0 Replies Latest reply on Dec 17, 2012 12:03 PM by joe.coyle
    How do I implement a virtual keyboard?  I will compensate for assistance.
    joe.coyle
      Administrators: I hope this is in the correct forum.  If this is not the correct forum please move it to the correct one.
      I have created a simple Adobe Air Windowed Application.  The application uses the mx:HTML control (location) to load a web page.  I have tried other means to load the web page but due to formatting issue, all other methods fail to load the page correctly.  Any solution will need to use the mx HTML controls unless there is something I am missing.  Also, I do not have access to the backend of the website.  I am only able to modify a custom style sheet to overrited the default style sheet.
      I have added a virtual keyboard to my project.  However, when I enter a text field and then select a key on the virtual keyboard, I lose focus on the text field.  These text fields are java text fields.  I think this makes a difference when setting up the fuctions to pass keyboard input.
      I understand the concept of event listeners and using a variable to store the text field id and using onfocus event to gain the id of the text field.  However, I am not a programmer by no means and this is way above my head.  I am looking for someone to spend 30 or 60 minutes adding the needed code to my project so I can use the virtual keyboard.  I would be willing to send someone a gift card to their favorite restaurant as compensation.
      I have included the 3 files that make up my project.
      Your help will be greatly appreciated.
      Best regards,
      Joe
      Main.mxml
      <s:WindowedApplication xmlns:fx="http://ns.adobe.com/mxml/2009"
                                                           xmlns:mx="library://ns.adobe.com/flex/mx"
                                                           xmlns:components="com.uibuzz.components.*"
                                                           xmlns:local="*"
                                                           xmlns:keyboard=".*"
                                                           xmlns:panel=".*"
                                                           showStatusBar="false"
                                                           alwaysInFront="true"
                                                           creationComplete="RunFunction(event)">
                <fx:Script>
                          <![CDATA[
                                    import mx.events.FlexEvent;
                                    protected function RunFunction(event:FlexEvent):void
                                              nativeWindow.x = (Capabilities.screenResolutionX - nativeWindow.width) / 2;
                                              nativeWindow.y = (Capabilities.screenResolutionY - nativeWindow.height) / 2;
                                              // Mouse.hide();
                                              //html.location = 'https://ccrcafe.prodqa.alohaonline.radiantsystems.com/Login.aspx';
                                              html.location = 'https://google.com';
                                              html.focusEnabled = true;
                </fx:Script>
                <fx:Script>
                          <![CDATA[
                                    // Virtual Keyboard
                                    import com.uibuzz.events.VirtualKeyboardEvent;
                                    protected function HandleKeyEvent(event:VirtualKeyboardEvent):void
                                              trace("Key pressed: " + event.keyLabel);
                </fx:Script>
                <mx:HTML id="html"
                          width="100%"
                          height="100%" x="0" y="0"/>
                <fx:Declarations>
                          <!-- Place non-visual elements (e.g., services, value objects) here -->
                </fx:Declarations>
      <components:VirtualKeyboard x="325" y="770" KeyClicked="HandleKeyEvent(event)"/>
      </s:WindowedApplication>
      VirtualKeyboard.mxml
      <s:Group xmlns:fx="http://ns.adobe.com/mxml/2009"
               width="610" height="215" currentState="Lowercase">
                <s:layout>
                          <s:BasicLayout/>
                </s:layout>
          <fx:Metadata>
              [Event(name="KeyClicked", type="com.uibuzz.events.VirtualKeyboardEvent")]
          </fx:Metadata>
          <fx:Script>
              <![CDATA[
                  protected function handleShiftButton(event:MouseEvent):void
                      if (this.currentState == "Lowercase")
                          this.currentState = "Uppercase";
                      else
                          this.currentState = "Lowercase";
                  protected function handleButtonClick(event:MouseEvent):void
                      var e:VirtualKeyboardEvent = new VirtualKeyboardEvent("KeyClicked");
                      e.keyLabel = event.currentTarget.label;
                      dispatchEvent(e);
          </fx:Script>
          <s:states>
              <s:State name="Lowercase"/>
              <s:State name="Uppercase"/>
          </s:states>
                <fx:Declarations>
                </fx:Declarations>
          <s:Button id="btn1" x="50" y="10" width="32" height="32" label="1"
                    click="handleButtonClick(event)"
                    label.Uppercase="!"/>
          <s:Button id="btnTilde" x="10" y="10" width="32" height="32" label="`"
                    label.Uppercase="~"/>
          <s:Button id="btn2" x="90" y="10" width="32" height="32" label="2"
                    label.Uppercase="@" fontSize.Uppercase="11"/>
          <s:Button id="btn3" x="130" y="10" width="32" height="32" label="3"
                    label.Uppercase="#"/>
          <s:Button id="btn4" x="170" y="10" width="32" height="32" label="4"
                    label.Uppercase="$"/>
          <s:Button id="btn5" x="210" y="10" width="32" height="32" label="5"
                    label.Uppercase="%"/>
          <s:Button id="btn6" x="250" y="10" width="32" height="32" label="6"
                    label.Uppercase="^"/>
