34.000 PM kernel[0]: Sandbox: sandboxd(2988) deny mach-lookup com.apple.coresymbolicationd
            12/18/12 5:50:34.358 PM sandboxd[2988]: ([317]) WebProcess(317) deny mach-lookup ATS Query Port 184
            12/18/12 5:50:34.379 PM sandboxd[2988]: ([317]) WebProcess(317) deny mach-lookup ATS Query Port 184
            12/18/12 6:00:48.174 PM WindowServer[122]: Created shield window 0xfe1 for display 0x04241064
            12/18/12 6:00:48.174 PM WindowServer[122]: device_generate_desktop_screenshot: authw 0x0(0), shield 0x0(0)
            12/18/12 6:00:48.192 PM WindowServer[122]: device_generate_lock_screen_screenshot: authw 0x0(0), shield 0x0(0)
            12/18/12 6:02:35.409 PM gconsync[3026]: [0x7fe56040a540] |ISyncManager|Warning| Could not retrieve ISyncClient with id com.apple.Keychain!
            12/18/12 6:05:48.267 PM helpd[3034]: Could not find access page in directory /Applications/Final Cut Pro.app/Contents/Resources/English.lproj/Final Cut Pro Help
            12/18/12 6:05:48.268 PM helpd[3034]: Could not find access page in directory /Applications/Final Cut Pro.app/Contents/Resources/English.lproj/Final Cut Pro Help
            12/18/12 6:05:58.287 PM helpd[3034]: CFPropertyListCreateFromXMLData(): Old-style plist parser: missing semicolon in dictionary on line 1. Parsing will be abandoned. Break on _CFPropertyListMissingSemicolon to debug.
            12/18/12 6:05:58.288 PM helpd[3034]: CFPropertyListCreateFromXMLData(): Old-style plist parser: missing semicolon in dictionary on line 1. Parsing will be abandoned. Break on _CFPropertyListMissingSemicolon to debug.
            12/18/12 6:05:58.289 PM helpd[3034]: CFPropertyListCreateFromXMLData(): Old-style plist parser: missing semicolon in dictionary on line 1. Parsing will be abandoned. Break on _CFPropertyListMissingSemicolon to debug.
            12/18/12 6:28:08.712 PM helpd[3109]: Could not find access page in directory /Applications/Final Cut Pro.app/Contents/Resources/English.lproj/Final Cut Pro Help
            12/18/12 6:28:08.713 PM helpd[3109]: Could not find access page in directory /Applications/Final Cut Pro.app/Contents/Resources/English.lproj/Final Cut Pro Help
            12/18/12 6:28:18.733 PM helpd[3109]: CFPropertyListCreateFromXMLData(): Old-style plist parser: missing semicolon in dictionary on line 1. Parsing will be abandoned. Break on _CFPropertyListMissingSemicolon to debug.
            12/18/12 6:28:18.734 PM helpd[3109]: CFPropertyListCreateFromXMLData(): Old-style plist parser: missing semicolon in dictionary on line 1. Parsing will be abandoned. Break on _CFPropertyListMissingSemicolon to debug.
            12/18/12 6:28:18.735 PM helpd[3109]: CFPropertyListCreateFromXMLData(): Old-style plist parser: missing semicolon in dictionary on line 1. Parsing will be abandoned. Break on _CFPropertyListMissingSemicolon to debug.
            12/18/12 6:30:09.477 PM WindowServer[122]: handle_will_sleep_auth_and_shield_windows: no lock state data
            12/18/12 6:35:26.802 PM com.apple.launchd.peruser.501[145]: ([0x0-0x341341].com.microsoft.error_reporting[3136]) Job appears to have crashed: Bus error: 10
            12/18/12 6:35:26.942 PM ReportCrash[3139]: Saved crash report for Microsoft Error Reporting[3136] version 2.2.4 (2.2.4) to /Users/Imacom/Library/Logs/DiagnosticReports/Microsoft Error Reporting_2012-12-18-183526_Mac-Pro-Imacom-5.crash
            12/18/12 6:41:58.898 PM System Preferences[3167]: Cannot setMachineString without first being authenticated
            12/18/12 6:41:58.944 PM System Preferences[3167]: *** WARNING: -[NSImage compositeToPoint:operation:] is deprecated in MacOSX 10.8 and later. Please use -[NSImage drawAtPoint:fromRect:operation:fraction:] instead.
            12/18/12 6:41:58.946 PM System Preferences[3167]: *** WARNING: -[NSImage compositeToPoint:fromRect:operation:] is deprecated in MacOSX 10.8 and later. Please use -[NSImage drawAtPoint:fromRect:operation:fraction:] instead.
            12/18/12 6:41:58.949 PM System Preferences[3167]: *** WARNING: -[NSImage compositeToPoint:operation:fraction:] is deprecated in MacOSX 10.8 and later. Please use -[NSImage drawAtPoint:fromRect:operation:fraction:] instead.
            12/18/12 6:41:58.950 PM System Preferences[3167]: *** WARNING: -[NSImage compositeToPoint:fromRect:operation:fraction:] is deprecated in MacOSX 10.8 and later. Please use -[NSImage drawAtPoint:fromRect:operation:fraction:] instead.
            12/18/12 6:43:37.000 PM kernel[0]: Sandbox: sandboxd(3180) deny mach-lookup com.apple.coresymbolicationd
            12/18/12 6:43:38.125 PM sandboxd[3180]: ([317]) WebProcess(317) deny mach-lookup ATS Query Port 184
            12/18/12 6:43:38.138 PM sandboxd[3180]: ([317]) WebProcess(317) deny mach-lookup ATS Query Port 184
            12/18/12 6:43:43.062 PM PluginProcess[2932]: 2932: CFNetwork internal error (0xc01a:/SourceCache/CFNetwork/CFNetwork-596.2.3/HTTP/HTTPReadStream.cpp:310)
            12/18/12 6:43:43.083 PM PluginProcess[2932]: 2932: CFNetwork internal error (0xc01a:/SourceCache/CFNetwork/CFNetwork-596.2.3/HTTP/HTTPReadStream.cpp:310)
            12/18/12 6:43:43.104 PM PluginProcess[2932]: 2932: CFNetwork internal error (0xc01a:/SourceCache/CFNetwork/CFNetwork-596.2.3/HTTP/HTTPReadStream.cpp:310)
            12/18/12 6:43:43.126 PM PluginProcess[2932]: 2932: CFNetwork internal error (0xc01a:/SourceCache/CFNetwork/CFNetwork-596.2.3/HTTP/HTTPReadStream.cpp:310)
            12/18/12 6:43:43.147 PM PluginProcess[2932]: 2932: CFNetwork internal error (0xc01a:/SourceCache/CFNetwork/CFNetwork-596.2.3/HTTP/HTTPReadStream.cpp:310)
            12/18/12 6:43:43.168 PM PluginProcess[2932]: 2932: CFNetwork internal error (0xc01a:/SourceCache/CFNetwork/CFNetwork-596.2.3/HTTP/HTTPReadStream.cpp:310)
            12/18/12 6:43:43.189 PM PluginProcess[2932]: 2932: CFNetwork internal error (0xc01a:/SourceCache/CFNetwork/CFNetwork-596.2.3/HTTP/HTTPReadStream.cpp:310)
            12/18/12 6:43:43.211 PM PluginProcess[2932]: 2932: CFNetwork internal error (0xc01a:/SourceCache/CFNetwork/CFNetwork-596.2.3/HTTP/HTTPReadStream.cpp:310)
            12/18/12 6:43:43.232 PM PluginProcess[2932]: 2932: CFNetwork internal error (0xc01a:/SourceCache/CFNetwork/CFNetwork-596.2.3/HTTP/HTTPReadStream.cpp:310)
            12/18/12 6:43:43.252 PM PluginProcess[2932]: 2932: CFNetwork internal error (0xc01a:/SourceCache/CFNetwork/CFNetwork-596.2.3/HTTP/HTTPReadStream.cpp:310)
            12/18/12 6:43:43.274 PM PluginProcess[2932]: 2932: CFNetwork internal error (0xc01a:/SourceCache/CFNetwork/CFNetwork-596.2.3/HTTP/HTTPReadStream.cpp:310)
            12/18/12 6:43:43.295 PM PluginProcess[2932]: 2932: CFNetwork internal error (0xc01a:/SourceCache/CFNetwork/CFNetwork-596.2.3/HTTP/HTTPReadStream.cpp:310)
            12/18/12 6:43:43.316 PM PluginProcess[2932]: 2932: CFNetwork internal error (0xc01a:/SourceCache/CFNetwork/CFNetwork-596.2.3/HTTP/HTTPReadStream.cpp:310)
            12/18/12 6:43:43.336 PM PluginProcess[2932]: 2932: CFNetwork internal error (0xc01a:/SourceCache/CFNetwork/CFNetwork-596.2.3/HTTP/HTTPReadStream.cpp:310)
            12/18/12 6:43:43.357 PM PluginProcess[2932]: 2932: CFNetwork internal error (0xc01a:/SourceCache/CFNetwork/CFNetwork-596.2.3/HTTP/HTTPReadStream.cpp:310)
            12/18/12 6:43:43.378 PM PluginProcess[2932]: 2932: CFNetwork internal error (0xc01a:/SourceCache/CFNetwork/CFNetwork-596.2.3/HTTP/HTTPReadStream.cpp:310)
            12/18/12 6:43:43.415 PM PluginProcess[2932]: 2932: CFNetwork internal error (0xc01a:/SourceCache/CFNetwork/CFNetwork-596.2.3/HTTP/HTTPReadStream.cpp:310)
            12/18/12 6:43:43.436 PM PluginProcess[2932]: 2932: CFNetwork internal error (0xc01a:/SourceCache/CFNetwork/CFNetwork-596.2.3/HTTP/HTTPReadStream.cpp:310)
            12/18/12 6:43:43.457 PM PluginProcess[2932]: 2932: CFNetwork internal error (0xc01a:/SourceCache/CFNetwork/CFNetwork-596.2.3/HTTP/HTTPReadStream.cpp:310)
            12/18/12 6:43:43.478 PM PluginProcess[2932]: 2932: CFNetwork internal error (0xc01a:/SourceCache/CFNetwork/CFNetwork-596.2.3/HTTP/HTTPReadStream.cpp:310)
            12/18/12 6:43:43.499 PM PluginProcess[2932]: 2932: CFNetwork internal error (0xc01a:/SourceCache/CFNetwork/CFNetwork-596.2.3/HTTP/HTTPReadStream.cpp:310)
            12/18/12 6:43:43.520 PM PluginProcess[2932]: 2932: CFNetwork internal error (0xc01a:/SourceCache/CFNetwork/CFNetwork-596.2.3/HTTP/HTTPReadStream.cpp:310)
            12/18/12 6:43:43.541 PM PluginProcess[2932]: 2932: CFNetwork internal error (0xc01a:/SourceCache/CFNetwork/CFNetwork-596.2.3/HTTP/HTTPReadStream.cpp:310)
            12/18/12 6:43:43.562 PM PluginProcess[2932]: 2932: CFNetwork internal error (0xc01a:/SourceCache/CFNetwork/CFNetwork-596.2.3/HTTP/HTTPReadStream.cpp:310)
            12/18/12 6:43:43.584 PM PluginProcess[2932]: 2932: CFNetwork internal error (0xc01a:/SourceCache/CFNetwork/CFNetwork-596.2.3/HTTP/HTTPReadStream.cpp:310)
            12/18/12 6:43:43.605 PM PluginProcess[2932]: 2932: CFNetwork internal error (0xc01a:/SourceCache/CFNetwork/CFNetwork-596.2.3/HTTP/HTTPReadStream.cpp:310)
            12/18/12 6:43:43.626 PM PluginProcess[2932]: 2932: CFNetwork internal error (0xc01a:/SourceCache/CFNetwork/CFNetwork-596.2.3/HTTP/HTTPReadStream.cpp:310)
            12/18/12 6:43:43.647 PM PluginProcess[2932]: 2932: CFNetwork internal error (0xc01a:/SourceCache/CFNetwork/CFNetwork-596.2.3/HTTP/HTTPReadStream.cpp:310)
            12/18/12 6:43:43.669 PM PluginProcess[2932]: 2932: CFNetwork internal error (0xc01a:/SourceCache/CFNetwork/CFNetwork-596.2.3/HTTP/HTTPReadStream.cpp:310)
            12/18/12 6:43:43.690 PM PluginProcess[2932]: 2932: CFNetwork internal error (0xc01a:/SourceCache/CFNetwork/CFNetwork-596.2.3/HTTP/HTTPReadStream.cpp:310)
            12/18/12 6:43:43.711 PM PluginProcess[2932]: 2932: CFNetwork internal error (0xc01a:/SourceCache/CFNetwork/CFNetwork-596.2.3/HTTP/HTTPReadStream.cpp:310)
            12/18/12 6:43:43.733 PM PluginProcess[2932]: 2932: CFNetwork internal error (0xc01a:/SourceCache/CFNetwork/CFNetwork-596.2.3/HTTP/HTTPReadStream.cpp:310)
            12/18/12 6:43:43.775 PM PluginProcess[2932]: 2932: CFNetwork internal error (0xc01a:/SourceCache/CFNetwork/CFNetwork-596.2.3/HTTP/HTTPReadStream.cpp:310)
            12/18/12 6:43:43.796 PM PluginProcess[2932]: 2932: CFNetwork internal error (0xc01a:/SourceCache/CFNetwork/CFNetwork-596.2.3/HTTP/HTTPReadStream.cpp:310)
            12/18/12 6:43:43.943 PM PluginProcess[2932]: 2932: CFNetwork internal error (0xc01a:/SourceCache/CFNetwork/CFNetwork-596.2.3/HTTP/HTTPReadStream.cpp:310)
            12/18/12 6:43:43.965 PM PluginProcess[2932]: 2932: CFNetwork internal error (0xc01a:/SourceCache/CFNetwork/CFNetwork-596.2.3/HTTP/HTTPReadStream.cpp:310)
            12/18/12 6:43:43.986 PM PluginProcess[2932]: 2932: CFNetwork internal error (0xc01a:/SourceCache/CFNetwork/CFNetwork-596.2.3/HTTP/HTTPReadStream.cpp:310)
            12/18/12 6:43:44.068 PM PluginProcess[2932]: 2932: CFNetwork internal error (0xc01a:/SourceCache/CFNetwork/CFNetwork-596.2.3/HTTP/HTTPReadStream.cpp:310)
            12/18/12 6:43:44.132 PM PluginProcess[2932]: 2932: CFNetwork internal error (0xc01a:/SourceCache/CFNetwork/CFNetwork-596.2.3/HTTP/HTTPReadStream.cpp:310)
            12/18/12 6:43:44.153 PM PluginProcess[2932]: 2932: CFNetwork internal error (0xc01a:/SourceCache/CFNetwork/CFNetwork-596.2.3/HTTP/HTTPReadStream.cpp:310)
            12/18/12 6:43:44.174 PM PluginProcess[2932]: 2932: CFNetwork internal error (0xc01a:/SourceCache/CFNetwork/CFNetwork-596.2.3/HTTP/HTTPReadStream.cpp:310)
            12/18/12 6:43:44.195 PM PluginProcess[2932]: 2932: CFNetwork internal error (0xc01a:/SourceCache/CFNetwork/CFNetwork-596.2.3/HTTP/HTTPReadStream.cpp:310)
            12/18/12 6:43:44.572 PM PluginProcess[2932]: 2932: CFNetwork internal error (0xc01a:/SourceCache/CFNetwork/CFNetwork-596.2.3/HTTP/HTTPReadStream.cpp:310)
            12/18/12 6:43:44.593 PM PluginProcess[2932]: 2932: CFNetwork internal error (0xc01a:/SourceCache/CFNetwork/CFNetwork-596.2.3/HTTP/HTTPReadStream.cpp:310)
            12/18/12 6:43:44.782 PM PluginProcess[2932]: 2932: CFNetwork internal error (0xc01a:/SourceCache/CFNetwork/CFNetwork-596.2.3/HTTP/HTTPReadStream.cpp:310)
            12/18/12 6:43:44.885 PM PluginProcess[2932]: 2932: CFNetwork internal error (0xc01a:/SourceCache/CFNetwork/CFNetwork-596.2.3/HTTP/HTTPReadStream.cpp:310)
            12/18/12 6:43:45.095 PM PluginProcess[2932]: 2932: CFNetwork internal error (0xc01a:/SourceCache/CFNetwork/CFNetwork-596.2.3/HTTP/HTTPReadStream.cpp:310)
            12/18/12 6:43:45.324 PM PluginProcess[2932]: 2932: CFNetwork internal error (0xc01a:/SourceCache/CFNetwork/CFNetwork-596.2.3/HTTP/HTTPReadStream.cpp:310)
            12/18/12 6:43:45.345 PM PluginProcess[2932]: 2932: CFNetwork internal error (0xc01a:/SourceCache/CFNetwork/CFNetwork-596.2.3/HTTP/HTTPReadStream.cpp:310)
            12/18/12 6:43:45.741 PM PluginProcess[2932]: 2932: CFNetwork internal error (0xc01a:/SourceCache/CFNetwork/CFNetwork-596.2.3/HTTP/HTTPReadStream.cpp:310)
            12/18/12 6:43:45.762 PM PluginProcess[2932]: 2932: CFNetwork internal error (0xc01a:/SourceCache/CFNetwork/CFNetwork-596.2.3/HTTP/HTTPReadStream.cpp:310)
            12/18/12 6:43:46.491 PM PluginProcess[2932]: 2932: CFNetwork internal error (0xc01a:/SourceCache/CFNetwork/CFNetwork-596.2.3/HTTP/HTTPReadStream.cpp:310)
            12/18/12 6:43:46.512 PM PluginProcess[2932]: 2932: CFNetwork internal error (0xc01a:/SourceCache/CFNetwork/CFNetwork-596.2.3/HTTP/HTTPReadStream.cpp:310)
            12/18/12 6:43:46.534 PM PluginProcess[2932]: 2932: CFNetwork internal error (0xc01a:/SourceCache/CFNetwork/CFNetwork-596.2.3/HTTP/HTTPReadStream.cpp:310)
            12/18/12 6:43:46.555 PM PluginProcess[2932]: 2932: CFNetwork internal error (0xc01a:/SourceCache/CFNetwork/CFNetwork-596.2.3/HTTP/HTTPReadStream.cpp:310)
            12/18/12 6:43:46.576 PM PluginProcess[2932]: 2932: CFNetwork internal error (0xc01a:/SourceCache/CFNetwork/CFNetwork-596.2.3/HTTP/HTTPReadStream.cpp:310)
            12/18/12 6:43:46.596 PM PluginProcess[2932]: 2932: CFNetwork internal error (0xc01a:/SourceCache/CFNetwork/CFNetwork-596.2.3/HTTP/HTTPReadStream.cpp:310)
            12/18/12 6:43:47.426 PM PluginProcess[2932]: 2932: CFNetwork internal error (0xc01a:/SourceCache/CFNetwork/CFNetwork-596.2.3/HTTP/HTTPReadStream.cpp:310)
            12/18/12 6:43:47.447 PM PluginProcess[2932]: 2932: CFNetwork internal error (0xc01a:/SourceCache/CFNetwork/CFNetwork-596.2.3/HTTP/HTTPReadStream.cpp:310)
            12/18/12 6:43:47.468 PM PluginProcess[2932]: 2932: CFNetwork internal error (0xc01a:/SourceCache/CFNetwork/CFNetwork-596.2.3/HTTP/HTTPReadStream.cpp:310)
            12/18/12 6:43:47.490 PM PluginProcess[2932]: 2932: CFNetwork internal error (0xc01a:/SourceCache/CFNetwork/CFNetwork-596.2.3/HTTP/HTTPReadStream.cpp:310)
            12/18/12 6:43:47.510 PM PluginProcess[2932]: 2932: CFNetwork internal error (0xc01a:/SourceCache/CFNetwork/CFNetwork-596.2.3/HTTP/HTTPReadStream.cpp:310)
            12/18/12 6:43:47.532 PM PluginProcess[2932]: 2932: CFNetwork internal error (0xc01a:/SourceCache/CFNetwork/CFNetwork-596.2.3/HTTP/HTTPReadStream.cpp:310)
            12/18/12 6:43:47.553 PM PluginProcess[2932]: 2932: CFNetwork internal error (0xc01a:/SourceCache/CFNetwork/CFNetwork-596.2.3/HTTP/HTTPReadStream.cpp:310)
            12/18/12 6:43:47.574 PM PluginProcess[2932]: 2932: CFNetwork internal error (0xc01a:/SourceCache/CFNetwork/CFNetwork-596.2.3/HTTP/HTTPReadStream.cpp:310)
            12/18/12 6:43:47.595 PM PluginProcess[2932]: 2932: CFNetwork internal error (0xc01a:/SourceCache/CFNetwork/CFNetwork-596.2.3/HTTP/HTTPReadStream.cpp:310)
            12/18/12 6:43:47.617 PM PluginProcess[2932]: 2932: CFNetwork internal error (0xc01a:/SourceCache/CFNetwork/CFNetwork-596.2.3/HTTP/HTTPReadStream.cpp:310)
            12/18/12 6:43:47.638 PM PluginProcess[2932]: 2932: CFNetwork internal error (0xc01a:/SourceCache/CFNetwork/CFNetwork-596.2.3/HTTP/HTTPReadStream.cpp:310)
            12/18/12 6:43:58.133 PM login[3187]: USER_PROCESS: 3187 ttys000
            12/18/12 6:45:38.047 PM mdworker[3157]: CFPropertyListCreateFromXMLData(): Old-style plist parser: missing semicolon in dictionary on line 1. Parsing will be abandoned. Break on _CFPropertyListMissingSemicolon to debug.
            12/18/12 6:46:45.479 PM mdworker[3157]: CFPropertyListCreateFromXMLData(): Old-style plist parser: missing semicolon in dictionary on line 1. Parsing will be abandoned. Break on _CFPropertyListMissingSemicolon to debug.
            12/18/12 6:46:49.136 PM Adobe Bridge CS6[3216]: CFPropertyListCreateFromXMLData(): Old-style plist parser: missing semicolon in dictionary on line 1. Parsing will be abandoned. Break on _CFPropertyListMissingSemicolon to debug.
            12/18/12 6:47:11.000 PM kernel[0]: CODE SIGNING: cs_invalid_page(0x1000): p=3220[GoogleSoftwareUp] clearing CS_VALID
            12/18/12 6:47:53.595 PM fseventsd[50]: Logging disabled completely for device:1: /private/tmp/com.bombich.ccc.SIqFDt
            12/18/12 6:47:53.647 PM fseventsd[50]: Logging disabled completely for device:1: /private/tmp/com.bombich.ccc.Is2xR2
            12/18/12 6:47:53.697 PM fseventsd[50]: Logging disabled completely for device:1: /private/tmp/com.bombich.ccc.fOazSX
            12/18/12 6:47:55.000 PM kernel[0]: Sandbox: sandboxd(3255) deny mach-lookup com.apple.coresymbolicationd
            12/18/12 6:47:55.176 PM sandboxd[3255]: ([317]) WebProcess(317) deny mach-lookup com.apple.pbs.fetch_services
            12/18/12 6:48:23.694 PM com.apple.backupd[3257]: Starting automatic backup
            12/18/12 6:48:23.820 PM com.apple.backupd[3257]: Backing up to: /Volumes/Backup-Internal Working Files-Mac/Backups.backupdb
            12/18/12 6:48:24.500 PM com.apple.backupd[3257]: Using file event preflight for Macintosh HD
            12/18/12 6:48:25.915 PM com.apple.backupd[3257]: Will copy (393.1 MB) from Macintosh HD
            12/18/12 6:48:25.922 PM com.apple.backupd[3257]: Found 392 files (398.2 MB) needing backup
            12/18/12 6:48:25.930 PM com.apple.backupd[3257]: 4.59 GB required (including padding), 1.84 TB available
            12/18/12 6:48:31.283 PM mdworker32[3264]: bootstrap_look_up2 failed with 0x44c
            12/18/12 6:48:31.534 PM sandboxd[3260]: ([3264]) mdworker32(3264) deny mach-lookup com.apple.PowerManagement.control (import fstype:hfs fsflag:4809000 flags:200000056 diag:0 uti:com.microsoft.excel.xls plugin:/Library/Spotlight/Microsoft Office.mdimporter - find suspect file using: sudo mdutil -t 22020051)
            12/18/12 6:48:31.000 PM kernel[0]: Sandbox: sandboxd(3260) deny mach-lookup com.apple.coresymbolicationd
            12/18/12 6:49:03.555 PM com.apple.backupd[3257]: Copied 3023 files (434.1 MB) from volume Macintosh HD.
            12/18/12 6:49:03.743 PM com.apple.backupd[3257]: Created new backup: 2012-12-18-184903
            12/18/12 6:49:03.811 PM com.apple.backupd[3257]: Starting post-backup thinning
            12/18/12 6:49:04.335 PM com.apple.backupd[3257]: Deleted /Volumes/Backup-Internal Working Files-Mac/Backups.backupdb/Mac Pro-Imacom/2012-12-15-213136 (57 KB)
            12/18/12 6:49:04.603 PM com.apple.backupd[3257]: Deleted /Volumes/Backup-Internal Working Files-Mac/Backups.backupdb/Mac Pro-Imacom/2012-12-15-203136 (57 KB)
            12/18/12 6:49:04.722 PM com.apple.backupd[3257]: Deleted /Volumes/Backup-Internal Working Files-Mac/Backups.backupdb/Mac Pro-Imacom/2012-12-15-193148 (5 MB)
            12/18/12 6:49:04.987 PM com.apple.backupd[3257]: Deleted /Volumes/Backup-Internal Working Files-Mac/Backups.backupdb/Mac Pro-Imacom/2012-12-15-183200 (123 KB)
            12/18/12 6:49:05.642 PM com.apple.backupd[3257]: Deleted /Volumes/Backup-Internal Working Files-Mac/Backups.backupdb/Mac Pro-Imacom/2012-12-15-173150 (115 KB)
            12/18/12 6:49:05.642 PM com.apple.backupd[3257]: Post-back up thinning complete: 5 expired backups removed
            12/18/12 6:49:05.676 PM com.apple.backupd[3257]: Backup completed successfully.
            12/18/12 6:50:34.556 PM mdworker[3262]: CFPropertyListCreateFromXMLData(): Old-style plist parser: missing semicolon in dictionary on line 1. Parsing will be abandoned. Break on _CFPropertyListMissingSemicolon to debug.
            12/18/12 6:51:26.662 PM login[3187]: DEAD_PROCESS: 3187 ttys000
            12/18/12 6:51:41.378 PM com.apple.usbmuxd[78]: stopping.
            12/18/12 6:51:41.393 PM com.apple.usbmuxd[3282]: usbmuxd-296.3 on Jul 25 2012 at 00:28:37, running 64 bit
            12/18/12 6:51:41.000 PM kernel[0]: MacAuthEvent en2   Auth result for: 00:0f:66:43:a4:fa  MAC AUTH succeeded
            12/18/12 6:51:41.000 PM kernel[0]: MacAuthEvent en2   Auth result for: 00:0f:66:43:a4:fa Unsolicited  Auth
            12/18/12 6:51:41.000 PM kernel[0]: wlEvent: en2 en2 Link UP virtIf = 0
            12/18/12 6:51:41.000 PM kernel[0]: AirPort: RSN handshake complete on en2
            12/18/12 6:51:41.000 PM kernel[0]: wl0: Roamed or switched channel, reason #2, bssid 00:0f:66:43:a4:fa
            12/18/12 6:51:41.000 PM kernel[0]: en2: BSSID changed to 00:0f:66:43:a4:fa
            12/18/12 6:51:41.000 PM kernel[0]: en2::IO80211Interface::postMessage bssid changed
            12/18/12 6:51:57.096 PM com.apple.launchd.peruser.501[145]: (com.apple.PackageKit.InstallStatus) Throttling respawn: Will start in 6 seconds
            12/18/12 6:51:57.158 PM WindowServer[122]: dict count after removing entry for window 0x9e5 is 0
            12/18/12 6:51:57.211 PM WindowServer[122]: CGXGetConnectionProperty: Invalid connection 62167
            12/18/12 6:51:57.212 PM WindowServer[122]: CGXGetConnectionProperty: Invalid connection 62167
            12/18/12 6:51:57.222 PM com.apple.launchd.peruser.501[145]: (com.prosofteng.DGMonitor[187]) Exited: Killed: 9
            12/18/12 6:51:57.235 PM coreservicesd[28]: SendFlattenedData, got error #268435459 (ipc/send) invalid destination port from ::mach_msg(), sending notification kLSNotifyApplicationDeath to notificationID=164
            12/18/12 6:51:57.235 PM coreservicesd[28]: SendFlattenedData, got error #268435459 (ipc/send) invalid destination port from ::mach_msg(), sending notification kLSNotifyApplicationDeath to notificationID=180
            12/18/12 6:51:57.237 PM coreservicesd[28]: SendFlattenedData, got error #268435459 (ipc/send) invalid destination port from ::mach_msg(), sending notification kLSNotifyApplicationDeath to notificationID=164
            12/18/12 6:51:57.237 PM coreservicesd[28]: SendFlattenedData, got error #268435459 (ipc/send) invalid destination port from ::mach_msg(), sending notification kLSNotifyApplicationDeath to notificationID=180
            12/18/12 6:51:57.238 PM coreservicesd[28]: SendFlattenedData, got error #268435459 (ipc/send) invalid destination port from ::mach_msg(), sending notification kLSNotifyApplicationDeath to notificationID=164
            12/18/12 6:51:57.250 PM coreservicesd[28]: SendFlattenedData, got error #268435460 (ipc/send) timed out from ::mach_msg(), sending notification kLSNotifyApplicationDeath to notificationID=1234
            12/18/12 6:51:57.253 PM WindowServer[122]: CGXGetConnectionProperty: Invalid connection 62167
            12/18/12 6:51:57.256 PM Splashtop Streamer[195]: going to close SRFeature.
            12/18/12 6:51:57.495 PM coreservicesd[28]: SendFlattenedData, got error #268435459 (ipc/send) invalid destination port from ::mach_msg(), sending notification kLSNotifyApplicationDeath to notificationID=147
            12/18/12 6:51:57.496 PM WindowServer[122]: CGXGetConnectionProperty: Invalid connection 62167
            12/18/12 6:51:57.497 PM WindowServer[122]: CGXGetConnectionProperty: Invalid connection 62167
            12/18/12 6:51:57.757 PM loginwindow[94]: sendQuitEventToApp (FMCore): AESendMessage returned error -1712
            12/18/12 6:51:57.782 PM loginwindow[94]: sendQuitEventToApp (Image Capture Extension): AESendMessage returned error -600
            12/18/12 6:51:57.783 PM loginwindow[94]: Application terminate returned -600
            12/18/12 6:51:57.784 PM com.apple.launchd.peruser.501[145]: ([0x0-0x24024].com.apple.AppleSpell[269]) Exited: Terminated: 15
            12/18/12 6:51:57.784 PM com.apple.launchd.peruser.501[145]: ([0x0-0x6c06c].com.adobe.switchboard-2.0[583]) Exited: Terminated: 15
            12/18/12 6:51:57.788 PM com.apple.launchd.peruser.501[145]: (com.apple.mdworker.shared.04000000-0000-0000-0000-000000000000[3262]) Exited: Killed: 9
            12/18/12 6:51:57.794 PM com.apple.launchd.peruser.501[145]: (com.apple.CalendarAgent[176]) Exited: Killed: 9
            12/18/12 6:51:58.259 PM Splashtop Streamer[195]:    AC Power
            12/18/12 6:52:07.816 PM loginwindow[94]: DEAD_PROCESS: 94 console
            12/18/12 6:52:07.828 PM com.apple.launchd.peruser.501[145]: (com.apple.PackageKit.InstallStatus) Throttling respawn: Will start in 6 seconds
            12/18/12 6:52:07.871 PM airportd[3283]: _doAutoJoin: Already associated to “abrazite”. Bailing on auto-join.
            12/18/12 6:52:07.937 PM helpd[3183]: Could not find access page in directory /Applications/Final Cut Pro.app/Contents/Resources/English.lproj/Final Cut Pro Help
            12/18/12 6:52:07.945 PM loginwindow[94]: Application hardKill returned -600
            12/18/12 6:52:07.946 PM loginwindow[94]: Application hardKill returned -600
            12/18/12 6:52:07.985 PM com.apple.kextd[12]: Warning: /Volumes/Macintosh HD/System/Library/Extensions: No such file or directory
            12/18/12 6:52:07.990 PM shutdown[3292]: reboot by Imacom:
            12/18/12 6:52:07.990 PM shutdown[3292]: SHUTDOWN_TIME: 1355874727 990267
            12/18/12 6:52:54.000 PM bootlog[0]: BOOT_TIME 1355874774 0
            12/18/12 6:52:56.000 PM kernel[0]: PMAP: PCID enabled
            12/18/12 6:52:56.000 PM kernel[0]: Darwin Kernel Version 12.2.0: Sat Aug 25 00:48:52 PDT 2012; root:xnu-2050.18.24~1/RELEASE_X86_64
            12/18/12 6:52:54.749 PM com.apple.launchd[1]: *** launchd[1] has started up. ***
            12/18/12 6:52:56.000 PM kernel[0]: vm_page_bootstrap: 7991548 free pages and 364292 wired pages
            12/18/12 6:52:56.000 PM kernel[0]: kext submap [0xffffff7f80741000 - 0xffffff8000000000], kernel text [0xffffff8000200000 - 0xffffff8000741000]
            12/18/12 6:52:56.000 PM kernel[0]: zone leak detection enabled
            12/18/12 6:52:56.000 PM kernel[0]: standard timeslicing quantum is 10000 us
            12/18/12 6:52:56.000 PM kernel[0]: standard background quantum is 2500 us
            12/18/12 6:52:56.000 PM kernel[0]: mig_table_max_displ = 74
            12/18/12 6:52:56.000 PM kernel[0]: corecrypto kext started!
            12/18/12 6:52:56.000 PM kernel[0]: Running kernel space in FIPS MODE
            12/18/12 6:52:56.000 PM kernel[0]: Plist hmac value is    735d392b68241ef173d81097b1c8ce9ba283521626d1c973ac376838c466757d
            12/18/12 6:52:56.000 PM kernel[0]: Computed hmac value is 735d392b68241ef173d81097b1c8ce9ba283521626d1c973ac376838c466757d
            12/18/12 6:52:56.000 PM kernel[0]: corecrypto.kext FIPS integrity POST test passed!
            12/18/12 6:52:56.000 PM kernel[0]: corecrypto.kext FIPS AES CBC POST test passed!
            12/18/12 6:52:56.000 PM kernel[0]: corecrypto.kext FIPS TDES CBC POST test passed!
            12/18/12 6:52:56.000 PM kernel[0]: corecrypto.kext FIPS AES ECB AESNI POST test passed!
            12/18/12 6:52:56.000 PM kernel[0]: corecrypto.kext FIPS AES XTS AESNI POST test passed!
            12/18/12 6:52:56.000 PM kernel[0]: corecrypto.kext FIPS SHA POST test passed!
            12/18/12 6:52:56.000 PM kernel[0]: corecrypto.kext FIPS HMAC POST test passed!
            12/18/12 6:52:56.000 PM kernel[0]: corecrypto.kext FIPS ECDSA POST test passed!
            12/18/12 6:52:56.000 PM kernel[0]: corecrypto.kext FIPS DRBG POST test passed!
            12/18/12 6:52:56.000 PM kernel[0]: corecrypto.kext FIPS POST passed!
            12/18/12 6:52:56.000 PM kernel[0]: AppleACPICPU: ProcessorId=0 LocalApicId=0 Enabled
            12/18/12 6:52:56.000 PM kernel[0]: AppleACPICPU: ProcessorId=1 LocalApicId=32 Enabled
            12/18/12 6:52:56.000 PM kernel[0]: AppleACPICPU: ProcessorId=2 LocalApicId=2 Enabled
            12/18/12 6:52:56.000 PM kernel[0]: AppleACPICPU: ProcessorId=3 LocalApicId=34 Enabled
            12/18/12 6:52:56.000 PM kernel[0]: AppleACPICPU: ProcessorId=4 LocalApicId=4 Enabled
            12/18/12 6:52:56.000 PM kernel[0]: AppleACPICPU: ProcessorId=5 LocalApicId=36 Enabled
            12/18/12 6:52:56.000 PM kernel[0]: AppleACPICPU: ProcessorId=6 LocalApicId=16 Enabled
            12/18/12 6:52:56.000 PM kernel[0]: AppleACPICPU: ProcessorId=7 LocalApicId=48 Enabled
            12/18/12 6:52:56.000 PM kernel[0]: AppleACPICPU: ProcessorId=8 LocalApicId=18 Enabled
            12/18/12 6:52:56.000 PM kernel[0]: AppleACPICPU: ProcessorId=9 LocalApicId=50 Enabled
            12/18/12 6:52:56.000 PM kernel[0]: AppleACPICPU: ProcessorId=10 LocalApicId=20 Enabled
            12/18/12 6:52:56.000 PM kernel[0]: AppleACPICPU: ProcessorId=11 LocalApicId=52 Enabled
            12/18/12 6:52:56.000 PM kernel[0]: AppleACPICPU: ProcessorId=12 LocalApicId=1 Enabled
            12/18/12 6:52:56.000 PM kernel[0]: AppleACPICPU: ProcessorId=13 LocalApicId=33 Enabled
            12/18/12 6:52:56.000 PM kernel[0]: AppleACPICPU: ProcessorId=14 LocalApicId=3 Enabled
            12/18/12 6:52:56.000 PM kernel[0]: AppleACPICPU: ProcessorId=15 LocalApicId=35 Enabled
            12/18/12 6:52:56.000 PM kernel[0]: AppleACPICPU: ProcessorId=16 LocalApicId=5 Enabled
            12/18/12 6:52:56.000 PM kernel[0]: AppleACPICPU: ProcessorId=17 LocalApicId=37 Enabled
            12/18/12 6:52:56.000 PM kernel[0]: AppleACPICPU: ProcessorId=18 LocalApicId=17 Enabled
            12/18/12 6:52:56.000 PM kernel[0]: AppleACPICPU: ProcessorId=19 LocalApicId=49 Enabled
            12/18/12 6:52:56.000 PM kernel[0]: AppleACPICPU: ProcessorId=20 LocalApicId=19 Enabled
            12/18/12 6:52:56.000 PM kernel[0]: AppleACPICPU: ProcessorId=21 LocalApicId=51 Enabled
            12/18/12 6:52:56.000 PM kernel[0]: AppleACPICPU: ProcessorId=22 LocalApicId=21 Enabled
            12/18/12 6:52:56.000 PM kernel[0]: AppleACPICPU: ProcessorId=23 LocalApicId=53 Enabled
            12/18/12 6:52:56.000 PM kernel[0]: calling mpo_policy_init for TMSafetyNet
            12/18/12 6:52:56.000 PM kernel[0]: Security policy loaded: Safety net for Time Machine (TMSafetyNet)
            12/18/12 6:52:56.000 PM kernel[0]: calling mpo_policy_init for Sandbox
            12/18/12 6:52:56.000 PM kernel[0]: Security policy loaded: Seatbelt sandbox policy (Sandbox)
            12/18/12 6:52:56.000 PM kernel[0]: calling mpo_policy_init for Quarantine
            12/18/12 6:52:56.000 PM kernel[0]: Security policy loaded: Quarantine policy (Quarantine)
            12/18/12 6:52:56.000 PM kernel[0]: Copyright (c) 1982, 1986, 1989, 1991, 1993
            12/18/12 6:52:56.000 PM kernel[0]: The Regents of the University of California. All rights reserved.
            12/18/12 6:52:56.000 PM kernel[0]: MAC Framework successfully initialized
            12/18/12 6:52:56.000 PM kernel[0]: using 16384 buffer headers and 10240 cluster IO buffer headers
            12/18/12 6:52:56.000 PM kernel[0]: IOAPIC: Version 0x20 Vectors 64:87
            12/18/12 6:52:56.000 PM kernel[0]: ACPI: System State [S0 S3 S4 S5]
            12/18/12 6:52:56.000 PM kernel[0]: PFM64 (40 cpu) 0xff80000000, 0x80000000
            12/18/12 6:52:56.000 PM kernel[0]: [ PCI configuration begin ]
            12/18/12 6:52:56.000 PM kernel[0]: AppleIntelCPUPowerManagement: Turbo Ratios 222233
            12/18/12 6:52:56.000 PM kernel[0]: AppleIntelCPUPowerManagement: (built 23:03:24 Jun 24 2012) initialization complete
            12/18/12 6:52:56.000 PM kernel[0]: console relocated to 0xff80010000
            12/18/12 6:52:56.000 PM kernel[0]: PCI configuration changed (bridge=7 device=2 cardbus=0)
            12/18/12 6:52:56.000 PM kernel[0]: [ PCI configuration end, bridges 15 devices 51 ]
            12/18/12 6:52:56.000 PM kernel[0]: mbinit: done [128 MB total pool size, (85/42) split]
            12/18/12 6:52:56.000 PM kernel[0]: Pthread support ABORTS when sync kernel primitives misused
            12/18/12 6:52:56.000 PM kernel[0]: ETH1 cannot assert wake from D3cold
            12/18/12 6:52:56.000 PM kernel[0]: ETH0 cannot assert wake from D3cold
            12/18/12 6:52:56.000 PM kernel[0]: rooting via boot-uuid from /chosen: 725DCE99-0F42-35F8-83CF-232BE79F8C0F
            12/18/12 6:52:56.000 PM kernel[0]: Waiting on <dict ID="0"><key>IOProviderClass</key><string ID="1">IOResources</string><key>IOResourceMatch</key><string ID="2">boot-uuid-media</string></dict>
            12/18/12 6:52:56.000 PM kernel[0]: com.apple.AppleFSCompressionTypeZlib kmod start
            12/18/12 6:52:56.000 PM kernel[0]: com.apple.AppleFSCompressionTypeDataless kmod start
            12/18/12 6:52:56.000 PM kernel[0]: com.apple.AppleFSCompressionTypeZlib load succeeded
            12/18/12 6:52:56.000 PM kernel[0]: com.apple.AppleFSCompressionTypeDataless load succeeded
            12/18/12 6:52:56.000 PM kernel[0]: AppleIntelCPUPowerManagementClient: ready
            12/18/12 6:52:56.000 PM kernel[0]: Intel82574L::start - Built Jun 24 2012 23:07:38 -- running on device at b9 d0 f0
            12/18/12 6:52:56.000 PM kernel[0]: Intel82574L::start - Built Jun 24 2012 23:07:38 -- running on device at b10 d0 f0
            12/18/12 6:52:56.000 PM kernel[0]: BTCOEXIST off
            12/18/12 6:52:56.000 PM kernel[0]: BRCM tunables:
            12/18/12 6:52:56.000 PM kernel[0]: pullmode[1] txringsize[  256] reapmin[   32] reapcount[  128]
            12/18/12 6:52:54.749 PM com.apple.launchd[1]: *** Shutdown logging is enabled. ***
            12/18/12 6:52:56.000 PM kernel[0]: highWaterMark: VO[  192]  VI[  192]  BE[  192]  BK[  192]
            12/18/12 6:52:56.650 PM com.apple.launchd[1]: (com.apple.automountd) Unknown key for boolean: NSSupportsSuddenTermination
            12/18/12 6:52:56.000 PM kernel[0]: FireWire (OHCI) TI ID 823f built-in now active, GUID 78ca39fffe123fc8; max speed s800.
            12/18/12 6:52:56.000 PM kernel[0]: Got boot device = IOService:/AppleACPIPlatformExpert/PCI0@0/AppleACPIPCI/SATA@1F,2/AppleAHCI/PRT2@2/IOAHCID evice@0/AppleAHCIDiskDriver/IOAHCIBlockStorageDevice/IOBlockStorageDriver/OCZ-VERTEX4 Media/IOGUIDPartitionScheme/Vertex SSD @2
            12/18/12 6:52:56.000 PM kernel[0]: BSD root: disk0s2, major 1, minor 1
            12/18/12 6:52:56.000 PM kernel[0]: Kernel is LP64
            12/18/12 6:52:56.000 PM kernel[0]: USBF:          1.484          [0xffffff806c596200] The IOUSBFamily is having trouble enumerating a USB device that has been plugged in.  It will keep retrying.  (Port 3 of Hub at 0x1d100000)
            12/18/12 6:52:57.000 PM kernel[0]: Intel82574L: Ethernet address e8:06:88:cc:10:44
            12/18/12 6:52:57.000 PM kernel[0]: Intel82574L: Ethernet address e8:06:88:cc:24:84
            12/18/12 6:52:57.000 PM kernel[0]: AirPort_Brcm4331: Ethernet address 00:26:08:fd:72:91
            12/18/12 6:52:57.000 PM kernel[0]: IO80211Controller::dataLinkLayerAttachComplete():  adding AppleEFINVRAM notification
            12/18/12 6:52:57.926 PM airportd[27]: _processDLILEvent: en2 attached (down)
            12/18/12 6:52:57.977 PM com.apple.SecurityServer[15]: Session 100000 created
            12/18/12 6:52:57.000 PM kernel[0]: createVirtIf(): ifRole = 1
            12/18/12 6:52:57.000 PM kernel[0]: in func createVirtualInterface ifRole = 1
            12/18/12 6:52:57.000 PM kernel[0]: AirPort_Brcm4331_P2PInterface::init name <p2p0> role 1 this 0xffffff806d089c00
            12/18/12 6:52:57.000 PM kernel[0]: AirPort_Brcm4331_P2PInterface::init() <p2p> role 1
            12/18/12 6:52:57.000 PM kernel[0]: Created virtif 0xffffff806d089c00 p2p0
            12/18/12 6:52:58.000 PM kernel[0]: Intel82574L::setLinkStatus - not active  1face000, 0
            12/18/12 6:52:58.019 PM com.apple.SecurityServer[15]: Entering service
            12/18/12 6:52:58.089 PM UserEventAgent[11]: Captive: [HandleNetworkInformationChanged:2435] nwi_state_copy returned NULL
            12/18/12 6:52:58.233 PM mDNSResponder[53]: mDNSResponder mDNSResponder-379.32.1 (Aug 31 2012 19:05:06) starting OSXVers 12
            12/18/12 6:52:58.319 PM systemkeychain[56]: done file: /var/run/systemkeychaincheck.done
            12/18/12 6:52:58.350 PM mDNSResponder[53]: D2D_IPC: Loaded
            12/18/12 6:52:58.350 PM mDNSResponder[53]: D2DInitialize succeeded
            12/18/12 6:52:58.000 PM kernel[0]: AirPort: Link Down on en2. Reason 8 (Disassociated because station leaving).
            12/18/12 6:52:58.000 PM kernel[0]: en2::IO80211Interface::postMessage bssid changed
            12/18/12 6:52:58.000 PM kernel[0]: Previous Shutdown Cause: 5
            12/18/12 6:52:58.000 PM kernel[0]: IOBluetoothUSBDFU::probe
            12/18/12 6:52:58.000 PM kernel[0]: IOBluetoothUSBDFU::probe ProductID - 0x8215 FirmwareVersion - 0x0201
            12/18/12 6:52:58.000 PM kernel[0]: [BroadcomBluetoothHCIControllerUSBTransport][start] -- completed
            12/18/12 6:52:58.000 PM kernel[0]: [IOBluetoothHCIController][staticBluetoothHCIControllerTransportShowsUp] -- Received Bluetooth Controller register service notification
            12/18/12 6:52:58.000 PM kernel[0]: [IOBluetoothHCIController][start] -- completed
            12/18/12 6:52:58.000 PM kernel[0]: [IOBluetoothHCIController::setConfigState] calling registerService
            12/18/12 6:52:58.000 PM kernel[0]: [AGPM Controller] unknownPlatform
            12/18/12 6:52:58.000 PM kernel[0]: AppleTyMCEDriver::start coreVIDPID = 0x2c708086 Number of packages = 1 Number of cpus = 24 memory monitor trough PCI
            12/18/12 6:52:58.000 PM kernel[0]: USBF:          4.748          [0xffffff806c596200] The IOUSBFamily was not able to enumerate a device.
            12/18/12 6:52:58.000 PM kernel[0]: Intel82574L::setLinkStatus - not active  1face001, 0
            12/18/12 6:52:58.838 PM configd[17]: bootp_session_transmit: bpf_write(en2) failed: Network is down (50)
            12/18/12 6:52:58.838 PM configd[17]: DHCP en2: INIT-REBOOT transmit failed
            12/18/12 6:52:58.867 PM configd[17]: network changed: DNS*
            12/18/12 6:52:58.868 PM configd[17]: setting hostname to "Mac-Pro-Imacom-5.local"
            12/18/12 6:52:58.000 PM kernel[0]: DSMOS has arrived
            12/18/12 6:52:59.000 PM kernel[0]: Intel82574L::setLinkStatus - not active  1face000, 0
            12/18/12 6:52:59.000 PM kernel[0]: USBF:          5.778          [0xffffff806c596200] The IOUSBFamily is having trouble enumerating a USB device that has been plugged in.  It will keep retrying.  (Port 3 of Hub at 0x1d100000)
            12/18/12 6:53:00.000 PM kernel[0]: MacAuthEvent en2   Auth result for: 00:0f:66:43:a4:fa  MAC AUTH succeeded
            12/18/12 6:53:00.000 PM kernel[0]: wlEvent: en2 en2 Link UP virtIf = 0
            12/18/12 6:53:00.000 PM kernel[0]: AirPort: Link Up on en2
            12/18/12 6:53:00.000 PM kernel[0]: en2: BSSID changed to 00:0f:66:43:a4:fa
            12/18/12 6:53:00.000 PM kernel[0]: en2::IO80211Interface::postMessage bssid changed
            12/18/12 6:53:00.394 PM airportd[27]: _doAutoJoin: Already associated to “abrazite”. Bailing on auto-join.
            12/18/12 6:53:00.000 PM kernel[0]: AirPort: RSN handshake complete on en2
            12/18/12 6:53:00.921 PM hidd[99]: Posting 'com.apple.iokit.hid.displayStatus' notifyState=1
            12/18/12 6:53:00.924 PM hidd[99]: void __IOHIDLoadBundles(): Loaded 0 HID plugins
            12/18/12 6:53:00.949 PM appleeventsd[104]: main: Starting up
            12/18/12 6:53:00.956 PM com.apple.kextd[12]: Can't load /System/Library/Extensions/CiscoVPN.kext - no code for running kernel's architecture.
            12/18/12 6:53:00.960 PM kdc[97]: label: default
            12/18/12 6:53:00.960 PM kdc[97]:           dbname: od:/Local/Default
            12/18/12 6:53:00.960 PM kdc[97]:           mkey_file: /var/db/krb5kdc/m-key
            12/18/12 6:53:00.960 PM kdc[97]:           acl_file: /var/db/krb5kdc/kadmind.acl
            12/18/12 6:53:00.961 PM SystemStarter[80]: Cisco Systems VPN Client Kernel Extension (117) did not complete successfully
            12/18/12 6:53:00.961 PM SystemStarter[80]: The following StartupItems failed to start properly:
            12/18/12 6:53:00.961 PM SystemStarter[80]: /System/Library/StartupItems/CiscoVPN
            12/18/12 6:53:00.962 PM SystemStarter[80]:  - execution of Startup script failed
            12/18/12 6:53:00.966 PM loginwindow[94]: Login Window Application Started
            12/18/12 6:53:00.974 PM com.apple.usbmuxd[78]: usbmuxd-296.3 on Jul 25 2012 at 00:28:37, running 64 bit
            12/18/12 6:53:00.979 PM kdc[97]: WARNING Found KDC certificate (O=System Identity,CN=com.apple.kerberos.kdc)is missing the PK-INIT KDC EKU, this is bad for interoperability.
            12/18/12 6:53:01.000 PM kernel[0]: macx_swapon SUCCESS
            12/18/12 6:53:01.013 PM netbiosd[90]: Unable to start NetBIOS name service:
            12/18/12 6:53:01.014 PM awacsd[108]: Starting awacsd connectivity-78 (Jul 26 2012 14:37:46)
            12/18/12 6:53:01.017 PM awacsd[108]: InnerStore CopyAllZones: no info in Dynamic Store
            12/18/12 6:53:01.033 PM kdc[97]: KDC started
            12/18/12 6:53:01.057 PM mds[91]: (Normal) FMW: FMW 0 0
            12/18/12 6:53:01.060 PM coreservicesd[28]: FindBestLSSession(), no match for inSessionID 0xfffffffffffffffc auditTokenInfo( uid=0 euid=0 auSessionID=100000 create=false
            12/18/12 6:53:01.061 PM WindowServer[122]: Server is starting up
            12/18/12 6:53:01.063 PM locationd[95]: NOTICE,Location icon should now be in state 0
            12/18/12 6:53:01.064 PM WindowServer[122]: Session 256 retained (2 references)
            12/18/12 6:53:01.065 PM WindowServer[122]: Session 256 released (1 references)
            12/18/12 6:53:01.074 PM WindowServer[122]: Session 256 retained (2 references)
            12/18/12 6:53:01.075 PM WindowServer[122]: init_page_flip: page flip mode is on
            12/18/12 6:53:01.084 PM apsd[110]: CGSLookupServerRootPort: Failed to look up the port for "com.apple.windowserver.active" (1102)
            12/18/12 6:53:01.310 PM BBDaemon[112]: IOBSDNameMatching returned a NULL dictionary.
            12/18/12 6:53:01.000 PM kernel[0]: Ethernet [Intel82574L]: Link up on en0, 1-Gigabit, Full-duplex, Symmetric flow-control, Debug [796d,af08,0de1,0200,c5e1,2800]
            12/18/12 6:53:01.000 PM kernel[0]: Intel82574L::setLinkStatus - active  1face000, b
            12/18/12 6:53:02.580 PM WindowServer[122]: mux_initialize: Couldn't find any matches
            12/18/12 6:53:02.595 PM WindowServer[122]: GLCompositor enabled for tile size [256 x 256]
            12/18/12 6:53:02.595 PM WindowServer[122]: CGXGLInitMipMap: mip map mode is on
            12/18/12 6:53:02.620 PM WindowServer[122]: WSMachineUsesNewStyleMirroring: false
            12/18/12 6:53:02.621 PM WindowServer[122]: Display 0x04241064: GL mask 0x1; bounds (0, 0)[2560 x 1600], 57 modes available
            Main, Active, on-line, enabled, boot, Vendor 610, Model 9232, S/N 2009ce4, Unit 0, Rotation 0
            UUID 0x000006100000923202009ce400000000
            12/18/12 6:53:02.621 PM WindowServer[122]: Display 0x003f003e: GL mask 0x4; bounds (0, 0)[0 x 0], 1 modes available
            off-line, enabled, Vendor ffffffff, Model ffffffff, S/N ffffffff, Unit 2, Rotation 0
            UUID 0xffffffffffffffffffffffff003f003e
            12/18/12 6:53:02.621 PM WindowServer[122]: Display 0x003f003d: GL mask 0x2; bounds (0, 0)[0 x 0], 1 modes available
            off-line, enabled, Vendor ffffffff, Model ffffffff, S/N ffffffff, Unit 1, Rotation 0
            UUID 0xffffffffffffffffffffffff003f003d
            12/18/12 6:53:02.631 PM WindowServer[122]: Created shield window 0x5 for display 0x04241064
            12/18/12 6:53:02.631 PM WindowServer[122]: Created shield window 0x6 for display 0x003f003e
            12/18/12 6:53:02.631 PM WindowServer[122]: Created shield window 0x7 for display 0x003f003d
            12/18/12 6:53:02.632 PM WindowServer[122]: Display 0x04241064: GL mask 0x1; bounds (0, 0)[2560 x 1600], 57 modes available
            12/18/12 6:53:02.632 PM WindowServer[122]: Display 0x003f003e: GL mask 0x4; bounds (3584, 0)[1 x 1], 1 modes available
            12/18/12 6:53:02.632 PM WindowServer[122]: Display 0x003f003d: GL mask 0x2; bounds (3585, 0)[1 x 1], 1 modes available
            12/18/12 6:53:02.632 PM WindowServer[122]: CGXPerformInitialDisplayConfiguration
            12/18/12 6:53:02.632 PM WindowServer[122]:   Display 0x04241064: MappedDisplay Unit 0; Vendor 0x610 Model 0x9232 S/N 33594596 Dimensions 25.24 x 15.79; online enabled, Bounds (0,0)[2560 x 1600], Rotation 0, Resolution 1
            12/18/12 6:53:02.632 PM WindowServer[122]:   Display 0x003f003e: MappedDisplay Unit 2; Vendor 0xffffffff Model 0xffffffff S/N -1 Dimensions 0.00 x 0.00; offline enabled, Bounds (3584,0)[1 x 1], Rotation 0, Resolution 1
            12/18/12 6:53:02.632 PM WindowServer[122]:   Display 0x003f003d: MappedDisplay Unit 1; Vendor 0xffffffff Model 0xffffffff S/N -1 Dimensions 0.00 x 0.00; offline enabled, Bounds (3585,0)[1 x 1], Rotation 0, Resolution 1
            12/18/12 6:53:02.657 PM WindowServer[122]: GLCompositor: GL renderer id 0x01021b01, GL mask 0x00000007, accelerator 0x00004037, unit 0, caps QEX|QGL|MIPMAP, vram 1024 MB
            12/18/12 6:53:02.657 PM WindowServer[122]: GLCompositor: GL renderer id 0x01021b01, GL mask 0x00000007, texture units 8, texture max 16384, viewport max {16384, 16384}, extensions FPRG|NPOT|GLSL|FLOAT
            12/18/12 6:53:02.660 PM loginwindow[94]: **DMPROXY** Found `/System/Library/CoreServices/DMProxy'.
            12/18/12 6:53:02.662 PM launchctl[129]: launchctl: Dubious permissions on file (skipping): /Library/LaunchAgents/com.adobe.AAM.Updater-1.0.plist
            12/18/12 6:53:02.697 PM WindowServer[122]: Created shield window 0x8 for display 0x04241064
            12/18/12 6:53:02.698 PM WindowServer[122]: Display 0x04241064: MappedDisplay Unit 0; ColorProfile { 2, "Cinema HD"}; TransferFormula (1.000000, 1.000000, 1.000000)
            12/18/12 6:53:02.702 PM launchctl[131]: launchctl: Dubious permissions on file (skipping): /Library/LaunchAgents/com.adobe.AAM.Updater-1.0.plist
            12/18/12 6:53:02.717 PM launchctl[131]: com.apple.findmymacmessenger: Already loaded
            12/18/12 6:53:02.730 PM com.apple.SecurityServer[15]: Session 100005 created
            12/18/12 6:53:02.746 PM airportd[27]: _doAutoJoin: Already associated to “abrazite”. Bailing on auto-join.
            12/18/12 6:53:02.772 PM loginwindow[94]: Login Window Started Security Agent
            12/18/12 6:53:02.834 PM SecurityAgent[142]: This is the first run
            12/18/12 6:53:02.834 PM SecurityAgent[142]: MacBuddy was run = 0
            12/18/12 6:53:02.844 PM WindowServer[122]: MPAccessSurfaceForDisplayDevice: Set up page flip mode on display 0x04241064 device: 0x1049d5320  isBackBuffered: 1 numComp: 3 numDisp: 3
            12/18/12 6:53:02.882 PM SecurityAgent[142]: User info context values set for Imacom
            12/18/12 6:53:02.930 PM coreaudiod[140]: 2012-12-18 06:53:02.929325 PM [AirPlay] Started browsing for _airplay._tcp.
            12/18/12 6:53:02.930 PM coreaudiod[140]: 2012-12-18 06:53:02.929728 PM [AirPlay] Started browsing for _raop._tcp.
            12/18/12 6:53:02.000 PM kernel[0]: USBF:          9.275          [0xffffff806c596200] The IOUSBFamily was not able to enumerate a device.
            12/18/12 6:53:03.187 PM loginwindow[94]: Login Window - Returned from Security Agent
            12/18/12 6:53:03.190 PM loginwindow[94]: ERROR | ScreensharingLoginNotification | Failed sending message to screen sharing GetScreensharingPort, err: 1102
            12/18/12 6:53:03.199 PM loginwindow[94]: USER_PROCESS: 94 console
            12/18/12 6:53:03.220 PM airportd[27]: _doAutoJoin: Already associated to “abrazite”. Bailing on auto-join.
            12/18/12 6:53:03.226 PM launchctl[147]: launchctl: Dubious permissions on file (skipping): /Library/LaunchAgents/com.adobe.AAM.Updater-1.0.plist
            12/18/12 6:53:03.245 PM launchctl[148]: launchctl: Dubious permissions on file (skipping): /Library/LaunchAgents/com.adobe.AAM.Updater-1.0.plist
            12/18/12 6:53:03.251 PM com.apple.launchd[1]: (com.wacom.wacomtablet[138]) Exited with code: 255
            12/18/12 6:53:03.258 PM com.apple.launchd.peruser.501[146]: (com.apple.gamed) Ignored this key: UserName
            12/18/12 6:53:03.258 PM com.apple.launchd.peruser.501[146]: (com.apple.gamed) Ignored this key: GroupName
            12/18/12 6:53:03.259 PM com.apple.launchd.peruser.501[146]: (com.apple.ReportCrash) Falling back to default Mach exception handler. Could not find: com.apple.ReportCrash.Self
            12/18/12 6:53:03.263 PM loginwindow[94]: Connection with distnoted server was invalidated
            12/18/12 6:53:03.268 PM distnoted[150]: # distnote server agent  absolute time: 9.617400847   civil time: Tue Dec 18 18:53:03 2012   pid: 150 uid: 501  root: no
            12/18/12 6:53:03.308 PM WindowServer[122]: **DMPROXY** (2) Found `/System/Library/CoreServices/DMProxy'.
