2 Replies Latest reply on Dec 17, 2012 5:55 AM by Marco Lugli
    Copy page items between 2 documents with same number of pages
    Marco Lugli
      Hello all,
      I have two Indesign Documents with the same number of pages; I'd like to copy every page item from source document and paste it in place on the corresponding page on destination document.
      This is my starting point (which stops at page 1..):
      //--- BEGIN CODE ---
      var docSource = app.documents.[0];
      var docDestination = app.documents.[1];
      function copyPages(){
      for (i=0; i<docSource.pages.length; i++){
        app.activeDocument = docSource;
        var myPageSource = docSource.pages.[i];
        var myActivePageSource = app.layoutWindows[i].activePage;
        var myPageSourceItems = myActivePageSource.pageItems.everyItem().select(SelectionOptions.ADD_TO);
        app.copy();
        app.activeDocument = docDestination;
        var myPageDestination = docDestination.pages.[i];
        var myActivePageDestination = app.layoutWindows[i].activePage;
        app.pasteInPlace();
      copyPages();
      //---- END CODE ---
      Any help would be much appreciated,
      Thanks in advance
        • 1. Re: Copy page items between 2 documents with same number of pages
          Jump_Over Level 5
          There are some syntax/typo errors inside your code.
          try this:
          ___________________________________________________________________
          var docSource = app.documents.item("1stName");     // input the proper name
          var docDestination = app.documents.item("2ndName")     // input the proper name
          function copyPages ( docSource, docDestination ) {
              var myPageSourceItems = app.select(app.activeDocument.pages[i].allPageItems);
              app.copy();
              var myPageDestination = docDestination.pages[i];
              docDestination.layoutWindows[0].activePage = myPageDestination;
              docDestination.layoutWindows[0].bringToFront();
              app.pasteInPlace();
          copyPages(docSource, docDestination);
          Notice that:
          - app.documents[0] refer to a currently activated doc (so could be different while script execution)
          - var myActivePageSource = app.layoutWindows[i].activePage means... your each page should be open in a separate window;
          rgds
          • 2. Re: Copy page items between 2 documents with same number of pages
            Marco Lugli Level 1
            Hi Jump_Over,
            I tried your code and it worked perfect! Thank you for your support (..and also for your specifications).
