1. Re: How can I put custom code into an Edge Animate page?
joel_pau Dec 18, 2012 2:19 AM (in response to alayna11)Hi Alayna,
Here are 3 demos: download files.
This could be done differenlty. For instance: using timeline labels.
2. Re: How can I put custom code into an Edge Animate page?
alayna11 Dec 18, 2012 2:35 AM (in response to joel_pau)Hi Joel,
Thanks very much for the demos. I am using a PC and it won't open the files you sent as they are made on a MAC. Any chance you could send PC versions?
Or some other instructions?
Cheers.
3. Re: How can I put custom code into an Edge Animate page?
alayna11 Dec 18, 2012 2:37 AM (in response to joel_pau)I just found the PC versions. Thank you very much. I think that has solved my problem, just testing now.
4. Re: How can I put custom code into an Edge Animate page?
alayna11 Dec 18, 2012 2:42 AM (in response to alayna11)Can you explain how you did this so I can re-create it.
Also I don't think it is exactly what I require. I want to be able to press a text link called MENU then the food menu will show up underneath the text. I want to list say 6 menus (breakfast, lunch etc) - and when a menu title is clicked the corresponding list of foods appears. I wouldn't want to have to leave a huge gap underneath each menu header.
Do you think I can use the example you have sent to make this happen?
Cheers.
5. Re: How can I put custom code into an Edge Animate page?
joel_pau Dec 18, 2012 10:18 AM (in response to alayna11)So, can you post your project file (download link)?
Your edge file contains: menu, submenu... (text boxes).
6. Re: How can I put custom code into an Edge Animate page?
alayna11 Dec 19, 2012 5:26 AM (in response to joel_pau)thanks i followed along with the file you sent me and worked out how to make text hidden or unhidden. I wanted to use some sort of slide mechanism though, so like this:
menu 1
menu 2
menu 3
when menu 1 is opened a paragraph or more of text appears and the menu 2 heading moves down underneath menu 1.
I have come up with a compromise instead - just using internal page links to take user from one part of the page to another. It's more basic but still works ok.
cheers.