            12/18/12 6:53:03.541 PM com.apple.SecurityServer[15]: Session 100003 created
            12/18/12 6:53:03.566 PM WindowServer[122]: Display 0x04241064: MappedDisplay Unit 0; ColorProfile { 2, "Cinema HD"}; TransferFormula (1.000000, 1.000000, 1.000000)
            12/18/12 6:53:03.574 PM coreservicesd[28]: SendFlattenedData, got error #268435460 (ipc/send) timed out from ::mach_msg(), sending notification kLSNotifyApplicationLaunch to notificationID=122
            12/18/12 6:53:03.586 PM configd[17]: network changed: v4(en2+:10.10.1.110) DNS+ Proxy+ SMB
            12/18/12 6:53:03.602 PM UserEventAgent[11]: Captive: en2: Not probing 'abrazite' (protected network)
            12/18/12 6:53:03.604 PM com.apple.launchd.peruser.501[146]: (com.akamai.single-user-client[192]) Bug: 12C60: launchd + 95444 [7DCC9489-2DF5-3807-83FA-EF5666EE8078]: 0xd
            12/18/12 6:53:03.604 PM com.apple.launchd.peruser.501[146]: (com.akamai.client.plist[193]) Bug: 12C60: launchd + 95444 [7DCC9489-2DF5-3807-83FA-EF5666EE8078]: 0xd
            12/18/12 6:53:03.605 PM configd[17]: network changed: v4(en2!:10.10.1.110) DNS Proxy SMB
            12/18/12 6:53:03.609 PM com.apple.launchd.peruser.501[146]: (com.apple.afpstat-qfa[182]) Exited with code: 2
            12/18/12 6:53:03.611 PM com.apple.launchd.peruser.501[146]: (com.adobe.ARM.0d92f8f114b2d0af95462120762f939f6c66651ac8ac214cb7bdbd84[196]) Exited with code: 2
            12/18/12 6:53:03.621 PM talagent[158]: _LSSetApplicationInformationItem(kLSDefaultSessionID, asn, _kLSApplicationIsHiddenKey, hidden ? kCFBooleanTrue : kCFBooleanFalse, NULL) produced OSStatus -50 on line 623 in TCApplication.m
            12/18/12 6:53:03.622 PM talagent[158]: _LSSetApplicationInformationItem(kLSDefaultSessionID, asn, TAL_kLSIsProxiedForTALKey, kCFBooleanTrue, NULL) produced OSStatus -50 on line 626 in TCApplication.m
            12/18/12 6:53:03.643 PM SRServiceAgent[184]: service agent got ipc message: 1094931542
            12/18/12 6:53:03.644 PM SRServiceAgent[184]: try start streamer
            12/18/12 6:53:03.647 PM SRServiceAgent[184]: start check timer
            12/18/12 6:53:03.648 PM SRServiceAgent[184]: create new task
            12/18/12 6:53:03.649 PM SRServiceAgent[184]: task is not running, launch task
            12/18/12 6:53:03.000 PM kernel[0]: CODE SIGNING: cs_invalid_page(0x1000): p=186[GoogleSoftwareUp] clearing CS_VALID
            12/18/12 6:53:03.743 PM NetworkBrowserAgent[201]: Starting NetworkBrowserAgent
            12/18/12 6:53:03.753 PM launchctl[206]: launchctl: Dubious permissions on file (skipping): /Library/LaunchAgents/com.adobe.AAM.Updater-1.0.plist
            12/18/12 6:53:03.943 PM Splashtop Streamer[198]: NSWindow does not support utility styleMask 0x10
            12/18/12 6:53:03.945 PM Splashtop Streamer[198]: NSWindow does not support utility styleMask 0x10
            12/18/12 6:53:03.000 PM kernel[0]: USBF:          10.192          [0xffffff806c596200] The IOUSBFamily is having trouble enumerating a USB device that has been plugged in.  It will keep retrying.  (Port 3 of Hub at 0x1d100000)
            12/18/12 6:53:03.959 PM Splashtop Streamer[198]: NSWindow does not support utility styleMask 0x10
            12/18/12 6:53:03.960 PM Splashtop Streamer[198]: NSWindow does not support utility styleMask 0x10
            12/18/12 6:53:03.968 PM Splashtop Streamer[198]: NSWindow does not support utility styleMask 0x10
            12/18/12 6:53:03.975 PM Splashtop Streamer[198]: Could not connect the action toggleServer: to target of class SplashtopRemoteAppDelegate
            12/18/12 6:53:03.988 PM Splashtop Streamer[198]: ---- http://www.splashtop.com/splashtop2#otherproducts-tab
            12/18/12 6:53:03.995 PM Splashtop Streamer[198]: -[DisplayView initWithFrame:] [{{0, 0}, {380, 70}}][{{0, 0}, {380, 70}}]
            12/18/12 6:53:03.998 PM Splashtop Streamer[198]: -[DisplayView(Private) setTextField:string:] 1 [{{20, 0}, {380, 70}}]
            12/18/12 6:53:03.999 PM Splashtop Streamer[198]: -[DisplayView(Private) setTextField:string:] 2 [{{20, 0}, {85, 14}}]
            12/18/12 6:53:04.024 PM Splashtop Streamer[198]: going to close SRFeature.
            12/18/12 6:53:04.078 PM DGAgent[190]: Resolved DG link from bookmark. /Applications/Drive Genius 3.app
            12/18/12 6:53:04.632 PM WindowServer[122]: **DMPROXY** (2) Found `/System/Library/CoreServices/DMProxy'.
            12/18/12 6:53:04.672 PM WindowServer[122]: Display 0x04241064: MappedDisplay Unit 0; ColorProfile { 2, "Cinema HD"}; TransferFormula (1.000000, 1.000000, 1.000000)
            12/18/12 6:53:04.717 PM WindowServer[122]: Display 0x04241064: MappedDisplay Unit 0; ColorProfile { 2, "Cinema HD"}; TransferFormula (1.000000, 1.000000, 1.000000)
            12/18/12 6:53:04.000 PM kernel[0]: USBF:          11. 57          [0xffffff806c596200] The IOUSBFamily gave up enumerating a USB device after 10 retries.  (Port 3 of Hub at 0x1d100000)
            12/18/12 6:53:04.000 PM kernel[0]: USBF:          11. 57          [0xffffff806c596200] The IOUSBFamily was not able to enumerate a device.
            12/18/12 6:53:04.803 PM YouSendIt Desktop App[232]: Set Version number 2.0.0.204
            12/18/12 6:53:04.839 PM Trim Enabler[229]: ON
            12/18/12 6:53:05.088 PM appleprofilepolicyd[238]: appleprofilepolicyd: profiling drivers not loaded, loading
            12/18/12 6:53:05.088 PM SRFeature[236]: Display server path : /Applications/Splashtop Streamer.app/Contents/MacOS/SRFeature.app/Contents/MacOS/SRXDisplayServer.app/Contents/Ma cOS/SRXDisplayServer
            12/18/12 6:53:05.092 PM configd[17]: network changed: v4(en0+:10.10.1.104, en2) DNS! Proxy! SMB
            12/18/12 6:53:05.116 PM SRXDisplayServer[240]: No SRX Display Card
            12/18/12 6:53:05.122 PM com.apple.launchd[1]: (com.apple.xprotectupdater[76]) Exited with code: 255
            12/18/12 6:53:05.123 PM imagent[175]: [Warning] Bag loading failed! Error (NSURLErrorDomain:-1003): A server with the specified hostname could not be found. http://init.ess.apple.com/WebObjects/VCInit.woa/wa/getBag?ix=1
            12/18/12 6:53:05.265 PM YouSendIt Desktop App[232]: finderPearlServerConnection = (** NSConnection 0x101b16700 receivePort <NSMachPort: 0x101b169c0> sendPort <NSMachPort: 0x101b169c0> refCount 1 remoteUsesKeyedDO: 0 **), pearlServices = <YSIPearlServices: 0x101b13460>
            12/18/12 6:53:05.281 PM YouSendIt Desktop App[232]: Need to check OSAX bundle
            12/18/12 6:53:05.282 PM YouSendIt Desktop App[232]: internal version=2.0.0.204, installed version=2.0.0.204
            12/18/12 6:53:05.283 PM YouSendIt Desktop App[232]: No valid connection
            12/18/12 6:53:05.341 PM Finder[161]: SDL checking if Pearl was loaded. hasLoaded=NO, addr=10476c2f4
            12/18/12 6:53:05.342 PM Finder[161]: not loaded, returning 1
            12/18/12 6:53:05.342 PM Finder[161]: handleYSILoad
            12/18/12 6:53:05.344 PM Finder[161]: YSI pearl loaded
            12/18/12 6:53:05.389 PM SRFeature[236]: pInfo data: [2][b000000][b][0]
            12/18/12 6:53:05.391 PM SRFeature[236]: FH: GetInfo
            12/18/12 6:53:05.397 PM SRFeature[236]: Error -5 sending Cancel request to remote message port.
            12/18/12 6:53:05.417 PM Finder[161]: pearl listener registered
            12/18/12 6:53:05.630 PM coreservicesd[28]: SendFlattenedData, got error #268435460 (ipc/send) timed out from ::mach_msg(), sending notification kLSNotifyApplicationReady to notificationID=168
            12/18/12 6:53:05.630 PM coreservicesd[28]: SendFlattenedData, got error #268435460 (ipc/send) timed out from ::mach_msg(), sending notification kLSNotifyApplicationReady to notificationID=178
            12/18/12 6:53:05.000 PM kernel[0]: Finder (map: 0xffffff806d93cf68) triggered DYLD shared region unnest for map: 0xffffff806d93cf68, region 0x7fff92a00000->0x7fff92c00000. While not abnormal for debuggers, this increases system memory footprint until the target exits.
            12/18/12 6:53:06.140 PM coreservicesd[28]: SendFlattenedData, got error #268435460 (ipc/send) timed out from ::mach_msg(), sending notification kLSNotifyChildApplicationLaunch to notificationID=131
            12/18/12 6:53:05.913 PM ntpd[74]: proto: precision = 1.000 usec
            12/18/12 6:53:06.474 PM blued[71]: kBTXPCUpdateUserPreferences gConsoleUserUID = 501
            12/18/12 6:53:07.119 PM Trim Enabler[229]: ON
            12/18/12 6:53:07.000 PM kernel[0]: Intel82574L::timeoutHandler - no link - reset the chipset once  1face001, 0
            12/18/12 6:53:07.000 PM kernel[0]: Intel82574L::setLinkStatus - not active  1face001, 0
            12/18/12 6:53:08.000 PM kernel[0]: Intel82574L::setLinkStatus - not active  1face001, 0
            12/18/12 6:53:08.470 PM locationd[285]: NOTICE,Location icon should now be in state 0
            12/18/12 6:53:08.532 PM UserEventAgent[149]: cannot find fw daemon port 1102
            12/18/12 6:53:08.820 PM CalendarAgent[179]: *** -[IADomainCache init]: IA domains cache is out of date.
            12/18/12 6:53:09.567 PM launchctl[297]: launchctl: Dubious permissions on file (skipping): /Library/LaunchAgents/com.adobe.AAM.Updater-1.0.plist
            12/18/12 6:53:09.745 PM Trim Enabler[229]: /Applications/Trim En
            12/18/12 6:53:09.749 PM Splashtop Streamer[198]: SRFEAT_NOTIFY_SERVER_CLOUD_NOTIFY_MSG
            12/18/12 6:53:09.749 PM Splashtop Streamer[198]: [ProcServerNotification] SRS_SERVER_RTN_INFO : [200][.srloginnotify.xml]
            12/18/12 6:53:09.778 PM Splashtop Streamer[198]:   receive backend string notify
            12/18/12 6:53:09.778 PM Splashtop Streamer[198]: -[CMXMLParser length]: unrecognized selector sent to instance 0x103711360
            12/18/12 6:53:09.779 PM Splashtop Streamer[198]: -[CMXMLParser length]: unrecognized selector sent to instance 0x103711360
            12/18/12 6:53:09.781 PM Splashtop Streamer[198]: (
                      0   CoreFoundation                      0x00007fff903250a6 __exceptionPreprocess + 198
                      1   libobjc.A.dylib                     0x00007fff915e83f0 objc_exception_throw + 43
                      2   CoreFoundation                      0x00007fff903bb6ea -[NSObject(NSObject) doesNotRecognizeSelector:] + 186
                      3   CoreFoundation                      0x00007fff903135ce ___forwarding___ + 414
                      4   CoreFoundation                      0x00007fff903133b8 _CF_forwarding_prep_0 + 232
                      5   Foundation                          0x00007fff8feddea8 -[NSPlaceholderString initWithString:] + 169
                      6   Splashtop Streamer                  0x000000010000be8f -[SplashtopRemoteAppDelegate getXMLContent:] + 199
                      7   CoreFoundation                      0x00007fff903815cc ____CFXNotificationPostToken_block_invoke_0 + 284
                      8   CoreFoundation                      0x00007fff902e2272 __CFRUNLOOP_IS_CALLING_OUT_TO_A_BLOCK__ + 18
                      9   CoreFoundation                      0x00007fff902a2a4f __CFRunLoopDoBlocks + 255
                      10  CoreFoundation                      0x00007fff902c7220 __CFRunLoopRun + 1904
                      11  CoreFoundation                      0x00007fff902c66b2 CFRunLoopRunSpecific + 290
                      12  HIToolbox                           0x00007fff921fa0a4 RunCurrentEventLoopInMode + 209
                      13  HIToolbox                           0x00007fff921f9e42 ReceiveNextEventCommon + 356
                      14  HIToolbox                           0x00007fff921f9cd3 BlockUntilNextEventMatchingListInMode + 62
                      15  AppKit                              0x00007fff951c5613 _DPSNextEvent + 685
                      16  AppKit                              0x00007fff951c4ed2 -[NSApplication nextEventMatchingMask:untilDate:inMode:dequeue:] + 128
                      17  AppKit                              0x00007fff951bc283 -[NSApplication run] + 517
                      18  AppKit                              0x00007fff95160cb6 NSApplicationMain + 869
                      19  Splashtop Streamer                  0x00000001000018b4 start + 52
            12/18/12 6:53:15.699 PM awacsd[108]: Exiting
            12/18/12 6:53:18.467 PM CalendarAgent[179]: [com.apple.calendar.store.log.caldav.queue] [Account refresh failed with error: Error Domain=CoreDAVHTTPStatusErrorDomain Code=404 "The operation couldn’t be completed. (CoreDAVHTTPStatusErrorDomain error 404.)" UserInfo=0x7f9250c4dd20 {AccountName=hmeichel@imacomdesign.com, CalDAVErrFromRefresh=YES, CoreDAVHTTPHeaders=<CFBasicHash 0x7f925640dd80 [0x7fff7a617fd0]>{type = immutable dict, count = 10,
            entries =>
                      0 : Case Insensitive Key: X-Content-Type-Options = <CFString 0x7f925640c330 [0x7fff7a617fd0]>{contents = "nosniff"}
                      1 : Case Insensitive Key: Content-Type = <CFString 0x7f925640d8e0 [0x7fff7a617fd0]>{contents = "text/html; charset=UTF-8"}
                      2 : Case Insensitive Key: Server = <CFString 0x7f925640dbc0 [0x7fff7a617fd0]>{contents = "GSE"}
                      3 : Case Insensitive Key: DAV = <CFString 0x7f925640d9c0 [0x7fff7a617fd0]>{contents = "1, calendar-access, calendar-schedule, calendar-proxy"}
                      4 : Case Insensitive Key: Transfer-Encoding = <CFString 0x7fff79b446f8 [0x7fff7a617fd0]>{contents = "Identity"}
                      6 : Case Insensitive Key: Date = <CFString 0x7f925640da10 [0x7fff7a617fd0]>{contents = "Tue, 18 Dec 2012 23:53:18 GMT"}
                      7 : Case Insensitive Key: X-Frame-Options = <CFString 0x7f92564095c0 [0x7fff7a617fd0]>{contents = "SAMEORIGIN"}
                      8 : Case Insensitive Key: X-XSS-Protection = <CFString 0x7f925640dba0 [0x7fff7a617fd0]>{contents = "1; mode=block"}
                      11 : Case Insensitive Key: Expires = <CFString 0x7f925640da40 [0x7fff7a617fd0]>{contents = "Tue, 18 Dec 2012 23:53:18 GMT"}
                      12 : Case Insensitive Key: Cache-Control = <CFString 0x7f925640da70 [0x7fff7a617fd0]>{contents = "private, max-age=0"}
            12/18/12 6:53:22.921 PM com.apple.launchd[1]: (com.apple.coreservices.appleid.authentication[137]) Exit timeout elapsed (20 seconds). Killing
            12/18/12 6:53:24.254 PM iCalExternalSync[301]: [0x7fef0140e520] |Miscellaneous|Error| SyncServices precondition failure in [ISyncConcreteSession pushChangesFromRecord:withIdentifier:]: you can't change the record's entity name from com.apple.calendars.MailAlarm to com.apple.calendars.DisplayAlarm in {
                "com.apple.syncservices.RecordEntityName" = "com.apple.calendars.DisplayAlarm";
                description = "";
                owner =     (
                    "Event/p935"
                triggerduration = "-900";
            12/18/12 6:53:24.254 PM iCalExternalSync[301]: [ICalExternalSync ]Encountered exception: [ISyncConcreteSession pushChangesFromRecord:withIdentifier:]: you can't change the record's entity name from com.apple.calendars.MailAlarm to com.apple.calendars.DisplayAlarm in {
                description = "";
                owner =     (
                    "Event/p935"
            } withStack: (
                      0   iCalExternalSync                    0x000000010f7bca60 iCalExternalSync + 125536
                      1   iCalExternalSync                    0x000000010f7abac9 iCalExternalSync + 56009
                      2   iCalExternalSync                    0x000000010f7bb694 iCalExternalSync + 120468
                      3   libdyld.dylib                       0x00007fff9644b7e1 start + 0
            12/18/12 6:53:24.255 PM iCalExternalSync[301]: [ICalExternalSync ]NSException name:ISyncInvalidArgumentsException reason:[ISyncConcreteSession pushChangesFromRecord:withIdentifier:]: you can't change the record's entity name from com.apple.calendars.MailAlarm to com.apple.calendars.DisplayAlarm in {
                description = "";
                owner =     (
                    "Event/p935"
            12/18/12 6:53:24.256 PM SyncServer[284]: [0x7fb4f240bde0] |Server|Warning| lost connection 0x7fb4f34016d0 to com.apple.iCal
            12/18/12 6:53:55.719 PM launchctl[313]: launchctl: Dubious permissions on file (skipping): /Library/LaunchAgents/com.adobe.AAM.Updater-1.0.plist
            12/18/12 6:53:55.920 PM com.apple.SecurityServer[15]: Session 100002 created
            12/18/12 6:55:43.377 PM mdworker[326]: CFPropertyListCreateFromXMLData(): Old-style plist parser: missing semicolon in dictionary on line 1. Parsing will be abandoned. Break on _CFPropertyListMissingSemicolon to debug.
            12/18/12 6:55:47.744 PM Adobe Bridge CS6[327]: CFPropertyListCreateFromXMLData(): Old-style plist parser: missing semicolon in dictionary on line 1. Parsing will be abandoned. Break on _CFPropertyListMissingSemicolon to debug.
            12/18/12 6:55:47.757 PM Adobe Bridge CS6[327]: CFPropertyListCreateFromXMLData(): Old-style plist parser: missing semicolon in dictionary on line 1. Parsing will be abandoned. Break on _CFPropertyListMissingSemicolon to debug.
            12/18/12 6:56:22.000 PM kernel[0]: Adobe Photoshop  (map: 0xffffff806d93dde8) triggered DYLD shared region unnest for map: 0xffffff806d93dde8, region 0x7fff8de00000->0x7fff8e000000. While not abnormal for debuggers, this increases system memory footprint until the target exits.
            12/18/12 6:56:50.675 PM Adobe Photoshop CS6[337]: *** WARNING: -[NSObject(NSKeyValueCoding) takeValuesFromDictionary:] is deprecated. It will be removed in a future release and should no longer be used.
            12/18/12 6:57:57.597 PM com.apple.kextd[12]: Warning: /Volumes/Macintosh HD/System/Library/Extensions: No such file or directory
            12/18/12 6:58:47.341 PM mdworker[326]: CFPropertyListCreateFromXMLData(): Old-style plist parser: missing semicolon in dictionary on line 1. Parsing will be abandoned. Break on _CFPropertyListMissingSemicolon to debug.
            12/18/12 6:58:50.359 PM xpcd[214]: (null): have symlinks: (
            12/18/12 6:58:51.520 PM librariand[362]: MMe quota status changed: under quota
            12/18/12 6:58:51.624 PM com.apple.security.pboxd[364]: Bug: 12C60: liblaunch.dylib + 23849 [2F71CAF8-6524-329E-AC56-C506658B4C0C]: 0x25
            12/18/12 7:02:01.073 PM CalendarAgent[179]: [com.apple.calendar.store.log.caldav] [During deep refresh in calendar "ImacomDesign", had collection tag match, but etag mismatch for url https://www.google.com/calendar/dav/imacom%40imacomdesign.com/events/http%3A%2F%2Fwww.brig httalk.com%2Fwebcast%2F452%2F30511.ics: server resource not present locally - cTag:63491553238 syncToken:(null)]
            12/18/12 7:02:01.073 PM CalendarAgent[179]: [com.apple.calendar.store.log.caldav] [During deep refresh in calendar "ImacomDesign", had collection tag match, but etag mismatch for url https://www.google.com/calendar/dav/imacom%40imacomdesign.com/events/http%3A%2F%2Fwww.brig httalk.com%2Fwebcast%2F21640.ics: server resource not present locally - cTag:63491553238 syncToken:(null)]
            12/18/12 7:02:06.429 PM CalendarAgent[179]: [com.apple.calendar.store.log.caldav] [During deep refresh in calendar "Helen Eichel - Work", had collection tag match, but etag mismatch for url https://www.google.com/calendar/dav/imacomdesign.com_7klr0v2r8acrf2adifrcupk6i4%40group.ca lendar.google.com/events/http%3A%2F%2Fwww.brighttalk.com%2Fwebcast%2F21640.ics: server resource not present locally - cTag:63486933486 syncToken:(null)]
            12/18/12 7:02:06.430 PM CalendarAgent[179]: [com.apple.calendar.store.log.caldav] [During deep refresh in calendar "Helen Eichel - Work", had collection tag match, but etag mismatch for url https://www.google.com/calendar/dav/imacomdesign.com_7klr0v2r8acrf2adifrcupk6i4%40group.ca lendar.google.com/events/http%3A%2F%2Fwww.brighttalk.com%2Fwebcast%2F452%2F30511.ics: server resource not present locally - cTag:63486933486 syncToken:(null)]
            12/18/12 7:02:12.006 PM iCalExternalSync[378]: [0x7fbeba40e520] |Miscellaneous|Error| SyncServices precondition failure in [ISyncConcreteSession pushChangesFromRecord:withIdentifier:]: you can't change the record's entity name from com.apple.calendars.MailAlarm to com.apple.calendars.DisplayAlarm in {
                description = "";
                owner =     (
                    "Event/p935"
            12/18/12 7:02:12.007 PM iCalExternalSync[378]: [ICalExternalSync ]Encountered exception: [ISyncConcreteSession pushChangesFromRecord:withIdentifier:]: you can't change the record's entity name from com.apple.calendars.MailAlarm to com.apple.calendars.DisplayAlarm in {
                description = "";
                owner =     (
                    "Event/p935"
            } withStack: (
                      0   iCalExternalSync                    0x000000010fb54a60 iCalExternalSync + 125536
                      1   iCalExternalSync                    0x000000010fb43ac9 iCalExternalSync + 56009
                      2   iCalExternalSync                    0x000000010fb53694 iCalExternalSync + 120468
            12/18/12 7:02:12.007 PM iCalExternalSync[378]: [ICalExternalSync ]NSException name:ISyncInvalidArgumentsException reason:[ISyncConcreteSession pushChangesFromRecord:withIdentifier:]: you can't change the record's entity name from com.apple.calendars.MailAlarm to com.apple.calendars.DisplayAlarm in {
                description = "";
                owner =     (
                    "Event/p935"
            12/18/12 7:02:12.008 PM SyncServer[379]: [0x7ff5d2c0bde0] |Server|Warning| lost connection 0x7ff5d591c280 to com.apple.iCal
            12/18/12 7:04:14.225 PM CVMServer[127]: Check-in to the service com.apple.cvmsCompAgent_x86_64 failed. This is likely because you have either unloaded the job or the MachService has the ResetAtClose attribute specified in the launchd.plist. If present, this attribute should be removed.
            12/18/12 7:04:14.236 PM launchctl[394]: launchctl: Dubious permissions on file (skipping): /Library/LaunchAgents/com.adobe.AAM.Updater-1.0.plist
            12/18/12 7:04:14.256 PM CVMServer[127]: Check-in to the service com.apple.cvmsCompAgent_x86_64 failed. This is likely because you have either unloaded the job or the MachService has the ResetAtClose attribute specified in the launchd.plist. If present, this attribute should be removed.
            12/18/12 7:04:16.000 PM kernel[0]: Sandbox: sandboxd(397) deny mach-lookup com.apple.coresymbolicationd
            12/18/12 7:04:20.279 PM sandboxd[397]: ([389]) WebProcess(389) deny mach-lookup ATS Query Port 187
            12/18/12 7:04:20.289 PM sandboxd[397]: ([389]) WebProcess(389) deny mach-lookup ATS Query Port 187
            12/18/12 7:04:31.619 PM GoogleTalkPlugin[400]: objc[400]: Class MacCocoaSocketServerHelper is implemented in both /Library/Application Support/Google/GoogleTalkPlugin.app/Contents/MacOS/GoogleTalkPlugin and /Library/Application Support/Google/GoogleTalkPlugin.app/Contents/Frameworks/libgoogletalkremoting.dylib. One of the two will be used. Which one is undefined.
            12/18/12 7:04:34.782 PM sandboxd[397]: ([389]) WebProcess(389) deny mach-lookup ATS Query Port 187
            12/18/12 7:05:15.828 PM sandboxd[407]: ([389]) WebProcess(389) deny mach-lookup ATS Query Port 187
            12/18/12 7:05:15.000 PM kernel[0]: Sandbox: sandboxd(407) deny mach-lookup com.apple.coresymbolicationd
            12/18/12 7:05:15.848 PM sandboxd[407]: ([389]) WebProcess(389) deny mach-lookup ATS Query Port 187
            12/18/12 7:05:15.869 PM sandboxd[407]: ([389]) WebProcess(389) deny mach-lookup ATS Query Port 187
            12/18/12 7:05:20.220 PM PluginProcess[401]: 401: CFNetwork internal error (0xc01a:/SourceCache/CFNetwork/CFNetwork-596.2.3/HTTP/HTTPReadStream.cpp:310)
            12/18/12 7:05:20.242 PM PluginProcess[401]: 401: CFNetwork internal error (0xc01a:/SourceCache/CFNetwork/CFNetwork-596.2.3/HTTP/HTTPReadStream.cpp:310)
            12/18/12 7:05:20.262 PM PluginProcess[401]: 401: CFNetwork internal error (0xc01a:/SourceCache/CFNetwork/CFNetwork-596.2.3/HTTP/HTTPReadStream.cpp:310)
            12/18/12 7:05:20.284 PM PluginProcess[401]: 401: CFNetwork internal error (0xc01a:/SourceCache/CFNetwork/CFNetwork-596.2.3/HTTP/HTTPReadStream.cpp:310)
            12/18/12 7:05:20.305 PM PluginProcess[401]: 401: CFNetwork internal error (0xc01a:/SourceCache/CFNetwork/CFNetwork-596.2.3/HTTP/HTTPReadStream.cpp:310)
            12/18/12 7:05:20.327 PM PluginProcess[401]: 401: CFNetwork internal error (0xc01a:/SourceCache/CFNetwork/CFNetwork-596.2.3/HTTP/HTTPReadStream.cpp:310)
            12/18/12 7:05:20.348 PM PluginProcess[401]: 401: CFNetwork internal error (0xc01a:/SourceCache/CFNetwork/CFNetwork-596.2.3/HTTP/HTTPReadStream.cpp:310)
            12/18/12 7:05:20.369 PM PluginProcess[401]: 401: CFNetwork internal error (0xc01a:/SourceCache/CFNetwork/CFNetwork-596.2.3/HTTP/HTTPReadStream.cpp:310)
            12/18/12 7:05:20.390 PM PluginProcess[401]: 401: CFNetwork internal error (0xc01a:/SourceCache/CFNetwork/CFNetwork-596.2.3/HTTP/HTTPReadStream.cpp:310)
            12/18/12 7:05:20.412 PM PluginProcess[401]: 401: CFNetwork internal error (0xc01a:/SourceCache/CFNetwork/CFNetwork-596.2.3/HTTP/HTTPReadStream.cpp:310)
            12/18/12 7:05:20.433 PM PluginProcess[401]: 401: CFNetwork internal error (0xc01a:/SourceCache/CFNetwork/CFNetwork-596.2.3/HTTP/HTTPReadStream.cpp:310)
            12/18/12 7:05:20.455 PM PluginProcess[401]: 401: CFNetwork internal error (0xc01a:/SourceCache/CFNetwork/CFNetwork-596.2.3/HTTP/HTTPReadStream.cpp:310)
            12/18/12 7:05:20.476 PM PluginProcess[401]: 401: CFNetwork internal error (0xc01a:/SourceCache/CFNetwork/CFNetwork-596.2.3/HTTP/HTTPReadStream.cpp:310)
            12/18/12 7:05:20.497 PM PluginProcess[401]: 401: CFNetwork internal error (0xc01a:/SourceCache/CFNetwork/CFNetwork-596.2.3/HTTP/HTTPReadStream.cpp:310)
            12/18/12 7:05:20.528 PM PluginProcess[401]: 401: CFNetwork internal error (0xc01a:/SourceCache/CFNetwork/CFNetwork-596.2.3/HTTP/HTTPReadStream.cpp:310)
            12/18/12 7:05:20.549 PM PluginProcess[401]: 401: CFNetwork internal error (0xc01a:/SourceCache/CFNetwork/CFNetwork-596.2.3/HTTP/HTTPReadStream.cpp:310)
            12/18/12 7:05:20.571 PM PluginProcess[401]: 401: CFNetwork internal error (0xc01a:/SourceCache/CFNetwork/CFNetwork-596.2.3/HTTP/HTTPReadStream.cpp:310)
            12/18/12 7:05:20.592 PM PluginProcess[401]: 401: CFNetwork internal error (0xc01a:/SourceCache/CFNetwork/CFNetwork-596.2.3/HTTP/HTTPReadStream.cpp:310)
            12/18/12 7:05:20.613 PM PluginProcess[401]: 401: CFNetwork internal error (0xc01a:/SourceCache/CFNetwork/CFNetwork-596.2.3/HTTP/HTTPReadStream.cpp:310)
            12/18/12 7:05:20.634 PM PluginProcess[401]: 401: CFNetwork internal error (0xc01a:/SourceCache/CFNetwork/CFNetwork-596.2.3/HTTP/HTTPReadStream.cpp:310)
            12/18/12 7:05:20.655 PM PluginProcess[401]: 401: CFNetwork internal error (0xc01a:/SourceCache/CFNetwork/CFNetwork-596.2.3/HTTP/HTTPReadStream.cpp:310)
            12/18/12 7:05:20.677 PM PluginProcess[401]: 401: CFNetwork internal error (0xc01a:/SourceCache/CFNetwork/CFNetwork-596.2.3/HTTP/HTTPReadStream.cpp:310)
            12/18/12 7:05:20.698 PM PluginProcess[401]: 401: CFNetwork internal error (0xc01a:/SourceCache/CFNetwork/CFNetwork-596.2.3/HTTP/HTTPReadStream.cpp:310)
            12/18/12 7:05:20.720 PM PluginProcess[401]: 401: CFNetwork internal error (0xc01a:/SourceCache/CFNetwork/CFNetwork-596.2.3/HTTP/HTTPReadStream.cpp:310)
            12/18/12 7:05:20.741 PM PluginProcess[401]: 401: CFNetwork internal error (0xc01a:/SourceCache/CFNetwork/CFNetwork-596.2.3/HTTP/HTTPReadStream.cpp:310)
            12/18/12 7:05:20.763 PM PluginProcess[401]: 401: CFNetwork internal error (0xc01a:/SourceCache/CFNetwork/CFNetwork-596.2.3/HTTP/HTTPReadStream.cpp:310)
            12/18/12 7:05:20.784 PM PluginProcess[401]: 401: CFNetwork internal error (0xc01a:/SourceCache/CFNetwork/CFNetwork-596.2.3/HTTP/HTTPReadStream.cpp:310)
            12/18/12 7:05:20.805 PM PluginProcess[401]: 401: CFNetwork internal error (0xc01a:/SourceCache/CFNetwork/CFNetwork-596.2.3/HTTP/HTTPReadStream.cpp:310)
            12/18/12 7:05:20.826 PM PluginProcess[401]: 401: CFNetwork internal error (0xc01a:/SourceCache/CFNetwork/CFNetwork-596.2.3/HTTP/HTTPReadStream.cpp:310)
            12/18/12 7:05:20.848 PM PluginProcess[401]: 401: CFNetwork internal error (0xc01a:/SourceCache/CFNetwork/CFNetwork-596.2.3/HTTP/HTTPReadStream.cpp:310)
            12/18/12 7:05:20.869 PM PluginProcess[401]: 401: CFNetwork internal error (0xc01a:/SourceCache/CFNetwork/CFNetwork-596.2.3/HTTP/HTTPReadStream.cpp:310)
            12/18/12 7:05:20.895 PM PluginProcess[401]: 401: CFNetwork internal error (0xc01a:/SourceCache/CFNetwork/CFNetwork-596.2.3/HTTP/HTTPReadStream.cpp:310)
            12/18/12 7:05:21.191 PM PluginProcess[401]: 401: CFNetwork internal error (0xc01a:/SourceCache/CFNetwork/CFNetwork-596.2.3/HTTP/HTTPReadStream.cpp:310)
            12/18/12 7:05:21.212 PM PluginProcess[401]: 401: CFNetwork internal error (0xc01a:/SourceCache/CFNetwork/CFNetwork-596.2.3/HTTP/HTTPReadStream.cpp:310)
            12/18/12 7:05:21.233 PM PluginProcess[401]: 401: CFNetwork internal error (0xc01a:/SourceCache/CFNetwork/CFNetwork-596.2.3/HTTP/HTTPReadStream.cpp:310)
            12/18/12 7:05:21.254 PM PluginProcess[401]: 401: CFNetwork internal error (0xc01a:/SourceCache/CFNetwork/CFNetwork-596.2.3/HTTP/HTTPReadStream.cpp:310)
            12/18/12 7:05:30.019 PM sandboxd[407]: ([389]) WebProcess(389) deny mach-lookup ATS Query Port 187
            12/18/12 7:05:30.040 PM sandboxd[407]: ([389]) WebProcess(389) deny mach-lookup ATS Query Port 187
            12/18/12 7:05:30.060 PM sandboxd[407]: ([389]) WebProcess(389) deny mach-lookup ATS Query Port 187
            12/18/12 7:05:30.081 PM sandboxd[407]: ([389]) WebProcess(389) deny mach-lookup ATS Query Port 187
            12/18/12 7:05:30.101 PM sandboxd[407]: ([389]) WebProcess(389) deny mach-lookup ATS Query Port 187
            12/18/12 7:05:30.122 PM sandboxd[407]: ([389]) WebProcess(389) deny mach-lookup ATS Query Port 187
            12/18/12 7:05:30.143 PM sandboxd[407]: ([389]) WebProcess(389) deny mach-lookup ATS Query Port 187
            12/18/12 7:05:30.164 PM sandboxd[407]: ([389]) WebProcess(389) deny mach-lookup ATS Query Port 187
            12/18/12 7:05:30.184 PM sandboxd[407]: ([389]) WebProcess(389) deny mach-lookup ATS Query Port 187
            12/18/12 7:05:30.205 PM sandboxd[407]: ([389]) WebProcess(389) deny mach-lookup ATS Query Port 187
            12/18/12 7:05:30.225 PM sandboxd[407]: ([389]) WebProcess(389) deny mach-lookup ATS Query Port 187
            12/18/12 7:05:30.246 PM sandboxd[407]: ([389]) WebProcess(389) deny mach-lookup ATS Query Port 187
            12/18/12 7:06:08.000 PM kernel[0]: Sandbox: sandboxd(412) deny mach-lookup com.apple.coresymbolicationd
            12/18/12 7:06:08.779 PM sandboxd[412]: ([389]) WebProcess(389) deny mach-lookup ATS Query Port 187
            12/18/12 7:07:20.699 PM Finder[161]: pearlBrowserSelectionChanged.
            12/18/12 7:07:22.188 PM login[422]: USER_PROCESS: 422 ttys000
            12/18/12 7:07:22.273 PM launchctl[429]: launchctl: Dubious permissions on file (skipping): /Library/LaunchAgents/com.adobe.AAM.Updater-1.0.plist
            12/18/12 7:08:07.395 PM Finder[161]: pearlBrowserSelectionChanged.
            12/18/12 7:08:24.099 PM Finder[161]: pearlBrowserSelectionChanged.
            12/18/12 7:08:26.891 PM Finder[161]: pearlBrowserSelectionChanged.
            12/18/12 7:09:01.180 PM Finder[161]: pearlBrowserSelectionChanged.
            12/18/12 7:09:09.333 PM Finder[161]: pearlBrowserSelectionChanged.
            12/18/12 7:09:23.335 PM Finder[161]: pearlBrowserSelectionChanged.
            12/18/12 7:09:27.143 PM Finder[161]: pearlBrowserSelectionChanged.
            12/18/12 7:09:30.500 PM Finder[161]: CFPropertyListCreateFromXMLData(): Old-style plist parser: missing semicolon in dictionary on line 1. Parsing will be abandoned. Break on _CFPropertyListMissingSemicolon to debug.
            12/18/12 7:09:30.502 PM Finder[161]: CFPropertyListCreateFromXMLData(): Old-style plist parser: missing semicolon in dictionary on line 1. Parsing will be abandoned. Break on _CFPropertyListMissingSemicolon to debug.
            12/18/12 7:09:45.000 PM kernel[0]: MacAuthEvent en2   Auth result for: 00:0f:66:43:a4:fa  MAC AUTH succeeded
            12/18/12 7:09:45.000 PM kernel[0]: wlEvent: en2 en2 Link UP virtIf = 0
            12/18/12 7:09:45.000 PM kernel[0]: AirPort: RSN handshake complete on en2
            12/18/12 7:09:45.000 PM kernel[0]: wl0: Roamed or switched channel, reason #2, bssid 00:0f:66:43:a4:fa
            12/18/12 7:09:45.000 PM kernel[0]: en2: BSSID changed to 00:0f:66:43:a4:fa
            12/18/12 7:09:45.000 PM kernel[0]: en2::IO80211Interface::postMessage bssid changed
            12/18/12 7:09:45.502 PM com.apple.launchd.peruser.501[146]: (com.apple.PackageKit.InstallStatus) Throttling respawn: Will start in 8 seconds
            12/18/12 7:09:45.508 PM login[422]: DEAD_PROCESS: 422 ttys000
            12/18/12 7:09:46.220 PM WindowServer[122]: dict count after removing entry for window 0x29 is 0
            12/18/12 7:09:46.232 PM WindowServer[122]: CGXGetConnectionProperty: Invalid connection 30095
            12/18/12 7:09:46.233 PM WindowServer[122]: CGXGetConnectionProperty: Invalid connection 30095
            12/18/12 7:09:46.242 PM com.apple.launchd.peruser.501[146]: (com.prosofteng.DGMonitor[190]) Exited: Killed: 9
            12/18/12 7:09:46.251 PM coreservicesd[28]: SendFlattenedData, got error #268435459 (ipc/send) invalid destination port from ::mach_msg(), sending notification kLSNotifyApplicationDeath to notificationID=169
            12/18/12 7:09:46.251 PM coreservicesd[28]: SendFlattenedData, got error #268435459 (ipc/send) invalid destination port from ::mach_msg(), sending notification kLSNotifyApplicationDeath to notificationID=177
            12/18/12 7:09:46.252 PM coreservicesd[28]: SendFlattenedData, got error #268435459 (ipc/send) invalid destination port from ::mach_msg(), sending notification kLSNotifyApplicationDeath to notificationID=169
            12/18/12 7:09:46.252 PM coreservicesd[28]: SendFlattenedData, got error #268435459 (ipc/send) invalid destination port from ::mach_msg(), sending notification kLSNotifyApplicationDeath to notificationID=177
            12/18/12 7:09:46.253 PM coreservicesd[28]: SendFlattenedData, got error #268435459 (ipc/send) invalid destination port from ::mach_msg(), sending notification kLSNotifyApplicationDeath to notificationID=169
            12/18/12 7:09:46.266 PM coreservicesd[28]: SendFlattenedData, got error #268435460 (ipc/send) timed out from ::mach_msg(), sending notification kLSNotifyApplicationDeath to notificationID=274
            12/18/12 7:09:46.269 PM WindowServer[122]: CGXGetConnectionProperty: Invalid connection 30095
            12/18/12 7:09:46.269 PM Splashtop Streamer[198]: going to close SRFeature.
            12/18/12 7:09:46.270 PM WindowServer[122]: CGXGetConnectionProperty: Invalid connection 30095
            12/18/12 7:09:46.517 PM coreservicesd[28]: SendFlattenedData, got error #268435459 (ipc/send) invalid destination port from ::mach_msg(), sending notification kLSNotifyApplicationDeath to notificationID=155
            12/18/12 7:09:46.517 PM WindowServer[122]: CGXGetConnectionProperty: Invalid connection 30095
            12/18/12 7:09:46.518 PM WindowServer[122]: CGXGetConnectionProperty: Invalid connection 30095
            12/18/12 7:09:46.771 PM loginwindow[94]: sendQuitEventToApp (FMCore): AESendMessage returned error -1712
            12/18/12 7:09:46.794 PM loginwindow[94]: sendQuitEventToApp (Image Capture Extension): AESendMessage returned error -600
            12/18/12 7:09:46.794 PM loginwindow[94]: Application terminate returned -600
            12/18/12 7:09:46.795 PM com.apple.launchd.peruser.501[146]: ([0x0-0x24024].com.apple.AppleSpell[261]) Exited: Terminated: 15
            12/18/12 7:09:46.797 PM com.apple.launchd.peruser.501[146]: (com.apple.quicklook[442]) Exited: Killed: 9
            12/18/12 7:09:46.797 PM com.apple.launchd.peruser.501[146]: (com.apple.mdworker.shared.04000000-0000-0000-0000-000000000000[376]) Exited: Killed: 9
            12/18/12 7:09:47.273 PM Splashtop Streamer[198]:    AC Power
            12/18/12 7:09:47.812 PM loginwindow[94]: DEAD_PROCESS: 94 console
            12/18/12 7:09:47.860 PM airportd[447]: _doAutoJoin: Already associated to “abrazite”. Bailing on auto-join.
            12/18/12 7:09:47.873 PM com.apple.kextd[12]: Warning: /Volumes/Macintosh HD/System/Library/Extensions: No such file or directory
            12/18/12 7:09:47.878 PM shutdown[452]: reboot by Imacom:
            12/18/12 7:09:47.879 PM shutdown[452]: SHUTDOWN_TIME: 1355875787 878573
            12/18/12 7:09:47.883 PM ntpd[74]: ntpd exiting on signal 15
            12/18/12 7:10:32.000 PM bootlog[0]: BOOT_TIME 1355875832 0
            12/18/12 7:10:34.000 PM kernel[0]: PMAP: PCID enabled
            12/18/12 7:10:34.000 PM kernel[0]: Darwin Kernel Version 12.2.0: Sat Aug 25 00:48:52 PDT 2012; root:xnu-2050.18.24~1/RELEASE_X86_64
            12/18/12 7:10:34.000 PM kernel[0]: vm_page_bootstrap: 8046439 free pages and 309401 wired pages
            12/18/12 7:10:34.000 PM kernel[0]: kext submap [0xffffff7f80741000 - 0xffffff8000000000], kernel text [0xffffff8000200000 - 0xffffff8000741000]
            12/18/12 7:10:34.000 PM kernel[0]: zone leak detection enabled
            12/18/12 7:10:34.000 PM kernel[0]: standard timeslicing quantum is 10000 us
            12/18/12 7:10:34.000 PM kernel[0]: standard background quantum is 2500 us
            12/18/12 7:10:34.000 PM kernel[0]: mig_table_max_displ = 74
            12/18/12 7:10:34.000 PM kernel[0]: corecrypto kext started!
            12/18/12 7:10:34.000 PM kernel[0]: Running kernel space in FIPS MODE
            12/18/12 7:10:34.000 PM kernel[0]: Plist hmac value is    735d392b68241ef173d81097b1c8ce9ba283521626d1c973ac376838c466757d
            12/18/12 7:10:34.000 PM kernel[0]: Computed hmac value is 735d392b68241ef173d81097b1c8ce9ba283521626d1c973ac376838c466757d
            12/18/12 7:10:34.000 PM kernel[0]: corecrypto.kext FIPS integrity POST test passed!
            12/18/12 7:10:34.000 PM kernel[0]: corecrypto.kext FIPS AES CBC POST test passed!
            12/18/12 7:10:34.000 PM kernel[0]: corecrypto.kext FIPS TDES CBC POST test passed!
            12/18/12 7:10:34.000 PM kernel[0]: corecrypto.kext FIPS AES ECB AESNI POST test passed!
            12/18/12 7:10:34.000 PM kernel[0]: corecrypto.kext FIPS AES XTS AESNI POST test passed!
            12/18/12 7:10:34.000 PM kernel[0]: corecrypto.kext FIPS SHA POST test passed!
            12/18/12 7:10:34.000 PM kernel[0]: corecrypto.kext FIPS HMAC POST test passed!
            12/18/12 7:10:34.000 PM kernel[0]: corecrypto.kext FIPS ECDSA POST test passed!
            12/18/12 7:10:34.000 PM kernel[0]: corecrypto.kext FIPS DRBG POST test passed!
            12/18/12 7:10:34.000 PM kernel[0]: corecrypto.kext FIPS POST passed!
            12/18/12 7:10:34.000 PM kernel[0]: AppleACPICPU: ProcessorId=0 LocalApicId=0 Enabled
            12/18/12 7:10:34.000 PM kernel[0]: AppleACPICPU: ProcessorId=1 LocalApicId=32 Enabled
            12/18/12 7:10:34.000 PM kernel[0]: AppleACPICPU: ProcessorId=2 LocalApicId=2 Enabled
            12/18/12 7:10:34.000 PM kernel[0]: AppleACPICPU: ProcessorId=3 LocalApicId=34 Enabled
            12/18/12 7:10:34.000 PM kernel[0]: AppleACPICPU: ProcessorId=4 LocalApicId=4 Enabled
            12/18/12 7:10:34.000 PM kernel[0]: AppleACPICPU: ProcessorId=5 LocalApicId=36 Enabled
            12/18/12 7:10:34.000 PM kernel[0]: AppleACPICPU: ProcessorId=6 LocalApicId=16 Enabled
            12/18/12 7:10:34.000 PM kernel[0]: AppleACPICPU: ProcessorId=7 LocalApicId=48 Enabled
            12/18/12 7:10:34.000 PM kernel[0]: AppleACPICPU: ProcessorId=8 LocalApicId=18 Enabled
            12/18/12 7:10:34.000 PM kernel[0]: AppleACPICPU: ProcessorId=9 LocalApicId=50 Enabled
            12/18/12 7:10:34.000 PM kernel[0]: AppleACPICPU: ProcessorId=10 LocalApicId=20 Enabled
            12/18/12 7:10:34.000 PM kernel[0]: AppleACPICPU: ProcessorId=11 LocalApicId=52 Enabled
            12/18/12 7:10:34.000 PM kernel[0]: AppleACPICPU: ProcessorId=12 LocalApicId=1 Enabled
            12/18/12 7:10:34.000 PM kernel[0]: AppleACPICPU: ProcessorId=13 LocalApicId=33 Enabled
            12/18/12 7:10:34.000 PM kernel[0]: AppleACPICPU: ProcessorId=14 LocalApicId=3 Enabled
            12/18/12 7:10:34.000 PM kernel[0]: AppleACPICPU: ProcessorId=15 LocalApicId=35 Enabled
            12/18/12 7:10:34.000 PM kernel[0]: AppleACPICPU: ProcessorId=16 LocalApicId=5 Enabled
            12/18/12 7:10:34.000 PM kernel[0]: AppleACPICPU: ProcessorId=17 LocalApicId=37 Enabled
            12/18/12 7:10:32.740 PM com.apple.launchd[1]: *** launchd[1] has started up. ***
            12/18/12 7:10:34.000 PM kernel[0]: AppleACPICPU: ProcessorId=18 LocalApicId=17 Enabled
            12/18/12 7:10:34.000 PM kernel[0]: AppleACPICPU: ProcessorId=19 LocalApicId=49 Enabled
            12/18/12 7:10:34.000 PM kernel[0]: AppleACPICPU: ProcessorId=20 LocalApicId=19 Enabled
            12/18/12 7:10:34.000 PM kernel[0]: AppleACPICPU: ProcessorId=21 LocalApicId=51 Enabled
            12/18/12 7:10:34.000 PM kernel[0]: AppleACPICPU: ProcessorId=22 LocalApicId=21 Enabled
            12/18/12 7:10:34.000 PM kernel[0]: AppleACPICPU: ProcessorId=23 LocalApicId=53 Enabled
            12/18/12 7:10:34.000 PM kernel[0]: calling mpo_policy_init for TMSafetyNet
            12/18/12 7:10:34.000 PM kernel[0]: Security policy loaded: Safety net for Time Machine (TMSafetyNet)
            12/18/12 7:10:34.000 PM kernel[0]: calling mpo_policy_init for Sandbox
            12/18/12 7:10:34.000 PM kernel[0]: Security policy loaded: Seatbelt sandbox policy (Sandbox)
            12/18/12 7:10:34.000 PM kernel[0]: calling mpo_policy_init for Quarantine
            12/18/12 7:10:34.000 PM kernel[0]: Security policy loaded: Quarantine policy (Quarantine)
            12/18/12 7:10:34.000 PM kernel[0]: Copyright (c) 1982, 1986, 1989, 1991, 1993
            12/18/12 7:10:34.000 PM kernel[0]: The Regents of the University of California. All rights reserved.
            12/18/12 7:10:34.000 PM kernel[0]: MAC Framework successfully initialized
            12/18/12 7:10:34.000 PM kernel[0]: using 16384 buffer headers and 10240 cluster IO buffer headers
            12/18/12 7:10:34.000 PM kernel[0]: IOAPIC: Version 0x20 Vectors 64:87
            12/18/12 7:10:34.000 PM kernel[0]: ACPI: System State [S0 S3 S4 S5]
            12/18/12 7:10:34.000 PM kernel[0]: PFM64 (40 cpu) 0xff80000000, 0x80000000
            12/18/12 7:10:34.000 PM kernel[0]: [ PCI configuration begin ]
            12/18/12 7:10:34.000 PM kernel[0]: AppleIntelCPUPowerManagement: Turbo Ratios 222233
            12/18/12 7:10:34.000 PM kernel[0]: AppleIntelCPUPowerManagement: (built 23:03:24 Jun 24 2012) initialization complete
            12/18/12 7:10:34.000 PM kernel[0]: console relocated to 0xff80010000
            12/18/12 7:10:34.000 PM kernel[0]: PCI configuration changed (bridge=7 device=2 cardbus=0)
            12/18/12 7:10:34.000 PM kernel[0]: [ PCI configuration end, bridges 15 devices 51 ]
            12/18/12 7:10:34.000 PM kernel[0]: mbinit: done [128 MB total pool size, (85/42) split]
            12/18/12 7:10:34.000 PM kernel[0]: Pthread support ABORTS when sync kernel primitives misused
            12/18/12 7:10:34.000 PM kernel[0]: ETH1 cannot assert wake from D3cold
            12/18/12 7:10:34.000 PM kernel[0]: ETH0 cannot assert wake from D3cold
            12/18/12 7:10:34.000 PM kernel[0]: rooting via boot-uuid from /chosen: 725DCE99-0F42-35F8-83CF-232BE79F8C0F
            12/18/12 7:10:34.000 PM kernel[0]: Waiting on <dict ID="0"><key>IOProviderClass</key><string ID="1">IOResources</string><key>IOResourceMatch</key><string ID="2">boot-uuid-media</string></dict>
            12/18/12 7:10:34.000 PM kernel[0]: com.apple.AppleFSCompressionTypeZlib kmod start
            12/18/12 7:10:34.000 PM kernel[0]: com.apple.AppleFSCompressionTypeDataless kmod start
            12/18/12 7:10:34.000 PM kernel[0]: com.apple.AppleFSCompressionTypeZlib load succeeded
            12/18/12 7:10:34.000 PM kernel[0]: com.apple.AppleFSCompressionTypeDataless load succeeded
            12/18/12 7:10:34.000 PM kernel[0]: AppleIntelCPUPowerManagementClient: ready
            12/18/12 7:10:34.000 PM kernel[0]: Intel82574L::start - Built Jun 24 2012 23:07:38 -- running on device at b10 d0 f0
            12/18/12 7:10:34.000 PM kernel[0]: Intel82574L::start - Built Jun 24 2012 23:07:38 -- running on device at b9 d0 f0
            12/18/12 7:10:34.000 PM kernel[0]: BTCOEXIST off
            12/18/12 7:10:34.000 PM kernel[0]: BRCM tunables:
            12/18/12 7:10:34.000 PM kernel[0]: pullmode[1] txringsize[  256] reapmin[   32] reapcount[  128]
            12/18/12 7:10:34.000 PM kernel[0]: highWaterMark: VO[  192]  VI[  192]  BE[  192]  BK[  192]
            12/18/12 7:10:34.000 PM kernel[0]: FireWire (OHCI) TI ID 823f built-in now active, GUID 78ca39fffe123fc8; max speed s800.
            12/18/12 7:10:34.000 PM kernel[0]: Got boot device = IOService:/AppleACPIPlatformExpert/PCI0@0/AppleACPIPCI/SATA@1F,2/AppleAHCI/PRT2@2/IOAHCID evice@0/AppleAHCIDiskDriver/IOAHCIBlockStorageDevice/IOBlockStorageDriver/OCZ-VERTEX4 Media/IOGUIDPartitionScheme/Vertex SSD @2
            12/18/12 7:10:34.000 PM kernel[0]: BSD root: disk0s2, major 1, minor 1
            12/18/12 7:10:34.000 PM kernel[0]: Kernel is LP64
            12/18/12 7:10:34.000 PM kernel[0]: USBF:          1.609          [0xffffff805ebf2000] The IOUSBFamily is having trouble enumerating a USB device that has been plugged in.  It will keep retrying.  (Port 3 of Hub at 0x1d100000)
            12/18/12 7:10:32.740 PM com.apple.launchd[1]: *** Shutdown logging is enabled. ***
            12/18/12 7:10:34.625 PM com.apple.launchd[1]: (com.apple.automountd) Unknown key for boolean: NSSupportsSuddenTermination
            12/18/12 7:10:35.000 PM kernel[0]: Intel82574L: Ethernet address e8:06:88:cc:10:44
            12/18/12 7:10:35.000 PM kernel[0]: Intel82574L: Ethernet address e8:06:88:cc:24:84
            12/18/12 7:10:35.000 PM kernel[0]: AirPort_Brcm4331: Ethernet address 00:26:08:fd:72:91
            12/18/12 7:10:35.000 PM kernel[0]: IO80211Controller::dataLinkLayerAttachComplete():  adding AppleEFINVRAM notification
            12/18/12 7:10:35.883 PM airportd[27]: _processDLILEvent: en2 attached (down)
            12/18/12 7:10:35.932 PM com.apple.SecurityServer[15]: Session 100000 created
            12/18/12 7:10:35.000 PM kernel[0]: createVirtIf(): ifRole = 1
            12/18/12 7:10:35.000 PM kernel[0]: in func createVirtualInterface ifRole = 1
            12/18/12 7:10:35.000 PM kernel[0]: AirPort_Brcm4331_P2PInterface::init name <p2p0> role 1 this 0xffffff805f694400
            12/18/12 7:10:35.000 PM kernel[0]: AirPort_Brcm4331_P2PInterface::init() <p2p> role 1
            12/18/12 7:10:35.000 PM kernel[0]: Created virtif 0xffffff805f694400 p2p0
            12/18/12 7:10:35.973 PM com.apple.SecurityServer[15]: Entering service
            12/18/12 7:10:36.000 PM kernel[0]: Intel82574L::setLinkStatus - not active  1face000, 0
            12/18/12 7:10:36.045 PM UserEventAgent[11]: Captive: [HandleNetworkInformationChanged:2435] nwi_state_copy returned NULL
            12/18/12 7:10:36.164 PM mDNSResponder[51]: mDNSResponder mDNSResponder-379.32.1 (Aug 31 2012 19:05:06) starting OSXVers 12
            12/18/12 7:10:36.249 PM systemkeychain[56]: done file: /var/run/systemkeychaincheck.done
            12/18/12 7:10:36.268 PM mDNSResponder[51]: D2D_IPC: Loaded
            12/18/12 7:10:36.268 PM mDNSResponder[51]: D2DInitialize succeeded
            12/18/12 7:10:36.000 PM kernel[0]: AirPort: Link Down on en2. Reason 8 (Disassociated because station leaving).
            12/18/12 7:10:36.000 PM kernel[0]: en2::IO80211Interface::postMessage bssid changed
            12/18/12 7:10:36.000 PM kernel[0]: Previous Shutdown Cause: 5
            12/18/12 7:10:36.000 PM kernel[0]: IOBluetoothUSBDFU::probe
            12/18/12 7:10:36.000 PM kernel[0]: IOBluetoothUSBDFU::probe ProductID - 0x8215 FirmwareVersion - 0x0201
            12/18/12 7:10:36.000 PM kernel[0]: [BroadcomBluetoothHCIControllerUSBTransport][start] -- completed
            12/18/12 7:10:36.000 PM kernel[0]: [IOBluetoothHCIController][staticBluetoothHCIControllerTransportShowsUp] -- Received Bluetooth Controller register service notification
            12/18/12 7:10:36.000 PM kernel[0]: [IOBluetoothHCIController][start] -- completed
            12/18/12 7:10:36.000 PM kernel[0]: [IOBluetoothHCIController::setConfigState] calling registerService
            12/18/12 7:10:36.000 PM kernel[0]: [AGPM Controller] unknownPlatform
            12/18/12 7:10:36.000 PM kernel[0]: AppleTyMCEDriver::start coreVIDPID = 0x2c708086 Number of packages = 1 Number of cpus = 24 memory monitor trough PCI
            12/18/12 7:10:36.000 PM kernel[0]: Intel82574L::setLinkStatus - not active  1face001, 0
            12/18/12 7:10:36.798 PM configd[17]: bootp_session_transmit: bpf_write(en2) failed: Network is down (50)
            12/18/12 7:10:36.798 PM configd[17]: DHCP en2: INIT-REBOOT transmit failed
            12/18/12 7:10:36.000 PM kernel[0]: USBF:          4.872          [0xffffff805ebf2000] The IOUSBFamily was not able to enumerate a device.
            12/18/12 7:10:36.000 PM kernel[0]: DSMOS has arrived
            12/18/12 7:10:36.826 PM configd[17]: network changed: DNS*
            12/18/12 7:10:36.827 PM configd[17]: setting hostname to "Mac-Pro-Imacom-5.local"
            12/18/12 7:10:37.000 PM kernel[0]: Intel82574L::setLinkStatus - not active  1face000, 0
            12/18/12 7:10:37.000 PM kernel[0]: USBF:          5.933          [0xffffff805ebf2000] The IOUSBFamily is having trouble enumerating a USB device that has been plugged in.  It will keep retrying.  (Port 3 of Hub at 0x1d100000)
            12/18/12 7:10:37.000 PM kernel[0]: MacAuthEvent en2   Auth result for: 00:0f:66:43:a4:fa  MAC AUTH succeeded
            12/18/12 7:10:37.000 PM kernel[0]: wlEvent: en2 en2 Link UP virtIf = 0
            12/18/12 7:10:37.000 PM kernel[0]: AirPort: Link Up on en2
            12/18/12 7:10:37.000 PM kernel[0]: en2: BSSID changed to 00:0f:66:43:a4:fa
            12/18/12 7:10:37.000 PM kernel[0]: en2::IO80211Interface::postMessage bssid changed
            12/18/12 7:10:38.000 PM kernel[0]: AirPort: RSN handshake complete on en2
            12/18/12 7:10:38.320 PM airportd[27]: _doAutoJoin: Already associated to “abrazite”. Bailing on auto-join.
            12/18/12 7:10:38.852 PM hidd[99]: Posting 'com.apple.iokit.hid.displayStatus' notifyState=1
            12/18/12 7:10:38.000 PM kernel[0]: macx_swapon SUCCESS
            12/18/12 7:10:38.856 PM hidd[99]: void __IOHIDLoadBundles(): Loaded 0 HID plugins
            12/18/12 7:10:38.880 PM appleeventsd[104]: main: Starting up
            12/18/12 7:10:38.885 PM kdc[97]: label: default
            12/18/12 7:10:38.885 PM kdc[97]:           dbname: od:/Local/Default
            12/18/12 7:10:38.885 PM kdc[97]:           mkey_file: /var/db/krb5kdc/m-key
            12/18/12 7:10:38.885 PM kdc[97]:           acl_file: /var/db/krb5kdc/kadmind.acl
            12/18/12 7:10:38.900 PM kdc[97]: WARNING Found KDC certificate (O=System Identity,CN=com.apple.kerberos.kdc)is missing the PK-INIT KDC EKU, this is bad for interoperability.
            12/18/12 7:10:38.900 PM com.apple.usbmuxd[78]: usbmuxd-296.3 on Jul 25 2012 at 00:28:37, running 64 bit
            12/18/12 7:10:38.910 PM com.apple.kextd[12]: Can't load /System/Library/Extensions/CiscoVPN.kext - no code for running kernel's architecture.
            12/18/12 7:10:38.914 PM SystemStarter[80]: Cisco Systems VPN Client Kernel Extension (118) did not complete successfully
            12/18/12 7:10:38.914 PM SystemStarter[80]: The following StartupItems failed to start properly:
            12/18/12 7:10:38.914 PM SystemStarter[80]: /System/Library/StartupItems/CiscoVPN
            12/18/12 7:10:38.914 PM SystemStarter[80]:  - execution of Startup script failed
            12/18/12 7:10:38.940 PM loginwindow[94]: Login Window Application Started
            12/18/12 7:10:38.942 PM apsd[110]: CGSLookupServerRootPort: Failed to look up the port for "com.apple.windowserver.active" (1102)
            12/18/12 7:10:38.943 PM apsd[110]: CGSLookupServerRootPort: Failed to look up the port for "com.apple.windowserver.active" (1102)
            12/18/12 7:10:38.947 PM netbiosd[90]: Unable to start NetBIOS name service:
            12/18/12 7:10:38.950 PM awacsd[108]: Starting awacsd connectivity-78 (Jul 26 2012 14:37:46)
            12/18/12 7:10:38.951 PM coreservicesd[28]: FindBestLSSession(), no match for inSessionID 0xfffffffffffffffc auditTokenInfo( uid=0 euid=0 auSessionID=100000 create=false
            12/18/12 7:10:38.952 PM mds[91]: (Normal) FMW: FMW 0 0
            12/18/12 7:10:38.953 PM awacsd[108]: InnerStore CopyAllZones: no info in Dynamic Store
            12/18/12 7:10:38.954 PM kdc[97]: KDC started
            12/18/12 7:10:39.006 PM WindowServer[122]: Server is starting up
            12/18/12 7:10:39.008 PM locationd[95]: NOTICE,Location icon should now be in state 0
            12/18/12 7:10:39.009 PM WindowServer[122]: Session 256 retained (2 references)
            12/18/12 7:10:39.009 PM WindowServer[122]: Session 256 released (1 references)
            12/18/12 7:10:39.016 PM WindowServer[122]: Session 256 retained (2 references)
            12/18/12 7:10:39.017 PM WindowServer[122]: init_page_flip: page flip mode is on
            12/18/12 7:10:39.230 PM BBDaemon[112]: IOBSDNameMatching returned a NULL dictionary.
            12/18/12 7:10:39.000 PM kernel[0]: Ethernet [Intel82574L]: Link up on en0, 1-Gigabit, Full-duplex, Symmetric flow-control, Debug [796d,af48,0de1,0200,c5e1,3800]
            12/18/12 7:10:39.000 PM kernel[0]: Intel82574L::setLinkStatus - active  1face000, b
            12/18/12 7:10:40.513 PM WindowServer[122]: mux_initialize: Couldn't find any matches
            12/18/12 7:10:40.528 PM WindowServer[122]: GLCompositor enabled for tile size [256 x 256]
            12/18/12 7:10:40.529 PM WindowServer[122]: CGXGLInitMipMap: mip map mode is on
            12/18/12 7:10:40.555 PM WindowServer[122]: WSMachineUsesNewStyleMirroring: false
            12/18/12 7:10:40.557 PM WindowServer[122]: Display 0x04241064: GL mask 0x1; bounds (0, 0)[2560 x 1600], 57 modes available
            12/18/12 7:10:40.557 PM WindowServer[122]: Display 0x003f003e: GL mask 0x4; bounds (0, 0)[0 x 0], 1 modes available
            12/18/12 7:10:40.557 PM WindowServer[122]: Display 0x003f003d: GL mask 0x2; bounds (0, 0)[0 x 0], 1 modes available
            12/18/12 7:10:40.567 PM WindowServer[122]: Created shield window 0x5 for display 0x04241064
            12/18/12 7:10:40.567 PM WindowServer[122]: Created shield window 0x6 for display 0x003f003e
            12/18/12 7:10:40.567 PM WindowServer[122]: Created shield window 0x7 for display 0x003f003d
            12/18/12 7:10:40.568 PM WindowServer[122]: Display 0x04241064: GL mask 0x1; bounds (0, 0)[2560 x 1600], 57 modes available
            12/18/12 7:10:40.568 PM WindowServer[122]: Display 0x003f003e: GL mask 0x4; bounds (3584, 0)[1 x 1], 1 modes available
            12/18/12 7:10:40.568 PM WindowServer[122]: Display 0x003f003d: GL mask 0x2; bounds (3585, 0)[1 x 1], 1 modes available
            12/18/12 7:10:40.568 PM WindowServer[122]: CGXPerformInitialDisplayConfiguration
            12/18/12 7:10:40.568 PM WindowServer[122]:   Display 0x04241064: MappedDisplay Unit 0; Vendor 0x610 Model 0x9232 S/N 33594596 Dimensions 25.24 x 15.79; online enabled, Bounds (0,0)[2560 x 1600], Rotation 0, Resolution 1
            12/18/12 7:10:40.568 PM WindowServer[122]:   Display 0x003f003e: MappedDisplay Unit 2; Vendor 0xffffffff Model 0xffffffff S/N -1 Dimensions 0.00 x 0.00; offline enabled, Bounds (3584,0)[1 x 1], Rotation 0, Resolution 1
            12/18/12 7:10:40.568 PM WindowServer[122]:   Display 0x003f003d: MappedDisplay Unit 1; Vendor 0xffffffff Model 0xffffffff S/N -1 Dimensions 0.00 x 0.00; offline enabled, Bounds (3585,0)[1 x 1], Rotation 0, Resolution 1
            12/18/12 7:10:40.594 PM WindowServer[122]: GLCompositor: GL renderer id 0x01021b01, GL mask 0x00000007, accelerator 0x00004137, unit 0, caps QEX|QGL|MIPMAP, vram 1024 MB
            12/18/12 7:10:40.594 PM WindowServer[122]: GLCompositor: GL renderer id 0x01021b01, GL mask 0x00000007, texture units 8, texture max 16384, viewport max {16384, 16384}, extensions FPRG|NPOT|GLSL|FLOAT
            12/18/12 7:10:40.597 PM loginwindow[94]: **DMPROXY** Found `/System/Library/CoreServices/DMProxy'.
