1 Reply Latest reply on Jan 9, 2013 11:32 PM by Mahesh.w
    Implementing spinner with n-number of images using Flex 4+ Rotate3D component
    Mahesh.w
      Hi Guys,
      I have a challenge in front of me and I am here to get some help from you.
      Target : Implement an application which takes n-number of images (paths from xml file) and each image rotates 90 Degrees in parallel(4images at a time)
      Details: Lets consider 4 images to begin. We name each image as a1, b1, c1 and d1.
      app starts with image a1 and rotates 90 Degrees from 0 D
      once the rotation is over, a1 rotates 180D from 90D in parallel b1 starts rotating from 0D to 90.
      in the next rotation: a1 from 180D to 270D and b1 from 90D to 180D and c1 from 0D to 90.
      next : a1 from 270D to 360D b1 from 180D to 270D -- c1 from 90D to 180D -- d1 from 0D to 90D
      and this process loops infinitely.
      Here important and challenging  task is, none of the images should show their back, I mean rotating image in any quadrant should show face.
      If anyone know or have seen any examples anywhere, please do reply to this thread.  Quick reply will be a greate help. And if the task is not clear please update me. Will try to make it clear.
      Thank you all.
      Here is my example:
      <s:Group xmlns:fx="http://ns.adobe.com/mxml/2009"
                           xmlns:mx="library://ns.adobe.com/flex/mx" width="400" height="300"
                           creationComplete="startPlay(new EffectEvent(EffectEvent.EFFECT_END))">
                <fx:Declarations>
                          <s:Rotate3D id="rotateEffect1" target="{targetImg1}" effectEnd="startPlay(event)" />
                          <s:Rotate3D id="rotateEffect2" target="{targetImg2}" />
                          <s:Rotate3D id="rotateEffect3" target="{targetImg3}" />
                          <s:Rotate3D id="rotateEffect4" target="{targetImg4}"/>
                </fx:Declarations>
                <fx:Script>
                          <![CDATA[
                                    import flash.text.engine.EastAsianJustifier;
                                    import mx.core.IVisualElement;
                                    import mx.events.EffectEvent;
                                    import spark.effects.easing.EaseInOutBase;
                                    public var count:Number = 1;
                                    public var angle:Number = 90;
                                    public var rot1:Boolean=false;
                                    public var rot2:Boolean=false;
                                    public var rot3:Boolean=false;
                                    public var countForAngle:Number=1;
                                    public function startPlay(evt:Event):void
                                              if(count>4)
                                                        count=1
                                              rotateEffect1.angleYFrom=(rotateEffect1.angleYTo==NaN)?0:rotateEffect1.angleYTo;
                                              rotateEffect1.target = targetImg1;
                                              rotateEffect1.duration=4000;
                                              rotateEffect1.repeatCount=1;
                                              rotateEffect1.angleYTo=countForAngle*angle;
                                              rotateEffect1.autoCenterProjection = false;
                                              rotateEffect1.applyLocalProjection = true;
                                              rotateEffect1.focalLength = 360;
                                              rotateEffect1.disableLayout = true;
                                              rotateEffect1.hideFocusRing = true;
                                              rotateEffect1.angleXFrom=0;
                                              rotateEffect1.angleXTo=0;
                                              rotateEffect1.angleZFrom=0;
                                              if(count==1)
                                                        var dispObj:DisplayObject = grp.getChildByName('4');
                                                        grp.setElementIndex(grp.getElementAt(grp.getChildIndex(dispObj)), 3);
                                              rotateEffect1.play();
                                              if(count==2)
                                                        rot1=true;
                                              if(rot1)
                                                        rotateEffect2.angleYFrom=(rotateEffect2.angleYTo==NaN)?0:rotateEffect2.angleYTo;
                                                        rotateEffect2.target = targetImg2;
                                                        rotateEffect2.duration=4000;
                                                        rotateEffect2.repeatCount=1;
                                                        rotateEffect2.angleYTo=rotateEffect1.angleYTo-90;
                                                        trace(rotateEffect2.angleYTo)
                                                        rotateEffect2.angleXFrom=0;
                                                        rotateEffect2.angleXTo=0;
                                                        rotateEffect2.angleZFrom=0;
                                                        rotateEffect2.autoCenterProjection = false;
                                                        rotateEffect2.applyLocalProjection = true;
                                                        rotateEffect2.focalLength = 360;
