2 Replies Latest reply on Aug 24, 2006 12:33 PM by SoapboxParade
    TextInput/Buttons in A Masked Movie
    wavuti
      I have a form that that has some textinput components plus a submit button. The form is included as a movie clip within a masked movie. For some reason, both the input fields and button are disabled in the movie. When I remove the mask, the form works with no problems. Is there any workaround? I really need to get the form to work with the mask. Thanks in advance!
        • 1. Re: TextInput/Buttons in A Masked Movie
          wavuti Level 1
          After a bit of googling I eventually found the solution. In case anyone else encounters the same problem, here is the actionscript solution:
          import mx.styles.CSSStyleDeclaration;
          _global.styles.TextInput = new CSSStyleDeclaration();
          _global.styles.TextInput.setStyle("fontFamily", "Verdana");
          _global.styles.TextInput.setStyle("backgroundColor ", 0xffffff);
          _global.styles.TextInput.setStyle("embedFonts", true);
          Thanks anyway!
          • 2. Re: TextInput/Buttons in A Masked Movie
            SoapboxParade
            Hello,
            I'm having this exact same problem. I tried inserting the ActionScript you've suggested...I tried on the main container swf as well as the loaded swf that has the TextInput components in it, but I still can't seem to get it to work.
            Where exactly did you end up putting that AS?
            Thank you very much!
            -Tony