            12/18/12 7:10:40.599 PM launchctl[129]: launchctl: Dubious permissions on file (skipping): /Library/LaunchAgents/com.adobe.AAM.Updater-1.0.plist
            12/18/12 7:10:40.634 PM WindowServer[122]: Created shield window 0x8 for display 0x04241064
            12/18/12 7:10:40.634 PM WindowServer[122]: Display 0x04241064: MappedDisplay Unit 0; ColorProfile { 2, "Cinema HD"}; TransferFormula (1.000000, 1.000000, 1.000000)
            12/18/12 7:10:40.639 PM launchctl[131]: launchctl: Dubious permissions on file (skipping): /Library/LaunchAgents/com.adobe.AAM.Updater-1.0.plist
            12/18/12 7:10:40.654 PM launchctl[131]: com.apple.findmymacmessenger: Already loaded
            12/18/12 7:10:40.666 PM com.apple.SecurityServer[15]: Session 100005 created
            12/18/12 7:10:40.679 PM airportd[27]: _doAutoJoin: Already associated to “abrazite”. Bailing on auto-join.
            12/18/12 7:10:40.708 PM loginwindow[94]: Login Window Started Security Agent
            12/18/12 7:10:40.767 PM SecurityAgent[142]: This is the first run
            12/18/12 7:10:40.767 PM SecurityAgent[142]: MacBuddy was run = 0
            12/18/12 7:10:40.777 PM WindowServer[122]: MPAccessSurfaceForDisplayDevice: Set up page flip mode on display 0x04241064 device: 0x104e4d320  isBackBuffered: 1 numComp: 3 numDisp: 3
            12/18/12 7:10:40.814 PM SecurityAgent[142]: User info context values set for Imacom
            12/18/12 7:10:40.868 PM coreaudiod[140]: 2012-12-18 07:10:40.867027 PM [AirPlay] Started browsing for _airplay._tcp.
            12/18/12 7:10:40.868 PM coreaudiod[140]: 2012-12-18 07:10:40.867731 PM [AirPlay] Started browsing for _raop._tcp.
            12/18/12 7:10:41.116 PM loginwindow[94]: Login Window - Returned from Security Agent
            12/18/12 7:10:41.000 PM kernel[0]: USBF:          9.433          [0xffffff805ebf2000] The IOUSBFamily was not able to enumerate a device.
            12/18/12 7:10:41.120 PM loginwindow[94]: ERROR | ScreensharingLoginNotification | Failed sending message to screen sharing GetScreensharingPort, err: 1102
            12/18/12 7:10:41.130 PM loginwindow[94]: USER_PROCESS: 94 console
            12/18/12 7:10:41.154 PM airportd[27]: _doAutoJoin: Already associated to “abrazite”. Bailing on auto-join.
            12/18/12 7:10:41.168 PM launchctl[147]: launchctl: Dubious permissions on file (skipping): /Library/LaunchAgents/com.adobe.AAM.Updater-1.0.plist
            12/18/12 7:10:41.187 PM launchctl[148]: launchctl: Dubious permissions on file (skipping): /Library/LaunchAgents/com.adobe.AAM.Updater-1.0.plist
            12/18/12 7:10:41.193 PM com.apple.launchd[1]: (com.wacom.wacomtablet[138]) Exited with code: 255
            12/18/12 7:10:41.200 PM com.apple.launchd.peruser.501[146]: (com.apple.gamed) Ignored this key: UserName
            12/18/12 7:10:41.200 PM com.apple.launchd.peruser.501[146]: (com.apple.gamed) Ignored this key: GroupName
            12/18/12 7:10:41.201 PM com.apple.launchd.peruser.501[146]: (com.apple.ReportCrash) Falling back to default Mach exception handler. Could not find: com.apple.ReportCrash.Self
            12/18/12 7:10:41.205 PM loginwindow[94]: Connection with distnoted server was invalidated
            12/18/12 7:10:41.210 PM distnoted[150]: # distnote server agent  absolute time: 9.563746619   civil time: Tue Dec 18 19:10:41 2012   pid: 150 uid: 501  root: no
            12/18/12 7:10:41.211 PM distnoted[150]: Bug: 12C60: liblaunch.dylib + 23849 [2F71CAF8-6524-329E-AC56-C506658B4C0C]: 0x25
            12/18/12 7:10:41.251 PM WindowServer[122]: **DMPROXY** (2) Found `/System/Library/CoreServices/DMProxy'.
            12/18/12 7:10:41.473 PM com.apple.SecurityServer[15]: Session 100003 created
            12/18/12 7:10:41.495 PM WindowServer[122]: Display 0x04241064: MappedDisplay Unit 0; ColorProfile { 2, "Cinema HD"}; TransferFormula (1.000000, 1.000000, 1.000000)
            12/18/12 7:10:41.503 PM coreservicesd[28]: SendFlattenedData, got error #268435460 (ipc/send) timed out from ::mach_msg(), sending notification kLSNotifyApplicationBirth to notificationID=122
            12/18/12 7:10:41.549 PM com.apple.launchd.peruser.501[146]: (com.akamai.client.plist[191]) Bug: 12C60: launchd + 95444 [7DCC9489-2DF5-3807-83FA-EF5666EE8078]: 0xd
            12/18/12 7:10:41.549 PM com.apple.launchd.peruser.501[146]: (com.akamai.single-user-client[190]) Bug: 12C60: launchd + 95444 [7DCC9489-2DF5-3807-83FA-EF5666EE8078]: 0xd
            12/18/12 7:10:41.550 PM talagent[158]: _LSSetApplicationInformationItem(kLSDefaultSessionID, asn, _kLSApplicationIsHiddenKey, hidden ? kCFBooleanTrue : kCFBooleanFalse, NULL) produced OSStatus -50 on line 623 in TCApplication.m
            12/18/12 7:10:41.551 PM talagent[158]: _LSSetApplicationInformationItem(kLSDefaultSessionID, asn, TAL_kLSIsProxiedForTALKey, kCFBooleanTrue, NULL) produced OSStatus -50 on line 626 in TCApplication.m
            12/18/12 7:10:41.555 PM com.apple.launchd.peruser.501[146]: (com.apple.afpstat-qfa[180]) Exited with code: 2
            12/18/12 7:10:41.555 PM com.apple.launchd.peruser.501[146]: (com.adobe.ARM.0d92f8f114b2d0af95462120762f939f6c66651ac8ac214cb7bdbd84[194]) Exited with code: 2
            12/18/12 7:10:41.589 PM SRServiceAgent[182]: service agent got ipc message: 1094931542
            12/18/12 7:10:41.590 PM SRServiceAgent[182]: try start streamer
            12/18/12 7:10:41.593 PM SRServiceAgent[182]: start check timer
            12/18/12 7:10:41.594 PM SRServiceAgent[182]: create new task
            12/18/12 7:10:41.594 PM SRServiceAgent[182]: task is not running, launch task
            12/18/12 7:10:41.000 PM kernel[0]: CODE SIGNING: cs_invalid_page(0x1000): p=184[GoogleSoftwareUp] clearing CS_VALID
            12/18/12 7:10:41.618 PM launchctl[199]: launchctl: Dubious permissions on file (skipping): /Library/LaunchAgents/com.adobe.AAM.Updater-1.0.plist
            12/18/12 7:10:41.682 PM NetworkBrowserAgent[203]: Starting NetworkBrowserAgent
            12/18/12 7:10:41.737 PM NotificationCenter[170]: In 'CFPasteboardCopyDataReturn __CFPasteboardCopyData(CFPasteboardRef, CFIndex, CFIndex, CFStringRef, Boolean)', file /SourceCache/CF/CF-744.12/AppServices.subproj/CFPasteboard.c, line 2373, during unlock, spin lock 0x103900018 has value 0x0, which is not locked.  The memory has been smashed or the lock is being unlocked when not locked.
            12/18/12 7:10:41.865 PM Splashtop Streamer[198]: NSWindow does not support utility styleMask 0x10
            12/18/12 7:10:41.872 PM Splashtop Streamer[198]: NSWindow does not support utility styleMask 0x10
            12/18/12 7:10:41.874 PM Splashtop Streamer[198]: NSWindow does not support utility styleMask 0x10
            12/18/12 7:10:41.877 PM Splashtop Streamer[198]: NSWindow does not support utility styleMask 0x10
            12/18/12 7:10:41.879 PM Splashtop Streamer[198]: NSWindow does not support utility styleMask 0x10
            12/18/12 7:10:41.894 PM Splashtop Streamer[198]: Could not connect the action toggleServer: to target of class SplashtopRemoteAppDelegate
            12/18/12 7:10:41.904 PM Splashtop Streamer[198]: -[DisplayView initWithFrame:] [{{0, 0}, {380, 70}}][{{0, 0}, {380, 70}}]
            12/18/12 7:10:41.911 PM Splashtop Streamer[198]: -[DisplayView(Private) setTextField:string:] 1 [{{20, 0}, {380, 70}}]
            12/18/12 7:10:41.912 PM Splashtop Streamer[198]: -[DisplayView(Private) setTextField:string:] 2 [{{20, 0}, {85, 14}}]
            12/18/12 7:10:41.916 PM Splashtop Streamer[198]: ---- http://www.splashtop.com/splashtop2#otherproducts-tab
            12/18/12 7:10:41.961 PM GoogleSoftwareUpdateDaemon[214]: -[KeystoneDaemon logServiceState] GoogleSoftwareUpdate daemon (1.1.0.3659) vending:
                      com.google.Keystone.Daemon.UpdateEngine: 2 connection(s)
                      com.google.Keystone.Daemon.Administration: 0 connection(s)
            12/18/12 7:10:41.986 PM GoogleSoftwareUpdateDaemon[214]: -[KSUpdateEngine updateProductID:] KSUpdateEngine updating product ID: "com.google.Keystone"
            12/18/12 7:10:41.995 PM GoogleSoftwareUpdateDaemon[214]: -[KSCheckAction performAction] KSCheckAction checking 1 ticket(s).
            12/18/12 7:10:42.007 PM GoogleSoftwareUpdateDaemon[214]: -[KSUpdateCheckAction performAction] KSUpdateCheckAction starting update check for ticket(s): {(
                      <KSTicket:0x4207690
                                productID=com.google.Keystone
                                version=1.1.0.3659
                                xc=<KSPathExistenceChecker:0x4204830 path=/Library/Google/GoogleSoftwareUpdate/GoogleSoftwareUpdate.bundle/>
                                serverType=Omaha
                                url=https://tools.google.com/service/update2
                                creationDate=2011-07-11 14:46:13
            Using server: <KSOmahaServer:0x60068d0
                      engine=<KSDaemonUpdateEngine:0x4205170>
                      params={
                                EngineVersion = "1.1.0.3659";
                                ActivesInfo = {
                                          "com.google.picasa" = {
                                                    LastActiveDate = 2012-03-16 03:12:34 +0000;
                                                    LastActivePingDate = 2012-03-16 07:00:00 +0000;
                                                    LastRollCallPingDate = 2012-12-18 08:00:00 +0000;
                                          "com.google.Keystone" = {
                                                    LastActiveDate = 2012-12-19 00:10:41 +0000;
                                                    LastActivePingDate = 2012-12-18 08:00:00 +0000;
                                          "com.google.Chrome" = {
                                                    LastActiveDate = 2012-11-16 04:43:04 +0000;
                                                    LastActivePingDate = 2012-11-16 08:00:01 +0000;
                                          "com.google.GoogleDrive" = {
                                                    LastActivePingDate = 2012-12-09 08:00:00 +0000;
                                                    LastActiveDate = 2012-12-08 20:19:33 +0000;
                                          "com.google.talkplugin" = {
                                                    LastActiveDate = 2012-01-19 13:54:09 +0000;
                                                    LastActivePingDate = 2012-07-21 07:00:00 +0000;
                                UserInitiated = 0;
                                IsSystem = 1;
                                OmahaOSVersion = "10.8.2_i486";
                                Identity = KeystoneDaemon;
                                AllowedSubdomains = (
                                          ".omaha.sandbox.google.com",
                                          ".tools.google.com",
                                          ".www.google.com",
                                          ".corp.google.com"
            12/18/12 7:10:42.000 PM kernel[0]: USBF:          10.351          [0xffffff805ebf2000] The IOUSBFamily is having trouble enumerating a USB device that has been plugged in.  It will keep retrying.  (Port 3 of Hub at 0x1d100000)
            12/18/12 7:10:42.017 PM GoogleSoftwareUpdateDaemon[214]: -[KSUpdateCheckAction performAction] KSUpdateCheckAction running KSServerUpdateRequest: <KSOmahaServerUpdateRequest:0x1d05120
                      server=<KSOmahaServer:0x60068d0>
                      url="https://tools.google.com/service/update2"
                      runningFetchers=0
                      tickets=1
                      activeTickets=0
                      rollCallTickets=0
                      body=
                                <?xml version="1.0" encoding="UTF-8" standalone="yes"?>
                                <o:gupdate xmlns:o="http://www.google.com/update2/request" protocol="2.0" version="KeystoneDaemon-1.1.0.3659" ismachine="1">
                                    <o:os platform="mac" version="MacOSX" sp="10.8.2_i486"></o:os>
                                    <o:app appid="com.google.Keystone" version="1.1.0.3659" lang="en-us" installage="526" brand="GGLG">
                                        <o:updatecheck></o:updatecheck>
                                    </o:app>
                                </o:gupdate>
            12/18/12 7:10:42.022 PM DGAgent[188]: Resolved DG link from bookmark. /Applications/Drive Genius 3.app
            12/18/12 7:10:42.128 PM launchctl[222]: launchctl: Dubious permissions on file (skipping): /Library/LaunchAgents/com.adobe.AAM.Updater-1.0.plist
            12/18/12 7:10:42.285 PM GoogleSoftwareUpdateDaemon[214]: -[KSOutOfProcessFetcher(PrivateMethods) helperDidTerminate:] The Internet connection appears to be offline. [NSURLErrorDomain:-1009]
            12/18/12 7:10:42.286 PM GoogleSoftwareUpdateDaemon[214]: -[KSServerUpdateRequest(PrivateMethods) fetcher:failedWithError:] KSServerUpdateRequest fetch failed. (productIDs: com.google.Keystone) [com.google.UpdateEngine.CoreErrorDomain:702 - 'https://tools.google.com/service/update2'] (The Internet connection appears to be offline. [NSURLErrorDomain:-1009])
            12/18/12 7:10:42.287 PM GoogleSoftwareUpdateDaemon[214]: -[KSUpdateCheckAction(PrivateMethods) finishAction] KSUpdateCheckAction found updates: {( )}
            12/18/12 7:10:42.290 PM GoogleSoftwareUpdateDaemon[214]: -[KSPrefetchAction performAction] KSPrefetchAction no updates to prefetch.
            12/18/12 7:10:42.291 PM GoogleSoftwareUpdateDaemon[214]: -[KSMultiUpdateAction performAction] KSSilentUpdateAction had no updates to apply.
            12/18/12 7:10:42.293 PM GoogleSoftwareUpdateDaemon[214]: -[KSMultiUpdateAction performAction] KSPromptAction had no updates to apply.
            12/18/12 7:10:42.297 PM GoogleSoftwareUpdateDaemon[214]: -[KSUpdateEngine(PrivateMethods) updateFinish] KSUpdateEngine update processing complete.
            12/18/12 7:10:42.370 PM Splashtop Streamer[198]: going to close SRFeature.
            12/18/12 7:10:42.567 PM WindowServer[122]: **DMPROXY** (2) Found `/System/Library/CoreServices/DMProxy'.
            12/18/12 7:10:42.603 PM WindowServer[122]: Display 0x04241064: MappedDisplay Unit 0; ColorProfile { 2, "Cinema HD"}; TransferFormula (1.000000, 1.000000, 1.000000)
            12/18/12 7:10:42.649 PM WindowServer[122]: Display 0x04241064: MappedDisplay Unit 0; ColorProfile { 2, "Cinema HD"}; TransferFormula (1.000000, 1.000000, 1.000000)
            12/18/12 7:10:43.000 PM kernel[0]: USBF:          11.213          [0xffffff805ebf2000] The IOUSBFamily gave up enumerating a USB device after 10 retries.  (Port 3 of Hub at 0x1d100000)
            12/18/12 7:10:43.000 PM kernel[0]: USBF:          11.213          [0xffffff805ebf2000] The IOUSBFamily was not able to enumerate a device.
            12/18/12 7:10:43.057 PM GoogleSoftwareUpdateDaemon[214]: -[KSUpdateEngine updateAllProducts] KSUpdateEngine updating all installed products.
            12/18/12 7:10:43.059 PM GoogleSoftwareUpdateDaemon[214]: -[KSCheckAction performAction] KSCheckAction checking 2 ticket(s).
            12/18/12 7:10:43.066 PM GoogleSoftwareUpdateDaemon[214]: -[KSUpdateCheckAction performAction] KSUpdateCheckAction starting update check for ticket(s): {(
                      <KSTicket:0x60088d0
                                version=1.1.0.3659
                                xc=<KSPathExistenceChecker:0x6007520 path=/Library/Google/GoogleSoftwareUpdate/GoogleSoftwareUpdate.bundle/>
                                serverType=Omaha
                      <KSTicket:0x6008a40
                                productID=com.google.talkplugin
                                version=3.10.2.10212
                                xc=<KSPathExistenceChecker:0x6008e40 path=/Library/Application Support/Google/GoogleTalkPlugin.app>
                                serverType=Omaha
                                creationDate=2012-07-20 22:50:59
            Using server: <KSOmahaServer:0x3406010
                      params={
                                ActivesInfo = {
                                UserInitiated = 0;
                                IsSystem = 1;
                                          ".www.google.com",
                                          ".corp.google.com"
            12/18/12 7:10:43.068 PM GoogleSoftwareUpdateDaemon[214]: -[KSUpdateCheckAction performAction] KSUpdateCheckAction running KSServerUpdateRequest: <KSOmahaServerUpdateRequest:0x4806980
                      server=<KSOmahaServer:0x3406010>
                      runningFetchers=0
                      tickets=2
                      activeTickets=0
                      rollCallTickets=0
                      body=
                                    </o:app>
                                    <o:app appid="com.google.talkplugin" version="3.10.2.10212" lang="en-us" installage="151" brand="GGLG">
                                    </o:app>
                                </o:gupdate>
            12/18/12 7:10:43.179 PM GoogleSoftwareUpdateDaemon[214]: -[KSOutOfProcessFetcher(PrivateMethods) helperDidTerminate:] The Internet connection appears to be offline. [NSURLErrorDomain:-1009]
            12/18/12 7:10:43.179 PM GoogleSoftwareUpdateDaemon[214]: -[KSServerUpdateRequest(PrivateMethods) fetcher:failedWithError:] KSServerUpdateRequest fetch failed. (productIDs: com.google.Keystone, ... (2)) [com.google.UpdateEngine.CoreErrorDomain:702 - 'https://tools.google.com/service/update2'] (The Internet connection appears to be offline. [NSURLErrorDomain:-1009])
            12/18/12 7:10:43.180 PM GoogleSoftwareUpdateDaemon[214]: -[KSUpdateCheckAction(PrivateMethods) finishAction] KSUpdateCheckAction found updates: {( )}
            12/18/12 7:10:43.184 PM GoogleSoftwareUpdateDaemon[214]: -[KSPrefetchAction performAction] KSPrefetchAction no updates to prefetch.
            12/18/12 7:10:43.186 PM GoogleSoftwareUpdateDaemon[214]: -[KSMultiUpdateAction performAction] KSSilentUpdateAction had no updates to apply.
            12/18/12 7:10:43.187 PM GoogleSoftwareUpdateDaemon[214]: -[KSMultiUpdateAction performAction] KSPromptAction had no updates to apply.
            12/18/12 7:10:43.190 PM GoogleSoftwareUpdateDaemon[214]: -[KSUpdateEngine(PrivateMethods) updateFinish] KSUpdateEngine update processing complete.
            12/18/12 7:10:43.362 PM appleprofilepolicyd[235]: appleprofilepolicyd: profiling drivers not loaded, loading
            12/18/12 7:10:43.431 PM SRFeature[237]: Display server path : /Applications/Splashtop Streamer.app/Contents/MacOS/SRFeature.app/Contents/MacOS/SRXDisplayServer.app/Contents/Ma cOS/SRXDisplayServer
            12/18/12 7:10:43.452 PM SRXDisplayServer[240]: No SRX Display Card
            12/18/12 7:10:43.707 PM SRFeature[237]: pInfo data: [2][b000000][b][0]
            12/18/12 7:10:43.708 PM SRFeature[237]: FH: GetInfo
            12/18/12 7:10:44.037 PM configd[17]: network changed: v4(en0+:10.10.1.104) DNS+ Proxy+ SMB
            12/18/12 7:10:45.041 PM ntpd[74]: proto: precision = 1.000 usec
            12/18/12 7:10:45.545 PM blued[71]: kBTXPCUpdateUserPreferences gConsoleUserUID = 501
            12/18/12 7:10:46.258 PM com.apple.launchd[1]: (com.apple.xprotectupdater[76]) Exited with code: 252
            12/18/12 7:10:46.000 PM kernel[0]: Intel82574L::timeoutHandler - no link - reset the chipset once  1face001, 0
            12/18/12 7:10:46.774 PM GoogleSoftwareUpdateDaemon[214]: -[KeystoneDaemon logServiceState] GoogleSoftwareUpdate daemon (1.1.0.3659) vending:
                      com.google.Keystone.Daemon.UpdateEngine: 1 connection(s)
            12/18/12 7:10:46.000 PM kernel[0]: Intel82574L::setLinkStatus - not active  1face001, 0
            12/18/12 7:10:47.000 PM kernel[0]: Intel82574L::setLinkStatus - not active  1face001, 0
            12/18/12 7:10:47.608 PM locationd[260]: NOTICE,Location icon should now be in state 0
            12/18/12 7:10:47.670 PM UserEventAgent[149]: cannot find fw daemon port 1102
            12/18/12 7:10:48.744 PM launchctl[271]: launchctl: Dubious permissions on file (skipping): /Library/LaunchAgents/com.adobe.AAM.Updater-1.0.plist
            12/18/12 7:10:48.938 PM CalendarAgent[177]: *** -[IADomainCache init]: IA domains cache is out of date.
            12/18/12 7:10:49.121 PM Splashtop Streamer[198]: SRFEAT_NOTIFY_SERVER_CLOUD_NOTIFY_MSG
            12/18/12 7:10:49.121 PM Splashtop Streamer[198]: [ProcServerNotification] SRS_SERVER_RTN_INFO : [200][.srloginnotify.xml]
            12/18/12 7:10:49.146 PM Splashtop Streamer[198]:   receive backend string notify
            12/18/12 7:10:49.147 PM Splashtop Streamer[198]: -[CMXMLParser length]: unrecognized selector sent to instance 0x101320040
            12/18/12 7:10:49.150 PM Splashtop Streamer[198]: (
                      0   CoreFoundation                      0x00007fff8e1830a6 __exceptionPreprocess + 198
                      1   libobjc.A.dylib                     0x00007fff8f4463f0 objc_exception_throw + 43
                      2   CoreFoundation                      0x00007fff8e2196ea -[NSObject(NSObject) doesNotRecognizeSelector:] + 186
                      3   CoreFoundation                      0x00007fff8e1715ce ___forwarding___ + 414
                      4   CoreFoundation                      0x00007fff8e1713b8 _CF_forwarding_prep_0 + 232
                      5   Foundation                          0x00007fff8dd3bea8 -[NSPlaceholderString initWithString:] + 169
                      7   CoreFoundation                      0x00007fff8e1df5cc ____CFXNotificationPostToken_block_invoke_0 + 284
                      8   CoreFoundation                      0x00007fff8e140272 __CFRUNLOOP_IS_CALLING_OUT_TO_A_BLOCK__ + 18
                      9   CoreFoundation                      0x00007fff8e100a4f __CFRunLoopDoBlocks + 255
                      10  CoreFoundation                      0x00007fff8e125220 __CFRunLoopRun + 1904
                      11  CoreFoundation                      0x00007fff8e1246b2 CFRunLoopRunSpecific + 290
                      12  HIToolbox                           0x00007fff900580a4 RunCurrentEventLoopInMode + 209
                      13  HIToolbox                           0x00007fff90057e42 ReceiveNextEventCommon + 356
                      14  HIToolbox                           0x00007fff90057cd3 BlockUntilNextEventMatchingListInMode + 62
                      15  AppKit                              0x00007fff93023613 _DPSNextEvent + 685
                      16  AppKit                              0x00007fff93022ed2 -[NSApplication nextEventMatchingMask:untilDate:inMode:dequeue:] + 128
                      17  AppKit                              0x00007fff9301a283 -[NSApplication run] + 517
                      18  AppKit                              0x00007fff92fbecb6 NSApplicationMain + 869
            12/18/12 7:10:52.613 PM Splashtop Streamer[198]: going to close SRFeature.
            12/18/12 7:10:52.616 PM configd[17]: network changed: v4(en0:10.10.1.104, en2+:10.10.1.105) DNS* Proxy SMB
            12/18/12 7:10:52.631 PM UserEventAgent[11]: Captive: en2: Not probing 'abrazite' (protected network)
            12/18/12 7:10:52.634 PM configd[17]: network changed: v4(en0:10.10.1.104, en2!:10.10.1.105) DNS Proxy SMB
            12/18/12 7:10:54.823 PM awacsd[108]: Exiting
            12/18/12 7:10:55.247 PM Splashtop Streamer[198]: cannot create remote port
            12/18/12 7:10:55.248 PM Splashtop Streamer[198]: Error -50 sending  ping to SRFeature.
            12/18/12 7:10:55.248 PM Splashtop Streamer[198]: Can not find SRFeature alive
            12/18/12 7:10:55.248 PM Splashtop Streamer[198]: going to close SRFeature.
            12/18/12 7:10:57.462 PM SRServiceAgent[182]: cannot find SRFeature
            12/18/12 7:11:02.051 PM com.apple.launchd[1]: (com.apple.coreservices.appleid.authentication[137]) Exit timeout elapsed (20 seconds). Killing
            12/18/12 7:11:02.463 PM SRServiceAgent[182]: cannot find SRFeature
            12/18/12 7:11:06.287 PM SRFeature[282]: Display server path : /Applications/Splashtop Streamer.app/Contents/MacOS/SRFeature.app/Contents/MacOS/SRXDisplayServer.app/Contents/Ma cOS/SRXDisplayServer
            12/18/12 7:11:06.306 PM SRXDisplayServer[284]: No SRX Display Card
            12/18/12 7:11:06.532 PM SRFeature[282]: pInfo data: [2][b000000][b][0]
            12/18/12 7:11:06.533 PM SRFeature[282]: FH: GetInfo
            12/18/12 7:11:11.052 PM Splashtop Streamer[198]: SRFEAT_NOTIFY_SERVER_CLOUD_NOTIFY_MSG
            12/18/12 7:11:11.052 PM Splashtop Streamer[198]: [ProcServerNotification] SRS_SERVER_RTN_INFO : [200][.srloginnotify.xml]
            12/18/12 7:11:11.054 PM Splashtop Streamer[198]:   receive backend string notify
            12/18/12 7:11:11.054 PM Splashtop Streamer[198]: -[CMXMLParser length]: unrecognized selector sent to instance 0x104502a00
            12/18/12 7:11:11.055 PM Splashtop Streamer[198]: (
                      6   Splashtop Streamer                  0x000000010000be8f -[SplashtopRemoteAppDelegate getXMLContent:] + 199
                      19  Splashtop Streamer                  0x00000001000018b4 start + 52
            12/18/12 7:11:11.056 PM Splashtop Streamer[198]:   receive backend string notify
            12/18/12 7:11:11.056 PM Splashtop Streamer[198]: -[CMXMLParser length]: unrecognized selector sent to instance 0x104502a00
            12/18/12 7:11:11.057 PM Splashtop Streamer[198]: (
                      10  CoreFoundation                      0x00007fff8e124db4 __CFRunLoopRun + 772
                      13  HIToolbox                           0x00007fff90057d84 ReceiveNextEventCommon + 166
            12/18/12 7:11:11.964 PM GoogleSoftwareUpdateDaemon[214]: -[KeystoneDaemon main] GoogleSoftwareUpdateDaemon inactive, shutdown.
            12/18/12 7:11:38.918 PM launchctl[293]: launchctl: Dubious permissions on file (skipping): /Library/LaunchAgents/com.adobe.AAM.Updater-1.0.plist
            12/18/12 7:11:38.949 PM distnoted[295]: Bug: 12C60: liblaunch.dylib + 23849 [2F71CAF8-6524-329E-AC56-C506658B4C0C]: 0x25
            12/18/12 7:11:39.163 PM com.apple.SecurityServer[15]: Session 100002 created
            12/18/12 7:13:10.420 PM librariand[311]: MMe quota status changed: under quota
            12/18/12 7:13:10.668 PM com.apple.XType.FontHelper[314]: FontHelper:  message received. (<dictionary: 0x7fc76a900920> { count = 2, contents =
                      "query" => <string: 0x7fc76a900a80> { length = 107, contents = "com_apple_ats_name_postscript == "Arial-BoldMT" && kMDItemContentTypeTree != com.adobe.postscript-lwfn-font" }
                      "restricted" => <bool: 0x7fff78a6c320>: true
            12/18/12 7:13:10.668 PM com.apple.XType.FontHelper[314]: AutoActivation:  scopes (
                "/Library/Application Support/Apple/Fonts"
            12/18/12 7:13:10.690 PM com.apple.XType.FontHelper[314]: FontHelper:  message received. (<dictionary: 0x7fc76db002e0> { count = 2, contents =
                      "query" => <string: 0x7fc76db00030> { length = 102, contents = "com_apple_ats_name_postscript == "ArialMT" && kMDItemContentTypeTree != com.adobe.postscript-lwfn-font" }
            12/18/12 7:13:10.690 PM com.apple.XType.FontHelper[314]: AutoActivation:  scopes (
            12/18/12 7:13:43.643 PM Finder[161]: CFPropertyListCreateFromXMLData(): Old-style plist parser: missing semicolon in dictionary on line 1. Parsing will be abandoned. Break on _CFPropertyListMissingSemicolon to debug.
            12/18/12 7:13:43.644 PM Finder[161]: CFPropertyListCreateFromXMLData(): Old-style plist parser: missing semicolon in dictionary on line 1. Parsing will be abandoned. Break on _CFPropertyListMissingSemicolon to debug.
            12/18/12 7:13:43.645 PM Finder[161]: CFPropertyListCreateFromXMLData(): Old-style plist parser: missing semicolon in dictionary on line 1. Parsing will be abandoned. Break on _CFPropertyListMissingSemicolon to debug.
            12/18/12 7:13:43.646 PM Finder[161]: CFPropertyListCreateFromXMLData(): Old-style plist parser: missing semicolon in dictionary on line 1. Parsing will be abandoned. Break on _CFPropertyListMissingSemicolon to debug.
            12/18/12 7:13:43.647 PM Finder[161]: CFPropertyListCreateFromXMLData(): Old-style plist parser: missing semicolon in dictionary on line 1. Parsing will be abandoned. Break on _CFPropertyListMissingSemicolon to debug.
            12/18/12 7:13:43.651 PM Finder[161]: CFPropertyListCreateFromXMLData(): Old-style plist parser: missing semicolon in dictionary on line 1. Parsing will be abandoned. Break on _CFPropertyListMissingSemicolon to debug.
            12/18/12 7:15:03.037 PM mdworker[299]: CFPropertyListCreateFromXMLData(): Old-style plist parser: missing semicolon in dictionary on line 1. Parsing will be abandoned. Break on _CFPropertyListMissingSemicolon to debug.
            12/18/12 7:15:12.000 PM kernel[0]: Adobe Photoshop  (map: 0xffffff80600a03a0) triggered DYLD shared region unnest for map: 0xffffff80600a03a0, region 0x7fff8bc00000->0x7fff8be00000. While not abnormal for debuggers, this increases system memory footprint until the target exits.
            12/18/12 7:15:12.000 PM kernel[0]: ALF: ifnet_get_address_list_family error 12
            12/18/12 7:15:36.744 PM com.apple.kextd[12]: Warning: /Volumes/Macintosh HD/System/Library/Extensions: No such file or directory
            12/18/12 7:18:11.945 PM Adobe Photoshop CS6[341]: *** WARNING: -[NSObject(NSKeyValueCoding) takeValuesFromDictionary:] is deprecated. It will be removed in a future release and should no longer be used.
            12/18/12 7:19:29.230 PM launchctl[373]: launchctl: Dubious permissions on file (skipping): /Library/LaunchAgents/com.adobe.AAM.Updater-1.0.plist
            12/18/12 7:21:10.350 PM WindowServer[122]: _CGXGetWindowOrderingGroup: Operation on a window 0x45 requiring rights 0x5 by caller Photoshop
            12/18/12 7:26:09.426 PM fseventsd[50]: could not open <</Volumes/Clone Vertex SSD (513.11 GB)/.fseventsd/fseventsd-uuid>> (No such file or directory)
            12/18/12 7:26:09.426 PM fseventsd[50]: log dir: /Volumes/Clone Vertex SSD (513.11 GB)/.fseventsd getting new uuid: 9B9D60DB-2CD0-4707-80C3-07128C0CF523
            12/18/12 7:26:09.000 PM kernel[0]: hfs: Initializing the journal (joffset 0xede000 sz 0x2800000)...
            12/18/12 7:26:11.620 PM coreservicesd[28]: Received request to reset fmod watch. Latest received id is 936834379561. Latest sent id is 936834379561
            12/18/12 7:26:52.695 PM Adobe Bridge CS6[336]: CFPropertyListCreateFromXMLData(): Old-style plist parser: missing semicolon in dictionary on line 1. Parsing will be abandoned. Break on _CFPropertyListMissingSemicolon to debug.
            12/18/12 7:27:54.653 PM com.apple.launchd.peruser.501[146]: (com.apple.PackageKit.InstallStatus) Throttling respawn: Will start in 8 seconds
            12/18/12 7:27:55.837 PM WindowServer[122]: dict count after removing entry for window 0x2c is 0
            12/18/12 7:27:55.846 PM WindowServer[122]: CGXGetConnectionProperty: Invalid connection 30335
            12/18/12 7:27:55.847 PM WindowServer[122]: CGXGetConnectionProperty: Invalid connection 30335
            12/18/12 7:27:55.854 PM com.apple.launchd.peruser.501[146]: (com.prosofteng.DGMonitor[188]) Exited: Killed: 9
            12/18/12 7:27:55.864 PM coreservicesd[28]: SendFlattenedData, got error #268435459 (ipc/send) invalid destination port from ::mach_msg(), sending notification kLSNotifyApplicationDeath to notificationID=167
            12/18/12 7:27:55.864 PM coreservicesd[28]: SendFlattenedData, got error #268435459 (ipc/send) invalid destination port from ::mach_msg(), sending notification kLSNotifyApplicationDeath to notificationID=176
            12/18/12 7:27:55.865 PM coreservicesd[28]: SendFlattenedData, got error #268435459 (ipc/send) invalid destination port from ::mach_msg(), sending notification kLSNotifyApplicationDeath to notificationID=167
            12/18/12 7:27:55.865 PM coreservicesd[28]: SendFlattenedData, got error #268435459 (ipc/send) invalid destination port from ::mach_msg(), sending notification kLSNotifyApplicationDeath to notificationID=176
            12/18/12 7:27:55.866 PM coreservicesd[28]: SendFlattenedData, got error #268435459 (ipc/send) invalid destination port from ::mach_msg(), sending notification kLSNotifyApplicationDeath to notificationID=167
            12/18/12 7:27:55.878 PM coreservicesd[28]: SendFlattenedData, got error #268435460 (ipc/send) timed out from ::mach_msg(), sending notification kLSNotifyApplicationDeath to notificationID=257
            12/18/12 7:27:55.879 PM WindowServer[122]: CGXGetConnectionProperty: Invalid connection 30335
            12/18/12 7:27:55.881 PM Splashtop Streamer[198]: going to close SRFeature.
            12/18/12 7:27:56.130 PM coreservicesd[28]: SendFlattenedData, got error #268435459 (ipc/send) invalid destination port from ::mach_msg(), sending notification kLSNotifyApplicationDeath to notificationID=152
            12/18/12 7:27:56.130 PM WindowServer[122]: CGXGetConnectionProperty: Invalid connection 30335
            12/18/12 7:27:56.131 PM WindowServer[122]: CGXGetConnectionProperty: Invalid connection 30335
            12/18/12 7:27:56.392 PM loginwindow[94]: sendQuitEventToApp (FMCore): AESendMessage returned error -1712
            12/18/12 7:27:56.395 PM com.apple.launchd.peruser.501[146]: ([0x0-0x21021].com.apple.AppleSpell[274]) Exited: Terminated: 15
            12/18/12 7:27:56.396 PM com.apple.launchd.peruser.501[146]: ([0x0-0x31031].com.adobe.switchboard-2.0[339]) Exited: Terminated: 15
            12/18/12 7:27:56.396 PM com.apple.launchd.peruser.501[146]: ([0x0-0x34034].com.adobe.dynamiclinkmanager[351]) Exited: Terminated: 15
            12/18/12 7:27:56.396 PM com.apple.launchd.peruser.501[146]: (com.apple.mdworker.shared.04000000-0000-0000-0000-000000000000[410]) Exited: Killed: 9
            12/18/12 7:27:56.396 PM com.apple.launchd.peruser.501[146]: (com.apple.mdworker.bundles[422]) Exited: Killed: 9
            12/18/12 7:27:56.397 PM com.apple.launchd.peruser.501[146]: ([0x0-0x2b02b].com.apple.ImageCaptureExtension2[317]) Exited: Killed: 9
            12/18/12 7:27:56.399 PM com.apple.launchd.peruser.501[146]: ([0x0-0x2a02a].com.apple.Preview[308]) Exited: Killed: 9
            12/18/12 7:27:56.884 PM Splashtop Streamer[198]:    AC Power
            12/18/12 7:27:57.913 PM loginwindow[94]: DEAD_PROCESS: 94 console
            12/18/12 7:27:57.974 PM airportd[424]: _doAutoJoin: Already associated to “abrazite”. Bailing on auto-join.
            12/18/12 7:27:58.109 PM com.apple.kextd[12]: Warning: /Volumes/Macintosh HD/System/Library/Extensions: No such file or directory
            12/18/12 7:27:58.112 PM shutdown[425]: reboot by Imacom:
            12/18/12 7:27:58.112 PM shutdown[425]: SHUTDOWN_TIME: 1355876878 112433
            12/18/12 7:27:58.146 PM ntpd[74]: ntpd exiting on signal 15
            12/18/12 7:28:43.000 PM bootlog[0]: BOOT_TIME 1355876923 0
            12/18/12 7:28:45.000 PM kernel[0]: PMAP: PCID enabled
            12/18/12 7:28:45.000 PM kernel[0]: Darwin Kernel Version 12.2.0: Sat Aug 25 00:48:52 PDT 2012; root:xnu-2050.18.24~1/RELEASE_X86_64
            12/18/12 7:28:45.000 PM kernel[0]: vm_page_bootstrap: 8048491 free pages and 307349 wired pages
            12/18/12 7:28:45.000 PM kernel[0]: kext submap [0xffffff7f80741000 - 0xffffff8000000000], kernel text [0xffffff8000200000 - 0xffffff8000741000]
            12/18/12 7:28:45.000 PM kernel[0]: zone leak detection enabled
            12/18/12 7:28:45.000 PM kernel[0]: standard timeslicing quantum is 10000 us
            12/18/12 7:28:45.000 PM kernel[0]: standard background quantum is 2500 us
            12/18/12 7:28:45.000 PM kernel[0]: mig_table_max_displ = 74
            12/18/12 7:28:45.000 PM kernel[0]: corecrypto kext started!
            12/18/12 7:28:45.000 PM kernel[0]: Running kernel space in FIPS MODE
            12/18/12 7:28:45.000 PM kernel[0]: Plist hmac value is    735d392b68241ef173d81097b1c8ce9ba283521626d1c973ac376838c466757d
            12/18/12 7:28:45.000 PM kernel[0]: Computed hmac value is 735d392b68241ef173d81097b1c8ce9ba283521626d1c973ac376838c466757d
            12/18/12 7:28:45.000 PM kernel[0]: corecrypto.kext FIPS integrity POST test passed!
            12/18/12 7:28:45.000 PM kernel[0]: corecrypto.kext FIPS AES CBC POST test passed!
            12/18/12 7:28:45.000 PM kernel[0]: corecrypto.kext FIPS TDES CBC POST test passed!
            12/18/12 7:28:45.000 PM kernel[0]: corecrypto.kext FIPS AES ECB AESNI POST test passed!
            12/18/12 7:28:45.000 PM kernel[0]: corecrypto.kext FIPS AES XTS AESNI POST test passed!
            12/18/12 7:28:45.000 PM kernel[0]: corecrypto.kext FIPS SHA POST test passed!
            12/18/12 7:28:45.000 PM kernel[0]: corecrypto.kext FIPS HMAC POST test passed!
            12/18/12 7:28:45.000 PM kernel[0]: corecrypto.kext FIPS ECDSA POST test passed!
            12/18/12 7:28:45.000 PM kernel[0]: corecrypto.kext FIPS DRBG POST test passed!
            12/18/12 7:28:45.000 PM kernel[0]: corecrypto.kext FIPS POST passed!
            12/18/12 7:28:45.000 PM kernel[0]: AppleACPICPU: ProcessorId=0 LocalApicId=0 Enabled
            12/18/12 7:28:45.000 PM kernel[0]: AppleACPICPU: ProcessorId=1 LocalApicId=32 Enabled
            12/18/12 7:28:45.000 PM kernel[0]: AppleACPICPU: ProcessorId=2 LocalApicId=2 Enabled
            12/18/12 7:28:45.000 PM kernel[0]: AppleACPICPU: ProcessorId=3 LocalApicId=34 Enabled
            12/18/12 7:28:45.000 PM kernel[0]: AppleACPICPU: ProcessorId=4 LocalApicId=4 Enabled
            12/18/12 7:28:45.000 PM kernel[0]: AppleACPICPU: ProcessorId=5 LocalApicId=36 Enabled
            12/18/12 7:28:45.000 PM kernel[0]: AppleACPICPU: ProcessorId=6 LocalApicId=16 Enabled
            12/18/12 7:28:45.000 PM kernel[0]: AppleACPICPU: ProcessorId=7 LocalApicId=48 Enabled
            12/18/12 7:28:45.000 PM kernel[0]: AppleACPICPU: ProcessorId=8 LocalApicId=18 Enabled
            12/18/12 7:28:45.000 PM kernel[0]: AppleACPICPU: ProcessorId=9 LocalApicId=50 Enabled
            12/18/12 7:28:45.000 PM kernel[0]: AppleACPICPU: ProcessorId=10 LocalApicId=20 Enabled
            12/18/12 7:28:45.000 PM kernel[0]: AppleACPICPU: ProcessorId=11 LocalApicId=52 Enabled
            12/18/12 7:28:45.000 PM kernel[0]: AppleACPICPU: ProcessorId=12 LocalApicId=1 Enabled
            12/18/12 7:28:45.000 PM kernel[0]: AppleACPICPU: ProcessorId=13 LocalApicId=33 Enabled
            12/18/12 7:28:45.000 PM kernel[0]: AppleACPICPU: ProcessorId=14 LocalApicId=3 Enabled
            12/18/12 7:28:45.000 PM kernel[0]: AppleACPICPU: ProcessorId=15 LocalApicId=35 Enabled
            12/18/12 7:28:45.000 PM kernel[0]: AppleACPICPU: ProcessorId=16 LocalApicId=5 Enabled
            12/18/12 7:28:45.000 PM kernel[0]: AppleACPICPU: ProcessorId=17 LocalApicId=37 Enabled
            12/18/12 7:28:45.000 PM kernel[0]: AppleACPICPU: ProcessorId=18 LocalApicId=17 Enabled
            12/18/12 7:28:45.000 PM kernel[0]: AppleACPICPU: ProcessorId=19 LocalApicId=49 Enabled
            12/18/12 7:28:45.000 PM kernel[0]: AppleACPICPU: ProcessorId=20 LocalApicId=19 Enabled
            12/18/12 7:28:45.000 PM kernel[0]: AppleACPICPU: ProcessorId=21 LocalApicId=51 Enabled
            12/18/12 7:28:45.000 PM kernel[0]: AppleACPICPU: ProcessorId=22 LocalApicId=21 Enabled
            12/18/12 7:28:45.000 PM kernel[0]: AppleACPICPU: ProcessorId=23 LocalApicId=53 Enabled
            12/18/12 7:28:45.000 PM kernel[0]: calling mpo_policy_init for TMSafetyNet
            12/18/12 7:28:45.000 PM kernel[0]: Security policy loaded: Safety net for Time Machine (TMSafetyNet)
            12/18/12 7:28:45.000 PM kernel[0]: calling mpo_policy_init for Sandbox
            12/18/12 7:28:45.000 PM kernel[0]: Security policy loaded: Seatbelt sandbox policy (Sandbox)
            12/18/12 7:28:45.000 PM kernel[0]: calling mpo_policy_init for Quarantine
            12/18/12 7:28:45.000 PM kernel[0]: Security policy loaded: Quarantine policy (Quarantine)
            12/18/12 7:28:45.000 PM kernel[0]: Copyright (c) 1982, 1986, 1989, 1991, 1993
            12/18/12 7:28:45.000 PM kernel[0]: The Regents of the University of California. All rights reserved.
            12/18/12 7:28:45.000 PM kernel[0]: MAC Framework successfully initialized
            12/18/12 7:28:45.000 PM kernel[0]: using 16384 buffer headers and 10240 cluster IO buffer headers
            12/18/12 7:28:45.000 PM kernel[0]: IOAPIC: Version 0x20 Vectors 64:87
            12/18/12 7:28:45.000 PM kernel[0]: ACPI: System State [S0 S3 S4 S5]
            12/18/12 7:28:45.000 PM kernel[0]: PFM64 (40 cpu) 0xff80000000, 0x80000000
            12/18/12 7:28:45.000 PM kernel[0]: [ PCI configuration begin ]
            12/18/12 7:28:45.000 PM kernel[0]: AppleIntelCPUPowerManagement: Turbo Ratios 222233
            12/18/12 7:28:45.000 PM kernel[0]: AppleIntelCPUPowerManagement: (built 23:03:24 Jun 24 2012) initialization complete
            12/18/12 7:28:45.000 PM kernel[0]: console relocated to 0xff80010000
            12/18/12 7:28:43.750 PM com.apple.launchd[1]: *** launchd[1] has started up. ***
            12/18/12 7:28:45.000 PM kernel[0]: PCI configuration changed (bridge=7 device=2 cardbus=0)
            12/18/12 7:28:45.000 PM kernel[0]: [ PCI configuration end, bridges 15 devices 51 ]
            12/18/12 7:28:45.000 PM kernel[0]: mbinit: done [128 MB total pool size, (85/42) split]
            12/18/12 7:28:45.000 PM kernel[0]: Pthread support ABORTS when sync kernel primitives misused
            12/18/12 7:28:45.000 PM kernel[0]: ETH1 cannot assert wake from D3cold
            12/18/12 7:28:45.000 PM kernel[0]: ETH0 cannot assert wake from D3cold
            12/18/12 7:28:45.000 PM kernel[0]: rooting via boot-uuid from /chosen: 725DCE99-0F42-35F8-83CF-232BE79F8C0F
            12/18/12 7:28:45.000 PM kernel[0]: Waiting on <dict ID="0"><key>IOProviderClass</key><string ID="1">IOResources</string><key>IOResourceMatch</key><string ID="2">boot-uuid-media</string></dict>
            12/18/12 7:28:45.000 PM kernel[0]: com.apple.AppleFSCompressionTypeZlib kmod start
            12/18/12 7:28:45.000 PM kernel[0]: com.apple.AppleFSCompressionTypeDataless kmod start
            12/18/12 7:28:45.000 PM kernel[0]: com.apple.AppleFSCompressionTypeZlib load succeeded
            12/18/12 7:28:45.000 PM kernel[0]: com.apple.AppleFSCompressionTypeDataless load succeeded
            12/18/12 7:28:45.000 PM kernel[0]: AppleIntelCPUPowerManagementClient: ready
            12/18/12 7:28:45.000 PM kernel[0]: Intel82574L::start - Built Jun 24 2012 23:07:38 -- running on device at b9 d0 f0
            12/18/12 7:28:45.000 PM kernel[0]: Intel82574L::start - Built Jun 24 2012 23:07:38 -- running on device at b10 d0 f0
            12/18/12 7:28:45.000 PM kernel[0]: BTCOEXIST off
            12/18/12 7:28:45.000 PM kernel[0]: BRCM tunables:
            12/18/12 7:28:45.000 PM kernel[0]: pullmode[1] txringsize[  256] reapmin[   32] reapcount[  128]
            12/18/12 7:28:45.000 PM kernel[0]: highWaterMark: VO[  192]  VI[  192]  BE[  192]  BK[  192]
            12/18/12 7:28:45.000 PM kernel[0]: FireWire (OHCI) TI ID 823f built-in now active, GUID 78ca39fffe123fc8; max speed s800.
            12/18/12 7:28:45.000 PM kernel[0]: Got boot device = IOService:/AppleACPIPlatformExpert/PCI0@0/AppleACPIPCI/SATA@1F,2/AppleAHCI/PRT2@2/IOAHCID evice@0/AppleAHCIDiskDriver/IOAHCIBlockStorageDevice/IOBlockStorageDriver/OCZ-VERTEX4 Media/IOGUIDPartitionScheme/Vertex SSD @2
            12/18/12 7:28:45.000 PM kernel[0]: BSD root: disk0s2, major 1, minor 2
            12/18/12 7:28:45.000 PM kernel[0]: Kernel is LP64
            12/18/12 7:28:45.000 PM kernel[0]: USBF:          1.488          [0xffffff805e536200] The IOUSBFamily is having trouble enumerating a USB device that has been plugged in.  It will keep retrying.  (Port 3 of Hub at 0x1d100000)
            12/18/12 7:28:43.750 PM com.apple.launchd[1]: *** Shutdown logging is enabled. ***
            12/18/12 7:28:45.617 PM com.apple.launchd[1]: (com.apple.automountd) Unknown key for boolean: NSSupportsSuddenTermination
            12/18/12 7:28:46.000 PM kernel[0]: Intel82574L: Ethernet address e8:06:88:cc:10:44
            12/18/12 7:28:46.000 PM kernel[0]: Intel82574L: Ethernet address e8:06:88:cc:24:84
            12/18/12 7:28:46.000 PM kernel[0]: AirPort_Brcm4331: Ethernet address 00:26:08:fd:72:91
            12/18/12 7:28:46.000 PM kernel[0]: IO80211Controller::dataLinkLayerAttachComplete():  adding AppleEFINVRAM notification
            12/18/12 7:28:46.874 PM airportd[27]: _processDLILEvent: en2 attached (down)
            12/18/12 7:28:46.925 PM com.apple.SecurityServer[15]: Session 100000 created
            12/18/12 7:28:46.000 PM kernel[0]: createVirtIf(): ifRole = 1
            12/18/12 7:28:46.000 PM kernel[0]: in func createVirtualInterface ifRole = 1
            12/18/12 7:28:46.000 PM kernel[0]: AirPort_Brcm4331_P2PInterface::init name <p2p0> role 1 this 0xffffff805efb4800
            12/18/12 7:28:46.000 PM kernel[0]: AirPort_Brcm4331_P2PInterface::init() <p2p> role 1
            12/18/12 7:28:46.000 PM kernel[0]: Created virtif 0xffffff805efb4800 p2p0
            12/18/12 7:28:46.966 PM com.apple.SecurityServer[15]: Entering service
            12/18/12 7:28:47.000 PM kernel[0]: Intel82574L::setLinkStatus - not active  1face000, 0
            12/18/12 7:28:47.033 PM UserEventAgent[11]: Captive: [HandleNetworkInformationChanged:2435] nwi_state_copy returned NULL
            12/18/12 7:28:47.179 PM mDNSResponder[52]: mDNSResponder mDNSResponder-379.32.1 (Aug 31 2012 19:05:06) starting OSXVers 12
            12/18/12 7:28:47.265 PM systemkeychain[55]: done file: /var/run/systemkeychaincheck.done
            12/18/12 7:28:47.292 PM mDNSResponder[52]: D2D_IPC: Loaded
            12/18/12 7:28:47.292 PM mDNSResponder[52]: D2DInitialize succeeded
            12/18/12 7:28:47.000 PM kernel[0]: AirPort: Link Down on en2. Reason 8 (Disassociated because station leaving).
            12/18/12 7:28:47.000 PM kernel[0]: en2::IO80211Interface::postMessage bssid changed
            12/18/12 7:28:47.000 PM kernel[0]: Previous Shutdown Cause: 5
            12/18/12 7:28:47.000 PM kernel[0]: IOBluetoothUSBDFU::probe
            12/18/12 7:28:47.000 PM kernel[0]: IOBluetoothUSBDFU::probe ProductID - 0x8215 FirmwareVersion - 0x0201
            12/18/12 7:28:47.000 PM kernel[0]: [BroadcomBluetoothHCIControllerUSBTransport][start] -- completed
            12/18/12 7:28:47.000 PM kernel[0]: [IOBluetoothHCIController][staticBluetoothHCIControllerTransportShowsUp] -- Received Bluetooth Controller register service notification
            12/18/12 7:28:47.000 PM kernel[0]: [IOBluetoothHCIController][start] -- completed
            12/18/12 7:28:47.000 PM kernel[0]: [IOBluetoothHCIController::setConfigState] calling registerService
            12/18/12 7:28:47.000 PM kernel[0]: [AGPM Controller] unknownPlatform
            12/18/12 7:28:47.000 PM kernel[0]: AppleTyMCEDriver::start coreVIDPID = 0x2c708086 Number of packages = 1 Number of cpus = 24 memory monitor trough PCI
            12/18/12 7:28:47.000 PM kernel[0]: Intel82574L::setLinkStatus - not active  1face001, 0
            12/18/12 7:28:47.781 PM configd[17]: bootp_session_transmit: bpf_write(en2) failed: Network is down (50)
            12/18/12 7:28:47.781 PM configd[17]: DHCP en2: INIT-REBOOT transmit failed
            12/18/12 7:28:47.801 PM configd[17]: setting hostname to "Mac-Pro-Imacom-5.local"
            12/18/12 7:28:47.000 PM kernel[0]: USBF:          4.750          [0xffffff805e536200] The IOUSBFamily was not able to enumerate a device.
            12/18/12 7:28:47.000 PM kernel[0]: DSMOS has arrived
            12/18/12 7:28:47.811 PM configd[17]: network changed: DNS*
            12/18/12 7:28:48.000 PM kernel[0]: Intel82574L::setLinkStatus - not active  1face000, 0
            12/18/12 7:28:48.000 PM kernel[0]: USBF:          5.815          [0xffffff805e536200] The IOUSBFamily is having trouble enumerating a USB device that has been plugged in.  It will keep retrying.  (Port 3 of Hub at 0x1d100000)
            12/18/12 7:28:48.000 PM kernel[0]: MacAuthEvent en2   Auth result for: 00:0f:66:43:a4:fa  MAC AUTH succeeded
            12/18/12 7:28:48.000 PM kernel[0]: wlEvent: en2 en2 Link UP virtIf = 0
            12/18/12 7:28:48.000 PM kernel[0]: AirPort: Link Up on en2
            12/18/12 7:28:48.000 PM kernel[0]: en2: BSSID changed to 00:0f:66:43:a4:fa
            12/18/12 7:28:48.000 PM kernel[0]: en2::IO80211Interface::postMessage bssid changed
            12/18/12 7:28:49.000 PM kernel[0]: AirPort: RSN handshake complete on en2
            12/18/12 7:28:49.383 PM airportd[27]: _doAutoJoin: Already associated to “abrazite”. Bailing on auto-join.
            12/18/12 7:28:49.759 PM hidd[96]: Posting 'com.apple.iokit.hid.displayStatus' notifyState=1
            12/18/12 7:28:49.762 PM hidd[96]: void __IOHIDLoadBundles(): Loaded 0 HID plugins
            12/18/12 7:28:49.780 PM coreservicesd[28]: FindBestLSSession(), no match for inSessionID 0xfffffffffffffffc auditTokenInfo( uid=0 euid=0 auSessionID=100000 create=false
            12/18/12 7:28:49.783 PM appleeventsd[101]: main: Starting up
            12/18/12 7:28:49.796 PM kdc[94]: label: default
            12/18/12 7:28:49.796 PM kdc[94]:           dbname: od:/Local/Default
            12/18/12 7:28:49.796 PM kdc[94]:           mkey_file: /var/db/krb5kdc/m-key
            12/18/12 7:28:49.796 PM kdc[94]:           acl_file: /var/db/krb5kdc/kadmind.acl
            12/18/12 7:28:49.809 PM com.apple.usbmuxd[75]: usbmuxd-296.3 on Jul 25 2012 at 00:28:37, running 64 bit
            12/18/12 7:28:49.813 PM kdc[94]: WARNING Found KDC certificate (O=System Identity,CN=com.apple.kerberos.kdc)is missing the PK-INIT KDC EKU, this is bad for interoperability.
            12/18/12 7:28:49.817 PM com.apple.kextd[12]: Can't load /System/Library/Extensions/CiscoVPN.kext - no code for running kernel's architecture.
            12/18/12 7:28:49.820 PM SystemStarter[77]: Cisco Systems VPN Client Kernel Extension (115) did not complete successfully
            12/18/12 7:28:49.820 PM SystemStarter[77]: The following StartupItems failed to start properly:
            12/18/12 7:28:49.820 PM SystemStarter[77]: /System/Library/StartupItems/CiscoVPN
            12/18/12 7:28:49.820 PM SystemStarter[77]:  - execution of Startup script failed
            12/18/12 7:28:49.854 PM mds[88]: (Normal) FMW: FMW 0 0
            12/18/12 7:28:49.854 PM netbiosd[87]: Unable to start NetBIOS name service:
            12/18/12 7:28:49.855 PM loginwindow[91]: Login Window Application Started
            12/18/12 7:28:49.863 PM awacsd[105]: Starting awacsd connectivity-78 (Jul 26 2012 14:37:46)
            12/18/12 7:28:49.867 PM awacsd[105]: InnerStore CopyAllZones: no info in Dynamic Store
            12/18/12 7:28:49.869 PM kdc[94]: KDC started
            12/18/12 7:28:49.900 PM locationd[92]: NOTICE,Location icon should now be in state 0
            12/18/12 7:28:49.921 PM WindowServer[120]: Server is starting up
            12/18/12 7:28:49.924 PM WindowServer[120]: Session 256 retained (2 references)
            12/18/12 7:28:49.924 PM WindowServer[120]: Session 256 released (1 references)
            12/18/12 7:28:49.930 PM apsd[107]: CGSLookupServerRootPort: Failed to look up the port for "com.apple.windowserver.active" (1102)
            12/18/12 7:28:49.931 PM apsd[107]: CGSLookupServerRootPort: Failed to look up the port for "com.apple.windowserver.active" (1102)
            12/18/12 7:28:49.000 PM kernel[0]: macx_swapon SUCCESS
            12/18/12 7:28:49.932 PM WindowServer[120]: Session 256 retained (2 references)
            12/18/12 7:28:49.933 PM WindowServer[120]: init_page_flip: page flip mode is on
            12/18/12 7:28:50.127 PM BBDaemon[109]: IOBSDNameMatching returned a NULL dictionary.
            12/18/12 7:28:50.000 PM kernel[0]: Ethernet [Intel82574L]: Link up on en0, 1-Gigabit, Full-duplex, Symmetric flow-control, Debug [796d,af48,0de1,0200,c5e1,2800]
            12/18/12 7:28:50.000 PM kernel[0]: Intel82574L::setLinkStatus - active  1face000, b
            12/18/12 7:28:51.430 PM WindowServer[120]: mux_initialize: Couldn't find any matches
            12/18/12 7:28:51.445 PM WindowServer[120]: GLCompositor enabled for tile size [256 x 256]
            12/18/12 7:28:51.445 PM WindowServer[120]: CGXGLInitMipMap: mip map mode is on
            12/18/12 7:28:51.470 PM WindowServer[120]: WSMachineUsesNewStyleMirroring: false
            12/18/12 7:28:51.471 PM WindowServer[120]: Display 0x04241064: GL mask 0x1; bounds (0, 0)[2560 x 1600], 57 modes available
            Main, Active, on-line, enabled, boot, Vendor 610, Model 9232, S/N 2009ce4, Unit 0, Rotation 0
            UUID 0x000006100000923202009ce400000000
            12/18/12 7:28:51.471 PM WindowServer[120]: Display 0x003f003e: GL mask 0x4; bounds (0, 0)[0 x 0], 1 modes available
            off-line, enabled, Vendor ffffffff, Model ffffffff, S/N ffffffff, Unit 2, Rotation 0
            UUID 0xffffffffffffffffffffffff003f003e
            12/18/12 7:28:51.471 PM WindowServer[120]: Display 0x003f003d: GL mask 0x2; bounds (0, 0)[0 x 0], 1 modes available
            off-line, enabled, Vendor ffffffff, Model ffffffff, S/N ffffffff, Unit 1, Rotation 0
            UUID 0xffffffffffffffffffffffff003f003d
            12/18/12 7:28:51.480 PM WindowServer[120]: Created shield window 0x5 for display 0x04241064
            12/18/12 7:28:51.480 PM WindowServer[120]: Created shield window 0x6 for display 0x003f003e
            12/18/12 7:28:51.480 PM WindowServer[120]: Created shield window 0x7 for display 0x003f003d
            12/18/12 7:28:51.481 PM WindowServer[120]: Display 0x04241064: GL mask 0x1; bounds (0, 0)[2560 x 1600], 57 modes available
            12/18/12 7:28:51.481 PM WindowServer[120]: Display 0x003f003e: GL mask 0x4; bounds (3584, 0)[1 x 1], 1 modes available
            12/18/12 7:28:51.481 PM WindowServer[120]: Display 0x003f003d: GL mask 0x2; bounds (3585, 0)[1 x 1], 1 modes available
            12/18/12 7:28:51.481 PM WindowServer[120]: CGXPerformInitialDisplayConfiguration
            12/18/12 7:28:51.482 PM WindowServer[120]:   Display 0x04241064: MappedDisplay Unit 0; Vendor 0x610 Model 0x9232 S/N 33594596 Dimensions 25.24 x 15.79; online enabled, Bounds (0,0)[2560 x 1600], Rotation 0, Resolution 1
            12/18/12 7:28:51.482 PM WindowServer[120]:   Display 0x003f003e: MappedDisplay Unit 2; Vendor 0xffffffff Model 0xffffffff S/N -1 Dimensions 0.00 x 0.00; offline enabled, Bounds (3584,0)[1 x 1], Rotation 0, Resolution 1
            12/18/12 7:28:51.482 PM WindowServer[120]:   Display 0x003f003d: MappedDisplay Unit 1; Vendor 0xffffffff Model 0xffffffff S/N -1 Dimensions 0.00 x 0.00; offline enabled, Bounds (3585,0)[1 x 1], Rotation 0, Resolution 1
            12/18/12 7:28:51.506 PM WindowServer[120]: GLCompositor: GL renderer id 0x01021b01, GL mask 0x00000007, accelerator 0x00003f37, unit 0, caps QEX|QGL|MIPMAP, vram 1024 MB
            12/18/12 7:28:51.506 PM WindowServer[120]: GLCompositor: GL renderer id 0x01021b01, GL mask 0x00000007, texture units 8, texture max 16384, viewport max {16384, 16384}, extensions FPRG|NPOT|GLSL|FLOAT
            12/18/12 7:28:51.509 PM loginwindow[91]: **DMPROXY** Found `/System/Library/CoreServices/DMProxy'.