                                                        rotateEffect2.disableLayout = true;
                                                        rotateEffect2.hideFocusRing = true;
                                                        if(count==2)
        var dispObj:DisplayObject = grp.getChildByName('3');
                                                        rotateEffect2.play();
                                              if(count==3)
                                                        rot2=true;
                                              if(rot2)
                                                        rotateEffect3.angleYFrom=(rotateEffect3.angleYTo==NaN)?0:rotateEffect3.angleYTo;;
                                                        rotateEffect3.target = targetImg3;
                                                        rotateEffect3.duration=4000;
                                                        rotateEffect3.repeatCount=1;
                                                        rotateEffect3.angleYTo=Math.abs(rotateEffect2.angleYTo-90);
                                                        rotateEffect3.angleXFrom=0;
                                                        rotateEffect3.angleXTo=0;
                                                        rotateEffect3.angleZFrom=0;
                                                        rotateEffect3.autoCenterProjection = false;
                                                        rotateEffect3.applyLocalProjection = true;
                                                        rotateEffect3.focalLength = 360;
                                                        rotateEffect3.disableLayout = true;
                                                        rotateEffect3.hideFocusRing = true;
                                                        if(count==3)
        var dispObj:DisplayObject = grp.getChildByName('2');
                                                        rotateEffect3.play();
                                              if(count==4)
                                                        rot3=true;
                                              if(rot3)
                                                        rotateEffect4.angleYFrom=(rotateEffect4.angleYTo==NaN)?0:rotateEffect4.angleYTo;;
                                                        rotateEffect4.target = targetImg4;
                                                        rotateEffect4.duration=4000;
                                                        rotateEffect4.repeatCount=1;
                                                        rotateEffect4.angleYTo=Math.abs(rotateEffect3.angleYTo-90);
                                                        rotateEffect4.angleXFrom=0;
                                                        rotateEffect4.angleXTo=0;
                                                        rotateEffect4.angleZFrom=0;
                                                        rotateEffect4.autoCenterProjection = false;
                                                        rotateEffect4.applyLocalProjection = true;
                                                        rotateEffect4.focalLength = 360;
                                                        rotateEffect4.disableLayout = true;
                                                        rotateEffect4.hideFocusRing = true;
                                                        if(count==4)
        var dispObj:DisplayObject = grp.getChildByName('1');
                                                        rotateEffect4.play();
                                              count++;
                                              countForAngle++;
                </fx:Script>
                <s:Group width="100%" height="100%">
                          <s:layout>
                                    <s:VerticalLayout horizontalAlign="center"/>
                          </s:layout>
                          <s:Button id="playButton"
                                                label="Rotate Image" />
                          <s:Panel width="75%" height="80%"
                                               horizontalCenter="0"
                                               title="Rotate3D Effect Sample">
                                              <s:BorderContainer backgroundColor="#DDDDDD" width="100%" height="100%">
                                                        <s:layout>
        <s:HorizontalLayout  paddingLeft="400" horizontalAlign="center"/>
                                                        </s:layout>
                                                        <s:Group width="100%" height="100%" id="grp">
        <s:Group id="a" name="1">
        <s:BitmapImage id="targetImg4" width="200" height="200" source="@Embed(source='assets/3.jpg')"/>
        </s:Group>
        <s:Group id="b" name="2">
        <s:BitmapImage id="targetImg3" width="200" height="200" source="@Embed(source='assets/2.jpg')"/>
        </s:Group>
        <s:Group id="c" name="3">
        <s:BitmapImage id="targetImg2" width="200" height="200" source="@Embed(source='assets/1.jpg')"/>
        </s:Group>
        <s:Group id="d" name="4">
        <s:BitmapImage id="targetImg1" width="200" height="200" source="@Embed(source='assets/4.jpg')"/>
        </s:Group>
                                                        </s:Group>
                                              </s:BorderContainer>
                                    </s:Group>
                          </s:Panel>
                </s:Group>
      </s:Group>
