9 Replies Latest reply on Jan 9, 2013 10:11 AM by AmintaAdobe
    How to get symbol ID in Edge
    AkariKamigishi Level 1
      I have some codes like this:
      function myFunc(name) {
           var $symbol = sym.$(name);
           //I want to do something with $symbol depending on their id, for example
           //$item.appendTo($symbol);
           //so $item will append to the corresponding symbol
      for (var i=0; i<10; i++) {
           var symbol = sym.createChildSymbol("MySymbol", sym.$(Stage"));
           myFunc(symbol.getSymbolElement().attr('id')); <--not working
      I tried .attr('id') and it seems not the id I want. Thanks for help.
      EDIT: indeed I want to get the selector inside myFunc
        • 1. Re: How to get symbol ID in Edge
          Aiesyaah
          Hey..
          I always do this to get the ID. After I run it in the browser, I right click > Inspect Element (on the symbol you want to know the ID), and it will be displayed. Hopefully it works for you.
          • 2. Re: How to get symbol ID in Edge
            You method gives the same thing as .attr('id') and it seems the the thing I want. Maybe the thing I want is called selector? Thanks anyway.
            • 3. Re: How to get symbol ID in Edge
              I think I figure out the solution:
              function myFunc($symbol) {
                   myFunc(symbol.getSymbolElement());
              • 4. Re: How to get symbol ID in Edge
                joel_pau Level 5
                How to get symbol id? sym.lookupSelector()
                • Creating a rectangle on Stage, sym.lookupSelector("Rectangle") returns "#Stage_Rectangle".
                • sym.lookupSelector("oneSymbol") returns symbol id.
                Now: for (var i=0; i<10; i++) { var symbol = sym.createChildSymbol("MySymbol", "Stage")); };
                So, ten children have been created.
                • sym.lookupSelector(symbol[0]) returns first child id.
                • sym.lookupSelector(symbol[9]) returns last child id.
                You can write:
                $( sym.lookupSelector(symbol[0]) ).hide();
                or
                $( sym.lookupSelector(symbol[9]) ).css(...)
                • 5. Re: How to get symbol ID in Edge
                  AmintaAdobe Level 1
                  Hi Joel!
                  Following your very useful hint, I tried to write down this code:
                  var symbol = sym.createChildSymbol("rect", "Stage")
                  var ID = sym.lookupSelector(symbol[0])
                  ID.hide();
                  But it doesn't work.
                  Why?
                  Thanks in advance,
                  Davide
                  • 6. Re: How to get symbol ID in Edge
                    joel_pau Level 5
                    Hello Davide,
                    So i rewrite an effective code be cause i was wrong this morning.
                    You can write:
                    or
                                var mySymbol = sym.createChildSymbol("rect", "Stage");
                                mySymbol.$("Text").html("child #"+i);
                                mySymbol.$("idText").html("rectangle ID = "+mySymbol.lookupSelector("Text"));
                                mySymbol.$("idRectangle").html("text ID = "+mySymbol.lookupSelector("Rectangle"));
                    var symbolChildren = sym.getChildSymbols();
                    symbolChildren[1].$("Rectangle").css("background-color","red");
                    symbolChildren[2].getSymbolElement().hide(5000);// ==> display:none
                    symbolChildren[5].getSymbolElement().css("visibility","hidden");//place is empty
                    console.log(symbolChildren[3].getSymbolElement().attr('id'));
                    ==> attachments.
                    • 7. Re: How to get symbol ID in Edge
                      AmintaAdobe Level 1
                      Hi Joel!!
                      Sorry for my very late feedback, but I was busy in the last weeks :-(
                      THANKS for your excellent explanation! Can you upload again the example files, because they are expired?
                      Thanks!
                      Davide
                      • 8. Re: How to get symbol ID in Edge
                        joel_pau Level 5
                        ==> attachments
                        post #6 code ==> see folder: "lookupSelector1".
                        • 9. Re: How to get symbol ID in Edge
                          AmintaAdobe Level 1
                          Thanks Joel!!! Your explanation and your files were - as usual - very very useful to learn to work in Edge with code!
                          Thanks!
                          Davide