            12/18/12 7:28:51.511 PM launchctl[126]: launchctl: Dubious permissions on file (skipping): /Library/LaunchAgents/com.adobe.AAM.Updater-1.0.plist
            12/18/12 7:28:51.547 PM WindowServer[120]: Created shield window 0x8 for display 0x04241064
            12/18/12 7:28:51.547 PM WindowServer[120]: Display 0x04241064: MappedDisplay Unit 0; ColorProfile { 2, "Cinema HD"}; TransferFormula (1.000000, 1.000000, 1.000000)
            12/18/12 7:28:51.552 PM launchctl[128]: launchctl: Dubious permissions on file (skipping): /Library/LaunchAgents/com.adobe.AAM.Updater-1.0.plist
            12/18/12 7:28:51.567 PM launchctl[128]: com.apple.findmymacmessenger: Already loaded
            12/18/12 7:28:51.579 PM com.apple.SecurityServer[15]: Session 100005 created
            12/18/12 7:28:51.594 PM airportd[27]: _doAutoJoin: Already associated to “abrazite”. Bailing on auto-join.
            12/18/12 7:28:51.623 PM loginwindow[91]: Login Window Started Security Agent
            12/18/12 7:28:51.682 PM SecurityAgent[139]: This is the first run
            12/18/12 7:28:51.683 PM SecurityAgent[139]: MacBuddy was run = 0
            12/18/12 7:28:51.692 PM WindowServer[120]: MPAccessSurfaceForDisplayDevice: Set up page flip mode on display 0x04241064 device: 0x10265f320  isBackBuffered: 1 numComp: 3 numDisp: 3
            12/18/12 7:28:51.731 PM SecurityAgent[139]: User info context values set for Imacom
            12/18/12 7:28:51.793 PM coreaudiod[137]: 2012-12-18 07:28:51.792397 PM [AirPlay] Started browsing for _airplay._tcp.
            12/18/12 7:28:51.793 PM coreaudiod[137]: 2012-12-18 07:28:51.793254 PM [AirPlay] Started browsing for _raop._tcp.
            12/18/12 7:28:52.000 PM kernel[0]: USBF:          9.311          [0xffffff805e536200] The IOUSBFamily was not able to enumerate a device.
            12/18/12 7:28:52.030 PM loginwindow[91]: Login Window - Returned from Security Agent
            12/18/12 7:28:52.033 PM loginwindow[91]: ERROR | ScreensharingLoginNotification | Failed sending message to screen sharing GetScreensharingPort, err: 1102
            12/18/12 7:28:52.062 PM loginwindow[91]: USER_PROCESS: 91 console
            12/18/12 7:28:52.063 PM airportd[27]: _doAutoJoin: Already associated to “abrazite”. Bailing on auto-join.
            12/18/12 7:28:52.086 PM launchctl[144]: launchctl: Dubious permissions on file (skipping): /Library/LaunchAgents/com.adobe.AAM.Updater-1.0.plist
            12/18/12 7:28:52.105 PM launchctl[145]: launchctl: Dubious permissions on file (skipping): /Library/LaunchAgents/com.adobe.AAM.Updater-1.0.plist
            12/18/12 7:28:52.111 PM com.apple.launchd[1]: (com.wacom.wacomtablet[135]) Exited with code: 255
            12/18/12 7:28:52.119 PM com.apple.launchd.peruser.501[143]: (com.apple.gamed) Ignored this key: UserName
            12/18/12 7:28:52.119 PM com.apple.launchd.peruser.501[143]: (com.apple.gamed) Ignored this key: GroupName
            12/18/12 7:28:52.119 PM com.apple.launchd.peruser.501[143]: (com.apple.ReportCrash) Falling back to default Mach exception handler. Could not find: com.apple.ReportCrash.Self
            12/18/12 7:28:52.123 PM loginwindow[91]: Connection with distnoted server was invalidated
            12/18/12 7:28:52.129 PM distnoted[147]: # distnote server agent  absolute time: 9.484124964   civil time: Tue Dec 18 19:28:52 2012   pid: 147 uid: 501  root: no
            12/18/12 7:28:52.170 PM WindowServer[120]: **DMPROXY** (2) Found `/System/Library/CoreServices/DMProxy'.
            12/18/12 7:28:52.199 PM WindowServer[120]: Display 0x04241064: MappedDisplay Unit 0; ColorProfile { 2, "Cinema HD"}; TransferFormula (1.000000, 1.000000, 1.000000)
            12/18/12 7:28:52.211 PM com.apple.SecurityServer[15]: Session 100003 created
            12/18/12 7:28:52.272 PM com.apple.launchd.peruser.501[143]: (com.akamai.single-user-client[187]) Bug: 12C60: launchd + 95444 [7DCC9489-2DF5-3807-83FA-EF5666EE8078]: 0xd
            12/18/12 7:28:52.272 PM com.apple.launchd.peruser.501[143]: (com.akamai.client.plist[188]) Bug: 12C60: launchd + 95444 [7DCC9489-2DF5-3807-83FA-EF5666EE8078]: 0xd
            12/18/12 7:28:52.274 PM talagent[155]: _LSSetApplicationInformationItem(kLSDefaultSessionID, asn, _kLSApplicationIsHiddenKey, hidden ? kCFBooleanTrue : kCFBooleanFalse, NULL) produced OSStatus -50 on line 623 in TCApplication.m
            12/18/12 7:28:52.274 PM talagent[155]: _LSSetApplicationInformationItem(kLSDefaultSessionID, asn, TAL_kLSIsProxiedForTALKey, kCFBooleanTrue, NULL) produced OSStatus -50 on line 626 in TCApplication.m
            12/18/12 7:28:52.278 PM com.apple.launchd.peruser.501[143]: (com.apple.afpstat-qfa[177]) Exited with code: 2
            12/18/12 7:28:52.278 PM com.apple.launchd.peruser.501[143]: (com.adobe.ARM.0d92f8f114b2d0af95462120762f939f6c66651ac8ac214cb7bdbd84[191]) Exited with code: 2
            12/18/12 7:28:52.310 PM SRServiceAgent[179]: service agent got ipc message: 1094931542
            12/18/12 7:28:52.311 PM SRServiceAgent[179]: try start streamer
            12/18/12 7:28:52.314 PM SRServiceAgent[179]: start check timer
            12/18/12 7:28:52.315 PM SRServiceAgent[179]: create new task
            12/18/12 7:28:52.316 PM SRServiceAgent[179]: task is not running, launch task
            12/18/12 7:28:52.343 PM launchctl[197]: launchctl: Dubious permissions on file (skipping): /Library/LaunchAgents/com.adobe.AAM.Updater-1.0.plist
            12/18/12 7:28:52.400 PM NetworkBrowserAgent[198]: Starting NetworkBrowserAgent
            12/18/12 7:28:52.000 PM kernel[0]: CODE SIGNING: cs_invalid_page(0x1000): p=181[GoogleSoftwareUp] clearing CS_VALID
            12/18/12 7:28:52.575 PM Splashtop Streamer[194]: NSWindow does not support utility styleMask 0x10
            12/18/12 7:28:52.577 PM Splashtop Streamer[194]: NSWindow does not support utility styleMask 0x10
            12/18/12 7:28:52.580 PM Splashtop Streamer[194]: NSWindow does not support utility styleMask 0x10
            12/18/12 7:28:52.586 PM Splashtop Streamer[194]: NSWindow does not support utility styleMask 0x10
            12/18/12 7:28:52.588 PM Splashtop Streamer[194]: NSWindow does not support utility styleMask 0x10
            12/18/12 7:28:52.601 PM Splashtop Streamer[194]: Could not connect the action toggleServer: to target of class SplashtopRemoteAppDelegate
            12/18/12 7:28:52.606 PM Splashtop Streamer[194]: -[DisplayView initWithFrame:] [{{0, 0}, {380, 70}}][{{0, 0}, {380, 70}}]
            12/18/12 7:28:52.613 PM Splashtop Streamer[194]: -[DisplayView(Private) setTextField:string:] 1 [{{20, 0}, {380, 70}}]
            12/18/12 7:28:52.614 PM Splashtop Streamer[194]: -[DisplayView(Private) setTextField:string:] 2 [{{20, 0}, {85, 14}}]
            12/18/12 7:28:52.617 PM GoogleSoftwareUpdateDaemon[209]: -[KeystoneDaemon logServiceState] GoogleSoftwareUpdate daemon (1.1.0.3659) vending:
            12/18/12 7:28:52.620 PM Splashtop Streamer[194]: ---- http://www.splashtop.com/splashtop2#otherproducts-tab
            12/18/12 7:28:52.624 PM Splashtop Streamer[194]: going to close SRFeature.
            12/18/12 7:28:52.637 PM GoogleSoftwareUpdateDaemon[209]: -[KSUpdateEngine updateProductID:] KSUpdateEngine updating product ID: "com.google.Keystone"
            12/18/12 7:28:52.644 PM GoogleSoftwareUpdateDaemon[209]: -[KSCheckAction performAction] KSCheckAction checking 1 ticket(s).
            12/18/12 7:28:52.656 PM GoogleSoftwareUpdateDaemon[209]: -[KSUpdateCheckAction performAction] KSUpdateCheckAction starting update check for ticket(s): {(
                      <KSTicket:0x607a3f0
                                version=1.1.0.3659
                                xc=<KSPathExistenceChecker:0x6078e30 path=/Library/Google/GoogleSoftwareUpdate/GoogleSoftwareUpdate.bundle/>
                                serverType=Omaha
            Using server: <KSOmahaServer:0x4c78b20
                      engine=<KSDaemonUpdateEngine:0x43785e0>
                      params={
                                ActivesInfo = {
                                                    LastActiveDate = 2012-12-19 00:28:52 +0000;
                                UserInitiated = 0;
                                IsSystem = 1;
                                          ".www.google.com",
                                          ".corp.google.com"
            12/18/12 7:28:52.666 PM GoogleSoftwareUpdateDaemon[209]: -[KSUpdateCheckAction performAction] KSUpdateCheckAction running KSServerUpdateRequest: <KSOmahaServerUpdateRequest:0x4379db0
                      server=<KSOmahaServer:0x4c78b20>
                      runningFetchers=0
                      tickets=1
                      activeTickets=0
                      rollCallTickets=0
                      body=
                                    </o:app>
                                </o:gupdate>
            12/18/12 7:28:52.738 PM DGAgent[185]: Resolved DG link from bookmark. /Applications/Drive Genius 3.app
            12/18/12 7:28:52.790 PM launchctl[219]: launchctl: Dubious permissions on file (skipping): /Library/LaunchAgents/com.adobe.AAM.Updater-1.0.plist
            12/18/12 7:28:52.930 PM GoogleSoftwareUpdateDaemon[209]: -[KSOutOfProcessFetcher(PrivateMethods) helperDidTerminate:] The Internet connection appears to be offline. [NSURLErrorDomain:-1009]
            12/18/12 7:28:52.930 PM GoogleSoftwareUpdateDaemon[209]: -[KSServerUpdateRequest(PrivateMethods) fetcher:failedWithError:] KSServerUpdateRequest fetch failed. (productIDs: com.google.Keystone) [com.google.UpdateEngine.CoreErrorDomain:702 - 'https://tools.google.com/service/update2'] (The Internet connection appears to be offline. [NSURLErrorDomain:-1009])
            12/18/12 7:28:52.931 PM GoogleSoftwareUpdateDaemon[209]: -[KSUpdateCheckAction(PrivateMethods) finishAction] KSUpdateCheckAction found updates: {( )}
            12/18/12 7:28:52.937 PM GoogleSoftwareUpdateDaemon[209]: -[KSPrefetchAction performAction] KSPrefetchAction no updates to prefetch.
            12/18/12 7:28:52.938 PM GoogleSoftwareUpdateDaemon[209]: -[KSMultiUpdateAction performAction] KSSilentUpdateAction had no updates to apply.
            12/18/12 7:28:52.940 PM GoogleSoftwareUpdateDaemon[209]: -[KSMultiUpdateAction performAction] KSPromptAction had no updates to apply.
            12/18/12 7:28:52.945 PM GoogleSoftwareUpdateDaemon[209]: -[KSUpdateEngine(PrivateMethods) updateFinish] KSUpdateEngine update processing complete.
            12/18/12 7:28:53.000 PM kernel[0]: USBF:          10.230          [0xffffff805e536200] The IOUSBFamily is having trouble enumerating a USB device that has been plugged in.  It will keep retrying.  (Port 3 of Hub at 0x1d100000)
            12/18/12 7:28:53.077 PM configd[17]: network changed: v4(en2+:10.10.1.105) DNS+ Proxy+ SMB
            12/18/12 7:28:53.099 PM UserEventAgent[11]: Captive: en2: Not probing 'abrazite' (protected network)
            12/18/12 7:28:53.103 PM configd[17]: network changed: v4(en2!:10.10.1.105) DNS Proxy SMB
            12/18/12 7:28:53.183 PM Trim Enabler[228]: ON
            12/18/12 7:28:53.275 PM YouSendIt Desktop App[231]: Set Version number 2.0.0.204
            12/18/12 7:28:53.482 PM WindowServer[120]: **DMPROXY** (2) Found `/System/Library/CoreServices/DMProxy'.
            12/18/12 7:28:53.525 PM WindowServer[120]: Display 0x04241064: MappedDisplay Unit 0; ColorProfile { 2, "Cinema HD"}; TransferFormula (1.000000, 1.000000, 1.000000)
            12/18/12 7:28:53.549 PM WindowServer[120]: Display 0x04241064: MappedDisplay Unit 0; ColorProfile { 2, "Cinema HD"}; TransferFormula (1.000000, 1.000000, 1.000000)
            12/18/12 7:28:53.650 PM coreservicesd[28]: Can't change an application into stopped state for app App:"Finder" [ 0x0/0x11011]  @ 0x0x7fbf46200280 because it's already been started.
            12/18/12 7:28:53.655 PM YouSendIt Desktop App[231]: finderPearlServerConnection = (** NSConnection 0x112c00560 receivePort <NSMachPort: 0x112c00820> sendPort <NSMachPort: 0x112c00820> refCount 1 remoteUsesKeyedDO: 0 **), pearlServices = <YSIPearlServices: 0x112c00e70>
            12/18/12 7:28:53.686 PM YouSendIt Desktop App[231]: Need to check OSAX bundle
            12/18/12 7:28:53.687 PM YouSendIt Desktop App[231]: internal version=2.0.0.204, installed version=2.0.0.204
            12/18/12 7:28:53.688 PM YouSendIt Desktop App[231]: No valid connection
            12/18/12 7:28:53.688 PM SRFeature[240]: Display server path : /Applications/Splashtop Streamer.app/Contents/MacOS/SRFeature.app/Contents/MacOS/SRXDisplayServer.app/Contents/Ma cOS/SRXDisplayServer
            12/18/12 7:28:53.702 PM WindowServer[120]: CGXSetWindowShadowParameters: Operation on a window 0x1a requiring rights kCGSWindowRightOwner by caller talagent
            12/18/12 7:28:53.710 PM GoogleSoftwareUpdateDaemon[209]: -[KSUpdateEngine updateAllProducts] KSUpdateEngine updating all installed products.
            12/18/12 7:28:53.713 PM GoogleSoftwareUpdateDaemon[209]: -[KSCheckAction performAction] KSCheckAction checking 2 ticket(s).
            12/18/12 7:28:53.716 PM SRXDisplayServer[242]: No SRX Display Card
            12/18/12 7:28:53.724 PM coreservicesd[28]: SendFlattenedData, got error #268435460 (ipc/send) timed out from ::mach_msg(), sending notification kLSNotifyApplicationReady to notificationID=165
            12/18/12 7:28:53.730 PM GoogleSoftwareUpdateDaemon[209]: -[KSUpdateCheckAction performAction] KSUpdateCheckAction starting update check for ticket(s): {(
                      <KSTicket:0x627a250
                                version=1.1.0.3659
                                xc=<KSPathExistenceChecker:0x6279430 path=/Library/Google/GoogleSoftwareUpdate/GoogleSoftwareUpdate.bundle/>
                                serverType=Omaha
                      <KSTicket:0x6279780
                                xc=<KSPathExistenceChecker:0x62791b0 path=/Library/Application Support/Google/GoogleTalkPlugin.app>
                                serverType=Omaha
            Using server: <KSOmahaServer:0x627b430
                      params={
                                ActivesInfo = {
                                UserInitiated = 0;
                                IsSystem = 1;
                                          ".www.google.com",
                                          ".corp.google.com"
            12/18/12 7:28:53.731 PM GoogleSoftwareUpdateDaemon[209]: -[KSUpdateCheckAction performAction] KSUpdateCheckAction running KSServerUpdateRequest: <KSOmahaServerUpdateRequest:0x627c4a0
                      server=<KSOmahaServer:0x627b430>
                      runningFetchers=0
                      tickets=2
                      activeTickets=0
                      rollCallTickets=0
                      body=
                                    </o:app>
                                    </o:app>
                                </o:gupdate>
            12/18/12 7:28:53.773 PM appleprofilepolicyd[245]: appleprofilepolicyd: profiling drivers not loaded, loading
            12/18/12 7:28:53.906 PM coreservicesd[28]: SendFlattenedData, got error #268435460 (ipc/send) timed out from ::mach_msg(), sending notification kLSNotifyApplicationReady to notificationID=178
            12/18/12 7:28:53.976 PM SRFeature[240]: pInfo data: [2][b000000][b][0]
            12/18/12 7:28:53.978 PM SRFeature[240]: FH: GetInfo
            12/18/12 7:28:54.000 PM kernel[0]: USBF:          11. 94          [0xffffff805e536200] The IOUSBFamily gave up enumerating a USB device after 10 retries.  (Port 3 of Hub at 0x1d100000)
            12/18/12 7:28:54.000 PM kernel[0]: USBF:          11. 94          [0xffffff805e536200] The IOUSBFamily was not able to enumerate a device.
            12/18/12 7:28:54.199 PM GoogleSoftwareUpdateDaemon[209]: -[KSUpdateCheckAction(KSServerUpdateRequestDelegate) serverRequest:fetchedWithResponse:] KSUpdateCheckAction received KSServerUpdateResponse: <KSOmahaServerUpdateResponse:0x407a6d0
                      status=200
                      tickets=2
                      activeTickets=0
                      rollCallTickets=0
                      data=
                                <gupdate xmlns="http://www.google.com/update2/response" protocol="2.0" server="prod">
                                    <daystart elapsed_seconds="59334"></daystart>
                                    <app appid="com.google.Keystone" status="ok">
                                        <updatecheck status="noupdate"></updatecheck>
                                    </app>
                                    <app appid="com.google.talkplugin" status="ok">
                                    </app>
                                </gupdate>
            12/18/12 7:28:54.214 PM GoogleSoftwareUpdateDaemon[209]: -[KSUpdateCheckAction(PrivateMethods) finishAction] KSUpdateCheckAction found updates: {( )}
            12/18/12 7:28:54.218 PM GoogleSoftwareUpdateDaemon[209]: -[KSPrefetchAction performAction] KSPrefetchAction no updates to prefetch.
            12/18/12 7:28:54.219 PM GoogleSoftwareUpdateDaemon[209]: -[KSMultiUpdateAction performAction] KSSilentUpdateAction had no updates to apply.
            12/18/12 7:28:54.220 PM GoogleSoftwareUpdateDaemon[209]: -[KSMultiUpdateAction performAction] KSPromptAction had no updates to apply.
            12/18/12 7:28:54.222 PM GoogleSoftwareUpdateDaemon[209]: -[KSUpdateEngine(PrivateMethods) updateFinish] KSUpdateEngine update processing complete.
            12/18/12 7:28:54.329 PM configd[17]: network changed: v4(en0+:10.10.1.104, en2) DNS! Proxy! SMB
            12/18/12 7:28:54.361 PM com.apple.launchd[1]: (com.apple.xprotectupdater[73]) Exited with code: 255
            12/18/12 7:28:54.558 PM ntpd[71]: proto: precision = 1.000 usec
            12/18/12 7:28:54.587 PM coreservicesd[28]: SendFlattenedData, got error #268435460 (ipc/send) timed out from ::mach_msg(), sending notification kLSNotifyChildApplicationLaunch to notificationID=131
            12/18/12 7:28:54.925 PM Finder[158]: SDL checking if Pearl was loaded. hasLoaded=NO, addr=10a24e2f4
            12/18/12 7:28:54.925 PM Finder[158]: not loaded, returning 1
            12/18/12 7:28:54.936 PM Finder[158]: handleYSILoad
            12/18/12 7:28:54.940 PM Finder[158]: YSI pearl loaded
            12/18/12 7:28:55.017 PM Finder[158]: pearl listener registered
            12/18/12 7:28:55.000 PM kernel[0]: Finder (map: 0xffffff805f7c0d98) triggered DYLD shared region unnest for map: 0xffffff805f7c0d98, region 0x7fff8f400000->0x7fff8f600000. While not abnormal for debuggers, this increases system memory footprint until the target exits.
            12/18/12 7:28:55.666 PM blued[68]: kBTXPCUpdateUserPreferences gConsoleUserUID = 501
            12/18/12 7:28:56.577 PM GoogleSoftwareUpdateDaemon[209]: -[KeystoneDaemon logServiceState] GoogleSoftwareUpdate daemon (1.1.0.3659) vending:
            12/18/12 7:28:56.853 PM Trim Enabler[228]: ON
            12/18/12 7:28:56.000 PM kernel[0]: Intel82574L::timeoutHandler - no link - reset the chipset once  1face001, 0
            12/18/12 7:28:56.000 PM kernel[0]: Intel82574L::setLinkStatus - not active  1face001, 0
            12/18/12 7:28:57.000 PM kernel[0]: Intel82574L::setLinkStatus - not active  1face001, 0
            12/18/12 7:28:57.568 PM locationd[285]: NOTICE,Location icon should now be in state 0
            12/18/12 7:28:57.631 PM UserEventAgent[146]: cannot find fw daemon port 1102
            12/18/12 7:28:58.290 PM CalendarAgent[174]: *** -[IADomainCache init]: IA domains cache is out of date.
            12/18/12 7:28:58.474 PM Splashtop Streamer[194]: SRFEAT_NOTIFY_SERVER_CLOUD_NOTIFY_MSG
            12/18/12 7:28:58.474 PM Splashtop Streamer[194]: [ProcServerNotification] SRS_SERVER_RTN_INFO : [200][.srloginnotify.xml]
            12/18/12 7:28:58.475 PM Splashtop Streamer[194]:   receive backend string notify
            12/18/12 7:28:58.476 PM Splashtop Streamer[194]: -[CMXMLParser length]: unrecognized selector sent to instance 0x10310e9c0
            12/18/12 7:28:58.480 PM Splashtop Streamer[194]: (
                      0   CoreFoundation                      0x00007fff8cd380a6 __exceptionPreprocess + 198
                      1   libobjc.A.dylib                     0x00007fff8dffb3f0 objc_exception_throw + 43
                      2   CoreFoundation                      0x00007fff8cdce6ea -[NSObject(NSObject) doesNotRecognizeSelector:] + 186
                      3   CoreFoundation                      0x00007fff8cd265ce ___forwarding___ + 414
                      4   CoreFoundation                      0x00007fff8cd263b8 _CF_forwarding_prep_0 + 232
                      5   Foundation                          0x00007fff8c8f0ea8 -[NSPlaceholderString initWithString:] + 169
                      7   CoreFoundation                      0x00007fff8cd945cc ____CFXNotificationPostToken_block_invoke_0 + 284
                      8   CoreFoundation                      0x00007fff8ccf5272 __CFRUNLOOP_IS_CALLING_OUT_TO_A_BLOCK__ + 18
                      9   CoreFoundation                      0x00007fff8ccb5a4f __CFRunLoopDoBlocks + 255
                      10  CoreFoundation                      0x00007fff8ccd9db4 __CFRunLoopRun + 772
                      11  CoreFoundation                      0x00007fff8ccd96b2 CFRunLoopRunSpecific + 290
                      12  HIToolbox                           0x00007fff8ec0d0a4 RunCurrentEventLoopInMode + 209
                      13  HIToolbox                           0x00007fff8ec0cd84 ReceiveNextEventCommon + 166
                      14  HIToolbox                           0x00007fff8ec0ccd3 BlockUntilNextEventMatchingListInMode + 62
                      15  AppKit                              0x00007fff91bd8613 _DPSNextEvent + 685
                      16  AppKit                              0x00007fff91bd7ed2 -[NSApplication nextEventMatchingMask:untilDate:inMode:dequeue:] + 128
                      17  AppKit                              0x00007fff91bcf283 -[NSApplication run] + 517
                      18  AppKit                              0x00007fff91b73cb6 NSApplicationMain + 869
            12/18/12 7:28:58.796 PM launchctl[300]: launchctl: Dubious permissions on file (skipping): /Library/LaunchAgents/com.adobe.AAM.Updater-1.0.plist
            12/18/12 7:28:59.665 PM Trim Enabler[228]: /Applications/Trim En
            12/18/12 7:29:04.939 PM awacsd[105]: Exiting
            12/18/12 7:29:12.171 PM com.apple.launchd[1]: (com.apple.coreservices.appleid.authentication[134]) Exit timeout elapsed (20 seconds). Killing
            12/18/12 7:29:22.620 PM GoogleSoftwareUpdateDaemon[209]: -[KeystoneDaemon main] GoogleSoftwareUpdateDaemon inactive, shutdown.
            12/18/12 7:29:27.796 PM launchctl[313]: launchctl: Dubious permissions on file (skipping): /Library/LaunchAgents/com.adobe.AAM.Updater-1.0.plist
            12/18/12 7:29:27.827 PM distnoted[315]: Bug: 12C60: liblaunch.dylib + 23849 [2F71CAF8-6524-329E-AC56-C506658B4C0C]: 0x25
            12/18/12 7:29:28.042 PM com.apple.SecurityServer[15]: Session 100002 created
            12/18/12 7:29:52.260 PM mdworker[323]: CFPropertyListCreateFromXMLData(): Old-style plist parser: missing semicolon in dictionary on line 1. Parsing will be abandoned. Break on _CFPropertyListMissingSemicolon to debug.
            12/18/12 7:31:02.100 PM Finder[158]: pearlBrowserSelectionChanged.
            12/18/12 7:31:08.035 PM Finder[158]: CFPropertyListCreateFromXMLData(): Old-style plist parser: missing semicolon in dictionary on line 1. Parsing will be abandoned. Break on _CFPropertyListMissingSemicolon to debug.
            12/18/12 7:31:08.036 PM Finder[158]: CFPropertyListCreateFromXMLData(): Old-style plist parser: missing semicolon in dictionary on line 1. Parsing will be abandoned. Break on _CFPropertyListMissingSemicolon to debug.
            12/18/12 7:31:08.037 PM Finder[158]: CFPropertyListCreateFromXMLData(): Old-style plist parser: missing semicolon in dictionary on line 1. Parsing will be abandoned. Break on _CFPropertyListMissingSemicolon to debug.
            12/18/12 7:31:08.038 PM Finder[158]: CFPropertyListCreateFromXMLData(): Old-style plist parser: missing semicolon in dictionary on line 1. Parsing will be abandoned. Break on _CFPropertyListMissingSemicolon to debug.
            12/18/12 7:31:23.000 PM kernel[0]: Sandbox: sandboxd(338) deny mach-lookup com.apple.coresymbolicationd
            12/18/12 7:31:30.033 PM sandboxd[338]: ([335]) WebProcess(335) deny mach-lookup ATS Query Port 182
            12/18/12 7:31:30.573 PM sandboxd[338]: ([335]) WebProcess(335) deny mach-lookup ATS Query Port 182
            12/18/12 7:31:30.582 PM sandboxd[338]: ([335]) WebProcess(335) deny mach-lookup ATS Query Port 182
            12/18/12 7:31:38.983 PM GoogleTalkPlugin[345]: objc[345]: Class MacCocoaSocketServerHelper is implemented in both /Library/Application Support/Google/GoogleTalkPlugin.app/Contents/MacOS/GoogleTalkPlugin and /Library/Application Support/Google/GoogleTalkPlugin.app/Contents/Frameworks/libgoogletalkremoting.dylib. One of the two will be used. Which one is undefined.
            12/18/12 7:31:57.334 PM Finder[158]: pearlBrowserSelectionChanged.
            12/18/12 7:31:57.687 PM login[352]: USER_PROCESS: 352 ttys000
            12/18/12 7:31:57.739 PM launchctl[362]: launchctl: Dubious permissions on file (skipping): /Library/LaunchAgents/com.adobe.AAM.Updater-1.0.plist
            12/18/12 7:33:02.590 PM Finder[158]: pearlBrowserSelectionChanged.
            12/18/12 7:33:27.777 PM Finder[158]: pearlBrowserSelectionChanged.
            12/18/12 7:33:46.935 PM com.apple.kextd[12]: Warning: /Volumes/Macintosh HD/System/Library/Extensions: No such file or directory
            12/18/12 7:34:01.143 PM com.apple.launchd.peruser.501[143]: (com.apple.PackageKit.InstallStatus) Throttling respawn: Will start in 8 seconds
            12/18/12 7:34:01.148 PM login[352]: DEAD_PROCESS: 352 ttys000
            12/18/12 7:34:01.630 PM WindowServer[120]: CGXGetConnectionProperty: Invalid connection 37635
            12/18/12 7:34:01.631 PM WindowServer[120]: CGXGetConnectionProperty: Invalid connection 37635
            12/18/12 7:34:01.632 PM WindowServer[120]: CGXGetConnectionProperty: Invalid connection 37635
            12/18/12 7:34:01.637 PM WindowServer[120]: dict count after removing entry for window 0x2e is 0
            12/18/12 7:34:01.641 PM com.apple.launchd.peruser.501[143]: (com.prosofteng.DGMonitor[185]) Exited: Killed: 9
            12/18/12 7:34:01.645 PM coreservicesd[28]: SendFlattenedData, got error #268435459 (ipc/send) invalid destination port from ::mach_msg(), sending notification kLSNotifyApplicationDeath to notificationID=166
            12/18/12 7:34:01.645 PM coreservicesd[28]: SendFlattenedData, got error #268435459 (ipc/send) invalid destination port from ::mach_msg(), sending notification kLSNotifyApplicationDeath to notificationID=177
            12/18/12 7:34:01.646 PM coreservicesd[28]: SendFlattenedData, got error #268435459 (ipc/send) invalid destination port from ::mach_msg(), sending notification kLSNotifyApplicationDeath to notificationID=166
            12/18/12 7:34:01.646 PM coreservicesd[28]: SendFlattenedData, got error #268435459 (ipc/send) invalid destination port from ::mach_msg(), sending notification kLSNotifyApplicationDeath to notificationID=177
            12/18/12 7:34:01.647 PM coreservicesd[28]: SendFlattenedData, got error #268435459 (ipc/send) invalid destination port from ::mach_msg(), sending notification kLSNotifyApplicationDeath to notificationID=166
            12/18/12 7:34:01.658 PM coreservicesd[28]: SendFlattenedData, got error #268435460 (ipc/send) timed out from ::mach_msg(), sending notification kLSNotifyApplicationDeath to notificationID=241
            12/18/12 7:34:01.661 PM Splashtop Streamer[194]: going to close SRFeature.
            12/18/12 7:34:01.661 PM WindowServer[120]: CGXGetConnectionProperty: Invalid connection 37635
            12/18/12 7:34:01.662 PM WindowServer[120]: CGXGetConnectionProperty: Invalid connection 37635
            12/18/12 7:34:01.910 PM coreservicesd[28]: SendFlattenedData, got error #268435459 (ipc/send) invalid destination port from ::mach_msg(), sending notification kLSNotifyApplicationDeath to notificationID=155
            12/18/12 7:34:01.910 PM WindowServer[120]: CGXGetConnectionProperty: Invalid connection 37635
            12/18/12 7:34:01.911 PM WindowServer[120]: CGXGetConnectionProperty: Invalid connection 37635
            12/18/12 7:34:02.165 PM loginwindow[91]: sendQuitEventToApp (FMCore): AESendMessage returned error -1712
            12/18/12 7:34:02.188 PM loginwindow[91]: sendQuitEventToApp (Image Capture Extension): AESendMessage returned error -600
            12/18/12 7:34:02.188 PM loginwindow[91]: Application terminate returned -600
            12/18/12 7:34:02.188 PM com.apple.launchd.peruser.501[143]: ([0x0-0x24024].com.apple.AppleSpell[259]) Exited: Terminated: 15
            12/18/12 7:34:02.190 PM com.apple.launchd.peruser.501[143]: (com.apple.mdworker.shared.03000000-0000-0000-0000-000000000000[323]) Exited: Killed: 9
            12/18/12 7:34:02.394 PM SRServiceAgent[179]: cannot find SRFeature
            12/18/12 7:34:02.664 PM Splashtop Streamer[194]:    AC Power
            12/18/12 7:34:03.705 PM loginwindow[91]: DEAD_PROCESS: 91 console
            12/18/12 7:34:03.728 PM com.apple.kextd[12]: Warning: /Volumes/Macintosh HD/System/Library/Extensions: No such file or directory
            12/18/12 7:34:03.733 PM shutdown[382]: reboot by Imacom:
            12/18/12 7:34:03.733 PM shutdown[382]: SHUTDOWN_TIME: 1355877243 732876
            12/18/12 7:34:03.736 PM ntpd[71]: ntpd exiting on signal 15
            12/18/12 7:34:47.000 PM bootlog[0]: BOOT_TIME 1355877287 0
            12/18/12 7:34:49.000 PM kernel[0]: PMAP: PCID enabled
            12/18/12 7:34:49.000 PM kernel[0]: Darwin Kernel Version 12.2.0: Sat Aug 25 00:48:52 PDT 2012; root:xnu-2050.18.24~1/RELEASE_X86_64
            12/18/12 7:34:49.000 PM kernel[0]: vm_page_bootstrap: 8000782 free pages and 355058 wired pages
            12/18/12 7:34:49.000 PM kernel[0]: kext submap [0xffffff7f80741000 - 0xffffff8000000000], kernel text [0xffffff8000200000 - 0xffffff8000741000]
            12/18/12 7:34:49.000 PM kernel[0]: zone leak detection enabled
            12/18/12 7:34:49.000 PM kernel[0]: standard timeslicing quantum is 10000 us
            12/18/12 7:34:49.000 PM kernel[0]: standard background quantum is 2500 us
            12/18/12 7:34:49.000 PM kernel[0]: mig_table_max_displ = 74
            12/18/12 7:34:49.000 PM kernel[0]: corecrypto kext started!
            12/18/12 7:34:49.000 PM kernel[0]: Running kernel space in FIPS MODE
            12/18/12 7:34:49.000 PM kernel[0]: Plist hmac value is    735d392b68241ef173d81097b1c8ce9ba283521626d1c973ac376838c466757d
            12/18/12 7:34:49.000 PM kernel[0]: Computed hmac value is 735d392b68241ef173d81097b1c8ce9ba283521626d1c973ac376838c466757d
            12/18/12 7:34:49.000 PM kernel[0]: corecrypto.kext FIPS integrity POST test passed!
            12/18/12 7:34:49.000 PM kernel[0]: corecrypto.kext FIPS AES CBC POST test passed!
            12/18/12 7:34:49.000 PM kernel[0]: corecrypto.kext FIPS TDES CBC POST test passed!
            12/18/12 7:34:49.000 PM kernel[0]: corecrypto.kext FIPS AES ECB AESNI POST test passed!
            12/18/12 7:34:49.000 PM kernel[0]: corecrypto.kext FIPS AES XTS AESNI POST test passed!
            12/18/12 7:34:49.000 PM kernel[0]: corecrypto.kext FIPS SHA POST test passed!
            12/18/12 7:34:49.000 PM kernel[0]: corecrypto.kext FIPS HMAC POST test passed!
            12/18/12 7:34:49.000 PM kernel[0]: corecrypto.kext FIPS ECDSA POST test passed!
            12/18/12 7:34:49.000 PM kernel[0]: corecrypto.kext FIPS DRBG POST test passed!
            12/18/12 7:34:49.000 PM kernel[0]: corecrypto.kext FIPS POST passed!
            12/18/12 7:34:49.000 PM kernel[0]: AppleACPICPU: ProcessorId=0 LocalApicId=0 Enabled
            12/18/12 7:34:49.000 PM kernel[0]: AppleACPICPU: ProcessorId=1 LocalApicId=32 Enabled
            12/18/12 7:34:49.000 PM kernel[0]: AppleACPICPU: ProcessorId=2 LocalApicId=2 Enabled
            12/18/12 7:34:49.000 PM kernel[0]: AppleACPICPU: ProcessorId=3 LocalApicId=34 Enabled
            12/18/12 7:34:49.000 PM kernel[0]: AppleACPICPU: ProcessorId=4 LocalApicId=4 Enabled
            12/18/12 7:34:49.000 PM kernel[0]: AppleACPICPU: ProcessorId=5 LocalApicId=36 Enabled
            12/18/12 7:34:49.000 PM kernel[0]: AppleACPICPU: ProcessorId=6 LocalApicId=16 Enabled
            12/18/12 7:34:49.000 PM kernel[0]: AppleACPICPU: ProcessorId=7 LocalApicId=48 Enabled
            12/18/12 7:34:49.000 PM kernel[0]: AppleACPICPU: ProcessorId=8 LocalApicId=18 Enabled
            12/18/12 7:34:49.000 PM kernel[0]: AppleACPICPU: ProcessorId=9 LocalApicId=50 Enabled
            12/18/12 7:34:47.740 PM com.apple.launchd[1]: *** launchd[1] has started up. ***
            12/18/12 7:34:49.000 PM kernel[0]: AppleACPICPU: ProcessorId=10 LocalApicId=20 Enabled
            12/18/12 7:34:49.000 PM kernel[0]: AppleACPICPU: ProcessorId=11 LocalApicId=52 Enabled
            12/18/12 7:34:49.000 PM kernel[0]: AppleACPICPU: ProcessorId=12 LocalApicId=1 Enabled
            12/18/12 7:34:49.000 PM kernel[0]: AppleACPICPU: ProcessorId=13 LocalApicId=33 Enabled
            12/18/12 7:34:49.000 PM kernel[0]: AppleACPICPU: ProcessorId=14 LocalApicId=3 Enabled
            12/18/12 7:34:49.000 PM kernel[0]: AppleACPICPU: ProcessorId=15 LocalApicId=35 Enabled
            12/18/12 7:34:49.000 PM kernel[0]: AppleACPICPU: ProcessorId=16 LocalApicId=5 Enabled
            12/18/12 7:34:49.000 PM kernel[0]: AppleACPICPU: ProcessorId=17 LocalApicId=37 Enabled
            12/18/12 7:34:49.000 PM kernel[0]: AppleACPICPU: ProcessorId=18 LocalApicId=17 Enabled
            12/18/12 7:34:49.000 PM kernel[0]: AppleACPICPU: ProcessorId=19 LocalApicId=49 Enabled
            12/18/12 7:34:49.000 PM kernel[0]: AppleACPICPU: ProcessorId=20 LocalApicId=19 Enabled
            12/18/12 7:34:49.000 PM kernel[0]: AppleACPICPU: ProcessorId=21 LocalApicId=51 Enabled
            12/18/12 7:34:49.000 PM kernel[0]: AppleACPICPU: ProcessorId=22 LocalApicId=21 Enabled
            12/18/12 7:34:49.000 PM kernel[0]: AppleACPICPU: ProcessorId=23 LocalApicId=53 Enabled
            12/18/12 7:34:49.000 PM kernel[0]: calling mpo_policy_init for TMSafetyNet
            12/18/12 7:34:49.000 PM kernel[0]: Security policy loaded: Safety net for Time Machine (TMSafetyNet)
            12/18/12 7:34:49.000 PM kernel[0]: calling mpo_policy_init for Sandbox
            12/18/12 7:34:49.000 PM kernel[0]: Security policy loaded: Seatbelt sandbox policy (Sandbox)
            12/18/12 7:34:49.000 PM kernel[0]: calling mpo_policy_init for Quarantine
            12/18/12 7:34:49.000 PM kernel[0]: Security policy loaded: Quarantine policy (Quarantine)
            12/18/12 7:34:49.000 PM kernel[0]: Copyright (c) 1982, 1986, 1989, 1991, 1993
            12/18/12 7:34:49.000 PM kernel[0]: The Regents of the University of California. All rights reserved.
            12/18/12 7:34:49.000 PM kernel[0]: MAC Framework successfully initialized
            12/18/12 7:34:49.000 PM kernel[0]: using 16384 buffer headers and 10240 cluster IO buffer headers
            12/18/12 7:34:49.000 PM kernel[0]: IOAPIC: Version 0x20 Vectors 64:87
            12/18/12 7:34:49.000 PM kernel[0]: ACPI: System State [S0 S3 S4 S5]
            12/18/12 7:34:49.000 PM kernel[0]: PFM64 (40 cpu) 0xff80000000, 0x80000000
            12/18/12 7:34:49.000 PM kernel[0]: [ PCI configuration begin ]
            12/18/12 7:34:49.000 PM kernel[0]: AppleIntelCPUPowerManagement: Turbo Ratios 222233
            12/18/12 7:34:49.000 PM kernel[0]: AppleIntelCPUPowerManagement: (built 23:03:24 Jun 24 2012) initialization complete
            12/18/12 7:34:49.000 PM kernel[0]: console relocated to 0xff80010000
            12/18/12 7:34:49.000 PM kernel[0]: PCI configuration changed (bridge=7 device=2 cardbus=0)
            12/18/12 7:34:49.000 PM kernel[0]: [ PCI configuration end, bridges 15 devices 51 ]
            12/18/12 7:34:49.000 PM kernel[0]: mbinit: done [128 MB total pool size, (85/42) split]
            12/18/12 7:34:49.000 PM kernel[0]: Pthread support ABORTS when sync kernel primitives misused
            12/18/12 7:34:49.000 PM kernel[0]: ETH1 cannot assert wake from D3cold
            12/18/12 7:34:49.000 PM kernel[0]: ETH0 cannot assert wake from D3cold
            12/18/12 7:34:49.000 PM kernel[0]: rooting via boot-uuid from /chosen: 725DCE99-0F42-35F8-83CF-232BE79F8C0F
            12/18/12 7:34:49.000 PM kernel[0]: Waiting on <dict ID="0"><key>IOProviderClass</key><string ID="1">IOResources</string><key>IOResourceMatch</key><string ID="2">boot-uuid-media</string></dict>
            12/18/12 7:34:49.000 PM kernel[0]: com.apple.AppleFSCompressionTypeZlib kmod start
            12/18/12 7:34:49.000 PM kernel[0]: com.apple.AppleFSCompressionTypeDataless kmod start
            12/18/12 7:34:49.000 PM kernel[0]: com.apple.AppleFSCompressionTypeZlib load succeeded
            12/18/12 7:34:49.000 PM kernel[0]: com.apple.AppleFSCompressionTypeDataless load succeeded
            12/18/12 7:34:49.000 PM kernel[0]: AppleIntelCPUPowerManagementClient: ready
            12/18/12 7:34:49.000 PM kernel[0]: Intel82574L::start - Built Jun 24 2012 23:07:38 -- running on device at b10 d0 f0
            12/18/12 7:34:49.000 PM kernel[0]: Intel82574L::start - Built Jun 24 2012 23:07:38 -- running on device at b9 d0 f0
            12/18/12 7:34:49.000 PM kernel[0]: BTCOEXIST off
            12/18/12 7:34:49.000 PM kernel[0]: BRCM tunables:
            12/18/12 7:34:49.000 PM kernel[0]: pullmode[1] txringsize[  256] reapmin[   32] reapcount[  128]
            12/18/12 7:34:49.000 PM kernel[0]: highWaterMark: VO[  192]  VI[  192]  BE[  192]  BK[  192]
            12/18/12 7:34:49.000 PM kernel[0]: FireWire (OHCI) TI ID 823f built-in now active, GUID 78ca39fffe123fc8; max speed s800.
            12/18/12 7:34:49.000 PM kernel[0]: Got boot device = IOService:/AppleACPIPlatformExpert/PCI0@0/AppleACPIPCI/SATA@1F,2/AppleAHCI/PRT2@2/IOAHCID evice@0/AppleAHCIDiskDriver/IOAHCIBlockStorageDevice/IOBlockStorageDriver/OCZ-VERTEX4 Media/IOGUIDPartitionScheme/Vertex SSD @2
            12/18/12 7:34:49.000 PM kernel[0]: BSD root: disk0s2, major 1, minor 1
            12/18/12 7:34:49.000 PM kernel[0]: Kernel is LP64
            12/18/12 7:34:49.000 PM kernel[0]: USBF:          1.482          [0xffffff806a230000] The IOUSBFamily is having trouble enumerating a USB device that has been plugged in.  It will keep retrying.  (Port 3 of Hub at 0x1d100000)
            12/18/12 7:34:47.740 PM com.apple.launchd[1]: *** Shutdown logging is enabled. ***
            12/18/12 7:34:49.610 PM com.apple.launchd[1]: (com.apple.automountd) Unknown key for boolean: NSSupportsSuddenTermination
            12/18/12 7:34:50.000 PM kernel[0]: Intel82574L: Ethernet address e8:06:88:cc:10:44
            12/18/12 7:34:50.000 PM kernel[0]: Intel82574L: Ethernet address e8:06:88:cc:24:84
            12/18/12 7:34:50.000 PM kernel[0]: AirPort_Brcm4331: Ethernet address 00:26:08:fd:72:91
            12/18/12 7:34:50.000 PM kernel[0]: IO80211Controller::dataLinkLayerAttachComplete():  adding AppleEFINVRAM notification
            12/18/12 7:34:50.865 PM airportd[27]: _processDLILEvent: en2 attached (down)
            12/18/12 7:34:50.916 PM com.apple.SecurityServer[15]: Session 100000 created
            12/18/12 7:34:50.000 PM kernel[0]: createVirtIf(): ifRole = 1
            12/18/12 7:34:50.000 PM kernel[0]: in func createVirtualInterface ifRole = 1
            12/18/12 7:34:50.000 PM kernel[0]: AirPort_Brcm4331_P2PInterface::init name <p2p0> role 1 this 0xffffff806acb2800
            12/18/12 7:34:50.000 PM kernel[0]: AirPort_Brcm4331_P2PInterface::init() <p2p> role 1
            12/18/12 7:34:50.000 PM kernel[0]: Created virtif 0xffffff806acb2800 p2p0
            12/18/12 7:34:50.957 PM com.apple.SecurityServer[15]: Entering service
            12/18/12 7:34:51.000 PM kernel[0]: Intel82574L::setLinkStatus - not active  1face000, 0
            12/18/12 7:34:51.026 PM UserEventAgent[11]: Captive: [HandleNetworkInformationChanged:2435] nwi_state_copy returned NULL
            12/18/12 7:34:51.145 PM mDNSResponder[51]: mDNSResponder mDNSResponder-379.32.1 (Aug 31 2012 19:05:06) starting OSXVers 12
            12/18/12 7:34:51.231 PM systemkeychain[55]: done file: /var/run/systemkeychaincheck.done
            12/18/12 7:34:51.269 PM mDNSResponder[51]: D2D_IPC: Loaded
            12/18/12 7:34:51.269 PM mDNSResponder[51]: D2DInitialize succeeded
            12/18/12 7:34:51.000 PM kernel[0]: AirPort: Link Down on en2. Reason 8 (Disassociated because station leaving).
            12/18/12 7:34:51.000 PM kernel[0]: en2::IO80211Interface::postMessage bssid changed
            12/18/12 7:34:51.000 PM kernel[0]: Previous Shutdown Cause: 5
            12/18/12 7:34:51.000 PM kernel[0]: IOBluetoothUSBDFU::probe
            12/18/12 7:34:51.000 PM kernel[0]: IOBluetoothUSBDFU::probe ProductID - 0x8215 FirmwareVersion - 0x0201
            12/18/12 7:34:51.000 PM kernel[0]: [BroadcomBluetoothHCIControllerUSBTransport][start] -- completed
            12/18/12 7:34:51.000 PM kernel[0]: [IOBluetoothHCIController][staticBluetoothHCIControllerTransportShowsUp] -- Received Bluetooth Controller register service notification
            12/18/12 7:34:51.000 PM kernel[0]: [IOBluetoothHCIController][start] -- completed
            12/18/12 7:34:51.000 PM kernel[0]: [IOBluetoothHCIController::setConfigState] calling registerService
            12/18/12 7:34:51.000 PM kernel[0]: [AGPM Controller] unknownPlatform
            12/18/12 7:34:51.000 PM kernel[0]: AppleTyMCEDriver::start coreVIDPID = 0x2c708086 Number of packages = 1 Number of cpus = 24 memory monitor trough PCI
            12/18/12 7:34:51.000 PM kernel[0]: Intel82574L::setLinkStatus - not active  1face001, 0
            12/18/12 7:34:51.779 PM configd[17]: bootp_session_transmit: bpf_write(en2) failed: Network is down (50)
            12/18/12 7:34:51.780 PM configd[17]: DHCP en2: INIT-REBOOT transmit failed
            12/18/12 7:34:51.000 PM kernel[0]: USBF:          4.745          [0xffffff806a230000] The IOUSBFamily was not able to enumerate a device.
            12/18/12 7:34:51.000 PM kernel[0]: DSMOS has arrived
            12/18/12 7:34:51.808 PM configd[17]: network changed: DNS*
            12/18/12 7:34:51.809 PM configd[17]: setting hostname to "Mac-Pro-Imacom-5.local"
            12/18/12 7:34:52.000 PM kernel[0]: Intel82574L::setLinkStatus - not active  1face000, 0
            12/18/12 7:34:52.000 PM kernel[0]: USBF:          5.809          [0xffffff806a230000] The IOUSBFamily is having trouble enumerating a USB device that has been plugged in.  It will keep retrying.  (Port 3 of Hub at 0x1d100000)
            12/18/12 7:34:52.000 PM kernel[0]: MacAuthEvent en2   Auth result for: 00:0f:66:43:a4:fa  MAC AUTH succeeded
            12/18/12 7:34:52.000 PM kernel[0]: wlEvent: en2 en2 Link UP virtIf = 0
            12/18/12 7:34:52.000 PM kernel[0]: AirPort: Link Up on en2
            12/18/12 7:34:52.000 PM kernel[0]: en2: BSSID changed to 00:0f:66:43:a4:fa
            12/18/12 7:34:52.000 PM kernel[0]: en2::IO80211Interface::postMessage bssid changed
            12/18/12 7:34:53.000 PM kernel[0]: AirPort: RSN handshake complete on en2
            12/18/12 7:34:53.269 PM airportd[27]: _doAutoJoin: Already associated to “abrazite”. Bailing on auto-join.
            12/18/12 7:34:53.286 PM airportd[27]: _doAutoJoin: Already associated to “abrazite”. Bailing on auto-join.
            12/18/12 7:34:53.822 PM hidd[96]: Posting 'com.apple.iokit.hid.displayStatus' notifyState=1
            12/18/12 7:34:53.000 PM kernel[0]: macx_swapon SUCCESS
            12/18/12 7:34:53.827 PM hidd[96]: void __IOHIDLoadBundles(): Loaded 0 HID plugins
            12/18/12 7:34:53.849 PM appleeventsd[101]: main: Starting up
            12/18/12 7:34:53.856 PM kdc[94]: label: default
            12/18/12 7:34:53.856 PM kdc[94]:           dbname: od:/Local/Default
            12/18/12 7:34:53.856 PM kdc[94]:           mkey_file: /var/db/krb5kdc/m-key
            12/18/12 7:34:53.856 PM kdc[94]:           acl_file: /var/db/krb5kdc/kadmind.acl
            12/18/12 7:34:53.857 PM com.apple.kextd[12]: Can't load /System/Library/Extensions/CiscoVPN.kext - no code for running kernel's architecture.
            12/18/12 7:34:53.860 PM SystemStarter[77]: Cisco Systems VPN Client Kernel Extension (115) did not complete successfully
            12/18/12 7:34:53.861 PM SystemStarter[77]: The following StartupItems failed to start properly:
            12/18/12 7:34:53.861 PM SystemStarter[77]: /System/Library/StartupItems/CiscoVPN
            12/18/12 7:34:53.861 PM SystemStarter[77]:  - execution of Startup script failed
            12/18/12 7:34:53.870 PM com.apple.usbmuxd[75]: usbmuxd-296.3 on Jul 25 2012 at 00:28:37, running 64 bit
            12/18/12 7:34:53.872 PM kdc[94]: WARNING Found KDC certificate (O=System Identity,CN=com.apple.kerberos.kdc)is missing the PK-INIT KDC EKU, this is bad for interoperability.
            12/18/12 7:34:53.918 PM loginwindow[91]: Login Window Application Started
            12/18/12 7:34:53.918 PM netbiosd[87]: Unable to start NetBIOS name service:
            12/18/12 7:34:53.919 PM apsd[107]: CGSLookupServerRootPort: Failed to look up the port for "com.apple.windowserver.active" (1102)
            12/18/12 7:34:53.919 PM awacsd[105]: Starting awacsd connectivity-78 (Jul 26 2012 14:37:46)
            12/18/12 7:34:53.920 PM apsd[107]: CGSLookupServerRootPort: Failed to look up the port for "com.apple.windowserver.active" (1102)
            12/18/12 7:34:53.922 PM awacsd[105]: InnerStore CopyAllZones: no info in Dynamic Store
            12/18/12 7:34:53.925 PM kdc[94]: KDC started
            12/18/12 7:34:53.925 PM coreservicesd[28]: FindBestLSSession(), no match for inSessionID 0xfffffffffffffffc auditTokenInfo( uid=0 euid=0 auSessionID=100000 create=false
            12/18/12 7:34:53.927 PM mds[88]: (Normal) FMW: FMW 0 0
            12/18/12 7:34:53.966 PM locationd[92]: NOTICE,Location icon should now be in state 0
            12/18/12 7:34:53.985 PM WindowServer[120]: Server is starting up
            12/18/12 7:34:53.987 PM WindowServer[120]: Session 256 retained (2 references)
            12/18/12 7:34:53.987 PM WindowServer[120]: Session 256 released (1 references)
            12/18/12 7:34:53.995 PM WindowServer[120]: Session 256 retained (2 references)
            12/18/12 7:34:53.995 PM WindowServer[120]: init_page_flip: page flip mode is on
            12/18/12 7:34:54.241 PM BBDaemon[109]: IOBSDNameMatching returned a NULL dictionary.
            12/18/12 7:34:54.000 PM kernel[0]: Ethernet [Intel82574L]: Link up on en0, 1-Gigabit, Full-duplex, Symmetric flow-control, Debug [796d,af48,0de1,0200,c5e1,3800]
            12/18/12 7:34:54.000 PM kernel[0]: Intel82574L::setLinkStatus - active  1face000, b
            12/18/12 7:34:55.497 PM WindowServer[120]: mux_initialize: Couldn't find any matches
            12/18/12 7:34:55.512 PM WindowServer[120]: GLCompositor enabled for tile size [256 x 256]
            12/18/12 7:34:55.512 PM WindowServer[120]: CGXGLInitMipMap: mip map mode is on
            12/18/12 7:34:55.538 PM WindowServer[120]: WSMachineUsesNewStyleMirroring: false
            12/18/12 7:34:55.540 PM WindowServer[120]: Display 0x04241064: GL mask 0x1; bounds (0, 0)[2560 x 1600], 57 modes available
            12/18/12 7:34:55.540 PM WindowServer[120]: Display 0x003f003e: GL mask 0x4; bounds (0, 0)[0 x 0], 1 modes available
            12/18/12 7:34:55.540 PM WindowServer[120]: Display 0x003f003d: GL mask 0x2; bounds (0, 0)[0 x 0], 1 modes available
            12/18/12 7:34:55.550 PM WindowServer[120]: Created shield window 0x5 for display 0x04241064
            12/18/12 7:34:55.550 PM WindowServer[120]: Created shield window 0x6 for display 0x003f003e
            12/18/12 7:34:55.550 PM WindowServer[120]: Created shield window 0x7 for display 0x003f003d
            12/18/12 7:34:55.551 PM WindowServer[120]: Display 0x04241064: GL mask 0x1; bounds (0, 0)[2560 x 1600], 57 modes available
            12/18/12 7:34:55.551 PM WindowServer[120]: Display 0x003f003e: GL mask 0x4; bounds (3584, 0)[1 x 1], 1 modes available
            12/18/12 7:34:55.551 PM WindowServer[120]: Display 0x003f003d: GL mask 0x2; bounds (3585, 0)[1 x 1], 1 modes available
            12/18/12 7:34:55.551 PM WindowServer[120]: CGXPerformInitialDisplayConfiguration
            12/18/12 7:34:55.551 PM WindowServer[120]:   Display 0x04241064: MappedDisplay Unit 0; Vendor 0x610 Model 0x9232 S/N 33594596 Dimensions 25.24 x 15.79; online enabled, Bounds (0,0)[2560 x 1600], Rotation 0, Resolution 1
            12/18/12 7:34:55.551 PM WindowServer[120]:   Display 0x003f003e: MappedDisplay Unit 2; Vendor 0xffffffff Model 0xffffffff S/N -1 Dimensions 0.00 x 0.00; offline enabled, Bounds (3584,0)[1 x 1], Rotation 0, Resolution 1
            12/18/12 7:34:55.552 PM WindowServer[120]:   Display 0x003f003d: MappedDisplay Unit 1; Vendor 0xffffffff Model 0xffffffff S/N -1 Dimensions 0.00 x 0.00; offline enabled, Bounds (3585,0)[1 x 1], Rotation 0, Resolution 1
            12/18/12 7:34:55.576 PM WindowServer[120]: GLCompositor: GL renderer id 0x01021b01, GL mask 0x00000007, accelerator 0x00004037, unit 0, caps QEX|QGL|MIPMAP, vram 1024 MB
            12/18/12 7:34:55.576 PM WindowServer[120]: GLCompositor: GL renderer id 0x01021b01, GL mask 0x00000007, texture units 8, texture max 16384, viewport max {16384, 16384}, extensions FPRG|NPOT|GLSL|FLOAT
            12/18/12 7:34:55.579 PM loginwindow[91]: **DMPROXY** Found `/System/Library/CoreServices/DMProxy'.
            12/18/12 7:34:55.581 PM launchctl[126]: launchctl: Dubious permissions on file (skipping): /Library/LaunchAgents/com.adobe.AAM.Updater-1.0.plist
            12/18/12 7:34:55.616 PM WindowServer[120]: Created shield window 0x8 for display 0x04241064
            12/18/12 7:34:55.616 PM WindowServer[120]: Display 0x04241064: MappedDisplay Unit 0; ColorProfile { 2, "Cinema HD"}; TransferFormula (1.000000, 1.000000, 1.000000)
            12/18/12 7:34:55.621 PM launchctl[128]: launchctl: Dubious permissions on file (skipping): /Library/LaunchAgents/com.adobe.AAM.Updater-1.0.plist
            12/18/12 7:34:55.635 PM launchctl[128]: com.apple.findmymacmessenger: Already loaded
            12/18/12 7:34:55.650 PM com.apple.SecurityServer[15]: Session 100005 created
            12/18/12 7:34:55.662 PM airportd[27]: _doAutoJoin: Already associated to “abrazite”. Bailing on auto-join.
            12/18/12 7:34:55.691 PM loginwindow[91]: Login Window Started Security Agent
            12/18/12 7:34:55.752 PM SecurityAgent[139]: This is the first run
            12/18/12 7:34:55.752 PM SecurityAgent[139]: MacBuddy was run = 0
            12/18/12 7:34:55.762 PM WindowServer[120]: MPAccessSurfaceForDisplayDevice: Set up page flip mode on display 0x04241064 device: 0x1054d0320  isBackBuffered: 1 numComp: 3 numDisp: 3
            12/18/12 7:34:55.800 PM SecurityAgent[139]: User info context values set for Imacom
            12/18/12 7:34:55.861 PM coreaudiod[137]: 2012-12-18 07:34:55.860938 PM [AirPlay] Started browsing for _airplay._tcp.
            12/18/12 7:34:55.862 PM coreaudiod[137]: 2012-12-18 07:34:55.861674 PM [AirPlay] Started browsing for _raop._tcp.
            12/18/12 7:34:55.000 PM kernel[0]: USBF:          9.304          [0xffffff806a230000] The IOUSBFamily was not able to enumerate a device.
            12/18/12 7:34:56.086 PM loginwindow[91]: Login Window - Returned from Security Agent
            12/18/12 7:34:56.089 PM loginwindow[91]: ERROR | ScreensharingLoginNotification | Failed sending message to screen sharing GetScreensharingPort, err: 1102
            12/18/12 7:34:56.112 PM loginwindow[91]: USER_PROCESS: 91 console
            12/18/12 7:34:56.132 PM airportd[27]: _doAutoJoin: Already associated to “abrazite”. Bailing on auto-join.
            12/18/12 7:34:56.134 PM launchctl[144]: launchctl: Dubious permissions on file (skipping): /Library/LaunchAgents/com.adobe.AAM.Updater-1.0.plist
            12/18/12 7:34:56.153 PM launchctl[145]: launchctl: Dubious permissions on file (skipping): /Library/LaunchAgents/com.adobe.AAM.Updater-1.0.plist
            12/18/12 7:34:56.159 PM com.apple.launchd[1]: (com.wacom.wacomtablet[135]) Exited with code: 255
            12/18/12 7:34:56.166 PM com.apple.launchd.peruser.501[143]: (com.apple.gamed) Ignored this key: UserName
            12/18/12 7:34:56.166 PM com.apple.launchd.peruser.501[143]: (com.apple.gamed) Ignored this key: GroupName
            12/18/12 7:34:56.167 PM com.apple.launchd.peruser.501[143]: (com.apple.ReportCrash) Falling back to default Mach exception handler. Could not find: com.apple.ReportCrash.Self
            12/18/12 7:34:56.171 PM loginwindow[91]: Connection with distnoted server was invalidated
            12/18/12 7:34:56.176 PM distnoted[147]: # distnote server agent  absolute time: 9.532941403   civil time: Tue Dec 18 19:34:56 2012   pid: 147 uid: 501  root: no
            12/18/12 7:34:56.215 PM WindowServer[120]: **DMPROXY** (2) Found `/System/Library/CoreServices/DMProxy'.
