2 Replies Latest reply on Dec 19, 2012 6:01 AM by bulan_
    Connect Remote Repository 5.3
    aragav123
           I am trying to connect to remote CRX repository of CQ5.3 from CQ5.5 application code. I tried using the below code as suggested in adobe documentation.
      But I am getting exception as below. Is there anything that I am missing or Is there any other way to get access to the nodes of 5.3 remote repository.
      Exception in thread "main" javax.jcr.RepositoryException: Unable to access a repository with the following settings:
          org.apache.jackrabbit.repository.uri: http://localhost:4502/crx/server
      The following RepositoryFactory classes were consulted:
          org.apache.jackrabbit.commons.JndiRepositoryFactory: declined
          org.apache.jackrabbit.rmi.repository.RmiRepositoryFactory: failed
              because of RepositoryException: Failed to read the resource at URL http://localhost:4502/crx/server
              because of StreamCorruptedException: invalid stream header: 3C68746D
      Perhaps the repository you are trying to access is not available at the moment.
                at org.apache.jackrabbit.commons.JcrUtils.getRepository(JcrUtils.java:217)
                at org.apache.jackrabbit.commons.JcrUtils.getRepository(JcrUtils.java:257)
                at com.wsgc.digitalasset.constants.TestMigration.main(TestMigration.java:17)
                          public static void main(String[] args) throws ClassCastException, MalformedURLException, RemoteException, NotBoundException, LoginException, NoSuchWorkspaceException, RepositoryException, NamingException  {
                                    System.out.println("Hello World.");
        //RMI Connection
      //                              Repository repository = JcrUtils.getRepository("rmi://localhost:4502/crx/server");
                                    Repository repository = JcrUtils.getRepository("http://localhost:4502/crx/server");
        //Workspace Login
                                    SimpleCredentials creds = new SimpleCredentials("admin", "admin".toCharArray());
                                    Session session = null;
                                    session = repository.login(creds, "crx.default");
        //List Children
                                    System.out.println("Workspace: " + session.getWorkspace().getName() + "\n");
                                    listChildren( "", session.getRootNode() );
                          private static void listChildren(String indent, Node node ) throws RepositoryException {
                                    System.out.println(indent + node.getName() );
                                    NodeIterator ni = node.getNodes();
                                    while(ni.hasNext()) {
                                              listChildren(indent+"  ", ni.nextNode());