          <s:Button id="btn7" x="290" y="10" width="32" height="32" label="7"
                    label.Uppercase="&amp;"/>
          <s:Button id="btn8" x="330" y="10" width="32" height="32" label="8"
                    label.Uppercase="*"/>
          <s:Button id="btn9" x="370" y="10" width="32" height="32" label="9"
                    label.Uppercase="("/>
          <s:Button id="btn0" x="410" y="10" width="32" height="32" label="0"
                    label.Uppercase=")"/>
          <s:Button id="btnMinus" x="450" y="10" width="32" height="32" label="-"
                    label.Uppercase="_"/>
          <s:Button id="btnEquals" x="490" y="10" width="32" height="32" label="="
                    label.Uppercase="+"/>
          <s:Button id="btnDelete" x="530" y="10" width="70" height="32" label="Delete" click="handleButtonClick(event)"/>
          <s:Button id="btnEnter" x="530" y="90" width="70" height="32" label="Enter" click="handleButtonClick(event)"/>
          <s:Button id="btnRightShift" x="510" y="130" width="70" height="32" label="Shift"
                    click="handleShiftButton(event)"/>
          <s:Button id="btnLeftShift" x="30" y="130" width="70" height="32" label="Shift"
          <s:Button id="btnTab" x="10" y="50" width="50" height="32" label="Tab" click="handleButtonClick(event)"/>
          <s:Button id="btnQ" x="70" y="50" width="32" height="32" label="q"
                    label.Uppercase="Q"/>
          <s:Button id="btnW" x="110" y="50" width="32" height="32" label="w"
                    label.Uppercase="W"/>
          <s:Button id="btnE" x="150" y="50" width="32" height="32" label="e"
                    label.Uppercase="E"/>
          <s:Button id="btnR" x="190" y="50" width="32" height="32" label="r"
                    label.Uppercase="R"/>
          <s:Button id="btnT" x="230" y="50" width="32" height="32" label="t"
                    label.Uppercase="T"/>
          <s:Button id="btnY" x="270" y="50" width="32" height="32" label="y"
                    label.Uppercase="Y"/>
          <s:Button id="btnU" x="310" y="50" width="32" height="32" label="u"
                    label.Uppercase="U"/>
          <s:Button id="btnI" x="350" y="50" width="32" height="32" label="i"
                    label.Uppercase="I"/>
          <s:Button id="btnO" x="390" y="50" width="32" height="32" label="o"
                    label.Uppercase="O"/>
          <s:Button id="btnP" x="430" y="50" width="32" height="32" label="p"
                    label.Uppercase="P"/>
          <s:Button id="btnLeftBracket" x="470" y="50" width="32" height="32" label="["
                    label.Uppercase="{"/>
          <s:Button id="btnRightBracket" x="510" y="50" width="32" height="32" label="]"
                    label.Uppercase="}"/>
          <s:Button id="btnBackSlash" x="550" y="50" width="32" height="32" label="\"
                    label.Uppercase="|"/>
          <s:Button id="btnA" x="90" y="90" width="32" height="32" label="a"
                    label.Uppercase="A"/>
          <s:Button id="btnS" x="130" y="90" width="32" height="32" label="s"
                    label.Uppercase="S"/>
          <s:Button id="btnD" x="170" y="90" width="32" height="32" label="d"
                    label.Uppercase="D"/>
          <s:Button id="btnF" x="210" y="90" width="32" height="32" label="f"
                    label.Uppercase="F"/>
          <s:Button id="btnG" x="250" y="90" width="32" height="32" label="g"
                    label.Uppercase="G"/>
          <s:Button id="btnH" x="290" y="90" width="32" height="32" label="h"
                    label.Uppercase="H"/>
          <s:Button id="btnJ" x="330" y="90" width="32" height="32" label="j"
                    label.Uppercase="J"/>
          <s:Button id="btnK" x="370" y="90" width="32" height="32" label="k"
                    label.Uppercase="K"/>
          <s:Button id="btnL" x="410" y="90" width="32" height="32" label="l"
                    label.Uppercase="L"/>
          <s:Button id="btnSemiColon" x="450" y="90" width="32" height="32" label=";"
                    label.Uppercase=":"/>
          <s:Button id="btnQuote" x="490" y="90" width="32" height="32" label="'"
                    label.Uppercase="&quot;"/>
          <s:Button id="btnZ" x="110" y="130" width="32" height="32" label="z"
                    label.Uppercase="Z"/>
          <s:Button id="btnX" x="150" y="130" width="32" height="32" label="x"
                    label.Uppercase="X"/>
          <s:Button id="btnC" x="190" y="130" width="32" height="32" label="c"
                    label.Uppercase="C"/>
          <s:Button id="btnV" x="230" y="130" width="32" height="32" label="v"
                    label.Uppercase="V"/>
          <s:Button id="btnB" x="270" y="130" width="32" height="32" label="b"
                    label.Uppercase="B"/>
          <s:Button id="btnSpace" x="150" y="170" width="272" height="32" label="Space" click="handleButtonClick(event)"/>
          <s:Button id="btnN" x="310" y="130" width="32" height="32" label="n"
                    label.Uppercase="N"/>
          <s:Button id="btnM" x="350" y="130" width="32" height="32" label="m"
                    label.Uppercase="M"/>
          <s:Button id="btnComma" x="390" y="130" width="32" height="32" label=","
                    label.Uppercase="&lt;"/>
          <s:Button id="btnStop" x="430" y="130" width="32" height="32" label="."
                    label.Uppercase="&gt;"/>
          <s:Button id="btnForwardSlash" x="470" y="130" width="32" height="32" label="/"
                    label.Uppercase="?"/>
      </s:Group>
      VirtualKeyboardEvents.as
      package com.uibuzz.events
          import flash.events.Event;
          public class VirtualKeyboardEvent extends Event
              public var keyLabel:String;
              public function VirtualKeyboardEvent(type:String)
                  super(type);
              override public function clone():Event
                  var eventObj:VirtualKeyboardEvent = new VirtualKeyboardEvent(type);
                  eventObj.keyLabel = this.keyLabel;
                  return eventObj;
      Message was edited by: joe.coyle  I left out some code on the Main.mxml file.