            12/18/12 7:34:56.439 PM com.apple.SecurityServer[15]: Session 100003 created
            12/18/12 7:34:56.464 PM WindowServer[120]: Display 0x04241064: MappedDisplay Unit 0; ColorProfile { 2, "Cinema HD"}; TransferFormula (1.000000, 1.000000, 1.000000)
            12/18/12 7:34:56.471 PM coreservicesd[28]: SendFlattenedData, got error #268435460 (ipc/send) timed out from ::mach_msg(), sending notification kLSNotifyApplicationBirth to notificationID=122
            12/18/12 7:34:56.512 PM com.apple.launchd.peruser.501[143]: (com.akamai.single-user-client[187]) Bug: 12C60: launchd + 95444 [7DCC9489-2DF5-3807-83FA-EF5666EE8078]: 0xd
            12/18/12 7:34:56.512 PM com.apple.launchd.peruser.501[143]: (com.akamai.client.plist[188]) Bug: 12C60: launchd + 95444 [7DCC9489-2DF5-3807-83FA-EF5666EE8078]: 0xd
            12/18/12 7:34:56.514 PM talagent[155]: _LSSetApplicationInformationItem(kLSDefaultSessionID, asn, _kLSApplicationIsHiddenKey, hidden ? kCFBooleanTrue : kCFBooleanFalse, NULL) produced OSStatus -50 on line 623 in TCApplication.m
            12/18/12 7:34:56.514 PM talagent[155]: _LSSetApplicationInformationItem(kLSDefaultSessionID, asn, TAL_kLSIsProxiedForTALKey, kCFBooleanTrue, NULL) produced OSStatus -50 on line 626 in TCApplication.m
            12/18/12 7:34:56.517 PM com.apple.launchd.peruser.501[143]: (com.apple.afpstat-qfa[177]) Exited with code: 2
            12/18/12 7:34:56.518 PM com.apple.launchd.peruser.501[143]: (com.adobe.ARM.0d92f8f114b2d0af95462120762f939f6c66651ac8ac214cb7bdbd84[191]) Exited with code: 2
            12/18/12 7:34:56.550 PM SRServiceAgent[179]: service agent got ipc message: 1094931542
            12/18/12 7:34:56.551 PM SRServiceAgent[179]: try start streamer
            12/18/12 7:34:56.554 PM SRServiceAgent[179]: start check timer
            12/18/12 7:34:56.555 PM SRServiceAgent[179]: create new task
            12/18/12 7:34:56.555 PM SRServiceAgent[179]: task is not running, launch task
            12/18/12 7:34:56.587 PM launchctl[196]: launchctl: Dubious permissions on file (skipping): /Library/LaunchAgents/com.adobe.AAM.Updater-1.0.plist
            12/18/12 7:34:56.638 PM NetworkBrowserAgent[199]: Starting NetworkBrowserAgent
            12/18/12 7:34:56.825 PM Splashtop Streamer[194]: NSWindow does not support utility styleMask 0x10
            12/18/12 7:34:56.827 PM Splashtop Streamer[194]: NSWindow does not support utility styleMask 0x10
            12/18/12 7:34:56.000 PM kernel[0]: CODE SIGNING: cs_invalid_page(0x1000): p=181[GoogleSoftwareUp] clearing CS_VALID
            12/18/12 7:34:56.832 PM Splashtop Streamer[194]: NSWindow does not support utility styleMask 0x10
            12/18/12 7:34:56.833 PM Splashtop Streamer[194]: NSWindow does not support utility styleMask 0x10
            12/18/12 7:34:56.000 PM kernel[0]: USBF:          10.191          [0xffffff806a230000] The IOUSBFamily is having trouble enumerating a USB device that has been plugged in.  It will keep retrying.  (Port 3 of Hub at 0x1d100000)
            12/18/12 7:34:56.843 PM Splashtop Streamer[194]: NSWindow does not support utility styleMask 0x10
            12/18/12 7:34:56.848 PM Splashtop Streamer[194]: Could not connect the action toggleServer: to target of class SplashtopRemoteAppDelegate
            12/18/12 7:34:56.978 PM DGAgent[185]: Resolved DG link from bookmark. /Applications/Drive Genius 3.app
            12/18/12 7:34:57.018 PM locationd[215]: NOTICE,Location icon should now be in state 0
            12/18/12 7:34:57.187 PM Splashtop Streamer[194]: ---- http://www.splashtop.com/splashtop2#otherproducts-tab
            12/18/12 7:34:57.190 PM Splashtop Streamer[194]: going to close SRFeature.
            12/18/12 7:34:57.335 PM YouSendIt Desktop App[225]: Set Version number 2.0.0.204
            12/18/12 7:34:57.358 PM Trim Enabler[221]: ON
            12/18/12 7:34:57.513 PM YouSendIt Desktop App[225]: finderPearlServerConnection = (** NSConnection 0x103103690 receivePort <NSMachPort: 0x103103950> sendPort <NSMachPort: 0x103103950> refCount 1 remoteUsesKeyedDO: 0 **), pearlServices = <YSIPearlServices: 0x103104010>
            12/18/12 7:34:57.538 PM YouSendIt Desktop App[225]: Need to check OSAX bundle
            12/18/12 7:34:57.540 PM YouSendIt Desktop App[225]: internal version=2.0.0.204, installed version=2.0.0.204
            12/18/12 7:34:57.540 PM YouSendIt Desktop App[225]: No valid connection
            12/18/12 7:34:57.550 PM WindowServer[120]: **DMPROXY** (2) Found `/System/Library/CoreServices/DMProxy'.
            12/18/12 7:34:57.609 PM WindowServer[120]: Display 0x04241064: MappedDisplay Unit 0; ColorProfile { 2, "Cinema HD"}; TransferFormula (1.000000, 1.000000, 1.000000)
            12/18/12 7:34:57.635 PM WindowServer[120]: Display 0x04241064: MappedDisplay Unit 0; ColorProfile { 2, "Cinema HD"}; TransferFormula (1.000000, 1.000000, 1.000000)
            12/18/12 7:34:57.997 PM coreservicesd[28]: Can't change an application into stopped state for app App:"Finder" [ 0x0/0x12012]  @ 0x0x7fd031700990 because it's already been started.
            12/18/12 7:34:57.999 PM appleprofilepolicyd[234]: appleprofilepolicyd: profiling drivers not loaded, loading
            12/18/12 7:34:58.000 PM kernel[0]: USBF:          11. 56          [0xffffff806a230000] The IOUSBFamily gave up enumerating a USB device after 10 retries.  (Port 3 of Hub at 0x1d100000)
            12/18/12 7:34:58.000 PM kernel[0]: USBF:          11. 56          [0xffffff806a230000] The IOUSBFamily was not able to enumerate a device.
            12/18/12 7:34:58.049 PM WindowServer[120]: CGXSetWindowShadowParameters: Operation on a window 0x1c requiring rights kCGSWindowRightOwner by caller talagent
            12/18/12 7:34:58.199 PM coreservicesd[28]: SendFlattenedData, got error #268435460 (ipc/send) timed out from ::mach_msg(), sending notification kLSNotifyApplicationReady to notificationID=165
            12/18/12 7:34:58.200 PM coreservicesd[28]: SendFlattenedData, got error #268435460 (ipc/send) timed out from ::mach_msg(), sending notification kLSNotifyApplicationReady to notificationID=180
            12/18/12 7:34:58.249 PM SRFeature[236]: Display server path : /Applications/Splashtop Streamer.app/Contents/MacOS/SRFeature.app/Contents/MacOS/SRXDisplayServer.app/Contents/Ma cOS/SRXDisplayServer
            12/18/12 7:34:58.275 PM SRXDisplayServer[239]: No SRX Display Card
            12/18/12 7:34:58.528 PM SRFeature[236]: pInfo data: [2][b000000][b][0]
            12/18/12 7:34:58.529 PM SRFeature[236]: FH: GetInfo
            12/18/12 7:34:58.601 PM Finder[158]: SDL checking if Pearl was loaded. hasLoaded=NO, addr=10c1642f4
            12/18/12 7:34:58.602 PM Finder[158]: not loaded, returning 1
            12/18/12 7:34:58.628 PM configd[17]: network changed: v4(en0+:10.10.1.104) DNS+ Proxy+ SMB
            12/18/12 7:34:58.651 PM Finder[158]: handleYSILoad
            12/18/12 7:34:58.653 PM Finder[158]: YSI pearl loaded
            12/18/12 7:34:58.721 PM Finder[158]: pearl listener registered
            12/18/12 7:35:00.328 PM ntpd[71]: proto: precision = 1.000 usec
            12/18/12 7:35:00.000 PM kernel[0]: Finder (map: 0xffffff806b62ab30) triggered DYLD shared region unnest for map: 0xffffff806b62ab30, region 0x7fff91000000->0x7fff91200000. While not abnormal for debuggers, this increases system memory footprint until the target exits.
            12/18/12 7:35:00.573 PM coreservicesd[28]: SendFlattenedData, got error #268435460 (ipc/send) timed out from ::mach_msg(), sending notification kLSNotifyChildApplicationLaunch to notificationID=131
            12/18/12 7:35:00.783 PM Splashtop Streamer[194]: -[DisplayView initWithFrame:] [{{0, 0}, {380, 70}}][{{0, 0}, {380, 70}}]
            12/18/12 7:35:00.784 PM Splashtop Streamer[194]: -[DisplayView(Private) setTextField:string:] 1 [{{20, 0}, {380, 70}}]
            12/18/12 7:35:00.785 PM Splashtop Streamer[194]: -[DisplayView(Private) setTextField:string:] 2 [{{20, 0}, {85, 14}}]
            12/18/12 7:35:01.229 PM blued[68]: kBTXPCUpdateUserPreferences gConsoleUserUID = 501
            12/18/12 7:35:01.541 PM com.apple.launchd[1]: (com.apple.xprotectupdater[73]) Exited with code: 252
            12/18/12 7:35:01.826 PM Trim Enabler[221]: ON
            12/18/12 7:35:02.136 PM com.apple.launchd.peruser.501[143]: ([0x0-0x1e01e].com.yousendit.YouSendIt[225]) Job appears to have crashed: Abort trap: 6
            12/18/12 7:35:02.317 PM ReportCrash[255]: Saved crash report for YouSendIt Desktop App[225] version 2.0.0.204 (2.0.0.204) to /Users/Imacom/Library/Logs/DiagnosticReports/YouSendIt Desktop App_2012-12-18-193502_Mac-Pro-Imacom-5.crash
            12/18/12 7:35:02.340 PM ReportCrash[255]: Removing excessive log: file://localhost/Users/Imacom/Library/Logs/DiagnosticReports/YouSendIt%20Desktop%20App_20 12-11-24-072604_Mac-Pro-Imacom-5.crash
            12/18/12 7:35:02.000 PM kernel[0]: Intel82574L::timeoutHandler - no link - reset the chipset once  1face001, 0
            12/18/12 7:35:02.000 PM kernel[0]: Intel82574L::setLinkStatus - not active  1face001, 0
            12/18/12 7:35:02.782 PM Finder[158]: connection went invalid while waiting for a reply because a mach port died
            12/18/12 7:35:02.784 PM Finder[158]: (
                      0   CoreFoundation                      0x00007fff8e8e80a6 __exceptionPreprocess + 198
                      1   libobjc.A.dylib                     0x00007fff8fbab3f0 objc_exception_throw + 43
                      2   CoreFoundation                      0x00007fff8e8e7e7c +[NSException raise:format:] + 204
                      3   Foundation                          0x00007fff8e4e0557 -[NSConnection sendInvocation:internal:] + 3079
                      4   CoreFoundation                      0x00007fff8e8d6737 ___forwarding___ + 775
                      5   CoreFoundation                      0x00007fff8e8d63b8 _CF_forwarding_prep_0 + 232
                      6   Foundation                          0x00007fff8e4dea69 -[NSConnection rootProxy] + 71
                      7   YSIPearl                            0x000000010c30e034 -[YSIPearl distributedServer] + 235
                      8   YSIPearl                            0x000000010c30d11a -[YSIPearl startup] + 2114
                      9   Foundation                          0x00007fff8e4c6677 __NSThreadPerformPerform + 225
                      10  CoreFoundation                      0x00007fff8e867101 __CFRUNLOOP_IS_CALLING_OUT_TO_A_SOURCE0_PERFORM_FUNCTION__ + 17
                      11  CoreFoundation                      0x00007fff8e866a25 __CFRunLoopDoSources0 + 245
                      12  CoreFoundation                      0x00007fff8e889dc5 __CFRunLoopRun + 789
                      13  CoreFoundation                      0x00007fff8e8896b2 CFRunLoopRunSpecific + 290
                      14  HIToolbox                           0x00007fff907bd0a4 RunCurrentEventLoopInMode + 209
                      15  HIToolbox                           0x00007fff907bce42 ReceiveNextEventCommon + 356
                      16  HIToolbox                           0x00007fff907bccd3 BlockUntilNextEventMatchingListInMode + 62
                      17  AppKit                              0x00007fff93788613 _DPSNextEvent + 685
                      18  AppKit                              0x00007fff93787ed2 -[NSApplication nextEventMatchingMask:untilDate:inMode:dequeue:] + 128
                      19  AppKit                              0x00007fff9377f283 -[NSApplication run] + 517
                      20  AppKit                              0x00007fff93723cb6 NSApplicationMain + 869
                      21  Finder                              0x0000000106840b46 Finder + 23366
                      22  libdyld.dylib                       0x00007fff94a0e7e1 start + 0
                      23  ???                                 0x0000000000000001 0x0 + 1
            12/18/12 7:35:03.265 PM locationd[286]: NOTICE,Location icon should now be in state 0
            12/18/12 7:35:03.000 PM kernel[0]: Intel82574L::setLinkStatus - not active  1face001, 0
            12/18/12 7:35:03.327 PM UserEventAgent[146]: cannot find fw daemon port 1102
            12/18/12 7:35:04.213 PM CalendarAgent[174]: *** -[IADomainCache init]: IA domains cache is out of date.
            12/18/12 7:35:04.355 PM launchctl[296]: launchctl: Dubious permissions on file (skipping): /Library/LaunchAgents/com.adobe.AAM.Updater-1.0.plist
            12/18/12 7:35:04.692 PM Splashtop Streamer[194]: SRFEAT_NOTIFY_SERVER_CLOUD_NOTIFY_MSG
            12/18/12 7:35:04.692 PM Splashtop Streamer[194]: [ProcServerNotification] SRS_SERVER_RTN_INFO : [200][.srloginnotify.xml]
            12/18/12 7:35:04.693 PM Splashtop Streamer[194]:   receive backend string notify
            12/18/12 7:35:04.694 PM Splashtop Streamer[194]: -[CMXMLParser length]: unrecognized selector sent to instance 0x105108110
            12/18/12 7:35:04.696 PM Splashtop Streamer[194]: (
                      2   CoreFoundation                      0x00007fff8e97e6ea -[NSObject(NSObject) doesNotRecognizeSelector:] + 186
                      3   CoreFoundation                      0x00007fff8e8d65ce ___forwarding___ + 414
                      4   CoreFoundation                      0x00007fff8e8d63b8 _CF_forwarding_prep_0 + 232
                      5   Foundation                          0x00007fff8e4a0ea8 -[NSPlaceholderString initWithString:] + 169
                      6   Splashtop Streamer                  0x000000010000be8f -[SplashtopRemoteAppDelegate getXMLContent:] + 199
                      7   CoreFoundation                      0x00007fff8e9445cc ____CFXNotificationPostToken_block_invoke_0 + 284
                      8   CoreFoundation                      0x00007fff8e8a5272 __CFRUNLOOP_IS_CALLING_OUT_TO_A_BLOCK__ + 18
                      9   CoreFoundation                      0x00007fff8e865a4f __CFRunLoopDoBlocks + 255
                      10  CoreFoundation                      0x00007fff8e889dda __CFRunLoopRun + 810
                      11  CoreFoundation                      0x00007fff8e8896b2 CFRunLoopRunSpecific + 290
                      12  HIToolbox                           0x00007fff907bd0a4 RunCurrentEventLoopInMode + 209
                      13  HIToolbox                           0x00007fff907bcd84 ReceiveNextEventCommon + 166
                      14  HIToolbox                           0x00007fff907bccd3 BlockUntilNextEventMatchingListInMode + 62
                      15  AppKit                              0x00007fff93788613 _DPSNextEvent + 685
                      16  AppKit                              0x00007fff93787ed2 -[NSApplication nextEventMatchingMask:untilDate:inMode:dequeue:] + 128
                      17  AppKit                              0x00007fff9377f283 -[NSApplication run] + 517
                      18  AppKit                              0x00007fff93723cb6 NSApplicationMain + 869
                      19  Splashtop Streamer                  0x00000001000018b4 start + 52
            12/18/12 7:35:04.808 PM Trim Enabler[221]: /Applications/Trim En
            12/18/12 7:35:09.151 PM Splashtop Streamer[194]: going to close SRFeature.
            12/18/12 7:35:09.154 PM configd[17]: network changed: v4(en0:10.10.1.104, en2+:10.10.1.105) DNS* Proxy SMB
            12/18/12 7:35:09.171 PM UserEventAgent[11]: Captive: en2: Not probing 'abrazite' (protected network)
            12/18/12 7:35:09.175 PM configd[17]: network changed: v4(en0:10.10.1.104, en2!:10.10.1.105) DNS Proxy SMB
            12/18/12 7:35:10.482 PM awacsd[105]: Exiting
            12/18/12 7:35:10.756 PM Splashtop Streamer[194]: cannot create remote port
            12/18/12 7:35:10.756 PM Splashtop Streamer[194]: Error -50 sending  ping to SRFeature.
            12/18/12 7:35:10.756 PM Splashtop Streamer[194]: Can not find SRFeature alive
            12/18/12 7:35:10.757 PM Splashtop Streamer[194]: going to close SRFeature.
            12/18/12 7:35:17.706 PM com.apple.launchd[1]: (com.apple.coreservices.appleid.authentication[134]) Exit timeout elapsed (20 seconds). Killing
            12/18/12 7:35:18.112 PM SRServiceAgent[179]: cannot find SRFeature
            12/18/12 7:35:21.797 PM SRFeature[306]: Display server path : /Applications/Splashtop Streamer.app/Contents/MacOS/SRFeature.app/Contents/MacOS/SRXDisplayServer.app/Contents/Ma cOS/SRXDisplayServer
            12/18/12 7:35:21.817 PM SRXDisplayServer[308]: No SRX Display Card
            12/18/12 7:35:22.043 PM SRFeature[306]: pInfo data: [2][b000000][b][0]
            12/18/12 7:35:22.044 PM SRFeature[306]: FH: GetInfo
            12/18/12 7:35:26.582 PM Splashtop Streamer[194]: SRFEAT_NOTIFY_SERVER_CLOUD_NOTIFY_MSG
            12/18/12 7:35:26.583 PM Splashtop Streamer[194]: [ProcServerNotification] SRS_SERVER_RTN_INFO : [200][.srloginnotify.xml]
            12/18/12 7:35:26.584 PM Splashtop Streamer[194]:   receive backend string notify
            12/18/12 7:35:26.584 PM Splashtop Streamer[194]: -[CMXMLParser length]: unrecognized selector sent to instance 0x10041c490
            12/18/12 7:35:26.585 PM Splashtop Streamer[194]: -[CMXMLParser length]: unrecognized selector sent to instance 0x10041c490
            12/18/12 7:35:26.586 PM Splashtop Streamer[194]: (
                      10  CoreFoundation                      0x00007fff8e88a220 __CFRunLoopRun + 1904
                      13  HIToolbox                           0x00007fff907bce42 ReceiveNextEventCommon + 356
            12/18/12 7:35:26.586 PM Splashtop Streamer[194]:   receive backend string notify
            12/18/12 7:35:26.587 PM Splashtop Streamer[194]: -[CMXMLParser length]: unrecognized selector sent to instance 0x100419a70
            12/18/12 7:35:26.588 PM Splashtop Streamer[194]: (
                      10  CoreFoundation                      0x00007fff8e889db4 __CFRunLoopRun + 772
            12/18/12 7:35:35.621 PM launchctl[315]: launchctl: Dubious permissions on file (skipping): /Library/LaunchAgents/com.adobe.AAM.Updater-1.0.plist
            12/18/12 7:35:35.868 PM com.apple.SecurityServer[15]: Session 100002 created
            12/18/12 7:39:52.416 PM com.apple.kextd[12]: Warning: /Volumes/Macintosh HD/System/Library/Extensions: No such file or directory
            12/18/12 7:44:58.056 PM WindowServer[120]: Created shield window 0x50 for display 0x04241064
            12/18/12 7:44:58.056 PM WindowServer[120]: device_generate_desktop_screenshot: authw 0x0(0), shield 0x0(0)
            12/18/12 7:44:58.073 PM WindowServer[120]: device_generate_lock_screen_screenshot: authw 0x0(0), shield 0x0(0)
            12/18/12 7:49:58.175 PM helpd[171]: Could not find access page in directory /Applications/Final Cut Pro.app/Contents/Resources/English.lproj/Final Cut Pro Help
            12/18/12 7:49:58.176 PM helpd[171]: Could not find access page in directory /Applications/Final Cut Pro.app/Contents/Resources/English.lproj/Final Cut Pro Help
            12/18/12 7:50:08.200 PM helpd[171]: CFPropertyListCreateFromXMLData(): Old-style plist parser: missing semicolon in dictionary on line 1. Parsing will be abandoned. Break on _CFPropertyListMissingSemicolon to debug.
            12/18/12 7:50:08.201 PM helpd[171]: CFPropertyListCreateFromXMLData(): Old-style plist parser: missing semicolon in dictionary on line 1. Parsing will be abandoned. Break on _CFPropertyListMissingSemicolon to debug.
            12/18/12 7:50:08.202 PM helpd[171]: CFPropertyListCreateFromXMLData(): Old-style plist parser: missing semicolon in dictionary on line 1. Parsing will be abandoned. Break on _CFPropertyListMissingSemicolon to debug.
            12/18/12 8:04:57.796 PM helpd[419]: Could not find access page in directory /Applications/Final Cut Pro.app/Contents/Resources/English.lproj/Final Cut Pro Help
            12/18/12 8:04:57.797 PM helpd[419]: Could not find access page in directory /Applications/Final Cut Pro.app/Contents/Resources/English.lproj/Final Cut Pro Help
            12/18/12 8:05:07.817 PM helpd[419]: CFPropertyListCreateFromXMLData(): Old-style plist parser: missing semicolon in dictionary on line 1. Parsing will be abandoned. Break on _CFPropertyListMissingSemicolon to debug.
            12/18/12 8:05:07.818 PM helpd[419]: CFPropertyListCreateFromXMLData(): Old-style plist parser: missing semicolon in dictionary on line 1. Parsing will be abandoned. Break on _CFPropertyListMissingSemicolon to debug.
            12/18/12 8:05:07.819 PM helpd[419]: CFPropertyListCreateFromXMLData(): Old-style plist parser: missing semicolon in dictionary on line 1. Parsing will be abandoned. Break on _CFPropertyListMissingSemicolon to debug.
            12/18/12 8:21:13.585 PM WindowServer[120]: handle_will_sleep_auth_and_shield_windows: no lock state data
            12/18/12 8:22:10.520 PM com.apple.launchd.peruser.501[143]: ([0x0-0x1f01f].com.getdropbox.dropbox[227]) Exited: Killed: 9
            12/18/12 8:22:55.273 PM CVMServer[124]: Check-in to the service com.apple.cvmsCompAgent_x86_64 failed. This is likely because you have either unloaded the job or the MachService has the ResetAtClose attribute specified in the launchd.plist. If present, this attribute should be removed.
            12/18/12 8:22:55.283 PM launchctl[521]: launchctl: Dubious permissions on file (skipping): /Library/LaunchAgents/com.adobe.AAM.Updater-1.0.plist
            12/18/12 8:22:55.302 PM CVMServer[124]: Check-in to the service com.apple.cvmsCompAgent_x86_64 failed. This is likely because you have either unloaded the job or the MachService has the ResetAtClose attribute specified in the launchd.plist. If present, this attribute should be removed.
            12/18/12 8:22:57.000 PM kernel[0]: Sandbox: sandboxd(525) deny mach-lookup com.apple.coresymbolicationd
            12/18/12 8:23:00.942 PM sandboxd[525]: ([516]) WebProcess(516) deny mach-lookup ATS Query Port 182
            12/18/12 8:23:00.952 PM sandboxd[525]: ([516]) WebProcess(516) deny mach-lookup ATS Query Port 182
            12/18/12 8:23:04.733 PM Safari[513]: CGContextClipToRect: invalid context 0x0
            12/18/12 8:23:11.902 PM GoogleTalkPlugin[532]: objc[532]: Class MacCocoaSocketServerHelper is implemented in both /Library/Application Support/Google/GoogleTalkPlugin.app/Contents/MacOS/GoogleTalkPlugin and /Library/Application Support/Google/GoogleTalkPlugin.app/Contents/Frameworks/libgoogletalkremoting.dylib. One of the two will be used. Which one is undefined.
            12/18/12 8:23:13.890 PM sandboxd[525]: ([528]) WebProcess(528) deny mach-lookup ATS Query Port 182
            12/18/12 8:23:13.901 PM sandboxd[525]: ([528]) WebProcess(528) deny mach-lookup ATS Query Port 182
            12/18/12 8:23:13.965 PM sandboxd[525]: ([528]) WebProcess(528) deny mach-lookup ATS Query Port 182
            12/18/12 8:23:13.983 PM sandboxd[525]: ([528]) WebProcess(528) deny mach-lookup ATS Query Port 182
            12/18/12 8:23:14.015 PM sandboxd[525]: ([528]) WebProcess(528) deny mach-lookup ATS Query Port 182
            12/18/12 8:23:14.036 PM sandboxd[525]: ([528]) WebProcess(528) deny mach-lookup ATS Query Port 182
            12/18/12 8:23:14.056 PM sandboxd[525]: ([528]) WebProcess(528) deny mach-lookup ATS Query Port 182
            12/18/12 8:23:14.077 PM sandboxd[525]: ([528]) WebProcess(528) deny mach-lookup ATS Query Port 182
            12/18/12 8:23:14.097 PM sandboxd[525]: ([528]) WebProcess(528) deny mach-lookup ATS Query Port 182
            12/18/12 8:23:14.118 PM sandboxd[525]: ([528]) WebProcess(528) deny mach-lookup ATS Query Port 182
            12/18/12 8:23:14.138 PM sandboxd[525]: ([528]) WebProcess(528) deny mach-lookup ATS Query Port 182
            12/18/12 8:23:14.797 PM sandboxd[525]: ([528]) WebProcess(528) deny mach-lookup ATS Query Port 182
            12/18/12 8:23:14.818 PM sandboxd[525]: ([528]) WebProcess(528) deny mach-lookup ATS Query Port 182
            12/18/12 8:23:14.838 PM sandboxd[525]: ([528]) WebProcess(528) deny mach-lookup ATS Query Port 182
            12/18/12 8:23:14.859 PM sandboxd[525]: ([528]) WebProcess(528) deny mach-lookup ATS Query Port 182
            12/18/12 8:23:14.879 PM sandboxd[525]: ([528]) WebProcess(528) deny mach-lookup ATS Query Port 182
            12/18/12 8:23:19.157 PM sandboxd[525]: ([528]) WebProcess(528) deny mach-lookup ATS Query Port 182
            12/18/12 8:23:19.177 PM sandboxd[525]: ([528]) WebProcess(528) deny mach-lookup ATS Query Port 182
            12/18/12 8:23:19.197 PM sandboxd[525]: ([528]) WebProcess(528) deny mach-lookup ATS Query Port 182
            12/18/12 8:23:19.218 PM sandboxd[525]: ([528]) WebProcess(528) deny mach-lookup ATS Query Port 182
            12/18/12 8:23:19.239 PM sandboxd[525]: ([528]) WebProcess(528) deny mach-lookup ATS Query Port 182
            12/18/12 8:23:30.155 PM sandboxd[525]: ([528]) WebProcess(528) deny mach-lookup ATS Query Port 182
            12/18/12 8:23:36.569 PM com.apple.kextd[12]: Warning: /Volumes/Macintosh HD/System/Library/Extensions: No such file or directory
            12/18/12 8:23:37.502 PM sandboxd[525]: ([516]) WebProcess(516) deny mach-lookup ATS Query Port 182
            12/18/12 8:23:37.523 PM sandboxd[525]: ([516]) WebProcess(516) deny mach-lookup ATS Query Port 182
            12/18/12 8:23:37.544 PM sandboxd[525]: ([516]) WebProcess(516) deny mach-lookup ATS Query Port 182
            12/18/12 8:23:37.565 PM sandboxd[525]: ([516]) WebProcess(516) deny mach-lookup ATS Query Port 182
            12/18/12 8:23:37.586 PM sandboxd[525]: ([516]) WebProcess(516) deny mach-lookup ATS Query Port 182
            12/18/12 8:23:37.606 PM sandboxd[525]: ([516]) WebProcess(516) deny mach-lookup ATS Query Port 182
            12/18/12 8:23:37.626 PM sandboxd[525]: ([516]) WebProcess(516) deny mach-lookup ATS Query Port 182
            12/18/12 8:23:37.648 PM sandboxd[525]: ([516]) WebProcess(516) deny mach-lookup ATS Query Port 182
            12/18/12 8:23:37.668 PM sandboxd[525]: ([516]) WebProcess(516) deny mach-lookup ATS Query Port 182
            12/18/12 8:23:37.689 PM sandboxd[525]: ([516]) WebProcess(516) deny mach-lookup ATS Query Port 182
            12/18/12 8:23:37.709 PM sandboxd[525]: ([516]) WebProcess(516) deny mach-lookup ATS Query Port 182
            12/18/12 8:23:37.730 PM sandboxd[525]: ([516]) WebProcess(516) deny mach-lookup ATS Query Port 182
            12/18/12 8:23:37.751 PM sandboxd[525]: ([516]) WebProcess(516) deny mach-lookup ATS Query Port 182
            12/18/12 8:23:38.405 PM sandboxd[525]: ([516]) WebProcess(516) deny mach-lookup ATS Query Port 182
            12/18/12 8:23:38.426 PM sandboxd[525]: ([516]) WebProcess(516) deny mach-lookup ATS Query Port 182
            12/18/12 8:23:38.447 PM sandboxd[525]: ([516]) WebProcess(516) deny mach-lookup ATS Query Port 182
            12/18/12 8:23:38.467 PM sandboxd[525]: ([516]) WebProcess(516) deny mach-lookup ATS Query Port 182
            12/18/12 8:23:38.488 PM sandboxd[525]: ([516]) WebProcess(516) deny mach-lookup ATS Query Port 182
            12/18/12 8:24:06.286 PM com.apple.backupd[548]: Starting automatic backup
            12/18/12 8:24:06.347 PM com.apple.backupd[548]: Backup failed with error: 19
            12/18/12 8:24:06.347 PM com.apple.backupd[548]: Starting automatic backup
            12/18/12 8:24:06.399 PM com.apple.backupd[548]: Backing up to: /Volumes/Backup-Internal Working Files-Mac/Backups.backupdb
            12/18/12 8:24:06.838 PM com.apple.backupd[548]: Using file event preflight for Macintosh HD
            12/18/12 8:24:07.638 PM com.apple.backupd[548]: Will copy (108.5 MB) from Macintosh HD
            12/18/12 8:24:07.640 PM com.apple.backupd[548]: Found 42 files (108.5 MB) needing backup
            12/18/12 8:24:07.646 PM com.apple.backupd[548]: 4.24 GB required (including padding), 1.84 TB available
            12/18/12 8:24:19.374 PM com.apple.backupd[548]: Copied 564 files (108.5 MB) from volume Macintosh HD.
            12/18/12 8:24:19.561 PM com.apple.backupd[548]: Created new backup: 2012-12-18-202419
            12/18/12 8:24:19.623 PM com.apple.backupd[548]: Starting post-backup thinning
            12/18/12 8:24:21.199 PM com.apple.backupd[548]: Deleted /Volumes/Backup-Internal Working Files-Mac/Backups.backupdb/Mac Pro-Imacom/2012-12-15-163147 (172 KB)
            12/18/12 8:24:22.143 PM com.apple.backupd[548]: Deleted /Volumes/Backup-Internal Working Files-Mac/Backups.backupdb/Mac Pro-Imacom/2012-12-15-153150 (229 KB)
            12/18/12 8:24:22.701 PM com.apple.backupd[548]: Deleted /Volumes/Backup-Internal Working Files-Mac/Backups.backupdb/Mac Pro-Imacom/2012-12-15-143137 (279 KB)
            12/18/12 8:24:22.845 PM com.apple.backupd[548]: Deleted /Volumes/Backup-Internal Working Files-Mac/Backups.backupdb/Mac Pro-Imacom/2012-12-15-133146 (57 KB)
            12/18/12 8:24:23.169 PM com.apple.backupd[548]: Deleted /Volumes/Backup-Internal Working Files-Mac/Backups.backupdb/Mac Pro-Imacom/2012-12-15-123134 (66 KB)
            12/18/12 8:24:23.169 PM com.apple.backupd[548]: Post-back up thinning complete: 5 expired backups removed
            12/18/12 8:24:23.196 PM com.apple.backupd[548]: Backup completed successfully.
            12/18/12 8:27:47.694 PM com.apple.kextd[12]: Warning: /Volumes/Macintosh HD/System/Library/Extensions: No such file or directory
            12/18/12 8:29:49.882 PM com.apple.kextd[12]: Warning: /Volumes/Macintosh HD/System/Library/Extensions: No such file or directory
            12/18/12 8:31:06.559 PM com.apple.launchd.peruser.501[143]: (com.apple.PackageKit.InstallStatus) Throttling respawn: Will start in 8 seconds
            12/18/12 8:31:06.632 PM WindowServer[120]: dict count after removing entry for window 0x2b is 0
            12/18/12 8:31:06.642 PM WindowServer[120]: CGXGetConnectionProperty: Invalid connection 33779
            12/18/12 8:31:06.643 PM WindowServer[120]: CGXGetConnectionProperty: Invalid connection 33779
            12/18/12 8:31:06.651 PM com.apple.launchd.peruser.501[143]: (com.prosofteng.DGMonitor[185]) Exited: Killed: 9
            12/18/12 8:31:06.659 PM coreservicesd[28]: SendFlattenedData, got error #268435459 (ipc/send) invalid destination port from ::mach_msg(), sending notification kLSNotifyApplicationDeath to notificationID=166
            12/18/12 8:31:06.659 PM coreservicesd[28]: SendFlattenedData, got error #268435459 (ipc/send) invalid destination port from ::mach_msg(), sending notification kLSNotifyApplicationDeath to notificationID=179
            12/18/12 8:31:06.660 PM coreservicesd[28]: SendFlattenedData, got error #268435459 (ipc/send) invalid destination port from ::mach_msg(), sending notification kLSNotifyApplicationDeath to notificationID=179
            12/18/12 8:31:06.660 PM coreservicesd[28]: SendFlattenedData, got error #268435459 (ipc/send) invalid destination port from ::mach_msg(), sending notification kLSNotifyApplicationDeath to notificationID=166
            12/18/12 8:31:06.670 PM coreservicesd[28]: SendFlattenedData, got error #268435460 (ipc/send) timed out from ::mach_msg(), sending notification kLSNotifyApplicationDeath to notificationID=315
            12/18/12 8:31:06.670 PM WindowServer[120]: CGXGetConnectionProperty: Invalid connection 33779
            12/18/12 8:31:06.671 PM WindowServer[120]: CGXGetConnectionProperty: Invalid connection 33779
            12/18/12 8:31:06.672 PM Splashtop Streamer[194]: going to close SRFeature.
            12/18/12 8:31:06.922 PM coreservicesd[28]: SendFlattenedData, got error #268435459 (ipc/send) invalid destination port from ::mach_msg(), sending notification kLSNotifyApplicationDeath to notificationID=147
            12/18/12 8:31:06.923 PM WindowServer[120]: CGXGetConnectionProperty: Invalid connection 33779
            12/18/12 8:31:07.171 PM loginwindow[91]: sendQuitEventToApp (FMCore): AESendMessage returned error -1712
            12/18/12 8:31:07.188 PM com.apple.launchd.peruser.501[143]: ([0x0-0x24024].com.apple.AppleSpell[260]) Exited: Terminated: 15
            12/18/12 8:31:07.188 PM com.apple.launchd.peruser.501[143]: (com.apple.mdworker.bundles[610]) Exited: Killed: 9
            12/18/12 8:31:07.188 PM com.apple.launchd.peruser.501[143]: (com.apple.mdworker.shared.03000000-0000-0000-0000-000000000000[589]) Exited: Killed: 9
            12/18/12 8:31:07.676 PM Splashtop Streamer[194]:    AC Power
            12/18/12 8:31:08.418 PM com.apple.usbmuxd[75]: stopping.
            12/18/12 8:31:08.432 PM com.apple.usbmuxd[616]: usbmuxd-296.3 on Jul 25 2012 at 00:28:37, running 64 bit
            12/18/12 8:31:08.703 PM loginwindow[91]: DEAD_PROCESS: 91 console
            12/18/12 8:31:08.730 PM com.apple.kextd[12]: Warning: /Volumes/Macintosh HD/System/Library/Extensions: No such file or directory
            12/18/12 8:31:08.733 PM shutdown[618]: halt by Imacom:
            12/18/12 8:31:08.733 PM shutdown[618]: SHUTDOWN_TIME: 1355880668 733145
            12/18/12 8:31:08.735 PM ntpd[71]: ntpd exiting on signal 15
            12/18/12 8:32:11.000 PM bootlog[0]: BOOT_TIME 1355880731 0
            12/18/12 8:32:13.000 PM kernel[0]: PMAP: PCID enabled
            12/18/12 8:32:13.000 PM kernel[0]: Darwin Kernel Version 12.2.0: Sat Aug 25 00:48:52 PDT 2012; root:xnu-2050.18.24~1/RELEASE_X86_64
            12/18/12 8:32:13.000 PM kernel[0]: vm_page_bootstrap: 8176083 free pages and 179757 wired pages
            12/18/12 8:32:13.000 PM kernel[0]: kext submap [0xffffff7f80741000 - 0xffffff8000000000], kernel text [0xffffff8000200000 - 0xffffff8000741000]
            12/18/12 8:32:13.000 PM kernel[0]: zone leak detection enabled
            12/18/12 8:32:13.000 PM kernel[0]: standard timeslicing quantum is 10000 us
            12/18/12 8:32:13.000 PM kernel[0]: standard background quantum is 2500 us
            12/18/12 8:32:13.000 PM kernel[0]: mig_table_max_displ = 74
            12/18/12 8:32:13.000 PM kernel[0]: corecrypto kext started!
            12/18/12 8:32:13.000 PM kernel[0]: Running kernel space in FIPS MODE
            12/18/12 8:32:13.000 PM kernel[0]: Plist hmac value is    735d392b68241ef173d81097b1c8ce9ba283521626d1c973ac376838c466757d
            12/18/12 8:32:13.000 PM kernel[0]: Computed hmac value is 735d392b68241ef173d81097b1c8ce9ba283521626d1c973ac376838c466757d
            12/18/12 8:32:13.000 PM kernel[0]: corecrypto.kext FIPS integrity POST test passed!
            12/18/12 8:32:13.000 PM kernel[0]: corecrypto.kext FIPS AES CBC POST test passed!
            12/18/12 8:32:13.000 PM kernel[0]: corecrypto.kext FIPS TDES CBC POST test passed!
            12/18/12 8:32:13.000 PM kernel[0]: corecrypto.kext FIPS AES ECB AESNI POST test passed!
            12/18/12 8:32:13.000 PM kernel[0]: corecrypto.kext FIPS AES XTS AESNI POST test passed!
            12/18/12 8:32:13.000 PM kernel[0]: corecrypto.kext FIPS SHA POST test passed!
            12/18/12 8:32:13.000 PM kernel[0]: corecrypto.kext FIPS HMAC POST test passed!
            12/18/12 8:32:13.000 PM kernel[0]: corecrypto.kext FIPS ECDSA POST test passed!
            12/18/12 8:32:13.000 PM kernel[0]: corecrypto.kext FIPS DRBG POST test passed!
            12/18/12 8:32:13.000 PM kernel[0]: corecrypto.kext FIPS POST passed!
            12/18/12 8:32:13.000 PM kernel[0]: AppleACPICPU: ProcessorId=0 LocalApicId=0 Enabled
            12/18/12 8:32:13.000 PM kernel[0]: AppleACPICPU: ProcessorId=1 LocalApicId=32 Enabled
            12/18/12 8:32:13.000 PM kernel[0]: AppleACPICPU: ProcessorId=2 LocalApicId=2 Enabled
            12/18/12 8:32:13.000 PM kernel[0]: AppleACPICPU: ProcessorId=3 LocalApicId=34 Enabled
            12/18/12 8:32:13.000 PM kernel[0]: AppleACPICPU: ProcessorId=4 LocalApicId=4 Enabled
            12/18/12 8:32:13.000 PM kernel[0]: AppleACPICPU: ProcessorId=5 LocalApicId=36 Enabled
            12/18/12 8:32:13.000 PM kernel[0]: AppleACPICPU: ProcessorId=6 LocalApicId=16 Enabled
            12/18/12 8:32:13.000 PM kernel[0]: AppleACPICPU: ProcessorId=7 LocalApicId=48 Enabled
            12/18/12 8:32:13.000 PM kernel[0]: AppleACPICPU: ProcessorId=8 LocalApicId=18 Enabled
            12/18/12 8:32:13.000 PM kernel[0]: AppleACPICPU: ProcessorId=9 LocalApicId=50 Enabled
            12/18/12 8:32:13.000 PM kernel[0]: AppleACPICPU: ProcessorId=10 LocalApicId=20 Enabled
            12/18/12 8:32:13.000 PM kernel[0]: AppleACPICPU: ProcessorId=11 LocalApicId=52 Enabled
            12/18/12 8:32:13.000 PM kernel[0]: AppleACPICPU: ProcessorId=12 LocalApicId=1 Enabled
            12/18/12 8:32:13.000 PM kernel[0]: AppleACPICPU: ProcessorId=13 LocalApicId=33 Enabled
            12/18/12 8:32:13.000 PM kernel[0]: AppleACPICPU: ProcessorId=14 LocalApicId=3 Enabled
            12/18/12 8:32:13.000 PM kernel[0]: AppleACPICPU: ProcessorId=15 LocalApicId=35 Enabled
            12/18/12 8:32:13.000 PM kernel[0]: AppleACPICPU: ProcessorId=16 LocalApicId=5 Enabled
            12/18/12 8:32:13.000 PM kernel[0]: AppleACPICPU: ProcessorId=17 LocalApicId=37 Enabled
            12/18/12 8:32:13.000 PM kernel[0]: AppleACPICPU: ProcessorId=18 LocalApicId=17 Enabled
            12/18/12 8:32:13.000 PM kernel[0]: AppleACPICPU: ProcessorId=19 LocalApicId=49 Enabled
            12/18/12 8:32:13.000 PM kernel[0]: AppleACPICPU: ProcessorId=20 LocalApicId=19 Enabled
            12/18/12 8:32:13.000 PM kernel[0]: AppleACPICPU: ProcessorId=21 LocalApicId=51 Enabled
            12/18/12 8:32:13.000 PM kernel[0]: AppleACPICPU: ProcessorId=22 LocalApicId=21 Enabled
            12/18/12 8:32:13.000 PM kernel[0]: AppleACPICPU: ProcessorId=23 LocalApicId=53 Enabled
            12/18/12 8:32:13.000 PM kernel[0]: calling mpo_policy_init for TMSafetyNet
            12/18/12 8:32:13.000 PM kernel[0]: Security policy loaded: Safety net for Time Machine (TMSafetyNet)
            12/18/12 8:32:13.000 PM kernel[0]: calling mpo_policy_init for Sandbox
            12/18/12 8:32:13.000 PM kernel[0]: Security policy loaded: Seatbelt sandbox policy (Sandbox)
            12/18/12 8:32:13.000 PM kernel[0]: calling mpo_policy_init for Quarantine
            12/18/12 8:32:13.000 PM kernel[0]: Security policy loaded: Quarantine policy (Quarantine)
            12/18/12 8:32:13.000 PM kernel[0]: Copyright (c) 1982, 1986, 1989, 1991, 1993
            12/18/12 8:32:13.000 PM kernel[0]: The Regents of the University of California. All rights reserved.
            12/18/12 8:32:13.000 PM kernel[0]: MAC Framework successfully initialized
            12/18/12 8:32:13.000 PM kernel[0]: using 16384 buffer headers and 10240 cluster IO buffer headers
            12/18/12 8:32:13.000 PM kernel[0]: IOAPIC: Version 0x20 Vectors 64:87
            12/18/12 8:32:13.000 PM kernel[0]: ACPI: System State [S0 S3 S4 S5]
            12/18/12 8:32:13.000 PM kernel[0]: PFM64 (40 cpu) 0xff80000000, 0x80000000
            12/18/12 8:32:13.000 PM kernel[0]: [ PCI configuration begin ]
            12/18/12 8:32:13.000 PM kernel[0]: AppleIntelCPUPowerManagement: Turbo Ratios 222233
            12/18/12 8:32:13.000 PM kernel[0]: AppleIntelCPUPowerManagement: (built 23:03:24 Jun 24 2012) initialization complete
            12/18/12 8:32:13.000 PM kernel[0]: console relocated to 0xff80010000
            12/18/12 8:32:13.000 PM kernel[0]: PCI configuration changed (bridge=7 device=2 cardbus=0)
            12/18/12 8:32:13.000 PM kernel[0]: [ PCI configuration end, bridges 15 devices 51 ]
            12/18/12 8:32:13.000 PM kernel[0]: mbinit: done [128 MB total pool size, (85/42) split]
            12/18/12 8:32:13.000 PM kernel[0]: Pthread support ABORTS when sync kernel primitives misused
            12/18/12 8:32:13.000 PM kernel[0]: ETH0 cannot assert wake from D3cold
            12/18/12 8:32:13.000 PM kernel[0]: ETH1 cannot assert wake from D3cold
            12/18/12 8:32:13.000 PM kernel[0]: rooting via boot-uuid from /chosen: 725DCE99-0F42-35F8-83CF-232BE79F8C0F
            12/18/12 8:32:13.000 PM kernel[0]: Waiting on <dict ID="0"><key>IOProviderClass</key><string ID="1">IOResources</string><key>IOResourceMatch</key><string ID="2">boot-uuid-media</string></dict>
            12/18/12 8:32:13.000 PM kernel[0]: com.apple.AppleFSCompressionTypeZlib kmod start
            12/18/12 8:32:13.000 PM kernel[0]: com.apple.AppleFSCompressionTypeDataless kmod start
            12/18/12 8:32:13.000 PM kernel[0]: com.apple.AppleFSCompressionTypeZlib load succeeded
            12/18/12 8:32:13.000 PM kernel[0]: com.apple.AppleFSCompressionTypeDataless load succeeded
            12/18/12 8:32:13.000 PM kernel[0]: AppleIntelCPUPowerManagementClient: ready
            12/18/12 8:32:13.000 PM kernel[0]: Intel82574L::start - Built Jun 24 2012 23:07:38 -- running on device at b9 d0 f0
            12/18/12 8:32:13.000 PM kernel[0]: Intel82574L::start - Built Jun 24 2012 23:07:38 -- running on device at b10 d0 f0
            12/18/12 8:32:11.745 PM com.apple.launchd[1]: *** launchd[1] has started up. ***
            12/18/12 8:32:13.000 PM kernel[0]: BTCOEXIST off
            12/18/12 8:32:13.000 PM kernel[0]: BRCM tunables:
            12/18/12 8:32:13.000 PM kernel[0]: pullmode[1] txringsize[  256] reapmin[   32] reapcount[  128]
            12/18/12 8:32:13.000 PM kernel[0]: highWaterMark: VO[  192]  VI[  192]  BE[  192]  BK[  192]
            12/18/12 8:32:13.000 PM kernel[0]: FireWire (OHCI) TI ID 823f built-in now active, GUID 78ca39fffe123fc8; max speed s800.
            12/18/12 8:32:13.000 PM kernel[0]: Got boot device = IOService:/AppleACPIPlatformExpert/PCI0@0/AppleACPIPCI/SATA@1F,2/AppleAHCI/PRT2@2/IOAHCID evice@0/AppleAHCIDiskDriver/IOAHCIBlockStorageDevice/IOBlockStorageDriver/OCZ-VERTEX4 Media/IOGUIDPartitionScheme/Vertex SSD @2
            12/18/12 8:32:13.000 PM kernel[0]: BSD root: disk0s2, major 1, minor 2
            12/18/12 8:32:13.000 PM kernel[0]: Kernel is LP64
            12/18/12 8:32:13.000 PM kernel[0]: USBF:          1.616          [0xffffff803ea57000] The IOUSBFamily is having trouble enumerating a USB device that has been plugged in.  It will keep retrying.  (Port 3 of Hub at 0x1d100000)
            12/18/12 8:32:11.745 PM com.apple.launchd[1]: *** Shutdown logging is enabled. ***
            12/18/12 8:32:13.621 PM com.apple.launchd[1]: (com.apple.automountd) Unknown key for boolean: NSSupportsSuddenTermination
            12/18/12 8:32:14.000 PM kernel[0]: Intel82574L: Ethernet address e8:06:88:cc:10:44
            12/18/12 8:32:14.000 PM kernel[0]: Intel82574L: Ethernet address e8:06:88:cc:24:84
            12/18/12 8:32:14.000 PM kernel[0]: AirPort_Brcm4331: Ethernet address 00:26:08:fd:72:91
            12/18/12 8:32:14.000 PM kernel[0]: IO80211Controller::dataLinkLayerAttachComplete():  adding AppleEFINVRAM notification
            12/18/12 8:32:14.877 PM airportd[27]: _processDLILEvent: en2 attached (down)
            12/18/12 8:32:14.926 PM com.apple.SecurityServer[15]: Session 100000 created
            12/18/12 8:32:14.000 PM kernel[0]: createVirtIf(): ifRole = 1
            12/18/12 8:32:14.000 PM kernel[0]: in func createVirtualInterface ifRole = 1
            12/18/12 8:32:14.000 PM kernel[0]: AirPort_Brcm4331_P2PInterface::init name <p2p0> role 1 this 0xffffff803f4e6c00
            12/18/12 8:32:14.000 PM kernel[0]: AirPort_Brcm4331_P2PInterface::init() <p2p> role 1
            12/18/12 8:32:14.000 PM kernel[0]: Created virtif 0xffffff803f4e6c00 p2p0
            12/18/12 8:32:14.977 PM com.apple.SecurityServer[15]: Entering service
            12/18/12 8:32:15.000 PM kernel[0]: Intel82574L::setLinkStatus - not active  1face000, 0
            12/18/12 8:32:15.039 PM UserEventAgent[11]: Captive: [HandleNetworkInformationChanged:2435] nwi_state_copy returned NULL
            12/18/12 8:32:15.171 PM mDNSResponder[51]: mDNSResponder mDNSResponder-379.32.1 (Aug 31 2012 19:05:06) starting OSXVers 12
            12/18/12 8:32:15.258 PM systemkeychain[55]: done file: /var/run/systemkeychaincheck.done
            12/18/12 8:32:15.271 PM mDNSResponder[51]: D2D_IPC: Loaded
            12/18/12 8:32:15.271 PM mDNSResponder[51]: D2DInitialize succeeded
            12/18/12 8:32:15.000 PM kernel[0]: AirPort: Link Down on en2. Reason 8 (Disassociated because station leaving).
            12/18/12 8:32:15.000 PM kernel[0]: en2::IO80211Interface::postMessage bssid changed
            12/18/12 8:32:15.000 PM kernel[0]: Previous Shutdown Cause: 5
            12/18/12 8:32:15.000 PM kernel[0]: IOBluetoothUSBDFU::probe
            12/18/12 8:32:15.000 PM kernel[0]: IOBluetoothUSBDFU::probe ProductID - 0x8215 FirmwareVersion - 0x0201
            12/18/12 8:32:15.000 PM kernel[0]: [BroadcomBluetoothHCIControllerUSBTransport][start] -- completed
            12/18/12 8:32:15.000 PM kernel[0]: [IOBluetoothHCIController][staticBluetoothHCIControllerTransportShowsUp] -- Received Bluetooth Controller register service notification
            12/18/12 8:32:15.000 PM kernel[0]: [IOBluetoothHCIController][start] -- completed
            12/18/12 8:32:15.000 PM kernel[0]: [IOBluetoothHCIController::setConfigState] calling registerService
            12/18/12 8:32:15.000 PM kernel[0]: [AGPM Controller] unknownPlatform
            12/18/12 8:32:15.000 PM kernel[0]: AppleTyMCEDriver::start coreVIDPID = 0x2c708086 Number of packages = 1 Number of cpus = 24 memory monitor trough PCI
            12/18/12 8:32:15.000 PM kernel[0]: Intel82574L::setLinkStatus - not active  1face001, 0
            12/18/12 8:32:15.792 PM configd[17]: bootp_session_transmit: bpf_write(en2) failed: Network is down (50)
            12/18/12 8:32:15.792 PM configd[17]: DHCP en2: INIT-REBOOT transmit failed
            12/18/12 8:32:15.000 PM kernel[0]: USBF:          4.913          [0xffffff803ea57000] The IOUSBFamily was not able to enumerate a device.
            12/18/12 8:32:15.000 PM kernel[0]: DSMOS has arrived
            12/18/12 8:32:15.822 PM configd[17]: network changed: DNS*
            12/18/12 8:32:15.824 PM configd[17]: setting hostname to "Mac-Pro-Imacom-5.local"
            12/18/12 8:32:16.000 PM kernel[0]: Intel82574L::setLinkStatus - not active  1face000, 0
            12/18/12 8:32:16.000 PM kernel[0]: USBF:          5.941          [0xffffff803ea57000] The IOUSBFamily is having trouble enumerating a USB device that has been plugged in.  It will keep retrying.  (Port 3 of Hub at 0x1d100000)
            12/18/12 8:32:16.000 PM kernel[0]: MacAuthEvent en2   Auth result for: 00:0f:66:43:a4:fa  MAC AUTH succeeded
            12/18/12 8:32:16.000 PM kernel[0]: wlEvent: en2 en2 Link UP virtIf = 0
            12/18/12 8:32:16.000 PM kernel[0]: AirPort: Link Up on en2
            12/18/12 8:32:16.000 PM kernel[0]: en2: BSSID changed to 00:0f:66:43:a4:fa
            12/18/12 8:32:16.000 PM kernel[0]: en2::IO80211Interface::postMessage bssid changed
            12/18/12 8:32:17.000 PM kernel[0]: AirPort: RSN handshake complete on en2
            12/18/12 8:32:17.304 PM airportd[27]: _doAutoJoin: Already associated to “abrazite”. Bailing on auto-join.
            12/18/12 8:32:17.730 PM hidd[96]: Posting 'com.apple.iokit.hid.displayStatus' notifyState=1
            12/18/12 8:32:17.000 PM kernel[0]: macx_swapon SUCCESS
            12/18/12 8:32:17.736 PM hidd[96]: void __IOHIDLoadBundles(): Loaded 0 HID plugins
            12/18/12 8:32:17.761 PM appleeventsd[101]: main: Starting up
            12/18/12 8:32:17.762 PM com.apple.kextd[12]: Can't load /System/Library/Extensions/CiscoVPN.kext - no code for running kernel's architecture.
            12/18/12 8:32:17.767 PM SystemStarter[77]: Cisco Systems VPN Client Kernel Extension (114) did not complete successfully
            12/18/12 8:32:17.767 PM SystemStarter[77]: The following StartupItems failed to start properly:
            12/18/12 8:32:17.767 PM SystemStarter[77]: /System/Library/StartupItems/CiscoVPN
            12/18/12 8:32:17.767 PM SystemStarter[77]:  - execution of Startup script failed
            12/18/12 8:32:17.768 PM kdc[94]: label: default
            12/18/12 8:32:17.768 PM kdc[94]:           dbname: od:/Local/Default
            12/18/12 8:32:17.768 PM kdc[94]:           mkey_file: /var/db/krb5kdc/m-key
            12/18/12 8:32:17.769 PM kdc[94]:           acl_file: /var/db/krb5kdc/kadmind.acl
            12/18/12 8:32:17.785 PM kdc[94]: WARNING Found KDC certificate (O=System Identity,CN=com.apple.kerberos.kdc)is missing the PK-INIT KDC EKU, this is bad for interoperability.
            12/18/12 8:32:17.789 PM com.apple.usbmuxd[75]: usbmuxd-296.3 on Jul 25 2012 at 00:28:37, running 64 bit
            12/18/12 8:32:17.807 PM loginwindow[91]: Login Window Application Started
            12/18/12 8:32:17.812 PM apsd[107]: CGSLookupServerRootPort: Failed to look up the port for "com.apple.windowserver.active" (1102)
            12/18/12 8:32:17.813 PM apsd[107]: CGSLookupServerRootPort: Failed to look up the port for "com.apple.windowserver.active" (1102)
            12/18/12 8:32:17.814 PM netbiosd[87]: Unable to start NetBIOS name service:
            12/18/12 8:32:17.819 PM awacsd[105]: Starting awacsd connectivity-78 (Jul 26 2012 14:37:46)
            12/18/12 8:32:17.822 PM awacsd[105]: InnerStore CopyAllZones: no info in Dynamic Store
            12/18/12 8:32:17.830 PM coreservicesd[28]: FindBestLSSession(), no match for inSessionID 0xfffffffffffffffc auditTokenInfo( uid=0 euid=0 auSessionID=100000 create=false
            12/18/12 8:32:17.831 PM mds[88]: (Normal) FMW: FMW 0 0
            12/18/12 8:32:17.840 PM kdc[94]: KDC started
            12/18/12 8:32:17.867 PM locationd[92]: NOTICE,Location icon should now be in state 0
            12/18/12 8:32:17.877 PM WindowServer[120]: Server is starting up
            12/18/12 8:32:17.880 PM WindowServer[120]: Session 256 retained (2 references)
            12/18/12 8:32:17.880 PM WindowServer[120]: Session 256 released (1 references)
            12/18/12 8:32:17.889 PM WindowServer[120]: Session 256 retained (2 references)
            12/18/12 8:32:17.890 PM WindowServer[120]: init_page_flip: page flip mode is on
            12/18/12 8:32:18.141 PM BBDaemon[109]: IOBSDNameMatching returned a NULL dictionary.
            12/18/12 8:32:18.000 PM kernel[0]: Ethernet [Intel82574L]: Link up on en0, 1-Gigabit, Full-duplex, Symmetric flow-control, Debug [796d,af48,0de1,0200,c5e1,2800]
            12/18/12 8:32:18.000 PM kernel[0]: Intel82574L::setLinkStatus - active  1face000, b
            12/18/12 8:32:19.400 PM WindowServer[120]: mux_initialize: Couldn't find any matches
            12/18/12 8:32:19.414 PM WindowServer[120]: GLCompositor enabled for tile size [256 x 256]
            12/18/12 8:32:19.414 PM WindowServer[120]: CGXGLInitMipMap: mip map mode is on
            12/18/12 8:32:19.440 PM WindowServer[120]: WSMachineUsesNewStyleMirroring: false
            12/18/12 8:32:19.441 PM WindowServer[120]: Display 0x04241064: GL mask 0x1; bounds (0, 0)[2560 x 1600], 57 modes available
            Main, Active, on-line, enabled, boot, Vendor 610, Model 9232, S/N 2009ce4, Unit 0, Rotation 0
            UUID 0x000006100000923202009ce400000000
            12/18/12 8:32:19.442 PM WindowServer[120]: Display 0x003f003e: GL mask 0x4; bounds (0, 0)[0 x 0], 1 modes available
            off-line, enabled, Vendor ffffffff, Model ffffffff, S/N ffffffff, Unit 2, Rotation 0
            UUID 0xffffffffffffffffffffffff003f003e
            12/18/12 8:32:19.442 PM WindowServer[120]: Display 0x003f003d: GL mask 0x2; bounds (0, 0)[0 x 0], 1 modes available
            off-line, enabled, Vendor ffffffff, Model ffffffff, S/N ffffffff, Unit 1, Rotation 0
            UUID 0xffffffffffffffffffffffff003f003d
            12/18/12 8:32:19.450 PM WindowServer[120]: Created shield window 0x5 for display 0x04241064
            12/18/12 8:32:19.450 PM WindowServer[120]: Created shield window 0x6 for display 0x003f003e
            12/18/12 8:32:19.451 PM WindowServer[120]: Created shield window 0x7 for display 0x003f003d
            12/18/12 8:32:19.452 PM WindowServer[120]: Display 0x04241064: GL mask 0x1; bounds (0, 0)[2560 x 1600], 57 modes available
            12/18/12 8:32:19.452 PM WindowServer[120]: Display 0x003f003e: GL mask 0x4; bounds (3584, 0)[1 x 1], 1 modes available
            12/18/12 8:32:19.452 PM WindowServer[120]: Display 0x003f003d: GL mask 0x2; bounds (3585, 0)[1 x 1], 1 modes available
            12/18/12 8:32:19.452 PM WindowServer[120]: CGXPerformInitialDisplayConfiguration
            12/18/12 8:32:19.452 PM WindowServer[120]:   Display 0x04241064: MappedDisplay Unit 0; Vendor 0x610 Model 0x9232 S/N 33594596 Dimensions 25.24 x 15.79; online enabled, Bounds (0,0)[2560 x 1600], Rotation 0, Resolution 1
            12/18/12 8:32:19.452 PM WindowServer[120]:   Display 0x003f003e: MappedDisplay Unit 2; Vendor 0xffffffff Model 0xffffffff S/N -1 Dimensions 0.00 x 0.00; offline enabled, Bounds (3584,0)[1 x 1], Rotation 0, Resolution 1
            12/18/12 8:32:19.452 PM WindowServer[120]:   Display 0x003f003d: MappedDisplay Unit 1; Vendor 0xffffffff Model 0xffffffff S/N -1 Dimensions 0.00 x 0.00; offline enabled, Bounds (3585,0)[1 x 1], Rotation 0, Resolution 1
            12/18/12 8:32:19.476 PM WindowServer[120]: GLCompositor: GL renderer id 0x01021b01, GL mask 0x00000007, accelerator 0x00003f37, unit 0, caps QEX|QGL|MIPMAP, vram 1024 MB
            12/18/12 8:32:19.476 PM WindowServer[120]: GLCompositor: GL renderer id 0x01021b01, GL mask 0x00000007, texture units 8, texture max 16384, viewport max {16384, 16384}, extensions FPRG|NPOT|GLSL|FLOAT
            12/18/12 8:32:19.479 PM loginwindow[91]: **DMPROXY** Found `/System/Library/CoreServices/DMProxy'.
            12/18/12 8:32:19.482 PM launchctl[126]: launchctl: Dubious permissions on file (skipping): /Library/LaunchAgents/com.adobe.AAM.Updater-1.0.plist
            12/18/12 8:32:19.517 PM WindowServer[120]: Created shield window 0x8 for display 0x04241064
            12/18/12 8:32:19.518 PM WindowServer[120]: Display 0x04241064: MappedDisplay Unit 0; ColorProfile { 2, "Cinema HD"}; TransferFormula (1.000000, 1.000000, 1.000000)
            12/18/12 8:32:19.522 PM launchctl[128]: launchctl: Dubious permissions on file (skipping): /Library/LaunchAgents/com.adobe.AAM.Updater-1.0.plist
            12/18/12 8:32:19.537 PM launchctl[128]: com.apple.findmymacmessenger: Already loaded
            12/18/12 8:32:19.550 PM com.apple.SecurityServer[15]: Session 100005 created
            12/18/12 8:32:19.563 PM airportd[27]: _doAutoJoin: Already associated to “abrazite”. Bailing on auto-join.
            12/18/12 8:32:19.589 PM loginwindow[91]: Login Window Started Security Agent
            12/18/12 8:32:19.652 PM SecurityAgent[139]: This is the first run
            12/18/12 8:32:19.652 PM SecurityAgent[139]: MacBuddy was run = 0
            12/18/12 8:32:19.662 PM WindowServer[120]: MPAccessSurfaceForDisplayDevice: Set up page flip mode on display 0x04241064 device: 0x10a6a8320  isBackBuffered: 1 numComp: 3 numDisp: 3
            12/18/12 8:32:19.699 PM SecurityAgent[139]: User info context values set for Imacom
            12/18/12 8:32:19.766 PM coreaudiod[137]: 2012-12-18 08:32:19.765891 PM [AirPlay] Started browsing for _airplay._tcp.
            12/18/12 8:32:19.766 PM coreaudiod[137]: 2012-12-18 08:32:19.766406 PM [AirPlay] Started browsing for _raop._tcp.
