1. Re: bridge cs 6 and camera raw
c.pfaffenbichler Dec 17, 2012 10:58 PM (in response to Ralf Oehrlein)This is neither the Bridge nor the Camera Raw Forum.
2. Re: bridge cs 6 and camera raw
SG...Dec 17, 2012 11:22 PM (in response to Ralf Oehrlein)
Have you tried purging the directories cache? Go to Tools> Cache> Purge Cache for Folder "..."
regards,
steve
3. Re: bridge cs 6 and camera raw
Ralf Oehrlein Dec 17, 2012 11:38 PM (in response to SG...)Yes i have tried to purge the cache. No result, its the same
Now i noticed, that i cannot see older raw files too, ( Canon Eos 5D mark II) files, that i can see in bridge cs4. Also I cannot see the same pictures , that i have converted with Adobe DNG Konverter.
regards.
ralf
4. Re: bridge cs 6 and camera raw
SG...Dec 17, 2012 11:46 PM (in response to Ralf Oehrlein)
With Bridge running, can you go to Edit> Camera Raw Preferences... and confirm the build string (at the top). For ACR 7.3 it should read "Version 7.3.0.71".
If you can't get that far, check that you have a plug-in at each of these locations:
64 bit Camera Raw Plug-in Folder:
C:\Program Files\Common Files\Adobe\Plug-Ins\CS6\File Formats
32 bit Camera Raw Plug-in Folder:
C:\Program Files (x86)\Common Files\Adobe\Plug-Ins\CS6\File Formats
regards,
steve
5. Re: bridge cs 6 and camera raw
Ralf Oehrlein Dec 18, 2012 12:25 AM (in response to SG...)Hi,
i cannot choose Camera Raw Preferences., Camera Raw Preferenzes is non-active
In the folder:C:\Program Files\Common Files\Adobe\Plug-Ins\CS6\File Formats i find Camera Raw.8bi
regards
Ralf
6. Re: bridge cs 6 and camera raw
SG...Dec 18, 2012 12:57 AM (in response to Ralf Oehrlein)
Hi Ralf,
When you look at properties for that Camera Raw.8bi file, what is the modification date and the byte size?
And when you say these files can be opened is that by double clicking them in Bridge? When they are open does the top of the dialog say "Camera Raw 7.3"?
It doesn't sound like Bridge s loading the ACR plug-in to me. What is your Bridge version?
regards,
steve
7. Re: bridge cs 6 and camera raw
Ralf Oehrlein Dec 18, 2012 2:36 AM (in response to SG...)Hallo Steve
The modification date is november,the 28th 2012, the size is 23.821KB
8. Re: bridge cs 6 and camera raw
Ralf Oehrlein Dec 19, 2012 3:02 AM (in response to SG...)Hallo Steve
Camera Raw version is 7.3, when i open the raw-files by double-click.
It is curious, when i try to find out the bridge version by ckicking about bridge i get the information, " the operation could not be completed. And in german : das system kann die angegebene datei nicht finden ( means: the system can not find the special file)
If i click on the desktop-symbol bridge i get the information : Vesion 5.0.1.23 Adobe Bridge CS6, Date 9.20.2012, language:english USA.
When i trie updating Bridge by clicking Help-Update ,i get the information: Bridge is unable to check for updates.
The most likely causes for this failure are an inabitity to connectz to the internet or beeing logged in as a non- administrative user. ( but i tryd it asadministrativ user).
photoshsop CS6 is able to update, i get the information. All applications are ap to date.
Do you think, I should install photoshop again.
regards
Ralf
PS
hi steve suddenly, bridge cs6 is running!
I have done following.
I have started Minibridge and i saw my raw files as pictures not as signs, than i changed to Bridge, where i saw my pictures too. Now Bridge is able to update and i see the menues of bridge in german language, (before in english)
Thankyou for your help
Ralf
Nachricht geändert durch Ralf Oehrlein
9. Re: bridge cs 6 and camera raw
SG...Dec 19, 2012 9:52 AM (in response to Ralf Oehrlein)
Hi Ralf,
How very odd. So to confirm, you now have Bridge 5.0.23 running as wanted in German language, and it correctly thumbnails your Canon EOS 6 files? All is functioning as expected at this point?
I do hope that's the case. :-)
regards,
steve
10. Re: bridge cs 6 and camera raw
Ralf Oehrlein Dec 19, 2012 10:02 AM (in response to SG...)Hi Steve, now i have got Bridge 5.0.1.23x64 and everything is working as wanted.
Thank you and Merry Christmas from Germany
Ralf
11. Re: bridge cs 6 and camera raw
SG...Dec 19, 2012 10:48 AM (in response to Ralf Oehrlein)
Great!
Happy Holidays from California.
steve
12. Re: bridge cs 6 and camera raw
Ralf Oehrlein Jan 11, 2013 8:55 AM (in response to SG...)Hi Steve, I wish you a happy new year.
I thought my problems with bridge cs 6 wood be solved but the trouble is going on.
When I start bridge before starting photoshop I see my raw-files not as a preview. The menues are in english, not in german and it is inpossible to change the language.
When I first start Photoshop and start minibridge, than, starting bridge, I see german menues and the tumbnails of my raw files.
What can I do?
