2 Replies Latest reply on Dec 17, 2012 10:23 AM by Jeff S GP2
    If, Then, based on layer name
    Jeff S GP2 Level 1
      Is it possible to create a script that calls an action based on a layers name?
      I have hundreds of image documents (layered psd's) that need specific images inserted at different scales.
      I can make these individual actions, but would need help with the beginning  "if then part"
      As an example:
      if a layer is called RN 100  it will call one action
      if another layer is called RN 205 it will call another action.
      if there is no recognizable layer name, it simply closes that document
      Thanks for any help
      Jeff
        • 1. Re: If, Then, based on layer name
          Ghoulfool Level 1
          This is the basis of what you want:
          It ignore the background, you need to change the script to call the actions you need. At the moment it calls "ACTION1" & "ACTION1". The script doesn't take into account groups of if  one of your layers is a variane to what you asked for ie "Rn 100" or "rn 100"
          var srcDoc = app.activeDocument;
          var numOfLayers = srcDoc.layers.length;
          // main loop starts here
          for (var i = numOfLayers -2; i >= 0  ; i--) //igore background
              srcDoc.activeLayer = srcDoc.artLayers[i];
              var temp = srcDoc.artLayers[i].name
              if (temp == "RN 100")
                  var id156 = charIDToTypeID( "Ply " );
                  var desc39 = new ActionDescriptor();
                  var id157 = charIDToTypeID( "null" );
                  var ref20 = new ActionReference();
                  var id158 = charIDToTypeID( "Actn" );
                  ref20.putName( id158, "ACTION1" ); // action 1 name
                  var id159 = charIDToTypeID( "ASet" );
                  ref20.putName( id159, "Scripts" );
                  desc39.putReference( id157, ref20 );
                  executeAction( id156, desc39, DialogModes.NO );
              else if (temp == "RN 205")
                  ref20.putName( id158, "ACTION2" ); //action 2 name
              else
                  //close without saving
                 app.activeDocument.close(SaveOptions.DONOTSAVECHANGES);
          }//end loop
          Hope this helps
          • 2. Re: If, Then, based on layer name
            Jeff S GP2 Level 1
            Wow!.. fantastic
            I can see allot of potential for this kind of script.
            Thanks allot,  I really appreciate this!
            Jeff