            12/18/12 8:32:20.010 PM loginwindow[91]: Login Window - Returned from Security Agent
            12/18/12 8:32:20.013 PM loginwindow[91]: ERROR | ScreensharingLoginNotification | Failed sending message to screen sharing GetScreensharingPort, err: 1102
            12/18/12 8:32:20.022 PM loginwindow[91]: USER_PROCESS: 91 console
            12/18/12 8:32:20.043 PM airportd[27]: _doAutoJoin: Already associated to “abrazite”. Bailing on auto-join.
            12/18/12 8:32:20.047 PM launchctl[144]: launchctl: Dubious permissions on file (skipping): /Library/LaunchAgents/com.adobe.AAM.Updater-1.0.plist
            12/18/12 8:32:20.066 PM launchctl[145]: launchctl: Dubious permissions on file (skipping): /Library/LaunchAgents/com.adobe.AAM.Updater-1.0.plist
            12/18/12 8:32:20.072 PM com.apple.launchd[1]: (com.wacom.wacomtablet[135]) Exited with code: 255
            12/18/12 8:32:20.079 PM com.apple.launchd.peruser.501[143]: (com.apple.gamed) Ignored this key: UserName
            12/18/12 8:32:20.079 PM com.apple.launchd.peruser.501[143]: (com.apple.gamed) Ignored this key: GroupName
            12/18/12 8:32:20.080 PM com.apple.launchd.peruser.501[143]: (com.apple.ReportCrash) Falling back to default Mach exception handler. Could not find: com.apple.ReportCrash.Self
            12/18/12 8:32:20.084 PM loginwindow[91]: Connection with distnoted server was invalidated
            12/18/12 8:32:20.089 PM distnoted[147]: # distnote server agent  absolute time: 9.446965734   civil time: Tue Dec 18 20:32:20 2012   pid: 147 uid: 501  root: no
            12/18/12 8:32:20.130 PM WindowServer[120]: **DMPROXY** (2) Found `/System/Library/CoreServices/DMProxy'.
            12/18/12 8:32:20.163 PM WindowServer[120]: Display 0x04241064: MappedDisplay Unit 0; ColorProfile { 2, "Cinema HD"}; TransferFormula (1.000000, 1.000000, 1.000000)
            12/18/12 8:32:20.163 PM com.apple.SecurityServer[15]: Session 100003 created
            12/18/12 8:32:20.230 PM com.apple.launchd.peruser.501[143]: (com.akamai.single-user-client[187]) Bug: 12C60: launchd + 95444 [7DCC9489-2DF5-3807-83FA-EF5666EE8078]: 0xd
            12/18/12 8:32:20.230 PM com.apple.launchd.peruser.501[143]: (com.akamai.client.plist[188]) Bug: 12C60: launchd + 95444 [7DCC9489-2DF5-3807-83FA-EF5666EE8078]: 0xd
            12/18/12 8:32:20.230 PM talagent[155]: _LSSetApplicationInformationItem(kLSDefaultSessionID, asn, _kLSApplicationIsHiddenKey, hidden ? kCFBooleanTrue : kCFBooleanFalse, NULL) produced OSStatus -50 on line 623 in TCApplication.m
            12/18/12 8:32:20.231 PM talagent[155]: _LSSetApplicationInformationItem(kLSDefaultSessionID, asn, TAL_kLSIsProxiedForTALKey, kCFBooleanTrue, NULL) produced OSStatus -50 on line 626 in TCApplication.m
            12/18/12 8:32:20.233 PM com.apple.launchd.peruser.501[143]: (com.apple.afpstat-qfa[177]) Exited with code: 2
            12/18/12 8:32:20.236 PM com.apple.launchd.peruser.501[143]: (com.adobe.ARM.0d92f8f114b2d0af95462120762f939f6c66651ac8ac214cb7bdbd84[191]) Exited with code: 2
            12/18/12 8:32:20.268 PM SRServiceAgent[179]: service agent got ipc message: 1094931542
            12/18/12 8:32:20.269 PM SRServiceAgent[179]: try start streamer
            12/18/12 8:32:20.271 PM SRServiceAgent[179]: start check timer
            12/18/12 8:32:20.272 PM SRServiceAgent[179]: create new task
            12/18/12 8:32:20.273 PM SRServiceAgent[179]: task is not running, launch task
            12/18/12 8:32:20.311 PM launchctl[198]: launchctl: Dubious permissions on file (skipping): /Library/LaunchAgents/com.adobe.AAM.Updater-1.0.plist
            12/18/12 8:32:20.359 PM NetworkBrowserAgent[199]: Starting NetworkBrowserAgent
            12/18/12 8:32:20.000 PM kernel[0]: USBF:          9.440          [0xffffff803ea57000] The IOUSBFamily was not able to enumerate a device.
            12/18/12 8:32:20.000 PM kernel[0]: CODE SIGNING: cs_invalid_page(0x1000): p=181[GoogleSoftwareUp] clearing CS_VALID
            12/18/12 8:32:20.533 PM Splashtop Streamer[194]: NSWindow does not support utility styleMask 0x10
            12/18/12 8:32:20.542 PM Splashtop Streamer[194]: NSWindow does not support utility styleMask 0x10
            12/18/12 8:32:20.544 PM Splashtop Streamer[194]: NSWindow does not support utility styleMask 0x10
            12/18/12 8:32:20.549 PM Splashtop Streamer[194]: NSWindow does not support utility styleMask 0x10
            12/18/12 8:32:20.551 PM Splashtop Streamer[194]: NSWindow does not support utility styleMask 0x10
            12/18/12 8:32:20.562 PM Splashtop Streamer[194]: Could not connect the action toggleServer: to target of class SplashtopRemoteAppDelegate
            12/18/12 8:32:20.586 PM Splashtop Streamer[194]: -[DisplayView initWithFrame:] [{{0, 0}, {380, 70}}][{{0, 0}, {380, 70}}]
            12/18/12 8:32:20.589 PM Splashtop Streamer[194]: -[DisplayView(Private) setTextField:string:] 1 [{{20, 0}, {380, 70}}]
            12/18/12 8:32:20.590 PM Splashtop Streamer[194]: -[DisplayView(Private) setTextField:string:] 2 [{{20, 0}, {85, 14}}]
            12/18/12 8:32:20.593 PM Splashtop Streamer[194]: ---- http://www.splashtop.com/splashtop2#otherproducts-tab
            12/18/12 8:32:20.597 PM Splashtop Streamer[194]: going to close SRFeature.
            12/18/12 8:32:20.769 PM CalendarAgent[174]: *** -[IADomainCache init]: IA domains cache is out of date.
            12/18/12 8:32:21.000 PM kernel[0]: USBF:          10.357          [0xffffff803ea57000] The IOUSBFamily is having trouble enumerating a USB device that has been plugged in.  It will keep retrying.  (Port 3 of Hub at 0x1d100000)
            12/18/12 8:32:21.110 PM YouSendIt Desktop App[223]: Set Version number 2.0.0.204
            12/18/12 8:32:21.116 PM Trim Enabler[221]: ON
            12/18/12 8:32:21.270 PM YouSendIt Desktop App[223]: finderPearlServerConnection = (** NSConnection 0x106620590 receivePort <NSMachPort: 0x106620730> sendPort <NSMachPort: 0x106620730> refCount 1 remoteUsesKeyedDO: 0 **), pearlServices = <YSIPearlServices: 0x106690f60>
            12/18/12 8:32:21.296 PM YouSendIt Desktop App[223]: Need to check OSAX bundle
            12/18/12 8:32:21.298 PM YouSendIt Desktop App[223]: internal version=2.0.0.204, installed version=2.0.0.204
            12/18/12 8:32:21.307 PM YouSendIt Desktop App[223]: No valid connection
            12/18/12 8:32:21.451 PM WindowServer[120]: **DMPROXY** (2) Found `/System/Library/CoreServices/DMProxy'.
            12/18/12 8:32:21.499 PM WindowServer[120]: Display 0x04241064: MappedDisplay Unit 0; ColorProfile { 2, "Cinema HD"}; TransferFormula (1.000000, 1.000000, 1.000000)
            12/18/12 8:32:21.532 PM WindowServer[120]: Display 0x04241064: MappedDisplay Unit 0; ColorProfile { 2, "Cinema HD"}; TransferFormula (1.000000, 1.000000, 1.000000)
            12/18/12 8:32:21.630 PM DGAgent[185]: Resolved DG link from bookmark. /Applications/Drive Genius 3.app
            12/18/12 8:32:21.673 PM SRFeature[230]: Display server path : /Applications/Splashtop Streamer.app/Contents/MacOS/SRFeature.app/Contents/MacOS/SRXDisplayServer.app/Contents/Ma cOS/SRXDisplayServer
            12/18/12 8:32:21.703 PM SRXDisplayServer[232]: No SRX Display Card
            12/18/12 8:32:21.716 PM appleprofilepolicyd[234]: appleprofilepolicyd: profiling drivers not loaded, loading
            12/18/12 8:32:21.789 PM coreservicesd[28]: Can't change an application into stopped state for app App:"Finder" [ 0x0/0x11011]  @ 0x0x7ffa9ec00980 because it's already been started.
            12/18/12 8:32:21.841 PM WindowServer[120]: CGXSetWindowShadowParameters: Operation on a window 0x1c requiring rights kCGSWindowRightOwner by caller talagent
            12/18/12 8:32:21.907 PM CalendarAgent[174]: [com.apple.calendar.store.log.caldav.queue] [Account refresh failed with error: Error Domain=NSURLErrorDomain Code=-1009 "The Internet connection appears to be offline." UserInfo=0x7f91de20ab10 {NSUnderlyingError=0x7f91d841ac80 "The Internet connection appears to be offline.", NSErrorFailingURLStringKey=https://imacom%40imacomdesign.com@www.google.com/calendar/dav/imacom%40imacomdesign.com/us er///imacom%40imacomdesign.com@www.google.com/calendar/dav/imacom%40imacomdesign.com/user/, NSErrorFailingURLKey=https://imacom%40imacomdesign.com@www.google.com/calendar/dav/imacom%40imacomdesign.com/us er///imacom%40imacomdesign.com@www.google.com/calendar/dav/imacom%40imacomdesign.com/user/, AccountName=hmeichel@imacomdesign.com, CalDAVErrFromRefresh=YES, NSLocalizedDescription=The Internet connection appears to be offline.}]
            12/18/12 8:32:21.972 PM SRFeature[230]: pInfo data: [2][b000000][b][0]
            12/18/12 8:32:21.974 PM SRFeature[230]: FH: GetInfo
            12/18/12 8:32:21.978 PM SRFeature[230]: Error -5 sending Cancel request to remote message port.
            12/18/12 8:32:21.985 PM coreservicesd[28]: SendFlattenedData, got error #268435460 (ipc/send) timed out from ::mach_msg(), sending notification kLSNotifyApplicationReady to notificationID=165
            12/18/12 8:32:22.008 PM Finder[158]: SDL checking if Pearl was loaded. hasLoaded=NO, addr=1071b22f4
            12/18/12 8:32:22.009 PM Finder[158]: not loaded, returning 1
            12/18/12 8:32:22.000 PM kernel[0]: USBF:          11.221          [0xffffff803ea57000] The IOUSBFamily gave up enumerating a USB device after 10 retries.  (Port 3 of Hub at 0x1d100000)
            12/18/12 8:32:22.000 PM kernel[0]: USBF:          11.221          [0xffffff803ea57000] The IOUSBFamily was not able to enumerate a device.
            12/18/12 8:32:22.010 PM Finder[158]: handleYSILoad
            12/18/12 8:32:22.011 PM Finder[158]: YSI pearl loaded
            12/18/12 8:32:22.079 PM Finder[158]: pearl listener registered
            12/18/12 8:32:22.000 PM kernel[0]: Finder (map: 0xffffff803fcea138) triggered DYLD shared region unnest for map: 0xffffff803fcea138, region 0x7fff92e00000->0x7fff93000000. While not abnormal for debuggers, this increases system memory footprint until the target exits.
            12/18/12 8:32:22.800 PM coreservicesd[28]: SendFlattenedData, got error #268435460 (ipc/send) timed out from ::mach_msg(), sending notification kLSNotifyChildApplicationLaunch to notificationID=131
            12/18/12 8:32:23.606 PM com.apple.launchd.peruser.501[143]: ([0x0-0x1f01f].com.yousendit.YouSendIt[223]) Job appears to have crashed: Abort trap: 6
            12/18/12 8:32:23.714 PM blued[68]: kBTXPCUpdateUserPreferences gConsoleUserUID = 501
            12/18/12 8:32:23.769 PM ReportCrash[239]: Saved crash report for YouSendIt Desktop App[223] version 2.0.0.204 (2.0.0.204) to /Users/Imacom/Library/Logs/DiagnosticReports/YouSendIt Desktop App_2012-12-18-203223_Mac-Pro-Imacom-5.crash
            12/18/12 8:32:23.775 PM ReportCrash[239]: Removing excessive log: file://localhost/Users/Imacom/Library/Logs/DiagnosticReports/YouSendIt%20Desktop%20App_20 12-11-24-083605_Mac-Pro-Imacom-5.crash
            12/18/12 8:32:24.450 PM configd[17]: network changed: v4(en0+:10.10.1.104) DNS+ Proxy+ SMB
            12/18/12 8:32:25.095 PM Finder[158]: connection went invalid while waiting for a reply because a mach port died
            12/18/12 8:32:25.097 PM Finder[158]: (
                      0   CoreFoundation                      0x00007fff905b30a6 __exceptionPreprocess + 198
                      1   libobjc.A.dylib                     0x00007fff918763f0 objc_exception_throw + 43
                      2   CoreFoundation                      0x00007fff905b2e7c +[NSException raise:format:] + 204
                      3   Foundation                          0x00007fff901ab557 -[NSConnection sendInvocation:internal:] + 3079
                      4   CoreFoundation                      0x00007fff905a1737 ___forwarding___ + 775
                      5   CoreFoundation                      0x00007fff905a13b8 _CF_forwarding_prep_0 + 232
                      6   Foundation                          0x00007fff901a9a69 -[NSConnection rootProxy] + 71
                      7   YSIPearl                            0x000000010ba79034 -[YSIPearl distributedServer] + 235
                      8   YSIPearl                            0x000000010ba7811a -[YSIPearl startup] + 2114
                      9   Foundation                          0x00007fff90191677 __NSThreadPerformPerform + 225
                      10  CoreFoundation                      0x00007fff90532101 __CFRUNLOOP_IS_CALLING_OUT_TO_A_SOURCE0_PERFORM_FUNCTION__ + 17
                      11  CoreFoundation                      0x00007fff90531a25 __CFRunLoopDoSources0 + 245
                      12  CoreFoundation                      0x00007fff90554dc5 __CFRunLoopRun + 789
                      13  CoreFoundation                      0x00007fff905546b2 CFRunLoopRunSpecific + 290
                      14  HIToolbox                           0x00007fff924880a4 RunCurrentEventLoopInMode + 209
                      15  HIToolbox                           0x00007fff92487e42 ReceiveNextEventCommon + 356
                      16  HIToolbox                           0x00007fff92487cd3 BlockUntilNextEventMatchingListInMode + 62
                      17  AppKit                              0x00007fff95453613 _DPSNextEvent + 685
                      18  AppKit                              0x00007fff95452ed2 -[NSApplication nextEventMatchingMask:untilDate:inMode:dequeue:] + 128
                      19  AppKit                              0x00007fff9544a283 -[NSApplication run] + 517
                      20  AppKit                              0x00007fff953eecb6 NSApplicationMain + 869
                      21  Finder                              0x0000000106527b46 Finder + 23366
                      22  libdyld.dylib                       0x00007fff966d97e1 start + 0
            12/18/12 8:32:25.100 PM ntpd[71]: proto: precision = 1.000 usec
            12/18/12 8:32:25.232 PM Trim Enabler[221]: ON
            12/18/12 8:32:25.000 PM kernel[0]: Intel82574L::timeoutHandler - no link - reset the chipset once  1face001, 0
            12/18/12 8:32:25.000 PM kernel[0]: Intel82574L::setLinkStatus - not active  1face001, 0
            12/18/12 8:32:26.178 PM locationd[273]: NOTICE,Location icon should now be in state 0
            12/18/12 8:32:26.000 PM kernel[0]: Intel82574L::setLinkStatus - not active  1face001, 0
            12/18/12 8:32:26.239 PM UserEventAgent[146]: cannot find fw daemon port 1102
            12/18/12 8:32:26.340 PM com.apple.launchd[1]: (com.apple.xprotectupdater[73]) Exited with code: 252
            12/18/12 8:32:27.019 PM Splashtop Streamer[194]: SRFEAT_NOTIFY_SERVER_CLOUD_NOTIFY_MSG
            12/18/12 8:32:27.020 PM Splashtop Streamer[194]: [ProcServerNotification] SRS_SERVER_RTN_INFO : [200][.srloginnotify.xml]
            12/18/12 8:32:27.021 PM Splashtop Streamer[194]:   receive backend string notify
            12/18/12 8:32:27.022 PM Splashtop Streamer[194]: -[CMXMLParser length]: unrecognized selector sent to instance 0x101505f30
            12/18/12 8:32:27.024 PM Splashtop Streamer[194]: (
                      2   CoreFoundation                      0x00007fff906496ea -[NSObject(NSObject) doesNotRecognizeSelector:] + 186
                      3   CoreFoundation                      0x00007fff905a15ce ___forwarding___ + 414
                      4   CoreFoundation                      0x00007fff905a13b8 _CF_forwarding_prep_0 + 232
                      5   Foundation                          0x00007fff9016bea8 -[NSPlaceholderString initWithString:] + 169
                      7   CoreFoundation                      0x00007fff9060f5cc ____CFXNotificationPostToken_block_invoke_0 + 284
                      8   CoreFoundation                      0x00007fff90570272 __CFRUNLOOP_IS_CALLING_OUT_TO_A_BLOCK__ + 18
                      9   CoreFoundation                      0x00007fff90530a4f __CFRunLoopDoBlocks + 255
                      10  CoreFoundation                      0x00007fff90555220 __CFRunLoopRun + 1904
                      11  CoreFoundation                      0x00007fff905546b2 CFRunLoopRunSpecific + 290
                      12  HIToolbox                           0x00007fff924880a4 RunCurrentEventLoopInMode + 209
                      13  HIToolbox                           0x00007fff92487e42 ReceiveNextEventCommon + 356
                      14  HIToolbox                           0x00007fff92487cd3 BlockUntilNextEventMatchingListInMode + 62
                      15  AppKit                              0x00007fff95453613 _DPSNextEvent + 685
                      16  AppKit                              0x00007fff95452ed2 -[NSApplication nextEventMatchingMask:untilDate:inMode:dequeue:] + 128
                      17  AppKit                              0x00007fff9544a283 -[NSApplication run] + 517
                      18  AppKit                              0x00007fff953eecb6 NSApplicationMain + 869
            12/18/12 8:32:27.320 PM launchctl[294]: launchctl: Dubious permissions on file (skipping): /Library/LaunchAgents/com.adobe.AAM.Updater-1.0.plist
            12/18/12 8:32:27.982 PM iCalExternalSync[259]: [0x7fa87940e500] |Miscellaneous|Error| SyncServices precondition failure in [ISyncConcreteSession pushChangesFromRecord:withIdentifier:]: you can't change the record's entity name from com.apple.calendars.MailAlarm to com.apple.calendars.DisplayAlarm in {
                "com.apple.syncservices.RecordEntityName" = "com.apple.calendars.DisplayAlarm";
                description = "";
                owner =     (
                    "Event/p935"
                triggerduration = "-900";
            12/18/12 8:32:27.982 PM iCalExternalSync[259]: [ICalExternalSync ]Encountered exception: [ISyncConcreteSession pushChangesFromRecord:withIdentifier:]: you can't change the record's entity name from com.apple.calendars.MailAlarm to com.apple.calendars.DisplayAlarm in {
                description = "";
                owner =     (
                    "Event/p935"
            } withStack: (
                      0   iCalExternalSync                    0x000000010b5a2a60 iCalExternalSync + 125536
                      1   iCalExternalSync                    0x000000010b591ac9 iCalExternalSync + 56009
                      2   iCalExternalSync                    0x000000010b5a1694 iCalExternalSync + 120468
                      3   libdyld.dylib                       0x00007fff966d97e1 start + 0
            12/18/12 8:32:27.983 PM iCalExternalSync[259]: [ICalExternalSync ]NSException name:ISyncInvalidArgumentsException reason:[ISyncConcreteSession pushChangesFromRecord:withIdentifier:]: you can't change the record's entity name from com.apple.calendars.MailAlarm to com.apple.calendars.DisplayAlarm in {
                description = "";
                owner =     (
                    "Event/p935"
            12/18/12 8:32:27.984 PM SyncServer[261]: [0x7fb200c0bd80] |Server|Warning| lost connection 0x7fb204400f40 to com.apple.iCal
            12/18/12 8:32:28.010 PM Trim Enabler[221]: /Applications/Trim En
            12/18/12 8:32:28.672 PM osascript[298]: CFURLGetFSRef was passed this URL which has no scheme (the URL may not work with other CFURL routines): /
            12/18/12 8:32:31.830 PM Splashtop Streamer[194]: going to close SRFeature.
            12/18/12 8:32:31.832 PM configd[17]: network changed: v4(en0:10.10.1.104, en2+:10.10.1.119) DNS* Proxy SMB
            12/18/12 8:32:31.848 PM UserEventAgent[11]: Captive: en2: Not probing 'abrazite' (protected network)
            12/18/12 8:32:31.851 PM configd[17]: network changed: v4(en0:10.10.1.104, en2!:10.10.1.119) DNS Proxy SMB
            12/18/12 8:32:33.119 PM Splashtop Streamer[194]: cannot create remote port
            12/18/12 8:32:33.119 PM Splashtop Streamer[194]: Error -50 sending  ping to SRFeature.
            12/18/12 8:32:33.119 PM Splashtop Streamer[194]: Can not find SRFeature alive
            12/18/12 8:32:33.120 PM Splashtop Streamer[194]: going to close SRFeature.
            12/18/12 8:32:33.336 PM awacsd[105]: Exiting
            12/18/12 8:32:33.512 PM CalendarAgent[174]: [com.apple.calendar.store.log.caldav] [During deep refresh in calendar "ImacomDesign", had collection tag match, but etag mismatch for url https://www.google.com/calendar/dav/imacom%40imacomdesign.com/events/http%3A%2F%2Fwww.brig httalk.com%2Fwebcast%2F452%2F30511.ics: server resource not present locally - cTag:63491553238 syncToken:(null)]
            12/18/12 8:32:33.512 PM CalendarAgent[174]: [com.apple.calendar.store.log.caldav] [During deep refresh in calendar "ImacomDesign", had collection tag match, but etag mismatch for url https://www.google.com/calendar/dav/imacom%40imacomdesign.com/events/http%3A%2F%2Fwww.brig httalk.com%2Fwebcast%2F21640.ics: server resource not present locally - cTag:63491553238 syncToken:(null)]
            12/18/12 8:32:40.508 PM CalendarAgent[174]: [com.apple.calendar.store.log.caldav] [During deep refresh in calendar "Helen Eichel - Work", had collection tag match, but etag mismatch for url https://www.google.com/calendar/dav/imacomdesign.com_7klr0v2r8acrf2adifrcupk6i4%40group.ca lendar.google.com/events/http%3A%2F%2Fwww.brighttalk.com%2Fwebcast%2F21640.ics: server resource not present locally - cTag:63486933486 syncToken:(null)]
            12/18/12 8:32:40.509 PM CalendarAgent[174]: [com.apple.calendar.store.log.caldav] [During deep refresh in calendar "Helen Eichel - Work", had collection tag match, but etag mismatch for url https://www.google.com/calendar/dav/imacomdesign.com_7klr0v2r8acrf2adifrcupk6i4%40group.ca lendar.google.com/events/http%3A%2F%2Fwww.brighttalk.com%2Fwebcast%2F452%2F30511.ics: server resource not present locally - cTag:63486933486 syncToken:(null)]
            12/18/12 8:32:40.574 PM com.apple.launchd[1]: (com.apple.coreservices.appleid.authentication[134]) Exit timeout elapsed (20 seconds). Killing
            12/18/12 8:32:40.786 PM SRServiceAgent[179]: cannot find SRFeature
            12/18/12 8:32:44.159 PM SRFeature[306]: Display server path : /Applications/Splashtop Streamer.app/Contents/MacOS/SRFeature.app/Contents/MacOS/SRXDisplayServer.app/Contents/Ma cOS/SRXDisplayServer
            12/18/12 8:32:44.179 PM SRXDisplayServer[308]: No SRX Display Card
            12/18/12 8:32:44.405 PM SRFeature[306]: pInfo data: [2][b000000][b][0]
            12/18/12 8:32:44.406 PM SRFeature[306]: FH: GetInfo
            12/18/12 8:32:45.934 PM iCalExternalSync[305]: [0x7fd021c0e500] |Miscellaneous|Error| SyncServices precondition failure in [ISyncConcreteSession pushChangesFromRecord:withIdentifier:]: you can't change the record's entity name from com.apple.calendars.MailAlarm to com.apple.calendars.DisplayAlarm in {
                description = "";
                owner =     (
                    "Event/p935"
            12/18/12 8:32:45.935 PM iCalExternalSync[305]: [ICalExternalSync ]Encountered exception: [ISyncConcreteSession pushChangesFromRecord:withIdentifier:]: you can't change the record's entity name from com.apple.calendars.MailAlarm to com.apple.calendars.DisplayAlarm in {
                description = "";
                owner =     (
                    "Event/p935"
            } withStack: (
                      0   iCalExternalSync                    0x0000000108341a60 iCalExternalSync + 125536
                      1   iCalExternalSync                    0x0000000108330ac9 iCalExternalSync + 56009
                      2   iCalExternalSync                    0x0000000108340694 iCalExternalSync + 120468
            12/18/12 8:32:45.935 PM iCalExternalSync[305]: [ICalExternalSync ]NSException name:ISyncInvalidArgumentsException reason:[ISyncConcreteSession pushChangesFromRecord:withIdentifier:]: you can't change the record's entity name from com.apple.calendars.MailAlarm to com.apple.calendars.DisplayAlarm in {
                description = "";
                owner =     (
                    "Event/p935"
            12/18/12 8:32:45.936 PM SyncServer[261]: [0x7fb200c0bd80] |Server|Warning| lost connection 0x7fb200c159e0 to com.apple.iCal
            12/18/12 8:32:48.950 PM Splashtop Streamer[194]: SRFEAT_NOTIFY_SERVER_CLOUD_NOTIFY_MSG
            12/18/12 8:32:48.951 PM Splashtop Streamer[194]: [ProcServerNotification] SRS_SERVER_RTN_INFO : [200][.srloginnotify.xml]
            12/18/12 8:32:48.952 PM Splashtop Streamer[194]:   receive backend string notify
            12/18/12 8:32:48.952 PM Splashtop Streamer[194]: -[CMXMLParser length]: unrecognized selector sent to instance 0x101508f60
            12/18/12 8:32:48.953 PM Splashtop Streamer[194]: -[CMXMLParser length]: unrecognized selector sent to instance 0x101508f60
            12/18/12 8:32:48.954 PM Splashtop Streamer[194]: (
            12/18/12 8:32:48.954 PM Splashtop Streamer[194]:   receive backend string notify
            12/18/12 8:32:48.954 PM Splashtop Streamer[194]: -[CMXMLParser length]: unrecognized selector sent to instance 0x101508f60
            12/18/12 8:32:48.955 PM Splashtop Streamer[194]: -[CMXMLParser length]: unrecognized selector sent to instance 0x101508f60
            12/18/12 8:32:48.956 PM Splashtop Streamer[194]: (
                      10  CoreFoundation                      0x00007fff90554db4 __CFRunLoopRun + 772
                      13  HIToolbox                           0x00007fff92487d84 ReceiveNextEventCommon + 166
            12/18/12 8:32:56.189 PM launchctl[316]: launchctl: Dubious permissions on file (skipping): /Library/LaunchAgents/com.adobe.AAM.Updater-1.0.plist
            12/18/12 8:32:56.433 PM com.apple.SecurityServer[15]: Session 100002 created
            12/18/12 8:33:26.592 PM Finder[158]: pearlBrowserSelectionChanged.
            12/18/12 8:33:47.296 PM Finder[158]: pearlBrowserSelectionChanged.
            12/18/12 8:35:34.896 PM Finder[158]: pearlBrowserSelectionChanged.
            12/18/12 8:35:35.135 PM login[339]: USER_PROCESS: 339 ttys000
            12/18/12 8:35:35.187 PM launchctl[346]: launchctl: Dubious permissions on file (skipping): /Library/LaunchAgents/com.adobe.AAM.Updater-1.0.plist
            12/18/12 8:35:35.222 PM login[347]: USER_PROCESS: 347 ttys001
            12/18/12 8:35:35.277 PM login[347]: DEAD_PROCESS: 347 ttys001
            12/18/12 8:36:28.367 PM Finder[158]: pearlBrowserSelectionChanged.
            12/18/12 8:36:38.870 PM Finder[158]: CFPropertyListCreateFromXMLData(): Old-style plist parser: missing semicolon in dictionary on line 1. Parsing will be abandoned. Break on _CFPropertyListMissingSemicolon to debug.
            12/18/12 8:36:38.871 PM Finder[158]: CFPropertyListCreateFromXMLData(): Old-style plist parser: missing semicolon in dictionary on line 1. Parsing will be abandoned. Break on _CFPropertyListMissingSemicolon to debug.
            12/18/12 8:36:38.872 PM Finder[158]: CFPropertyListCreateFromXMLData(): Old-style plist parser: missing semicolon in dictionary on line 1. Parsing will be abandoned. Break on _CFPropertyListMissingSemicolon to debug.
            12/18/12 8:36:38.873 PM Finder[158]: CFPropertyListCreateFromXMLData(): Old-style plist parser: missing semicolon in dictionary on line 1. Parsing will be abandoned. Break on _CFPropertyListMissingSemicolon to debug.
            12/18/12 8:37:09.000 PM kernel[0]: Adobe Photoshop  (map: 0xffffff803fcea220) triggered DYLD shared region unnest for map: 0xffffff803fcea220, region 0x7fff8e000000->0x7fff8e200000. While not abnormal for debuggers, this increases system memory footprint until the target exits.
            12/18/12 8:37:15.381 PM com.apple.kextd[12]: Warning: /Volumes/Macintosh HD/System/Library/Extensions: No such file or directory
            12/18/12 8:37:56.610 PM Adobe Photoshop CS6[362]: *** WARNING: -[NSObject(NSKeyValueCoding) takeValuesFromDictionary:] is deprecated. It will be removed in a future release and should no longer be used.
            12/18/12 8:41:00.389 PM WindowServer[120]: _CGXGetWindowOrderingGroup: Operation on a window 0x32 requiring rights 0x5 by caller Photoshop
            12/18/12 8:41:04.734 PM System Preferences[390]: Cannot setMachineString without first being authenticated
            12/18/12 8:41:04.790 PM System Preferences[390]: *** WARNING: -[NSImage compositeToPoint:operation:] is deprecated in MacOSX 10.8 and later. Please use -[NSImage drawAtPoint:fromRect:operation:fraction:] instead.
            12/18/12 8:41:04.792 PM System Preferences[390]: *** WARNING: -[NSImage compositeToPoint:fromRect:operation:] is deprecated in MacOSX 10.8 and later. Please use -[NSImage drawAtPoint:fromRect:operation:fraction:] instead.
            12/18/12 8:41:04.795 PM System Preferences[390]: *** WARNING: -[NSImage compositeToPoint:operation:fraction:] is deprecated in MacOSX 10.8 and later. Please use -[NSImage drawAtPoint:fromRect:operation:fraction:] instead.
            12/18/12 8:41:04.797 PM System Preferences[390]: *** WARNING: -[NSImage compositeToPoint:fromRect:operation:fraction:] is deprecated in MacOSX 10.8 and later. Please use -[NSImage drawAtPoint:fromRect:operation:fraction:] instead.
            12/18/12 8:41:15.257 PM WindowServer[120]: _CGXGetWindowOrderingGroup: Operation on a window 0x32 requiring rights 0x5 by caller Photoshop
            12/18/12 8:41:35.170 PM Finder[158]: pearlBrowserSelectionChanged.
            12/18/12 8:41:50.507 PM Finder[158]: pearlBrowserSelectionChanged.
            12/18/12 8:41:59.086 PM com.apple.launchd.peruser.501[143]: ([0x0-0x20020].com.getdropbox.dropbox[224]) Exited: Killed: 9
            12/18/12 8:43:24.872 PM com.apple.kextd[12]: Warning: /Volumes/Macintosh HD/System/Library/Extensions: No such file or directory
            12/18/12 8:47:48.287 PM login[339]: DEAD_PROCESS: 339 ttys000
            12/18/12 8:48:00.752 PM com.apple.launchd.peruser.501[143]: (com.apple.PackageKit.InstallStatus) Throttling respawn: Will start in 8 seconds
            12/18/12 8:48:00.776 PM WindowServer[120]: CGXGetConnectionProperty: Invalid connection 31863
            12/18/12 8:48:00.777 PM WindowServer[120]: CGXGetConnectionProperty: Invalid connection 31863
            12/18/12 8:48:00.781 PM WindowServer[120]: dict count after removing entry for window 0x30 is 0
            12/18/12 8:48:00.784 PM Splashtop Streamer[194]: going to close SRFeature.
            12/18/12 8:48:00.785 PM com.apple.launchd.peruser.501[143]: (com.prosofteng.DGMonitor[185]) Exited: Killed: 9
            12/18/12 8:48:00.791 PM coreservicesd[28]: SendFlattenedData, got error #268435459 (ipc/send) invalid destination port from ::mach_msg(), sending notification kLSNotifyApplicationDeath to notificationID=166
            12/18/12 8:48:00.791 PM coreservicesd[28]: SendFlattenedData, got error #268435459 (ipc/send) invalid destination port from ::mach_msg(), sending notification kLSNotifyApplicationDeath to notificationID=196
            12/18/12 8:48:00.792 PM coreservicesd[28]: SendFlattenedData, got error #268435459 (ipc/send) invalid destination port from ::mach_msg(), sending notification kLSNotifyApplicationDeath to notificationID=166
            12/18/12 8:48:00.801 PM coreservicesd[28]: SendFlattenedData, got error #268435460 (ipc/send) timed out from ::mach_msg(), sending notification kLSNotifyApplicationDeath to notificationID=266
            12/18/12 8:48:00.809 PM WindowServer[120]: CGXGetConnectionProperty: Invalid connection 31863
            12/18/12 8:48:00.810 PM WindowServer[120]: CGXGetConnectionProperty: Invalid connection 31863
            12/18/12 8:48:00.811 PM SRServiceAgent[179]: cannot find SRFeature
            12/18/12 8:48:01.050 PM coreservicesd[28]: SendFlattenedData, got error #268435459 (ipc/send) invalid destination port from ::mach_msg(), sending notification kLSNotifyApplicationDeath to notificationID=149
            12/18/12 8:48:01.050 PM WindowServer[120]: CGXGetConnectionProperty: Invalid connection 31863
            12/18/12 8:48:01.051 PM WindowServer[120]: CGXGetConnectionProperty: Invalid connection 31863
            12/18/12 8:48:01.303 PM loginwindow[91]: sendQuitEventToApp (FMCore): AESendMessage returned error -1712
            12/18/12 8:48:01.320 PM com.apple.launchd.peruser.501[143]: ([0x0-0x24024].com.apple.AppleSpell[257]) Exited: Terminated: 15
            12/18/12 8:48:01.321 PM com.apple.launchd.peruser.501[143]: (com.apple.mdworker.shared.04000000-0000-0000-0000-000000000000[456]) Exited: Killed: 9
            12/18/12 8:48:01.787 PM Splashtop Streamer[194]:    AC Power
            12/18/12 8:48:02.834 PM loginwindow[91]: DEAD_PROCESS: 91 console
            12/18/12 8:48:02.890 PM airportd[462]: _doAutoJoin: Already associated to “abrazite”. Bailing on auto-join.
            12/18/12 8:48:02.896 PM com.apple.kextd[12]: Warning: /Volumes/Macintosh HD/System/Library/Extensions: No such file or directory
            12/18/12 8:48:02.901 PM shutdown[463]: halt by Imacom:
            12/18/12 8:48:02.901 PM shutdown[463]: SHUTDOWN_TIME: 1355881682 900895
            12/18/12 8:48:02.905 PM ntpd[71]: ntpd exiting on signal 15
            12/18/12 8:50:00.000 PM bootlog[0]: BOOT_TIME 1355881800 0
            12/18/12 8:50:02.000 PM kernel[0]: PMAP: PCID enabled
            12/18/12 8:50:02.000 PM kernel[0]: Darwin Kernel Version 12.2.0: Sat Aug 25 00:48:52 PDT 2012; root:xnu-2050.18.24~1/RELEASE_X86_64
            12/18/12 8:50:02.000 PM kernel[0]: vm_page_bootstrap: 8129491 free pages and 226349 wired pages
            12/18/12 8:50:02.000 PM kernel[0]: kext submap [0xffffff7f80741000 - 0xffffff8000000000], kernel text [0xffffff8000200000 - 0xffffff8000741000]
            12/18/12 8:50:02.000 PM kernel[0]: zone leak detection enabled
            12/18/12 8:50:02.000 PM kernel[0]: standard timeslicing quantum is 10000 us
            12/18/12 8:50:02.000 PM kernel[0]: standard background quantum is 2500 us
            12/18/12 8:50:02.000 PM kernel[0]: mig_table_max_displ = 74
            12/18/12 8:50:02.000 PM kernel[0]: corecrypto kext started!
            12/18/12 8:50:02.000 PM kernel[0]: Running kernel space in FIPS MODE
            12/18/12 8:50:02.000 PM kernel[0]: Plist hmac value is    735d392b68241ef173d81097b1c8ce9ba283521626d1c973ac376838c466757d
            12/18/12 8:50:02.000 PM kernel[0]: Computed hmac value is 735d392b68241ef173d81097b1c8ce9ba283521626d1c973ac376838c466757d
            12/18/12 8:50:02.000 PM kernel[0]: corecrypto.kext FIPS integrity POST test passed!
            12/18/12 8:50:02.000 PM kernel[0]: corecrypto.kext FIPS AES CBC POST test passed!
            12/18/12 8:50:02.000 PM kernel[0]: corecrypto.kext FIPS TDES CBC POST test passed!
            12/18/12 8:50:02.000 PM kernel[0]: corecrypto.kext FIPS AES ECB AESNI POST test passed!
            12/18/12 8:50:02.000 PM kernel[0]: corecrypto.kext FIPS AES XTS AESNI POST test passed!
            12/18/12 8:50:02.000 PM kernel[0]: corecrypto.kext FIPS SHA POST test passed!
            12/18/12 8:50:02.000 PM kernel[0]: corecrypto.kext FIPS HMAC POST test passed!
            12/18/12 8:50:02.000 PM kernel[0]: corecrypto.kext FIPS ECDSA POST test passed!
            12/18/12 8:50:02.000 PM kernel[0]: corecrypto.kext FIPS DRBG POST test passed!
            12/18/12 8:50:02.000 PM kernel[0]: corecrypto.kext FIPS POST passed!
            12/18/12 8:50:02.000 PM kernel[0]: AppleACPICPU: ProcessorId=0 LocalApicId=0 Enabled
            12/18/12 8:50:02.000 PM kernel[0]: AppleACPICPU: ProcessorId=1 LocalApicId=32 Enabled
            12/18/12 8:50:02.000 PM kernel[0]: AppleACPICPU: ProcessorId=2 LocalApicId=2 Enabled
            12/18/12 8:50:02.000 PM kernel[0]: AppleACPICPU: ProcessorId=3 LocalApicId=34 Enabled
            12/18/12 8:50:02.000 PM kernel[0]: AppleACPICPU: ProcessorId=4 LocalApicId=4 Enabled
            12/18/12 8:50:02.000 PM kernel[0]: AppleACPICPU: ProcessorId=5 LocalApicId=36 Enabled
            12/18/12 8:50:02.000 PM kernel[0]: AppleACPICPU: ProcessorId=6 LocalApicId=16 Enabled
            12/18/12 8:50:02.000 PM kernel[0]: AppleACPICPU: ProcessorId=7 LocalApicId=48 Enabled
            12/18/12 8:50:02.000 PM kernel[0]: AppleACPICPU: ProcessorId=8 LocalApicId=18 Enabled
            12/18/12 8:50:02.000 PM kernel[0]: AppleACPICPU: ProcessorId=9 LocalApicId=50 Enabled
            12/18/12 8:50:02.000 PM kernel[0]: AppleACPICPU: ProcessorId=10 LocalApicId=20 Enabled
            12/18/12 8:50:02.000 PM kernel[0]: AppleACPICPU: ProcessorId=11 LocalApicId=52 Enabled
            12/18/12 8:50:02.000 PM kernel[0]: AppleACPICPU: ProcessorId=12 LocalApicId=1 Enabled
            12/18/12 8:50:02.000 PM kernel[0]: AppleACPICPU: ProcessorId=13 LocalApicId=33 Enabled
            12/18/12 8:50:02.000 PM kernel[0]: AppleACPICPU: ProcessorId=14 LocalApicId=3 Enabled
            12/18/12 8:50:02.000 PM kernel[0]: AppleACPICPU: ProcessorId=15 LocalApicId=35 Enabled
            12/18/12 8:50:02.000 PM kernel[0]: AppleACPICPU: ProcessorId=16 LocalApicId=5 Enabled
            12/18/12 8:50:02.000 PM kernel[0]: AppleACPICPU: ProcessorId=17 LocalApicId=37 Enabled
            12/18/12 8:50:02.000 PM kernel[0]: AppleACPICPU: ProcessorId=18 LocalApicId=17 Enabled
            12/18/12 8:50:02.000 PM kernel[0]: AppleACPICPU: ProcessorId=19 LocalApicId=49 Enabled
            12/18/12 8:50:02.000 PM kernel[0]: AppleACPICPU: ProcessorId=20 LocalApicId=19 Enabled
            12/18/12 8:50:02.000 PM kernel[0]: AppleACPICPU: ProcessorId=21 LocalApicId=51 Enabled
            12/18/12 8:50:02.000 PM kernel[0]: AppleACPICPU: ProcessorId=22 LocalApicId=21 Enabled
            12/18/12 8:50:02.000 PM kernel[0]: AppleACPICPU: ProcessorId=23 LocalApicId=53 Enabled
            12/18/12 8:50:02.000 PM kernel[0]: calling mpo_policy_init for TMSafetyNet
            12/18/12 8:50:02.000 PM kernel[0]: Security policy loaded: Safety net for Time Machine (TMSafetyNet)
            12/18/12 8:50:02.000 PM kernel[0]: calling mpo_policy_init for Sandbox
            12/18/12 8:50:02.000 PM kernel[0]: Security policy loaded: Seatbelt sandbox policy (Sandbox)
            12/18/12 8:50:02.000 PM kernel[0]: calling mpo_policy_init for Quarantine
            12/18/12 8:50:02.000 PM kernel[0]: Security policy loaded: Quarantine policy (Quarantine)
            12/18/12 8:50:02.000 PM kernel[0]: Copyright (c) 1982, 1986, 1989, 1991, 1993
            12/18/12 8:50:02.000 PM kernel[0]: The Regents of the University of California. All rights reserved.
            12/18/12 8:50:02.000 PM kernel[0]: MAC Framework successfully initialized
            12/18/12 8:50:02.000 PM kernel[0]: using 16384 buffer headers and 10240 cluster IO buffer headers
            12/18/12 8:50:02.000 PM kernel[0]: IOAPIC: Version 0x20 Vectors 64:87
            12/18/12 8:50:02.000 PM kernel[0]: ACPI: System State [S0 S3 S4 S5]
            12/18/12 8:50:02.000 PM kernel[0]: PFM64 (40 cpu) 0xff80000000, 0x80000000
            12/18/12 8:50:02.000 PM kernel[0]: [ PCI configuration begin ]
            12/18/12 8:50:02.000 PM kernel[0]: AppleIntelCPUPowerManagement: Turbo Ratios 222233
            12/18/12 8:50:02.000 PM kernel[0]: AppleIntelCPUPowerManagement: (built 23:03:24 Jun 24 2012) initialization complete
            12/18/12 8:50:02.000 PM kernel[0]: console relocated to 0xff80010000
            12/18/12 8:50:02.000 PM kernel[0]: PCI configuration changed (bridge=7 device=2 cardbus=0)
            12/18/12 8:50:02.000 PM kernel[0]: [ PCI configuration end, bridges 15 devices 51 ]
            12/18/12 8:50:02.000 PM kernel[0]: mbinit: done [128 MB total pool size, (85/42) split]
            12/18/12 8:50:02.000 PM kernel[0]: Pthread support ABORTS when sync kernel primitives misused
            12/18/12 8:50:02.000 PM kernel[0]: ETH0 cannot assert wake from D3cold
            12/18/12 8:50:02.000 PM kernel[0]: ETH1 cannot assert wake from D3cold
            12/18/12 8:50:02.000 PM kernel[0]: rooting via boot-uuid from /chosen: 725DCE99-0F42-35F8-83CF-232BE79F8C0F
            12/18/12 8:50:02.000 PM kernel[0]: Waiting on <dict ID="0"><key>IOProviderClass</key><string ID="1">IOResources</string><key>IOResourceMatch</key><string ID="2">boot-uuid-media</string></dict>
            12/18/12 8:50:02.000 PM kernel[0]: com.apple.AppleFSCompressionTypeZlib kmod start
            12/18/12 8:50:02.000 PM kernel[0]: com.apple.AppleFSCompressionTypeDataless kmod start
            12/18/12 8:50:02.000 PM kernel[0]: com.apple.AppleFSCompressionTypeZlib load succeeded
            12/18/12 8:50:02.000 PM kernel[0]: com.apple.AppleFSCompressionTypeDataless load succeeded
            12/18/12 8:50:00.738 PM com.apple.launchd[1]: *** launchd[1] has started up. ***
            12/18/12 8:50:02.000 PM kernel[0]: AppleIntelCPUPowerManagementClient: ready
            12/18/12 8:50:02.000 PM kernel[0]: Intel82574L::start - Built Jun 24 2012 23:07:38 -- running on device at b9 d0 f0
            12/18/12 8:50:02.000 PM kernel[0]: Intel82574L::start - Built Jun 24 2012 23:07:38 -- running on device at b10 d0 f0
            12/18/12 8:50:02.000 PM kernel[0]: BTCOEXIST off
            12/18/12 8:50:02.000 PM kernel[0]: BRCM tunables:
            12/18/12 8:50:02.000 PM kernel[0]: pullmode[1] txringsize[  256] reapmin[   32] reapcount[  128]
            12/18/12 8:50:02.000 PM kernel[0]: highWaterMark: VO[  192]  VI[  192]  BE[  192]  BK[  192]
            12/18/12 8:50:02.000 PM kernel[0]: FireWire (OHCI) TI ID 823f built-in now active, GUID 78ca39fffe123fc8; max speed s800.
            12/18/12 8:50:02.000 PM kernel[0]: Got boot device = IOService:/AppleACPIPlatformExpert/PCI0@0/AppleACPIPCI/SATA@1F,2/AppleAHCI/PRT2@2/IOAHCID evice@0/AppleAHCIDiskDriver/IOAHCIBlockStorageDevice/IOBlockStorageDriver/OCZ-VERTEX4 Media/IOGUIDPartitionScheme/Vertex SSD @2
            12/18/12 8:50:02.000 PM kernel[0]: BSD root: disk0s2, major 1, minor 1
            12/18/12 8:50:02.000 PM kernel[0]: Kernel is LP64
            12/18/12 8:50:02.000 PM kernel[0]: USBF:          1.493          [0xffffff804a2de000] The IOUSBFamily is having trouble enumerating a USB device that has been plugged in.  It will keep retrying.  (Port 3 of Hub at 0x1d100000)
            12/18/12 8:50:00.738 PM com.apple.launchd[1]: *** Shutdown logging is enabled. ***
            12/18/12 8:50:02.608 PM com.apple.launchd[1]: (com.apple.automountd) Unknown key for boolean: NSSupportsSuddenTermination
            12/18/12 8:50:03.000 PM kernel[0]: Intel82574L: Ethernet address e8:06:88:cc:10:44
            12/18/12 8:50:03.000 PM kernel[0]: Intel82574L: Ethernet address e8:06:88:cc:24:84
            12/18/12 8:50:03.000 PM kernel[0]: AirPort_Brcm4331: Ethernet address 00:26:08:fd:72:91
            12/18/12 8:50:03.000 PM kernel[0]: IO80211Controller::dataLinkLayerAttachComplete():  adding AppleEFINVRAM notification
            12/18/12 8:50:03.864 PM airportd[27]: _processDLILEvent: en2 attached (down)
            12/18/12 8:50:03.917 PM com.apple.SecurityServer[15]: Session 100000 created
            12/18/12 8:50:03.000 PM kernel[0]: createVirtIf(): ifRole = 1
            12/18/12 8:50:03.000 PM kernel[0]: in func createVirtualInterface ifRole = 1
            12/18/12 8:50:03.000 PM kernel[0]: AirPort_Brcm4331_P2PInterface::init name <p2p0> role 1 this 0xffffff804ad7a400
            12/18/12 8:50:03.000 PM kernel[0]: AirPort_Brcm4331_P2PInterface::init() <p2p> role 1
            12/18/12 8:50:03.000 PM kernel[0]: Created virtif 0xffffff804ad7a400 p2p0
            12/18/12 8:50:03.967 PM com.apple.SecurityServer[15]: Entering service
            12/18/12 8:50:04.000 PM kernel[0]: Intel82574L::setLinkStatus - not active  1face000, 0
            12/18/12 8:50:04.027 PM UserEventAgent[11]: Captive: [HandleNetworkInformationChanged:2435] nwi_state_copy returned NULL
            12/18/12 8:50:04.158 PM mDNSResponder[52]: mDNSResponder mDNSResponder-379.32.1 (Aug 31 2012 19:05:06) starting OSXVers 12
            12/18/12 8:50:04.246 PM systemkeychain[55]: done file: /var/run/systemkeychaincheck.done
            12/18/12 8:50:04.273 PM mDNSResponder[52]: D2D_IPC: Loaded
            12/18/12 8:50:04.273 PM mDNSResponder[52]: D2DInitialize succeeded
            12/18/12 8:50:04.000 PM kernel[0]: AirPort: Link Down on en2. Reason 8 (Disassociated because station leaving).
            12/18/12 8:50:04.000 PM kernel[0]: en2::IO80211Interface::postMessage bssid changed
            12/18/12 8:50:04.000 PM kernel[0]: Previous Shutdown Cause: 5
            12/18/12 8:50:04.000 PM kernel[0]: IOBluetoothUSBDFU::probe
            12/18/12 8:50:04.000 PM kernel[0]: IOBluetoothUSBDFU::probe ProductID - 0x8215 FirmwareVersion - 0x0201
            12/18/12 8:50:04.000 PM kernel[0]: [BroadcomBluetoothHCIControllerUSBTransport][start] -- completed
            12/18/12 8:50:04.000 PM kernel[0]: [IOBluetoothHCIController][staticBluetoothHCIControllerTransportShowsUp] -- Received Bluetooth Controller register service notification
            12/18/12 8:50:04.000 PM kernel[0]: [IOBluetoothHCIController][start] -- completed
            12/18/12 8:50:04.000 PM kernel[0]: [IOBluetoothHCIController::setConfigState] calling registerService
            12/18/12 8:50:04.000 PM kernel[0]: [AGPM Controller] unknownPlatform
            12/18/12 8:50:04.000 PM kernel[0]: AppleTyMCEDriver::start coreVIDPID = 0x2c708086 Number of packages = 1 Number of cpus = 24 memory monitor trough PCI
            12/18/12 8:50:04.000 PM kernel[0]: Intel82574L::setLinkStatus - not active  1face001, 0
            12/18/12 8:50:04.777 PM configd[17]: bootp_session_transmit: bpf_write(en2) failed: Network is down (50)
            12/18/12 8:50:04.777 PM configd[17]: DHCP en2: INIT-REBOOT transmit failed
            12/18/12 8:50:04.000 PM kernel[0]: USBF:          4.790          [0xffffff804a2de000] The IOUSBFamily was not able to enumerate a device.
            12/18/12 8:50:04.000 PM kernel[0]: DSMOS has arrived
            12/18/12 8:50:04.805 PM configd[17]: network changed: DNS*
            12/18/12 8:50:04.806 PM configd[17]: setting hostname to "Mac-Pro-Imacom-5.local"
            12/18/12 8:50:05.000 PM kernel[0]: Intel82574L::setLinkStatus - not active  1face000, 0
            12/18/12 8:50:05.000 PM kernel[0]: USBF:          5.817          [0xffffff804a2de000] The IOUSBFamily is having trouble enumerating a USB device that has been plugged in.  It will keep retrying.  (Port 3 of Hub at 0x1d100000)
            12/18/12 8:50:05.000 PM kernel[0]: MacAuthEvent en2   Auth result for: 00:0f:66:43:a4:fa  MAC AUTH succeeded
            12/18/12 8:50:05.000 PM kernel[0]: wlEvent: en2 en2 Link UP virtIf = 0
            12/18/12 8:50:05.000 PM kernel[0]: AirPort: Link Up on en2
            12/18/12 8:50:05.000 PM kernel[0]: en2: BSSID changed to 00:0f:66:43:a4:fa
            12/18/12 8:50:05.000 PM kernel[0]: en2::IO80211Interface::postMessage bssid changed
            12/18/12 8:50:06.000 PM kernel[0]: AirPort: RSN handshake complete on en2
            12/18/12 8:50:06.425 PM airportd[27]: _doAutoJoin: Already associated to “abrazite”. Bailing on auto-join.
            12/18/12 8:50:06.830 PM hidd[96]: Posting 'com.apple.iokit.hid.displayStatus' notifyState=1
            12/18/12 8:50:06.834 PM hidd[96]: void __IOHIDLoadBundles(): Loaded 0 HID plugins
            12/18/12 8:50:06.000 PM kernel[0]: macx_swapon SUCCESS
            12/18/12 8:50:06.862 PM com.apple.kextd[12]: Can't load /System/Library/Extensions/CiscoVPN.kext - no code for running kernel's architecture.
            12/18/12 8:50:06.863 PM kdc[94]: label: default
            12/18/12 8:50:06.863 PM kdc[94]:           dbname: od:/Local/Default
            12/18/12 8:50:06.863 PM kdc[94]:           mkey_file: /var/db/krb5kdc/m-key
            12/18/12 8:50:06.863 PM kdc[94]:           acl_file: /var/db/krb5kdc/kadmind.acl
            12/18/12 8:50:06.865 PM SystemStarter[77]: Cisco Systems VPN Client Kernel Extension (114) did not complete successfully
            12/18/12 8:50:06.866 PM SystemStarter[77]: The following StartupItems failed to start properly:
            12/18/12 8:50:06.866 PM SystemStarter[77]: /System/Library/StartupItems/CiscoVPN
            12/18/12 8:50:06.866 PM SystemStarter[77]:  - execution of Startup script failed
            12/18/12 8:50:06.867 PM appleeventsd[101]: main: Starting up
            12/18/12 8:50:06.880 PM kdc[94]: WARNING Found KDC certificate (O=System Identity,CN=com.apple.kerberos.kdc)is missing the PK-INIT KDC EKU, this is bad for interoperability.
            12/18/12 8:50:06.891 PM com.apple.usbmuxd[75]: usbmuxd-296.3 on Jul 25 2012 at 00:28:37, running 64 bit
            12/18/12 8:50:06.902 PM loginwindow[91]: Login Window Application Started
            12/18/12 8:50:06.915 PM apsd[107]: CGSLookupServerRootPort: Failed to look up the port for "com.apple.windowserver.active" (1102)
            12/18/12 8:50:06.916 PM apsd[107]: CGSLookupServerRootPort: Failed to look up the port for "com.apple.windowserver.active" (1102)
            12/18/12 8:50:06.922 PM netbiosd[87]: Unable to start NetBIOS name service:
            12/18/12 8:50:06.923 PM awacsd[105]: Starting awacsd connectivity-78 (Jul 26 2012 14:37:46)
            12/18/12 8:50:06.925 PM awacsd[105]: InnerStore CopyAllZones: no info in Dynamic Store
            12/18/12 8:50:06.930 PM mds[88]: (Normal) FMW: FMW 0 0
            12/18/12 8:50:06.936 PM kdc[94]: KDC started
            12/18/12 8:50:06.965 PM coreservicesd[28]: FindBestLSSession(), no match for inSessionID 0xfffffffffffffffc auditTokenInfo( uid=0 euid=0 auSessionID=100000 create=false
            12/18/12 8:50:06.969 PM WindowServer[119]: Server is starting up
            12/18/12 8:50:06.973 PM WindowServer[119]: Session 256 retained (2 references)
            12/18/12 8:50:06.973 PM WindowServer[119]: Session 256 released (1 references)
            12/18/12 8:50:06.973 PM locationd[92]: NOTICE,Location icon should now be in state 0
            12/18/12 8:50:06.983 PM WindowServer[119]: Session 256 retained (2 references)
            12/18/12 8:50:06.983 PM WindowServer[119]: init_page_flip: page flip mode is on
            12/18/12 8:50:07.300 PM BBDaemon[109]: IOBSDNameMatching returned a NULL dictionary.
            12/18/12 8:50:07.000 PM kernel[0]: Ethernet [Intel82574L]: Link up on en0, 1-Gigabit, Full-duplex, Symmetric flow-control, Debug [796d,af08,0de1,0200,c5e1,2800]
            12/18/12 8:50:07.000 PM kernel[0]: Intel82574L::setLinkStatus - active  1face000, b
            12/18/12 8:50:08.477 PM WindowServer[119]: mux_initialize: Couldn't find any matches
            12/18/12 8:50:08.491 PM WindowServer[119]: GLCompositor enabled for tile size [256 x 256]
            12/18/12 8:50:08.492 PM WindowServer[119]: CGXGLInitMipMap: mip map mode is on
            12/18/12 8:50:08.516 PM WindowServer[119]: WSMachineUsesNewStyleMirroring: false
            12/18/12 8:50:08.517 PM WindowServer[119]: Display 0x04241064: GL mask 0x1; bounds (0, 0)[2560 x 1600], 57 modes available
            12/18/12 8:50:08.517 PM WindowServer[119]: Display 0x003f003e: GL mask 0x4; bounds (0, 0)[0 x 0], 1 modes available
            12/18/12 8:50:08.517 PM WindowServer[119]: Display 0x003f003d: GL mask 0x2; bounds (0, 0)[0 x 0], 1 modes available
            12/18/12 8:50:08.526 PM WindowServer[119]: Created shield window 0x5 for display 0x04241064
            12/18/12 8:50:08.526 PM WindowServer[119]: Created shield window 0x6 for display 0x003f003e
            12/18/12 8:50:08.526 PM WindowServer[119]: Created shield window 0x7 for display 0x003f003d
            12/18/12 8:50:08.527 PM WindowServer[119]: Display 0x04241064: GL mask 0x1; bounds (0, 0)[2560 x 1600], 57 modes available
            12/18/12 8:50:08.527 PM WindowServer[119]: Display 0x003f003e: GL mask 0x4; bounds (3584, 0)[1 x 1], 1 modes available
            12/18/12 8:50:08.527 PM WindowServer[119]: Display 0x003f003d: GL mask 0x2; bounds (3585, 0)[1 x 1], 1 modes available
            12/18/12 8:50:08.527 PM WindowServer[119]: CGXPerformInitialDisplayConfiguration
            12/18/12 8:50:08.527 PM WindowServer[119]:   Display 0x04241064: MappedDisplay Unit 0; Vendor 0x610 Model 0x9232 S/N 33594596 Dimensions 25.24 x 15.79; online enabled, Bounds (0,0)[2560 x 1600], Rotation 0, Resolution 1
            12/18/12 8:50:08.527 PM WindowServer[119]:   Display 0x003f003e: MappedDisplay Unit 2; Vendor 0xffffffff Model 0xffffffff S/N -1 Dimensions 0.00 x 0.00; offline enabled, Bounds (3584,0)[1 x 1], Rotation 0, Resolution 1
            12/18/12 8:50:08.527 PM WindowServer[119]:   Display 0x003f003d: MappedDisplay Unit 1; Vendor 0xffffffff Model 0xffffffff S/N -1 Dimensions 0.00 x 0.00; offline enabled, Bounds (3585,0)[1 x 1], Rotation 0, Resolution 1
            12/18/12 8:50:08.552 PM WindowServer[119]: GLCompositor: GL renderer id 0x01021b01, GL mask 0x00000007, accelerator 0x00003f37, unit 0, caps QEX|QGL|MIPMAP, vram 1024 MB
            12/18/12 8:50:08.552 PM WindowServer[119]: GLCompositor: GL renderer id 0x01021b01, GL mask 0x00000007, texture units 8, texture max 16384, viewport max {16384, 16384}, extensions FPRG|NPOT|GLSL|FLOAT
            12/18/12 8:50:08.555 PM loginwindow[91]: **DMPROXY** Found `/System/Library/CoreServices/DMProxy'.
            12/18/12 8:50:08.557 PM launchctl[126]: launchctl: Dubious permissions on file (skipping): /Library/LaunchAgents/com.adobe.AAM.Updater-1.0.plist
            12/18/12 8:50:08.592 PM WindowServer[119]: Created shield window 0x8 for display 0x04241064
            12/18/12 8:50:08.592 PM WindowServer[119]: Display 0x04241064: MappedDisplay Unit 0; ColorProfile { 2, "Cinema HD"}; TransferFormula (1.000000, 1.000000, 1.000000)
            12/18/12 8:50:08.597 PM launchctl[128]: launchctl: Dubious permissions on file (skipping): /Library/LaunchAgents/com.adobe.AAM.Updater-1.0.plist
            12/18/12 8:50:08.611 PM launchctl[128]: com.apple.findmymacmessenger: Already loaded
            12/18/12 8:50:08.625 PM com.apple.SecurityServer[15]: Session 100005 created
            12/18/12 8:50:08.640 PM airportd[27]: _doAutoJoin: Already associated to “abrazite”. Bailing on auto-join.
            12/18/12 8:50:08.668 PM loginwindow[91]: Login Window Started Security Agent
            12/18/12 8:50:08.730 PM SecurityAgent[139]: This is the first run
            12/18/12 8:50:08.731 PM SecurityAgent[139]: MacBuddy was run = 0
            12/18/12 8:50:08.741 PM WindowServer[119]: MPAccessSurfaceForDisplayDevice: Set up page flip mode on display 0x04241064 device: 0x108547320  isBackBuffered: 1 numComp: 3 numDisp: 3
            12/18/12 8:50:08.779 PM SecurityAgent[139]: User info context values set for Imacom
            12/18/12 8:50:08.827 PM coreaudiod[137]: 2012-12-18 08:50:08.827174 PM [AirPlay] Started browsing for _airplay._tcp.
            12/18/12 8:50:08.828 PM coreaudiod[137]: 2012-12-18 08:50:08.827589 PM [AirPlay] Started browsing for _raop._tcp.
            12/18/12 8:50:08.000 PM kernel[0]: USBF:          9.314          [0xffffff804a2de000] The IOUSBFamily was not able to enumerate a device.
            12/18/12 8:50:09.064 PM loginwindow[91]: Login Window - Returned from Security Agent
            12/18/12 8:50:09.067 PM loginwindow[91]: ERROR | ScreensharingLoginNotification | Failed sending message to screen sharing GetScreensharingPort, err: 1102
            12/18/12 8:50:09.090 PM loginwindow[91]: USER_PROCESS: 91 console
            12/18/12 8:50:09.110 PM airportd[27]: _doAutoJoin: Already associated to “abrazite”. Bailing on auto-join.
            12/18/12 8:50:09.114 PM launchctl[144]: launchctl: Dubious permissions on file (skipping): /Library/LaunchAgents/com.adobe.AAM.Updater-1.0.plist
            12/18/12 8:50:09.133 PM launchctl[145]: launchctl: Dubious permissions on file (skipping): /Library/LaunchAgents/com.adobe.AAM.Updater-1.0.plist
            12/18/12 8:50:09.139 PM com.apple.launchd[1]: (com.wacom.wacomtablet[135]) Exited with code: 255
            12/18/12 8:50:09.146 PM com.apple.launchd.peruser.501[143]: (com.apple.gamed) Ignored this key: UserName
            12/18/12 8:50:09.146 PM com.apple.launchd.peruser.501[143]: (com.apple.gamed) Ignored this key: GroupName
            12/18/12 8:50:09.147 PM com.apple.launchd.peruser.501[143]: (com.apple.ReportCrash) Falling back to default Mach exception handler. Could not find: com.apple.ReportCrash.Self
            12/18/12 8:50:09.151 PM loginwindow[91]: Connection with distnoted server was invalidated
            12/18/12 8:50:09.156 PM distnoted[147]: # distnote server agent  absolute time: 9.517980521   civil time: Tue Dec 18 20:50:09 2012   pid: 147 uid: 501  root: no
            12/18/12 8:50:09.196 PM WindowServer[119]: **DMPROXY** (2) Found `/System/Library/CoreServices/DMProxy'.
            12/18/12 8:50:09.221 PM WindowServer[119]: Display 0x04241064: MappedDisplay Unit 0; ColorProfile { 2, "Cinema HD"}; TransferFormula (1.000000, 1.000000, 1.000000)
            12/18/12 8:50:09.230 PM com.apple.SecurityServer[15]: Session 100003 created
            12/18/12 8:50:09.298 PM com.apple.launchd.peruser.501[143]: (com.akamai.single-user-client[187]) Bug: 12C60: launchd + 95444 [7DCC9489-2DF5-3807-83FA-EF5666EE8078]: 0xd
            12/18/12 8:50:09.298 PM com.apple.launchd.peruser.501[143]: (com.akamai.client.plist[188]) Bug: 12C60: launchd + 95444 [7DCC9489-2DF5-3807-83FA-EF5666EE8078]: 0xd
            12/18/12 8:50:09.300 PM talagent[155]: _LSSetApplicationInformationItem(kLSDefaultSessionID, asn, _kLSApplicationIsHiddenKey, hidden ? kCFBooleanTrue : kCFBooleanFalse, NULL) produced OSStatus -50 on line 623 in TCApplication.m
            12/18/12 8:50:09.301 PM talagent[155]: _LSSetApplicationInformationItem(kLSDefaultSessionID, asn, TAL_kLSIsProxiedForTALKey, kCFBooleanTrue, NULL) produced OSStatus -50 on line 626 in TCApplication.m
            12/18/12 8:50:09.302 PM com.apple.launchd.peruser.501[143]: (com.apple.afpstat-qfa[177]) Exited with code: 2
            12/18/12 8:50:09.305 PM com.apple.launchd.peruser.501[143]: (com.adobe.ARM.0d92f8f114b2d0af95462120762f939f6c66651ac8ac214cb7bdbd84[191]) Exited with code: 2
            12/18/12 8:50:09.341 PM SRServiceAgent[179]: service agent got ipc message: 1094931542
            12/18/12 8:50:09.342 PM SRServiceAgent[179]: try start streamer
            12/18/12 8:50:09.346 PM SRServiceAgent[179]: start check timer
            12/18/12 8:50:09.349 PM SRServiceAgent[179]: create new task
            12/18/12 8:50:09.350 PM SRServiceAgent[179]: task is not running, launch task
            12/18/12 8:50:09.360 PM launchctl[198]: launchctl: Dubious permissions on file (skipping): /Library/LaunchAgents/com.adobe.AAM.Updater-1.0.plist
            12/18/12 8:50:09.424 PM NetworkBrowserAgent[196]: Starting NetworkBrowserAgent
            12/18/12 8:50:09.000 PM kernel[0]: CODE SIGNING: cs_invalid_page(0x1000): p=181[GoogleSoftwareUp] clearing CS_VALID
            12/18/12 8:50:09.615 PM Splashtop Streamer[197]: NSWindow does not support utility styleMask 0x10
            12/18/12 8:50:09.619 PM Splashtop Streamer[197]: NSWindow does not support utility styleMask 0x10
            12/18/12 8:50:09.623 PM Splashtop Streamer[197]: NSWindow does not support utility styleMask 0x10
            12/18/12 8:50:09.625 PM Splashtop Streamer[197]: NSWindow does not support utility styleMask 0x10
            12/18/12 8:50:09.629 PM Splashtop Streamer[197]: NSWindow does not support utility styleMask 0x10
            12/18/12 8:50:09.640 PM Splashtop Streamer[197]: Could not connect the action toggleServer: to target of class SplashtopRemoteAppDelegate
            12/18/12 8:50:09.680 PM Splashtop Streamer[197]: going to close SRFeature.
            12/18/12 8:50:09.000 PM kernel[0]: USBF:          10.203          [0xffffff804a2de000] The IOUSBFamily is having trouble enumerating a USB device that has been plugged in.  It will keep retrying.  (Port 3 of Hub at 0x1d100000)
            12/18/12 8:50:10.078 PM YouSendIt Desktop App[223]: Set Version number 2.0.0.204
            12/18/12 8:50:10.085 PM Trim Enabler[220]: ON
            12/18/12 8:50:10.241 PM YouSendIt Desktop App[223]: finderPearlServerConnection = (** NSConnection 0x1073085e0 receivePort <NSMachPort: 0x10730dc90> sendPort <NSMachPort: 0x10730dc90> refCount 1 remoteUsesKeyedDO: 0 **), pearlServices = <YSIPearlServices: 0x1073007d0>
            12/18/12 8:50:10.269 PM YouSendIt Desktop App[223]: Need to check OSAX bundle
            12/18/12 8:50:10.271 PM YouSendIt Desktop App[223]: internal version=2.0.0.204, installed version=2.0.0.204
            12/18/12 8:50:10.272 PM YouSendIt Desktop App[223]: No valid connection
            12/18/12 8:50:10.447 PM DGAgent[185]: Resolved DG link from bookmark. /Applications/Drive Genius 3.app
            12/18/12 8:50:10.527 PM WindowServer[119]: **DMPROXY** (2) Found `/System/Library/CoreServices/DMProxy'.
            12/18/12 8:50:10.581 PM WindowServer[119]: Display 0x04241064: MappedDisplay Unit 0; ColorProfile { 2, "Cinema HD"}; TransferFormula (1.000000, 1.000000, 1.000000)
            12/18/12 8:50:10.609 PM WindowServer[119]: Display 0x04241064: MappedDisplay Unit 0; ColorProfile { 2, "Cinema HD"}; TransferFormula (1.000000, 1.000000, 1.000000)
            12/18/12 8:50:10.625 PM coreservicesd[28]: SendFlattenedData, got error #268435460 (ipc/send) timed out from ::mach_msg(), sending notification kLSNotifyApplicationReady to notificationID=166
            12/18/12 8:50:10.651 PM coreservicesd[28]: Can't change an application into stopped state for app App:"Finder" [ 0x0/0xe00e]  @ 0x0x7fdd12b04d30 because it's already been started.
            12/18/12 8:50:10.702 PM WindowServer[119]: CGXSetWindowShadowParameters: Operation on a window 0x1c requiring rights kCGSWindowRightOwner by caller talagent
            12/18/12 8:50:10.742 PM appleprofilepolicyd[234]: appleprofilepolicyd: profiling drivers not loaded, loading
            12/18/12 8:50:10.797 PM Finder[158]: SDL checking if Pearl was loaded. hasLoaded=NO, addr=1126322f4
            12/18/12 8:50:10.797 PM Finder[158]: not loaded, returning 1
            12/18/12 8:50:10.000 PM kernel[0]: USBF:          11. 67          [0xffffff804a2de000] The IOUSBFamily gave up enumerating a USB device after 10 retries.  (Port 3 of Hub at 0x1d100000)
            12/18/12 8:50:10.000 PM kernel[0]: USBF:          11. 67          [0xffffff804a2de000] The IOUSBFamily was not able to enumerate a device.
            12/18/12 8:50:10.827 PM configd[17]: network changed: v4(en0+:10.10.1.104) DNS+ Proxy+ SMB
            12/18/12 8:50:10.921 PM SRFeature[238]: Display server path : /Applications/Splashtop Streamer.app/Contents/MacOS/SRFeature.app/Contents/MacOS/SRXDisplayServer.app/Contents/Ma cOS/SRXDisplayServer
            12/18/12 8:50:10.942 PM SRXDisplayServer[240]: No SRX Display Card
            12/18/12 8:50:10.792 PM ntpd[71]: proto: precision = 1.000 usec
            12/18/12 8:50:11.002 PM Finder[158]: handleYSILoad
            12/18/12 8:50:11.004 PM Finder[158]: YSI pearl loaded
            12/18/12 8:50:11.023 PM SRFeature[238]: pInfo data: [2][b000000][b][0]
            12/18/12 8:50:11.024 PM SRFeature[238]: FH: GetInfo
            12/18/12 8:50:11.000 PM kernel[0]: Finder (map: 0xffffff804a43d658) triggered DYLD shared region unnest for map: 0xffffff804a43d658, region 0x7fff89800000->0x7fff89a00000. While not abnormal for debuggers, this increases system memory footprint until the target exits.
            12/18/12 8:50:11.068 PM Finder[158]: pearl listener registered
            12/18/12 8:50:11.484 PM coreservicesd[28]: SendFlattenedData, got error #268435460 (ipc/send) timed out from ::mach_msg(), sending notification kLSNotifyChildApplicationLaunch to notificationID=131
            12/18/12 8:50:11.727 PM Splashtop Streamer[197]: ---- http://www.splashtop.com/splashtop2#otherproducts-tab
            12/18/12 8:50:11.728 PM Splashtop Streamer[197]: -[DisplayView initWithFrame:] [{{0, 0}, {380, 70}}][{{0, 0}, {380, 70}}]
            12/18/12 8:50:11.730 PM Splashtop Streamer[197]: -[DisplayView(Private) setTextField:string:] 1 [{{20, 0}, {380, 70}}]
            12/18/12 8:50:11.730 PM Splashtop Streamer[197]: -[DisplayView(Private) setTextField:string:] 2 [{{20, 0}, {85, 14}}]
            12/18/12 8:50:12.073 PM com.apple.launchd[1]: (com.apple.xprotectupdater[73]) Exited with code: 252
            12/18/12 8:50:12.533 PM blued[68]: kBTXPCUpdateUserPreferences gConsoleUserUID = 501
            12/18/12 8:50:12.739 PM Trim Enabler[220]: ON
            12/18/12 8:50:13.000 PM kernel[0]: Intel82574L::timeoutHandler - no link - reset the chipset once  1face001, 0
            12/18/12 8:50:13.000 PM kernel[0]: Intel82574L::setLinkStatus - not active  1face001, 0
            12/18/12 8:50:14.178 PM locationd[283]: NOTICE,Location icon should now be in state 0
            12/18/12 8:50:14.000 PM kernel[0]: Intel82574L::setLinkStatus - not active  1face001, 0
            12/18/12 8:50:14.240 PM UserEventAgent[146]: cannot find fw daemon port 1102
            12/18/12 8:50:14.683 PM CalendarAgent[174]: *** -[IADomainCache init]: IA domains cache is out of date.
            12/18/12 8:50:15.273 PM launchctl[294]: launchctl: Dubious permissions on file (skipping): /Library/LaunchAgents/com.adobe.AAM.Updater-1.0.plist
            12/18/12 8:50:15.395 PM Trim Enabler[220]: /Applications/Trim En
            12/18/12 8:50:15.990 PM Splashtop Streamer[197]: SRFEAT_NOTIFY_SERVER_CLOUD_NOTIFY_MSG
            12/18/12 8:50:15.990 PM Splashtop Streamer[197]: [ProcServerNotification] SRS_SERVER_RTN_INFO : [200][.srloginnotify.xml]
            12/18/12 8:50:16.017 PM Splashtop Streamer[197]:   receive backend string notify
            12/18/12 8:50:16.017 PM Splashtop Streamer[197]: -[CMXMLParser length]: unrecognized selector sent to instance 0x1004134a0
            12/18/12 8:50:16.020 PM Splashtop Streamer[197]: (
                      0   CoreFoundation                      0x00007fff870ec0a6 __exceptionPreprocess + 198
                      1   libobjc.A.dylib                     0x00007fff883af3f0 objc_exception_throw + 43
                      2   CoreFoundation                      0x00007fff871826ea -[NSObject(NSObject) doesNotRecognizeSelector:] + 186
                      3   CoreFoundation                      0x00007fff870da5ce ___forwarding___ + 414
                      4   CoreFoundation                      0x00007fff870da3b8 _CF_forwarding_prep_0 + 232
                      5   Foundation                          0x00007fff86ca4ea8 -[NSPlaceholderString initWithString:] + 169
                      6   Splashtop Streamer                  0x000000010000be8f -[SplashtopRemoteAppDelegate getXMLContent:] + 199
                      7   CoreFoundation                      0x00007fff871485cc ____CFXNotificationPostToken_block_invoke_0 + 284
                      8   CoreFoundation                      0x00007fff870a9272 __CFRUNLOOP_IS_CALLING_OUT_TO_A_BLOCK__ + 18
                      9   CoreFoundation                      0x00007fff87069a4f __CFRunLoopDoBlocks + 255
                      10  CoreFoundation                      0x00007fff8708e220 __CFRunLoopRun + 1904
                      11  CoreFoundation                      0x00007fff8708d6b2 CFRunLoopRunSpecific + 290
                      12  HIToolbox                           0x00007fff88fc10a4 RunCurrentEventLoopInMode + 209
                      13  HIToolbox                           0x00007fff88fc0e42 ReceiveNextEventCommon + 356
                      14  HIToolbox                           0x00007fff88fc0cd3 BlockUntilNextEventMatchingListInMode + 62
                      15  AppKit                              0x00007fff8bf8c613 _DPSNextEvent + 685
                      16  AppKit                              0x00007fff8bf8bed2 -[NSApplication nextEventMatchingMask:untilDate:inMode:dequeue:] + 128
                      17  AppKit                              0x00007fff8bf83283 -[NSApplication run] + 517
                      18  AppKit                              0x00007fff8bf27cb6 NSApplicationMain + 869
                      19  Splashtop Streamer                  0x00000001000018b4 start + 52
            12/18/12 8:50:21.751 PM awacsd[105]: Exiting
            12/18/12 8:50:28.952 PM com.apple.launchd[1]: (com.apple.coreservices.appleid.authentication[134]) Exit timeout elapsed (20 seconds). Killing
            12/18/12 8:50:32.573 PM Splashtop Streamer[197]: going to close SRFeature.
            12/18/12 8:50:32.574 PM configd[17]: network changed: v4(en0:10.10.1.104, en2+:169.254.92.28) DNS Proxy SMB
            12/18/12 8:50:32.589 PM UserEventAgent[11]: Captive: en2: Not probing 'abrazite' (protected network)
            12/18/12 8:50:32.592 PM configd[17]: network changed: v4(en0:10.10.1.104, en2) DNS Proxy SMB
            12/18/12 8:50:36.716 PM Splashtop Streamer[197]: cannot create remote port
            12/18/12 8:50:36.716 PM Splashtop Streamer[197]: Error -50 sending  ping to SRFeature.
            12/18/12 8:50:36.716 PM Splashtop Streamer[197]: Can not find SRFeature alive
            12/18/12 8:50:36.717 PM Splashtop Streamer[197]: going to close SRFeature.
            12/18/12 8:50:37.756 PM SRFeature[304]: Display server path : /Applications/Splashtop Streamer.app/Contents/MacOS/SRFeature.app/Contents/MacOS/SRXDisplayServer.app/Contents/Ma cOS/SRXDisplayServer
            12/18/12 8:50:37.774 PM SRXDisplayServer[306]: No SRX Display Card
            12/18/12 8:50:38.000 PM SRFeature[304]: pInfo data: [2][b000000][b][0]
            12/18/12 8:50:38.001 PM SRFeature[304]: FH: GetInfo
            12/18/12 8:50:42.556 PM Splashtop Streamer[197]: SRFEAT_NOTIFY_SERVER_CLOUD_NOTIFY_MSG
            12/18/12 8:50:42.557 PM Splashtop Streamer[197]: [ProcServerNotification] SRS_SERVER_RTN_INFO : [200][.srloginnotify.xml]
            12/18/12 8:50:42.558 PM Splashtop Streamer[197]:   receive backend string notify
            12/18/12 8:50:42.558 PM Splashtop Streamer[197]: -[CMXMLParser length]: unrecognized selector sent to instance 0x104912e00
            12/18/12 8:50:42.559 PM Splashtop Streamer[197]: (
            12/18/12 8:50:42.560 PM Splashtop Streamer[197]:   receive backend string notify
            12/18/12 8:50:42.560 PM Splashtop Streamer[197]: -[CMXMLParser length]: unrecognized selector sent to instance 0x104912e00
            12/18/12 8:50:42.561 PM Splashtop Streamer[197]: -[CMXMLParser length]: unrecognized selector sent to instance 0x104912e00
            12/18/12 8:50:42.561 PM Splashtop Streamer[197]: (
                      10  CoreFoundation                      0x00007fff8708ddb4 __CFRunLoopRun + 772
                      13  HIToolbox                           0x00007fff88fc0d84 ReceiveNextEventCommon + 166
            12/18/12 8:50:44.566 PM launchctl[312]: launchctl: Dubious permissions on file (skipping): /Library/LaunchAgents/com.adobe.AAM.Updater-1.0.plist
            12/18/12 8:50:44.749 PM Splashtop Streamer[197]: going to close SRFeature.
            12/18/12 8:50:44.751 PM configd[17]: network changed: v4(en0:10.10.1.104, en2!:10.10.1.105) DNS* Proxy SMB
            12/18/12 8:50:44.770 PM UserEventAgent[11]: Captive: en2: Not probing 'abrazite' (protected network)
            12/18/12 8:50:44.808 PM com.apple.SecurityServer[15]: Session 100002 created
            12/18/12 8:50:48.969 PM Splashtop Streamer[197]: cannot create remote port
            12/18/12 8:50:48.969 PM Splashtop Streamer[197]: Error -50 sending  ping to SRFeature.
            12/18/12 8:50:48.970 PM Splashtop Streamer[197]: Can not find SRFeature alive
            12/18/12 8:50:48.970 PM Splashtop Streamer[197]: going to close SRFeature.
            12/18/12 8:50:50.009 PM SRFeature[318]: Display server path : /Applications/Splashtop Streamer.app/Contents/MacOS/SRFeature.app/Contents/MacOS/SRXDisplayServer.app/Contents/Ma cOS/SRXDisplayServer
            12/18/12 8:50:50.028 PM SRXDisplayServer[320]: No SRX Display Card
            12/18/12 8:50:50.257 PM SRFeature[318]: pInfo data: [2][b000000][b][0]
            12/18/12 8:50:50.258 PM SRFeature[318]: FH: GetInfo
            12/18/12 8:50:54.822 PM Splashtop Streamer[197]: SRFEAT_NOTIFY_SERVER_CLOUD_NOTIFY_MSG
            12/18/12 8:50:54.822 PM Splashtop Streamer[197]: [ProcServerNotification] SRS_SERVER_RTN_INFO : [200][.srloginnotify.xml]
            12/18/12 8:50:54.823 PM Splashtop Streamer[197]:   receive backend string notify
            12/18/12 8:50:54.824 PM Splashtop Streamer[197]: -[CMXMLParser length]: unrecognized selector sent to instance 0x10491cd60
            12/18/12 8:50:54.825 PM Splashtop Streamer[197]: (
            12/18/12 8:50:54.826 PM Splashtop Streamer[197]:   receive backend string notify
            12/18/12 8:50:54.826 PM Splashtop Streamer[197]: -[CMXMLParser length]: unrecognized selector sent to instance 0x105babc00
            12/18/12 8:50:54.827 PM Splashtop Streamer[197]: (
            12/18/12 8:50:55.179 PM Finder[158]: pearlBrowserSelectionChanged.
            12/18/12 8:50:58.482 PM Finder[158]: CFPropertyListCreateFromXMLData(): Old-style plist parser: missing semicolon in dictionary on line 1. Parsing will be abandoned. Break on _CFPropertyListMissingSemicolon to debug.
            12/18/12 8:50:58.484 PM Finder[158]: CFPropertyListCreateFromXMLData(): Old-style plist parser: missing semicolon in dictionary on line 1. Parsing will be abandoned. Break on _CFPropertyListMissingSemicolon to debug.
            12/18/12 8:50:58.485 PM Finder[158]: CFPropertyListCreateFromXMLData(): Old-style plist parser: missing semicolon in dictionary on line 1. Parsing will be abandoned. Break on _CFPropertyListMissingSemicolon to debug.
            12/18/12 8:51:55.000 PM kernel[0]: Adobe Photoshop  (map: 0xffffff804a43d2b8) triggered DYLD shared region unnest for map: 0xffffff804a43d2b8, region 0x7fff84c00000->0x7fff84e00000. While not abnormal for debuggers, this increases system memory footprint until the target exits.
            12/18/12 8:52:33.819 PM Adobe Photoshop CS6[338]: *** WARNING: -[NSObject(NSKeyValueCoding) takeValuesFromDictionary:] is deprecated. It will be removed in a future release and should no longer be used.
            12/18/12 8:55:03.680 PM com.apple.kextd[12]: Warning: /Volumes/Macintosh HD/System/Library/Extensions: No such file or directory
            12/18/12 9:03:36.310 PM WindowServer[119]: Created shield window 0x68 for display 0x04241064
            12/18/12 9:03:36.310 PM WindowServer[119]: device_generate_desktop_screenshot: authw 0x0(0), shield 0x0(0)
            12/18/12 9:03:36.327 PM WindowServer[119]: device_generate_lock_screen_screenshot: authw 0x0(0), shield 0x0(0)
            12/18/12 9:04:27.636 PM WindowServer[119]: handle_will_sleep_auth_and_shield_windows: no lock state data
            12/18/12 9:04:37.000 PM kernel[0]: Adobe Photoshop  (map: 0xffffff804d6b63f0) triggered DYLD shared region unnest for map: 0xffffff804d6b63f0, region 0x7fff84c00000->0x7fff84e00000. While not abnormal for debuggers, this increases system memory footprint until the target exits.
            12/18/12 9:05:11.664 PM Adobe Photoshop CS6[389]: *** WARNING: -[NSObject(NSKeyValueCoding) takeValuesFromDictionary:] is deprecated. It will be removed in a future release and should no longer be used.
            12/18/12 9:05:51.950 PM Finder[158]: please update <rdar://problem/6955835> with the following: invalid vRefNum 0
            12/18/12 9:06:37.827 PM Finder[158]: pearlBrowserSelectionChanged.
            12/18/12 9:06:39.004 PM Locum[409]: Connection with distnoted server was invalidated
            12/18/12 9:06:47.984 PM ReclaimSpaceAgent[411]: Received request for 488.98 GB of free space on volume /Users/Imacom/Documents, operation UUID: (null)
            12/18/12 9:06:48.001 PM ReclaimSpaceAgent[411]: Current free space: 287.26 GB, recoverable space from Time Machine Local Snapshots: Zero KB, recoverable space from Package Kit: Zero KB, recoverable space from Commerce Kit Zero KB, total recoverable space: Zero KB
            12/18/12 9:07:31.820 PM Finder[158]: pearlBrowserSelectionChanged.
            12/18/12 9:07:50.166 PM Finder[158]: pearlBrowserSelectionChanged.
            12/18/12 9:07:53.506 PM Finder[158]: pearlBrowserSelectionChanged.
            12/18/12 9:08:02.725 PM Finder[158]: pearlBrowserSelectionChanged.
            12/18/12 9:08:06.743 PM Finder[158]: pearlBrowserSelectionChanged.
            12/18/12 9:08:09.647 PM Finder[158]: pearlBrowserSelectionChanged.
            12/18/12 9:08:12.285 PM Finder[158]: pearlBrowserSelectionChanged.
            12/18/12 9:08:20.829 PM Finder[158]: pearlBrowserSelectionChanged.
            12/18/12 9:08:22.070 PM Finder[158]: pearlBrowserSelectionChanged.
            12/18/12 9:08:27.879 PM Finder[158]: pearlBrowserSelectionChanged.
            12/18/12 9:09:59.879 PM WindowServer[119]: _CGXGetWindowOrderingGroup: Operation on a window 0x32 requiring rights 0x5 by caller Photoshop
            12/18/12 9:10:06.531 PM Finder[158]: pearlBrowserSelectionChanged.
            12/18/12 9:12:56.751 PM WindowServer[119]: CGXDisableUpdate: UI updates were forcibly disabled by application "Photoshop" for over 1.00 seconds. Server has re-enabled them.
            12/18/12 9:12:58.358 PM WindowServer[119]: reenable_update_for_connection: UI updates were finally reenabled by application "Photoshop" after 2.61 seconds (server forcibly re-enabled them after 1.00 seconds)
            12/18/12 9:13:12.123 PM WindowServer[119]: CGXDisableUpdate: UI updates were forcibly disabled by application "Photoshop" for over 1.00 seconds. Server has re-enabled them.
            12/18/12 9:13:13.449 PM WindowServer[119]: reenable_update_for_connection: UI updates were finally reenabled by application "Photoshop" after 2.33 seconds (server forcibly re-enabled them after 1.00 seconds)
            12/18/12 9:13:26.492 PM WindowServer[119]: CGXDisableUpdate: UI updates were forcibly disabled by application "Photoshop" for over 1.00 seconds. Server has re-enabled them.
            12/18/12 9:13:28.423 PM WindowServer[119]: reenable_update_for_connection: UI updates were finally reenabled by application "Photoshop" after 2.93 seconds (server forcibly re-enabled them after 1.00 seconds)
            12/18/12 9:17:38.440 PM SystemUIServer[157]: *** WARNING: -[NSImage compositeToPoint:operation:fraction:] is deprecated in MacOSX 10.8 and later. Please use -[NSImage drawAtPoint:fromRect:operation:fraction:] instead.
            12/18/12 9:17:38.440 PM SystemUIServer[157]: *** WARNING: -[NSImage compositeToPoint:fromRect:operation:fraction:] is deprecated in MacOSX 10.8 and later. Please use -[NSImage drawAtPoint:fromRect:operation:fraction:] instead.
            12/18/12 9:17:38.465 PM SystemUIServer[157]: *** WARNING: -[NSImage compositeToPoint:operation:] is deprecated in MacOSX 10.8 and later. Please use -[NSImage drawAtPoint:fromRect:operation:fraction:] instead.
            12/18/12 9:17:38.465 PM SystemUIServer[157]: *** WARNING: -[NSImage compositeToPoint:fromRect:operation:] is deprecated in MacOSX 10.8 and later. Please use -[NSImage drawAtPoint:fromRect:operation:fraction:] instead.
            12/18/12 9:18:02.499 PM System Preferences[467]: Cannot setMachineString without first being authenticated
            12/18/12 9:18:02.545 PM System Preferences[467]: *** WARNING: -[NSImage compositeToPoint:operation:] is deprecated in MacOSX 10.8 and later. Please use -[NSImage drawAtPoint:fromRect:operation:fraction:] instead.
            12/18/12 9:18:02.547 PM System Preferences[467]: *** WARNING: -[NSImage compositeToPoint:fromRect:operation:] is deprecated in MacOSX 10.8 and later. Please use -[NSImage drawAtPoint:fromRect:operation:fraction:] instead.
            12/18/12 9:18:02.549 PM System Preferences[467]: *** WARNING: -[NSImage compositeToPoint:operation:fraction:] is deprecated in MacOSX 10.8 and later. Please use -[NSImage drawAtPoint:fromRect:operation:fraction:] instead.
            12/18/12 9:18:02.551 PM System Preferences[467]: *** WARNING: -[NSImage compositeToPoint:fromRect:operation:fraction:] is deprecated in MacOSX 10.8 and later. Please use -[NSImage drawAtPoint:fromRect:operation:fraction:] instead.
            12/18/12 9:18:22.856 PM System Preferences[474]: Cannot setMachineString without first being authenticated
            12/18/12 9:18:22.897 PM System Preferences[474]: *** WARNING: -[NSImage compositeToPoint:operation:] is deprecated in MacOSX 10.8 and later. Please use -[NSImage drawAtPoint:fromRect:operation:fraction:] instead.
            12/18/12 9:18:22.899 PM System Preferences[474]: *** WARNING: -[NSImage compositeToPoint:fromRect:operation:] is deprecated in MacOSX 10.8 and later. Please use -[NSImage drawAtPoint:fromRect:operation:fraction:] instead.
            12/18/12 9:18:22.901 PM System Preferences[474]: *** WARNING: -[NSImage compositeToPoint:operation:fraction:] is deprecated in MacOSX 10.8 and later. Please use -[NSImage drawAtPoint:fromRect:operation:fraction:] instead.
            12/18/12 9:18:22.903 PM System Preferences[474]: *** WARNING: -[NSImage compositeToPoint:fromRect:operation:fraction:] is deprecated in MacOSX 10.8 and later. Please use -[NSImage drawAtPoint:fromRect:operation:fraction:] instead.
            12/18/12 9:22:23.026 PM Finder[158]: pearlBrowserSelectionChanged.
            12/18/12 9:22:29.734 PM Finder[158]: pearlBrowserSelectionChanged.
            12/18/12 9:22:30.000 PM kernel[0]: CODE SIGNING: cs_invalid_page(0x100000000): p=496[AdobeCrashDaemon] clearing CS_VALID
            12/18/12 9:22:32.000 PM kernel[0]: CODE SIGNING: cs_invalid_page(0x100000000): p=497[VulcanMessageCmd] clearing CS_VALID
            12/18/12 9:23:19.000 PM kernel[0]: Sandbox: sandboxd(511) deny mach-lookup com.apple.coresymbolicationd
            12/18/12 9:23:24.357 PM sandboxd[511]: ([509]) WebProcess(509) deny mach-lookup ATS Query Port 182
            12/18/12 9:23:24.367 PM sandboxd[511]: ([509]) WebProcess(509) deny mach-lookup ATS Query Port 182
            12/18/12 9:23:33.443 PM GoogleTalkPlugin[514]: objc[514]: Class MacCocoaSocketServerHelper is implemented in both /Library/Application Support/Google/GoogleTalkPlugin.app/Contents/MacOS/GoogleTalkPlugin and /Library/Application Support/Google/GoogleTalkPlugin.app/Contents/Frameworks/libgoogletalkremoting.dylib. One of the two will be used. Which one is undefined.
            12/18/12 9:24:04.000 PM kernel[0]: Sandbox: sandboxd(520) deny mach-lookup com.apple.coresymbolicationd
            12/18/12 9:24:04.210 PM sandboxd[520]: ([509]) WebProcess(509) deny mach-lookup ATS Query Port 182
            12/18/12 9:24:04.220 PM sandboxd[520]: ([509]) WebProcess(509) deny mach-lookup ATS Query Port 182
            12/18/12 9:24:04.229 PM sandboxd[520]: ([509]) WebProcess(509) deny mach-lookup ATS Query Port 182
            12/18/12 9:24:04.237 PM sandboxd[520]: ([509]) WebProcess(509) deny mach-lookup ATS Query Port 182
            12/18/12 9:24:04.246 PM sandboxd[520]: ([509]) WebProcess(509) deny mach-lookup ATS Query Port 182
            12/18/12 9:24:04.255 PM sandboxd[520]: ([509]) WebProcess(509) deny mach-lookup ATS Query Port 182
            12/18/12 9:24:04.264 PM sandboxd[520]: ([509]) WebProcess(509) deny mach-lookup ATS Query Port 182
            12/18/12 9:24:15.939 PM Finder[158]: pearlBrowserSelectionChanged.
            12/18/12 9:24:16.344 PM login[527]: USER_PROCESS: 527 ttys000
            12/18/12 9:24:16.414 PM launchctl[534]: launchctl: Dubious permissions on file (skipping): /Library/LaunchAgents/com.adobe.AAM.Updater-1.0.plist
            12/18/12 9:26:20.579 PM login[527]: DEAD_PROCESS: 527 ttys000
            12/18/12 9:26:23.209 PM login[547]: USER_PROCESS: 547 ttys000
            12/18/12 9:27:39.653 PM sudo[555]:   Imacom : TTY=ttys000 ; PWD=/Applications/Adobe ; USER=root ; COMMAND=/usr/bin/touch ExManLog.YES
            12/18/12 9:29:08.669 PM sudo[564]:   Imacom : TTY=ttys000 ; PWD=/Applications/Adobe Extension Manager CS6/Adobe Extension Manager CS6.app/Contents/MacOS ; USER=root ; COMMAND=/usr/bin/touch ExManLog.YES
            12/18/12 9:31:58.219 PM Finder[158]: pearlBrowserSelectionChanged.
            12/18/12 9:32:03.894 PM Finder[158]: pearlBrowserSelectionChanged.
            12/18/12 9:32:05.000 PM kernel[0]: CODE SIGNING: cs_invalid_page(0x100000000): p=582[AdobeCrashDaemon] clearing CS_VALID
            12/18/12 9:32:06.000 PM kernel[0]: CODE SIGNING: cs_invalid_page(0x100000000): p=584[VulcanMessageCmd] clearing CS_VALID
            12/18/12 9:34:15.923 PM Finder[158]: pearlBrowserSelectionChanged.
            12/18/12 9:34:18.243 PM Finder[158]: pearlBrowserSelectionChanged.
            12/18/12 9:34:27.308 PM Finder[158]: pearlBrowserSelectionChanged.
            12/18/12 9:35:00.215 PM Finder[158]: pearlBrowserSelectionChanged.
            12/18/12 9:35:21.302 PM Finder[158]: pearlBrowserSelectionChanged.
            12/18/12 9:35:21.357 PM Finder[158]: pearlBrowserSelectionChanged.
            • 3. Re: Dreamweaver CS6 no longer shows up in Extension Manager
              Carl Sun Level 4
              The log you posted seems the Console output. It is not the log generated by Extension Manager. Please refer to the link I gave you above (http://forums.adobe.com/message/4275082#4275082) to generate log files.
              Please note that you have to use double quotation mark to enclose the path when you change directory. i.e., use
              cd "/Applications/Adobe Extension Manager CS6/Adobe Extension Manager CS6.app/Contents/MacOS"
              to change directory.
              Also "/Users/<UserName>/Library/" is hidden in Mac OSX 10.7 and later. You can go to this folder in Finder by holding down option key then click menu "Go"-->"Library".
              • 4. Re: Dreamweaver CS6 no longer shows up in Extension Manager
                Helen Eichel Level 1
                Hopefully this is what you're looking for - thanks:
                12/18/2012 22:19:58.348 [INFO] com.adobe.exman.controller.PassiveGatewayPrepCommand execute(), PassiveGatewayPrepCommand is executed.
                12/18/2012 22:19:58.352 [INFO] com.adobe.exman.controller.gateway.PassiveExternalGateway registerAirInterfaces
                12/18/2012 22:19:58.352 [INFO] com.adobe.exman.controller.gateway.PassiveExternalGateway sendCallBackReady(), available==true
                12/18/2012 22:19:58.353 [INFO] com.adobe.exman.controller.ModelPrepCommand ModelPrepCommand command finished.
                12/18/2012 22:19:58.356 [INFO] com.adobe.exman.model.ExManConfigurationProxy ExManConfigurationProxy(), zstringPath is: /Applications/Adobe Extension Manager CS6/Adobe Extension Manager CS6.app/Contents/MacOS/ZStringResources
                12/18/2012 22:19:58.357 [INFO] com.adobe.exman.model.ExManConfigurationProxy initLocaleList(), the locale list is: en_US,da_DK,de_DE,cs_CZ,es_ES,fi_FI,fr_FR,hu_HU,it_IT,ja_JP,ko_KR,nb_NO,nl_NL,pl_PL,pt_BR ,ru_RU,sv_SE,tr_TR,uk_UA,zh_CN,zh_TW
                12/18/2012 22:19:58.360 [INFO] com.adobe.exman.view.ExManApp ExManApp(), instance is constructed.
                12/18/2012 22:19:58.381 [DEBUG] com.adobe.exman.util.ExManVulcan ExManVulcan: ctor...
                12/18/2012 22:19:58.388 [DEBUG] com.adobe.exman.util.ExManVulcan ExManVulcan, vulcanSetup
                12/18/2012 22:19:58.420 [INFO] com.adobe.exman.controller.gateway.Application ###Receive airGetLocaleList Message:-1,airGetLocaleList
                12/18/2012 22:19:58.420 [INFO] com.adobe.exman.controller.gateway.PassiveExternalGateway handleAirGetLocaleList(), sessionId== -1
                12/18/2012 22:19:58.421 [INFO] com.adobe.exman.controller.passivecommand.GetLocaleListCommand execute(), sessionId= -1
                12/18/2012 22:19:58.421 [INFO] com.adobe.exman.controller.passivecommand.GetLocaleListCommand execute(), the locale list is: en_US,da_DK,de_DE,cs_CZ,es_ES,fi_FI,fr_FR,hu_HU,it_IT,ja_JP,ko_KR,nb_NO,nl_NL,pl_PL,pt_BR ,ru_RU,sv_SE,tr_TR,uk_UA,zh_CN,zh_TW
                12/18/2012 22:19:58.422 [INFO] com.adobe.exman.controller.passivecommand.RespondPassiveExternalGatewayCommand execute(), parameter: sessionId to respond: -1parameters to respond: en_US,da_DK,de_DE,cs_CZ,es_ES,fi_FI,fr_FR,hu_HU,it_IT,ja_JP,ko_KR,nb_NO,nl_NL,pl_PL,pt_BR ,ru_RU,sv_SE,tr_TR,uk_UA,zh_CN,zh_TW
                12/18/2012 22:19:58.422 [INFO] com.adobe.exman.controller.gateway.PassiveExternalGateway giveResponseToExternal(), the args to external interface is: externalCallBack,-1,0,en_US,da_DK,de_DE,cs_CZ,es_ES,fi_FI,fr_FR,hu_HU,it_IT,ja_JP,ko_KR,n b_NO,nl_NL,pl_PL,pt_BR,ru_RU,sv_SE,tr_TR,uk_UA,zh_CN,zh_TW
                12/18/2012 22:19:58.423 [DEBUG] com.adobe.exman.controller.gateway.ExternalGateway ###call2extensionMgr externalCallBack,-1,0,en_US,da_DK,de_DE,cs_CZ,es_ES,fi_FI,fr_FR,hu_HU,it_IT,ja_JP,ko_KR,n b_NO,nl_NL,pl_PL,pt_BR,ru_RU,sv_SE,tr_TR,uk_UA,zh_CN,zh_TW
                12/18/2012 22:19:58.426 [INFO] com.adobe.exman.controller.gateway.Application ###Receive airSetLocale Message:-2,airSetLocale,en_US
                12/18/2012 22:19:58.426 [INFO] com.adobe.exman.controller.gateway.PassiveExternalGateway handleAirSetLocale(), sessionId=-2args=en_US
                12/18/2012 22:19:58.426 [INFO] com.adobe.exman.model.ExManConfigurationProxy defaultOSLocale(), set to: en_US
                12/18/2012 22:19:58.432 [INFO] com.adobe.exman.view.ExManApp handleNotification(), got notification: SET_LOCAL
                notification body: en_US
                12/18/2012 22:19:58.433 [DEBUG] com.adobe.exman.view.ExManApp @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
                12/18/2012 22:19:58.433 [DEBUG] com.adobe.exman.view.ExManApp SET_LOCAL
                12/18/2012 22:19:58.433 [INFO] com.adobe.exman.view.ExManApp handleNotification(), locale= en_US
                12/18/2012 22:19:58.436 [INFO] com.adobe.exman.controller.LoadUIPreferencesCommand execute(), LoadUIPreferencesCommand is executed.
                12/18/2012 22:19:58.437 [INFO] com.adobe.exman.view.ExManApp handleNotification(), got notification: LOAD_UI_PREFERENCES_DONE
                notification body: [object UIPreferences]
                12/18/2012 22:19:58.437 [DEBUG] com.adobe.exman.view.ExManApp @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
                12/18/2012 22:19:58.437 [DEBUG] com.adobe.exman.view.ExManApp LOAD_UI_PREFERENCES_DONE
                12/18/2012 22:19:58.438 [INFO] com.adobe.exman.controller.SetWindowPreferencesCommand execute(), SetWindowPreferencesCommand is executed.
                12/18/2012 22:19:58.439 [INFO] com.adobe.exman.model.SessionManagerProxy outputAllTheSessionId(), there are following sessions now: 0----
                12/18/2012 22:19:58.440 [INFO] com.adobe.exman.controller.gateway.ExternalGateway ExternalGateway()
                12/18/2012 22:19:58.440 [INFO] com.adobe.exman.controller.gateway.ExternalGateway resetExternalInterface()
                12/18/2012 22:19:58.440 [INFO] com.adobe.exman.controller.gateway.ExternalGateway resetExternalInterface(), airCallBack added.
                12/18/2012 22:19:58.440 [INFO] com.adobe.exman.model.SessionManagerProxy outputAllTheSessionId(), there are following sessions now: 0----
                12/18/2012 22:19:58.441 [INFO] com.adobe.exman.controller.gateway.ExternalGateway setWindowPreferences(), sessionId= 0, windowPosition_x= 714, windowPosition_y= 464, windowWidth= 810, windowHeight= 600
                12/18/2012 22:19:58.521 [INFO] com.adobe.exman.ExManGUI onColumnAssociateChange()
                12/18/2012 22:19:58.522 [INFO] com.adobe.exman.view.widget.ExManDataGridColumn adjustColumnWidth()
                12/18/2012 22:19:58.523 [INFO] com.adobe.exman.view.widget.ExManDataGridColumn adjustColumnWidth(), width of column [OnOff] set to: 69
                12/18/2012 22:19:58.523 [INFO] com.adobe.exman.ExManGUI onColumnAssociateChange(), width of column [0] is changed to: 69
                12/18/2012 22:19:58.546 [INFO] com.adobe.exman.controller.gateway.Application ###Receive airCallBack Message0,0
                12/18/2012 22:19:58.547 [INFO] com.adobe.exman.controller.gateway.ExternalGateway handleResponse(), parameters of handleResponse:
                sessionId= 0
                responseType= 0
                responseBody=
                12/18/2012 22:19:58.547 [INFO] com.adobe.exman.controller.session.backend.BackendSession com.adobe.exman.controller.session.backend::SetWindowPreferencesSession got parameters in handleResponse:
                responseType= 0
                12/18/2012 22:19:58.547 [DEBUG] com.adobe.exman.view.ExManApp @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
                12/18/2012 22:19:58.548 [DEBUG] com.adobe.exman.view.ExManApp NOTIF_SET_WINDOW_PREFERENCES_SUCCEED
                12/18/2012 22:19:58.548 [INFO] com.adobe.exman.model.SessionManagerProxy outputAllTheSessionId(), there are following sessions now:
                12/18/2012 22:19:58.550 [INFO] com.adobe.exman.controller.gateway.Application ###Receive airParseXML Message:-3,airParseXML,/Applications/Adobe Contribute CS5/Configuration/XManConfig.xml,Configuration.VariableForExMan.Data
                12/18/2012 22:19:58.551 [INFO] com.adobe.exman.controller.gateway.PassiveExternalGateway handleAirParseXML(), sessionId==-3got xml String to parse: /Applications/Adobe Contribute CS5/Configuration/XManConfig.xml
                12/18/2012 22:19:58.552 [INFO] com.adobe.exman.controller.ParseXMLCommand execute(), ParseXMLCommand is executed.
                12/18/2012 22:19:58.553 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: file:///Applications/Adobe%20Contribute%20CS5/Configuration/XManConfig.xml
                12/18/2012 22:19:58.553 [DEBUG] com.adobe.exman.business.XMLLoader XMLLoader(), XML file is XManConfig.xml file, just load it directly
                12/18/2012 22:19:58.553 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), try to load: file:///Applications/Adobe%20Contribute%20CS5/Configuration/XManConfig.xml
                12/18/2012 22:19:58.565 [INFO] com.adobe.exman.controller.gateway.PassiveExternalGateway handleAirParseXML, success, externalCallBack,-3,0,UserExtensionFolder,$UserDataFolder/Adobe/Adobe Contribute CS5/$Locale/Configuration/Extensions,$contribute,$InstallFolder,$contribute_user,$UserDat aFolder/Adobe/Adobe Contribute CS5/$Locale,DisplayName,Contribute CS5,ProductName,Contribute,ProductVersion,6.0,HostNameForCSXS,CNTB,IconPath,Configuration /Icon.png,SupportedInSuite,CS5,DefaultLocale,en_US,Bit,32
                12/18/2012 22:19:58.566 [DEBUG] com.adobe.exman.controller.gateway.ExternalGateway ###call2extensionMgr externalCallBack,-3,0,UserExtensionFolder,$UserDataFolder/Adobe/Adobe Contribute CS5/$Locale/Configuration/Extensions,$contribute,$InstallFolder,$contribute_user,$UserDat aFolder/Adobe/Adobe Contribute CS5/$Locale,DisplayName,Contribute CS5,ProductName,Contribute,ProductVersion,6.0,HostNameForCSXS,CNTB,IconPath,Configuration /Icon.png,SupportedInSuite,CS5,DefaultLocale,en_US,Bit,32
                12/18/2012 22:19:58.573 [INFO] com.adobe.exman.controller.gateway.Application ###Receive airParseXML Message:-4,airParseXML,/Applications/Adobe Bridge CS4/Configuration/XManConfig.xml,Configuration.VariableForExMan.Data
                12/18/2012 22:19:58.573 [INFO] com.adobe.exman.controller.gateway.PassiveExternalGateway handleAirParseXML(), sessionId==-4got xml String to parse: /Applications/Adobe Bridge CS4/Configuration/XManConfig.xml
                12/18/2012 22:19:58.573 [INFO] com.adobe.exman.controller.ParseXMLCommand execute(), ParseXMLCommand is executed.
                12/18/2012 22:19:58.574 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: file:///Applications/Adobe%20Bridge%20CS4/Configuration/XManConfig.xml
                12/18/2012 22:19:58.574 [DEBUG] com.adobe.exman.business.XMLLoader XMLLoader(), XML file is XManConfig.xml file, just load it directly
                12/18/2012 22:19:58.574 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), try to load: file:///Applications/Adobe%20Bridge%20CS4/Configuration/XManConfig.xml
                12/18/2012 22:19:58.589 [INFO] com.adobe.exman.controller.gateway.PassiveExternalGateway handleAirParseXML, success, externalCallBack,-4,0,DisplayName,Bridge CS4,ProductName,Bridge,FamilyName,Bridge,ProductVersion,3.0,IconPath,Configuration/Icon.p ng,UserExtensionFolder,$UserDataFolder/Adobe/Bridge CS4/Configuration/Extensions,$bridgeappfolder,$installfolder,$pluginsfolder,$bridgeappfol der/Plug-Ins,$presetsfolder,$bridgeappfolder/Presets,$bridge,$UserDataFolder/Adobe/Bridge CS4/Configuration,$startupscripts,$adobecommon/Startup Scripts CS4,$bridgestartupscripts,$startupscripts/Adobe Bridge,$extensions,$adobecommon/Bridge CS4 Extensions,$workspaces,$UserDataFolder/Adobe/Bridge CS4/Workspaces,$extensionworkspaces,$extensions/Workspaces,$userscripts,$UserDataFolder/A dobe/Bridge CS4/Startup Scripts
                12/18/2012 22:19:58.589 [DEBUG] com.adobe.exman.controller.gateway.ExternalGateway ###call2extensionMgr externalCallBack,-4,0,DisplayName,Bridge CS4,ProductName,Bridge,FamilyName,Bridge,ProductVersion,3.0,IconPath,Configuration/Icon.p ng,UserExtensionFolder,$UserDataFolder/Adobe/Bridge CS4/Configuration/Extensions,$bridgeappfolder,$installfolder,$pluginsfolder,$bridgeappfol der/Plug-Ins,$presetsfolder,$bridgeappfolder/Presets,$bridge,$UserDataFolder/Adobe/Bridge CS4/Configuration,$startupscripts,$adobecommon/Startup Scripts CS4,$bridgestartupscripts,$startupscripts/Adobe Bridge,$extensions,$adobecommon/Bridge CS4 Extensions,$workspaces,$UserDataFolder/Adobe/Bridge CS4/Workspaces,$extensionworkspaces,$extensions/Workspaces,$userscripts,$UserDataFolder/A dobe/Bridge CS4/Startup Scripts
                12/18/2012 22:19:58.597 [INFO] com.adobe.exman.controller.gateway.Application ###Receive airParseXML Message:-5,airParseXML,/Applications/Adobe Bridge CS5/Configuration/XManConfig.xml,Configuration.VariableForExMan.Data
                12/18/2012 22:19:58.597 [INFO] com.adobe.exman.controller.gateway.PassiveExternalGateway handleAirParseXML(), sessionId==-5got xml String to parse: /Applications/Adobe Bridge CS5/Configuration/XManConfig.xml
                12/18/2012 22:19:58.597 [INFO] com.adobe.exman.controller.ParseXMLCommand execute(), ParseXMLCommand is executed.
                12/18/2012 22:19:58.598 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: file:///Applications/Adobe%20Bridge%20CS5/Configuration/XManConfig.xml
                12/18/2012 22:19:58.598 [DEBUG] com.adobe.exman.business.XMLLoader XMLLoader(), XML file is XManConfig.xml file, just load it directly
                12/18/2012 22:19:58.598 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), try to load: file:///Applications/Adobe%20Bridge%20CS5/Configuration/XManConfig.xml
                12/18/2012 22:19:58.610 [INFO] com.adobe.exman.controller.gateway.PassiveExternalGateway handleAirParseXML, success, externalCallBack,-5,0,DisplayName,Bridge CS5,ProductName,Bridge,FamilyName,Bridge,ProductVersion,4.0,IconPath,Configuration/Icon.p ng,UserExtensionFolder,$UserDataFolder/Adobe/Bridge CS5/Configuration/Extensions,SupportedInSuite,CS5,$bridgeappfolder,$installfolder,$plugin sfolder,$bridgeappfolder/Plug-Ins,$presetsfolder,$bridgeappfolder/Presets,$bridge,$UserDat aFolder/Adobe/Bridge CS5/Configuration,$startupscripts,$adobecommon/Startup Scripts CS5,$bridgestartupscripts,$startupscripts/Adobe Bridge,$extensions,$adobecommon/Bridge CS5 Extensions,$workspaces,$UserDataFolder/Adobe/Bridge CS5/Workspaces,$extensionworkspaces,$extensions/Workspaces,$userscripts,$UserDataFolder/A dobe/Bridge CS5/Startup Scripts
                12/18/2012 22:19:58.610 [DEBUG] com.adobe.exman.controller.gateway.ExternalGateway ###call2extensionMgr externalCallBack,-5,0,DisplayName,Bridge CS5,ProductName,Bridge,FamilyName,Bridge,ProductVersion,4.0,IconPath,Configuration/Icon.p ng,UserExtensionFolder,$UserDataFolder/Adobe/Bridge CS5/Configuration/Extensions,SupportedInSuite,CS5,$bridgeappfolder,$installfolder,$plugin sfolder,$bridgeappfolder/Plug-Ins,$presetsfolder,$bridgeappfolder/Presets,$bridge,$UserDat aFolder/Adobe/Bridge CS5/Configuration,$startupscripts,$adobecommon/Startup Scripts CS5,$bridgestartupscripts,$startupscripts/Adobe Bridge,$extensions,$adobecommon/Bridge CS5 Extensions,$workspaces,$UserDataFolder/Adobe/Bridge CS5/Workspaces,$extensionworkspaces,$extensions/Workspaces,$userscripts,$UserDataFolder/A dobe/Bridge CS5/Startup Scripts
                12/18/2012 22:19:58.622 [INFO] com.adobe.exman.controller.gateway.Application ###Receive airParseXML Message:-6,airParseXML,/Applications/Adobe Illustrator CS5/Configuration/XManConfig.xml,Configuration.VariableForExMan.Data
                12/18/2012 22:19:58.622 [INFO] com.adobe.exman.controller.gateway.PassiveExternalGateway handleAirParseXML(), sessionId==-6got xml String to parse: /Applications/Adobe Illustrator CS5/Configuration/XManConfig.xml
                12/18/2012 22:19:58.622 [INFO] com.adobe.exman.controller.ParseXMLCommand execute(), ParseXMLCommand is executed.
                12/18/2012 22:19:58.622 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: file:///Applications/Adobe%20Illustrator%20CS5/Configuration/XManConfig.xml
                12/18/2012 22:19:58.622 [DEBUG] com.adobe.exman.business.XMLLoader XMLLoader(), XML file is XManConfig.xml file, just load it directly
                12/18/2012 22:19:58.623 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), try to load: file:///Applications/Adobe%20Illustrator%20CS5/Configuration/XManConfig.xml
                12/18/2012 22:19:58.631 [INFO] com.adobe.exman.controller.gateway.PassiveExternalGateway handleAirParseXML, success, externalCallBack,-6,0,UserExtensionFolder,$InstallFolder/Configuration/Extensions,$illust rator,$InstallFolder,$plugin,$InstallFolder/Plug-ins.localized,$scripting,$InstallFolder/S cripting.localized,$presets,$InstallFolder/Presets.localized,DisplayName,Illustrator CS5,ProductName,Illustrator,ProductVersion,15.0,HostNameForCSXS,ILST,IconPath,Configurati on/ai_app_24px.png,SupportedInSuite,CS5,DefaultLocale,en_US,EmStorePath,$SharedRibsDataFol der/Adobe/Extension Manager CS5/Illustrator CS5,Bit,32
                12/18/2012 22:19:58.631 [DEBUG] com.adobe.exman.controller.gateway.ExternalGateway ###call2extensionMgr externalCallBack,-6,0,UserExtensionFolder,$InstallFolder/Configuration/Extensions,$illust rator,$InstallFolder,$plugin,$InstallFolder/Plug-ins.localized,$scripting,$InstallFolder/S cripting.localized,$presets,$InstallFolder/Presets.localized,DisplayName,Illustrator CS5,ProductName,Illustrator,ProductVersion,15.0,HostNameForCSXS,ILST,IconPath,Configurati on/ai_app_24px.png,SupportedInSuite,CS5,DefaultLocale,en_US,EmStorePath,$SharedRibsDataFol der/Adobe/Extension Manager CS5/Illustrator CS5,Bit,32
                12/18/2012 22:19:58.637 [INFO] com.adobe.exman.controller.gateway.Application ###Receive airParseXML Message:-7,airParseXML,/Applications/Adobe InDesign CS4/Configuration/XManConfig.xml,Configuration.VariableForExMan.Data
                12/18/2012 22:19:58.638 [INFO] com.adobe.exman.controller.gateway.PassiveExternalGateway handleAirParseXML(), sessionId==-7got xml String to parse: /Applications/Adobe InDesign CS4/Configuration/XManConfig.xml
                12/18/2012 22:19:58.638 [INFO] com.adobe.exman.controller.ParseXMLCommand execute(), ParseXMLCommand is executed.
                12/18/2012 22:19:58.638 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: file:///Applications/Adobe%20InDesign%20CS4/Configuration/XManConfig.xml
                12/18/2012 22:19:58.638 [DEBUG] com.adobe.exman.business.XMLLoader XMLLoader(), XML file is XManConfig.xml file, just load it directly
                12/18/2012 22:19:58.638 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), try to load: file:///Applications/Adobe%20InDesign%20CS4/Configuration/XManConfig.xml
                12/18/2012 22:19:58.651 [INFO] com.adobe.exman.controller.gateway.PassiveExternalGateway handleAirParseXML, success, externalCallBack,-7,0,UserExtensionFolder,$UserDataFolder/Adobe/Adobe InDesign CS4/Configuration/Extensions,$indesign,$InstallFolder,$indesign_user,$UserDataFolder/Adob e/Adobe InDesign CS4,DisplayName,InDesign CS4,ProductName,InDesign,ProductVersion,6.0,IconPath,Configuration/Icon.png,SupportedInSu ite,CS4,DefaultLocale,en_US
                12/18/2012 22:19:58.651 [DEBUG] com.adobe.exman.controller.gateway.ExternalGateway ###call2extensionMgr externalCallBack,-7,0,UserExtensionFolder,$UserDataFolder/Adobe/Adobe InDesign CS4/Configuration/Extensions,$indesign,$InstallFolder,$indesign_user,$UserDataFolder/Adob e/Adobe InDesign CS4,DisplayName,InDesign CS4,ProductName,InDesign,ProductVersion,6.0,IconPath,Configuration/Icon.png,SupportedInSu ite,CS4,DefaultLocale,en_US
                12/18/2012 22:19:58.656 [INFO] com.adobe.exman.controller.gateway.Application ###Receive airParseXML Message:-8,airParseXML,/Applications/Adobe InDesign CS5/Configuration/XManConfig.xml,Configuration.VariableForExMan.Data
                12/18/2012 22:19:58.657 [INFO] com.adobe.exman.controller.gateway.PassiveExternalGateway handleAirParseXML(), sessionId==-8got xml String to parse: /Applications/Adobe InDesign CS5/Configuration/XManConfig.xml
                12/18/2012 22:19:58.657 [INFO] com.adobe.exman.controller.ParseXMLCommand execute(), ParseXMLCommand is executed.
                12/18/2012 22:19:58.657 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: file:///Applications/Adobe%20InDesign%20CS5/Configuration/XManConfig.xml
                12/18/2012 22:19:58.657 [DEBUG] com.adobe.exman.business.XMLLoader XMLLoader(), XML file is XManConfig.xml file, just load it directly
                12/18/2012 22:19:58.657 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), try to load: file:///Applications/Adobe%20InDesign%20CS5/Configuration/XManConfig.xml
                12/18/2012 22:19:58.671 [INFO] com.adobe.exman.controller.gateway.PassiveExternalGateway handleAirParseXML, success, externalCallBack,-8,0,UserExtensionFolder,$UserDataFolder/Adobe/Adobe InDesign CS5/Configuration/Extensions,$indesign,$InstallFolder,$indesign_user,$UserDataFolder/Adob e/Adobe InDesign CS5,DisplayName,InDesign CS5,GlobalProductName,Adobe InDesign CS5,ProductName,InDesign,ProductVersion,7.0,HostNameForCSXS,IDSN,IconPath,Configuration/I con.png,SupportedInSuite,CS5,DefaultLocale,en_US,NeedLockableExtension,true,ShowInstalledF iles,true,Bit,32,PreExtensionFolder,$SharedCommonDataFolder/Adobe/InDesign/Version 7.0/en_US/Extensions,EmStorePath,$SharedCommonDataFolder/Adobe/InDesign/Version 7.0/EmStorePath,PluginConfigFile,$UserLibraryFolder/Preferences/Adobe InDesign/Version 7.0/en_US/PlugInConfig.txt
                12/18/2012 22:19:58.671 [DEBUG] com.adobe.exman.controller.gateway.ExternalGateway ###call2extensionMgr externalCallBack,-8,0,UserExtensionFolder,$UserDataFolder/Adobe/Adobe InDesign CS5/Configuration/Extensions,$indesign,$InstallFolder,$indesign_user,$UserDataFolder/Adob e/Adobe InDesign CS5,DisplayName,InDesign CS5,GlobalProductName,Adobe InDesign CS5,ProductName,InDesign,ProductVersion,7.0,HostNameForCSXS,IDSN,IconPath,Configuration/I con.png,SupportedInSuite,CS5,DefaultLocale,en_US,NeedLockableExtension,true,ShowInstalledF iles,true,Bit,32,PreExtensionFolder,$SharedCommonDataFolder/Adobe/InDesign/Version 7.0/en_US/Extensions,EmStorePath,$SharedCommonDataFolder/Adobe/InDesign/Version 7.0/EmStorePath,PluginConfigFile,$UserLibraryFolder/Preferences/Adobe InDesign/Version 7.0/en_US/PlugInConfig.txt
                12/18/2012 22:19:58.678 [INFO] com.adobe.exman.controller.gateway.Application ###Receive airParseXML Message:-9,airParseXML,/Applications/Adobe InDesign CS6/Configuration/XManConfig.xml,Configuration.VariableForExMan.Data
                12/18/2012 22:19:58.678 [INFO] com.adobe.exman.controller.gateway.PassiveExternalGateway handleAirParseXML(), sessionId==-9got xml String to parse: /Applications/Adobe InDesign CS6/Configuration/XManConfig.xml
                12/18/2012 22:19:58.678 [INFO] com.adobe.exman.controller.ParseXMLCommand execute(), ParseXMLCommand is executed.
                12/18/2012 22:19:58.678 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: file:///Applications/Adobe%20InDesign%20CS6/Configuration/XManConfig.xml
                12/18/2012 22:19:58.678 [DEBUG] com.adobe.exman.business.XMLLoader XMLLoader(), XML file is XManConfig.xml file, just load it directly
                12/18/2012 22:19:58.679 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), try to load: file:///Applications/Adobe%20InDesign%20CS6/Configuration/XManConfig.xml
                12/18/2012 22:19:58.692 [INFO] com.adobe.exman.controller.gateway.PassiveExternalGateway handleAirParseXML, success, externalCallBack,-9,0,$indesign,$InstallFolder,$indesign_user,$UserDataFolder/Adobe/Adobe InDesign CS6,DisplayName,InDesign CS6,GlobalProductName,Adobe InDesign CS6,ProductName,InDesign,ProductVersion,8.0,HostNameForCSXS,IDSN,IconPath,Configuration/I con.png,SupportedInSuite,CS6,DefaultLocale,en_US,NeedLockableExtension,true,ShowInstalledF iles,true,Bit,32,PreExtensionFolder,$SharedCommonDataFolder/Adobe/InDesign/Version 8.0/en_US/Extensions,PluginConfigFile,$UserLibraryFolder/Preferences/Adobe InDesign/Version 8.0/en_US/PlugInConfig.txt
                12/18/2012 22:19:58.692 [DEBUG] com.adobe.exman.controller.gateway.ExternalGateway ###call2extensionMgr externalCallBack,-9,0,$indesign,$InstallFolder,$indesign_user,$UserDataFolder/Adobe/Adobe InDesign CS6,DisplayName,InDesign CS6,GlobalProductName,Adobe InDesign CS6,ProductName,InDesign,ProductVersion,8.0,HostNameForCSXS,IDSN,IconPath,Configuration/I con.png,SupportedInSuite,CS6,DefaultLocale,en_US,NeedLockableExtension,true,ShowInstalledF iles,true,Bit,32,PreExtensionFolder,$SharedCommonDataFolder/Adobe/InDesign/Version 8.0/en_US/Extensions,PluginConfigFile,$UserLibraryFolder/Preferences/Adobe InDesign/Version 8.0/en_US/PlugInConfig.txt
                12/18/2012 22:19:58.699 [INFO] com.adobe.exman.controller.gateway.Application ###Receive airParseXML Message:-10,airParseXML,/Applications/Adobe Photoshop CS5/Configuration/XManConfig.xml,Configuration.VariableForExMan.Data
                12/18/2012 22:19:58.699 [INFO] com.adobe.exman.controller.gateway.PassiveExternalGateway handleAirParseXML(), sessionId==-10got xml String to parse: /Applications/Adobe Photoshop CS5/Configuration/XManConfig.xml
                12/18/2012 22:19:58.699 [INFO] com.adobe.exman.controller.ParseXMLCommand execute(), ParseXMLCommand is executed.
                12/18/2012 22:19:58.699 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: file:///Applications/Adobe%20Photoshop%20CS5/Configuration/XManConfig.xml
                12/18/2012 22:19:58.699 [DEBUG] com.adobe.exman.business.XMLLoader XMLLoader(), XML file is XManConfig.xml file, just load it directly
                12/18/2012 22:19:58.700 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), try to load: file:///Applications/Adobe%20Photoshop%20CS5/Configuration/XManConfig.xml
                12/18/2012 22:19:58.712 [INFO] com.adobe.exman.controller.gateway.PassiveExternalGateway handleAirParseXML, success, externalCallBack,-10,0,EmStorePath,$SharedRibsDataFolder/Adobe/Extension Manager,$photoshopappfolder,$installfolder,$pluginsfolder,$photoshopappfolder/Plug-Ins,$p resetsfolder,$photoshopappfolder/Presets,$platform,Mac,$actions,$presetsfolder/Actions,$bl ackandwhite,$presetsfolder/Black and White,$brushes,$presetsfolder/Brushes,$channelmixer,$presetsfolder/Channel Mixer,$colorbooks,$presetsfolder/Color Books,$colorrange,$presetsfolder/Color Range,$colorswatches,$presetsfolder/Color Swatches,$contours,$presetsfolder/Contours,$curves,$presetsfolder/Curves,$customshapes,$p resetsfolder/Custom Shapes,$duotones,$presetsfolder/Duotones,$exposure,$presetsfolder/Exposure,$gradients,$pr esetsfolder/Gradients,$huesat,$presetsfolder/Hue Sat,$imagestatistics,$presetsfolder/Image Statistics,$keyboardshortcuts,$presetsfolder/Keyboard Shortcuts,$layouts,$presetsfolder/Layouts,$lenscorrection,$presetsfolder/Lens Correction,$levels,$presetsfolder/Levels,$liquifymeshes,$presetsfolder/Liquify Meshes,$menucustomization,$presetsfolder/Menu Customization,$optimizedcolors,$presetsfolder/Optimized Colors,$optimizedoutputSettings,$presetsfolder/Optimized Output Settings,$optimizedsettings,$presetsfolder/Optimized Settings,$patterns,$presetsfolder/Patterns,$reducenoise,$presetsfolder/Reduce Noise,$replacecolor,$presetsfolder/Replace Color,$scripts,$presetsfolder/Scripts,$selectivecolor,$presetsfolder/Selective Color,$shadowhighlight,$presetsfolder/Shadow Highlight,$smartsharpen,$presetsfolder/Smart Sharpen,$styles,$presetsfolder/Styles,$textures,$presetsfolder/Textures,$tools,$presetsfo lder/Tools,$variations,$presetsfolder/Variations,$webphotogallery,$presetsfolder/Web Photo Gallery,$workspaces,$presetsfolder/Workspaces,$zoomify,$presetsfolder/Zoomify,$hueandsatu ration,$presetsfolder/Hue and Saturation,$lights,$presetsfolder/Lights,$materials,$presetsfolder/Materials,$meshes,$pre setsfolder/Meshes,$rendersettings,$presetsfolder/Render Settings,$volumes,$presetsfolder/Volumes,$widgets,$presetsfolder/Widgets,$localesfolder,$ photoshopappfolder/Locales,$additionalplugins,$localesfolder/$LOCALE/Additional Plug-ins,$additionalpresets,$localesfolder/$LOCALE/Additional Presets,$localeskeyboardshortcuts,$localesfolder/$LOCALE/Additional Presets/$platform/Keyboard Shortcuts,$localesmenucustomization,$localesfolder/$LOCALE/Additional Presets/$platform/Menu Customization,$localesworkspaces,$localesfolder/$LOCALE/Additional Presets/$platform/Workspaces,$automate,$pluginsfolder/Automate,$digimarc,$pluginsfolder/D igimarc,$displacementmaps,$pluginsfolder/Displacement Maps,$effects,$pluginsfolder/Effects,$extensions,$pluginsfolder/Extensions,$fileformats,$ pluginsfolder/File Formats,$filters,$pluginsfolder/Filters,$imagestacks,$pluginsfolder/Image Stacks,$importexport,$pluginsfolder/Import-Export,$measurements,$pluginsfolder/Measuremen ts,$panels,$pluginsfolder/Panels,$parser,$pluginsfolder/Parser,$3dengines,$pluginsfolder/3 D Engines,$lightingstyles,$pluginsfolder/Filters/Lighting Styles,$matlab,$photoshopappfolder/MATLAB,UserExtensionFolder,$photoshopappfolder,$photos hop,$UserDataFolder/Adobe/Adobe Photoshop CS5/Configuration,DisplayName,Photoshop CS5,ProductName,Photoshop,FamilyName,Photoshop,ProductVersion,12.0,IconPath,Configuration /PS_exman_24px.png,SupportedInSuite,CS5,HostNameForCSXS,PHSP
                12/18/2012 22:19:58.714 [DEBUG] com.adobe.exman.controller.gateway.ExternalGateway ###call2extensionMgr externalCallBack,-10,0,EmStorePath,$SharedRibsDataFolder/Adobe/Extension Manager,$photoshopappfolder,$installfolder,$pluginsfolder,$photoshopappfolder/Plug-Ins,$p resetsfolder,$photoshopappfolder/Presets,$platform,Mac,$actions,$presetsfolder/Actions,$bl ackandwhite,$presetsfolder/Black and White,$brushes,$presetsfolder/Brushes,$channelmixer,$presetsfolder/Channel Mixer,$colorbooks,$presetsfolder/Color Books,$colorrange,$presetsfolder/Color Range,$colorswatches,$presetsfolder/Color Swatches,$contours,$presetsfolder/Contours,$curves,$presetsfolder/Curves,$customshapes,$p resetsfolder/Custom Shapes,$duotones,$presetsfolder/Duotones,$exposure,$presetsfolder/Exposure,$gradients,$pr esetsfolder/Gradients,$huesat,$presetsfolder/Hue Sat,$imagestatistics,$presetsfolder/Image Statistics,$keyboardshortcuts,$presetsfolder/Keyboard Shortcuts,$layouts,$presetsfolder/Layouts,$lenscorrection,$presetsfolder/Lens Correction,$levels,$presetsfolder/Levels,$liquifymeshes,$presetsfolder/Liquify Meshes,$menucustomization,$presetsfolder/Menu Customization,$optimizedcolors,$presetsfolder/Optimized Colors,$optimizedoutputSettings,$presetsfolder/Optimized Output Settings,$optimizedsettings,$presetsfolder/Optimized Settings,$patterns,$presetsfolder/Patterns,$reducenoise,$presetsfolder/Reduce Noise,$replacecolor,$presetsfolder/Replace Color,$scripts,$presetsfolder/Scripts,$selectivecolor,$presetsfolder/Selective Color,$shadowhighlight,$presetsfolder/Shadow Highlight,$smartsharpen,$presetsfolder/Smart Sharpen,$styles,$presetsfolder/Styles,$textures,$presetsfolder/Textures,$tools,$presetsfo lder/Tools,$variations,$presetsfolder/Variations,$webphotogallery,$presetsfolder/Web Photo Gallery,$workspaces,$presetsfolder/Workspaces,$zoomify,$presetsfolder/Zoomify,$hueandsatu ration,$presetsfolder/Hue and Saturation,$lights,$presetsfolder/Lights,$materials,$presetsfolder/Materials,$meshes,$pre setsfolder/Meshes,$rendersettings,$presetsfolder/Render Settings,$volumes,$presetsfolder/Volumes,$widgets,$presetsfolder/Widgets,$localesfolder,$ photoshopappfolder/Locales,$additionalplugins,$localesfolder/$LOCALE/Additional Plug-ins,$additionalpresets,$localesfolder/$LOCALE/Additional Presets,$localeskeyboardshortcuts,$localesfolder/$LOCALE/Additional Presets/$platform/Keyboard Shortcuts,$localesmenucustomization,$localesfolder/$LOCALE/Additional Presets/$platform/Menu Customization,$localesworkspaces,$localesfolder/$LOCALE/Additional Presets/$platform/Workspaces,$automate,$pluginsfolder/Automate,$digimarc,$pluginsfolder/D igimarc,$displacementmaps,$pluginsfolder/Displacement Maps,$effects,$pluginsfolder/Effects,$extensions,$pluginsfolder/Extensions,$fileformats,$ pluginsfolder/File Formats,$filters,$pluginsfolder/Filters,$imagestacks,$pluginsfolder/Image Stacks,$importexport,$pluginsfolder/Import-Export,$measurements,$pluginsfolder/Measuremen ts,$panels,$pluginsfolder/Panels,$parser,$pluginsfolder/Parser,$3dengines,$pluginsfolder/3 D Engines,$lightingstyles,$pluginsfolder/Filters/Lighting Styles,$matlab,$photoshopappfolder/MATLAB,UserExtensionFolder,$photoshopappfolder,$photos hop,$UserDataFolder/Adobe/Adobe Photoshop CS5/Configuration,DisplayName,Photoshop CS5,ProductName,Photoshop,FamilyName,Photoshop,ProductVersion,12.0,IconPath,Configuration /PS_exman_24px.png,SupportedInSuite,CS5,HostNameForCSXS,PHSP
                12/18/2012 22:19:58.730 [INFO] com.adobe.exman.controller.gateway.Application ###Receive airParseXML Message:-11,airParseXML,/Applications/Adobe Prelude CS6/Configuration/XManConfig.xml,Configuration.VariableForExMan.Data
                12/18/2012 22:19:58.731 [INFO] com.adobe.exman.controller.gateway.PassiveExternalGateway handleAirParseXML(), sessionId==-11got xml String to parse: /Applications/Adobe Prelude CS6/Configuration/XManConfig.xml
                12/18/2012 22:19:58.731 [INFO] com.adobe.exman.controller.ParseXMLCommand execute(), ParseXMLCommand is executed.
                12/18/2012 22:19:58.731 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: file:///Applications/Adobe%20Prelude%20CS6/Configuration/XManConfig.xml
                12/18/2012 22:19:58.731 [DEBUG] com.adobe.exman.business.XMLLoader XMLLoader(), XML file is XManConfig.xml file, just load it directly
                12/18/2012 22:19:58.731 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), try to load: file:///Applications/Adobe%20Prelude%20CS6/Configuration/XManConfig.xml
                12/18/2012 22:19:58.736 [INFO] com.adobe.exman.controller.gateway.PassiveExternalGateway handleAirParseXML, success, externalCallBack,-11,0,ProductName,Prelude,DisplayName,Prelude CS6,ProductVersion,6.0,HostNameForCSXS,PRLD,IconPath,Configuration/pl_app_24.png,Supporte dInSuite,CS6
                12/18/2012 22:19:58.736 [DEBUG] com.adobe.exman.controller.gateway.ExternalGateway ###call2extensionMgr externalCallBack,-11,0,ProductName,Prelude,DisplayName,Prelude CS6,ProductVersion,6.0,HostNameForCSXS,PRLD,IconPath,Configuration/pl_app_24.png,Supporte dInSuite,CS6
                12/18/2012 22:19:58.741 [INFO] com.adobe.exman.controller.gateway.Application ###Receive airParseXML Message:-12,airParseXML,/Applications/Adobe Premiere Pro CS5/Configuration/XManConfig.xml,Configuration.VariableForExMan.Data
                12/18/2012 22:19:58.742 [INFO] com.adobe.exman.controller.gateway.PassiveExternalGateway handleAirParseXML(), sessionId==-12got xml String to parse: /Applications/Adobe Premiere Pro CS5/Configuration/XManConfig.xml
                12/18/2012 22:19:58.742 [INFO] com.adobe.exman.controller.ParseXMLCommand execute(), ParseXMLCommand is executed.
                12/18/2012 22:19:58.742 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: file:///Applications/Adobe%20Premiere%20Pro%20CS5/Configuration/XManConfig.xml
                12/18/2012 22:19:58.742 [DEBUG] com.adobe.exman.business.XMLLoader XMLLoader(), XML file is XManConfig.xml file, just load it directly
                12/18/2012 22:19:58.742 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), try to load: file:///Applications/Adobe%20Premiere%20Pro%20CS5/Configuration/XManConfig.xml
                12/18/2012 22:19:58.757 [INFO] com.adobe.exman.controller.gateway.PassiveExternalGateway handleAirParseXML, success, externalCallBack,-12,0,ProductName,Premiere,DisplayName,Premiere Pro CS5,ProductVersion,5.0,HostNameForCSXS,PPRO,UserExtensionFolder,$SharedCommonDataFolder/A dobe/Premiere Pro CS5/Configuration/Extensions,EmStorePath,$SharedRibsDataFolder/Adobe/Extension Manager CS5/Premiere Pro CS5,IconPath,Configuration/pr_icon_24.png,SupportedInSuite,CS5,Bit,64
                12/18/2012 22:19:58.757 [DEBUG] com.adobe.exman.controller.gateway.ExternalGateway ###call2extensionMgr externalCallBack,-12,0,ProductName,Premiere,DisplayName,Premiere Pro CS5,ProductVersion,5.0,HostNameForCSXS,PPRO,UserExtensionFolder,$SharedCommonDataFolder/A dobe/Premiere Pro CS5/Configuration/Extensions,EmStorePath,$SharedRibsDataFolder/Adobe/Extension Manager CS5/Premiere Pro CS5,IconPath,Configuration/pr_icon_24.png,SupportedInSuite,CS5,Bit,64
                12/18/2012 22:19:58.762 [INFO] com.adobe.exman.controller.gateway.Application ###Receive airParseXML Message:-13,airParseXML,/Applications/Adobe Premiere Pro CS6/Configuration/XManConfig.xml,Configuration.VariableForExMan.Data
                12/18/2012 22:19:58.762 [INFO] com.adobe.exman.controller.gateway.PassiveExternalGateway handleAirParseXML(), sessionId==-13got xml String to parse: /Applications/Adobe Premiere Pro CS6/Configuration/XManConfig.xml
                12/18/2012 22:19:58.763 [INFO] com.adobe.exman.controller.ParseXMLCommand execute(), ParseXMLCommand is executed.
                12/18/2012 22:19:58.763 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: file:///Applications/Adobe%20Premiere%20Pro%20CS6/Configuration/XManConfig.xml
                12/18/2012 22:19:58.763 [DEBUG] com.adobe.exman.business.XMLLoader XMLLoader(), XML file is XManConfig.xml file, just load it directly
                12/18/2012 22:19:58.763 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), try to load: file:///Applications/Adobe%20Premiere%20Pro%20CS6/Configuration/XManConfig.xml
                12/18/2012 22:19:58.778 [INFO] com.adobe.exman.controller.gateway.PassiveExternalGateway handleAirParseXML, success, externalCallBack,-13,0,ProductName,Premiere,DisplayName,Premiere Pro CS6.0,ProductVersion,6.0,HostNameForCSXS,PPRO,IconPath,Configuration/pr_icon_24.png,Suppo rtedInSuite,CS6,Bit,64
                12/18/2012 22:19:58.778 [DEBUG] com.adobe.exman.controller.gateway.ExternalGateway ###call2extensionMgr externalCallBack,-13,0,ProductName,Premiere,DisplayName,Premiere Pro CS6.0,ProductVersion,6.0,HostNameForCSXS,PPRO,IconPath,Configuration/pr_icon_24.png,Suppo rtedInSuite,CS6,Bit,64
                12/18/2012 22:19:58.784 [INFO] com.adobe.exman.controller.gateway.Application ###Receive airParseXML Message:-14,airParseXML,/Applications/Adobe Dreamweaver CS5.5/Configuration/XManConfig.xml,Configuration.VariableForExMan.Data
                12/18/2012 22:19:58.784 [INFO] com.adobe.exman.controller.gateway.PassiveExternalGateway handleAirParseXML(), sessionId==-14got xml String to parse: /Applications/Adobe Dreamweaver CS5.5/Configuration/XManConfig.xml
                12/18/2012 22:19:58.785 [INFO] com.adobe.exman.controller.ParseXMLCommand execute(), ParseXMLCommand is executed.
                12/18/2012 22:19:58.785 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: file:///Applications/Adobe%20Dreamweaver%20CS5.5/Configuration/XManConfig.xml
                12/18/2012 22:19:58.785 [DEBUG] com.adobe.exman.business.XMLLoader XMLLoader(), XML file is XManConfig.xml file, just load it directly
                12/18/2012 22:19:58.785 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), try to load: file:///Applications/Adobe%20Dreamweaver%20CS5.5/Configuration/XManConfig.xml
                12/18/2012 22:19:58.798 [INFO] com.adobe.exman.controller.gateway.PassiveExternalGateway handleAirParseXML, success, externalCallBack,-14,0,$userextensionfolder,$userdatafolder/Adobe/Dreamweaver CS5.5/$LOCALE/Configuration/Extensions,$sharedextensionfolder,$shareddatafolder/Adobe/Dre amweaver CS5.5/$LOCALE/Configuration/Extensions,$dreamweaver,$installfolder,$dreamweaver/Configura tion,$userdatafolder/Adobe/Dreamweaver CS5.5/$LOCALE/Configuration,$UserBinfolder,$userdatafolder/Adobe/Dreamweaver CS5.5/$LOCALE,NeedOperationNotification,true,QuitScript,dw.quitApplication(),SupportedInS uite,CS5.5,HostNameForCSXS,DRWV,ProductVersion,11.5,Bit,32,DefaultLocale,en_US
                12/18/2012 22:19:58.798 [DEBUG] com.adobe.exman.controller.gateway.ExternalGateway ###call2extensionMgr externalCallBack,-14,0,$userextensionfolder,$userdatafolder/Adobe/Dreamweaver CS5.5/$LOCALE/Configuration/Extensions,$sharedextensionfolder,$shareddatafolder/Adobe/Dre amweaver CS5.5/$LOCALE/Configuration/Extensions,$dreamweaver,$installfolder,$dreamweaver/Configura tion,$userdatafolder/Adobe/Dreamweaver CS5.5/$LOCALE/Configuration,$UserBinfolder,$userdatafolder/Adobe/Dreamweaver CS5.5/$LOCALE,NeedOperationNotification,true,QuitScript,dw.quitApplication(),SupportedInS uite,CS5.5,HostNameForCSXS,DRWV,ProductVersion,11.5,Bit,32,DefaultLocale,en_US
                12/18/2012 22:19:58.811 [INFO] com.adobe.exman.controller.gateway.Application ###Receive airParseXML Message:-15,airParseXML,/Applications/Adobe Fireworks CS6/Configuration/XManConfig.xml,Configuration.VariableForExMan.Data
                12/18/2012 22:19:58.811 [INFO] com.adobe.exman.controller.gateway.PassiveExternalGateway handleAirParseXML(), sessionId==-15got xml String to parse: /Applications/Adobe Fireworks CS6/Configuration/XManConfig.xml
                12/18/2012 22:19:58.811 [INFO] com.adobe.exman.controller.ParseXMLCommand execute(), ParseXMLCommand is executed.
                12/18/2012 22:19:58.811 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: file:///Applications/Adobe%20Fireworks%20CS6/Configuration/XManConfig.xml
                12/18/2012 22:19:58.812 [DEBUG] com.adobe.exman.business.XMLLoader XMLLoader(), XML file is XManConfig.xml file, just load it directly
                12/18/2012 22:19:58.812 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), try to load: file:///Applications/Adobe%20Fireworks%20CS6/Configuration/XManConfig.xml
                12/18/2012 22:19:58.818 [INFO] com.adobe.exman.controller.gateway.PassiveExternalGateway handleAirParseXML, success, externalCallBack,-15,0,HostNameForCSXS,FWKS,ProductVersion,12.0,PreExtensionFolder,$Share dCommonDataFolder/Adobe/Fireworks CS6/PreInstall,$fireworks,$installfolder,$fireworksuser,$userdatafolder/adobe/Fireworks CS6,SupportedInSuite,CS6,Bit,32
                12/18/2012 22:19:58.818 [DEBUG] com.adobe.exman.controller.gateway.ExternalGateway ###call2extensionMgr externalCallBack,-15,0,HostNameForCSXS,FWKS,ProductVersion,12.0,PreExtensionFolder,$Share dCommonDataFolder/Adobe/Fireworks CS6/PreInstall,$fireworks,$installfolder,$fireworksuser,$userdatafolder/adobe/Fireworks CS6,SupportedInSuite,CS6,Bit,32
                12/18/2012 22:19:58.831 [INFO] com.adobe.exman.controller.gateway.Application ###Receive airParseXML Message:-16,airParseXML,/Applications/Adobe Flash CS6/XManConfig.xml,Configuration.VariableForExMan.Data
                12/18/2012 22:19:58.831 [INFO] com.adobe.exman.controller.gateway.PassiveExternalGateway handleAirParseXML(), sessionId==-16got xml String to parse: /Applications/Adobe Flash CS6/XManConfig.xml
                12/18/2012 22:19:58.831 [INFO] com.adobe.exman.controller.ParseXMLCommand execute(), ParseXMLCommand is executed.
                12/18/2012 22:19:58.832 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: file:///Applications/Adobe%20Flash%20CS6/XManConfig.xml
                12/18/2012 22:19:58.832 [DEBUG] com.adobe.exman.business.XMLLoader XMLLoader(), XML file is XManConfig.xml file, just load it directly
                12/18/2012 22:19:58.832 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), try to load: file:///Applications/Adobe%20Flash%20CS6/XManConfig.xml
                12/18/2012 22:19:58.838 [INFO] com.adobe.exman.controller.gateway.PassiveExternalGateway handleAirParseXML, success, externalCallBack,-16,0,$UserExtensionFolder,$UserDataFolder/Adobe/Flash CS6/$Locale/Configuration/Extensions,SupportedInSuite,CS6,HostNameForCSXS,FLPR,Bit,32,$Ro otFolder,$InstallFolder,$RootFolderLocal,$InstallFolder/$LOCALE,$flash,$userdatafolder/Ado be/Flash CS6/$LOCALE/Configuration,$UserBinfolder,$userdatafolder/Adobe/Flash CS6/$LOCALE/Configuration
                12/18/2012 22:19:58.839 [DEBUG] com.adobe.exman.controller.gateway.ExternalGateway ###call2extensionMgr externalCallBack,-16,0,$UserExtensionFolder,$UserDataFolder/Adobe/Flash CS6/$Locale/Configuration/Extensions,SupportedInSuite,CS6,HostNameForCSXS,FLPR,Bit,32,$Ro otFolder,$InstallFolder,$RootFolderLocal,$InstallFolder/$LOCALE,$flash,$userdatafolder/Ado be/Flash CS6/$LOCALE/Configuration,$UserBinfolder,$userdatafolder/Adobe/Flash CS6/$LOCALE/Configuration
                12/18/2012 22:19:58.850 [INFO] com.adobe.exman.controller.gateway.Application ###Receive airNotifyReady Message:-18,airNotifyReady
                12/18/2012 22:19:58.850 [INFO] com.adobe.exman.controller.gateway.PassiveExternalGateway handleAirNotifyReady(), sessionId=-18
                12/18/2012 22:19:58.851 [INFO] com.adobe.exman.model.SessionManagerProxy outputAllTheSessionId(), there are following sessions now: 1----
                12/18/2012 22:19:58.852 [INFO] com.adobe.exman.model.SessionManagerProxy outputAllTheSessionId(), there are following sessions now: 1----2----
                12/18/2012 22:19:58.852 [INFO] com.adobe.exman.model.SessionManagerProxy outputAllTheSessionId(), there are following sessions now: 1----2----3----
                12/18/2012 22:19:58.853 [INFO] com.adobe.exman.controller.gateway.ExternalGateway ###getExManConfigPath(), the params to OWL: sessionid=2
                12/18/2012 22:19:58.853 [DEBUG] com.adobe.exman.controller.gateway.ExternalGateway ###call2extensionMgr externalGetExManConfigPath,2
                12/18/2012 22:19:58.854 [INFO] com.adobe.exman.controller.gateway.ExternalGateway ###getSupportedProducts(), the params to OWL: sessionid=3
                12/18/2012 22:19:58.854 [DEBUG] com.adobe.exman.controller.gateway.ExternalGateway ###call2extensionMgr externalGetSupportedProducts,3
                12/18/2012 22:19:58.855 [INFO] com.adobe.exman.controller.gateway.Application ###Receive airCallBack Message2,0,/Library/Application Support/Adobe/Extension Manager CS6/EM Store,/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store,6.0.4.8,/Users/******/Library/Application Support/Adobe/Extension Manager CS5.5/Configuration/Extensions,file:///Library/Application Support/Adobe/Extension Manager CS6/,file:///Library/Application Support/Adobe/Extension Manager CS5.5/,/Applications
                12/18/2012 22:19:58.856 [INFO] com.adobe.exman.controller.gateway.ExternalGateway handleResponse(), parameters of handleResponse:
                sessionId= 2
                responseType= 0
                responseBody=/Library/Application Support/Adobe/Extension Manager CS6/EM Store,/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store,6.0.4.8,/Users/******/Library/Application Support/Adobe/Extension Manager CS5.5/Configuration/Extensions,file:///Library/Application Support/Adobe/Extension Manager CS6/,file:///Library/Application Support/Adobe/Extension Manager CS5.5/,/Applications
                12/18/2012 22:19:58.856 [INFO] com.adobe.exman.controller.session.backend.BackendSession com.adobe.exman.controller.session.backend::GetExManConfigPathSession got parameters in handleResponse:
                responseType= 0
                12/18/2012 22:19:58.856 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 0 :/Library/Application Support/Adobe/Extension Manager CS6/EM Store
                12/18/2012 22:19:58.856 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 1 :/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store
                12/18/2012 22:19:58.856 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 2 :6.0.4.8
                12/18/2012 22:19:58.857 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 3 :/Users/******/Library/Application Support/Adobe/Extension Manager CS5.5/Configuration/Extensions
                12/18/2012 22:19:58.857 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 4 :file:///Library/Application Support/Adobe/Extension Manager CS6/
                12/18/2012 22:19:58.857 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 5 :file:///Library/Application Support/Adobe/Extension Manager CS5.5/
                12/18/2012 22:19:58.857 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 6 :/Applications
                12/18/2012 22:19:58.858 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy totalExtDir(), the _totalExtDir is set to: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/
                12/18/2012 22:19:58.858 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy myEMStorePath(), the _myEMStorePath is set to: /Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/
                12/18/2012 22:19:58.858 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy the extension manager's version is set to: 6.0.4.8
                12/18/2012 22:19:58.859 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy the extension manager last version extension path is set to: /Users/******/Library/Application Support/Adobe/Extension Manager CS5.5/Configuration/Extensions/
                12/18/2012 22:19:58.859 [INFO] com.adobe.exman.model.SessionManagerProxy outputAllTheSessionId(), there are following sessions now: 1----3----
                12/18/2012 22:19:58.867 [INFO] com.adobe.exman.controller.gateway.Application ###Receive airCallBack Message3,0,0,Flash CS6,Flash,12.0.0,/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Flash CS6,/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Flash CS6,/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Flash CS6/,http://www.adobe.com/go/exchange,NoDefined,http://www.adobe.com/cfusion/exchange/upload/in dex.cfm,Flash,/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Flash CS6,/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Flash CS6,/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Flash CS6          ,0,0,FLPR,,,1,/Applications/Adobe Flash CS6,0,Fireworks CS6,Fireworks,12.0.0,/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Fireworks CS6,/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Fireworks CS6,/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Fireworks CS6/,http://www.adobe.com/go/exchange,NoDefined,http://www.adobe.com/cfusion/exchange/upload/in dex.cfm,Fireworks,/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Fireworks CS6,/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Fireworks CS6,/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Fireworks CS6          ,0,0,FWKS,,,1,/Applications/Adobe Fireworks CS6/Configuration,0,Premiere Pro CS6.0,Premiere,6.0.0,/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Premiere Pro CS6.0,/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Premiere Pro CS6.0,/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Premiere Pro CS6.0/,http://www.adobe.com/go/exchange,/Applications/Adobe Premiere Pro CS6/Configuration/pr_icon_24.png,http://www.adobe.com/cfusion/exchange/upload/index.cfm,,/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Premiere Pro CS6.0,/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Premiere Pro CS6.0,/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Premiere Pro CS6.0          ,0,0,PPRO,,,2,/Applications/Adobe Premiere Pro CS6/Configuration,0,Prelude CS6,Prelude,6.0.0,/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Prelude CS6,/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Prelude CS6,/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Prelude CS6/,http://www.adobe.com/go/exchange,/Applications/Adobe Prelude CS6/Configuration/pl_app_24.png,http://www.adobe.com/cfusion/exchange/upload/index.cfm,,/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Prelude CS6,/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Prelude CS6,/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Prelude CS6          ,0,0,PRLD,,,0,/Applications/Adobe Prelude CS6/Configuration,0,InDesign CS6,InDesign,8.0.0,/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6,/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6,/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/,http://www.adobe.com/go/exchange,/Applications/Adobe InDesign CS6/Configuration/Icon.png,http://www.adobe.com/cfusion/exchange/upload/index.cfm,,/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6,/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6,/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6          ,1,1,IDSN,/Users/******/Library/Preferences/Adobe InDesign/Version 8.0/en_US/PlugInConfig.txt,Adobe InDesign CS6,1,/Applications/Adobe InDesign CS6/Configuration
                12/18/2012 22:19:58.868 [INFO] com.adobe.exman.controller.gateway.ExternalGateway handleResponse(), parameters of handleResponse:
                sessionId= 3
                responseType= 0
                responseBody=0,Flash CS6,Flash,12.0.0,/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Flash CS6,/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Flash CS6,/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Flash CS6/,http://www.adobe.com/go/exchange,NoDefined,http://www.adobe.com/cfusion/exchange/upload/in dex.cfm,Flash,/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Flash CS6,/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Flash CS6,/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Flash CS6          ,0,0,FLPR,,,1,/Applications/Adobe Flash CS6,0,Fireworks CS6,Fireworks,12.0.0,/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Fireworks CS6,/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Fireworks CS6,/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Fireworks CS6/,http://www.adobe.com/go/exchange,NoDefined,http://www.adobe.com/cfusion/exchange/upload/in dex.cfm,Fireworks,/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Fireworks CS6,/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Fireworks CS6,/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Fireworks CS6          ,0,0,FWKS,,,1,/Applications/Adobe Fireworks CS6/Configuration,0,Premiere Pro CS6.0,Premiere,6.0.0,/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Premiere Pro CS6.0,/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Premiere Pro CS6.0,/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Premiere Pro CS6.0/,http://www.adobe.com/go/exchange,/Applications/Adobe Premiere Pro CS6/Configuration/pr_icon_24.png,http://www.adobe.com/cfusion/exchange/upload/index.cfm,,/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Premiere Pro CS6.0,/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Premiere Pro CS6.0,/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Premiere Pro CS6.0          ,0,0,PPRO,,,2,/Applications/Adobe Premiere Pro CS6/Configuration,0,Prelude CS6,Prelude,6.0.0,/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Prelude CS6,/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Prelude CS6,/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Prelude CS6/,http://www.adobe.com/go/exchange,/Applications/Adobe Prelude CS6/Configuration/pl_app_24.png,http://www.adobe.com/cfusion/exchange/upload/index.cfm,,/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Prelude CS6,/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Prelude CS6,/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Prelude CS6          ,0,0,PRLD,,,0,/Applications/Adobe Prelude CS6/Configuration,0,InDesign CS6,InDesign,8.0.0,/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6,/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6,/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/,http://www.adobe.com/go/exchange,/Applications/Adobe InDesign CS6/Configuration/Icon.png,http://www.adobe.com/cfusion/exchange/upload/index.cfm,,/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6,/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6,/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6          ,1,1,IDSN,/Users/******/Library/Preferences/Adobe InDesign/Version 8.0/en_US/PlugInConfig.txt,Adobe InDesign CS6,1,/Applications/Adobe InDesign CS6/Configuration
                12/18/2012 22:19:58.868 [INFO] com.adobe.exman.controller.session.backend.BackendSession com.adobe.exman.controller.session.backend::GetSupportedProductsSession got parameters in handleResponse:
                responseType= 0
                12/18/2012 22:19:58.868 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 0
                12/18/2012 22:19:58.868 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 1 :Flash CS6
                12/18/2012 22:19:58.868 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 2 :Flash
                12/18/2012 22:19:58.869 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 3 :12.0.0
                12/18/2012 22:19:58.869 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 4 :/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Flash CS6
                12/18/2012 22:19:58.869 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 5 :/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Flash CS6
                12/18/2012 22:19:58.869 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 6 :/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Flash CS6/
                12/18/2012 22:19:58.869 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 7 :http://www.adobe.com/go/exchange
                12/18/2012 22:19:58.870 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 8 :NoDefined
                12/18/2012 22:19:58.870 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 9 :http://www.adobe.com/cfusion/exchange/upload/index.cfm
                12/18/2012 22:19:58.870 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 10 :Flash
                12/18/2012 22:19:58.870 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 11 :/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Flash CS6
                12/18/2012 22:19:58.870 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 12 :/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Flash CS6
                12/18/2012 22:19:58.870 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 13 :/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Flash CS6
                12/18/2012 22:19:58.871 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 14
                12/18/2012 22:19:58.871 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 15
                12/18/2012 22:19:58.871 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 16 :FLPR
                12/18/2012 22:19:58.871 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 17 :
                12/18/2012 22:19:58.872 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 18 :
                12/18/2012 22:19:58.872 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 19 :1
                12/18/2012 22:19:58.872 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 20 :/Applications/Adobe Flash CS6
                12/18/2012 22:19:58.872 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 21
                12/18/2012 22:19:58.872 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 22 :Fireworks CS6
                12/18/2012 22:19:58.872 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 23 :Fireworks
                12/18/2012 22:19:58.873 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 24 :12.0.0
                12/18/2012 22:19:58.873 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 25 :/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Fireworks CS6
                12/18/2012 22:19:58.873 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 26 :/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Fireworks CS6
                12/18/2012 22:19:58.873 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 27 :/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Fireworks CS6/
                12/18/2012 22:19:58.873 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 28 :http://www.adobe.com/go/exchange
                12/18/2012 22:19:58.873 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 29 :NoDefined
                12/18/2012 22:19:58.874 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 30 :http://www.adobe.com/cfusion/exchange/upload/index.cfm
                12/18/2012 22:19:58.874 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 31 :Fireworks
                12/18/2012 22:19:58.874 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 32 :/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Fireworks CS6
                12/18/2012 22:19:58.874 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 33 :/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Fireworks CS6
                12/18/2012 22:19:58.874 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 34 :/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Fireworks CS6
                12/18/2012 22:19:58.874 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 35
                12/18/2012 22:19:58.875 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 36
                12/18/2012 22:19:58.875 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 37 :FWKS
                12/18/2012 22:19:58.875 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 38 :
                12/18/2012 22:19:58.875 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 39 :
                12/18/2012 22:19:58.875 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 40 :1
                12/18/2012 22:19:58.876 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 41 :/Applications/Adobe Fireworks CS6/Configuration
                12/18/2012 22:19:58.876 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 42
                12/18/2012 22:19:58.876 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 43 :Premiere Pro CS6.0
                12/18/2012 22:19:58.876 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 44 :Premiere
                12/18/2012 22:19:58.876 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 45 :6.0.0
                12/18/2012 22:19:58.876 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 46 :/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Premiere Pro CS6.0
                12/18/2012 22:19:58.877 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 47 :/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Premiere Pro CS6.0
                12/18/2012 22:19:58.877 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 48 :/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Premiere Pro CS6.0/
                12/18/2012 22:19:58.877 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 49 :http://www.adobe.com/go/exchange
                12/18/2012 22:19:58.877 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 50 :/Applications/Adobe Premiere Pro CS6/Configuration/pr_icon_24.png
                12/18/2012 22:19:58.877 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 51 :http://www.adobe.com/cfusion/exchange/upload/index.cfm
                12/18/2012 22:19:58.877 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 52 :
                12/18/2012 22:19:58.878 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 53 :/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Premiere Pro CS6.0
                12/18/2012 22:19:58.878 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 54 :/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Premiere Pro CS6.0
                12/18/2012 22:19:58.878 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 55 :/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Premiere Pro CS6.0
                12/18/2012 22:19:58.878 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 56
                12/18/2012 22:19:58.878 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 57
                12/18/2012 22:19:58.879 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 58 :PPRO
                12/18/2012 22:19:58.879 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 59 :
                12/18/2012 22:19:58.879 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 60 :
                12/18/2012 22:19:58.879 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 61 :2
                12/18/2012 22:19:58.879 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 62 :/Applications/Adobe Premiere Pro CS6/Configuration
                12/18/2012 22:19:58.879 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 63
                12/18/2012 22:19:58.880 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 64 :Prelude CS6
                12/18/2012 22:19:58.880 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 65 :Prelude
                12/18/2012 22:19:58.880 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 66 :6.0.0
                12/18/2012 22:19:58.880 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 67 :/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Prelude CS6
                12/18/2012 22:19:58.881 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 68 :/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Prelude CS6
                12/18/2012 22:19:58.881 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 69 :/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Prelude CS6/
                12/18/2012 22:19:58.881 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 70 :http://www.adobe.com/go/exchange
                12/18/2012 22:19:58.881 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 71 :/Applications/Adobe Prelude CS6/Configuration/pl_app_24.png
                12/18/2012 22:19:58.881 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 72 :http://www.adobe.com/cfusion/exchange/upload/index.cfm
                12/18/2012 22:19:58.881 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 73 :
                12/18/2012 22:19:58.882 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 74 :/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Prelude CS6
                12/18/2012 22:19:58.882 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 75 :/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Prelude CS6
                12/18/2012 22:19:58.882 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 76 :/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Prelude CS6
                12/18/2012 22:19:58.882 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 77
                12/18/2012 22:19:58.882 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 78
                12/18/2012 22:19:58.883 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 79 :PRLD
                12/18/2012 22:19:58.883 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 80 :
                12/18/2012 22:19:58.883 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 81 :
                12/18/2012 22:19:58.883 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 82
                12/18/2012 22:19:58.883 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 83 :/Applications/Adobe Prelude CS6/Configuration
                12/18/2012 22:19:58.883 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 84
                12/18/2012 22:19:58.884 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 85 :InDesign CS6
                12/18/2012 22:19:58.884 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 86 :InDesign
                12/18/2012 22:19:58.884 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 87 :8.0.0
                12/18/2012 22:19:58.884 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 88 :/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6
                12/18/2012 22:19:58.884 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 89 :/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6
                12/18/2012 22:19:58.884 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 90 :/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/
                12/18/2012 22:19:58.885 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 91 :http://www.adobe.com/go/exchange
                12/18/2012 22:19:58.885 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 92 :/Applications/Adobe InDesign CS6/Configuration/Icon.png
                12/18/2012 22:19:58.885 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 93 :http://www.adobe.com/cfusion/exchange/upload/index.cfm
                12/18/2012 22:19:58.885 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 94 :
                12/18/2012 22:19:58.885 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 95 :/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6
                12/18/2012 22:19:58.885 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 96 :/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6
                12/18/2012 22:19:58.886 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 97 :/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6
                12/18/2012 22:19:58.886 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 98 :1
                12/18/2012 22:19:58.886 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 99 :1
                12/18/2012 22:19:58.886 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 100 :IDSN
                12/18/2012 22:19:58.886 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 101 :/Users/******/Library/Preferences/Adobe InDesign/Version 8.0/en_US/PlugInConfig.txt
                12/18/2012 22:19:58.886 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 102 :Adobe InDesign CS6
                12/18/2012 22:19:58.887 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 103 :1
                12/18/2012 22:19:58.887 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 104 :/Applications/Adobe InDesign CS6/Configuration
                12/18/2012 22:19:58.889 [INFO] com.adobe.exman.vo.ProductInfo productMachineEMStorePath(), product name: Flash CS6, EM store path set to: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/Flash CS6/
                12/18/2012 22:19:58.889 [INFO] com.adobe.exman.vo.ProductInfo productMyEMStorePath(), product name: Flash CS6, EM store path set to: /Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Flash CS6/
                12/18/2012 22:19:58.889 [INFO] com.adobe.exman.vo.ProductInfo productMachineEMStorePath(), product name: Fireworks CS6, EM store path set to: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/Fireworks CS6/
                12/18/2012 22:19:58.890 [INFO] com.adobe.exman.vo.ProductInfo productMyEMStorePath(), product name: Fireworks CS6, EM store path set to: /Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Fireworks CS6/
                12/18/2012 22:19:58.890 [INFO] com.adobe.exman.vo.ProductInfo ProductInfo(), icon path /Applications/Adobe Premiere Pro CS6/Configuration/pr_icon_24.png
                12/18/2012 22:19:58.890 [INFO] com.adobe.exman.vo.ProductInfo productMachineEMStorePath(), product name: Premiere Pro CS6.0, EM store path set to: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/Premiere Pro CS6.0/
                12/18/2012 22:19:58.891 [INFO] com.adobe.exman.vo.ProductInfo productMyEMStorePath(), product name: Premiere Pro CS6.0, EM store path set to: /Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Premiere Pro CS6.0/
                12/18/2012 22:19:58.891 [INFO] com.adobe.exman.vo.ProductInfo ProductInfo(), icon path /Applications/Adobe Prelude CS6/Configuration/pl_app_24.png
                12/18/2012 22:19:58.891 [INFO] com.adobe.exman.vo.ProductInfo productMachineEMStorePath(), product name: Prelude CS6, EM store path set to: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/Prelude CS6/
                12/18/2012 22:19:58.891 [INFO] com.adobe.exman.vo.ProductInfo productMyEMStorePath(), product name: Prelude CS6, EM store path set to: /Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Prelude CS6/
                12/18/2012 22:19:58.891 [INFO] com.adobe.exman.vo.ProductInfo ProductInfo(), icon path /Applications/Adobe InDesign CS6/Configuration/Icon.png
                12/18/2012 22:19:58.892 [INFO] com.adobe.exman.vo.ProductInfo productMachineEMStorePath(), product name: InDesign CS6, EM store path set to: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/
                12/18/2012 22:19:58.892 [INFO] com.adobe.exman.vo.ProductInfo productMyEMStorePath(), product name: InDesign CS6, EM store path set to: /Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/
                12/18/2012 22:19:58.894 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper: ctor...
                12/18/2012 22:19:58.895 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper: open public db conn...
                12/18/2012 22:19:58.896 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper: attach user db conn...
                12/18/2012 22:19:58.900 [DEBUG] com.adobe.exman.view.ExManApp @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
                12/18/2012 22:19:58.900 [DEBUG] com.adobe.exman.view.ExManApp NOTIF_APPLICATION_STARTUP_SUCCEED
                12/18/2012 22:19:58.901 [INFO] com.adobe.exman.controller.MigratePreferredExtensionCommand execute(), MigratePreferredExtensionCommand
                12/18/2012 22:19:58.901 [INFO] com.adobe.exman.model.SessionManagerProxy outputAllTheSessionId(), there are following sessions now: 1----3----4----
                12/18/2012 22:19:58.902 [INFO] com.adobe.exman.model.SessionManagerProxy outputAllTheSessionId(), there are following sessions now: 1----3----4----5----
                12/18/2012 22:19:58.902 [INFO] com.adobe.exman.controller.session.frontend.FrontendMigratePreferredExtensionSession initiate()
                12/18/2012 22:19:58.903 [INFO] com.adobe.exman.model.SessionManagerProxy outputAllTheSessionId(), there are following sessions now: 1----3----4----
                12/18/2012 22:19:58.903 [INFO] com.adobe.exman.view.ExManApp handleNotification(), got notification: NOTIF_ACTION_BEGIN
                notification body: [object ActionBeginParameter]
                12/18/2012 22:19:58.903 [DEBUG] com.adobe.exman.view.ExManApp @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
                12/18/2012 22:19:58.904 [DEBUG] com.adobe.exman.view.ExManApp NOTIF_ACTION_BEGIN
                12/18/2012 22:19:58.904 [INFO] com.adobe.exman.model.CommandLineRequestProxy canExecuteCommandLineRequest, set value to: false
                12/18/2012 22:19:58.905 [INFO] com.adobe.exman.ExManGUI enableApp(), set value to: false
                12/18/2012 22:19:58.906 [INFO] com.adobe.exman.ExManGUI canAcceptUIInput(), set to: false
                12/18/2012 22:19:58.906 [INFO] com.adobe.exman.controller.AppWinOperationCommand execute(), AppWinOperationCommand is executed. notification=APPWIN_MODALDIALOG_POPUP
                12/18/2012 22:19:58.907 [INFO] com.adobe.exman.controller.gateway.ExternalGateway ###appWinOperate(), sessionId: 6, opCode=10, mouseX=0, mouseY=0
                12/18/2012 22:19:58.907 [INFO] com.adobe.exman.controller.MigratePreferredExtensionSession. MigratePreferredExtensionSession. initiate ()
                12/18/2012 22:19:58.907 [INFO] com.adobe.exman.controller.NotifyOperationBeginEndCommand execute(), NotifyOperationBeginEndCommand is executed.
                12/18/2012 22:19:58.908 [DEBUG] com.adobe.exman.controller.gateway.ExternalGateway ###call2extensionMgr airNotifyOperationBeginOrEnd,7,preinstall,1,0
                12/18/2012 22:19:58.908 [INFO] com.adobe.exman.controller.gateway.ExternalGateway migratePreferredExtension(), the params to external install: sessionid=4
                12/18/2012 22:19:58.908 [DEBUG] com.adobe.exman.controller.gateway.ExternalGateway ###call2extensionMgr externalMigratePreferredExtension,4
                12/18/2012 22:19:58.909 [INFO] com.adobe.exman.model.SessionManagerProxy outputAllTheSessionId(), there are following sessions now: 3----4----
                12/18/2012 22:19:58.909 [INFO] com.adobe.exman.model.SessionManagerProxy outputAllTheSessionId(), there are following sessions now: 4----
                12/18/2012 22:19:58.922 [INFO] com.adobe.exman.controller.gateway.Application ###Receive airCallBack Message4,0
                12/18/2012 22:19:58.922 [INFO] com.adobe.exman.controller.gateway.ExternalGateway handleResponse(), parameters of handleResponse:
                sessionId= 4
                responseType= 0
                responseBody=
                12/18/2012 22:19:58.923 [INFO] com.adobe.exman.controller.session.backend.BackendSession com.adobe.exman.controller.session.backend::MigratePreferredExtensionSession got parameters in handleResponse:
                responseType= 0
                12/18/2012 22:19:58.923 [INFO] com.adobe.exman.controller.MigratePreferredExtensionSession. MigratePreferredExtensionSession. specificHandleSuccess ()
                12/18/2012 22:19:58.923 [INFO] com.adobe.exman.controller.NotifyOperationBeginEndCommand execute(), NotifyOperationBeginEndCommand is executed.
                12/18/2012 22:19:58.923 [DEBUG] com.adobe.exman.controller.gateway.ExternalGateway ###call2extensionMgr airNotifyOperationBeginOrEnd,8,preinstall,0,0
                12/18/2012 22:19:58.924 [DEBUG] com.adobe.exman.view.ExManApp @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
                12/18/2012 22:19:58.924 [DEBUG] com.adobe.exman.view.ExManApp NOTIF_MIGRATE_PREFERRED_EXTENSION_COMPLETE
                12/18/2012 22:19:58.925 [INFO] com.adobe.exman.controller.GetLastVersionPointProductsCommand execute(), GetLastVersionPointProductsCommand
                12/18/2012 22:19:58.926 [INFO] com.adobe.exman.model.SessionManagerProxy outputAllTheSessionId(), there are following sessions now: 4----9----
                12/18/2012 22:19:58.926 [INFO] com.adobe.exman.model.SessionManagerProxy outputAllTheSessionId(), there are following sessions now: 4----9----10----
                12/18/2012 22:19:58.927 [INFO] com.adobe.exman.controller.session.frontend.FrontendGetLastVersionPointProductsSession initiate()
                12/18/2012 22:19:58.927 [INFO] com.adobe.exman.model.SessionManagerProxy outputAllTheSessionId(), there are following sessions now: 4----9----
                12/18/2012 22:19:58.927 [INFO] com.adobe.exman.view.ExManApp handleNotification(), got notification: NOTIF_ACTION_BEGIN
                12/18/2012 22:19:58.927 [DEBUG] com.adobe.exman.view.ExManApp @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
                12/18/2012 22:19:58.927 [DEBUG] com.adobe.exman.view.ExManApp NOTIF_ACTION_BEGIN
                12/18/2012 22:19:58.928 [INFO] com.adobe.exman.model.CommandLineRequestProxy canExecuteCommandLineRequest, set value to: false
                12/18/2012 22:19:58.928 [DEBUG] com.adobe.exman.ExManGUI onActionBegin(), unknown action name: GET_LAST_VERSION_PRODUCTS
                12/18/2012 22:19:58.928 [INFO] com.adobe.exman.ExManGUI enableApp(), set value to: false
                12/18/2012 22:19:58.928 [INFO] com.adobe.exman.ExManGUI canAcceptUIInput(), set to: false
                12/18/2012 22:19:58.928 [INFO] com.adobe.exman.controller.AppWinOperationCommand execute(), AppWinOperationCommand is executed. notification=APPWIN_MODALDIALOG_POPUP
                12/18/2012 22:19:58.929 [INFO] com.adobe.exman.controller.gateway.ExternalGateway ###appWinOperate(), sessionId: 11, opCode=10, mouseX=0, mouseY=0
                12/18/2012 22:19:58.929 [INFO] com.adobe.exman.controller.session.backend.GetLastVersionPointProductsSession. GetLastVersionPointProductsSession. initiate ()
                12/18/2012 22:19:58.929 [INFO] com.adobe.exman.controller.gateway.ExternalGateway getLastVersionPointProducts(), the params to external install: sessionid=9
                12/18/2012 22:19:58.929 [DEBUG] com.adobe.exman.controller.gateway.ExternalGateway ###call2extensionMgr externalGetLastVersionPointProducts,9
                12/18/2012 22:19:58.930 [INFO] com.adobe.exman.model.SessionManagerProxy outputAllTheSessionId(), there are following sessions now: 9----
                12/18/2012 22:19:58.931 [INFO] com.adobe.exman.controller.gateway.Application ###Receive airCallBack Message9,0,Dreamweaver CS5.5,Dreamweaver,11.5.0,/Users/******/Library/Application Support/Adobe/Extension Manager CS5.5/Configuration/Extensions,,-1
                12/18/2012 22:19:58.931 [INFO] com.adobe.exman.controller.gateway.ExternalGateway handleResponse(), parameters of handleResponse:
                sessionId= 9
                responseType= 0
                responseBody=Dreamweaver CS5.5,Dreamweaver,11.5.0,/Users/******/Library/Application Support/Adobe/Extension Manager CS5.5/Configuration/Extensions,,-1
                12/18/2012 22:19:58.931 [INFO] com.adobe.exman.controller.session.backend.BackendSession com.adobe.exman.controller.session.backend::GetLastVersionPointProductsSession got parameters in handleResponse:
                responseType= 0
                12/18/2012 22:19:58.931 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 0 :Dreamweaver CS5.5
                12/18/2012 22:19:58.931 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 1 :Dreamweaver
                12/18/2012 22:19:58.932 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 2 :11.5.0
                12/18/2012 22:19:58.932 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 3 :/Users/******/Library/Application Support/Adobe/Extension Manager CS5.5/Configuration/Extensions
                12/18/2012 22:19:58.932 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 4 :
                12/18/2012 22:19:58.932 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 5 :-1
                12/18/2012 22:19:58.933 [INFO] com.adobe.exman.controller.session.backend.GetLastVersionPointProductsSession. GetLastVersionPointProductsSession. specificHandleSuccess ()
                12/18/2012 22:19:58.933 [INFO] com.adobe.exman.vo.ProductInfo productMachineEMStorePath(), product name: Dreamweaver CS5.5, EM store path set to: /Users/******/Library/Application Support/Adobe/Extension Manager CS5.5/Configuration/Extensions/
                12/18/2012 22:19:58.933 [INFO] com.adobe.exman.vo.ProductInfo productMyEMStorePath(), product name: Dreamweaver CS5.5, EM store path set to: /Users/******/Library/Application Support/Adobe/Extension Manager CS5.5/Configuration/Extensions/
                12/18/2012 22:19:58.933 [ERROR] com.adobe.exman.vo.ProductInfo XManConfigFolder length is 0, return directly
                12/18/2012 22:19:58.934 [DEBUG] com.adobe.exman.view.ExManApp @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
                12/18/2012 22:19:58.934 [DEBUG] com.adobe.exman.view.ExManApp END_GET_LAST_VERSION_POINT_PRODUCTS
                12/18/2012 22:19:58.935 [INFO] com.adobe.exman.model.MigrationExtensionsProxy MigrateExtensionsProxy(), _already_Migrated_Flag_File: /Users/******/Library/Preferences/Adobe/Extension Manager CS6/Migrated.YES
                12/18/2012 22:19:58.935 [INFO] com.adobe.exman.model.MigrationExtensionsProxy MigrateExtensionsProxy(), _never_Migrated_Flag_File: /Users/******/Library/Preferences/Adobe/Extension Manager CS6/Migrated.NEVER
                12/18/2012 22:19:58.935 [INFO] com.adobe.exman.model.MigrationExtensionsProxy needToMigrateExtensions(), don't need to immigrate extensions.
                12/18/2012 22:19:58.936 [INFO] com.adobe.exman.controller.RequestLoadExtensionCommand execute(), RequestLoadExtensionCommand
                12/18/2012 22:19:58.936 [INFO] com.adobe.exman.model.SessionManagerProxy outputAllTheSessionId(), there are following sessions now: 9----12----
                12/18/2012 22:19:58.937 [INFO] com.adobe.exman.model.SessionManagerProxy outputAllTheSessionId(), there are following sessions now: 9----12----
                12/18/2012 22:19:58.937 [INFO] com.adobe.exman.model.SessionManagerProxy outputAllTheSessionId(), there are following sessions now: 9----12----13----
                12/18/2012 22:19:58.937 [INFO] com.adobe.exman.controller.session.frontend.FrontendRequestLoadExtensionSession initiate()
                12/18/2012 22:19:58.937 [INFO] com.adobe.exman.view.ExManApp handleNotification(), got notification: NOTIF_ACTION_BEGIN
                12/18/2012 22:19:58.938 [DEBUG] com.adobe.exman.view.ExManApp @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
                12/18/2012 22:19:58.938 [DEBUG] com.adobe.exman.view.ExManApp NOTIF_ACTION_BEGIN
                12/18/2012 22:19:58.938 [INFO] com.adobe.exman.model.CommandLineRequestProxy canExecuteCommandLineRequest, set value to: false
                12/18/2012 22:19:58.938 [INFO] com.adobe.exman.ExManGUI enableApp(), set value to: false
                12/18/2012 22:19:58.938 [INFO] com.adobe.exman.ExManGUI canAcceptUIInput(), set to: false
                12/18/2012 22:19:58.939 [INFO] com.adobe.exman.controller.AppWinOperationCommand execute(), AppWinOperationCommand is executed. notification=APPWIN_MODALDIALOG_POPUP
                12/18/2012 22:19:58.939 [INFO] com.adobe.exman.controller.gateway.ExternalGateway ###appWinOperate(), sessionId: 14, opCode=10, mouseX=0, mouseY=0
                12/18/2012 22:19:58.939 [INFO] com.adobe.exman.controller.RequestLoadExtensionSession. MigratePreferredExtensionSession. initiate ()
                12/18/2012 22:19:58.939 [INFO] com.adobe.exman.controller.gateway.ExternalGateway requestToLoadExtension(), the params to external install: sessionid=12
                12/18/2012 22:19:58.940 [DEBUG] com.adobe.exman.controller.gateway.ExternalGateway ###call2extensionMgr externalLoadExtension,12
                12/18/2012 22:19:58.940 [INFO] com.adobe.exman.model.SessionManagerProxy outputAllTheSessionId(), there are following sessions now: 12----
                12/18/2012 22:19:59.014 [INFO] com.adobe.exman.controller.gateway.Application ###Receive airCallBack Message12,9,1
                12/18/2012 22:19:59.014 [INFO] com.adobe.exman.controller.gateway.ExternalGateway handleResponse(), parameters of handleResponse:
                sessionId= 12
                responseType= 9
                responseBody=1
                12/18/2012 22:19:59.014 [INFO] com.adobe.exman.controller.session.backend.BackendSession com.adobe.exman.controller.session.backend::RequestLoadExtensionSession got parameters in handleResponse:
                responseType= 9
                12/18/2012 22:19:59.014 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 0 :1
                12/18/2012 22:19:59.015 [INFO] com.adobe.exman.view.ExManApp handleNotification(), got notification: NOTIF_PROGRESS
                notification body: 1
                12/18/2012 22:19:59.015 [DEBUG] com.adobe.exman.view.ExManApp @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
                12/18/2012 22:19:59.015 [DEBUG] com.adobe.exman.view.ExManApp NOTIF_PROGRESS
                12/18/2012 22:19:59.015 [INFO] com.adobe.exman.view.ExManApp app got progress: 1
                12/18/2012 22:19:59.029 [INFO] com.adobe.exman.controller.gateway.Application ###Receive airCallBack Message12,9,2
                12/18/2012 22:19:59.029 [INFO] com.adobe.exman.controller.gateway.ExternalGateway handleResponse(), parameters of handleResponse:
                sessionId= 12
                responseType= 9
                responseBody=2
                12/18/2012 22:19:59.029 [INFO] com.adobe.exman.controller.session.backend.BackendSession com.adobe.exman.controller.session.backend::RequestLoadExtensionSession got parameters in handleResponse:
                responseType= 9
                12/18/2012 22:19:59.029 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 0 :2
                12/18/2012 22:19:59.029 [INFO] com.adobe.exman.view.ExManApp handleNotification(), got notification: NOTIF_PROGRESS
                notification body: 2
                12/18/2012 22:19:59.030 [DEBUG] com.adobe.exman.view.ExManApp @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
                12/18/2012 22:19:59.030 [DEBUG] com.adobe.exman.view.ExManApp NOTIF_PROGRESS
                12/18/2012 22:19:59.030 [INFO] com.adobe.exman.view.ExManApp app got progress: 2
                12/18/2012 22:19:59.047 [INFO] com.adobe.exman.controller.gateway.Application ###Receive airCallBack Message12,9,3
                12/18/2012 22:19:59.047 [INFO] com.adobe.exman.controller.gateway.ExternalGateway handleResponse(), parameters of handleResponse:
                sessionId= 12
                responseType= 9
                responseBody=3
                12/18/2012 22:19:59.047 [INFO] com.adobe.exman.controller.session.backend.BackendSession com.adobe.exman.controller.session.backend::RequestLoadExtensionSession got parameters in handleResponse:
                responseType= 9
                12/18/2012 22:19:59.047 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 0 :3
                12/18/2012 22:19:59.047 [INFO] com.adobe.exman.view.ExManApp handleNotification(), got notification: NOTIF_PROGRESS
                notification body: 3
                12/18/2012 22:19:59.048 [DEBUG] com.adobe.exman.view.ExManApp @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
                12/18/2012 22:19:59.048 [DEBUG] com.adobe.exman.view.ExManApp NOTIF_PROGRESS
                12/18/2012 22:19:59.048 [INFO] com.adobe.exman.view.ExManApp app got progress: 3
                12/18/2012 22:19:59.056 [INFO] com.adobe.exman.controller.gateway.Application ###Receive airCallBack Message12,9,4
                12/18/2012 22:19:59.057 [INFO] com.adobe.exman.controller.gateway.ExternalGateway handleResponse(), parameters of handleResponse:
                sessionId= 12
                responseType= 9
                responseBody=4
                12/18/2012 22:19:59.057 [INFO] com.adobe.exman.controller.session.backend.BackendSession com.adobe.exman.controller.session.backend::RequestLoadExtensionSession got parameters in handleResponse:
                responseType= 9
                12/18/2012 22:19:59.057 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 0 :4
                12/18/2012 22:19:59.057 [INFO] com.adobe.exman.view.ExManApp handleNotification(), got notification: NOTIF_PROGRESS
                notification body: 4
                12/18/2012 22:19:59.057 [DEBUG] com.adobe.exman.view.ExManApp @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
                12/18/2012 22:19:59.058 [DEBUG] com.adobe.exman.view.ExManApp NOTIF_PROGRESS
                12/18/2012 22:19:59.058 [INFO] com.adobe.exman.view.ExManApp app got progress: 4
                12/18/2012 22:19:59.072 [INFO] com.adobe.exman.controller.gateway.Application ###Receive airCallBack Message12,9,5
                12/18/2012 22:19:59.072 [INFO] com.adobe.exman.controller.gateway.ExternalGateway handleResponse(), parameters of handleResponse:
                sessionId= 12
                responseType= 9
                responseBody=5
                12/18/2012 22:19:59.072 [INFO] com.adobe.exman.controller.session.backend.BackendSession com.adobe.exman.controller.session.backend::RequestLoadExtensionSession got parameters in handleResponse:
                responseType= 9
                12/18/2012 22:19:59.073 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 0 :5
                12/18/2012 22:19:59.073 [INFO] com.adobe.exman.view.ExManApp handleNotification(), got notification: NOTIF_PROGRESS
                notification body: 5
                12/18/2012 22:19:59.073 [DEBUG] com.adobe.exman.view.ExManApp @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
                12/18/2012 22:19:59.073 [DEBUG] com.adobe.exman.view.ExManApp NOTIF_PROGRESS
                12/18/2012 22:19:59.073 [INFO] com.adobe.exman.view.ExManApp app got progress: 5
                12/18/2012 22:19:59.100 [INFO] com.adobe.exman.controller.gateway.Application ###Receive airCallBack Message12,9,6
                12/18/2012 22:19:59.100 [INFO] com.adobe.exman.controller.gateway.ExternalGateway handleResponse(), parameters of handleResponse:
                sessionId= 12
                responseType= 9
                responseBody=6
                12/18/2012 22:19:59.100 [INFO] com.adobe.exman.controller.session.backend.BackendSession com.adobe.exman.controller.session.backend::RequestLoadExtensionSession got parameters in handleResponse:
                responseType= 9
                12/18/2012 22:19:59.101 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 0 :6
                12/18/2012 22:19:59.101 [INFO] com.adobe.exman.view.ExManApp handleNotification(), got notification: NOTIF_PROGRESS
                notification body: 6
                12/18/2012 22:19:59.101 [DEBUG] com.adobe.exman.view.ExManApp @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
                12/18/2012 22:19:59.101 [DEBUG] com.adobe.exman.view.ExManApp NOTIF_PROGRESS
                12/18/2012 22:19:59.101 [INFO] com.adobe.exman.view.ExManApp app got progress: 6
                12/18/2012 22:19:59.107 [INFO] com.adobe.exman.controller.gateway.Application ###Receive airCallBack Message12,9,7
                12/18/2012 22:19:59.107 [INFO] com.adobe.exman.controller.gateway.ExternalGateway handleResponse(), parameters of handleResponse:
                sessionId= 12
                responseType= 9
                responseBody=7
                12/18/2012 22:19:59.108 [INFO] com.adobe.exman.controller.session.backend.BackendSession com.adobe.exman.controller.session.backend::RequestLoadExtensionSession got parameters in handleResponse:
                responseType= 9
                12/18/2012 22:19:59.108 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 0 :7
                12/18/2012 22:19:59.108 [INFO] com.adobe.exman.view.ExManApp handleNotification(), got notification: NOTIF_PROGRESS
                notification body: 7
                12/18/2012 22:19:59.108 [DEBUG] com.adobe.exman.view.ExManApp @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
                12/18/2012 22:19:59.108 [DEBUG] com.adobe.exman.view.ExManApp NOTIF_PROGRESS
                12/18/2012 22:19:59.108 [INFO] com.adobe.exman.view.ExManApp app got progress: 7
                12/18/2012 22:19:59.125 [INFO] com.adobe.exman.controller.gateway.Application ###Receive airCallBack Message12,9,8
                12/18/2012 22:19:59.125 [INFO] com.adobe.exman.controller.gateway.ExternalGateway handleResponse(), parameters of handleResponse:
                sessionId= 12
                responseType= 9
                responseBody=8
                12/18/2012 22:19:59.125 [INFO] com.adobe.exman.controller.session.backend.BackendSession com.adobe.exman.controller.session.backend::RequestLoadExtensionSession got parameters in handleResponse:
                responseType= 9
                12/18/2012 22:19:59.125 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 0 :8
                12/18/2012 22:19:59.126 [INFO] com.adobe.exman.view.ExManApp handleNotification(), got notification: NOTIF_PROGRESS
                notification body: 8
                12/18/2012 22:19:59.126 [DEBUG] com.adobe.exman.view.ExManApp @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
                12/18/2012 22:19:59.126 [DEBUG] com.adobe.exman.view.ExManApp NOTIF_PROGRESS
                12/18/2012 22:19:59.126 [INFO] com.adobe.exman.view.ExManApp app got progress: 8
                12/18/2012 22:19:59.143 [INFO] com.adobe.exman.controller.gateway.Application ###Receive airCallBack Message12,9,9
                12/18/2012 22:19:59.143 [INFO] com.adobe.exman.controller.gateway.ExternalGatewa
